commit e5012d1f3861d18c7f3814e757c1c3ab3741dbcd upstream.
Attribute IDs assigned in RFC 5661 now require three bitmaps.
Fixes hitting a BUG_ON in xdr_shrink_bufhead when getting ACLs.
Signed-off-by: Andy Adamson <andros@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 2aa15890f3c191326678f1bd68af61ec6b8753ec upstream.
Michael Leun reported that running parallel opens on a fuse filesystem
can trigger a "kernel BUG at mm/truncate.c:475"
Gurudas Pai reported the same bug on NFS.
The reason is, unmap_mapping_range() is not prepared for more than
one concurrent invocation per inode. For example:
thread1: going through a big range, stops in the middle of a vma and
stores the restart address in vm_truncate_count.
thread2: comes in with a small (e.g. single page) unmap request on
the same vma, somewhere before restart_address, finds that the
vma was already unmapped up to the restart address and happily
returns without doing anything.
Another scenario would be two big unmap requests, both having to
restart the unmapping and each one setting vm_truncate_count to its
own value. This could go on forever without any of them being able to
finish.
Truncate and hole punching already serialize with i_mutex. Other
callers of unmap_mapping_range() do not, and it's difficult to get
i_mutex protection for all callers. In particular ->d_revalidate(),
which calls invalidate_inode_pages2_range() in fuse, may be called
with or without i_mutex.
This patch adds a new mutex to 'struct address_space' to prevent
running multiple concurrent unmap_mapping_range() on the same mapping.
[ We'll hopefully get rid of all this with the upcoming mm
preemptibility series by Peter Zijlstra, the "mm: Remove i_mmap_mutex
lockbreak" patch in particular. But that is for 2.6.39 ]
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Reported-by: Michael Leun <lkml20101129@newton.leun.net>
Reported-by: Gurudas Pai <gurudas.pai@oracle.com>
Tested-by: Gurudas Pai <gurudas.pai@oracle.com>
commit dac853ae89043f1b7752875300faf614de43c74b upstream.
Unconditionally changing the address limit to USER_DS and not restoring
it to its old value in the error path is wrong because it prevents us
using kernel memory on repeated calls to this function. This, in fact,
breaks the fallback of hard coded paths to the init program from being
ever successful if the first candidate fails to load.
With this patch applied switching to USER_DS is delayed until the point
of no return is reached which makes it possible to have a multi-arch
rootfs with one arch specific init binary for each of the (hard coded)
probed paths.
Since the address limit is already set to USER_DS when start_thread()
will be invoked, this redundancy can be safely removed.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit 081003fff467ea0e727f66d5d435b4f473a789b3 upstream.
When marking an inode reclaimable, a per-AG counter is increased, the
inode is tagged reclaimable in its per-AG tree, and, when this is the
first reclaimable inode in the AG, the AG entry in the per-mount tree
is also tagged.
When an inode is finally reclaimed, however, it is only deleted from
the per-AG tree. Neither the counter is decreased, nor is the parent
tree's AG entry untagged properly.
Since the tags in the per-mount tree are not cleared, the inode
shrinker iterates over all AGs that have had reclaimable inodes at one
point in time.
The counters on the other hand signal an increasing amount of slab
objects to reclaim. Since "70e60ce xfs: convert inode shrinker to
per-filesystem context" this is not a real issue anymore because the
shrinker bails out after one iteration.
But the problem was observable on a machine running v2.6.34, where the
reclaimable work increased and each process going into direct reclaim
eventually got stuck on the xfs inode shrinking path, trying to scan
several million objects.
Fix this by properly unwinding the reclaimable-state tracking of an
inode when it is reclaimed.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
Backported-by: Stefan Priebe <s.priebe@profihost.ag>
commit fe47ae7f53e179d2ef6771024feb000cbb86640f upstream.
The lockdep warning below detects a possible A->B/B->A locking
dependency of mm->mmap_sem and dcookie_mutex. The order in
sync_buffer() is mm->mmap_sem/dcookie_mutex, while in
sys_lookup_dcookie() it is vice versa.
