path: root/fs
2007-04-30reiserfs: suppress lockdep warningJeff Mahoney
We're getting lockdep warnings due to a post-2.6.21-rc7 bugfix. The xattr_sem can never be taken in the manner described. Internal inodes are protected by I_PRIVATE. Add the appropriate annotation. Cc: <stable@kernel.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30Merge branch 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-block: [PATCH] elevator: elv_list_lock does not need irq disabling [BLOCK] Don't pin lots of memory in mempools cfq-iosched: speedup cic rb lookup ll_rw_blk: add io_context private pointer cfq-iosched: get rid of cfqq hash cfq-iosched: tighten queue request overlap condition cfq-iosched: improve sync vs async workloads cfq-iosched: never allow an async queue idling cfq-iosched: get rid of ->dispatch_slice cfq-iosched: don't pass unused preemption variable around cfq-iosched: get rid of ->cur_rr and ->cfq_list cfq-iosched: slice offset should take ioprio into account [PATCH] cfq-iosched: style cleanups and comments cfq-iosched: sort IDLE queues into the rbtree cfq-iosched: sort RT queues into the rbtree [PATCH] cfq-iosched: speed up rbtree handling cfq-iosched: rework the whole round-robin list concept cfq-iosched: minor updates cfq-iosched: development update cfq-iosched: improve preemption for cooperating tasks
2007-04-30[BLOCK] Don't pin lots of memory in mempoolsJens Axboe
Currently we scale the mempool sizes depending on memory installed in the machine, except for the bio pool itself which sits at a fixed 256 entry pre-allocation. There's really no point in "optimizing" this OOM path, we just need enough preallocated to make progress. A single unit is enough, lets scale it down to 2 just to be on the safe side. This patch saves ~150kb of pinned kernel memory on a 32-bit box. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30Merge branch 'linux-2.6' into for-2.6.22Paul Mackerras
2007-04-27Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [NET]: Fix networking compilation errors [AF_RXRPC/AFS]: Arch-specific fixes. [AFS]: Fix VLocation record update wakeup [NET]: Revert sk_buff walker cleanups.
2007-04-27Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (46 commits) [MTD] [MAPS] drivers/mtd/maps/ck804xrom.c: convert pci_module_init() [MTD] [NAND] CM-x270 MTD driver [MTD] [NAND] Wrong calculation of page number in nand_block_bad() [MTD] [MAPS] fix plat-ram printk format [JFFS2] Fix compr_rubin.c build after include file elimination. [JFFS2] Handle inodes with only a single metadata node with non-zero isize [JFFS2] Tidy up licensing/copyright boilerplate. [MTD] [OneNAND] Exit loop only when column start with 0 [MTD] [OneNAND] Fix access the past of the real oobfree array [MTD] [OneNAND] Update Samsung OneNAND official URL [JFFS2] Better fix for all-zero node headers [JFFS2] Improve read_inode memory usage, v2. [JFFS2] Improve failure mode if inode checking leaves unchecked space. [JFFS2] Fix cross-endian build. [MTD] Finish conversion mtd_blkdevs to use the kthread API [JFFS2] Obsolete dirent nodes immediately on unlink, where possible. Use menuconfig objects: MTD [MTD] mtd_blkdevs: Convert to use the kthread API [MTD] Fix fwh_lock locking [JFFS2] Speed up mount for directly-mapped NOR flash ...
2007-04-27[AF_RXRPC/AFS]: Arch-specific fixes.David Howells
Fixes for various arch compilation problems: (*) Missing module exports. (*) Variable name collision when rxkad and af_rxrpc both built in (rxrpc_debug). (*) Large constant representation problem (AFS_UUID_TO_UNIX_TIME). (*) Configuration dependencies. (*) printk() format warnings. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-27[AFS]: Fix VLocation record update wakeupDavid Howells
Fix the wakeup transitions after a VLocation record update completes one way or another. This builds on Dave Miller's partial fix. Also move wakeups outside the spinlocked sections. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-27Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6: (46 commits) dev_dbg: check dev_dbg() arguments drivers/base/attribute_container.c: use mutex instead of binary semaphore mod_sysfs_setup() doesn't return errno when kobject_add_dir() failure occurs s2ram: add arch irq disable/enable hooks define platform wakeup hook, use in pci_enable_wake() security: prevent permission checking of file removal via sysfs_remove_group() device_schedule_callback() needs a module reference s390: cio: Delay uevents for subchannels sysfs: bin.c printk fix Driver core: use mutex instead of semaphore in DMA pool handler driver core: bus_add_driver should return an error if no bus debugfs: Add debugfs_create_u64() the overdue removal of the mount/umount uevents kobject: Comment and warning fixes to kobject.c Driver core: warn when userspace writes to the uevent file in a non-supported way Driver core: make uevent-environment available in uevent-file kobject core: remove rwsem from struct subsystem qeth: Remove usage of subsys.rwsem PHY: remove rwsem use from phy core IEEE1394: remove rwsem use from ieee1394 core ...
