commit 839f7ad6932d95f4d5ae7267b95c574714ff3d5b upstream.
Nick Piggin reports:
> I'm getting use after frees in aio code in NFS
> [ 2703.396766] Call Trace:
> [ 2703.396858] [<ffffffff8100b057>] ? native_sched_clock+0x27/0x80
> [ 2703.396959] [<ffffffff8108509e>] ? put_lock_stats+0xe/0x40
> [ 2703.397058] [<ffffffff81088348>] ? lock_release_holdtime+0xa8/0x140
> [ 2703.397159] [<ffffffff8108a2a5>] lock_acquire+0x95/0x1b0
> [ 2703.397260] [<ffffffff811627db>] ? aio_put_req+0x2b/0x60
> [ 2703.397361] [<ffffffff81039701>] ? get_parent_ip+0x11/0x50
> [ 2703.397464] [<ffffffff81612a31>] _raw_spin_lock_irq+0x41/0x80
> [ 2703.397564] [<ffffffff811627db>] ? aio_put_req+0x2b/0x60
> [ 2703.397662] [<ffffffff811627db>] aio_put_req+0x2b/0x60
> [ 2703.397761] [<ffffffff811647fe>] do_io_submit+0x2be/0x7c0
> [ 2703.397895] [<ffffffff81164d0b>] sys_io_submit+0xb/0x10
> [ 2703.397995] [<ffffffff8100307b>] system_call_fastpath+0x16/0x1b
> Adding some tracing, it is due to nfs completing the request then
> returning something other than -EIOCBQUEUED, so aio.c
> also completes the request.
To address this, prevent the NFS direct I/O engine from completing
async iocbs when the forward path returns an error without starting
any I/O.
This fix appears to survive ^C during both "xfstest no. 208" and "fsx
-Z."
It's likely this bug has existed for a very long while, as we are seeing
very similar symptoms in OEL 5. Copying stable.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 462e635e5b73ba9a4c03913b77138cd57ce4b050 upstream.
The install_special_mapping routine (used, for example, to setup the
vdso) skips the security check before insert_vm_struct, allowing a local
attacker to bypass the mmap_min_addr security restriction by limiting
the available pages for special mappings.
bprm_mm_init() also skips the check, and although I don't think this can
be used to bypass any restrictions, I don't see any reason not to have
the security check.
$ uname -m
x86_64
$ cat /proc/sys/vm/mmap_min_addr
65536
$ cat install_special_mapping.s
section .bss
resb BSS_SIZE
section .text
global _start
_start:
mov eax, __NR_pause
int 0x80
$ nasm -D__NR_pause=29 -DBSS_SIZE=0xfffed000 -f elf -o install_special_mapping.o install_special_mapping.s
$ ld -m elf_i386 -Ttext=0x10000 -Tbss=0x11000 -o install_special_mapping install_special_mapping.o
$ ./install_special_mapping &
[1] 14303
$ cat /proc/14303/maps
0000f000-00010000 r-xp 00000000 00:00 0 [vdso]
00010000-00011000 r-xp 00001000 00:19 2453665 /home/taviso/install_special_mapping
00011000-ffffe000 rwxp 00000000 00:00 0 [stack]
It's worth noting that Red Hat are shipping with mmap_min_addr set to
4096.
Signed-off-by: Tavis Ormandy <taviso@google.com>
Acked-by: Kees Cook <kees@ubuntu.com>
Acked-by: Robert Swiecki <swiecki@google.com>
[ Changed to not drop the error code - akpm ]
Reviewed-by: James Morris <jmorris@namei.org>
commit 21ac19d484a8ffb66f64487846c8d53afef04d2b upstream.
The commit 129a84de2347002f09721cda3155ccfd19fade40 (locks: fix F_GETLK
regression (failure to find conflicts)) fixed the posix_test_lock()
function by itself, however, its usage in NFS changed by the commit
9d6a8c5c213e34c475e72b245a8eb709258e968c (locks: give posix_test_lock
same interface as ->lock) remained broken - subsequent NFS-specific
locking code received F_UNLCK instead of the user-specified lock type.
To fix the problem, fl->fl_type needs to be saved before the
posix_test_lock() call and restored if no local conflicts were reported.
