path: root/fs
2013-02-01Merge tag 'nfs-for-3.8-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: - Error reporting in nfs_xdev_mount incorrectly maps all errors to ENOMEM - Fix an NFSv4 refcounting issue - Fix a mount failure when the server reboots during NFSv4 trunking discovery - NFSv4.1 mounts may need to run the lease recovery thread. - Don't silently fail setattr() requests on mountpoints - Fix a SUNRPC socket/transport livelock and priority queue issue - We must handle NFS4ERR_DELAY when resetting the NFSv4.1 session. * tag 'nfs-for-3.8-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFSv4.1: Handle NFS4ERR_DELAY when resetting the NFSv4.1 session SUNRPC: When changing the queue priority, ensure that we change the owner NFS: Don't silently fail setattr() requests on mountpoints NFSv4.1: Ensure that nfs41_walk_client_list() does start lease recovery NFSv4: Fix NFSv4 trunking discovery NFSv4: Fix NFSv4 reference counting for trunked sessions NFS: Fix error reporting in nfs_xdev_mount
2013-01-30NFSv4.1: Handle NFS4ERR_DELAY when resetting the NFSv4.1 sessionTrond Myklebust
NFS4ERR_DELAY is a legal reply when we call DESTROY_SESSION. It usually means that the server is busy handling an unfinished RPC request. Just sleep for a second and then retry. We also need to be able to handle the NFS4ERR_BACK_CHAN_BUSY return value. If the NFS server has outstanding callbacks, we just want to similarly sleep & retry. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@vger.kernel.org
2013-01-30NFS: Don't silently fail setattr() requests on mountpointsTrond Myklebust
Ensure that any setattr and getattr requests for junctions and/or mountpoints are sent to the server. Ever since commit 0ec26fd0698 (vfs: automount should ignore LOOKUP_FOLLOW), we have silently dropped any setattr requests to a server-side mountpoint. For referrals, we have silently dropped both getattr and setattr requests. This patch restores the original behaviour for setattr on mountpoints, and tries to do the same for referrals, provided that we have a filehandle... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@vger.kernel.org
2013-01-30Merge tag 'for-linus-v3.8-rc6' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull xfs bugfixes from Ben Myers: "Here are fixes for returning EFSCORRUPTED on probe of a non-xfs filesystem, the stack switch in xfs_bmapi_allocate, a crash in _xfs_buf_find, speculative preallocation as the filesystem nears ENOSPC, an unmount hang, a race with AIO, and a regression with xfs_fsr: - fix return value when filesystem probe finds no XFS magic, a regression introduced in 9802182. - fix stack switch in __xfs_bmapi_allocate by moving the check for stack switch up into xfs_bmapi_write. - fix oops in _xfs_buf_find by validating that the requested block is within the filesystem bounds. - limit speculative preallocation near ENOSPC. - fix an unmount hang in xfs_wait_buftarg by freeing the xfs_buf_log_item in xfs_buf_item_unlock. - fix a possible use after free with AIO. - fix xfs_swap_extents after removal of xfs_flushinval_pages, a regression introduced in commit fb59581404a." * tag 'for-linus-v3.8-rc6' of git://oss.sgi.com/xfs/xfs: xfs: Fix xfs_swap_extents() after removal of xfs_flushinval_pages() xfs: Fix possible use-after-free with AIO xfs: fix shutdown hang on invalid inode during create xfs: limit speculative prealloc near ENOSPC thresholds xfs: fix _xfs_buf_find oops on blocks beyond the filesystem end xfs: pull up stack_switch check into xfs_bmapi_write xfs: Do not return EFSCORRUPTED when filesystem probe finds no XFS magic
