toradex_4.9-2.3.x-imx-next
sound/soc/codecs/sgtl5000.c
sound/soc/fsl/imx-sgtl5000.c
This is the 4.9.220 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/common.h
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm/mach-imx/suspend-imx6.S
block/blk-core.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/host/sdhci.c
drivers/net/can/flexcan.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/phy/phy_device.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/tty/serial/imx.c
drivers/usb/dwc3/gadget.c
drivers/usb/host/xhci.c
include/linux/blkdev.h
include/linux/cpu.h
include/linux/platform_data/dma-imx-sdma.h
kernel/cpu.c
net/wireless/util.c
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
sound/soc/fsl/fsl_sai.c
[ Upstream commit 32302085a8d90859c40cf1a5e8313f575d06ec75 ]
Fix a debug-only build error in ext2/xattr.c:
When building without extra debugging, (and with another patch that uses
no_printk() instead of <empty> for the ext2-xattr debug-print macros,
this build error happens:
../fs/ext2/xattr.c: In function ‘ext2_xattr_cache_insert’:
../fs/ext2/xattr.c:869:18: error: ‘ext2_xattr_cache’ undeclared (first use in
this function); did you mean ‘ext2_xattr_list’?
atomic_read(&ext2_xattr_cache->c_entry_count));
Fix the problem by removing cached entry count from the debug message
since otherwise we'd have to export the mbcache structure just for that.
Fixes: be0726d33cb8 ("ext2: convert to mbcache2")
Reported-by: Randy Dunlap <rdunlap@infradead.org>
[ Upstream commit 44a52022e7f15cbaab957df1c14f7a4f527ef7cf ]
When EXT2_ATTR_DEBUG is not defined, modify the 2 debug macros
to use the no_printk() macro instead of <nothing>.
This fixes gcc warnings when -Wextra is used:
../fs/ext2/xattr.c:252:42: warning: suggest braces around empty body in an ‘if’ statement [-Wempty-body]
../fs/ext2/xattr.c:258:42: warning: suggest braces around empty body in an ‘if’ statement [-Wempty-body]
../fs/ext2/xattr.c:330:42: warning: suggest braces around empty body in an ‘if’ statement [-Wempty-body]
../fs/ext2/xattr.c:872:45: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body]
I have verified that the only object code change (with gcc 7.5.0) is
the reversal of some instructions from 'cmp a,b' to 'cmp b,a'.
Link: https://lore.kernel.org/r/e18a7395-61fb-2093-18e8-ed4f8cf56248@infradead.org
Cc: Jan Kara <jack@suse.com>
Cc: linux-ext4@vger.kernel.org
[ Upstream commit 862f35c94730c9270833f3ad05bd758a29f204ed ]
If we just set the mirror count to 1 without first clearing out
the mirrors, we can leak queued up requests.
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
[ Upstream commit c96e2b8564adfb8ac14469ebc51ddc1bfecb3ae2 ]
Under some circumstances we may encounter a filesystem error on a
read-only block device, and if we try to save the error info to the
superblock and commit it, we'll wind up with a noisy error and
backtrace, i.e.:
[ 3337.146838] EXT4-fs error (device pmem1p2): ext4_get_journal_inode:4634: comm mount: inode #0: comm mount: iget: illegal inode #
generic_make_request: Trying to write to read-only block-device pmem1p2 (partno 2)
WARNING: CPU: 107 PID: 115347 at block/blk-core.c:788 generic_make_request_checks+0x6b4/0x7d0
To avoid this, commit the error info in the superblock only if the
block device is writable.
Reported-by: Ritesh Harjani <riteshh@linux.ibm.com>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
Link: https://lore.kernel.org/r/4b6e774d-cc00-3469-7abb-108eb151071a@sandeen.net
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
[ Upstream commit 8605cf0e852af3b2c771c18417499dc4ceed03d5 ]
When dreq is allocated by nfs_direct_req_alloc(), dreq->kref is
initialized to 2. Therefore we need to call nfs_direct_req_release()
twice to release the allocated dreq. Usually it is called in
nfs_file_direct_{read, write}() and nfs_direct_complete().
However, current code only calls nfs_direct_req_relese() once if
nfs_get_lock_context() fails in nfs_file_direct_{read, write}().
So, that case would result in memory leak.
Fix this by adding the missing call.
Signed-off-by: Misono Tomohiro <misono.tomohiro@jp.fujitsu.com>
commit 801674f34ecfed033b062a0f217506b93c8d5e8a upstream.
We do not want to create initialized extents beyond end of file because
for e2fsck it is impossible to distinguish them from a case of corrupted
file size / extent tree and so it complains like:
Inode 12, i_size is 147456, should be 163840. Fix? no
Code in ext4_ext_convert_to_initialized() and
ext4_split_convert_extents() try to make sure it does not create
initialized extents beyond inode size however they check against
inode->i_size which is wrong. They should instead check against
EXT4_I(inode)->i_disksize which is the current inode size on disk.
That's what e2fsck is going to see in case of crash before all dirty
data is written. This bug manifests as generic/456 test failure (with
recent enough fstests where fsx got fixed to properly pass
FALLOC_KEEP_SIZE_FL flags to the kernel) when run with dioread_lock
mount option.
CC: stable@vger.kernel.org
Fixes: 21ca087a3891 ("ext4: Do not zero out uninitialized extents beyond i_size")
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
Link: https://lore.kernel.org/r/20200331105016.8674-1-jack@suse.cz
commit 4d4225fc228e46948486d8b8207955f0c031b92e upstream.
Previously we would set the reloc root's last snapshot to transid - 1.
However there was a problem with doing this, and we changed it to
setting the last snapshot to the generation of the commit node of the fs
root.
This however broke should_ignore_root(). The assumption is that if we
are in a generation newer than when the reloc root was created, then we
would find the reloc root through normal backref lookups, and thus can
ignore any fs roots we find with an old enough reloc root.
Now that the last snapshot could be considerably further in the past
than before, we'd end up incorrectly ignoring an fs root. Thus we'd
find no nodes for the bytenr we were searching for, and we'd fail to
relocate anything. We'd loop through the relocate code again and see
that there were still used space in that block group, attempt to
relocate those bytenr's again, fail in the same way, and just loop like
this forever. This is tricky in that we have to not modify the fs root
at all during this time, so we need to have a block group that has data
in this fs root that is not shared by any other root, which is why this
has been difficult to reproduce.
Fixes: 054570a1dc94 ("Btrfs: fix relocation incorrectly dropping data references")
CC: stable@vger.kernel.org # 4.9+
Reviewed-by: Filipe Manana <fdmanana@suse.com>
Signed-off-by: Josef Bacik <josef@toxicpanda.com>
Signed-off-by: David Sterba <dsterba@suse.com>
commit b9c538da4e52a7b79dfcf4cfa487c46125066dfb upstream.
If ext4_fill_super detects an invalid number of inodes per group, the
resulting error message printed the number of blocks per group, rather
than the number of inodes per group. Fix it to print the correct value.
