path: root/fs
2009-11-12__generic_block_fiemap(): fix for files bigger than 4GBMike Hommey
Because of an integer overflow on start_blk, various kind of wrong results would be returned by the generic_block_fiemap() handler, such as no extents when there is a 4GB+ hole at the beginning of the file, or wrong fe_logical when an extent starts after the first 4GB. Signed-off-by: Mike Hommey <mh@glandium.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Eric Sandeen <sandeen@sgi.com> Cc: Josef Bacik <jbacik@redhat.com> Cc: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12exec: setup_arg_pages() fails to return errorsAnton Blanchard
In setup_arg_pages we work hard to assign a value to ret, but on exit we always return 0. Also remove a now duplicated exit path and branch to out_unlock instead. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12fs: add missing compat_ptr handling for FS_IOC_RESVSP ioctlHeiko Carstens
For FS_IOC_RESVSP and FS_IOC_RESVSP64 compat_sys_ioctl() uses its arg argument as a pointer to userspace. However it is missing a a call to compat_ptr() which will do a proper pointer conversion. This was introduced with 3e63cbb1 "fs: Add new pre-allocation ioctls to vfs for compatibility with legacy xfs ioctls". Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ankit Jain <me@ankitjain.org> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Arnd Bergmann <arndbergmann@googlemail.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: <stable@kernel.org> [2.6.31.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12pidns: fix a leak in /proc dentries and inodes with pid namespaces.Sukadev Bhattiprolu
Daniel Lezcano reported a leak in 'struct pid' and 'struct pid_namespace' that is discussed in: http://lkml.org/lkml/2009/10/2/159. To summarize the thread, when container-init is terminated, it sets the PF_EXITING flag, zaps other processes in the container and waits to reap them. As a part of reaping, the container-init should flush any /proc dentries associated with the processes. But because the container-init is itself exiting and the following PF_EXITING check, the dentries are not flushed, resulting in leak in /proc inodes and dentries. This fix reverts the commit 7766755a2f249e7e0 ("Fix /proc dcache deadlock in do_exit") which introduced the check for PF_EXITING. At the time of the commit, shrink_dcache_parent() flushed dentries from other filesystems also and could have caused a deadlock which the commit fixed. But as pointed out by Eric Biederman, after commit 0feae5c47aabdde59, shrink_dcache_parent() no longer affects other filesystems. So reverting the commit is now safe. As pointed out by Jan Kara, the leak is not as critical since the unclaimed space will be reclaimed under memory pressure or by: echo 3 > /proc/sys/vm/drop_caches But since this check is no longer required, its best to remove it. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Reported-by: Daniel Lezcano <dlezcano@fr.ibm.com> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Jan Kara <jack@ucw.cz> Cc: Andrea Arcangeli <andrea@cpushare.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12fs/jbd: Export log_start_commit to fix ext3 build.Stefan Schmidt
This fixes: ERROR: "log_start_commit" [fs/ext3/ext3.ko] undefined! Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
2009-11-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: fix panic when trying to destroy a newly allocated Btrfs: allow more metadata chunk preallocation Btrfs: fallback on uncompressed io if compressed io fails Btrfs: find ideal block group for caching Btrfs: avoid null deref in unpin_extent_cache() Btrfs: skip btrfs_release_path in btrfs_update_root and btrfs_del_root Btrfs: fix some metadata enospc issues Btrfs: fix how we set max_size for free space clusters Btrfs: cleanup transaction starting and fix journal_info usage Btrfs: fix data allocation hint start
2009-11-11Btrfs: fix panic when trying to destroy a newly allocatedJosef Bacik
There is a problem where iget5_locked will look for an inode, not find it, and then subsequently try to allocate it. Another CPU will have raced in and allocated the inode instead, so when iget5_locked gets the inode spin lock again and does a search, it finds the new inode. So it goes ahead and calls destroy_inode on the inode it just allocated. The problem is we don't set BTRFS_I(inode)->root until the new inode is completely initialized. This patch makes us set root to NULL when alloc'ing a new inode, so when we get to btrfs_destroy_inode and we see that root is NULL we can just free up the memory and continue on. This fixes the panic http://www.kerneloops.org/submitresult.php?number=812690 Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-11-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: JBD/JBD2: free j_wbuf if journal init fails. ext3: Wait for proper transaction commit on fsync ext3: retry failed direct IO allocations