2013-01-28xfs: Fix xfs_swap_extents() after removal of xfs_flushinval_pages()Torsten Kaiser
Commit fb59581404ab7ec5075299065c22cb211a9262a9 removed xfs_flushinval_pages() and changed its callers to use filemap_write_and_wait() and truncate_pagecache_range() directly. But in xfs_swap_extents() this change accidental switched the argument for 'tip' to 'ip'. This patch switches it back to 'tip' Signed-off-by: Torsten Kaiser <just.for.lkml@googlemail.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-01-28xfs: Fix possible use-after-free with AIOJan Kara
Running AIO is pinning inode in memory using file reference. Once AIO is completed using aio_complete(), file reference is put and inode can be freed from memory. So we have to be sure that calling aio_complete() is the last thing we do with the inode. CC: xfs@oss.sgi.com CC: Ben Myers <bpm@sgi.com> CC: stable@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-01-28xfs: fix shutdown hang on invalid inode during createDave Chinner
When the new inode verify in xfs_iread() fails, the create transaction is aborted and a shutdown occurs. The subsequent unmount then hangs in xfs_wait_buftarg() on a buffer that has an elevated hold count. Debug showed that it was an AGI buffer getting stuck: [ 22.576147] XFS (vdb): buffer 0x2/0x1, hold 0x2 stuck [ 22.976213] XFS (vdb): buffer 0x2/0x1, hold 0x2 stuck [ 23.376206] XFS (vdb): buffer 0x2/0x1, hold 0x2 stuck [ 23.776325] XFS (vdb): buffer 0x2/0x1, hold 0x2 stuck The trace of this buffer leading up to the shutdown (trimmed for brevity) looks like: xfs_buf_init: bno 0x2 nblks 0x1 hold 1 caller xfs_buf_get_map xfs_buf_get: bno 0x2 len 0x200 hold 1 caller xfs_buf_read_map xfs_buf_read: bno 0x2 len 0x200 hold 1 caller xfs_trans_read_buf_map xfs_buf_iorequest: bno 0x2 nblks 0x1 hold 1 caller _xfs_buf_read xfs_buf_hold: bno 0x2 nblks 0x1 hold 1 caller xfs_buf_iorequest xfs_buf_rele: bno 0x2 nblks 0x1 hold 2 caller xfs_buf_iorequest xfs_buf_iowait: bno 0x2 nblks 0x1 hold 1 caller _xfs_buf_read xfs_buf_ioerror: bno 0x2 len 0x200 hold 1 caller xfs_buf_bio_end_io xfs_buf_iodone: bno 0x2 nblks 0x1 hold 1 caller _xfs_buf_ioend xfs_buf_iowait_done: bno 0x2 nblks 0x1 hold 1 caller _xfs_buf_read xfs_buf_hold: bno 0x2 nblks 0x1 hold 1 caller xfs_buf_item_init xfs_trans_read_buf: bno 0x2 len 0x200 hold 2 recur 0 refcount 1 xfs_trans_brelse: bno 0x2 len 0x200 hold 2 recur 0 refcount 1 xfs_buf_item_relse: bno 0x2 nblks 0x1 hold 2 caller xfs_trans_brelse xfs_buf_rele: bno 0x2 nblks 0x1 hold 2 caller xfs_buf_item_relse xfs_buf_unlock: bno 0x2 nblks 0x1 hold 1 caller xfs_trans_brelse xfs_buf_rele: bno 0x2 nblks 0x1 hold 1 caller xfs_trans_brelse xfs_buf_trylock: bno 0x2 nblks 0x1 hold 2 caller _xfs_buf_find xfs_buf_find: bno 0x2 len 0x200 hold 2 caller xfs_buf_get_map xfs_buf_get: bno 0x2 len 0x200 hold 2 caller xfs_buf_read_map xfs_buf_read: bno 0x2 len 0x200 hold 2 caller xfs_trans_read_buf_map xfs_buf_hold: bno 0x2 nblks 0x1 hold 2 caller xfs_buf_item_init xfs_trans_read_buf: bno 0x2 len 0x200 hold 3 recur 0 refcount 1 xfs_trans_log_buf: bno 0x2 len 0x200 hold 3 recur 0 refcount 1 xfs_buf_item_unlock: bno 0x2 len 0x200 hold 3 flags DIRTY liflags ABORTED xfs_buf_unlock: bno 0x2 nblks 0x1 hold 3 caller xfs_buf_item_unlock xfs_buf_rele: bno 0x2 nblks 0x1 hold 3 caller xfs_buf_item_unlock And that is the AGI buffer from cold cache read into memory to transaction abort. You can see at transaction abort the bli is dirty and only has a single