commit 0e9a9a1ad619e7e987815d20262d36a2f95717ca upstream.
When trying to mount a file system which does not contain a journal,
but which does have a orphan list containing an inode which needs to
be truncated, the mount call with hang forever in
ext4_orphan_cleanup() because ext4_orphan_del() will return
immediately without removing the inode from the orphan list, leading
to an uninterruptible loop in kernel code which will busy out one of
the CPU's on the system.
This can be trivially reproduced by trying to mount the file system
found in tests/f_orphan_extents_inode/image.gz from the e2fsprogs
source tree. If a malicious user were to put this on a USB stick, and
mount it on a Linux desktop which has automatic mounts enabled, this
could be considered a potential denial of service attack. (Not a big
deal in practice, but professional paranoids worry about such things,
and have even been known to allocate CVE numbers for such problems.)
-js: This is a fix for CVE-2013-2015.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Reviewed-by: Zheng Liu <wenqing.lz@taobao.com>
Acked-by: Jan Kara <jack@suse.cz>
commit 17b7f7cf58926844e1dd40f5eb5348d481deca6a upstream.
Refuse RW mount of isofs filesystem. So far we just silently changed it
to RO mount but when the media is writeable, block layer won't notice
this change and thus will think device is used RW and will block eject
button of the drive. That is unexpected by users because for
non-writeable media eject button works just fine.
Userspace mount(8) command handles this just fine and retries mounting
with MS_RDONLY set so userspace shouldn't see any regression. Plus any
tool mounting isofs is likely confronted with the case of read-only
media where block layer already refuses to mount the filesystem without
MS_RDONLY set so our behavior shouldn't be anything new for it.
Reported-by: Hui Wang <hui.wang@canonical.com>
commit 03a1cec1f17ac1a6041996b3e40f96b5a2f90e1b upstream.
Boyd Yang reported a problem for the case that multiple threads of the same
thread group are waiting for a reponse for a permission event.
In this case it is possible that some of the threads are never woken up, even
if the response for the event has been received
(see http://marc.info/?l=linux-kernel&m=131822913806350&w=2).
The reason is that we are currently merging permission events if they belong to
the same thread group. But we are not prepared to wake up more than one waiter
for each event. We do
wait_event(group->fanotify_data.access_waitq, event->response ||
atomic_read(&group->fanotify_data.bypass_perm));
and after that
event->response = 0;
which is the reason that even if we woke up all waiters for the same event
some of them may see event->response being already set 0 again, then go back to
sleep and block forever.
With this patch we avoid that more than one thread is waiting for a response
by not merging permission events for the same thread group any more.
Reported-by: Boyd Yang <boyd.yang@gmail.com>
Signed-off-by: Lino Sanfilippo <LinoSanfilipp@gmx.de>
Signed-off-by: Eric Paris <eparis@redhat.com>
commit 776164c1faac4966ab14418bb0922e1820da1d19 upstream.
debugfs_remove_recursive() is wrong,
1. it wrongly assumes that !list_empty(d_subdirs) means that this
dir should be removed.
This is not that bad by itself, but:
2. if d_subdirs does not becomes empty after __debugfs_remove()
it gives up and silently fails, it doesn't even try to remove
other entries.
However ->d_subdirs can be non-empty because it still has the
already deleted !debugfs_positive() entries.
3. simple_release_fs() is called even if __debugfs_remove() fails.
Suppose we have
dir1/
dir2/
file2
file1
and someone opens dir1/dir2/file2.
Now, debugfs_remove_recursive(dir1/dir2) succeeds, and dir1/dir2 goes
away.
But debugfs_remove_recursive(dir1) silently fails and doesn't remove
this directory. Because it tries to delete (the already deleted)
dir1/dir2/file2 again and then fails due to "Avoid infinite loop"
logic.
Test-case:
#!/bin/sh
cd /sys/kernel/debug/tracing
echo 'p:probe/sigprocmask sigprocmask' >> kprobe_events
sleep 1000 < events/probe/sigprocmask/id &
echo -n >| kprobe_events
[ -d events/probe ] && echo "ERR!! failed to rm probe"
And after that it is not possible to create another probe entry.
With this patch debugfs_remove_recursive() skips !debugfs_positive()
files although this is not strictly needed. The most important change
is that it does not try to make ->d_subdirs empty, it simply scans
the whole list(s) recursively and removes as much as possible.
Link: http://lkml.kernel.org/r/20130726151256.GC19472@redhat.com
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
dirty blocks
commit 7f42ec3941560f0902fe3671e36f2c20ffd3af0a upstream.
Many NILFS2 users were reported about strange file system corruption
(for example):
NILFS: bad btree node (blocknr=185027): level = 0, flags = 0x0, nchildren = 768
NILFS error (device sda4): nilfs_bmap_last_key: broken bmap (inode number=11540)
But such error messages are consequence of file system's issue that takes
place more earlier. Fortunately, Jerome Poulin <jeromepoulin@gmail.com>
and Anton Eliasson <devel@antoneliasson.se> were reported about another
issue not so recently. These reports describe the issue with segctor
thread's crash:
BUG: unable to handle kernel paging request at 0000000000004c83
IP: nilfs_end_page_io+0x12/0xd0 [nilfs2]
Call Trace:
nilfs_segctor_do_construct+0xf25/0x1b20 [nilfs2]
nilfs_segctor_construct+0x17b/0x290 [nilfs2]
nilfs_segctor_thread+0x122/0x3b0 [nilfs2]
kthread+0xc0/0xd0
ret_from_fork+0x7c/0xb0
These two issues have one reason. This reason can raise third issue
too. Third issue results in hanging of segctor thread with eating of
100% CPU.
REPRODUCING PATH:
One of the possible way or the issue reproducing was described by
Jermoe me Poulin <jeromepoulin@gmail.com>:
1. init S to get to single user mode.
2. sysrq+E to make sure only my shell is running
3. start network-manager to get my wifi connection up
4. login as root and launch "screen"
5. cd /boot/log/nilfs which is a ext3 mount point and can log when NILFS dies.
6. lscp | xz -9e > lscp.txt.xz
7. mount my snapshot using mount -o cp=3360839,ro /dev/vgUbuntu/root /mnt/nilfs
8. start a screen to dump /proc/kmsg to text file since rsyslog is killed
9. start a screen and launch strace -f -o find-cat.log -t find
/mnt/nilfs -type f -exec cat {} > /dev/null \;
10. start a screen and launch strace -f -o apt-get.log -t apt-get update
11. launch the last command again as it did not crash the first time
12. apt-get crashes
13. ps aux > ps-aux-crashed.log
13. sysrq+W
14. sysrq+E wait for everything to terminate
15. sysrq+SUSB
Simplified way of the issue reproducing is starting kernel compilation
task and "apt-get update" in parallel.
