path: root/fs
2008-06-06uml: activate_mm: remove the dead PF_BORROWED_MM checktip-core-topology-2008-06-16_09.13_Montip-core-misc-2008-06-16_09.11_MonOleg Nesterov
use_mm() was changed to use switch_mm() instead of activate_mm(), since then nobody calls (and nobody should call) activate_mm() with PF_BORROWED_MM bit set. As Jeff Dike pointed out, we can also remove the "old != new" check, it is always true. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6: capabilities: remain source compatible with 32-bit raw legacy capability support. LSM: remove stale web site from MAINTAINERS
2008-06-06pagemap: return EINVAL, not EIO, for unaligned reads of kpagecount or kpageflagsThomas Tuttle
If the user tries to read from a position that is not a multiple of 8, or read a number of bytes that is not a multiple of 8, they have passed an invalid argument to read, for the purpose of reading these files. It's not an IO error because we didn't encounter any trouble finding the data they asked for. Signed-off-by: Thomas Tuttle <ttuttle@google.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06pagemap: return map count, not reference count, in /proc/kpagecountThomas Tuttle
Since pagemap is all about examining pages mapped into processes' memory spaces, it makes sense for kpagecount to return the map counts, not the reference counts. Signed-off-by: Thomas Tuttle <ttuttle@google.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06proc: calculate the correct /proc/<pid> link countVegard Nossum
This patch: commit e9720acd728a46cb40daa52c99a979f7c4ff195c Author: Pavel Emelyanov <xemul@openvz.org> Date: Fri Mar 7 11:08:40 2008 -0800 [NET]: Make /proc/net a symlink on /proc/self/net (v3) introduced a /proc/self/net directory without bumping the corresponding link count for /proc/self. This patch replaces the static link count initializations with a call that counts the number of directory entries in the given pid_entry table whenever it is instantiated, and thus relieves the burden of manually keeping the two in sync. [akpm@linux-foundation.org: cleanup] Acked-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06ext3: fix online resize bugJosef Bacik
There is a bug when we are trying to verify that the reserve inode's double indirect blocks point back to the primary gdt blocks. The fix is obvious, we need to mod the gdb count by the addr's per block. You can verify this with the following test case dd if=/dev/zero of=disk1 seek=1024 count=1 bs=100M losetup /dev/loop1 disk1 pvcreate /dev/loop1 vgcreate loopvg1 /dev/loop1 lvcreate -l 100%VG loopvg1 -n looplv1 mkfs.ext3 -J size=64 -b 1024 /dev/loopvg1/looplv1 mount /dev/loopvg1/looplv1 /mnt/loop dd if=/dev/zero of=disk2 seek=1024 count=1 bs=50M losetup /dev/loop2 disk2 pvcreate /dev/loop2 vgextend loopvg1 /dev/loop2 lvextend -l 100%VG /dev/loopvg1/looplv1 resize2fs /dev/loopvg1/looplv1 without this patch the resize2fs fails, with it the resize2fs succeeds. Signed-off-by: Josef Bacik <jbacik@redhat.com> Acked-by: Andreas Dilger <adilger@sun.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06nommu: fix ksize() abusePekka Enberg
The nommu binfmt code uses ksize() for pointers returned from do_mmap() which is wrong. This converts the call-sites to use the nommu specific kobjsize() function which works as expected. Cc: Christoph Lameter <clameter@sgi.com> Cc: Matt Mackall <mpm@selenic.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06pagemap: fix bug in add_to_pagemap, require aligned-length reads of ↵Thomas Tuttle
/proc/pid/pagemap Fix a bug in add_to_pagemap. Previously, since pm->out was a char *, put_user was only copying 1 byte of every PFN, resulting in the top 7 bytes of each PFN not being copied. By requiring that reads be a multiple of 8 bytes, I can make pm->out and pm->end u64*s instead of char*s, which makes put_user work properly, and also simplifies the logic in add_to_pagemap a bit. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Thomas Tuttle <ttuttle@google.com> Cc: Matt Mackall <mpm@selenic.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06devscgroup: check for device permissions at mount timePavel Emelyanov
Currently even if a task sits in an all-denied cgroup it can still mount any block device in any mode it wants. Put a proper check in do_open for block device to prevent this. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Tested-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06introduce memory_read_from_buffer()Akinobu Mita
This patch introduces memory_read_from_buffer(). The only difference between memory_read_from_buffer() and simple_read_from_buffer() is which address space the function copies to. simple_read_from_buffer copies to user space memory. memory_read_from_buffer copies to normal memory. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Doug Warzecha <Douglas_Warzecha@dell.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: Abhay Salunke <Abhay_Salunke@dell.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Markus Rechberger <markus.rechberger@amd.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Bob Moore <robert.moore@intel.com> Cc: Thomas Renninger <trenn@suse.de> Cc: Len Brown <lenb@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Cc: Michael Holzheu <holzheu@de.ibm.com> Cc: Brian King <brking@us.ibm.com> Cc: James E.J. Bottomley <James.Bottomley@HansenPartnership.com> Cc: Andrew Vasquez <linux-driver@qlogic.com> Cc: Seokmann Ju <seokmann.ju@qlogic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06Fix various old email addresses for dwmw2David Woodhouse