reference. The item is not pinned, and it's not in the AIL. Hence the only reference to it is this transaction. The problem is that the xfs_buf_item_unlock() call is dropping the last reference to the xfs_buf_log_item attached to the buffer (which holds a reference to the buffer), but it is not freeing the xfs_buf_log_item. Hence nothing will ever release the buffer, and the unmount hangs waiting for this reference to go away. The fix is simple - xfs_buf_item_unlock needs to detect the last reference going away in this case and free the xfs_buf_log_item to release the reference it holds on the buffer. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-01-28xfs: limit speculative prealloc near ENOSPC thresholdsDave Chinner
There is a window on small filesytsems where specualtive preallocation can be larger than that ENOSPC throttling thresholds, resulting in specualtive preallocation trying to reserve more space than there is space available. This causes immediate ENOSPC to be triggered, prealloc to be turned off and flushing to occur. One the next write (i.e. next 4k page), we do exactly the same thing, and so effective drive into synchronous 4k writes by triggering ENOSPC flushing on every page while in the window between the prealloc size and the ENOSPC prealloc throttle threshold. Fix this by checking to see if the prealloc size would consume all free space, and throttle it appropriately to avoid premature ENOSPC... Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-01-28xfs: fix _xfs_buf_find oops on blocks beyond the filesystem endDave Chinner
When _xfs_buf_find is passed an out of range address, it will fail to find a relevant struct xfs_perag and oops with a null dereference. This can happen when trying to walk a filesystem with a metadata inode that has a partially corrupted extent map (i.e. the block number returned is corrupt, but is otherwise intact) and we try to read from the corrupted block address. In this case, just fail the lookup. If it is readahead being issued, it will simply not be done, but if it is real read that fails we will get an error being reported. Ideally this case should result in an EFSCORRUPTED error being reported, but we cannot return an error through xfs_buf_read() or xfs_buf_get() so this lookup failure may result in ENOMEM or EIO errors being reported instead. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-01-28xfs: pull up stack_switch check into xfs_bmapi_writeBrian Foster
The stack_switch check currently occurs in __xfs_bmapi_allocate, which means the stack switch only occurs when xfs_bmapi_allocate() is called in a loop. Pull the check up before the loop in xfs_bmapi_write() such that the first iteration of the loop has consistent behavior. Signed-off-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-01-28xfs: Do not return EFSCORRUPTED when filesystem probe finds no XFS magicEric Sandeen
9802182 changed the return value from EWRONGFS (aka EINVAL) to EFSCORRUPTED which doesn't seem to be handled properly by the root filesystem probe. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Tested-by: Sergei Trofimovich <slyfox@gentoo.org> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-01-28GFS2: fix skip unlock conditionDavid Teigland
The recent commit fb6791d100d1bba20b5cdbc4912e1f7086ec60f8 included the wrong logic. The lvbptr check was incorrectly added after the patch was tested. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-01-27NFSv4.1: Ensure that nfs41_walk_client_list() does start lease recoveryTrond Myklebust