REPRODUCIBILITY:
The issue is reproduced not stable [60% - 80%]. It is very important to
have proper environment for the issue reproducing. The critical
conditions for successful reproducing:
(1) It should have big modified file by mmap() way.
(2) This file should have the count of dirty blocks are greater that
several segments in size (for example, two or three) from time to time
during processing.
(3) It should be intensive background activity of files modification
in another thread.
INVESTIGATION:
First of all, it is possible to see that the reason of crash is not valid
page address:
NILFS [nilfs_segctor_complete_write]:2100 bh->b_count 0, bh->b_blocknr 13895680, bh->b_size 13897727, bh->b_page 0000000000001a82
NILFS [nilfs_segctor_complete_write]:2101 segbuf->sb_segnum 6783
Moreover, value of b_page (0x1a82) is 6786. This value looks like segment
number. And b_blocknr with b_size values look like block numbers. So,
buffer_head's pointer points on not proper address value.
Detailed investigation of the issue is discovered such picture:
[-----------------------------SEGMENT 6783-------------------------------]
NILFS [nilfs_segctor_do_construct]:2310 nilfs_segctor_begin_construction
NILFS [nilfs_segctor_do_construct]:2321 nilfs_segctor_collect
NILFS [nilfs_segctor_do_construct]:2336 nilfs_segctor_assign
NILFS [nilfs_segctor_do_construct]:2367 nilfs_segctor_update_segusage
NILFS [nilfs_segctor_do_construct]:2371 nilfs_segctor_prepare_write
NILFS [nilfs_segctor_do_construct]:2376 nilfs_add_checksums_on_logs
NILFS [nilfs_segctor_do_construct]:2381 nilfs_segctor_write
NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111149024, segbuf->sb_segnum 6783
[-----------------------------SEGMENT 6784-------------------------------]
NILFS [nilfs_lookup_dirty_data_buffers]:782 bh->b_count 1, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824
NILFS [nilfs_lookup_dirty_data_buffers]:783 bh->b_assoc_buffers.next ffff8802174a6798, bh->b_assoc_buffers.prev ffff880221cffee8
NILFS [nilfs_segbuf_submit_bh]:575 bh->b_count 1, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824
NILFS [nilfs_segbuf_submit_bh]:576 segbuf->sb_segnum 6784
NILFS [nilfs_segbuf_submit_bh]:577 bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880218bcdf50
NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111150080, segbuf->sb_segnum 6784, segbuf->sb_nbio 0
[----------] ditto
NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111164416, segbuf->sb_segnum 6784, segbuf->sb_nbio 15
[-----------------------------SEGMENT 6785-------------------------------]
NILFS [nilfs_lookup_dirty_data_buffers]:782 bh->b_count 2, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824
NILFS [nilfs_lookup_dirty_data_buffers]:783 bh->b_assoc_buffers.next ffff880219277e80, bh->b_assoc_buffers.prev ffff880221cffc88
NILFS [nilfs_segbuf_submit_bh]:575 bh->b_count 2, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824
NILFS [nilfs_segbuf_submit_bh]:576 segbuf->sb_segnum 6785
NILFS [nilfs_segbuf_submit_bh]:577 bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880222cc7ee8
NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111165440, segbuf->sb_segnum 6785, segbuf->sb_nbio 0
[----------] ditto
NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111177728, segbuf->sb_segnum 6785, segbuf->sb_nbio 12
NILFS [nilfs_segctor_do_construct]:2399 nilfs_segctor_wait
NILFS [nilfs_segbuf_wait]:676 segbuf->sb_segnum 6783
NILFS [nilfs_segbuf_wait]:676 segbuf->sb_segnum 6784
NILFS [nilfs_segbuf_wait]:676 segbuf->sb_segnum 6785
BUG: unable to handle kernel paging request at 0000000000001a82
IP: [<ffffffffa024d0f2>] nilfs_end_page_io+0x12/0xd0 [nilfs2]
Usually, for every segment we collect dirty files in list. Then, dirty
blocks are gathered for every dirty file, prepared for write and
submitted by means of nilfs_segbuf_submit_bh() call. Finally, it takes
place complete write phase after calling nilfs_end_bio_write() on the
block layer. Buffers/pages are marked as not dirty on final phase and
processed files removed from the list of dirty files.
It is possible to see that we had three prepare_write and submit_bio
phases before segbuf_wait and complete_write phase. Moreover, segments
compete between each other for dirty blocks because on every iteration
of segments processing dirty buffer_heads are added in several lists of
payload_buffers:
[SEGMENT 6784]: bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880218bcdf50
[SEGMENT 6785]: bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880222cc7ee8
The next pointer is the same but prev pointer has changed. It means
that buffer_head has next pointer from one list but prev pointer from
another. Such modification can be made several times. And, finally, it
can be resulted in various issues: (1) segctor hanging, (2) segctor
crashing, (3) file system metadata corruption.
FIX:
This patch adds:
(1) setting of BH_Async_Write flag in nilfs_segctor_prepare_write()
for every proccessed dirty block;
(2) checking of BH_Async_Write flag in
nilfs_lookup_dirty_data_buffers() and
nilfs_lookup_dirty_node_buffers();
(3) clearing of BH_Async_Write flag in nilfs_segctor_complete_write(),
nilfs_abort_logs(), nilfs_forget_buffer(), nilfs_clear_dirty_page().
Reported-by: Jerome Poulin <jeromepoulin@gmail.com>
Reported-by: Anton Eliasson <devel@antoneliasson.se>
Cc: Paul Fertser <fercerpav@gmail.com>
Cc: ARAI Shun-ichi <hermes@ceres.dti.ne.jp>
Cc: Piotr Szymaniak <szarpaj@grubelek.pl>
Cc: Juan Barry Manuel Canham <Linux@riotingpacifist.net>
Cc: Zahid Chowdhury <zahid.chowdhury@starsolutions.com>
Cc: Elmer Zhang <freeboy6716@gmail.com>
Cc: Kenneth Langga <klangga@gmail.com>
Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
[bwh: Backported to 3.2: nilfs_clear_dirty_page() has not been separated
from nilfs_clear_dirty_pages()]
commit 28e8be31803b19d0d8f76216cb11b480b8a98bec upstream.