Fixing it in sys_lookup_dcookie() by unlocking dcookie_mutex before
copy_to_user().
oprofiled/4432 is trying to acquire lock:
(&mm->mmap_sem){++++++}, at: [<ffffffff810b444b>] might_fault+0x53/0xa3
but task is already holding lock:
(dcookie_mutex){+.+.+.}, at: [<ffffffff81124d28>] sys_lookup_dcookie+0x45/0x149
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (dcookie_mutex){+.+.+.}:
[<ffffffff8106557f>] lock_acquire+0xf8/0x11e
[<ffffffff814634f0>] mutex_lock_nested+0x63/0x309
[<ffffffff81124e5c>] get_dcookie+0x30/0x144
[<ffffffffa0000fba>] sync_buffer+0x196/0x3ec [oprofile]
[<ffffffffa0001226>] task_exit_notify+0x16/0x1a [oprofile]
[<ffffffff81467b96>] notifier_call_chain+0x37/0x63
[<ffffffff8105803d>] __blocking_notifier_call_chain+0x50/0x67
[<ffffffff81058068>] blocking_notifier_call_chain+0x14/0x16
[<ffffffff8105a718>] profile_task_exit+0x1a/0x1c
[<ffffffff81039e8f>] do_exit+0x2a/0x6fc
[<ffffffff8103a5e4>] do_group_exit+0x83/0xae
[<ffffffff8103a626>] sys_exit_group+0x17/0x1b
[<ffffffff8146ad4b>] system_call_fastpath+0x16/0x1b
-> #0 (&mm->mmap_sem){++++++}:
[<ffffffff81064dfb>] __lock_acquire+0x1085/0x1711
[<ffffffff810b4478>] might_fault+0x80/0xa3
[<ffffffff81124de7>] sys_lookup_dcookie+0x104/0x149
1 lock held by oprofiled/4432:
#0: (dcookie_mutex){+.+.+.}, at: [<ffffffff81124d28>] sys_lookup_dcookie+0x45/0x149
stack backtrace:
Pid: 4432, comm: oprofiled Not tainted 2.6.39-00008-ge5a450d #9
Call Trace:
[<ffffffff81063193>] print_circular_bug+0xae/0xbc
[<ffffffff8102ef13>] ? get_parent_ip+0x11/0x42
[<ffffffff810b444b>] ? might_fault+0x53/0xa3
[<ffffffff810d7d54>] ? path_put+0x22/0x27
References: https://bugzilla.kernel.org/show_bug.cgi?id=13809
Signed-off-by: Robert Richter <robert.richter@amd.com>
commit 1adffbae22332bb558c2a29de19d9aca391869f6 upstream.
We are clearly missing '~' in fat_ioctl_set_attributes().
Reported-by: Dmitry Dmitriev <dimondmm@yandex.ru>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
commit 812eb258311f89bcd664a34a620f249d54a2cd83 upstream.
UBIFS leaks memory on error path in 'ubifs_jnl_update()' in case of write
failure because it forgets to free the 'struct ubifs_dent_node *dent' object.
Although the object is small, the alignment can make it large - e.g., 2KiB
if the min. I/O unit is 2KiB.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
commit cf610bf4199770420629d3bc273494bd27ad6c1d upstream.
Sometimes VM asks the shrinker to return amount of objects it can shrink,
and we return the ubifs_clean_zn_cnt in that case. However, it is possible
that this counter is negative for a short period of time, due to the way
UBIFS TNC code updates it. And I can observe the following warnings sometimes:
shrink_slab: ubifs_shrinker+0x0/0x2b7 [ubifs] negative objects to delete nr=-8541616642706119788
This patch makes sure UBIFS never returns negative count of objects.
commit eaeee242c531cd4b0a4a46e8b5dd7ef504380c42 upstream.
When re-mounting from R/O mode to R/W mode and the LEB count in the superblock
is not up-to date, because for the underlying UBI volume became larger, we
re-write the superblock. We allocate RAM for these purposes, but never free it.
So this is a memory leak, although very rare one.
commit 8d08dab786ad5cc2aca2bf870de370144b78c85a upstream.