Although if people have questions about ARCnet, perhaps it's _better_ for them to be mailing dwmw2@cam.ac.uk about it... Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06eCryptfs: remove unnecessary page decrypt callMichael Halcrow
The page decrypt calls in ecryptfs_write() are both pointless and buggy. Pointless because ecryptfs_get_locked_page() has already brought the page up to date, and buggy because prior mmap writes will just be blown away by the decrypt call. This patch also removes the declaration of a now-nonexistent function ecryptfs_write_zeros(). Thanks to Eric Sandeen and David Kleikamp for helping to track this down. Eric said: fsx w/ mmap dies quickly ( < 100 ops) without this, and survives nicely (to millions of ops+) with it in place. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Eric Sandeen <sandeen@redhat.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06frv: don't offer BINFMT_FLATAdrian Bunk
Fix the following compile error: CC fs/binfmt_flat.o In file included from /home/bunk/linux/kernel-2.6/git/linux-2.6/fs/binfmt_flat.c:36: /home/bunk/linux/kernel-2.6/git/linux-2.6/include/linux/flat.h:14:22: error: asm/flat.h: No such file or directory /home/bunk/linux/kernel-2.6/git/linux-2.6/fs/binfmt_flat.c: In function 'create_flat_tables': /home/bunk/linux/kernel-2.6/git/linux-2.6/fs/binfmt_flat.c:124: error: implicit declaration of function 'flat_stack_align' /home/bunk/linux/kernel-2.6/git/linux-2.6/fs/binfmt_flat.c:125: error: implicit declaration of function 'flat_argvp_envp_on_stack' /home/bunk/linux/kernel-2.6/git/linux-2.6/fs/binfmt_flat.c: In function 'calc_reloc': /home/bunk/linux/kernel-2.6/git/linux-2.6/fs/binfmt_flat.c:347: error: implicit declaration of function 'flat_reloc_valid' /home/bunk/linux/kernel-2.6/git/linux-2.6/fs/binfmt_flat.c: In function 'load_flat_file': /home/bunk/linux/kernel-2.6/git/linux-2.6/fs/binfmt_flat.c:479: error: implicit declaration of function 'flat_old_ram_flag' /home/bunk/linux/kernel-2.6/git/linux-2.6/fs/binfmt_flat.c:755: error: implicit declaration of function 'flat_set_persistent' /home/bunk/linux/kernel-2.6/git/linux-2.6/fs/binfmt_flat.c:757: error: implicit declaration of function 'flat_get_relocate_addr' /home/bunk/linux/kernel-2.6/git/linux-2.6/fs/binfmt_flat.c:765: error: implicit declaration of function 'flat_get_addr_from_rp' /home/bunk/linux/kernel-2.6/git/linux-2.6/fs/binfmt_flat.c:781: error: implicit declaration of function 'flat_put_addr_at_rp' Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Tested-by: David Howells <dhowells@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-05asn1: additional sanity checking during BER decodingChris Wright
- Don't trust a length which is greater than the working buffer. An invalid length could cause overflow when calculating buffer size for decoding oid. - An oid length of zero is invalid and allows for an off-by-one error when decoding oid because the first subid actually encodes first 2 subids. - A primitive encoding may not have an indefinite length. Thanks to Wei Wang from McAfee for report. Cc: Steven French <sfrench@us.ibm.com> Cc: stable@kernel.org Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-04cifs endianness fixesAl Viro
__le16 fields used as host-endian. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Steve French <smfrench@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-31capabilities: remain source compatible with 32-bit raw legacy capability ↵Andrew G. Morgan
support. Source code out there hard-codes a notion of what the _LINUX_CAPABILITY_VERSION #define means in terms of the semantics of the raw capability system calls capget() and capset(). Its unfortunate, but true. Since the confusing header file has been in a released kernel, there is software that is erroneously using 64-bit capabilities with the semantics of 32-bit compatibilities. These recently compiled programs may suffer corruption of their memory when sys_getcap() overwrites more memory than they are coded to expect, and the raising of added capabilities when using sys_capset(). As such, this patch does a number of things to clean up the situation for all. It 1. forces the _LINUX_CAPABILITY_VERSION define to always retain its legacy value. 2. adopts a new #define strategy for the kernel's internal implementation of the preferred magic. 3. deprecates v2 capability magic in favor of a new (v3) magic number. The functionality of v3 is entirely equivalent to v2, the only difference being that the v2 magic causes the kernel to log a "deprecated" warning so the admin can find applications that may be using v2 inappropriately. [User space code continues to be encouraged to use the libcap API which protects the application from details like this. libcap-2.10 is the first to support v3 capabilities.] Fixes issue reported in https://bugzilla.redhat.com/show_bug.cgi?id=447518. Thanks to Bojan Smojver for the report. [akpm@linux-foundation.org: s/depreciate/deprecate/g] [akpm@linux-foundation.org: be robust about put_user size] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andrew G. Morgan <morgan@kernel.org> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Bojan Smojver <bojan@rexursive.com> Cc: stable@kernel.org Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2008-05-30[PATCH 3/3] ocfs2/net: Silence build warningsSunil Mushran