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: partial revert to fix double brelse WARNING() ext4: Fix return value of ext4_split_unwritten_extents() to fix direct I/O ext4: code clean up for dio fallocate handling ext4: skip conversion of uninit extents after direct IO if there isn't any ext4: fix ext4_ext_direct_IO()'s return value after converting uninit extents ext4: discard preallocation when restarting a transaction during truncate
2009-11-11Btrfs: allow more metadata chunk preallocationChris Mason
On an FS where all of the space has not been allocated into chunks yet, the enospc can return enospc just because the existing metadata chunks are full. We get around this by allowing more metadata chunks to be allocated up to a certain limit, and finding the right limit is a little fuzzy. The problem is the reservations for delalloc would preallocate way too much of the FS as metadata. We need to start saying no and just force some IO to happen. But we also need to let a reasonable amount of the FS become metadata. This bumps the hard limit up, later releases will have a better system. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-11-11Btrfs: fallback on uncompressed io if compressed io failsJosef Bacik
Currently compressed IO does not deal with not having its entire extent able to be allocated. So if we have enough free space to allocate for the extent, but its not contiguous, it will fail spectacularly. This patch fixes this by falling back on uncompressed IO which lets us spread the delalloc extent across multiple extents. I tested this by making us randomly think the reservation had failed to make it fallback on the uncompressed io way and it seemed to work fine. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-11-11Btrfs: find ideal block group for cachingJosef Bacik
This patch changes a few things. Hopefully the comments are helpfull, but I'll try and be as verbose here. Problem: My fedora box was taking 1 minute and 21 seconds to boot with btrfs as root. Part of this problem was we pick the first block group we can find and start caching it, even if it may not have enough free space. The other problem is we only search for cached block groups the first time around, which we won't find any cached block groups because this is a newly mounted fs, so we end up caching several block groups during bootup, which with alot of fragmentation takes around 30-45 seconds to complete, which bogs down the system. So Solution: 1) Don't cache block groups willy-nilly at first. Instead try and figure out which block group has the most free, and therefore will take the least amount of time to cache. 2) Don't be so picky about cached block groups. The other problem is once we've filled up a cluster, if the block group isn't finished caching the next time we try and do the allocation we'll completely ignore the cluster and start searching from the beginning of the space, which makes us cache more block groups, which slows us down even more. So instead of skipping block groups that are not finished caching when we have a hint, only skip the block group if it hasn't started caching yet. There is one other tweak in here. Before if we allocated a chunk and still couldn't find new space, we'd end up switching the space info to force another chunk allocation. This could make us end up with way too many chunks, so keep track of this particular case. With this patch and my previous cluster fixes my fedora box now boots in 43 seconds, and according to the bootchart is not held up by our block group caching at all. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-11-11Btrfs: avoid null deref in unpin_extent_cache()Dan Carpenter
I re-orderred the checks to avoid dereferencing "em" if it was null. Found by smatch static checker. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-11-11Btrfs: skip btrfs_release_path in btrfs_update_root and btrfs_del_rootLi Dongyang
We don't need to call btrfs_release_path because btrfs_free_path will do that for us. Signed-off-by: Li Dongyang <Jerry87905@gmail.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-11-11Btrfs: fix some metadata enospc issuesJosef Bacik
We weren't reserving metadata space for rename, rmdir and unlink, which could cause problems. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-11-11Btrfs: fix how we set max_size for free space clustersJosef Bacik