We do need to start the lease recovery thread prior to waiting for the client initialisation to complete in NFSv4.1. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Chuck Lever <chuck.lever@oracle.com> Cc: Ben Greear <greearb@candelatech.com> Cc: stable@vger.kernel.org [>=3.7]
2013-01-27NFSv4: Fix NFSv4 trunking discoveryTrond Myklebust
If walking the list in nfs4[01]_walk_client_list fails, then the most likely explanation is that the server dropped the clientid before we actually managed to confirm it. As long as our nfs_client is the very last one in the list to be tested, the caller can be assured that this is the case when the final return value is NFS4ERR_STALE_CLIENTID. Reported-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Chuck Lever <chuck.lever@oracle.com> Cc: stable@vger.kernel.org [>=3.7] Tested-by: Ben Greear <greearb@candelatech.com>
2013-01-27NFSv4: Fix NFSv4 reference counting for trunked sessionsTrond Myklebust
The reference counting in nfs4_init_client assumes wongly that it is safe for nfs4_discover_server_trunking() to return a pointer to a nfs_client prior to bumping the reference count. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Chuck Lever <chuck.lever@oracle.com> Cc: Ben Greear <greearb@candelatech.com> Cc: stable@vger.kernel.org [>=3.7]
2013-01-27NFS: Fix error reporting in nfs_xdev_mountTrond Myklebust
Currently, nfs_xdev_mount converts all errors from clone_server() to ENOMEM, which can then leak to userspace (for instance to 'mount'). Fix that. Also ensure that if nfs_fs_mount_common() returns an error, we don't dprintk(0)... The regression originated in commit 3d176e3fe4f6dc379b252bf43e2e146a8f7caf01 (NFS: Use nfs_fs_mount_common() for xdev mounts) Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@vger.kernel.org [>= 3.5]
2013-01-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "It turns out that we had two crc bugs when running fsx-linux in a loop. Many thanks to Josef, Miao Xie, and Dave Sterba for nailing it all down. Miao also has a new OOM fix in this v2 pull as well. Ilya fixed a regression Liu Bo found in the balance ioctls for pausing and resuming a running balance across drives. Josef's orphan truncate patch fixes an obscure corruption we'd see during xfstests. Arne's patches address problems with subvolume quotas. If the user destroys quota groups incorrectly the FS will refuse to mount. The rest are smaller fixes and plugs for memory leaks." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (30 commits) Btrfs: fix repeated delalloc work allocation Btrfs: fix wrong max device number for single profile Btrfs: fix missed transaction->aborted check Btrfs: Add ACCESS_ONCE() to transaction->abort accesses Btrfs: put csums on the right ordered extent Btrfs: use right range to find checksum for compressed extents Btrfs: fix panic when recovering tree log Btrfs: do not allow logged extents to be merged or removed Btrfs: fix a regression in balance usage filter Btrfs: prevent qgroup destroy when there are still relations Btrfs: ignore orphan qgroup relations Btrfs: reorder locks and sanity checks in btrfs_ioctl_defrag Btrfs: fix unlock order in btrfs_ioctl_rm_dev Btrfs: fix unlock order in btrfs_ioctl_resize Btrfs: fix "mutually exclusive op is running" error code Btrfs: bring back balance pause/resume logic btrfs: update timestamps on truncate() btrfs: fix btrfs_cont_expand() freeing IS_ERR em Btrfs: fix a bug when llseek for delalloc bytes behind prealloc extents Btrfs: fix off-by-one in lseek ...