Call fiemap ioctl(2) with given start offset as well as an desired mapping
range should show extents if possible. However, we somehow figure out the
end offset of mapping via 'mapping_end -= cpos' before iterating the
extent records which would cause problems if the given fiemap length is
too small to a cluster size, e.g,
Cluster size 4096:
debugfs.ocfs2 1.6.3
Block Size Bits: 12 Cluster Size Bits: 12
The extended fiemap test utility From David:
https://gist.github.com/anonymous/6172331
# dd if=/dev/urandom of=/ocfs2/test_file bs=1M count=1000
# ./fiemap /ocfs2/test_file 4096 10
start: 4096, length: 10
File /ocfs2/test_file has 0 extents:
# Logical Physical Length Flags
^^^^^ <-- No extent is shown
In this case, at ocfs2_fiemap(): cpos == mapping_end == 1. Hence the
loop of searching extent records was not executed at all.
This patch remove the in question 'mapping_end -= cpos', and loops
until the cpos is larger than the mapping_end as usual.
File /ocfs2/test_file has 1 extents:
0: 0000000000000000 0000000056a01000 0000000006a00000 0000
Signed-off-by: Jie Liu <jeff.liu@oracle.com>
Reported-by: David Weber <wb@munzinger.de>
Tested-by: David Weber <wb@munzinger.de>
Cc: Sunil Mushran <sunil.mushran@gmail.com>
Cc: Mark Fashen <mfasheh@suse.de>
commit efeb9e60d48f7778fdcad4a0f3ad9ea9b19e5dfd upstream.
Userspace can add names containing a slash character to the directory
listing. Don't allow this as it could cause all sorts of trouble.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
[bwh: Backported to 3.2: drop changes to parse_dirplusfile() which we
don't have]
commit 06a7c3c2781409af95000c60a5df743fd4e2f8b4 upstream.
The way how fuse calls truncate_pagecache() from fuse_change_attributes()
is completely wrong. Because, w/o i_mutex held, we never sure whether
'oldsize' and 'attr->size' are valid by the time of execution of
truncate_pagecache(inode, oldsize, attr->size). In fact, as soon as we
released fc->lock in the middle of fuse_change_attributes(), we completely
loose control of actions which may happen with given inode until we reach
truncate_pagecache. The list of potentially dangerous actions includes
mmap-ed reads and writes, ftruncate(2) and write(2) extending file size.
The typical outcome of doing truncate_pagecache() with outdated arguments
is data corruption from user point of view. This is (in some sense)
acceptable in cases when the issue is triggered by a change of the file on
the server (i.e. externally wrt fuse operation), but it is absolutely
intolerable in scenarios when a single fuse client modifies a file without
any external intervention. A real life case I discovered by fsx-linux
looked like this:
1. Shrinking ftruncate(2) comes to fuse_do_setattr(). The latter sends
FUSE_SETATTR to the server synchronously, but before getting fc->lock ...
2. fuse_dentry_revalidate() is asynchronously called. It sends FUSE_LOOKUP
to the server synchronously, then calls fuse_change_attributes(). The
latter updates i_size, releases fc->lock, but before comparing oldsize vs
attr->size..
3. fuse_do_setattr() from the first step proceeds by acquiring fc->lock and
updating attributes and i_size, but now oldsize is equal to
outarg.attr.size because i_size has just been updated (step 2). Hence,
fuse_do_setattr() returns w/o calling truncate_pagecache().
4. As soon as ftruncate(2) completes, the user extends file size by
write(2) making a hole in the middle of file, then reads data from the hole
either by read(2) or mmap-ed read. The user expects to get zero data from
the hole, but gets stale data because truncate_pagecache() is not executed
yet.
The scenario above illustrates one side of the problem: not truncating the
page cache even though we should. Another side corresponds to truncating
page cache too late, when the state of inode changed significantly.
Theoretically, the following is possible:
1. As in the previous scenario fuse_dentry_revalidate() discovered that
i_size changed (due to our own fuse_do_setattr()) and is going to call
truncate_pagecache() for some 'new_size' it believes valid right now. But
by the time that particular truncate_pagecache() is called ...
2. fuse_do_setattr() returns (either having called truncate_pagecache() or
not -- it doesn't matter).
3. The file is extended either by write(2) or ftruncate(2) or fallocate(2).
4. mmap-ed write makes a page in the extended region dirty.
The result will be the lost of data user wrote on the fourth step.
The patch is a hotfix resolving the issue in a simplistic way: let's skip
dangerous i_size update and truncate_pagecache if an operation changing
file size is in progress. This simplistic approach looks correct for the
cases w/o external changes. And to handle them properly, more sophisticated
and intrusive techniques (e.g. NFS-like one) would be required. I'd like to
postpone it until the issue is well discussed on the mailing list(s).
Changed in v2:
- improved patch description to cover both sides of the issue.
Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com>
[bwh: Backported to 3.2: add the fuse_inode::state field which we didn't have]
commit d331a415aef98717393dda0be69b7947da08eba3 upstream.
Calls like setxattr and removexattr result in updation of ctime.
Therefore invalidate inode attributes to force a refresh.
Signed-off-by: Anand Avati <avati@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
commit 4a4ac4eba1010ef9a804569058ab29e3450c0315 upstream.
The patch fixes a race between ftruncate(2), mmap-ed write and write(2):
1) An user makes a page dirty via mmap-ed write.
2) The user performs shrinking truncate(2) intended to purge the page.
3) Before fuse_do_setattr calls truncate_pagecache, the page goes to
writeback. fuse_writepage_locked fills FUSE_WRITE request and releases
the original page by end_page_writeback.
4) fuse_do_setattr() completes and successfully returns. Since now, i_mutex
is free.
5) Ordinary write(2) extends i_size back to cover the page. Note that
fuse_send_write_pages do wait for fuse writeback, but for another
page->index.
6) fuse_writepage_locked proceeds by queueing FUSE_WRITE request.
fuse_send_writepage is supposed to crop inarg->size of the request,
but it doesn't because i_size has already been extended back.
Moving end_page_writeback to the end of fuse_writepage_locked fixes the
race because now the fact that truncate_pagecache is successfully returned
infers that fuse_writepage_locked has already called end_page_writeback.
And this, in turn, infers that fuse_flush_writepages has already called
fuse_send_writepage, and the latter used valid (shrunk) i_size. write(2)
could not extend it because of i_mutex held by ftruncate(2).
error detection
commit 4bf93b50fd04118ac7f33a3c2b8a0a1f9fa80bc9 upstream.
Fix the issue with improper counting number of flying bio requests for
BIO_EOPNOTSUPP error detection case.