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=23892
Tested-by: Alexander Morozov <amorozov@etersoft.ru>
Signed-off-by: Sergey Vlasov <vsu@altlinux.ru>
commit c1ac3ffcd0bc7e9617f62be8c7043d53ab84deac upstream.
If vfs_getattr in fill_post_wcc returns an error, we don't
set fh_post_change.
For NFSv4, this can result in set_change_info triggering a BUG_ON.
i.e. fh_post_saved being zero isn't really a bug.
So:
- instead of BUGging when fh_post_saved is zero, just clear ->atomic.
- if vfs_getattr fails in fill_post_wcc, take a copy of i_ctime anyway.
This will be used i seg_change_info, but not overly trusted.
- While we are there, remove the pointless 'if' statements in set_change_info.
There is no harm setting all the values.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 5b362ac3799ff4225c40935500f520cad4d7ed66 upstream.
After a few unsuccessful NFS mount attempts in which the client and
server cannot agree on an authentication flavor both support, the
client panics. nfs_umount() is invoked in the kernel in this case.
Turns out nfs_umount()'s UMNT RPC invocation causes the RPC client to
write off the end of the rpc_clnt's iostat array. This is because the
mount client's nrprocs field is initialized with the count of defined
procedures (two: MNT and UMNT), rather than the size of the client's
proc array (four).
The fix is to use the same initialization technique used by most other
upper layer clients in the kernel.
Introduced by commit 0b524123, which failed to update nrprocs when
support was added for UMNT in the kernel.
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=24302
BugLink: http://bugs.launchpad.net/bugs/683938
Reported-by: Stefan Bader <stefan.bader@canonical.com>
Tested-by: Stefan Bader <stefan.bader@canonical.com>
commit d9d318d39dd5cb686660504a3565aac453709ccc upstream.
If a 32bit CUSE server is run on 64bit this results in EIO being
returned to the caller.
The reason is that FUSE_IOCTL_RETRY reply was defined to use 'struct
iovec', which is different on 32bit and 64bit archs.
Work around this by looking at the size of the reply to determine
which struct was used. This is only needed if CONFIG_COMPAT is
defined.
A more permanent fix for the interface will be to use the same struct
on both 32bit and 64bit.
Reported-by: "ccmail111" <ccmail111@yahoo.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
CC: Tejun Heo <tj@kernel.org>
commit 7572777eef78ebdee1ecb7c258c0ef94d35bad16 upstream.
Verify that the total length of the iovec returned in FUSE_IOCTL_RETRY
doesn't overflow iov_length().
commit a0822c55779d9319939eac69f00bb729ea9d23da upstream.
The attribute cache for a file was not being cleared when a file is opened
with O_TRUNC.
If the filesystem's open operation truncates the file ("atomic_o_trunc"
feature flag is set) then the kernel should invalidate the cached st_mtime
and st_ctime attributes.
Also i_size should be explicitly be set to zero as it is used sometimes
without refreshing the cache.
Signed-off-by: Ken Sumrall <ksumrall@android.com>
Cc: Anfei <anfei.zhou@gmail.com>
Cc: "Anand V. Avati" <avati@gluster.com>
Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
commit cb4644cac4a2797afc847e6c92736664d4b0ea34 upstream.
If the iovec is being set up in a way that causes uaddr + PAGE_SIZE
to overflow, we could end up attempting to map a huge number of
pages. Check for this invalid input type.
Reported-by: Dan Rosenberg <drosenberg@vsecurity.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit 2e21b3f124eceb6ab5a07c8a061adce14ac94e14 upstream.
eCryptfs was passing the LOOKUP_OPEN flag through to the lower file
system, even though ecryptfs_create() doesn't support the flag. A valid
filp for the lower filesystem could be returned in the nameidata if the
lower file system's create() function supported LOOKUP_OPEN, possibly
resulting in unencrypted writes to the lower file.
However, this is only a potential problem in filesystems (FUSE, NFS,
CIFS, CEPH, 9p) that eCryptfs isn't known to support today.
https://bugs.launchpad.net/ecryptfs/+bug/641703
Reported-by: Kevin Buhr
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
commit f3f63c1c28bc861a931fac283b5bc3585efb8967 upstream.
commit e5953cbdff26f7cbae7eff30cd9b18c4e19b7594 upstream.
The arguments were transposed, we want to assign the error code to
'ret', which is being returned.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
commit 39aa3cb3e8250db9188a6f1e3fb62ffa1a717678 upstream.
