commit 894c6350eaad7e613ae267504014a456e00a3e2a from the 3.2-stable branch.
We need to check the position and size of file writes against various
limits, using generic_write_check(). This was not being done for
the splice write path. It was fixed upstream by commit 8d0207652cbe
("->splice_write() via ->write_iter()") but we can't apply that.
CVE-2014-7822
Cc: Vinson Lee <vlee@twopensource.com>
commit 5f5bc6b1e2d5a6f827bc860ef2dc5b6f365d1339 upstream.
Replacing a xattr consists of doing a lookup for its existing value, delete
the current value from the respective leaf, release the search path and then
finally insert the new value. This leaves a time window where readers (getxattr,
listxattrs) won't see any value for the xattr. Xattrs are used to store ACLs,
so this has security implications.
This change also fixes 2 other existing issues which were:
*) Deleting the old xattr value without verifying first if the new xattr will
fit in the existing leaf item (in case multiple xattrs are packed in the
same item due to name hash collision);
*) Returning -EEXIST when the flag XATTR_CREATE is given and the xattr doesn't
exist but we have have an existing item that packs muliple xattrs with
the same name hash as the input xattr. In this case we should return ENOSPC.
A test case for xfstests follows soon.
Thanks to Alexandre Oliva for reporting the non-atomicity of the xattr replace
implementation.
Reported-by: Alexandre Oliva <oliva@gnu.org>
Signed-off-by: Filipe Manana <fdmanana@suse.com>
Signed-off-by: Chris Mason <clm@fb.com>
pipe_iov_copy_{from,to}_user() may be tried twice with the same iovec,
the first time atomically and the second time not. The second attempt
needs to continue from the iovec position, pipe buffer offset and
remaining length where the first attempt failed, but currently the
pipe buffer offset and remaining length are reset. This will corrupt
the piped data (possibly also leading to an information leak between
processes) and may also corrupt kernel memory.
This was fixed upstream by commits f0d1bec9d58d ("new helper:
copy_page_from_iter()") and 637b58c2887e ("switch pipe_read() to
copy_page_to_iter()"), but those aren't suitable for stable. This fix
for older kernel versions was made by Seth Jennings for RHEL and I
have extracted it from their update.
CVE-2015-1805
References: https://bugzilla.redhat.com/show_bug.cgi?id=1202855
commit 727b9784b6085c99c2f836bf4fcc2848dc9cf904 upstream.
Orphans in the fs tree are cleaned up via open_ctree and subvolume
orphans are cleaned via btrfs_lookup_dentry -- except when a default
subvolume is in use. The name for the default subvolume uses a manual
lookup that doesn't trigger orphan cleanup and needs to trigger it
manually as well. This doesn't apply to the remount case since the
subvolumes are cleaned up by walking the root radix tree.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Reviewed-by: David Sterba <dsterba@suse.cz>
commit 26e726afe01c1c82072cf23a5ed89ce25f39d9f2 upstream.
fiemap_fill_next_extent returns 0 on success, -errno on error, 1 if this was
the last extent that will fit in user array. If 1 is returned, the return
value may eventually returned to user space, which should not happen, according
to manpage of ioctl.
Signed-off-by: Chengyu Song <csong84@gatech.edu>
Reviewed-by: Liu Bo <bo.li.liu@oracle.com>
commit 2b1d3ae940acd11be44c6eced5873d47c2e00ffa upstream.
load_elf_binary() returns `retval', not `error'.
Fixes: a87938b2e246b81b4fb ("fs/binfmt_elf.c: fix bug in loading of PIE binaries")
Reported-by: James Hogan <james.hogan@imgtec.com>
Cc: Michael Davidson <md@google.com>
commit 161f873b89136eb1e69477c847d5a5033239d9ba upstream.
We used to read file_handle twice. Once to get the amount of extra
bytes, and once to fetch the entire structure.
This may be problematic since we do size verifications only after the
first read, so if the number of extra bytes changes in userspace between
the first and second calls, we'll have an incoherent view of
file_handle.
Instead, read the constant size once, and copy that over to the final
structure without having to re-read it again.
commit e531d0bceb402e643a4499de40dd3fa39d8d2e43 upstream.