This patch silences the build warnings concerning o2net_init_nst() and friends when building without CONFIG_DEBUG_FS enabled. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-05-30[PATCH 2/3] ocfs2/dlm: Silence build warningsSunil Mushran
This patch silences the build warnings concerning dlm_debug_init() and friends when building without CONFIG_DEBUG_FS enabled. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-05-30[PATCH 1/3] ocfs2/net: Silence build warningsSunil Mushran
This patch silences the build warnings concerning o2net_debugfs_init() and friends when building without CONFIG_DEBUG_FS enabled. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-05-30ocfs2: Rename 'user_stack' plugin structure to 'ocfs2_user_plugin'Joel Becker
The static structure describing the userspace cluster plugin for ocfs2 was named 'user_stack', which is a real pain when people are grep(1)ing the tree for the program stack object 'user_stack'. Change the name to something distinct and namespaced. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-05-28splice: handle try_to_release_page() failureJens Axboe
splice currently assumes that try_to_release_page() always suceeds, but it can return failure. If it does, we cannot steal the page. Acked-by: Mingming Cao <cmm@us.ibm.com Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-28splice: fix sendfile() issue with relayTom Zanussi
Splice isn't always incrementing the ppos correctly, which broke relay splice. Signed-off-by: Tom Zanussi <zanussi@comcast.net> Tested-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-26posix timers: discard SI_TIMER signals on execOleg Nesterov
Based on Roland's patch. This approach was suggested by Austin Clements from the very beginning, and then by Linus. As Austin pointed out, the execing task can be killed by SI_TIMER signal because exec flushes the signal handlers, but doesn't discard the pending signals generated by posix timers. Perhaps not a bug, but people find this surprising. See http://bugzilla.kernel.org/show_bug.cgi?id=10460 Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Austin Clements <amdragon+kernelbugzilla@mit.edu> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24proc: proc_get_inode() should get module only onceDenis V. Lunev
Any file under /proc/net opened more than once leaked the refcounter on the module it belongs to. The problem is that module_get is called for each file opening while module_put is called only when /proc inode is destroyed. So, lets put module counter if we are dealing with already initialised inode. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=10737 Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: David Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Acked-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Robert Olsson <robert.olsson@its.uu.se> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Reported-by: Roland Kletzing <devzero@web.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24mm: fix atomic_t overflow in vmAlan Cox
The atomic_t type is 32bit but a 64bit system can have more than 2^32 pages of virtual address space available. Without this we overflow on ludicrously large mappings Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24ntfs: le*_add_cpu conversionMarcin Slusarz
replace all: little_endian_variable = cpu_to_leX(leX_to_cpu(little_endian_variable) + expression_in_cpu_byteorder); with: leX_add_cpu(&little_endian_variable, expression_in_cpu_byteorder); generated with semantic patch Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24ecryptfs: fix missed mutex_unlockCyrill Gorcunov
Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24fuse: fix bdi naming conflictMiklos Szeredi
Fuse allocates a separate bdi for each filesystem, and registers them in sysfs with "MAJOR:MINOR" of sb->s_dev (st_dev). This works fine for anon devices normally used by fuse, but can conflict with an already registered BDI for "fuseblk" filesystems, where sb->s_dev represents a real block device. In particularl this happens if a non-partitioned device is being mounted. Fix by registering with a different name for "fuseblk" filesystems. Thanks to Ioan Ionita for the bug report. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Reported-by: Ioan Ionita <opslynx@gmail.com> Tested-by: Ioan Ionita <opslynx@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-23Merge branch 'for-linus' of git://oss.sgi.com:8090/xfs/xfs-2.6Linus Torvalds
* 'for-linus' of git://oss.sgi.com:8090/xfs/xfs-2.6: [XFS] Fix memory corruption with small buffer reads [XFS] Fix inode list allocation size in writeback. [XFS] Don't allow memory reclaim to wait on the filesystem in inode [XFS] Fix fsync() b0rkage. [XFS] Include linux/random.h in all builds, not just debug builds.