The sb_nbio must be incremented exactly the same number of times as
complete() function was called (or will be called) because
nilfs_segbuf_wait() will call wail_for_completion() for the number of
times set to sb_nbio:
do {
wait_for_completion(&segbuf->sb_bio_event);
} while (--segbuf->sb_nbio > 0);
Two functions complete() and wait_for_completion() must be called the
same number of times for the same sb_bio_event. Otherwise,
wait_for_completion() will hang or leak.
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
error
commit 2df37a19c686c2d7c4e9b4ce1505b5141e3e5552 upstream.
Remove double call of bio_put() in nilfs_end_bio_write() for the case of
BIO_EOPNOTSUPP error detection. The issue was found by Dan Carpenter
and he suggests first version of the fix too.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
commit 35dc248383bbab0a7203fca4d722875bc81ef091 upstream.
There is a nasty bug in the SCSI SG_IO ioctl that in some circumstances
leads to one process writing data into the address space of some other
random unrelated process if the ioctl is interrupted by a signal.
What happens is the following:
- A process issues an SG_IO ioctl with direction DXFER_FROM_DEV (ie the
underlying SCSI command will transfer data from the SCSI device to
the buffer provided in the ioctl)
- Before the command finishes, a signal is sent to the process waiting
in the ioctl. This will end up waking up the sg_ioctl() code:
result = wait_event_interruptible(sfp->read_wait,
(srp_done(sfp, srp) || sdp->detached));
but neither srp_done() nor sdp->detached is true, so we end up just
setting srp->orphan and returning to userspace:
srp->orphan = 1;
write_unlock_irq(&sfp->rq_list_lock);
return result; /* -ERESTARTSYS because signal hit process */
At this point the original process is done with the ioctl and
blithely goes ahead handling the signal, reissuing the ioctl, etc.
- Eventually, the SCSI command issued by the first ioctl finishes and
ends up in sg_rq_end_io(). At the end of that function, we run through:
write_lock_irqsave(&sfp->rq_list_lock, iflags);
if (unlikely(srp->orphan)) {
if (sfp->keep_orphan)
srp->sg_io_owned = 0;
else
done = 0;
srp->done = done;
write_unlock_irqrestore(&sfp->rq_list_lock, iflags);
if (likely(done)) {
/* Now wake up any sg_read() that is waiting for this
* packet.
wake_up_interruptible(&sfp->read_wait);
kill_fasync(&sfp->async_qp, SIGPOLL, POLL_IN);
kref_put(&sfp->f_ref, sg_remove_sfp);
} else {
INIT_WORK(&srp->ew.work, sg_rq_end_io_usercontext);
schedule_work(&srp->ew.work);
Since srp->orphan *is* set, we set done to 0 (assuming the
userspace app has not set keep_orphan via an SG_SET_KEEP_ORPHAN
ioctl), and therefore we end up scheduling sg_rq_end_io_usercontext()
to run in a workqueue.
- In workqueue context we go through sg_rq_end_io_usercontext() ->
sg_finish_rem_req() -> blk_rq_unmap_user() -> ... ->
bio_uncopy_user() -> __bio_copy_iov() -> copy_to_user().
The key point here is that we are doing copy_to_user() on a
workqueue -- that is, we're on a kernel thread with current->mm
equal to whatever random previous user process was scheduled before
this kernel thread. So we end up copying whatever data the SCSI
command returned to the virtual address of the buffer passed into
the original ioctl, but it's quite likely we do this copying into a
different address space!
As suggested by James Bottomley <James.Bottomley@hansenpartnership.com>,
add a check for current->mm (which is NULL if we're on a kernel thread
without a real userspace address space) in bio_uncopy_user(), and skip
the copy if we're on a kernel thread.
There's no reason that I can think of for any caller of bio_uncopy_user()
to want to do copying on a kernel thread with a random active userspace
address space.
Huge thanks to Costa Sapuntzakis <costa@purestorage.com> for the
original pointer to this bug in the sg code.
Signed-off-by: Roland Dreier <roland@purestorage.com>
Tested-by: David Milburn <dmilburn@redhat.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit d74c6d514fe314b8bdab58b487b25992291577ec upstream.
__bio_for_each_segment() iterates bvecs from the specified index
instead of bio->bv_idx. Currently, the only usage is to walk all the
bvecs after the bio has been advanced by specifying 0 index.
For immutable bvecs, we need to split these apart;
bio_for_each_segment() is going to have a different implementation.
This will also help document the intent of code that's using it -
bio_for_each_segment_all() is only legal to use for code that owns the
bio.
Signed-off-by: Kent Overstreet <koverstreet@google.com>
CC: Jens Axboe <axboe@kernel.dk>
CC: Neil Brown <neilb@suse.de>
CC: Boaz Harrosh <bharrosh@panasas.com>
[bwh: Backported to 3.2: drop inapplicable change to drivers/block/rbd.c.
This is a prerequisite for commit 35dc248383bb 'sg: Fix user memory
corruption when SG_IO is interrupted by a signal']
commit 8c8296223f3abb142be8fc31711b18a704c0e7d8 upstream.
Recently we met quite a lot of random kernel panic issues after enabling
CONFIG_PROC_PAGE_MONITOR. After debuggind we found this has something
to do with following bug in pagemap:
In struct pagemapread:
struct pagemapread {
int pos, len;
pagemap_entry_t *buffer;
bool v2;
pos is number of PM_ENTRY_BYTES in buffer, but len is the size of
buffer, it is a mistake to compare pos and len in add_page_map() for
checking buffer is full or not, and this can lead to buffer overflow and
random kernel panic issue.
Correct len to be total number of PM_ENTRY_BYTES in buffer.
[akpm@linux-foundation.org: document pagemapread.pos and .len units, fix PM_ENTRY_BYTES definition]
Signed-off-by: Yonghua Zheng <younghua.zheng@gmail.com>
- Adjust context
- There is no pagemap_entry_t definition; keep using u64]
commit 91aa11fae1cf8c2fd67be0609692ea9741cdcc43 upstream.
When jbd2_journal_dirty_metadata() returns error,
__ext4_handle_dirty_metadata() stops the handle. However callers of this
function do not count with that fact and still happily used now freed
handle. This use after free can result in various issues but very likely
we oops soon.
The motivation of adding __ext4_journal_stop() into
__ext4_handle_dirty_metadata() in commit 9ea7a0df seems to be only to
improve error reporting. So replace __ext4_journal_stop() with
ext4_journal_abort_handle() which was there before that commit and add
WARN_ON_ONCE() to dump stack to provide useful information.
Reported-by: Sage Weil <sage@inktank.com>
commit 6ae6514b33f941d3386da0dfbe2942766eab1577 upstream.