The journal revoke block recovery code does not check r_count for
sanity, which means that an evil value of r_count could result in
the kernel reading off the end of the revoke table and into whatever
garbage lies beyond. This could crash the kernel, so fix that.
However, in testing this fix, I discovered that the code to write
out the revoke tables also was not correctly checking to see if the
block was full -- the current offset check is fine so long as the
revoke table space size is a multiple of the record size, but this
is not true when either journal_csum_v[23] are set.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 2f974865ffdfe7b9f46a9940836c8b167342563d upstream.
The following commit introduced a bug when checking for zero length extent
5946d08 ext4: check for overlapping extents in ext4_valid_extent_entries()
Zero length extent could pass the check if lblock is zero.
Adding the explicit check for zero length back.
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
commit 9d506594069355d1fb2de3f9104667312ff08ed3 upstream.
Currently when journal restart fails, we'll have the h_transaction of
the handle set to NULL to indicate that the handle has been effectively
aborted. We handle this situation quietly in the jbd2_journal_stop() and just
free the handle and exit because everything else has been done before we
attempted (and failed) to restart the journal.
Unfortunately there are a number of problems with that approach
introduced with commit
41a5b913197c "jbd2: invalidate handle if jbd2_journal_restart()
fails"
First of all in ext4 jbd2_journal_stop() will be called through
__ext4_journal_stop() where we would try to get a hold of the superblock
by dereferencing h_transaction which in this case would lead to NULL
pointer dereference and crash.
In addition we're going to free the handle regardless of the refcount
which is bad as well, because others up the call chain will still
reference the handle so we might potentially reference already freed
memory.
Moreover it's expected that we'll get aborted handle as well as detached
handle in some of the journalling function as the error propagates up
the stack, so it's unnecessary to call WARN_ON every time we get
detached handle.
And finally we might leak some memory by forgetting to free reserved
handle in jbd2_journal_stop() in the case where handle was detached from
the transaction (h_transaction is NULL).
Fix the NULL pointer dereference in __ext4_journal_stop() by just
calling jbd2_journal_stop() quietly as suggested by Jan Kara. Also fix
the potential memory leak in jbd2_journal_stop() and use proper
handle refcounting before we attempt to free it to avoid use-after-free
issues.
And finally remove all WARN_ON(!transaction) from the code so that we do
not get random traces when something goes wrong because when journal
restart fails we will get to some of those functions.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
commit 2159184ea01e4ae7d15f2017e296d4bc82d5aeb0 upstream.
when we find that a child has died while we'd been trying to ascend,
we should go into the first live sibling itself, rather than its sibling.
Off-by-one in question had been introduced in "deal with deadlock in
d_walk()" and the fix needs to be backported to all branches this one
has been backported to.
commit dcbff39da3d815f08750552fdd04f96b51751129 upstream.
match_token() expects a NULL terminator at the end of the token list so
that it would know where to stop. Not having one causes it to overrun
to invalid memory.
In practice, passing a mount option that omfs didn't recognize would
sometimes panic the system.
Signed-off-by: Bob Copeland <me@bobcopeland.com>
commit ca5358ef75fc69fee5322a38a340f5739d997c10 upstream.
... by not hitting rename_retry for reasons other than rename having
happened. In other words, do _not_ restart when finding that
between unlocking the child and locking the parent the former got
into __dentry_kill(). Skip the killed siblings instead...
Cc: Ben Hutchings <ben@decadent.org.uk>
[hujianyang: Backported to 3.14 refer to the work of Ben Hutchings in 3.2:
- Adjust context to make __dentry_kill() apply to d_kill()]
Signed-off-by: hujianyang <hujianyang@huawei.com>
commit 7e96c1b0e0f495c5a7450dc4aa7c9a24ba4305bd upstream.
This fixes a dumb bug in fs_fully_visible that allows proc or sys to
be mounted if there is a bind mount of part of /proc/ or /sys/ visible.
Reported-by: Eric Windisch <ewindisch@docker.com>
commit d8fd150fe3935e1692bf57c66691e17409ebb9c1 upstream.
The range check for b-tree level parameter in nilfs_btree_root_broken()
is wrong; it accepts the case of "level == NILFS_BTREE_LEVEL_MAX" even
though the level is limited to values in the range of 0 to
(NILFS_BTREE_LEVEL_MAX - 1).