Fixes: cd6bb35bf7f6d ("ext4: use more strict checks for inodes_per_block on mount")
Link: https://lore.kernel.org/r/8be03355983a08e5d4eed480944613454d7e2550.1585434649.git.josh@joshtriplett.org
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
commit df41460a21b06a76437af040d90ccee03888e8e5 upstream.
ext4_fill_super doublechecks the number of groups before mounting; if
that check fails, the resulting error message prints the group count
from the ext4_sb_info sbi, which hasn't been set yet. Print the freshly
computed group count instead (which at that point has just been computed
in "blocks_count").
Fixes: 4ec1102813798 ("ext4: Add sanity checks for the superblock before mounting the filesystem")
Link: https://lore.kernel.org/r/8b957cd1513fcc4550fe675c10bcce2175c33a49.1585431964.git.josh@joshtriplett.org
commit 780f66e59231fcf882f36c63f287252ee47cc75a upstream.
Improve comments in jbd2_journal_commit_transaction() to describe why
we don't need to clear the buffer_mapped bit for freeing file mapping
buffers whose page mapping is NULL.
Link: https://lore.kernel.org/r/20200217112706.20085-1-yi.zhang@huawei.com
Fixes: c96dceeabf76 ("jbd2: do not clear the BH_Mapped flag when forgetting a metadata buffer")
Suggested-by: Jan Kara <jack@suse.cz>
Signed-off-by: zhangyi (F) <yi.zhang@huawei.com>
[ Upstream commit f0cc2cd70164efe8f75c5d99560f0f69969c72e4 ]
During unmount we can have a job from the delayed inode items work queue
still running, that can lead to at least two bad things:
1) A crash, because the worker can try to create a transaction just
after the fs roots were freed;
2) A transaction leak, because the worker can create a transaction
before the fs roots are freed and just after we committed the last
transaction and after we stopped the transaction kthread.
A stack trace example of the crash:
[79011.691214] kernel BUG at lib/radix-tree.c:982!
[79011.692056] invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC PTI
[79011.693180] CPU: 3 PID: 1394 Comm: kworker/u8:2 Tainted: G W 5.6.0-rc2-btrfs-next-54 #2
[79011.696789] Workqueue: btrfs-delayed-meta btrfs_work_helper [btrfs]
[79011.697904] RIP: 0010:radix_tree_tag_set+0xe7/0x170
[79011.702014] RSP: 0018:ffffb3c84a317ca0 EFLAGS: 00010293
[79011.702949] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
[79011.704202] RDX: ffffb3c84a317cb0 RSI: ffffb3c84a317ca8 RDI: ffff8db3931340a0
[79011.705463] RBP: 0000000000000005 R08: 0000000000000005 R09: ffffffff974629d0
[79011.706756] R10: ffffb3c84a317bc0 R11: 0000000000000001 R12: ffff8db393134000
[79011.708010] R13: ffff8db3931340a0 R14: ffff8db393134068 R15: 0000000000000001
[79011.709270] FS: 0000000000000000(0000) GS:ffff8db3b6a00000(0000) knlGS:0000000000000000
[79011.710699] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[79011.711710] CR2: 00007f22c2a0a000 CR3: 0000000232ad4005 CR4: 00000000003606e0
[79011.712958] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[79011.714205] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[79011.715448] Call Trace:
[79011.715925] record_root_in_trans+0x72/0xf0 [btrfs]
[79011.716819] btrfs_record_root_in_trans+0x4b/0x70 [btrfs]
[79011.717925] start_transaction+0xdd/0x5c0 [btrfs]
[79011.718829] btrfs_async_run_delayed_root+0x17e/0x2b0 [btrfs]
[79011.719915] btrfs_work_helper+0xaa/0x720 [btrfs]
[79011.720773] process_one_work+0x26d/0x6a0
[79011.721497] worker_thread+0x4f/0x3e0
[79011.722153] ? process_one_work+0x6a0/0x6a0
[79011.722901] kthread+0x103/0x140
[79011.723481] ? kthread_create_worker_on_cpu+0x70/0x70
[79011.724379] ret_from_fork+0x3a/0x50
The following diagram shows a sequence of steps that lead to the crash
during ummount of the filesystem:
CPU 1 CPU 2 CPU 3
btrfs_punch_hole()
btrfs_btree_balance_dirty()
btrfs_balance_delayed_items()
--> sees
fs_info->delayed_root->items
with value 200, which is greater
than
BTRFS_DELAYED_BACKGROUND (128)
and smaller than
BTRFS_DELAYED_WRITEBACK (512)
btrfs_wq_run_delayed_node()
--> queues a job for
fs_info->delayed_workers to run
btrfs_async_run_delayed_root()
--> job queued by CPU 1
--> starts picking and running
delayed nodes from the
prepare_list list
close_ctree()
btrfs_delete_unused_bgs()
btrfs_commit_super()
btrfs_join_transaction()
--> gets transaction N
btrfs_commit_transaction(N)
--> set transaction state
to TRANTS_STATE_COMMIT_START
btrfs_first_prepared_delayed_node()
--> picks delayed node X through
the prepared_list list
btrfs_run_delayed_items()
btrfs_first_delayed_node()
--> also picks delayed node X
but through the node_list
list
__btrfs_commit_inode_delayed_items()
--> runs all delayed items from
this node and drops the
node's item count to 0
through call to
btrfs_release_delayed_inode()
--> finishes running any remaining
delayed nodes
--> finishes transaction commit
--> stops cleaner and transaction threads
btrfs_free_fs_roots()
--> frees all roots and removes them
from the radix tree
fs_info->fs_roots_radix
start_transaction()
btrfs_record_root_in_trans()
radix_tree_tag_set()
--> crashes because
the root is not in
the radix tree
anymore
If the worker is able to call btrfs_join_transaction() before the unmount
task frees the fs roots, we end up leaking a transaction and all its
resources, since after the call to btrfs_commit_super() and stopping the
transaction kthread, we don't expect to have any transaction open anymore.
When this situation happens the worker has a delayed node that has no
more items to run, since the task calling btrfs_run_delayed_items(),
which is doing a transaction commit, picks the same node and runs all
its items first.
We can not wait for the worker to complete when running delayed items
through btrfs_run_delayed_items(), because we call that function in
several phases of a transaction commit, and that could cause a deadlock
because the worker calls btrfs_join_transaction() and the task doing the
transaction commit may have already set the transaction state to
TRANS_STATE_COMMIT_DOING.
Also it's not possible to get into a situation where only some of the
items of a delayed node are added to the fs/subvolume tree in the current
transaction and the remaining ones in the next transaction, because when
running the items of a delayed inode we lock its mutex, effectively
waiting for the worker if the worker is running the items of the delayed
node already.
Since this can only cause issues when unmounting a filesystem, fix it in
a simple way by waiting for any jobs on the delayed workers queue before
calling btrfs_commit_supper() at close_ctree(). This works because at this
point no one can call btrfs_btree_balance_dirty() or
btrfs_balance_delayed_items(), and if we end up waiting for any worker to
complete, btrfs_commit_super() will commit the transaction created by the
worker.