Commit 5688978 ("ext4: improve handling of conflicting mount options")
introduced incorrect messages shown while choosing wrong mount options.
First of all, both cases of incorrect mount options,
"data=journal,delalloc" and "data=journal,dioread_nolock" result in
the same error message.
Secondly, the problem above isn't solved for remount option: the
mismatched parameter is simply ignored. Moreover, ext4_msg states
that remount with options "data=journal,delalloc" succeeded, which is
not true.
To fix it up, I added a simple check after parse_options() call to
ensure that data=journal and delalloc/dioread_nolock parameters are
not present at the same time.
Signed-off-by: Piotr Sarna <p.sarna@partner.samsung.com>
Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
revalidated immediately
commit 757c4f6260febff982276818bb946df89c1105aa upstream.
David reported that commit c2b93e06 (cifs: only set ops for inodes in
I_NEW state) caused a regression with mfsymlinks. Prior to that patch,
if a mfsymlink dentry was instantiated at readdir time, the inode would
get a new set of ops when it was revalidated. After that patch, this
did not occur.
This patch addresses this by simply skipping instantiating dentries in
the readdir codepath when we know that they will need to be immediately
revalidated. The next attempt to use that dentry will cause a new lookup
to occur (which is basically what we want to happen anyway).
Cc: "Stefan (metze) Metzmacher" <metze@samba.org>
Cc: Sachin Prabhu <sprabhu@redhat.com>
Reported-and-Tested-by: David McBride <dwm37@cam.ac.uk>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
[bwh: Backported to 3.2: need to return NULL]
commit 057d6332b24a4497c55a761c83c823eed9e3f23b upstream.
For cifs_set_cifscreds() in "fs/cifs/connect.c", 'desc' buffer length
is 'CIFSCREDS_DESC_SIZE' (56 is less than 256), and 'ses->domainName'
length may be "255 + '\0'".
The related sprintf() may cause memory overflow, so need extend related
buffer enough to hold all things.
It is also necessary to be sure of 'ses->domainName' must be less than
256, and define the related macro instead of hard code number '256'.
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Reviewed-by: Scott Lovenberg <scott.lovenberg@gmail.com>
- Adjust context in sess.c
- Drop inapplicable changes to connect.c]
commit 44512449c0ab368889dd13ae0031fba74ee7e1d2 upstream.
NFSv4 reserves readdir cookie values 0-2 for special entries (. and ..),
but jfs allows a value of 2 for a non-special entry. This incompatibility
can result in the nfs client reporting a readdir loop.
This patch doesn't change the value stored internally, but adds one to
the value exposed to the iterate method.
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Tested-by: Christian Kujau <lists@nerdbynature.de>
- Adjust context
- s/ctx->pos/filp->f_pos/]
commit 0439f31c35d1da0b28988b308ea455e38e6a350d upstream.
This seems like it could overflow on 32 bits. Use kmalloc_array() which
has overflow protection built in.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
struct file
commit e4daf1ffbe6cc3b12aab4d604e627829e93e9914 upstream.
The following call chain:
nfs4_get_vfs_file
- nfsd_open
- dentry_open
- do_dentry_open
- __get_file_write_access
- get_write_access
- return atomic_inc_unless_negative(&inode->i_writecount) ? 0 : -ETXTBSY;
can result in the following state:
struct nfs4_file {
fi_fds = {0xffff880c1fa65c80, 0xffffffffffffffe6, 0x0},
fi_access = {{
counter = 0x1
counter = 0x0
1) First time around, in nfs4_get_vfs_file() fp->fi_fds[O_WRONLY] is
NULL, hence nfsd_open() is called where we get status set to an error
and fp->fi_fds[O_WRONLY] to -ETXTBSY. Thus we do not reach
nfs4_file_get_access() and fi_access[O_WRONLY] is not incremented.
2) Second time around, in nfs4_get_vfs_file() fp->fi_fds[O_WRONLY] is
NOT NULL (-ETXTBSY), so nfsd_open() is NOT called, but
nfs4_file_get_access() IS called and fi_access[O_WRONLY] is incremented.
Thus we leave a landmine in the form of the nfs4_file data structure in
an incorrect state.
3) Eventually, when __nfs4_file_put_access() is called it finds
fi_access[O_WRONLY] being non-zero, it decrements it and calls
nfs4_file_put_fd() which tries to fput -ETXTBSY.
[exception RIP: fput+0x9]
RIP: ffffffff81177fa9 RSP: ffff88062e365c90 RFLAGS: 00010282
RAX: ffff880c2b3d99cc RBX: ffff880c2b3d9978 RCX: 0000000000000002
RDX: dead000000100101 RSI: 0000000000000001 RDI: ffffffffffffffe6
RBP: ffff88062e365c90 R8: ffff88041fe797d8 R9: ffff88062e365d58
R10: 0000000000000008 R11: 0000000000000000 R12: 0000000000000001
R13: 0000000000000007 R14: 0000000000000000 R15: 0000000000000000
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
#9 [ffff88062e365c98] __nfs4_file_put_access at ffffffffa0562334 [nfsd]
#10 [ffff88062e365cc8] nfs4_file_put_access at ffffffffa05623ab [nfsd]
#11 [ffff88062e365ce8] free_generic_stateid at ffffffffa056634d [nfsd]
#12 [ffff88062e365d18] release_open_stateid at ffffffffa0566e4b [nfsd]
#13 [ffff88062e365d38] nfsd4_close at ffffffffa0567401 [nfsd]
#14 [ffff88062e365d88] nfsd4_proc_compound at ffffffffa0557f28 [nfsd]
#15 [ffff88062e365dd8] nfsd_dispatch at ffffffffa054543e [nfsd]
#16 [ffff88062e365e18] svc_process_common at ffffffffa04ba5a4 [sunrpc]
#17 [ffff88062e365e98] svc_process at ffffffffa04babe0 [sunrpc]
#18 [ffff88062e365eb8] nfsd at ffffffffa0545b62 [nfsd]
#19 [ffff88062e365ee8] kthread at ffffffff81090886
#20 [ffff88062e365f48] kernel_thread at ffffffff8100c14a
Signed-off-by: Harshula Jayasuriya <harshula@redhat.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
[bwh: Backported to 3.2: adjust context]
commit d29a9f629e009c9b90e5859bce581070fd6247fc upstream.
If we stop dropping a root for whatever reason we need to add it back to the
dead root list so that we will re-start the dropping next transaction commit.