Since the level parameter is read from storage device and used to index
nilfs_btree_path array whose element count is NILFS_BTREE_LEVEL_MAX, it
can cause memory overrun during btree operations if the boundary value
is set to the level parameter on device.
This fixes the broken sanity check and adds a comment to clarify that
the upper bound NILFS_BTREE_LEVEL_MAX is exclusive.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit b1432a2a35565f538586774a03bf277c27fc267d upstream.
There is a race window in dlm_get_lock_resource(), which may return a
lock resource which has been purged. This will cause the process to
hang forever in dlmlock() as the ast msg can't be handled due to its
lock resource not existing.
dlm_get_lock_resource {
spin_lock(&dlm->spinlock);
tmpres = __dlm_lookup_lockres_full(dlm, lockid, namelen, hash);
if (tmpres) {
spin_unlock(&dlm->spinlock);
>>>>>>>> race window, dlm_run_purge_list() may run and purge
the lock resource
spin_lock(&tmpres->spinlock);
spin_unlock(&tmpres->spinlock);
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Cc: Joseph Qi <joseph.qi@huawei.com>
Cc: Mark Fasheh <mfasheh@suse.com>
commit d2dc317d564a46dfc683978a2e5a4f91434e9711 upstream.
Currently it is possible to lose whole file system block worth of data
when we hit the specific interaction with unwritten and delayed extents
in status extent tree.
The problem is that when we insert delayed extent into extent status
tree the only way to get rid of it is when we write out delayed buffer.
However there is a limitation in the extent status tree implementation
so that when inserting unwritten extent should there be even a single
delayed block the whole unwritten extent would be marked as delayed.
At this point, there is no way to get rid of the delayed extents,
because there are no delayed buffers to write out. So when a we write
into said unwritten extent we will convert it to written, but it still
remains delayed.
When we try to write into that block later ext4_da_map_blocks() will set
the buffer new and delayed and map it to invalid block which causes
the rest of the block to be zeroed loosing already written data.
For now we can fix this by simply not allowing to set delayed status on
written extent in the extent status tree. Also add WARN_ON() to make
sure that we notice if this happens in the future.
This problem can be easily reproduced by running the following xfs_io.
xfs_io -f -c "pwrite -S 0xaa 4096 2048" \
-c "falloc 0 131072" \
-c "pwrite -S 0xbb 65536 2048" \
-c "fsync" /mnt/test/fff
echo 3 > /proc/sys/vm/drop_caches
xfs_io -c "pwrite -S 0xdd 67584 2048" /mnt/test/fff
This can be theoretically also reproduced by at random by running fsx,
but it's not very reliable, though on machines with bigger page size
(like ppc) this can be seen more often (especially xfstest generic/127)
commit 8b01fc86b9f425899f8a3a8fc1c47d73c2c20543 upstream.
This prevents a race between chown() and execve(), where chowning a
setuid-user binary to root would momentarily make the binary setuid
root.
This patch was mostly written by Linus Torvalds.
Signed-off-by: Jann Horn <jann@thejh.net>
Signed-off-by: Charles Williams <ciwillia@brocade.com>
commit 3cab989afd8d8d1bc3d99fef0e7ed87c31e7b647 upstream.
Calling unlazy_walk() in walk_component() and do_last() when we find
a symlink that needs to be followed doesn't acquire a reference to vfsmount.
That's fine when the symlink is on the same vfsmount as the parent directory
(which is almost always the case), but it's not always true - one _can_
manage to bind a symlink on top of something. And in such cases we end up
with excessive mntput().
commit e12fb97222fc41e8442896934f76d39ef99b590a upstream.
Previously commit 14ece1028b3ed53ffec1b1213ffc6acaf79ad77c added a
support for for syncing parent directory of newly created inodes to
make sure that the inode is not lost after a power failure in
no-journal mode.
However this does not work in majority of cases, namely:
- if the directory has inline data
- if the directory is already indexed
- if the directory already has at least one block and:
- the new entry fits into it
- or we've successfully converted it to indexed
So in those cases we might lose the inode entirely even after fsync in
the no-journal mode. This also includes ext2 default mode obviously.