2007-04-27Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/mtd/Kconfig Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-04-27security: prevent permission checking of file removal via sysfs_remove_group()James Morris
Prevent permission checking from being performed when the kernel wants to unconditionally remove a sysfs group, by introducing an kernel-only variant of lookup_one_len(), lookup_one_len_kern(). Additionally, as sysfs_remove_group() does not check the return value of the lookup before using it, a BUG_ON has been added to pinpoint the cause of any problems potentially caused by this (and as a form of annotation). Signed-off-by: James Morris <jmorris@namei.org> Cc: Nagendra Singh Tomar <nagendra_tomar@adaptec.com> Cc: Tejun Heo <htejun@gmail.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27device_schedule_callback() needs a module referenceAlan Stern
This patch (as896b) fixes an oversight in the design of device_schedule_callback(). It is necessary to acquire a reference to the module owning the callback routine, to prevent the module from being unloaded before the callback can run. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: Satyam Sharma <satyam.sharma@gmail.com> Cc: Neil Brown <neilb@suse.de> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27sysfs: bin.c printk fixAndrew Morton
fs/sysfs/bin.c: In function 'read': fs/sysfs/bin.c:77: warning: format '%zd' expects type 'signed size_t', but argument 4 has type 'int' Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27debugfs: Add debugfs_create_u64()Michael Ellerman
I went to use this the other day, only to find it didn't exist. It's a straight copy of the debugfs u32 code, then s/u32/u64/. A quick test shows it seems to be working. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27the overdue removal of the mount/umount ueventsAdrian Bunk
This patch contains the overdue removal of the mount/umount uevents. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27Merge branch 'for-linus' of git://git.infradead.org/ubi-2.6Linus Torvalds
* 'for-linus' of git://git.infradead.org/ubi-2.6: UBI: remove unused variable UBI: add me to MAINTAINERS JFFS2: add UBI support UBI: Unsorted Block Images
2007-04-27Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2: (27 commits) ocfs2: Cache extent records ocfs2: Remember rw lock level during direct io ocfs2: Fix up i_blocks calculation to know about holes ocfs2: Fix extent lookup to return true size of holes ocfs2: Read from an unwritten extent returns zeros ocfs2: make room for unwritten extents flag ocfs2: Use own splice write actor ocfs2: Use do_sync_mapping_range() in ocfs2_zero_tail_for_truncate() [PATCH] Turn do_sync_file_range() into do_sync_mapping_range() ocfs2: zero tail of sparse files on truncate ocfs2: Teach ocfs2_get_block() about holes ocfs2: remove ocfs2_prepare_write() and ocfs2_commit_write() ocfs2: teach ocfs2_file_aio_write() about sparse files ocfs2: Turn off shared writeable mmap for local files systems with holes. ocfs2: abstract out allocation locking ocfs2: teach extend/truncate about sparse files ocfs2: temporarily remove extent map caching ocfs2: sparse b-tree support ocfs2: small cleanup of ocfs2_request_delete() ocfs2: remove unused code ...