The other case this happens is if we recover a drop because we will add a root
without adding it to the fs radix tree, so we can leak it's root and commit root
extent buffer, adding this to the dead root list makes this cleanup happen.
Thanks,
Reported-by: Alex Lyakas <alex.btrfs@zadarastorage.com>
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
commit fec386ac1428f9c0e672df952cbca5cebd4e4e2f upstream.
We aren't setting path->locks[level] when we resume a snapshot deletion which
means we won't unlock the buffer when we free the path. This causes deadlocks
if we happen to re-allocate the block before we've evicted the extent buffer
from cache. Thanks,
commit e7676a704ee0a1ef71a6b23760b5a8f6896cb1a1 upstream.
The filesystem should not be marked inconsistent if ext4_free_blocks()
is not able to allocate memory. Unfortunately some callers (most
notably ext4_truncate) don't have a way to reflect an error back up to
the VFS. And even if we did, most userspace applications won't deal
with most system calls returning ENOMEM anyway.
Reported-by: Nagachandra P <nagachandra@gmail.com>
commit 1c327d962fc420aea046c16215a552710bde8231 upstream.
In nlmsvc_retry_blocked, the check that the list is non-empty and acquiring
the pointer of the first entry is unprotected by any lock. This allows a rare
race condition when there is only one entry on the list. A function such as
nlmsvc_grant_callback() can be called, which will temporarily remove the entry
from the list. Between the list_empty() and list_entry(),the list may become
empty, causing an invalid pointer to be used as an nlm_block, leading to a
possible crash.
This patch adds the nlm_block_lock around these calls to prevent concurrent
use of the nlm_blocked list.
This was a regression introduced by
f904be9cc77f361d37d71468b13ff3d1a1823dea "lockd: Mostly remove BKL from
the server".
Cc: Bryan Schumaker <bjschuma@netapp.com>
Signed-off-by: David Jeffery <djeffery@redhat.com>
commit de1e0c40aceb9d5bff09c3a3b97b2f1b178af53f upstream.
The ->reserved field isn't cleared so we leak one byte of stack
information to userspace.
Cc: Eric Paris <eparis@redhat.com>
commit a60697f411eb365fb09e639e6f183fe33d1eb796 upstream.
On 32-bit architectures with 32-bit sector_t computation of data offset
in ext4_xattr_fiemap() can overflow resulting in reporting bogus data
location. Fix the problem by typing block number to proper type before
shifting.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 8af8eecc1331dbf5e8c662022272cf667e213da5 upstream.
The arithmetics adding delalloc blocks to the number of used blocks in
ext4_getattr() can easily overflow on 32-bit archs as we first multiply
number of blocks by blocksize and then divide back by 512. Make the
arithmetics more clever and also use proper type (unsigned long long
instead of unsigned long).
commit 92a49fb0f79f3300e6e50ddf56238e70678e4202 upstream.
Different versions of glibc are broken in different ways, but the short of
it is that for the time being, frsize should == bsize, and be used as the
multiple for the blocks, free, and available fields. This mirrors what is
done for NFS. The previous reporting of the page size for frsize meant
that newer glibc and df would report a very small value for the fs size.
Fixes http://tracker.ceph.com/issues/3793.
Signed-off-by: Sage Weil <sage@inktank.com>
Reviewed-by: Greg Farnum <greg@inktank.com>
commit 3ebacb05044f82c5f0bb456a894eb9dc57d0ed90 upstream.
The test if bitmap access is out of bound could errorneously pass if the
device size is divisible by 16384 sectors and we are asking for one bitmap
after the end.
Check for invalid size in the superblock. Invalid size could cause integer
overflows in the rest of the code.
Signed-off-by: Mikulas Patocka <mpatocka@artax.karlin.mff.cuni.cz>
commit ef962df057aaafd714f5c22ba3de1be459571fdf upstream.
Inlined xattr shared free space of inode block with inlined data or data
extent record, so the size of the later two should be adjusted when
inlined xattr is enabled. See ocfs2_xattr_ibody_init(). But this isn't
done well when reflink. For inode with inlined data, its max inlined
data size is adjusted in ocfs2_duplicate_inline_data(), no problem. But
for inode with data extent record, its record count isn't adjusted. Fix
it, or data extent record and inlined xattr may overwrite each other,
then cause data corruption or xattr failure.
One panic caused by this bug in our test environment is the following:
kernel BUG at fs/ocfs2/xattr.c:1435!
invalid opcode: 0000 [#1] SMP
Pid: 10871, comm: multi_reflink_t Not tainted 2.6.39-300.17.1.el5uek #1
RIP: ocfs2_xa_offset_pointer+0x17/0x20 [ocfs2]
RSP: e02b:ffff88007a587948 EFLAGS: 00010283
RAX: 0000000000000000 RBX: 0000000000000010 RCX: 00000000000051e4
RDX: ffff880057092060 RSI: 0000000000000f80 RDI: ffff88007a587a68
RBP: ffff88007a587948 R08: 00000000000062f4 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000010
R13: ffff88007a587a68 R14: 0000000000000001 R15: ffff88007a587c68
FS: 00007fccff7f06e0(0000) GS:ffff88007fc00000(0000) knlGS:0000000000000000
CS: e033 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00000000015cf000 CR3: 000000007aa76000 CR4: 0000000000000660
Process multi_reflink_t
Call Trace:
ocfs2_xa_reuse_entry+0x60/0x280 [ocfs2]
ocfs2_xa_prepare_entry+0x17e/0x2a0 [ocfs2]
ocfs2_xa_set+0xcc/0x250 [ocfs2]
ocfs2_xattr_ibody_set+0x98/0x230 [ocfs2]
__ocfs2_xattr_set_handle+0x4f/0x700 [ocfs2]
ocfs2_xattr_set+0x6c6/0x890 [ocfs2]
ocfs2_xattr_user_set+0x46/0x50 [ocfs2]
generic_setxattr+0x70/0x90
__vfs_setxattr_noperm+0x80/0x1a0
vfs_setxattr+0xa9/0xb0
setxattr+0xc3/0x120
sys_fsetxattr+0xa8/0xd0
system_call_fastpath+0x16/0x1b
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Reviewed-by: Jie Liu <jeff.liu@oracle.com>
Acked-by: Joel Becker <jlbec@evilplan.org>
Cc: Mark Fasheh <mfasheh@suse.com>
commit 247500820ebd02ad87525db5d9b199e5b66f6636 upstream.
A freebsd NFSv4.0 client was getting rare IO errors expanding a tarball.
A network trace showed the server returning BAD_XDR on the final getattr
of a getattr+write+getattr compound. The final getattr started on a
page boundary.