2013-01-24Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull cifs fixes from Steve French: "Two small cifs fixes" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: fs/cifs/cifs_dfs_ref.c: fix potential memory leakage cifs: fix srcip_matches() for ipv6
2013-01-24Btrfs: fix repeated delalloc work allocationMiao Xie
btrfs_start_delalloc_inodes() locks the delalloc_inodes list, fetches the first inode, unlocks the list, triggers btrfs_alloc_delalloc_work/ btrfs_queue_worker for this inode, and then it locks the list, checks the head of the list again. But because we don't delete the first inode that it deals with before, it will fetch the same inode. As a result, this function allocates a huge amount of btrfs_delalloc_work structures, and OOM happens. Fix this problem by splice this delalloc list. Reported-by: Alex Lyakas <alex.btrfs@zadarastorage.com> Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-24Btrfs: fix wrong max device number for single profileMiao Xie
The max device number of single profile is 1, not 0 (0 means 'as many as possible'). Fix it. Cc: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Reviewed-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-24Btrfs: fix missed transaction->aborted checkMiao Xie
First, though the current transaction->aborted check can stop the commit early and avoid unnecessary operations, it is too early, and some transaction handles don't end, those handles may set transaction->aborted after the check. Second, when we commit the transaction, we will wake up some worker threads to flush the space cache and inode cache. Those threads also allocate some transaction handles and may set transaction->aborted if some serious error happens. So we need more check for ->aborted when committing the transaction. Fix it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-24Btrfs: Add ACCESS_ONCE() to transaction->abort accessesMiao Xie
We may access and update transaction->aborted on the different CPUs without lock, so we need ACCESS_ONCE() wrapper to prevent the compiler from creating unsolicited accesses and make sure we can get the right value. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-24Btrfs: put csums on the right ordered extentJosef Bacik
I noticed a WARN_ON going off when adding csums because we were going over the amount of csum bytes that should have been allowed for an ordered extent. This is a leftover from when we used to hold the csums privately for direct io, but now we use the normal ordered sum stuff so we need to make sure and check if we've moved on to another extent so that the csums are added to the right extent. Without this we could end up with csums for bytenrs that don't have extents to cover them yet. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-24Btrfs: use right range to find checksum for compressed extentsLiu Bo
For compressed extents, the range of checksum is covered by disk length, and the disk length is different with ram length, so we need to use disk length instead to get us the right checksum. Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-24Btrfs: fix panic when recovering tree logJosef Bacik
A user reported a BUG_ON(ret) that occured during tree log replay. Ret was -EAGAIN, so what I think happened is that we removed an extent that covered a bitmap entry and an extent entry. We remove the part from the bitmap and return -EAGAIN and then search for the next piece we want to remove, which happens to be an entire extent entry, so we just free the sucker and return. The problem is ret is still set to -EAGAIN so we trip the BUG_ON(). The user used btrfs-zero-log so I'm not 100% sure this is what happened so I've added a WARN_ON() to catch the other possibility. Thanks, Reported-by: Jan Steffens <jan.steffens@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-24Btrfs: do not allow logged extents to be merged or removedJosef Bacik
We drop the extent map tree lock while we're logging extents, so somebody could come in and merge another extent into this one and screw up our logging, or they could even remove us from the list which would keep us from logging the extent or freeing our ref on it, so we need to make sure to not clear LOGGING until after the extent is logged, and then we can merge it to adjacent extents. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-01-22fs/cifs/cifs_dfs_ref.c: fix potential memory leakageCong Ding
When it goes to error through line 144, the memory allocated to *devname is not freed, and the caller doesn't free it either in line 250. So we free the memroy of *devname in function cifs_compose_mount_options() when it goes to error. Signed-off-by: Cong Ding <dinggnu@gmail.com> CC: stable <stable@kernel.org> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-01-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse Pull fuse fixes from Miklos Szeredi: "This contain a bugfix for CUSE and miscellaneous small fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: remove unused variable in fuse_try_move_page() fuse: make fuse_file_fallocate() static fuse: Move CUSE Kconfig entry from fs/Kconfig into fs/fuse/Kconfig cuse: fix uninitialized variable warnings cuse: do not register multiple devices with identical names cuse: use mutex as registration lock instead of spinlocks
2013-01-22Merge tag 'f2fs-for-3.8-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull f2fs fixes from Jaegeuk Kim: o Support swap file and link generic_file_remap_pages o Enhance the bio streaming flow and free section control o Major bug fix on recovery routine o Minor bug/warning fixes and code cleanups * tag 'f2fs-for-3.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (22 commits) f2fs: use _safe() version of list_for_each f2fs: add comments of start_bidx_of_node f2fs: avoid issuing small bios due to several dirty node pages f2fs: support swapfile f2fs: add remap_pages as generic_file_remap_pages f2fs: add __init to functions in init_f2fs_fs f2fs: fix the debugfs entry creation path f2fs: add global mutex_lock to protect f2fs_stat_list f2fs: remove the blk_plug usage in f2fs_write_data_pages f2fs: avoid redundant time update for parent directory in f2fs_delete_entry f2fs: remove redundant call to set_blocksize in f2fs_fill_super f2fs: move f2fs_balance_fs to punch_hole f2fs: add f2fs_balance_fs in several interfaces f2fs: revisit the f2fs_gc flow f2fs: check return value during recovery f2fs: avoid null dereference in f2fs_acl_from_disk f2fs: initialize newly allocated dnode structure f2fs: update f2fs partition info about SIT/NAT layout f2fs: update f2fs document to reflect SIT/NAT layout correctly f2fs: remove unneeded INIT_LIST_HEAD at few places ...