2007-04-27JFFS2: add UBI supportArtem Bityutskiy
This patch make JFFS2 able to work with UBI volumes via the emulated MTD devices which are directly mapped to these volumes. Signed-off-by: Artem Bityutskiy <dedekind@infradead.org>
2007-04-26[AFS]: Eliminate cmpxchg() usage in vlocation code.David S. Miller
cmpxchg() is not available on every processor so can't be used in generic code. Replace with spinlock protection on the ->state changes, wakeups, and wait loops. Add what appears to be a missing wakeup on transition to AFS_VL_VALID state in afs_vlocation_updater(). Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Fix u64 printing in debug logging.David S. Miller
Need 'unsigned long long' casts to quiet warnings on 64-bit platforms when using %ll on a u64. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Add "directory write" support.David Howells
Add support for the create, link, symlink, unlink, mkdir, rmdir and rename VFS operations to the in-kernel AFS filesystem. Also: (1) Fix dentry and inode revalidation. d_revalidate should only look at state of the dentry. Revalidation of the contents of an inode pointed to by a dentry is now separate. (2) Fix afs_lookup() to hash negative dentries as well as positive ones. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Implement the CB.InitCallBackState3 operation.David Howells
Implement the CB.InitCallBackState3 operation for the fileserver to call. This reduces the amount of network traffic because if this op is aborted, the fileserver will then attempt an CB.InitCallBackState operation. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Add support for the CB.GetCapabilities operation.David Howells
Add support for the CB.GetCapabilities operation with which the fileserver can ask the client for the following information: (1) The list of network interfaces it has available as IPv4 address + netmask plus the MTUs. (2) The client's UUID. (3) The extended capabilities of the client, for which the only current one is unified error mapping (abort code interpretation). To support this, the patch adds the following routines to AFS: (1) A function to iterate through all the network interfaces using RTNETLINK to extract IPv4 addresses and MTUs. (2) A function to iterate through all the network interfaces using RTNETLINK to pull out the MAC address of the lowest index interface to use in UUID construction. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Add security support.David Howells
Add security support to the AFS filesystem. Kerberos IV tickets are added as RxRPC keys are added to the session keyring with the klog program. open() and other VFS operations then find this ticket with request_key() and either use it immediately (eg: mkdir, unlink) or attach it to a file descriptor (open). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Handle multiple mounts of an AFS superblock correctly.David Howells
Handle multiple mounts of an AFS superblock correctly, checking to see whether the superblock is already initialised after calling sget() rather than just unconditionally stamping all over it. Also delete the "silent" parameter to afs_fill_super() as it's not used and can, in any case, be obtained from sb->s_flags. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Delete the old RxRPC code.David Howells
Delete the old RxRPC code as it's now no longer used. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Make the in-kernel AFS filesystem use AF_RXRPC.David Howells
Make the in-kernel AFS filesystem use AF_RXRPC instead of the old RxRPC code. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Clean up the AFS sourcesDavid Howells
Clean up the AFS sources. Also remove references to AFS keys. RxRPC keys are used instead. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26ocfs2: Cache extent recordsMark Fasheh
The extent map code was ripped out earlier because of an inability to deal with holes. This patch adds back a simpler caching scheme requiring far less code. Our old extent map caching was designed back when meta data block caching in Ocfs2 didn't work very well, resulting in many disk reads. These days our metadata caching is much better, resulting in no un-necessary disk reads. As a result, extent caching doesn't have to be as fancy, nor does it have to cache as many extents. Keeping the last 3 extents seen should be sufficient to give us a small performance boost on some streaming workloads. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Remember rw lock level during direct ioMark Fasheh
Cluster locking might have been redone because a direct write won't complete, so this needs to be reflected in the iocb. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Fix up i_blocks calculation to know about holesMark Fasheh
Older file systems which didn't support holes did a dumb calculation of i_blocks based on i_size. This is no longer accurate, so fix things up to take actual allocation into account. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Fix extent lookup to return true size of holesMark Fasheh
Initially, we had wired things to return a size '1' of holes. Cook up a small amount of code to find the next extent and calculate the number of clusters between the virtual offset and the next allocated extent. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Read from an unwritten extent returns zerosMark Fasheh
Return an optional extent flags field from our lookup functions and wire up callers to treat unwritten regions as holes for the purpose of returning zeros to the user. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: make room for unwritten extents flagMark Fasheh
Due to the size of our group bitmaps, we'll never have a leaf node extent record with more than 16 bits worth of clusters. Split e_clusters up so that leaf nodes can get a flags field where we can mark unwritten extents. Interior nodes whose length references all the child nodes beneath it can't split their e_clusters field, so we use a union to preserve sizing there. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Use own splice write actorMark Fasheh
We need to fill holes during a splice write. Provide our own splice write actor which can call ocfs2_file_buffered_write() with a splice-specific callback. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Use do_sync_mapping_range() in ocfs2_zero_tail_for_truncate()Mark Fasheh