CC: stable@vger.kernel.org # 4.4+
Signed-off-by: Filipe Manana <fdmanana@suse.com>
Reviewed-by: David Sterba <dsterba@suse.com>
commit 25efb2ffdf991177e740b2f63e92b4ec7d310a92 upstream.
When removing files containing extended attributes, the hfsplus driver may
remove the wrong entries from the attributes b-tree, causing major
filesystem damage and in some cases even kernel crashes.
To remove a file, all its extended attributes have to be removed as well.
The driver does this by looking up all keys in the attributes b-tree with
the cnid of the file. Each of these entries then gets deleted using the
key used for searching, which doesn't contain the attribute's name when it
should. Since the key doesn't contain the name, the deletion routine will
not find the correct entry and instead remove the one in front of it. If
parent nodes have to be modified, these become corrupt as well. This
causes invalid links and unsorted entries that not even macOS's fsck_hfs
is able to fix.
To fix this, modify the search key before an entry is deleted from the
attributes b-tree by copying the found entry's key into the search key,
therefore ensuring that the correct entry gets removed from the tree.
Signed-off-by: Simon Gander <simon@tuxera.com>
Reviewed-by: Anton Altaparmakov <anton@tuxera.com>
Cc: <stable@vger.kernel.org>
Link: http://lkml.kernel.org/r/20200327155541.1521-1-simon@tuxera.com
commit 783fda856e1034dee90a873f7654c418212d12d7 upstream.
Linux fallocate(2) with FALLOC_FL_PUNCH_HOLE mode set, its offset can
exceed the inode size. Ocfs2 now doesn't allow that offset beyond inode
size. This restriction is not necessary and violates fallocate(2)
semantics.
If fallocate(2) offset is beyond inode size, just return success and do
nothing further.
Otherwise, ocfs2 will crash the kernel.
kernel BUG at fs/ocfs2//alloc.c:7264!
ocfs2_truncate_inline+0x20f/0x360 [ocfs2]
ocfs2_remove_inode_range+0x23c/0xcb0 [ocfs2]
__ocfs2_change_file_space+0x4a5/0x650 [ocfs2]
ocfs2_fallocate+0x83/0xa0 [ocfs2]
vfs_fallocate+0x148/0x230
SyS_fallocate+0x48/0x80
do_syscall_64+0x79/0x170
Signed-off-by: Changwei Ge <chge@linux.alibaba.com>
Reviewed-by: Joseph Qi <joseph.qi@linux.alibaba.com>
Cc: Mark Fasheh <mark@fasheh.com>
Cc: Junxiao Bi <junxiao.bi@oracle.com>
Cc: Changwei Ge <gechangwei@live.cn>
Cc: Gang He <ghe@suse.com>
Cc: Jun Piao <piaojun@huawei.com>
Link: http://lkml.kernel.org/r/20200407082754.17565-1-chge@linux.alibaba.com
commit 28936b62e71e41600bab319f262ea9f9b1027629 upstream.
inode->i_blocks could be accessed concurrently as noticed by KCSAN,
BUG: KCSAN: data-race in ext4_do_update_inode [ext4] / inode_add_bytes
write to 0xffff9a00d4b982d0 of 8 bytes by task 22100 on cpu 118:
inode_add_bytes+0x65/0xf0
__inode_add_bytes at fs/stat.c:689
(inlined by) inode_add_bytes at fs/stat.c:702
ext4_mb_new_blocks+0x418/0xca0 [ext4]
ext4_ext_map_blocks+0x1a6b/0x27b0 [ext4]
ext4_map_blocks+0x1a9/0x950 [ext4]
_ext4_get_block+0xfc/0x270 [ext4]
ext4_get_block_unwritten+0x33/0x50 [ext4]
__block_write_begin_int+0x22e/0xae0
__block_write_begin+0x39/0x50
ext4_write_begin+0x388/0xb50 [ext4]
ext4_da_write_begin+0x35f/0x8f0 [ext4]
generic_perform_write+0x15d/0x290
ext4_buffered_write_iter+0x11f/0x210 [ext4]
ext4_file_write_iter+0xce/0x9e0 [ext4]
new_sync_write+0x29c/0x3b0
__vfs_write+0x92/0xa0
vfs_write+0x103/0x260
ksys_write+0x9d/0x130
__x64_sys_write+0x4c/0x60
do_syscall_64+0x91/0xb05
entry_SYSCALL_64_after_hwframe+0x49/0xbe
read to 0xffff9a00d4b982d0 of 8 bytes by task 8 on cpu 65:
ext4_do_update_inode+0x4a0/0xf60 [ext4]
ext4_inode_blocks_set at fs/ext4/inode.c:4815
ext4_mark_iloc_dirty+0xaf/0x160 [ext4]
ext4_mark_inode_dirty+0x129/0x3e0 [ext4]
ext4_convert_unwritten_extents+0x253/0x2d0 [ext4]
ext4_convert_unwritten_io_end_vec+0xc5/0x150 [ext4]
ext4_end_io_rsv_work+0x22c/0x350 [ext4]
process_one_work+0x54f/0xb90
worker_thread+0x80/0x5f0
kthread+0x1cd/0x1f0
ret_from_fork+0x27/0x50
4 locks held by kworker/u256:0/8:
#0: ffff9a025abc4328 ((wq_completion)ext4-rsv-conversion){+.+.}, at: process_one_work+0x443/0xb90
#1: ffffab5a862dbe20 ((work_completion)(&ei->i_rsv_conversion_work)){+.+.}, at: process_one_work+0x443/0xb90
#2: ffff9a025a9d0f58 (jbd2_handle){++++}, at: start_this_handle+0x1c1/0x9d0 [jbd2]
#3: ffff9a00d4b985d8 (&(&ei->i_raw_lock)->rlock){+.+.}, at: ext4_do_update_inode+0xaa/0xf60 [ext4]
irq event stamp: 3009267
hardirqs last enabled at (3009267): [<ffffffff980da9b7>] __find_get_block+0x107/0x790
hardirqs last disabled at (3009266): [<ffffffff980da8f9>] __find_get_block+0x49/0x790
softirqs last enabled at (3009230): [<ffffffff98a0034c>] __do_softirq+0x34c/0x57c
softirqs last disabled at (3009223): [<ffffffff97cc67a2>] irq_exit+0xa2/0xc0
Reported by Kernel Concurrency Sanitizer on:
CPU: 65 PID: 8 Comm: kworker/u256:0 Tainted: G L 5.6.0-rc2-next-20200221+ #7
Hardware name: HPE ProLiant DL385 Gen10/ProLiant DL385 Gen10, BIOS A40 07/10/2019
Workqueue: ext4-rsv-conversion ext4_end_io_rsv_work [ext4]
The plain read is outside of inode->i_lock critical section which
results in a data race. Fix it by adding READ_ONCE() there.
Link: https://lore.kernel.org/r/20200222043258.2279-1-cai@lca.pw
Signed-off-by: Qian Cai <cai@lca.pw>
Cc: stable@kernel.org
commit 8e19c9732ad1d127b5575a10f4fbcacf740500ff upstream.