The buffers allocated while encrypting and decrypting long filenames can
sometimes straddle two pages. In this situation, virt_to_scatterlist()
will return -ENOMEM, causing the operation to fail and the user will get
scary error messages in their logs:
kernel: ecryptfs_write_tag_70_packet: Internal error whilst attempting
to convert filename memory to scatterlist; expected rc = 1; got rc =
[-12]. block_aligned_filename_size = [272]
kernel: ecryptfs_encrypt_filename: Error attempting to generate tag 70
packet; rc = [-12]
kernel: ecryptfs_encrypt_and_encode_filename: Error attempting to
encrypt filename; rc = [-12]
kernel: ecryptfs_lookup: Error attempting to encrypt and encode
The solution is to allow up to 2 scatterlist entries to be used.
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
commit cae13fe4cc3f24820ffb990c09110626837e85d4 upstream.
As Ben Hutchings discovered [1], the patch for CVE-2011-1017 (buffer
overflow in ldm_frag_add) is not sufficient. The original patch in
commit c340b1d64000 ("fs/partitions/ldm.c: fix oops caused by corrupted
partition table") does not consider that, for subsequent fragments,
previously allocated memory is used.
[1] http://lkml.org/lkml/2011/5/6/407
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Signed-off-by: Timo Warns <warns@pre-sense.de>
commit 26626f1172fb4f3f323239a6a5cf4e082643fa46 upstream.
Add missing page_cache_release in the error path of ext4_mb_load_buddy
Signed-off-by: Yang Ruirui <ruirui.r.yang@tieto.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit d9b01934d56a96d9f4ae2d6204d4ea78a36f5f36 upstream.
If an application program does not make any changes to the indirect
blocks or extent tree, i_datasync_tid will not get updated. If there
are enough commits (i.e., 2**31) such that tid_geq()'s calculations
wrap, and there isn't a currently active transaction at the time of
the fdatasync() call, this can end up triggering a BUG_ON in
fs/jbd/commit.c:
J_ASSERT(journal->j_running_transaction != NULL);
It's pretty rare that this can happen, since it requires the use of
fdatasync() plus *very* frequent and excessive use of fsync(). But
with the right workload, it can.
We fix this by replacing the use of tid_geq() with an equality test,
since there's only one valid transaction id that is valid for us to
start: namely, the currently running transaction (if it exists).
Reported-by: Martin_Zielinski@McAfee.com
commit 2842bb20eed2e25cde5114298edc62c8883a1d9a upstream.
In do_get_write_access() we wait on BH_Unshadow bit for buffer to get
from shadow state. The waking code in journal_commit_transaction() has
a bug because it does not issue a memory barrier after the buffer is moved
from the shadow state and before wake_up_bit() is called. Thus a waitqueue
check can happen before the buffer is actually moved from the shadow state
and waiting process may never be woken. Fix the problem by issuing proper
barrier.
Reported-by: Tao Ma <boyu.mt@taobao.com>
commit 86c4f6d85595cd7da635dc6985d27bfa43b1ae10 upstream.
When make_indexed_dir() fails (e.g. because of ENOSPC) after it has allocated
block for index tree root, we did not properly mark all changed buffers dirty.
This lead to only some of these buffers being written out and thus effectively
corrupting the directory.
Fix the issue by marking all changed data dirty even in the error failure case.
commit 02e352287a40bd456eb78df705bf888bc3161d3f upstream.
__blkdev_get() doesn't rescan partitions if disk->fops->open() fails,
which leads to ghost partition devices lingering after medimum removal
is known to both the kernel and userland. The behavior also creates a
subtle inconsistency where O_NONBLOCK open, which doesn't fail even if
there's no medium, clears the ghots partitions, which is exploited to
work around the problem from userland.
Fix it by updating __blkdev_get() to issue partition rescan after
-ENOMEDIA too.
This was reported in the following bz.
https://bugzilla.kernel.org/show_bug.cgi?id=13029
Stable: 2.6.38
Reported-by: David Zeuthen <zeuthen@gmail.com>
Reported-by: Martin Pitt <martin.pitt@ubuntu.com>
Reported-by: Kay Sievers <kay.sievers@vrfy.org>
Tested-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit 221d1d797202984cb874e3ed9f1388593d34ee22 upstream.
The is_path_accessible check uses a QPathInfo call, which isn't
supported by ancient win9x era servers. Fall back to an older
SMBQueryInfo call if it fails with the magic error codes.