I believe the Linux client ignores errors on the post-write getattr, and
that that's why we haven't seen this before.
Reported-by: Rick Macklem <rmacklem@uoguelph.ca>
commit 39c04153fda8c32e85b51c96eb5511a326ad7609 upstream.
Once we decrement transaction->t_updates, if this is the last handle
holding the transaction from closing, and once we release the
t_handle_lock spinlock, it's possible for the transaction to commit
and be released. In practice with normal kernels, this probably won't
happen, since the commit happens in a separate kernel thread and it's
unlikely this could all happen within the space of a few CPU cycles.
On the other hand, with a real-time kernel, this could potentially
happen, so save the tid found in transaction->t_tid before we release
t_handle_lock. It would require an insane configuration, such as one
where the jbd2 thread was set to a very high real-time priority,
perhaps because a high priority real-time thread is trying to read or
write to a file system. But some people who use real-time kernels
have been known to do insane things, including controlling
laser-wielding industrial robots. :-)
commit 64cb927371cd2ec43758d8a094a003d27bc3d0dc upstream.
Both ext3 and ext4 htree_dirblock_to_tree() is just filling the
in-core rbtree for use by call_filldir(). All updates of ->f_pos are
done by the latter; bumping it here (on error) is obviously wrong - we
might very well have it nowhere near the block we'd found an error in.
commit 605c912bb843c024b1ed173dc427cd5c08e5d54d upstream.
Al Viro pointed me to the fact that '->readdir()' and '->llseek()' have no
mutual exclusion, which means the 'ubifs_dir_llseek()' can be run while we are
in the middle of 'ubifs_readdir()'.
This means that 'file->private_data' can be freed while 'ubifs_readdir()' uses
it, and this is a very bad bug: not only 'ubifs_readdir()' can return garbage,
but this may corrupt memory and lead to all kinds of problems like crashes an
security holes.
This patch fixes the problem by using the 'file->f_version' field, which
'->llseek()' always unconditionally sets to zero. We set it to 1 in
'ubifs_readdir()' and whenever we detect that it became 0, we know there was a
seek and it is time to clear the state saved in 'file->private_data'.
I tested this patch by writing a user-space program which runds readdir and
seek in parallell. I could easily crash the kernel without these patches, but
could not crash it with these patches.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit 33f1a63ae84dfd9ad298cf275b8f1887043ced36 upstream.
First of all, this means that 'file->private_data' can be freed while
'ubifs_readdir()' uses it. But this particular patch does not fix the problem.
This patch is only a preparation, and the fix will follow next.
In this patch we make 'ubifs_readdir()' stop using 'file->f_pos' directly,
because 'file->f_pos' can be changed by '->llseek()' at any point. This may
lead 'ubifs_readdir()' to returning inconsistent data: directory entry names
may correspond to incorrect file positions.
So here we introduce a local variable 'pos', read 'file->f_pose' once at very
the beginning, and then stick to 'pos'. The result of this is that when
'ubifs_dir_llseek()' changes 'file->f_pos' while we are in the middle of
'ubifs_readdir()', the latter "wins".
commit a5faeaf9109578e65e1a32e2a3e76c8b47e7dcb6 upstream.
Code in blkdev.c moves a device inode to default_backing_dev_info when
the last reference to the device is put and moves the device inode back
to its bdi when the first reference is acquired. This includes moving to
wb.b_dirty list if the device inode is dirty. The code however doesn't
setup timer to wake corresponding flusher thread and while wb.b_dirty
list is non-empty __mark_inode_dirty() will not set it up either. Thus
periodic writeback is effectively disabled until a sync(2) call which can
lead to unexpected data loss in case of crash or power failure.
Fix the problem by setting up a timer for periodic writeback in case we
add the first dirty inode to wb.b_dirty list in bdev_inode_switch_bdi().
Reported-by: Bert De Jonghe <Bert.DeJonghe@amplidata.com>
commit fdf96a907c1fbb93c633e2b7ede3b8df26d6a4c0 upstream.
This is RH bug 970891
Uppercasing of username during calculation of ntlmv2 hash fails
because UniStrupr function does not handle big endian wchars.
Also fix a comment in the same code to reflect its correct usage.
[To make it easier for stable (rather than require 2nd patch) fixed
this patch of Shirish's to remove endian warning generated
by sparse -- steve f.]
Reported-by: steve <sanpatr1@in.ibm.com>
Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
[bwh: Backported to 3.2: adjust context, indentation]
commit 2976b10f05bd7f6dab9f9e7524451ddfed656a89 upstream.
There was a a bug in setup_new_exec(), whereby
the test to disabled perf monitoring was not
correct because the new credentials for the
process were not yet committed and therefore
the get_dumpable() test was never firing.
The patch fixes the problem by moving the
perf_event test until after the credentials
are committed.
Signed-off-by: Stephane Eranian <eranian@google.com>
Tested-by: Jiri Olsa <jolsa@redhat.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
commit 698b8223631472bf982ed570b0812faa61955683 upstream.
1d2ef5901483004d74947bbf78d5146c24038fe7 caused a regression in ncpfs such that
directories could no longer be removed. This was because ncp_rmdir checked
to see if a dentry could be unhashed before allowing it to be removed. Since
1d2ef5901483004d74947bbf78d5146c24038fe7 introduced a change that incremented
dentry->d_count causing it to always be greater than 1 unhash would always
fail. Thus causing the error path in ncp_rmdir to always be taken. Removing
this error path is safe as unhashing is still accomplished by calls to dput
from vfs_rmdir.
Signed-off-by: Dave Chiluk <chiluk@canonical.com>
Signed-off-by: Petr Vandrovec <petr@vandrovec.name>
commit 721e3eba21e43532e438652dd8f1fcdfce3187e7 upstream.
Commit c278531d39 added a warning when ext4_flush_unwritten_io() is
called without i_mutex being taken. It had previously not been taken
during orphan cleanup since races weren't possible at that point in
the mount process, but as a result of this c278531d39, we will now see
a kernel WARN_ON in this case. Take the i_mutex in
ext4_orphan_cleanup() to suppress this warning.
Reported-by: Alexander Beregalov <a.beregalov@gmail.com>
commit 73aaa22d5ffb2630456bac2f9a4ed9b81d0d7271 upstream.
This patch fixes races uncovered by xfstests testcase 068.
One race is the result of jfs_sync() trying to write a sync point to the
journal after it has been frozen (or possibly in the process). Since
freezing sync's the journal, there is no need to write a sync point so
we simply want to return.
The second involves jfs_write_inode() being called on a deleted inode.