If we have an error while building the backref tree in relocation we'll
process all the pending edges and then free the node. However if we
integrated some edges into the cache we'll lose our link to those edges
by simply freeing this node, which means we'll leak memory and
references to any roots that we've found.
Instead we need to use remove_backref_node(), which walks through all of
the edges that are still linked to this node and free's them up and
drops any root references we may be holding.
Reviewed-by: Qu Wenruo <wqu@suse.com>
commit d1e7fd6462ca9fc76650fbe6ca800e35b24267da upstream.
Replace the 32bit exec_id with a 64bit exec_id to make it impossible
to wrap the exec_id counter. With care an attacker can cause exec_id
wrap and send arbitrary signals to a newly exec'd parent. This
bypasses the signal sending checks if the parent changes their
credentials during exec.
The severity of this problem can been seen that in my limited testing
of a 32bit exec_id it can take as little as 19s to exec 65536 times.
Which means that it can take as little as 14 days to wrap a 32bit
exec_id. Adam Zabrocki has succeeded wrapping the self_exe_id in 7
days. Even my slower timing is in the uptime of a typical server.
Which means self_exec_id is simply a speed bump today, and if exec
gets noticably faster self_exec_id won't even be a speed bump.
Extending self_exec_id to 64bits introduces a problem on 32bit
architectures where reading self_exec_id is no longer atomic and can
take two read instructions. Which means that is is possible to hit
a window where the read value of exec_id does not match the written
value. So with very lucky timing after this change this still
remains expoiltable.
I have updated the update of exec_id on exec to use WRITE_ONCE
and the read of exec_id in do_notify_parent to use READ_ONCE
to make it clear that there is no locking between these two
locations.
Link: https://lore.kernel.org/kernel-hardening/20200324215049.GA3710@pi3.com.pl
Fixes: 2.3.23pre2
Cc: stable@vger.kernel.org
[ Upstream commit ea287ab157c2816bf12aad4cece41372f9d146b4 ]
We always search the commit root of the extent tree for looking up back
references, however we track the reloc roots based on their current
bytenr.
This is wrong, if we commit the transaction between relocating tree
blocks we could end up in this code in build_backref_tree
if (key.objectid == key.offset) {
* Only root blocks of reloc trees use backref
* pointing to itself.
root = find_reloc_root(rc, cur->bytenr);
ASSERT(root);
cur->root = root;
break;
find_reloc_root() is looking based on the bytenr we had in the commit
root, but if we've COWed this reloc root we will not find that bytenr,
and we will trip over the ASSERT(root).
Fix this by using the commit_root->start bytenr for indexing the commit
root. Then we change the __update_reloc_root() caller to be used when
we switch the commit root for the reloc root during commit.
This fixes the panic I was seeing when we started throttling relocation
for delayed refs.
[ Upstream commit 7b7b74315b24dc064bc1c683659061c3d48f8668 ]
This was pretty subtle, we default to reloc roots having 0 root refs, so
if we crash in the middle of the relocation they can just be deleted.
If we successfully complete the relocation operations we'll set our root
refs to 1 in prepare_to_merge() and then go on to merge_reloc_roots().
At prepare_to_merge() time if any of the reloc roots have a 0 reference
still, we will remove that reloc root from our reloc root rb tree, and
then clean it up later.
However this only happens if we successfully start a transaction. If
we've aborted previously we will skip this step completely, and only
have reloc roots with a reference count of 0, but were never properly
removed from the reloc control's rb tree.
This isn't a problem per-se, our references are held by the list the
reloc roots are on, and by the original root the reloc root belongs to.
If we end up in this situation all the reloc roots will be added to the
dirty_reloc_list, and then properly dropped at that point. The reloc
control will be free'd and the rb tree is no longer used.
There were two options when fixing this, one was to remove the BUG_ON(),
the other was to make prepare_to_merge() handle the case where we
couldn't start a trans handle.
IMO this is the cleaner solution. I started with handling the error in
prepare_to_merge(), but it turned out super ugly. And in the end this
BUG_ON() simply doesn't matter, the cleanup was happening properly, we
were just panicing because this BUG_ON() only matters in the success
case. So I've opted to just remove it and add a comment where it was.
[ Upstream commit df5db5f9ee112e76b5202fbc331f990a0fc316d6 ]
Before this patch, run_queue would demote glocks based on whether
there are any more holders. But if the glock has pending revokes that
haven't been written to the media, giving up the glock might end in
file system corruption if the revokes never get written due to
io errors, node crashes and fences, etc. In that case, another node
will replay the metadata blocks associated with the glock, but
because the revoke was never written, it could replay that block
even though the glock had since been granted to another node who
might have made changes.
This patch changes the logic in run_queue so that it never demotes
a glock until its count of pending revokes reaches zero.
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
Reviewed-by: Andreas Gruenbacher <agruenba@redhat.com>
Allow to disable extended attribute support.
This aids in reliability testing, especially since some xattr
related bugs have surfaced.
Also an embedded system might not need it, so this allows for a
slightly smaller kernel (about 4KiB).
Signed-off-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Richard Weinberger <richard@nod.at>
(cherry picked from commit 7e5471ce6dba5f28a3c7afdfe168655d236f677b)
When write syscall is called, every time security label is searched to
determine that file's privileges should be changed.
If LSM(Linux Security Model) is not used, this is useless.
So introduce CONFIG_UBIFS_SECURITY to disable security labels. it's default
value is "y".
Signed-off-by: Hyunchul Lee <cheol.lee@lge.com>
(cherry picked from commit 8326c1eec2449f0e868f7b19a5fa7bfa0386ab48)
commit b27a939e8376a3f1ed09b9c33ef44d20f18ec3d0 upstream.
syzbot reported that 4fbc0c711b24 ("ceph: remove the extra slashes in
the server path") had caused a regression where an allocation could be
done under a spinlock -- compare_mount_options() is called by sget_fc()
with sb_lock held.
We don't really need the supplied server path, so canonicalize it
in place and compare it directly. To make this work, the leading
slash is kept around and the logic in ceph_real_mount() to skip it
is restored. CEPH_MSG_CLIENT_SESSION now reports the same (i.e.
canonicalized) path, with the leading slash of course.
Fixes: 4fbc0c711b24 ("ceph: remove the extra slashes in the server path")
Reported-by: syzbot+98704a51af8e3d9425a9@syzkaller.appspotmail.com
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Jeff Layton <jlayton@kernel.org>
Signed-off-by: Luis Henriques <lhenriques@suse.com>
commit 4fbc0c711b2464ee1551850b85002faae0b775d5 upstream.
It's possible to pass the mount helper a server path that has more
than one contiguous slash character. For example:
$ mount -t ceph 192.168.195.165:40176:/// /mnt/cephfs/
In the MDS server side the extra slashes of the server path will be
treated as snap dir, and then we can get the following debug logs:
ceph: mount opening path //
ceph: open_root_inode opening '//'
ceph: fill_trace 0000000059b8a3bc is_dentry 0 is_target 1
ceph: alloc_inode 00000000dc4ca00b
ceph: get_inode created new inode 00000000dc4ca00b 1.ffffffffffffffff ino 1
ceph: get_inode on 1=1.ffffffffffffffff got 00000000dc4ca00b
And then when creating any new file or directory under the mount
point, we can hit the following BUG_ON in ceph_fill_trace():
BUG_ON(ceph_snap(dir) != dvino.snap);
Have the client ignore the extra slashes in the server path when
mounting. This will also canonicalize the path, so that identical mounts
can be consilidated.