So it can be used by all that need to check for that.
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
commit 9aea5a65aa7a1af9a4236dfaeb0088f1624f9919 upstream.
An execve with a very large total of argument/environment strings
can take a really long time in the execve system call. It runs
uninterruptibly to count and copy all the strings. This change
makes it abort the exec quickly if sent a SIGKILL.
Note that this is the conservative change, to interrupt only for
SIGKILL, by using fatal_signal_pending(). It would be perfectly
correct semantics to let any signal interrupt the string-copying in
execve, i.e. use signal_pending() instead of fatal_signal_pending().
We'll save that change for later, since it could have user-visible
consequences, such as having a timer set too quickly make it so that
an execve can never complete, though it always happened to work before.
Signed-off-by: Roland McGrath <roland@redhat.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
commit 7993bc1f4663c0db67bb8f0d98e6678145b387cd upstream.
This adds a preemption point during the copying of the argument and
environment strings for execve, in copy_strings(). There is already
a preemption point in the count() loop, so this doesn't add any new
points in the abstract sense.
When the total argument+environment strings are very large, the time
spent copying them can be much more than a normal user time slice.
So this change improves the interactivity of the rest of the system
when one process is doing an execve with very large arguments.
commit 1b528181b2ffa14721fb28ad1bd539fe1732c583 upstream.
The CONFIG_STACK_GROWSDOWN variant of setup_arg_pages() does not
check the size of the argument/environment area on the stack.
When it is unworkably large, shift_arg_pages() hits its BUG_ON.
This is exploitable with a very large RLIMIT_STACK limit, to
create a crash pretty easily.
Check that the initial stack is not too large to make it possible
to map in any executable. We're not checking that the actual
executable (or intepreter, for binfmt_elf) will fit. So those
mappings might clobber part of the initial stack mapping. But
that is just userland lossage that userland made happen, not a
kernel problem.
commit 1fc8a117865b54590acd773a55fbac9221b018f0 upstream.
ocfs2 fast symlinks are NUL terminated strings stored inline in the
inode data area. However, disk corruption or a local attacker could, in
theory, remove that NUL. Because we're using strlen() (my fault,
introduced in a731d1 when removing vfs_follow_link()), we could walk off
the end of that string.
Signed-off-by: Joel Becker <joel.becker@oracle.com>
commit ff311008ab8d2f2cfdbbefd407d1b05acc8164b2 upstream.
During the large inotify rewrite to fsnotify I completely dropped support
for IN_ONESHOT. Reimplement that support.
Signed-off-by: Eric Paris <eparis@redhat.com>
commit cffab6bc5511cd6f67a60bf16b62de4267b68c4c upstream.
Partition boundary calculation fails for DASD FBA disks under the
following conditions:
- disk is formatted with CMS FORMAT with a blocksize of more than
512 bytes
- all of the disk is reserved to a single CMS file using CMS RESERVE
- the disk is accessed using the DIAG mode of the DASD driver
Under these circumstances, the partition detection code tries to
read the CMS label block containing partition-relevant information
from logical block offset 1, while it is in fact located at physical
block offset 1.
Fix this problem by using the correct CMS label block location
depending on the device type as determined by the DASD SENSE ID
information.
Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
[bwh: Adjust for 2.6.32]
commit a122eb2fdfd78b58c6dd992d6f4b1aaef667eef9 upstream.
The XFS_IOC_FSGETXATTR ioctl allows unprivileged users to read 12
bytes of uninitialized stack memory, because the fsxattr struct
declared on the stack in xfs_ioc_fsgetxattr() does not alter (or zero)
the 12-byte fsx_pad member before copying it back to the user. This
patch takes care of it.
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
Cc: dann frazier <dannf@debian.org>
commit 84a8dce2710cc425089a2b92acc354d4fbb5788d upstream.
A few functions were still modifying i_flags in a racy manner.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 611da04f7a31b2208e838be55a42c7a1310ae321 upstream.
Since the .31 or so notify rewrite inotify has not sent events about
inodes which are unmounted. This patch restores those events.
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 75e1c70fc31490ef8a373ea2a4bea2524099b478 upstream.