2008-05-23[XFS] Fix memory corruption with small buffer readsChristoph Hellwig
When we have multiple buffers in a single page for a blocksize == pagesize filesystem we might overwrite the page contents if two callers hit it shortly after each other. To prevent that we need to keep the page locked until I/O is completed and the page marked uptodate. Thanks to Eric Sandeen for triaging this bug and finding a reproducible testcase and Dave Chinner for additional advice. This should fix kernel.org bz #10421. Tested-by: Eric Sandeen <sandeen@sandeen.net> SGI-PV: 981813 SGI-Modid: xfs-linux-melb:xfs-kern:31173a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-05-23[XFS] Fix inode list allocation size in writeback.David Chinner
We only need to allocate space for the number of inodes in the cluster when writing back inodes, not every byte in the inode cluster. This reduces the amount of memory needing to be allocated to 256 bytes instead of 64k. SGI-PV: 981949 SGI-Modid: xfs-linux-melb:xfs-kern:31182a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-05-23[XFS] Don't allow memory reclaim to wait on the filesystem in inodeDavid Chinner
writeback If we allow memory reclaim to wait on the pages under writeback in inode cluster writeback we could deadlock because we are currently holding the ILOCK on the initial writeback inode which is needed in data I/O completion to change the file size or do unwritten extent conversion before the pages are taken out of writeback state. SGI-PV: 981091 SGI-Modid: xfs-linux-melb:xfs-kern:31015a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-05-23[XFS] Fix fsync() b0rkage.David Chinner
xfs_fsync() fails to wait for data I/O completion before checking if the inode is dirty or clean to decide whether to log the inode or not. This misses inode size updates when the data flushed by the fsync() is extending the file. Hence, like fdatasync(), we need to wait for I/o completion first, then check the inode for cleanliness. Doing so makes the behaviour of xfs_fsync() identical for fsync and fdatasync and we *always* use synchronous semantics if the inode is dirty. Therefore also kill the differences and remove the unused flags from the xfs_fsync function and callers. SGI-PV: 981296 SGI-Modid: xfs-linux-melb:xfs-kern:31033a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-05-22[CIFS] Fix reversed memset argumentsDave Jones
Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-22Adds username in the upcall key for unattended mounts with keytabIgor Mammedov
Signed-off-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-22[CIFS] Remove redundant NULL checkSteve French
Noticed by Coverity checker. Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-21ocfs2 endianness fixesAl Viro
2008-05-21ecryptfs fixesAl Viro
memcpy() from userland pointer is a Bad Thing(tm) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-21fix hppfs Makefile breakageAl Viro
Fallout from commit 46d7b522ebf486edbd096965d534cc6465e9e309 ("uml: move hppfs_kern.c to hppfs.c") Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: (21 commits) [CIFS] Remove debug statement Fix possible access to undefined memory region. [CIFS] Enable DFS support for Windows query path info [CIFS] Enable DFS support for Unix query path info [CIFS] add missing seq_printf to cifs_show_options for hard mount option [CIFS] add more complete mount options to cifs_show_options [CIFS] Add missing defines for DFS CIFSGetDFSRefer cleanup + dfs_referral_level_3 fixed to conform REFERRAL_V3 the MS-DFSC spec. Fixed DFS code to work with new 'build_path_from_dentry', that returns full path if share in the dfs, now. [CIFS] enable parsing for transport encryption mount parm [CIFS] Finishup DFS code [CIFS] BKL-removal: convert CIFS over to unlocked_ioctl [CIFS] suppress duplicate warning [CIFS] Fix paths when share is in DFS to include proper prefix add function to convert access flags to legacy open mode clarify return value of cifs_convert_flags() [CIFS] don't explicitly do a FindClose on rewind when directory search has ended [CIFS] cleanup old checkpatch warnings [CIFS] CIFSSMBPosixLock should return -EINVAL on error fix memory leak in CIFSFindNext ...