Reported-and-Tested-by: Sandro Bonazzola <sandro.bonazzola@gmail.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit 4906e50b37e6f6c264e7ee4237343eb2b7f8d16d upstream.
While password processing we can get out of options array bound if
the next character after array is delimiter. The patch adds a check
if we reach the end.
Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
commit fa039d5f6b126fbd65eefa05db2f67e44df8f121 upstream.
Otherwise corrupted EFI partition tables can cause total confusion.
commit fcda7f4578bbf9717444ca6da8a421d21489d078 upstream.
It's possible that when we go to decode the string area in the
SESSION_SETUP response, that bytes_remaining will be 0. Decrementing it at
that point will mean that it can go "negative" and wrap. Check for a
bytes_remaining value of 0, and don't try to decode the string area if
that's the case.
Reported-and-Acked-by: David Howells <dhowells@redhat.com>
commit 6f88a4403def422bd8e276ddf6863d6ac71435d2 upstream.
Filesystem rebalancing (BTRFS_IOC_BALANCE) affects the entire
filesystem and may run uninterruptibly for a long time. This does not
seem to be something that an unprivileged user should be able to do.
Reported-by: Aron Xu <happyaron.xu@gmail.com>
Signed-off-by: Chris Mason <chris.mason@oracle.com>
commit a7851ce73b9fdef53f251420e6883cf4f3766534 upstream.
cifs_root_iget allocates full_path through
cifs_build_path_to_root, but fails to kfree it upon
cifs_get_inode_info* failure.
Make all failure exit paths traverse clean up
handling at the end of the function.
Signed-off-by: Oskar Schirmer <oskar@scara.com>
Reviewed-by: Jesper Juhl <jj@chaosbits.net>
commit 34d211a2d5df4984a35b18d8ccacbe1d10abb067 upstream.
It turns out that while a maximum of 8 partitions may be what people
"should" have had, you can actually fit up to 18 entries(*) in a sector.
And some people clearly were taking advantage of that, like Michael
Cree, who had ten partitions on one of his OSF disks.
(*) The OSF partition data starts at byte offset 64 in the first sector,
and the array of 16-byte partition entries start at offset 148 in
the on-disk partition structure.
Reported-by: Michael Cree <mcree@orcon.net.nz>
Cc: stable@kernel.org (v2.6.38)
commit 1eafbfeb7bdf59cfe173304c76188f3fd5f1fd05 upstream.
The kernel automatically evaluates partition tables of storage devices.
The code for evaluating OSF partitions contains a bug that leaks data
from kernel heap memory to userspace for certain corrupted OSF
partitions.
In more detail:
for (i = 0 ; i < le16_to_cpu(label->d_npartitions); i++, partition++) {
iterates from 0 to d_npartitions - 1, where d_npartitions is read from
the partition table without validation and partition is a pointer to an
array of at most 8 d_partitions.
Add the proper and obvious validation.
[ Changed the patch trivially to not repeat the whole le16_to_cpu()
thing, and to use an explicit constant for the magic value '8' ]
commit 43b7c3f051dea504afccc39bcb56d8e26c2e0b77 upstream.
this commit fix compilation warning as following:
linux-2.6/fs/nfs/nfs4proc.c:3265: warning: comparison of distinct pointer types lacks a cast
Signed-off-by: Jovi Zhang <bookjovi@gmail.com>
commit e9e3d724e2145f5039b423c290ce2b2c3d8f94bc upstream.
The "bad_page()" page allocator sanity check was reported recently (call
chain as follows):
bad_page+0x69/0x91
free_hot_cold_page+0x81/0x144
skb_release_data+0x5f/0x98
__kfree_skb+0x11/0x1a
tcp_ack+0x6a3/0x1868
tcp_rcv_established+0x7a6/0x8b9
tcp_v4_do_rcv+0x2a/0x2fa
tcp_v4_rcv+0x9a2/0x9f6
do_timer+0x2df/0x52c
ip_local_deliver+0x19d/0x263
ip_rcv+0x539/0x57c
netif_receive_skb+0x470/0x49f
:virtio_net:virtnet_poll+0x46b/0x5c5
net_rx_action+0xac/0x1b3
__do_softirq+0x89/0x133
call_softirq+0x1c/0x28
do_softirq+0x2c/0x7d
do_IRQ+0xec/0xf5
default_idle+0x0/0x50
ret_from_intr+0x0/0xa
default_idle+0x29/0x50
cpu_idle+0x95/0xb8
start_kernel+0x220/0x225
_sinittext+0x22f/0x236
It occurs because an skb with a fraglist was freed from the tcp
retransmit queue when it was acked, but a page on that fraglist had
PG_Slab set (indicating it was allocated from the Slab allocator (which
means the free path above can't safely free it via put_page.