Tavis Ormandy pointed out that do_io_submit does not do proper bounds
checking on the passed-in iocb array:
if (unlikely(nr < 0))
return -EINVAL;
if (unlikely(!access_ok(VERIFY_READ, iocbpp, (nr*sizeof(iocbpp)))))
return -EFAULT; ^^^^^^^^^^^^^^^^^^
The attached patch checks for overflow, and if it is detected, the
number of iocbs submitted is scaled down to a number that will fit in
the long. This is an ok thing to do, as sys_io_submit is documented as
returning the number of iocbs submitted, so callers should handle a
return value of less than the 'nr' argument passed in.
Reported-by: Tavis Ormandy <taviso@cmpxchg8b.com>
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
commit 371d217ee1ff8b418b8f73fb2a34990f951ec2d4 upstream.
These devices don't do any writeback but their device inodes still can get
dirty so mark bdi appropriately so that bdi code does the right thing and files
inodes to lists of bdi carrying the device inodes.
commit b20d37ca9561711c6a3c4b859c2855f49565e061 upstream.
Reported-by: Ben Greear <greearb@candelatech.com>
commit ee3aebdd8f5f8eac41c25c80ceee3d728f920f3b upstream.
Commit 74641f584da ("alpha: binfmt_aout fix") (May 2009) introduced a
regression - binfmt_misc is now consulted after binfmt_elf, which will
unfortunately break ia32el. ia32 ELF binaries on ia64 used to be matched
using binfmt_misc and executed using wrapper. As 32bit binaries are now
matched by binfmt_elf before bindmt_misc kicks in, the wrapper is ignored.
The fix increases precedence of binfmt_misc to the original state.
Signed-off-by: Jan Sembera <jsembera@suse.cz>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Richard Henderson <rth@twiddle.net>
commit 57f9bdac2510cd7fda58e4a111d250861eb1ebeb upstream.
d_path() returns an ERR_PTR and it doesn't return NULL.
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
commit f5ce5a08a40f2086435858ddc80cb40394b082eb upstream.
For local mounts, ocfs2_read_locked_inode() calls ocfs2_read_blocks_sync() to
read the inode off the disk. The latter first checks to see if that block is
cached in the journal, and, if so, returns that block. That is ok.
But ocfs2_read_locked_inode() goes wrong when it tries to validate the checksum
of such blocks. Blocks that are cached in the journal may not have had their
checksum computed as yet. We should not validate the checksums of such blocks.
Fixes ossbz#1282
http://oss.oracle.com/bugzilla/show_bug.cgi?id=1282
Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com>
Singed-off-by: Tao Ma <tao.ma@oracle.com>
commit 595afaf9e6ee1b48e13ec4b8bcc8c7dee888161a upstream.
David Bartly reported that fuse can hang in fuse_get_req_nofail() when
the connection to the filesystem server is no longer active.
If bg_queue is not empty then flush_bg_queue() called from
request_end() can put more requests on to the pending queue. If this
happens while ending requests on the processing queue then those
background requests will be queued to the pending list and never
ended.
Another problem is that fuse_dev_release() didn't wake up processes
sleeping on blocked_waitq.
Solve this by:
a) flushing the background queue before calling end_requests() on the
pending and processing queues
b) setting blocked = 0 and waking up processes waiting on
blocked_waitq()
Thanks to David for an excellent bug report.
Reported-by: David Bartley <andareed@gmail.com>
commit 731eb1a03a8445cde2cb23ecfb3580c6fa7bb690 upstream.
There are duplicate macro definitions of in_range() in mballoc.h and
balloc.c. This consolidates these two definitions into ext4.h, and
changes extents.c to use in_range() as well.
Cc: Andreas Dilger <adilger@sun.com>
commit 9b00c64318cc337846a7a08a5678f5f19aeff188 upstream.
Running "cat /proc/mounts" fails to display the "lookupcache" option.
This oversight cost me a bunch of wasted time recently.
The following simple patch fixes it.
Signed-off-by: Patrick LoPresti <lopresti@gmail.com>
commit 845b6cf34150100deb5f58c8a37a372b111f2918 upstream.
Thanks a lot for all the review and comments so far;) I'd like to send
the improved (V4) version of this patch.