1) "//mydir1///mydir//"
2) "/mydir1/mydir"
3) "/mydir1/mydir/"
Regardless of the internal treatment of these paths, the kernel still
stores the original string including the leading '/' for presentation
to userland.
URL: https://tracker.ceph.com/issues/42771
Signed-off-by: Xiubo Li <xiubli@redhat.com>
commit a65cab7d7f05c2061a3e2490257d3086ff3202c6 upstream.
Reading from a debugfs file at a nonzero position, without first reading
at position 0, leaks uninitialized memory to userspace.
It's a bit tricky to do this, since lseek() and pread() aren't allowed
on these files, and write() doesn't update the position on them. But
writing to them with splice() *does* update the position:
#define _GNU_SOURCE 1
#include <fcntl.h>
#include <stdio.h>
#include <unistd.h>
int main()
int pipes[2], fd, n, i;
char buf[32];
pipe(pipes);
write(pipes[1], "0", 1);
fd = open("/sys/kernel/debug/fault_around_bytes", O_RDWR);
splice(pipes[0], NULL, fd, NULL, 1, 0);
n = read(fd, buf, sizeof(buf));
for (i = 0; i < n; i++)
printf("%02x", buf[i]);
printf("\n");
Output:
5a5a5a5a5a5a5a5a5a5a5a5a5a5a5a5a5a5a5a5a5a5a5a30
Fix the infoleak by making simple_attr_read() always fill
simple_attr::get_buf if it hasn't been filled yet.
Reported-by: syzbot+fcab69d1ada3e8d6f06b@syzkaller.appspotmail.com
Reported-by: Alexander Potapenko <glider@google.com>
Fixes: acaefc25d21f ("[PATCH] libfs: add simple attribute files")
Link: https://lore.kernel.org/r/20200308023849.988264-1-ebiggers@kernel.org
commit 8019ad13ef7f64be44d4f892af9c840179009254 upstream.
As reported by Jann, ihold() does not in fact guarantee inode
persistence. And instead of making it so, replace the usage of inode
pointers with a per boot, machine wide, unique inode identifier.
This sequence number is global, but shared (file backed) futexes are
rare enough that this should not become a performance issue.
Reported-by: Jann Horn <jannh@google.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
[ Upstream commit 6c5d911249290f41f7b50b43344a7520605b1acb ]
journal_head::b_transaction and journal_head::b_next_transaction could
LTP: starting fsync04
/dev/zero: Can't open blockdev
EXT4-fs (loop0): mounting ext3 file system using the ext4 subsystem
EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
BUG: KCSAN: data-race in __jbd2_journal_refile_buffer [jbd2] / jbd2_write_access_granted [jbd2]
write to 0xffff99f9b1bd0e30 of 8 bytes by task 25721 on cpu 70:
__jbd2_journal_refile_buffer+0xdd/0x210 [jbd2]
__jbd2_journal_refile_buffer at fs/jbd2/transaction.c:2569
jbd2_journal_commit_transaction+0x2d15/0x3f20 [jbd2]
(inlined by) jbd2_journal_commit_transaction at fs/jbd2/commit.c:1034
kjournald2+0x13b/0x450 [jbd2]
kthread+0x1cd/0x1f0
read to 0xffff99f9b1bd0e30 of 8 bytes by task 25724 on cpu 68:
jbd2_write_access_granted+0x1b2/0x250 [jbd2]
jbd2_write_access_granted at fs/jbd2/transaction.c:1155
jbd2_journal_get_write_access+0x2c/0x60 [jbd2]
__ext4_journal_get_write_access+0x50/0x90 [ext4]
ext4_mb_mark_diskspace_used+0x158/0x620 [ext4]
ext4_mb_new_blocks+0x54f/0xca0 [ext4]
ext4_ind_map_blocks+0xc79/0x1b40 [ext4]
ext4_map_blocks+0x3b4/0x950 [ext4]
ext4_get_block+0x3b/0x50 [ext4]
5 locks held by fsync04/25724:
#0: ffff99f9911093f8 (sb_writers#13){.+.+}, at: vfs_write+0x21c/0x260
#1: ffff99f9db4c0348 (&sb->s_type->i_mutex_key#15){+.+.}, at: ext4_buffered_write_iter+0x65/0x210 [ext4]
#2: ffff99f5e7dfcf58 (jbd2_handle){++++}, at: start_this_handle+0x1c1/0x9d0 [jbd2]
#3: ffff99f9db4c0168 (&ei->i_data_sem){++++}, at: ext4_map_blocks+0x176/0x950 [ext4]
#4: ffffffff99086b40 (rcu_read_lock){....}, at: jbd2_write_access_granted+0x4e/0x250 [jbd2]
irq event stamp: 1407125
hardirqs last enabled at (1407125): [<ffffffff980da9b7>] __find_get_block+0x107/0x790
hardirqs last disabled at (1407124): [<ffffffff980da8f9>] __find_get_block+0x49/0x790
softirqs last enabled at (1405528): [<ffffffff98a0034c>] __do_softirq+0x34c/0x57c
softirqs last disabled at (1405521): [<ffffffff97cc67a2>] irq_exit+0xa2/0xc0
CPU: 68 PID: 25724 Comm: fsync04 Tainted: G L 5.6.0-rc2-next-20200221+ #7
The plain reads are outside of jh->b_state_lock critical section which result
in data races. Fix them by adding pairs of READ|WRITE_ONCE().
Link: https://lore.kernel.org/r/20200222043111.2227-1-cai@lca.pw
commit 21039132650281de06a169cbe8a0f7e5c578fd8b upstream.
with the way fs/namei.c:do_last() had been done, ->atomic_open()
instances needed to recognize the case when existing file got
found with O_EXCL|O_CREAT, either by falling back to finish_no_open()
or failing themselves. gfs2 one didn't.
Fixes: 6d4ade986f9c (GFS2: Add atomic_open support)
Cc: stable@kernel.org # v3.11
commit d9a9f4849fe0c9d560851ab22a85a666cddfdd24 upstream.
several iterations of ->atomic_open() calling conventions ago, we
used to need fput() if ->atomic_open() failed at some point after
successful finish_open(). Now (since 2016) it's not needed -
struct file carries enough state to make fput() work regardless
of the point in struct file lifecycle and discarding it on
failure exits in open() got unified. Unfortunately, I'd missed
the fact that we had an instance of ->atomic_open() (cifs one)
that used to need that fput(), as well as the stale comment in
finish_open() demanding such late failure handling. Trivially
fixed...
Fixes: fe9ec8291fca "do_last(): take fput() on error after opening to out:"
Cc: stable@kernel.org # v4.7+
Array is mapped by nfs_readdir_get_array(), the further kmap is a result
of a bad merge and should be removed.