We tracked this back to an nfsv4 setacl operation, in which the nfs code
attempted to fill convert the passed in buffer to an array of pages in
__nfs4_proc_set_acl, which gets used by the skb->frags list in
xs_sendpages. __nfs4_proc_set_acl just converts each page in the buffer
to a page struct via virt_to_page, but the vfs allocates the buffer via
kmalloc, meaning the PG_slab bit is set. We can't create a buffer with
kmalloc and free it later in the tcp ack path with put_page, so we need
to either:
1) ensure that when we create the list of pages, no page struct has
PG_Slab set
or
2) not use a page list to send this data
Given that these buffers can be multiple pages and arbitrarily sized, I
think (1) is the right way to go. I've written the below patch to
allocate a page from the buddy allocator directly and copy the data over
to it. This ensures that we have a put_page free-able page for every
entry that winds up on an skb frag list, so it can be safely freed when
the frame is acked. We do a put page on each entry after the
rpc_call_sync call so as to drop our own reference count to the page,
leaving only the ref count taken by tcp_sendpages. This way the data
will be properly freed when the ack comes in
Successfully tested by myself to solve the above oops.
Note, as this is the result of a setacl operation that exceeded a page
of data, I think this amounts to a local DOS triggerable by an
uprivlidged user, so I'm CCing security on this as well.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Trond Myklebust <Trond.Myklebust@netapp.com>
CC: security@kernel.org
CC: Jeff Layton <jlayton@redhat.com>
commit 8b4216018bdbfbb1b76150d202b15ee68c38e991 upstream.
HighMem pages on i686 do not get mapped to the buffer_heads and this was
causing a NULL pointer dereference when we were trying to memset page buffers
to zero.
We now use zero_user() that kmaps the page and directly manipulates page data.
This patch also fixes a boundary condition that was incorrect.
Signed-off-by: Abhi Das <adas@redhat.com>
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
[Adjusted to apply to 2.6.32 by dann frazier <dannf@debian.org>]
commit 7e619bc3e6252dc746f64ac3b486e784822e9533 upstream.
This is the upstream fix for this bug. This patch differs
from the RHEL5 fix (Red Hat bz #555754) which simply writes to the 8-byte
value field of the quota. In upstream quota code, we're
required to write the entire quota (88 bytes) which can be split
across a page boundary. We check for such quotas, and read/write
the two parts from/to the corresponding pages holding these parts.
With this patch, I don't see the bug anymore using the reproducer
in Red Hat bz 555754. I successfully ran a couple of simple tests/mounts/
umounts and it doesn't seem like this patch breaks anything else.
[Backported to 2.6.32 by dann frazier <dannf@debian.org>]
commit 1e72c0f7c40e665d2ed40014750fdd2fa9968bcf upstream.
Both of these functions contained confusing and in one case
duplicate code. This patch adds a new check in do_glock()
so that we report -ENOENT if we are asked to sync a quota
entry which doesn't exist. Due to the previous patch this is
now reported correctly to userspace.
Also there are a few new comments, and I hope that the code
is easier to understand now.
commit c340b1d640001c8c9ecff74f68fd90422ae2448a upstream.
The code for evaluating LDM partitions (in fs/partitions/ldm.c) contains
a bug that causes a kernel oops on certain corrupted LDM partitions.
A kernel subsystem seems to crash, because, after the oops, the kernel no
longer recognizes newly connected storage devices.
The patch validates the value of vblk_size.
Cc: Eugene Teo <eugeneteo@kernel.sg>
Cc: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Richard Russon <rich@flatcap.org>
directories
commit 1574dff8996ab1ed92c09012f8038b5566fce313 upstream.