This patch fixes a deadlock in OCFS2 ACL. We found this bug in OCFS2
and Samba integration using scenario, the symptom is several smbd
processes will be hung under heavy workload. Finally we found out it
is the nested PR lock calling that leads to this deadlock:
node1 node2
gr PR
V
PR(EX)---> BAST:OCFS2_LOCK_BLOCKED
V
rq PR
V
wait=1
After requesting the 2nd PR lock, the process "smbd" went into D
state. It can only be woken up when the 1st PR lock's RO holder equals
zero. There should be an ocfs2_inode_unlock in the calling path later
on, which can decrement the RO holder. But since it has been in
uninterruptible sleep, the unlock function has no chance to be called.
The related stack trace is:
smbd D ffff8800013d0600 0 9522 5608 0x00000000
ffff88002ca7fb18 0000000000000282 ffff88002f964500 ffff88002ca7fa98
ffff8800013d0600 ffff88002ca7fae0 ffff88002f964340 ffff88002f964340
ffff88002ca7ffd8 ffff88002ca7ffd8 ffff88002f964340 ffff88002f964340
Call Trace:
[<ffffffff80350425>] schedule_timeout+0x175/0x210
[<ffffffff8034f580>] wait_for_common+0xf0/0x210
[<ffffffffa03e12b9>] __ocfs2_cluster_lock+0x3b9/0xa90 [ocfs2]
[<ffffffffa03e7665>] ocfs2_inode_lock_full_nested+0x255/0xdb0 [ocfs2]
[<ffffffffa0446019>] ocfs2_get_acl+0x69/0x120 [ocfs2]
[<ffffffffa0446368>] ocfs2_check_acl+0x28/0x80 [ocfs2]
[<ffffffff800e3507>] acl_permission_check+0x57/0xb0
[<ffffffff800e357d>] generic_permission+0x1d/0xc0
[<ffffffffa03eecea>] ocfs2_permission+0x10a/0x1d0 [ocfs2]
[<ffffffff800e3f65>] inode_permission+0x45/0x100
[<ffffffff800d86b3>] sys_chdir+0x53/0x90
[<ffffffff80007458>] system_call_fastpath+0x16/0x1b
[<00007f34a4ef6927>] 0x7f34a4ef6927
For details, please see:
https://bugzilla.novell.com/show_bug.cgi?id=614332 and
http://oss.oracle.com/bugzilla/show_bug.cgi?id=1278
Signed-off-by: Jiaju Zhang <jjzhang@suse.de>
Acked-by: Mark Fasheh <mfasheh@suse.com>
commit b11f1f1ab73fd358b1b734a9427744802202ba68 upstream.
When we need to take both dlm_domain_lock and dlm->spinlock, we should take
them in order of: dlm_domain_lock then dlm->spinlock.
There is pathes disobey this order. That is calling dlm_lockres_put() with
dlm->spinlock held in dlm_run_purge_list. dlm_lockres_put() calls dlm_put() at
the ref and dlm_put() locks on dlm_domain_lock.
Fix:
Don't grab/put the dlm when the initialising/releasing lockres.
That grab is not required because we don't call dlm_unregister_domain()
based on refcount.
Signed-off-by: Wengang Wang <wen.gang.wang@oracle.com>
commit a524812b7eaa7783d7811198921100f079034e61 upstream.
In the following situation, there remains an incorrect bit in refmap on the
recovery master. Finally the recovery master will fail at purging the lockres
due to the incorrect bit in refmap.
1) node A has no interest on lockres A any longer, so it is purging it.
2) the owner of lockres A is node B, so node A is sending de-ref message
to node B.
3) at this time, node B crashed. node C becomes the recovery master. it recovers
lockres A(because the master is the dead node B).
4) node A migrated lockres A to node C with a refbit there.
5) node A failed to send de-ref message to node B because it crashed. The failure
is ignored. no other action is done for lockres A any more.
For mormal, re-send the deref message to it to recovery master can fix it. Well,
ignoring the failure of deref to the original master and not recovering the lockres
to recovery master has the same effect. And the later is simpler.
Acked-by: Srinivas Eeda <srinivas.eeda@oracle.com>
commit 8a2e70c40ff58f82dde67770e6623ca45f0cb0c8 upstream.
The refcount record calculation in ocfs2_calc_refcount_meta_credits
is too optimistic that we can always allocate contiguous clusters
and handle an already existed refcount rec as a whole. Actually
because of file system fragmentation, we may have the chance to split
a refcount record into 3 parts during the transaction. So consider
the worst case in record calculation.