This patch fixes a problem where max_size can be set to 0 even though we filled the cluster properly. We set max_size to 0 if we restart the cluster window, but if the new start entry is big enough to be our new cluster then we could return with a max_size set to 0, which will mean the next time we try to allocate from this cluster it will fail. So set max_extent to the entry's size. Tested this on my box and now we actually allocate from the cluster after we fill it. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-11-11Btrfs: cleanup transaction starting and fix journal_info usageJosef Bacik
We use journal_info to tell if we're in a nested transaction to make sure we don't commit the transaction within a nested transaction. We use another method to see if there are any outstanding ioctl trans handles, so if we're starting one do not set current->journal_info, since it will screw with other filesystems. This patch also cleans up the starting stuff so there aren't any magic numbers. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-11-11Btrfs: fix data allocation hint startJosef Bacik
Sometimes our start allocation hint when we cow a file can be either EXTENT_HOLE or some other such place holder, which is not optimal. So if we find that our em->block_start is one of these special values, check to see where the first block of the inode is stored, and use that as a hint. If that block is also a special value, just fallback on a hint of 0 and let the allocator figure out a good place to put the data. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-11-11JBD/JBD2: free j_wbuf if journal init fails.Tao Ma
If journal init fails, we need to free j_wbuf. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-11-11ext3: Wait for proper transaction commit on fsyncJan Kara
We cannot rely on buffer dirty bits during fsync because pdflush can come before fsync is called and clear dirty bits without forcing a transaction commit. What we do is that we track which transaction has last changed the inode and which transaction last changed allocation and force it to disk on fsync. Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2009-11-11ext3: retry failed direct IO allocationsEric Sandeen
On a 256M 4k block filesystem, doing this in a loop: dd if=/dev/zero of=test oflag=direct bs=1M count=64 rm -f test eventually leads to spurious ENOSPC: dd: writing `test': No space left on device As with other block allocation callers, it looks like we need to potentially retry the allocations on the initial ENOSPC. A similar patch went into ext4 (commit fbbf69456619de5d251cb9f1df609069178c62d5) Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-11-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: nilfs2: fix missing cleanup of gc cache on error cases nilfs2: fix kernel oops in error case of nilfs_ioctl_move_blocks
2009-11-08ext4: partial revert to fix double brelse WARNING()Theodore Ts'o
This is a partial revert of commit 6487a9d (only the changes made to fs/ext4/namei.c), since it is causing the following brelse() double-free warning when running fsstress on a file system with 1k blocksize and we run into a block allocation failure while converting a single-block directory to a multi-block hash-tree indexed directory. WARNING: at fs/buffer.c:1197 __brelse+0x2e/0x33() Hardware name: VFS: brelse: Trying to free free buffer Modules linked in: Pid: 2226, comm: jbd2/sdd-8 Not tainted 2.6.32-rc6-00577-g0003f55 #101 Call Trace: [<c01587fb>] warn_slowpath_common+0x65/0x95 [<c0158869>] warn_slowpath_fmt+0x29/0x2c [<c021168e>] __brelse+0x2e/0x33 [<c0288a9f>] jbd2_journal_refile_buffer+0x67/0x6c [<c028a9ed>] jbd2_journal_commit_transaction+0x319/0x14d8 [<c0164d73>] ? try_to_del_timer_sync+0x58/0x60 [<c0175bcc>] ? sched_clock_cpu+0x12a/0x13e [<c017f6b4>] ? trace_hardirqs_off+0xb/0xd [<c0175c1f>] ? cpu_clock+0x3f/0x5b [<c017f6ec>] ? lock_release_holdtime+0x36/0x137 [<c0664ad0>] ? _spin_unlock_irqrestore+0x44/0x51 [<c0180af3>] ? trace_hardirqs_on_caller+0x103/0x124 [<c0180b1f>] ? trace_hardirqs_on+0xb/0xd [<c0164d73>] ? try_to_del_timer_sync+0x58/0x60 [<c0290d1c>] kjournald2+0x11a/0x310 [<c017118e>] ? autoremove_wake_function+0x0/0x38 [<c0290c02>] ? kjournald2+0x0/0x310 [<c0170ee6>] kthread+0x66/0x6b [<c0170e80>] ? kthread+0x0/0x6b [<c01251b3>] kernel_thread_helper+0x7/0x10 ---[ end trace 5579351b86af61e3 ]--- Commit 6487a9d was an attempt some buffer head leaks in an ENOSPC error path, but in some cases it actually results in an excess ENOSPC, as shown above. Fixing this means cleaning up who is responsible for releasing the buffer heads from the callee to the caller of add_dirent_to_buf(). Since that's a relatively complex change, and we're late in the rcX development cycle, I'm reverting this now, and holding back a more complete fix until after 2.6.32 ships. We've lived with this buffer_head leak on ENOSPC in ext3 and ext4 for a very long time; a few more months won't kill us. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Curt Wohlgemuth <curtw@google.com>