An open on a NFS4 share using the O_CREAT flag on an existing file for
which we have permissions to open but contained in a directory with no
write permissions will fail with EACCES.
A tcpdump shows that the client had set the open mode to UNCHECKED which
indicates that the file should be created if it doesn't exist and
encountering an existing flag is not an error. Since in this case the
file exists and can be opened by the user, the NFS server is wrong in
attempting to check create permissions on the parent directory.
The patch adds a conditional statement to check for create permissions
only if the file doesn't exist.
Signed-off-by: Sachin S. Prabhu <sprabhu@redhat.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 47c2199b6eb5fbe38ddb844db7cdbd914d304f9c upstream.
Currently, the state manager may continue to try recovering state forever
even after the last filesystem to reference that nfs_client has umounted.
commit 26c4c170731f00008f4317a2888a0a07ac99d90d upstream.
On a remount, the VFS layer will clear the MS_SYNCHRONOUS bit on the
assumption that the flags on the mount syscall will have it set if the
remounted fs is supposed to keep it.
In the case of "noac" though, MS_SYNCHRONOUS is implied. A remount of
such a mount will lose the MS_SYNCHRONOUS flag since "sync" isn't part
of the mount options.
Reported-by: Max Matveev <makc@redhat.com>
commit 6e0d9fd38b750d678bf9fd07db23582f52fafa55 upstream.
This patch fixes the following symptoms:
1. Unmount UBIFS cleanly.
2. Start mounting UBIFS R/W and have a power cut immediately
3. Start mounting UBIFS R/O, this succeeds
4. Try to re-mount UBIFS R/W - this fails immediately or later on,
because UBIFS will write the master node to the flash area
which has been written before.
The analysis of the problem:
1. UBIFS is unmounted cleanly, both copies of the master node are clean.
2. UBIFS is being mounter R/W, starts changing master node copy 1, and
a power cut happens. The copy N1 becomes corrupted.
3. UBIFS is being mounted R/O. It notices the copy N1 is corrupted and
reads copy N2. Copy N2 is clean.
4. Because of R/O mode, UBIFS cannot recover copy 1.
5. The mount code (ubifs_mount()) sees that the master node is clean,
so it decides that no recovery is needed.
6. We are re-mounting R/W. UBIFS believes no recovery is needed and
starts updating the master node, but copy N1 is still corrupted
and was not recovered!
Fix this problem by marking the master node as dirty every time we
recover it and we are in R/O mode. This forces further recovery and
the UBIFS cleans-up the corruptions and recovers the copy N1 when
re-mounting R/W later.
commit 27dc1cd3ad9300f81e1219e5fc305d91d85353f8 upstream.
If the call to nfs_wcc_update_inode() results in an attribute update, we
need to ensure that the inode's attr_gencount gets bumped too, otherwise
we are not protected against races with other GETATTR calls.
commit d8bdc59f215e62098bc5b4256fd9928bf27053a1 upstream.
Rather than pass in some random truncated offset to the pid-related
functions, check that the offset is in range up-front.
This is just cleanup, the previous commit fixed the real problem.
commit 78530bf7f2559b317c04991b52217c1608d5a58d upstream.
This patch fixes severe UBIFS bug: UBIFS oopses when we 'fsync()' an
file on R/O-mounter file-system. We (the UBIFS authors) incorrectly
thought that VFS would not propagate 'fsync()' down to the file-system
if it is read-only, but this is not the case.
It is easy to exploit this bug using the following simple perl script:
use strict;
use File::Sync qw(fsync sync);
die "File path is not specified" if not defined $ARGV[0];
my $path = $ARGV[0];
open FILE, "<", "$path" or die "Cannot open $path: $!";
fsync(\*FILE) or die "cannot fsync $path: $!";
close FILE or die "Cannot close $path: $!";
Thanks to Reuben Dowle <Reuben.Dowle@navico.com> for reporting about this
issue.
Reported-by: Reuben Dowle <Reuben.Dowle@navico.com>
commit b836aec53e2bce71de1d5415313380688c851477 upstream.
On no-mmu arch, there is a memleak during shmem test. The cause of this
memleak is ramfs_nommu_expand_for_mapping() added page refcount to 2
which makes iput() can't free that pages.