Signed-off-by: Tao Ma <tao.ma@oracle.com>
commit 7beaf243787f85a2ef9213ccf13ab4a243283fde upstream.
This patch fixes two problems in dlm_run_purgelist
1. If a lockres is found to be in use, dlm_run_purgelist keeps trying to purge
the same lockres instead of trying the next lockres.
2. When a lockres is found unused, dlm_run_purgelist releases lockres spinlock
before setting DLM_LOCK_RES_DROPPING_REF and calls dlm_purge_lockres.
spinlock is reacquired but in this window lockres can get reused. This leads
to BUG.
This patch modifies dlm_run_purgelist to skip lockres if it's in use and purge
next lockres. It also sets DLM_LOCK_RES_DROPPING_REF before releasing the
lockres spinlock protecting it from getting reused.
Signed-off-by: Srinivas Eeda <srinivas.eeda@oracle.com>
Acked-by: Sunil Mushran <sunil.mushran@oracle.com>
commit 6d98c3ccb52f692f1a60339dde7c700686a5568b upstream.
When we have to take both dlm->master_lock and lockres->spinlock,
take them in order
lockres->spinlock and then dlm->master_lock.
The patch fixes a violation of the rule.
We can simply move taking dlm->master_lock to where we have dropped res->spinlock
since when we access res->state and free mle memory we don't need master_lock's
protection.
commit 6eda3dd33f8a0ce58ee56a11351758643a698db4 upstream.
Setting the acl while creating a new inode depends on
the error codes of posix_acl_create_masq. This patch fix
a issue of overwriting the error codes of it.
Reported-by: Pawel Zawora <pzawora@gmail.com>
Signed-off-by: Tiger Yang <tiger.yang@oracle.com>
commit d7824370e26325c881b665350ce64fb0a4fde24a upstream.
This commit makes the stack guard page somewhat less visible to user
space. It does this by:
- not showing the guard page in /proc/<pid>/maps
It looks like lvm-tools will actually read /proc/self/maps to figure
out where all its mappings are, and effectively do a specialized
"mlockall()" in user space. By not showing the guard page as part of
the mapping (by just adding PAGE_SIZE to the start for grows-up
pages), lvm-tools ends up not being aware of it.
- by also teaching the _real_ mlock() functionality not to try to lock
the guard page.
That would just expand the mapping down to create a new guard page,
so there really is no point in trying to lock it in place.
It would perhaps be nice to show the guard page specially in
/proc/<pid>/maps (or at least mark grow-down segments some way), but
let's not open ourselves up to more breakage by user space from programs
that depends on the exact deails of the 'maps' file.
Special thanks to Henrique de Moraes Holschuh for diving into lvm-tools
source code to see what was going on with the whole new warning.
Reported-and-tested-by: François Valenduc <francois.valenduc@tvcablenet.be
Reported-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
commit ee860b6a650360c91f5d5f9a94262aad9be90015 upstream.
ocfs2_lock() will skip locks on file which has mode set to 02666. This
is a problem in cases where the mode of the file is changed after a
process has obtained a lock on the file.
ocfs2_lock() should skip the check for mandatory locks when unlocking a
file.
Signed-off-by: Sachin Prabhu <sprabhu@redhat.com>
Signed-off-by: Neil Brown <neilb@suse.de>
commit 57b09bb5e492c37c1e4273fe4e435ffd1d2ddbe0 upstream.
We have to set MS_POSIXACL on remount as well. Otherwise VFS
would not know we started supporting ACLs after remount and
thus ACLs would not work.
Signed-off-by: Mark Fasheh <mfasheh@suse.com>
commit 38a04e432768ec0b016f3c687b4de31ac111ae59 upstream.
ocfs2 refcount tree is stored as an extent tree while
the leaf ocfs2_refcount_rec points to a refcount block.