Do this instead of filemap_fdatawrite() - this way we sync only the range between i_size and the cluster boundary. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26[PATCH] Turn do_sync_file_range() into do_sync_mapping_range()Mark Fasheh
do_sync_file_range() accepts a file * from which it takes an address_space to sync. Abstract out the bulk of the function into do_sync_mapping_range() which takes the address_space directly. This way callers who want to sync an address_space directly can take advantage of the functionality provided. do_sync_file_range() is preserved as a small wrapper around do_sync_mapping_range(). Ocfs2 in particular would like to use this to initiate a sync of a specific inode range during truncate, where a file * may not be available. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-04-26ocfs2: zero tail of sparse files on truncateMark Fasheh
Since we don't zero on extend anymore, truncate needs to be fixed up to zero the part of a file between i_size and and end of it's cluster. Otherwise a subsequent extend could expose bad data. This introduced a new helper, which can be used in ocfs2_write(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Teach ocfs2_get_block() about holesMark Fasheh
ocfs2_get_block() didn't understand sparse files, fix that. Also remove some code that isn't really useful anymore. We can fix up ocfs2_direct_IO_get_blocks() at the same time. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: remove ocfs2_prepare_write() and ocfs2_commit_write()Mark Fasheh
These are no longer used, and can't handle file systems with sparse file allocation. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: teach ocfs2_file_aio_write() about sparse filesMark Fasheh
Unfortunately, ocfs2 can no longer make use of generic_file_aio_write_nlock() because allocating writes will require zeroing of pages adjacent to the I/O for cluster sizes greater than page size. Implement a custom file write here, which can order page locks for zeroing. This also has the advantage that cluster locks can easily be ordered outside of the page locks. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Turn off shared writeable mmap for local files systems with holes.Mark Fasheh
This will be turned back on once we can do allocation in ->page_mkwrite(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: abstract out allocation lockingMark Fasheh
Right now, file allocation for ocfs2 is done within ocfs2_extend_file(), which is either called from ->setattr() (for an i_size change), or at the top of ocfs2_file_aio_write(). Inodes on file systems with sparse file support will want to do their allocation during the actual write call. In either case the cluster locking decisions are the same. We abstract out that code into a new function, ocfs2_lock_allocators() which will be used by a later patch to enable writing to sparse files. This also provides a nice cleanup of ocfs2_extend_allocation(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: teach extend/truncate about sparse filesMark Fasheh
For ocfs2_truncate_file(), we eliminate the "simple" truncate case which no longer exists since i_size is not tied to i_clusters. In ocfs2_extend_file(), we skip the allocation / page zeroing code for file systems which understand sparse files. The core truncate code is changed to do a bottom up tree traversal. This gets abstracted out into it's own function. To make things more readable, most of the special case handling for in-inode extents from ocfs2_do_truncate() is also removed. Though write support for sparse files comes in a later patch, we at least update ocfs2_prepare_inode_for_write() to skip allocation for sparse files. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: temporarily remove extent map cachingMark Fasheh
The code in extent_map.c is not prepared to deal with a subtree being rotated between lookups. This can happen when filling holes in sparse files. Instead of a lengthy patch to update the code (which would likely lose the benefit of caching subtree roots), we remove most of the algorithms and implement a simple path based lookup. A less ambitious extent caching scheme will be added in a later patch. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: sparse b-tree supportMark Fasheh
Introduce tree rotations into the b-tree code. This will allow ocfs2 to support sparse files. Much of the added code is designed to be generic (in the ocfs2 sense) so that it can later be re-used to implement large extended attributes. This patch only adds the rotation code and does minimal updates to callers of the extent api. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: small cleanup of ocfs2_request_delete()Mark Fasheh
There are two checks in there (one for inode newness, one for other mounted nodes) which are unnecessary, so remove them. The DLM will allow the trylock in either case without any messaging overhead. Removing these makes ocfs2_request_delete() a one liner function, so just move the trylock out one level into ocfs2_query_inode_wipe(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: remove unused codeTiger Yang
Remove node messaging code that becomes unused with the delete inode vote removal. [Removed even more cruft which I spotted during review --Mark] Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Remove delete inode voteTiger Yang
Ocfs2 currently does cluster-wide node messaging to check the open state of an inode during delete. This patch removes that mechanism in favor of an inode cluster lock which is taken at shared read when an inode is first read and dropped in clear_inode(). This allows a deleting node to test the liveness of an inode by attempting to take an exclusive lock. Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: filter more error printsMark Fasheh
We don't want to print anything at all in ocfs2_lookup() when getting an error from ocfs2_iget() - it could be something as innocuous as a signal being detected in the dlm. ocfs2_permission() should filter on -ENOENT which ocfs2_meta_lock() can return if the inode was deleted on another node. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