This resource leakage can be exploited for DoS by receptively reading
a content of a directory on NFS (e.g. by running ls).
Fixes: 67a56e9743171 ("NFS: Fix memory leaks and corruption in readdir")
Signed-off-by: Petr Malat <oss@malat.biz>
commit bc87302a093f0eab45cd4e250c2021299f712ec6 upstream.
When get an error in the middle of reading an inode, some fields in the
inode might be still not initialized. And then the evict_inode path may
access those fields via iput().
To fix, this makes sure that inode fields are initialized.
Reported-by: syzbot+9d82b8de2992579da5d0@syzkaller.appspotmail.com
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Link: http://lkml.kernel.org/r/871rqnreqx.fsf@mail.parknet.co.jp
commit fc513fac56e1b626ae48a74d7551d9c35c50129e upstream.
If from cifs_revalidate_dentry_attr() the SMB2/QUERY_INFO call fails with an
error, such as STATUS_SESSION_EXPIRED, causing the session to be reconnected
it is possible we will leak -EAGAIN back to the application even for
system calls such as stat() where this is not a valid error.
Fix this by re-trying the operation from within cifs_revalidate_dentry_attr()
if cifs_get_inode_info*() returns -EAGAIN.
This fixes stat() and possibly also other system calls that uses
cifs_revalidate_dentry*().
Signed-off-by: Ronnie Sahlberg <lsahlber@redhat.com>
Signed-off-by: Steve French <stfrench@microsoft.com>
Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
Reviewed-by: Aurelien Aptel <aaptel@suse.com>
CC: Stable <stable@vger.kernel.org>
commit 2b98149c2377bff12be5dd3ce02ae0506e2dd613 upstream.
It's over-zealous to return hard errors under RCU-walk here, given that
a REF-walk will be triggered for all other cases handling ".." under
RCU.
The original purpose of this check was to ensure that if a rename occurs
such that a directory is moved outside of the bind-mount which the
resolution started in, it would be detected and blocked to avoid being
able to mess with paths outside of the bind-mount. However, triggering a
new REF-walk is just as effective a solution.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Fixes: 397d425dc26d ("vfs: Test for and handle paths that are unreachable from their mnt_root")
Suggested-by: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Aleksa Sarai <cyphar@cyphar.com>
When doing the 4.9 merge into certain Android trees, I noticed a warning
from Android's deprecated GCC 4.9.4, which causes a build failure in
those trees due to basically -Werror:
fs/ecryptfs/keystore.c: In function 'ecryptfs_parse_packet_set':
fs/ecryptfs/keystore.c:1357:2: warning: 'auth_tok_list_item' may be used
uninitialized in this function [-Wmaybe-uninitialized]
memset(auth_tok_list_item, 0,
fs/ecryptfs/keystore.c:1260:38: note: 'auth_tok_list_item' was declared
here
struct ecryptfs_auth_tok_list_item *auth_tok_list_item;
GCC 9.2.0 was not able to pick up this warning when I tested it.
Turns out that Clang warns as well when -Wuninitialized is used, which
is not the case in older stable trees at the moment (but shows value in
potentially backporting the various warning fixes currently in upstream
to get more coverage).
fs/ecryptfs/keystore.c:1284:6: warning: variable 'auth_tok_list_item' is
used uninitialized whenever 'if' condition is true
[-Wsometimes-uninitialized]
if (data[(*packet_size)++] != ECRYPTFS_TAG_1_PACKET_TYPE) {
fs/ecryptfs/keystore.c:1360:4: note: uninitialized use occurs here
auth_tok_list_item);
fs/ecryptfs/keystore.c:1284:2: note: remove the 'if' if its condition is
always false
fs/ecryptfs/keystore.c:1260:56: note: initialize the variable
'auth_tok_list_item' to silence this warning
= NULL
1 warning generated.
Somehow, commit fe2e082f5da5 ("ecryptfs: fix a memory leak bug in
parse_tag_1_packet()") upstream was not applied in the correct if block
in 4.4.215, 4.9.215, and 4.14.172, which will indeed lead to use of
uninitialized memory. Fix it up by undoing the bad backport in those
trees then reapplying the patch in the proper location.
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
commit 37b0b6b8b99c0e1c1f11abbe7cf49b6d03795b3f upstream.
If sbi->s_flex_groups_allocated is zero and the first allocation fails
then this code will crash. The problem is that "i--" will set "i" to
-1 but when we compare "i >= sbi->s_flex_groups_allocated" then the -1
is type promoted to unsigned and becomes UINT_MAX. Since UINT_MAX
is more than zero, the condition is true so we call kvfree(new_groups[-1]).
The loop will carry on freeing invalid memory until it crashes.
Fixes: 7c990728b99e ("ext4: fix potential race between s_flex_groups online resizing and access")
Reviewed-by: Suraj Jitindar Singh <surajjs@amazon.com>
Link: https://lore.kernel.org/r/20200228092142.7irbc44yaz3by7nb@kili.mountain
[ Upstream commit f52aa79df43c4509146140de0241bc21a4a3b4c7 ]
A number of the debug statements output file or directory mode
in hex. Change these to print using octal.
Signed-off-by: Frank Sorenson <sorenson@redhat.com>
[ Upstream commit df3da4ea5a0fc5d115c90d5aa6caa4dd433750a7 ]
During an online resize an array of pointers to s_group_info gets replaced
so it can get enlarged. If there is a concurrent access to the array in
ext4_get_group_info() and this memory has been reused then this can lead to
an invalid memory access.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=206443
Link: https://lore.kernel.org/r/20200221053458.730016-3-tytso@mit.edu
Signed-off-by: Suraj Jitindar Singh <surajjs@amazon.com>
Reviewed-by: Balbir Singh <sblbir@amazon.com>
commit 7c990728b99ed6fbe9c75fc202fce1172d9916da upstream.
During an online resize an array of s_flex_groups structures gets replaced
so it can get enlarged. If there is a concurrent access to the array and
this memory has been reused then this can lead to an invalid memory access.
The s_flex_group array has been converted into an array of pointers rather
than an array of structures. This is to ensure that the information
contained in the structures cannot get out of sync during a resize due to
an accessor updating the value in the old structure after it has been
copied but before the array pointer is updated. Since the structures them-
selves are no longer copied but only the pointers to them this case is
mitigated.
Link: https://lore.kernel.org/r/20200221053458.730016-4-tytso@mit.edu
Cc: stable@kernel.org # 4.4.x
Cc: stable@kernel.org # 4.9.x
commit 1d0c3924a92e69bfa91163bda83c12a994b4d106 upstream.
During an online resize an array of pointers to buffer heads gets
replaced so it can get enlarged. If there is a racing block
allocation or deallocation which uses the old array, and the old array
has gotten reused this can lead to a GPF or some other random kernel
memory getting modified.
Link: https://lore.kernel.org/r/20200221053458.730016-2-tytso@mit.edu
Reported-by: Suraj Jitindar Singh <surajjs@amazon.com>
commit 2c2a7552dd6465e8fde6bc9cccf8d66ed1c1eb72 upstream.