The following step can trip a kernel panic.
mkfs.ocfs2 -b 512 -C 1M --fs-features=refcount $DEVICE
mount -t ocfs2 $DEVICE $MNT_DIR
FILE_NAME=$RANDOM
FILE_NAME_1=$RANDOM
FILE_REF="${FILE_NAME}_ref"
FILE_REF_1="${FILE_NAME}_ref_1"
for((i=0;i<305;i++))
do
# /mnt/1048576 is a file with 1048576 sizes.
cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME
cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME_1
done
for((i=0;i<3;i++))
do
done
for((i=0;i<2;i++))
do
done
for((i=0;i<11;i++))
do
done
reflink $MNT_DIR/$FILE_NAME $MNT_DIR/$FILE_REF
# write_f is a program which will write some bytes to a file at offset.
# write_f -f file_name -l offset -w write_bytes.
./write_f -f $MNT_DIR/$FILE_REF -l $[310*1048576] -w 4096
./write_f -f $MNT_DIR/$FILE_REF -l $[306*1048576] -w 4096
./write_f -f $MNT_DIR/$FILE_REF -l $[311*1048576] -w 4096
./write_f -f $MNT_DIR/$FILE_NAME -l $[310*1048576] -w 4096
./write_f -f $MNT_DIR/$FILE_NAME -l $[311*1048576] -w 4096
reflink $MNT_DIR/$FILE_NAME $MNT_DIR/$FILE_REF_1
#kernel panic here.
The reason is that if the ocfs2_extent_rec is the last record
in a leaf extent block, the old solution fails to find the
suitable end cpos. So this patch try to walk through the b-tree,
find the next sub root and get the c_pos the next sub-tree starts
from.
btw, I have runned tristan's test case against the patched kernel
for several days and this type of kernel panic never happens again.
commit cf6620acc0f6fac57968aafef79ab372bdcf6157 upstream.
When the lock master processes a successful operation (request,
convert, cancel, or unlock), it will process the effects of the
change before sending the reply for the operation. The "effects"
of the operation are:
- blocking callbacks (basts) for any newly granted locks
- waiting or converting locks that can now be granted
The cast is queued on the local node when the reply from the lock
master is received. This means that a lock holder can receive a
bast for a lock mode that is doesn't yet know has been granted.
Signed-off-by: David Teigland <teigland@redhat.com>
commit 7fe2b3190b8b299409f13cf3a6f85c2bd371f8bb upstream.
When both blocking and completion callbacks are queued for lock,
the dlm would always deliver the completion callback (cast) first.
In some cases the blocking callback (bast) is queued before the
cast, though, and should be delivered first. This patch keeps
track of the order in which they were queued and delivers them
in that order.
This patch also keeps track of the granted mode in the last cast
and eliminates the following bast if the bast mode is compatible
with the preceding cast mode. This happens when a remotely mastered
lock is demoted, e.g. EX->NL, in which case the local node queues
a cast immediately after sending the demote message. In this way
a cast can be queued for a mode, e.g. NL, that makes an in-transit
bast extraneous.
commit 573c24c4af6664ffcd9aa7ba617a35fde2b95534 upstream.
Replace all GFP_KERNEL and ls_allocation with GFP_NOFS.
ls_allocation would be GFP_KERNEL for userland lockspaces
and GFP_NOFS for file system lockspaces.
It was discovered that any lockspaces on the system can
affect all others by triggering memory reclaim in the
file system which could in turn call back into the dlm
to acquire locks, deadlocking dlm threads that were
shared by all lockspaces, like dlm_recv.
commit 6cb4aff0a77cc0e6bae9475d62205319e3ebbf3f upstream.
Commit 57fe60df ("reiserfs: add atomic addition of selinux attributes
during inode creation") contains a bug that will cause it to oops when
mounting a file system that didn't previously contain extended attributes
on a system using security.* xattrs.
The issue is that while creating the privroot during mount
reiserfs_security_init calls reiserfs_xattr_jcreate_nblocks which
dereferences the xattr root. The xattr root doesn't exist, so we get an
oops.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=15309
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit 3f8b5ee33293d43ca360771b535dfae8c57259dc upstream.
The reiserfs journal behaves inconsistently when determining whether to
allow a mount of a read-only device.
This is due to the use of the continue_replay variable to short circuit
the journal scanning. If it's set, it's assumed that there are
transactions to replay, but there may not be. If it's unset, it's assumed
that there aren't any, and that may not be the case either.
I've observed two failure cases:
1) Where a clean file system on a read-only device refuses to mount
2) Where a clean file system on a read-only device passes the
optimization and then tries writing the journal header to update
the latest mount id.
The former is easily observable by using a freshly created file system on
a read-only loopback device.
This patch moves the check into journal_read_transaction, where it can
bail out before it's about to replay a transaction. That way it can go
through and skip transactions where appropriate, yet still refuse to mount
a file system with outstanding transactions.
commit 15121c18a22ae483279f76dc9e554334b800d0f7 upstream.