It calls jfs_flush_journal which is held up by the jfs_commit thread
doing the final iput on the same deleted inode, which itself is
waiting for the I_SYNC flag to be cleared. jfs_write_inode need not
do anything when i_nlink is zero, which is the easy fix.
Reported-by: Michael L. Semon <mlsemon35@gmail.com>
commit 2962f5a5dcc56f69cbf62121a7be67cc15d6940b upstream.
XFS has failed to kill suid/sgid bits correctly when truncating
files of non-zero size since commit c4ed4243 ("xfs: split
xfs_setattr") introduced in the 3.1 kernel. Fix it.
Fix it.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
(cherry picked from commit 56c19e89b38618390addfc743d822f99519055c6)
commit 166faf21bd14bc5c5295a44874bf7f3930c30b20 upstream.
Consider the case where we have a very short ip= string in the original
mount options, and when we chase a referral we end up with a very long
IPv6 address. Be sure to allow for that possibility when estimating the
size of the string to allocate.
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit b4ca2b4b577c3530e34dcfaafccb2cc680ce95d1 upstream.
Last time we found there is lock/unlock bug in ocfs2_file_aio_write, and
then we did a thorough search for all lock resources in
ocfs2_inode_info, including rw, inode and open lockres and found this
bug. My kernel version is 3.0.13, and it is also in the lastest version
3.9. In ocfs2_fiemap, once ocfs2_get_clusters_nocache failed, it should
goto out_unlock instead of out, because we need release buffer head, up
read alloc sem and unlock inode.
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Acked-by: Sunil Mushran <sunil.mushran@gmail.com>
commit 136e8770cd5d1fe38b3c613100dd6dc4db6d4fa6 upstream.
nilfs2: fix issue of nilfs_set_page_dirty for page at EOF boundary
DESCRIPTION:
There are use-cases when NILFS2 file system (formatted with block size
lesser than 4 KB) can be remounted in RO mode because of encountering of
"broken bmap" issue.
The issue was reported by Anthony Doggett <Anthony2486@interfaces.org.uk>:
"The machine I've been trialling nilfs on is running Debian Testing,
Linux version 3.2.0-4-686-pae (debian-kernel@lists.debian.org) (gcc
version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Debian 3.2.35-2), but I've
also reproduced it (identically) with Debian Unstable amd64 and Debian
Experimental (using the 3.8-trunk kernel). The problematic partitions
were formatted with "mkfs.nilfs2 -b 1024 -B 8192"."
SYMPTOMS:
(1) System log contains error messages likewise:
[63102.496756] nilfs_direct_assign: invalid pointer: 0
[63102.496786] NILFS error (device dm-17): nilfs_bmap_assign: broken bmap (inode number=28)
[63102.496798]
[63102.524403] Remounting filesystem read-only
(2) The NILFS2 file system is remounted in RO mode.
REPRODUSING PATH:
(1) Create volume group with name "unencrypted" by means of vgcreate utility.
(2) Run script (prepared by Anthony Doggett <Anthony2486@interfaces.org.uk>):
----------------[BEGIN SCRIPT]--------------------
VG=unencrypted
lvcreate --size 2G --name ntest $VG
mkfs.nilfs2 -b 1024 -B 8192 /dev/mapper/$VG-ntest
mkdir /var/tmp/n
mkdir /var/tmp/n/ntest
mount /dev/mapper/$VG-ntest /var/tmp/n/ntest
mkdir /var/tmp/n/ntest/thedir
cd /var/tmp/n/ntest/thedir
sleep 2
date
darcs init
sleep 2
dmesg|tail -n 5
date
darcs whatsnew || true
date
sleep 2
dmesg|tail -n 5
----------------[END SCRIPT]--------------------
REPRODUCIBILITY: 100%
INVESTIGATION:
As it was discovered, the issue takes place during segment
construction after executing such sequence of user-space operations:
open("_darcs/index", O_RDWR|O_CREAT|O_NOCTTY, 0666) = 7
fstat(7, {st_mode=S_IFREG|0644, st_size=0, ...}) = 0
ftruncate(7, 60)
The error message "NILFS error (device dm-17): nilfs_bmap_assign: broken
bmap (inode number=28)" takes place because of trying to get block
number for third block of the file with logical offset #3072 bytes. As
it is possible to see from above output, the file has 60 bytes of the
whole size. So, it is enough one block (1 KB in size) allocation for
the whole file. Trying to operate with several blocks instead of one
takes place because of discovering several dirty buffers for this file
in nilfs_segctor_scan_file() method.
The root cause of this issue is in nilfs_set_page_dirty function which
is called just before writing to an mmapped page.
When nilfs_page_mkwrite function handles a page at EOF boundary, it
fills hole blocks only inside EOF through __block_page_mkwrite().
The __block_page_mkwrite() function calls set_page_dirty() after filling
hole blocks, thus nilfs_set_page_dirty function (=
a_ops->set_page_dirty) is called. However, the current implementation
of nilfs_set_page_dirty() wrongly marks all buffers dirty even for page
at EOF boundary.
As a result, buffers outside EOF are inconsistently marked dirty and
queued for write even though they are not mapped with nilfs_get_block
function.
FIX:
This modifies nilfs_set_page_dirty() not to mark hole blocks dirty.
Thanks to Vyacheslav Dubeyko for his effort on analysis and proposals
for this issue.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Reported-by: Anthony Doggett <Anthony2486@interfaces.org.uk>
Reported-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Vyacheslav Dubeyko <slava@dubeyko.com>
commit 7b92d03c3239f43e5b86c9cc9630f026d36ee995 upstream.
Intermediate value of fat_clusters can be overflowed on 32bits arch.
Reported-by: Krzysztof Strasburger <strasbur@chkw386.ch.pwr.wroc.pl>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
commit 03b71c6ca6286625d8f1ed44aabab9b5bf5dac10 upstream.
The search ioctl skips items that are too large for a result buffer, but
inline items of a certain size occuring before any search result is
found would trigger an overflow and stop the search entirely.
Bug: https://bugzilla.kernel.org/show_bug.cgi?id=57641
Signed-off-by: Gabriel de Perthuis <g2p.code+btrfs@gmail.com>
commit c2b93e0699723700f886ce17bb65ffd771195a6d upstream.
It's generally not safe to reset the inode ops once they've been set. In
the case where the inode was originally thought to be a directory and
then later found to be a DFS referral, this can lead to an oops when we
try to trigger an inode op on it after changing the ops to the blank
referral operations.
Reported-and-Tested-by: Sachin Prabhu <sprabhu@redhat.com>