In crypt_scatterlist, if the crypt_stat argument is not set up
correctly, the kernel crashes. Instead, by returning an error code
upstream, the error is handled safely.
The issue is detected via a static analysis tool written by us.
Fixes: 237fead619984 (ecryptfs: fs/Makefile and fs/Kconfig)
Signed-off-by: Aditya Pakki <pakki001@umn.edu>
Signed-off-by: Tyler Hicks <code@tyhicks.com>
commit e75fd33b3f744f644061a4f9662bd63f5434f806 upstream.
In btrfs_wait_ordered_range() once we find an ordered extent that has
finished with an error we exit the loop and don't wait for any other
ordered extents that might be still in progress.
All the users of btrfs_wait_ordered_range() expect that there are no more
ordered extents in progress after that function returns. So past fixes
such like the ones from the two following commits:
ff612ba7849964 ("btrfs: fix panic during relocation after ENOSPC before
writeback happens")
28aeeac1dd3080 ("Btrfs: fix panic when starting bg cache writeout after
IO error")
don't work when there are multiple ordered extents in the range.
Fix that by making btrfs_wait_ordered_range() wait for all ordered extents
even after it finds one that had an error.
Link: https://github.com/kdave/btrfs-progs/issues/228#issuecomment-569777554
Reviewed-by: Josef Bacik <josef@toxicpanda.com>
commit cb85f4d23f794e24127f3e562cb3b54b0803f456 upstream.
If EXT4_EXTENTS_FL is set on an inode while ext4_writepages() is running
on it, the following warning in ext4_add_complete_io() can be hit:
WARNING: CPU: 1 PID: 0 at fs/ext4/page-io.c:234 ext4_put_io_end_defer+0xf0/0x120
Here's a minimal reproducer (not 100% reliable) (root isn't required):
while true; do
sync
done &
while true; do
rm -f file
touch file
chattr -e file
echo X >> file
chattr +e file
done
The problem is that in ext4_writepages(), ext4_should_dioread_nolock()
(which only returns true on extent-based files) is checked once to set
the number of reserved journal credits, and also again later to select
the flags for ext4_map_blocks() and copy the reserved journal handle to
ext4_io_end::handle. But if EXT4_EXTENTS_FL is being concurrently set,
the first check can see dioread_nolock disabled while the later one can
see it enabled, causing the reserved handle to unexpectedly be NULL.
Since changing EXT4_EXTENTS_FL is uncommon, and there may be other races
related to doing so as well, fix this by synchronizing changing
EXT4_EXTENTS_FL with ext4_writepages() via the existing
s_writepages_rwsem (previously called s_journal_flag_rwsem).
This was originally reported by syzbot without a reproducer at
https://syzkaller.appspot.com/bug?extid=2202a584a00fffd19fbf,
but now that dioread_nolock is the default I also started seeing this
when running syzkaller locally.
Link: https://lore.kernel.org/r/20200219183047.47417-3-ebiggers@kernel.org
Reported-by: syzbot+2202a584a00fffd19fbf@syzkaller.appspotmail.com
Fixes: 6b523df4fb5a ("ext4: use transaction reservation for extent conversion in ext4_end_io")
commit bbd55937de8f2754adc5792b0f8e5ff7d9c0420e upstream.
In preparation for making s_journal_flag_rwsem synchronize
ext4_writepages() with changes to both the EXTENTS and JOURNAL_DATA
flags (rather than just JOURNAL_DATA as it does currently), rename it to
s_writepages_rwsem.
Link: https://lore.kernel.org/r/20200219183047.47417-2-ebiggers@kernel.org
commit 9db176bceb5c5df4990486709da386edadc6bd1d upstream.
When CONFIG_QFMT_V2 is configured as a module, the test in
ext4_feature_set_ok() fails and so mount of filesystems with quota or
project features fails. Fix the test to use IS_ENABLED macro which
works properly even for modules.
Link: https://lore.kernel.org/r/20200221100835.9332-1-jack@suse.cz
Fixes: d65d87a07476 ("ext4: improve explanation of a mount failure caused by a misconfigured kernel")
commit 9424ef56e13a1f14c57ea161eed3ecfdc7b2770e upstream.
We tested a soft lockup problem in linux 4.19 which could also
be found in linux 5.x.
When dir inode takes up a large number of blocks, and if the
directory is growing when we are searching, it's possible the
restart branch could be called many times, and the do while loop
could hold cpu a long time.
Here is the call trace in linux 4.19.
[ 473.756186] Call trace:
[ 473.756196] dump_backtrace+0x0/0x198
[ 473.756199] show_stack+0x24/0x30
[ 473.756205] dump_stack+0xa4/0xcc
[ 473.756210] watchdog_timer_fn+0x300/0x3e8
[ 473.756215] __hrtimer_run_queues+0x114/0x358
[ 473.756217] hrtimer_interrupt+0x104/0x2d8
[ 473.756222] arch_timer_handler_virt+0x38/0x58
[ 473.756226] handle_percpu_devid_irq+0x90/0x248
[ 473.756231] generic_handle_irq+0x34/0x50
[ 473.756234] __handle_domain_irq+0x68/0xc0
[ 473.756236] gic_handle_irq+0x6c/0x150
[ 473.756238] el1_irq+0xb8/0x140
[ 473.756286] ext4_es_lookup_extent+0xdc/0x258 [ext4]
[ 473.756310] ext4_map_blocks+0x64/0x5c0 [ext4]
[ 473.756333] ext4_getblk+0x6c/0x1d0 [ext4]
[ 473.756356] ext4_bread_batch+0x7c/0x1f8 [ext4]
[ 473.756379] ext4_find_entry+0x124/0x3f8 [ext4]
[ 473.756402] ext4_lookup+0x8c/0x258 [ext4]
[ 473.756407] __lookup_hash+0x8c/0xe8
[ 473.756411] filename_create+0xa0/0x170
[ 473.756413] do_mkdirat+0x6c/0x140
[ 473.756415] __arm64_sys_mkdirat+0x28/0x38
[ 473.756419] el0_svc_common+0x78/0x130
[ 473.756421] el0_svc_handler+0x38/0x78
[ 473.756423] el0_svc+0x8/0xc
[ 485.755156] watchdog: BUG: soft lockup - CPU#2 stuck for 22s! [tmp:5149]
Add cond_resched() to avoid soft lockup and to provide a better
system responding.
Link: https://lore.kernel.org/r/20200215080206.13293-1-luoshijie1@huawei.com
Signed-off-by: Shijie Luo <luoshijie1@huawei.com>
commit 35df4299a6487f323b0aca120ea3f485dfee2ae3 upstream.