We have 2 mount options, "barrier" and "auto_da_alloc" which may or
may not take a 1/0 argument. This causes the ext4 superblock mount
code to subtract uninitialized pointers and pass the result to
kmalloc, which results in very noisy failures.
Per Ted's suggestion, initialize the args struct so that
we know whether match_token() found an argument for the
option, and skip match_int() if not.
Also, return error (0) from parse_options if we thought
we found an argument, but match_int() Fails.
Reported-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Acked-by: Jeff Mahoney <jeffm@suse.com>
commit 1f5a81e41f8b1a782c68d3843e9ec1bfaadf7d72 upstream.
Dan Roseberg has reported a problem with the MOVE_EXT ioctl. If the
donor file is an append-only file, we should not allow the operation
to proceed, lest we end up overwriting the contents of an append-only
file.
Cc: Dan Rosenberg <dan.j.rosenberg@gmail.com>
commit 0cf55e1ec08bb5a22e068309e2d8ba1180ab4239 upstream.
This is a real fix for problem of utime/stime values decreasing
described in the thread:
http://lkml.org/lkml/2009/11/3/522
Now cputime is accounted in the following way:
- {u,s}time in task_struct are increased every time when the thread
is interrupted by a tick (timer interrupt).
- When a thread exits, its {u,s}time are added to signal->{u,s}time,
after adjusted by task_times().
- When all threads in a thread_group exits, accumulated {u,s}time
(and also c{u,s}time) in signal struct are added to c{u,s}time
in signal struct of the group's parent.
So {u,s}time in task struct are "raw" tick count, while
{u,s}time and c{u,s}time in signal struct are "adjusted" values.
And accounted values are used by:
- task_times(), to get cputime of a thread:
This function returns adjusted values that originates from raw
{u,s}time and scaled by sum_exec_runtime that accounted by CFS.
- thread_group_cputime(), to get cputime of a thread group:
This function returns sum of all {u,s}time of living threads in
the group, plus {u,s}time in the signal struct that is sum of
adjusted cputimes of all exited threads belonged to the group.
The problem is the return value of thread_group_cputime(),
because it is mixed sum of "raw" value and "adjusted" value:
group's {u,s}time = foreach(thread){{u,s}time} + exited({u,s}time)
This misbehavior can break {u,s}time monotonicity.
Assume that if there is a thread that have raw values greater
than adjusted values (e.g. interrupted by 1000Hz ticks 50 times
but only runs 45ms) and if it exits, cputime will decrease (e.g.
-5ms).
To fix this, we could do:
group's {u,s}time = foreach(t){task_times(t)} + exited({u,s}time)
But task_times() contains hard divisions, so applying it for
every thread should be avoided.
This patch fixes the above problem in the following way:
- Modify thread's exit (= __exit_signal()) not to use task_times().
It means {u,s}time in signal struct accumulates raw values instead
of adjusted values. As the result it makes thread_group_cputime()
to return pure sum of "raw" values.
- Introduce a new function thread_group_times(*task, *utime, *stime)
that converts "raw" values of thread_group_cputime() to "adjusted"
values, in same calculation procedure as task_times().
- Modify group's exit (= wait_task_zombie()) to use this introduced
thread_group_times(). It make c{u,s}time in signal struct to
have adjusted values like before this patch.
- Replace some thread_group_cputime() by thread_group_times().
This replacements are only applied where conveys the "adjusted"
cputime to users, and where already uses task_times() near by it.
(i.e. sys_times(), getrusage(), and /proc/<PID>/stat.)
This patch have a positive side effect:
- Before this patch, if a group contains many short-life threads
(e.g. runs 0.9ms and not interrupted by ticks), the group's
cputime could be invisible since thread's cputime was accumulated
after adjusted: imagine adjustment function as adj(ticks, runtime),
{adj(0, 0.9) + adj(0, 0.9) + ....} = {0 + 0 + ....} = 0.
After this patch it will not happen because the adjustment is
applied after accumulated.
v2:
- remove if()s, put new variables into signal_struct.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Spencer Candland <spencer@bluehost.com>
Cc: Americo Wang <xiyou.wangcong@gmail.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
LKML-Reference: <4B162517.8040909@jp.fujitsu.com>