The simple test file is like this:
int main(void)
int i;
key_t k = ftok("/etc", 42);
for ( i=0; i<100; ++i) {
int id = shmget(k, 10000, 0644|IPC_CREAT);
if (id == -1) {
printf("shmget error\n");
if(shmctl(id, IPC_RMID, NULL ) == -1) {
printf("shm rm error\n");
return -1;
printf("run ok...\n");
return 0;
And the result:
root:/> free
total used free shared buffers
Mem: 60320 17912 42408 0 0
-/+ buffers: 17912 42408
root:/> shmem
run ok...
root:/> free
Mem: 60320 19096 41224 0 0
-/+ buffers: 19096 41224
root:/> shmem
run ok...
root:/> free
Mem: 60320 20296 40024 0 0
-/+ buffers: 20296 40024
After this patch the test result is:(no memleak anymore)
root:/> free
Mem: 60320 16668 43652 0 0
-/+ buffers: 16668 43652
root:/> shmem
run ok...
root:/> free
Signed-off-by: Bob Liu <lliubbo@gmail.com>
commit 8c559d30b4e59cf6994215ada1fe744928f494bf upstream.
Don't allow everybody to dump sensitive information about filesystems.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
commit 70945643722ffeac779d2529a348f99567fa5c33 upstream.
Currently, we skip doing the is_path_accessible check in cifs_mount if
there is no prefixpath. I have a report of at least one server however
that allows a TREE_CONNECT to a share that has a DFS referral at its
root. The reporter in this case was using a UNC that had no prefixpath,
so the is_path_accessible check was not triggered and the box later hit
a BUG() because we were chasing a DFS referral on the root dentry for
the mount.
This patch fixes this by removing the check for a zero-length
prefixpath. That should make the is_path_accessible check be done in
this situation and should allow the client to chase the DFS referral at
mount time instead.
Reported-and-Tested-by: Yogesh Sharma <ysharma@cymer.com>
commit af24ee9ea8d532e16883251a6684dfa1be8eec29 upstream.
Commit 493f3358cb289ccf716c5a14fa5bb52ab75943e5 added this call to
xfs_fs_geometry() in order to avoid passing kernel stack data back
to user space:
+ memset(geo, 0, sizeof(*geo));
Unfortunately, one of the callers of that function passes the
address of a smaller data type, cast to fit the type that
xfs_fs_geometry() requires. As a result, this can happen:
Kernel panic - not syncing: stack-protector: Kernel stack is corrupted
in: f87aca93
Pid: 262, comm: xfs_fsr Not tainted 2.6.38-rc6-493f3358cb2+ #1
Call Trace:
[<c12991ac>] ? panic+0x50/0x150
[<c102ed71>] ? __stack_chk_fail+0x10/0x18
[<f87aca93>] ? xfs_ioc_fsgeometry_v1+0x56/0x5d [xfs]
Fix this by fixing that one caller to pass the right type and then
copy out the subset it is interested in.
Note: This patch is an alternative to one originally proposed by
Eric Sandeen.
Reported-by: Jeffrey Hundstad <jeffrey.hundstad@mnsu.edu>
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
Tested-by: Jeffrey Hundstad <jeffrey.hundstad@mnsu.edu>
commit 114279be2120a916e8a04feeb2ac976a10016f2f upstream.
Note: this patch targets 2.6.37 and tries to be as simple as possible.
That is why it adds more copy-and-paste horror into fs/compat.c and
uglifies fs/exec.c, this will be cleanuped later.
compat_copy_strings() plays with bprm->vma/mm directly and thus has
two problems: it lacks the RLIMIT_STACK check and argv/envp memory
is not visible to oom killer.
Export acct_arg_size() and get_arg_page(), change compat_copy_strings()
to use get_arg_page(), change compat_do_execve() to do acct_arg_size(0)
as do_execve() does.
Add the fatal_signal_pending/cond_resched checks into compat_count() and
compat_copy_strings(), this matches the code in fs/exec.c and certainly
makes sense.
Cc: Moritz Muehlenhoff <jmm@debian.org>
commit 3c77f845722158206a7209c45ccddc264d19319c upstream.