2013-01-22f2fs: use _safe() version of list_for_eachDan Carpenter
This is calling list_del() inside a loop which is a problem when we try move to the next item on the list. I've converted it to use the _safe version. And also, as a cleanup, I've converted it to use list_for_each_entry instead of list_for_each. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-01-22f2fs: add comments of start_bidx_of_nodeJaegeuk Kim
The caller of start_bidx_of_node() should give proper node offsets which point only direct node blocks. Otherwise, it is a caller's bug. This patch adds comments to make it clear. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-01-22f2fs: avoid issuing small bios due to several dirty node pagesJaegeuk Kim
If some small bios of dirty node pages are supposed to be issued during the sequential data writes, there-in well-produced consecutive data bios are able to be split by the small node bios, resulting in performance degradation. So, let's collect a number of dirty node pages until reaching a threshold. And, by default, I set the threshold as 2MB, a segment size. This improves sequential write performance on i5, 512GB SSD (830 w/ SATA2) as follows. Before: 231 MB/s -> After: 255 MB/s Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com> Reviewed-by: Namjae Jeon <namjae.jeon@samsung.com>
2013-01-22f2fs: support swapfileJaegeuk Kim
This patch adds f2fs_bmap operation to the data address space. This enables f2fs to support swapfile. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-01-22f2fs: add remap_pages as generic_file_remap_pagesJaegeuk Kim
This was added for all the file systems before. See the following commit. commit id: 0b173bc4daa8f8ec03a85abf5e47b23502ff80af [PATCH] mm: kill vma flag VM_CAN_NONLINEAR This patch moves actual ptes filling for non-linear file mappings into special vma operation: ->remap_pages(). File system must implement this method to get non-linear mappings support, if it uses filemap_fault() then generic_file_remap_pages() can be used. Now device drivers can implement this method and obtain nonlinear vma support." Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-01-22f2fs: add __init to functions in init_f2fs_fsNamjae Jeon
Add __init to functions in init_f2fs_fs for code consistency. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-01-21Btrfs: fix a regression in balance usage filterIlya Dryomov
Commit 3fed40cc ("Btrfs: cleanup duplicated division functions"), which was merged into 3.8-rc1, has introduced a regression by removing logic that was guarding us against bad user input. Bring it back. Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-01-21Merge branch 'mutex-ops@next-for-chris' of ↵Chris Mason
git://github.com/idryomov/btrfs-unstable into linus
2013-01-21Merge branch 'for-chris' of ↵Chris Mason
git://git.kernel.org/pub/scm/linux/kernel/git/josef/btrfs-next into linus
2013-01-21Btrfs: prevent qgroup destroy when there are still relationsArne Jansen
Currently you can just destroy a qgroup even though it is in use by other qgroups or has qgroups assigned to it. This patch prevents destruction of qgroups unless they are completely unused. Otherwise destroy will return EBUSY. Reported-by: Eric Hopper <hopper@omnifarious.org> Signed-off-by: Arne Jansen <sensille@gmx.net> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-01-21Btrfs: ignore orphan qgroup relationsArne Jansen
If a qgroup that has still assignments is deleted by the user, the corresponding relations are left in the tree. This leads to an unmountable filesystem. With this patch, those relations are simple ignored. Reported-by: Eric Hopper <hopper@omnifarious.org> Signed-off-by: Arne Jansen <sensille@gmx.net> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-01-21cifs: fix srcip_matches() for ipv6Nickolai Zeldovich