2009-11-08nilfs2: fix missing cleanup of gc cache on error casesRyusuke Konishi
This fixes an -rc1 regression brought by the commit: 1cf58fa840472ec7df6bf2312885949ebb308853 ("nilfs2: shorten freeze period due to GC in write operation v3"). Although the patch moved out a function call of nilfs_ioctl_move_blocks() to nilfs_ioctl_clean_segments() from nilfs_ioctl_prepare_clean_segments(), it didn't move corresponding cleanup job needed for the error case. This will move the missing cleanup job to the destination function. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: Jiro SEKIBA <jir@unicus.jp>
2009-11-08nilfs2: fix kernel oops in error case of nilfs_ioctl_move_blocksRyusuke Konishi
This fixes a kernel oops reported by Markus Trippelsdorf in the email titled "[NILFS users] kernel Oops while running nilfs_cleanerd". The oops was caused by a bug of error path in nilfs_ioctl_move_blocks() function, which was inlined in nilfs_ioctl_clean_segments(). nilfs_ioctl_move_blocks checks duplication of blocks which will be moved in garbage collection. But, the check should have be done within nilfs_ioctl_move_inode_block() to prevent list corruption among buffers storing the target blocks. To fix the kernel oops, this moves forward the duplication check before the list insertion. I also tested this for stable trees [2.6.30, 2.6.31]. Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: stable <stable@kernel.org>
2009-11-06cifs: don't use CIFSGetSrvInodeNumber in is_path_accessibleJeff Layton
Because it's lighter weight, CIFS tries to use CIFSGetSrvInodeNumber to verify the accessibility of the root inode and then falls back to doing a full QPathInfo if that fails with -EOPNOTSUPP. I have at least a report of a server that returns NT_STATUS_INTERNAL_ERROR rather than something that translates to EOPNOTSUPP. Rather than trying to be clever with that call, just have is_path_accessible do a normal QPathInfo. That call is widely supported and it shouldn't increase the overhead significantly. Cc: Stable <stable@kernel.org> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-11-06cifs: clean up handling when server doesn't consistently support inode numbersJeff Layton
It's possible that a server will return a valid FileID when we query the FILE_INTERNAL_INFO for the root inode, but then zeroed out inode numbers when we do a FindFile with an infolevel of SMB_FIND_FILE_ID_FULL_DIR_INFO. In this situation turn off querying for server inode numbers, generate a warning for the user and just generate an inode number using iunique. Once we generate any inode number with iunique we can no longer use any server inode numbers or we risk collisions, so ensure that we don't do that in cifs_get_inode_info either. Cc: Stable <stable@kernel.org> Reported-by: Timothy Normand Miller <theosib@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-11-06ext4: Fix return value of ext4_split_unwritten_extents() to fix direct I/OMingming
To prepare for a direct I/O write, we need to split the unwritten extents before submitting the I/O. When no extents needed to be split, ext4_split_unwritten_extents() was incorrectly returning 0 instead of the size of uninitialized extents. This bug caused the wrong return value sent back to VFS code when it gets called from async IO path, leading to an unnecessary fall back to buffered IO. This bug also hid the fact that the check to see whether or not a split would be necessary was incorrect; we can only skip splitting the extent if the write completely covers the uninitialized extent. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-11-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: invalidate target of rename fuse: fix kunmap in fuse_ioctl_copy_user fuse: prevent fuse_put_request on invalid pointer
2009-11-05Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/kvm: Remove problematic BUILD_BUG_ON statement powerpc/pci: Fix regression in powerpc MSI-X powerpc: Avoid giving out RTC dates below EPOCH powerpc/mm: Remove debug context clamping from nohash code powerpc: Cleanup Kconfig selection of hugetlbfs support
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: sysfs: Don't leak secdata when a sysfs_dirent is freed.