Brad Spengler published a local memory-allocation DoS that
evades the OOM-killer (though not the virtual memory RLIMIT):
http://www.grsecurity.net/~spender/64bit_dos.c
execve()->copy_strings() can allocate a lot of memory, but
this is not visible to oom-killer, nobody can see the nascent
bprm->mm and take it into account.
With this patch get_arg_page() increments current's MM_ANONPAGES
counter every time we allocate the new page for argv/envp. When
do_execve() succeds or fails, we change this counter back.
Technically this is not 100% correct, we can't know if the new
page is swapped out and turn MM_ANONPAGES into MM_SWAPENTS, but
I don't think this really matters and everything becomes correct
once exec changes ->mm or fails.
Reported-by: Brad Spengler <spender@grsecurity.net>
Reviewed-and-discussed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
commit 954032d2527f2fce7355ba70709b5e143d6b686f upstream.
This was noticed by users who performed more than 2^32 lock operations
and hence made this counter overflow (eventually leading to
use-after-free's). Setting rq_client to NULL here means that it won't
later get auth_domain_put() when it should be.
Appears to have been introduced in 2.5.42 by "[PATCH] kNFSd: Move auth
domain lookup into svcauth" which moved most of the rq_client handling
to common svcauth code, but left behind this one line.
Cc: Neil Brown <neilb@suse.de>
commit 5b41395fcc0265fc9f193aef9df39ce49d64677c upstream.
When writing a contiguous set of blocks, two indirect blocks could be
needed depending on how the blocks are aligned, so we need to increase
the number of credits needed by one.
[ Also fixed a another bug which could further underestimate the
number of journal credits needed by 1; the code was using integer
division instead of DIV_ROUND_UP() -- tytso]
Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com>
commit 44cff8a9ee8a974f9e931df910688e7fc1f0b0f9 upstream.
Handle the rare case where a directory metadata block is uncompressed and
corrupted, leading to a kernel oops in directory scanning (memcpy).
Normally corruption is detected at the decompression stage and dealt with
then, however, this will not happen if:
- metadata isn't compressed (users can optionally request no metadata
compression), or
- the compressed metadata block was larger than the original, in which
case the uncompressed version was used, or
- the data was corrupt after decompression
This patch fixes this by adding some sanity checks against known maximum
values.
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
commit 272b62c1f0f6f742046e45b50b6fec98860208a0 upstream.
When a hole spans across page boundaries, the next write forces
a read of the block. This could end up reading existing garbage
data from the disk in ocfs2_map_page_blocks. This leads to
non-zero holes. In order to avoid this, mark the writes as new
when the holes span across page boundaries.
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de>
Signed-off-by: jlbec <jlbec@evilplan.org>
commit b03f24567ce7caf2420b8be4c6eb74c191d59a91 upstream.
There's no reason to write quota info in dquot_commit(). The writing is a
relict from the old days when we didn't have dquot_acquire() and
dquot_release() and thus dquot_commit() could have created / removed quota
structures from the file. These days dquot_commit() only updates usage counters
/ limits in quota structure and thus there's no need to write quota info.
This also fixes an issue with journaling filesystem which didn't reserve
enough space in the transaction for write of quota info (it could have been
dirty at the time of dquot_commit() because of a race with other operation
changing it).
Reported-and-tested-by: Lukas Czerner <lczerner@redhat.com>
commit 7da6443aca9be29c6948dcbd636ad50154d0bc0c upstream.
This patch fixes a debugging failure with which looks like this:
UBIFS error (pid 32313): dbg_check_space_info: free space changed from 6019344 to 6022654
The reason for this failure is described in the comment this patch adds
to the code. But in short - 'c->freeable_cnt' may be different before
and after re-mounting, and this is normal. So the debugging code should
make sure that free space calculations do not depend on 'c->freeable_cnt'.
A similar issue has been reported here:
http://lists.infradead.org/pipermail/linux-mtd/2011-April/034647.html
This patch should fix it.
For the -stable guys: this patch is only relevant for kernels 2.6.30
onwards.
commit 54acbaaa523ca0bd284a18f67ad213c379679e86 upstream.
Thanks to coverity which spotted that UBIFS will oops if 'kmalloc()'
in 'read_pnode()' fails and we dereference a NULL 'pnode' pointer
when we 'goto out'.