EXT4_I(inode)->i_disksize could be accessed concurrently as noticed by
KCSAN,
BUG: KCSAN: data-race in ext4_write_end [ext4] / ext4_writepages [ext4]
write to 0xffff91c6713b00f8 of 8 bytes by task 49268 on cpu 127:
ext4_write_end+0x4e3/0x750 [ext4]
ext4_update_i_disksize at fs/ext4/ext4.h:3032
(inlined by) ext4_update_inode_size at fs/ext4/ext4.h:3046
(inlined by) ext4_write_end at fs/ext4/inode.c:1287
generic_perform_write+0x208/0x2a0
do_syscall_64+0x91/0xb47
read to 0xffff91c6713b00f8 of 8 bytes by task 24872 on cpu 37:
ext4_writepages+0x10ac/0x1d00 [ext4]
mpage_map_and_submit_extent at fs/ext4/inode.c:2468
(inlined by) ext4_writepages at fs/ext4/inode.c:2772
do_writepages+0x5e/0x130
__writeback_single_inode+0xeb/0xb20
writeback_sb_inodes+0x429/0x900
__writeback_inodes_wb+0xc4/0x150
wb_writeback+0x4bd/0x870
wb_workfn+0x6b4/0x960
process_one_work+0x54c/0xbe0
worker_thread+0x80/0x650
kthread+0x1e0/0x200
CPU: 37 PID: 24872 Comm: kworker/u261:2 Tainted: G W O L 5.5.0-next-20200204+ #5
Workqueue: writeback wb_workfn (flush-7:0)
Since only the read is operating as lockless (outside of the
"i_data_sem"), load tearing could introduce a logic bug. Fix it by
adding READ_ONCE() for the read and WRITE_ONCE() for the write.
Link: https://lore.kernel.org/r/1581085751-31793-1-git-send-email-cai@lca.pw
[ Upstream commit 9f198a2ac543eaaf47be275531ad5cbd50db3edf ]
if seq_file .next fuction does not change position index,
read after some lseek can generate unexpected output.
https://bugzilla.kernel.org/show_bug.cgi?id=206283
Signed-off-by: Vasily Averin <vvs@virtuozzo.com>
Signed-off-by: Mike Marshall <hubcap@omnibond.com>
[ Upstream commit aacee5446a2a1aa35d0a49dab289552578657fb4 ]
The variable inode may be NULL in reiserfs_insert_item(), but there is
no check before accessing the member of inode.
Fix this by adding NULL pointer check before calling reiserfs_debug().
Link: http://lkml.kernel.org/r/79c5135d-ff25-1cc9-4e99-9f572b88cc00@huawei.com
Signed-off-by: Yunfeng Ye <yeyunfeng@huawei.com>
Cc: zhengbin <zhengbin13@huawei.com>
Cc: Hu Shiyuan <hushiyuan@huawei.com>
Cc: Feilong Lin <linfeilong@huawei.com>
Cc: Jan Kara <jack@suse.cz>
[ Upstream commit 9f16ca48fc818a17de8be1f75d08e7f4addc4497 ]
I found a NULL pointer dereference in ocfs2_update_inode_fsync_trans(),
handle->h_transaction may be NULL in this situation:
ocfs2_file_write_iter
->__generic_file_write_iter
->generic_perform_write
->ocfs2_write_begin
->ocfs2_write_begin_nolock
->ocfs2_write_cluster_by_desc
->ocfs2_mark_extent_written
->ocfs2_change_extent_flag
->ocfs2_split_extent
->ocfs2_try_to_merge_extent
->ocfs2_extend_rotate_transaction
->ocfs2_extend_trans
->jbd2_journal_restart
->jbd2__journal_restart
// handle->h_transaction is NULL here
->handle->h_transaction = NULL;
->start_this_handle
/* journal aborted due to storage
network disconnection, return error */
->return -EROFS;
/* line 3806 in ocfs2_try_to_merge_extent (),
it will ignore ret error. */
->ret = 0;
->ocfs2_write_end
->ocfs2_write_end_nolock
->ocfs2_update_inode_fsync_trans
// NULL pointer dereference
->oi->i_sync_tid = handle->h_transaction->t_tid;
The information of NULL pointer dereference as follows:
JBD2: Detected IO errors while flushing file data on dm-11-45
Aborting journal on device dm-11-45.
JBD2: Error -5 detected when updating journal superblock for dm-11-45.
(dd,22081,3):ocfs2_extend_trans:474 ERROR: status = -30
(dd,22081,3):ocfs2_try_to_merge_extent:3877 ERROR: status = -30
Unable to handle kernel NULL pointer dereference at
virtual address 0000000000000008
Mem abort info:
ESR = 0x96000004
Exception class = DABT (current EL), IL = 32 bits
SET = 0, FnV = 0
EA = 0, S1PTW = 0
Data abort info:
ISV = 0, ISS = 0x00000004
CM = 0, WnR = 0
user pgtable: 4k pages, 48-bit VAs, pgdp = 00000000e74e1338
[0000000000000008] pgd=0000000000000000
Internal error: Oops: 96000004 [#1] SMP
Process dd (pid: 22081, stack limit = 0x00000000584f35a9)
CPU: 3 PID: 22081 Comm: dd Kdump: loaded
Hardware name: Huawei TaiShan 2280 V2/BC82AMDD, BIOS 0.98 08/25/2019
pstate: 60400009 (nZCv daif +PAN -UAO)
pc : ocfs2_write_end_nolock+0x2b8/0x550 [ocfs2]
lr : ocfs2_write_end_nolock+0x2a0/0x550 [ocfs2]
sp : ffff0000459fba70
x29: ffff0000459fba70 x28: 0000000000000000
x27: ffff807ccf7f1000 x26: 0000000000000001
x25: ffff807bdff57970 x24: ffff807caf1d4000
x23: ffff807cc79e9000 x22: 0000000000001000
x21: 000000006c6cd000 x20: ffff0000091d9000
x19: ffff807ccb239db0 x18: ffffffffffffffff
x17: 000000000000000e x16: 0000000000000007
x15: ffff807c5e15bd78 x14: 0000000000000000
x13: 0000000000000000 x12: 0000000000000000
x11: 0000000000000000 x10: 0000000000000001
x9 : 0000000000000228 x8 : 000000000000000c
x7 : 0000000000000fff x6 : ffff807a308ed6b0
x5 : ffff7e01f10967c0 x4 : 0000000000000018
x3 : d0bc661572445600 x2 : 0000000000000000
x1 : 000000001b2e0200 x0 : 0000000000000000
Call trace:
ocfs2_write_end+0x4c/0x80 [ocfs2]
generic_perform_write+0x108/0x1a8
__generic_file_write_iter+0x158/0x1c8
ocfs2_file_write_iter+0x668/0x950 [ocfs2]
__vfs_write+0x11c/0x190
vfs_write+0xac/0x1c0
ksys_write+0x6c/0xd8
__arm64_sys_write+0x24/0x30
el0_svc+0x8/0xc
To prevent NULL pointer dereference in this situation, we use
is_handle_aborted() before using handle->h_transaction->t_tid.
Link: http://lkml.kernel.org/r/03e750ab-9ade-83aa-b000-b9e81e34e539@huawei.com
Signed-off-by: Yan Wang <wangyan122@huawei.com>
Reviewed-by: Jun Piao <piaojun@huawei.com>
Cc: Joseph Qi <jiangqi903@gmail.com>