2009-11-05Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, fs: Fix x86 procfs stack information for threads on 64-bit x86: Add reboot quirk for 3 series Mac mini x86: Fix printk message typo in mtrr cleanup code dma-debug: Fix compile warning with PAE enabled x86/amd-iommu: Un__init function required on shutdown x86/amd-iommu: Workaround for erratum 63
2009-11-05sysfs: Don't leak secdata when a sysfs_dirent is freed.Eric W. Biederman
While refreshing my sysfs patches I noticed a leak in the secdata implementation. We don't free the secdata when we free the sysfs dirent. This is a bug in 2.6.32-rc5 that we really should close. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-11-04x86, fs: Fix x86 procfs stack information for threads on 64-bitStefani Seibold
This patch fixes two issues in the procfs stack information on x86-64 linux. The 32 bit loader compat_do_execve did not store stack start. (this was figured out by Alexey Dobriyan). The stack information on a x64_64 kernel always shows 0 kbyte stack usage, because of a missing implementation of the KSTK_ESP macro which always returned -1. The new implementation now returns the right value. Signed-off-by: Stefani Seibold <stefani@seibold.net> Cc: Americo Wang <xiyou.wangcong@gmail.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <1257240160.4889.24.camel@wall-e> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-04fuse: invalidate target of renameMiklos Szeredi
Invalidate the target's attributes, which may have changed (such as nlink, change time) so that they are refreshed on the next getattr(). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2009-11-04fuse: fix kunmap in fuse_ioctl_copy_userJens Axboe
Looks like another victim of the confusing kmap() vs kmap_atomic() API differences. Reported-by: Todor Gyumyushev <yodor1@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: stable@kernel.org
2009-11-04fuse: prevent fuse_put_request on invalid pointerAnand V. Avati
fuse_direct_io() has a loop where requests are allocated in each iteration. if allocation fails, the loop is broken out and follows into an unconditional fuse_put_request() on that invalid pointer. Signed-off-by: Anand V. Avati <avati@gluster.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: stable@kernel.org
2009-11-03Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: cfq-iosched: limit coop preemption cfq-iosched: fix bad return value cfq_should_preempt() backing-dev: bdi sb prune should be in the unregister path, not destroy Fix bio_alloc() and bio_kmalloc() documentation bio_put(): add bio_clone() to the list of functions in the comment
2009-11-03ext4: code clean up for dio fallocate handlingMingming
The ext4_debug() call in ext4_end_io_dio() should be moved after the check to make sure that io_end is non-NULL. The comment above ext4_get_block_dio_write() ("Maximum number of blocks...") is a duplicate; the original and correct comment is above the #define DIO_MAX_BLOCKS up above. Based on review comments from Curt Wohlgemuth. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-11-10ext4: skip conversion of uninit extents after direct IO if there isn't anyMingming
At the end of direct I/O operation, ext4_ext_direct_IO() always called ext4_convert_unwritten_extents(), regardless of whether there were any unwritten extents involved in the I/O or not. This commit adds a state flag so that ext4_ext_direct_IO() only calls ext4_convert_unwritten_extents() when necessary. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-11-10ext4: fix ext4_ext_direct_IO()'s return value after converting uninit extentsMingming
After a direct I/O request covering an uninitalized extent (i.e., created using the fallocate system call) or a hole in a file, ext4 will convert the uninitialized extent so it is marked as initialized by calling ext4_convert_unwritten_extents(). This function returns zero on success. This return value was getting returned by ext4_direct_IO(); however the file system's direct_IO function is supposed to return the number of bytes read or written on a success. By returning zero, it confused the direct I/O code into falling back to buffered I/O unnecessarily. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-11-03nilfs2: add zero-fill for new btree node buffersRyusuke Konishi
Adds missing initialization of newly allocated b-tree node buffers. This avoids garbage data to be mixed in b-tree node blocks. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-11-03nilfs2: fix irregular checkpoint creation due to data flushRyusuke Konishi