srcip_matches() previously had code like this: srcip_matches(..., struct sockaddr *rhs) { /* ... */ struct sockaddr_in6 *vaddr6 = (struct sockaddr_in6 *) &rhs; return ipv6_addr_equal(..., &vaddr6->sin6_addr); } which interpreted the values on the stack after the 'rhs' pointer as an ipv6 address. The correct thing to do is to use 'rhs', not '&rhs'. Signed-off-by: Nickolai Zeldovich <nickolai@csail.mit.edu> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2013-01-20Btrfs: reorder locks and sanity checks in btrfs_ioctl_defragIlya Dryomov
Operation-specific check (whether subvol is readonly or not) should go after the mutual exclusiveness check. Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2013-01-20Btrfs: fix unlock order in btrfs_ioctl_rm_devIlya Dryomov
Fix unlock order in btrfs_ioctl_rm_dev(). Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2013-01-20Btrfs: fix unlock order in btrfs_ioctl_resizeIlya Dryomov
Fix unlock order in btrfs_ioctl_resize(). Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2013-01-20Btrfs: fix "mutually exclusive op is running" error codeIlya Dryomov
The error code that is returned in response to starting a mutually exclusive operation when there is one already running got silently changed from EINVAL to EINPROGRESS by 5ac00add. Returning EINPROGRESS to, say, add_dev, when rm_dev is running is misleading. Furthermore, the operation itself may want to use EINPROGRESS for other purposes. Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2013-01-20Btrfs: bring back balance pause/resume logicIlya Dryomov
Balance pause/resume logic got broken by 5ac00add (went in into 3.8-rc1 as part of dev-replace merge). Offending commit took a stab at making mutually exclusive volume operations (add_dev, rm_dev, resize, balance, replace_dev) not block behind volume_mutex if another such operation is in progress and instead return an error right away. Balancing front-end relied on the blocking behaviour, so the fix is ugly, but short of a complete rework, it's the best we can do. Reported-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2013-01-17fuse: remove unused variable in fuse_try_move_page()Wei Yongjun
The variables mapping,index are initialized but never used otherwise, so remove the unused variables. dpatch engine is used to auto generate this patch. (https://github.com/weiyj/dpatch) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-17fuse: make fuse_file_fallocate() staticMiklos Szeredi
Fix the following sparse warning: fs/fuse/file.c:2249:6: warning: symbol 'fuse_file_fallocate' was not declared. Should it be static? Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-17fuse: Move CUSE Kconfig entry from fs/Kconfig into fs/fuse/KconfigRobert P. J. Day
Given that CUSE depends on FUSE, it only makes sense to move its Kconfig entry into the FUSE Kconfig file. Also, add a few grammatical and semantic touchups. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-17cuse: fix uninitialized variable warningsMiklos Szeredi
Fix the following compiler warnings: fs/fuse/cuse.c: In function 'cuse_process_init_reply': fs/fuse/cuse.c:288:24: warning: 'val' may be used uninitialized in this function [-Wmaybe-uninitialized] fs/fuse/cuse.c:272:14: note: 'val' was declared here fs/fuse/cuse.c:284:10: warning: 'key' may be used uninitialized in this function [-Wmaybe-uninitialized] fs/fuse/cuse.c:272:8: note: 'key' was declared here Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