2008-05-21[CIFS] Remove debug statementSteve French
2008-05-21Fix possible access to undefined memory region.Igor Mammedov
2008-05-20Merge branch 'for-2.6.26' of git://linux-nfs.org/~bfields/linuxtip-x86-xsave-2008-05-26_08_54_Montip-x86-cpu-2008-05-26_08_53_MonLinus Torvalds
* 'for-2.6.26' of git://linux-nfs.org/~bfields/linux: (25 commits) svcrdma: Verify read-list fits within RPCSVC_MAXPAGES svcrdma: Change svc_rdma_send_error return type to void svcrdma: Copy transport address and arm CQ before calling rdma_accept svcrdma: Set rqstp transport address in rdma_read_complete function svcrdma: Use ib verbs version of dma_unmap svcrdma: Cleanup queued, but unprocessed I/O in svc_rdma_free svcrdma: Move the QP and cm_id destruction to svc_rdma_free svcrdma: Add reference for each SQ/RQ WR svcrdma: Move destroy to kernel thread svcrdma: Shrink scope of spinlock on RQ CQ svcrdma: Use standard Linux lists for context cache svcrdma: Simplify RDMA_READ deferral buffer management svcrdma: Remove unused READ_DONE context flags bit svcrdma: Return error from rdma_read_xdr so caller knows to free context svcrdma: Fix error handling during listening endpoint creation svcrdma: Free context on post_recv error in send_reply svcrdma: Free context on ib_post_recv error svcrdma: Add put of connection ESTABLISHED reference in rdma_cma_handler svcrdma: Fix return value in svc_rdma_send svcrdma: Fix race with dto_tasklet in svc_rdma_send ...
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) pktgen: make sure that pktgen_thread_worker has been executed [VLAN]: Propagate selected feature bits to VLAN devices drivers/atm/: remove CVS keywords vlan: Correctly handle device notifications for layered VLAN devices net: Fix call to ->change_rx_flags(dev, IFF_MULTICAST) in dev_change_flags() net_sched: cls_api: fix return value for non-existant classifiers ipsec: Use the correct ip_local_out function ipv6 addrconf: Allow infinite prefix lifetime. ipv6 route: Fix lifetime in netlink. ipv6 addrconf: Fix route lifetime setting in corner case. ndisc: Add missing strategies for per-device retrans timer/reachable time settings. ipv6: Move <linux/in6.h> from header-y to unifdef-y. l2tp: avoid skb truesize bug if headroom is increased wireless: Create 'device' symlink in sysfs wireless, airo: waitbusy() won't delay libertas: fix command timeout after firmware failure mac80211: Add RTNL version of ieee80211_iterate_active_interfaces mac80211 : Association with 11n hidden ssid ap. hostap: fix "registers" registration in procfs isdn/capi: Return proper errnos on module init. ...
2008-05-20[CIFS] Enable DFS support for Windows query path infoSteve French
Final piece for handling DFS in query_path_info, constructing a fake inode for the junction directory which the submount will cover. This handles the non-Unix (Windows etc.) code path. Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-20[CIFS] Enable DFS support for Unix query path infoSteve French
Final piece for handling DFS in unix_query_path_info, constructing a fake inode for the junction directory which the submount will cover. Acked-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixes: [GFS2] Prefer strlcpy() over snprintf() [GFS2] Fix cast from unsigned int to s64 [GFS2] filesystem consistency error from do_strip
2008-05-19Merge branch 'audit.b51' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b51' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: [PATCH] list_for_each_rcu must die: audit [patch 1/1] audit_send_reply(): fix error-path memory leak [PATCH] open sessionid permissions
2008-05-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: [PATCH] return to old errno choice in mkdir() et.al. [Patch] fs/binfmt_elf.c: fix wrong return values [PATCH] get rid of leak in compat_execve() [Patch] fs/binfmt_elf.c: fix a wrong free [PATCH] avoid multiplication overflows and signedness issues for max_fds [PATCH] dup_fd() part 4 - race fix [PATCH] dup_fd() - part 3 [PATCH] dup_fd() part 2 [PATCH] dup_fd() fixes, part 1 [PATCH] take init_files to fs/file.c
2008-05-19[CIFS] add missing seq_printf to cifs_show_options for hard mount optionSteve French
Also Kari Hurtta noticed a missing check in the same function which is now fixed. CC: Kari Hurtta <hurtta+gmane@siilo.fmi.fi> Signed-off-by: Steve French <sfrench@us.ibm.com>