When nilfs flushes out dirty data to reduce memory pressure, creation of checkpoints is wrongly postponed. This bug causes irregular checkpoint creation especially in small footprint systems. To correct this issue, a timer for the checkpoint creation has to be continued if a log writer does not create a checkpoint. This will do the correction. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-11-03nilfs2: fix dirty page accounting leak causing hang at writeRyusuke Konishi
Bruno Prémont and Dunphy, Bill noticed me that NILFS will certainly hang on ARM-based targets. I found this was caused by an underflow of dirty pages counter. A b-tree cache routine was marking page dirty without adjusting page account information. This fixes the dirty page accounting leak and resolves the hang on arm-based targets. Reported-by: Bruno Prémont <bonbons@linux-vserver.org> Reported-by: Dunphy, Bill <WDunphy@tandbergdata.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Bruno Prémont <bonbons@linux-vserver.org> Cc: stable <stable@kernel.org>
2009-11-02ext4: discard preallocation when restarting a transaction during truncateAneesh Kumar K.V
When restart a transaction during a truncate operation, we drop and reacquire i_data_sem. After reacquiring i_data_sem, we need to discard any inode-based preallocation that might have been grabbed while we released i_data_sem (for example, if pdflush is allocating blocks and racing against the truncate). Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-11-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: fix readdir corner cases 9p: fix readlink 9p: fix a small bug in readdir for long directories
2009-11-02Revert "ext4: Remove journal_checksum mount option and enable it by default"Linus Torvalds
This reverts commit d0646f7b636d067d715fab52a2ba9c6f0f46b0d7, as requested by Eric Sandeen. It can basically cause an ext4 filesystem to miss recovery (and thus get mounted with errors) if the journal checksum does not match. Quoth Eric: "My hand-wavy hunch about what is happening is that we're finding a bad checksum on the last partially-written transaction, which is not surprising, but if we have a wrapped log and we're doing the initial scan for head/tail, and we abort scanning on that bad checksum, then we are essentially running an unrecovered filesystem. But that's hand-wavy and I need to go look at the code. We lived without journal checksums on by default until now, and at this point they're doing more harm than good, so we should revert the default-changing commit until we can fix it and do some good power-fail testing with the fixes in place." See http://bugzilla.kernel.org/show_bug.cgi?id=14354 for all the gory details. Requested-by: Eric Sandeen <sandeen@redhat.com> Cc: Theodore Tso <tytso@mit.edu> Cc: Alexey Fisher <bug-track@fisher-privat.net> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Mathias Burén <mathias.buren@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-029p: fix readdir corner casesEric Van Hensbergen
The patch below also addresses a couple of other corner cases in readdir seen with a large (e.g. 64k) msize. I'm not sure what people think of my co-opting of fid->aux here. I'd be happy to rework if there's a better way. When the size of the user supplied buffer passed to readdir is smaller than the data returned in one go by the 9P read request, v9fs_dir_readdir() currently discards extra data so that, on the next call, a 9P read request will be issued with offset < previous offset + bytes returned, which voilates the constraint described in paragraph 3 of read(5) description. This patch preseves the leftover data in fid->aux for use in the next call. Signed-off-by: Jim Garlick <garlick@llnl.gov> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2009-11-029p: fix readlinkMartin Stava
I do not know if you've looked on the patch, but unfortunately it is incorrect. A suggested better version is in this email (the old version didn't work in case the user provided buffer was not long enough - it incorrectly appended null byte on a position of last char, and thus broke the contract of the readlink method). However, I'm still not sure this is 100% correct thing to do, I think readlink is supposed to return buffer without last null byte in all cases, but we do return last null byte (even the old version).. on the other hand it is likely unspecified what is in the remaining part of the buffer, so null character may be fine there ;): Signed-off-by: Martin Stava <martin.stava@gmail.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2009-11-029p: fix a small bug in readdir for long directoriesMartin Stava
Here is a proposed patch for bug in readdir. Listing of dirs with many files fails without this patch. Signed-off-by: Martin Stava <martin.stava@gmail.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