I've noticed this while running xfstest generic/321 and even though the
test should fail (we need to run fsck after a crash in no-journal mode)
I could not find a newly created entries even when if it was fsynced
before.
Fix this by adjusting the ext4_add_entry() successful exit paths to set
the inode EXT4_STATE_NEWENTRY so that fsync has the chance to fsync the
parent directory as well.
Cc: Frank Mayhar <fmayhar@google.com>
commit a87938b2e246b81b4fb713edb371a9fa3c5c3c86 upstream.
With CONFIG_ARCH_BINFMT_ELF_RANDOMIZE_PIE enabled, and a normal top-down
address allocation strategy, load_elf_binary() will attempt to map a PIE
binary into an address range immediately below mm->mmap_base.
Unfortunately, load_elf_ binary() does not take account of the need to
allocate sufficient space for the entire binary which means that, while
the first PT_LOAD segment is mapped below mm->mmap_base, the subsequent
PT_LOAD segment(s) end up being mapped above mm->mmap_base into the are
that is supposed to be the "gap" between the stack and the binary.
Since the size of the "gap" on x86_64 is only guaranteed to be 128MB this
means that binaries with large data segments > 128MB can end up mapping
part of their data segment over their stack resulting in corruption of the
stack (and the data segment once the binary starts to run).
Any PIE binary with a data segment > 128MB is vulnerable to this although
address randomization means that the actual gap between the stack and the
end of the binary is normally greater than 128MB. The larger the data
segment of the binary the higher the probability of failure.
Fix this by calculating the total size of the binary in the same way as
load_elf_interp().
Signed-off-by: Michael Davidson <md@google.com>
Cc: Jiri Kosina <jkosina@suse.cz>
commit c1b8940b42bb6487b10f2267a96b486276ce9ff7 upstream.
We have observed a BUG() crash in fs/attr.c:notify_change(). The crash
occurs during an rsync into a filesystem that is exported via NFS.
1.) fs/attr.c:notify_change() modifies the caller's version of attr.
2.) 6de0ec00ba8d ("VFS: make notify_change pass ATTR_KILL_S*ID to
setattr operations") introduced a BUG() restriction such that "no
function will ever call notify_change() with both ATTR_MODE and
ATTR_KILL_S*ID set". Under some circumstances though, it will have
assisted in setting the caller's version of attr to this very
combination.
3.) 27ac0ffeac80 ("locks: break delegations on any attribute
modification") introduced code to handle breaking
delegations. This can result in notify_change() being re-called. attr
_must_ be explicitly reset to avoid triggering the BUG() established
in #2.
4.) The path that that triggers this is via fs/open.c:chmod_common().
The combination of attr flags set here and in the first call to
notify_change() along with a later failed break_deleg_wait()
results in notify_change() being called again via retry_deleg
without resetting attr.
Solution is to move retry_deleg in chmod_common() a bit further up to
ensure attr is completely reset.
There are other places where this seemingly could occur, such as
fs/utimes.c:utimes_common(), but the attr flags are not initially
set in such a way to trigger this.
Fixes: 27ac0ffeac80 ("locks: break delegations on any attribute modification")
Reported-by: Eric Meddaugh <etmsys@rit.edu>
Tested-by: Eric Meddaugh <etmsys@rit.edu>
Signed-off-by: Andrew Elble <aweits@rit.edu>
commit 113e8283869b9855c8b999796aadd506bbac155f upstream.
If we pass a length of 0 to the extent_same ioctl, we end up locking an
extent range with a start offset greater then its end offset (if the
destination file's offset is greater than zero). This results in a warning
from extent_io.c:insert_state through the following call chain:
btrfs_extent_same()
btrfs_double_lock()
lock_extent_range()
lock_extent(inode->io_tree, offset, offset + len - 1)
lock_extent_bits()
__set_extent_bit()
insert_state()
--> WARN_ON(end < start)
This leads to an infinite loop when evicting the inode. This is the same
problem that my previous patch titled
"Btrfs: fix inode eviction infinite loop after cloning into it" addressed
but for the extent_same ioctl instead of the clone ioctl.
Reviewed-by: Omar Sandoval <osandov@osandov.com>
commit ccccf3d67294714af2d72a6fd6fd7d73b01c9329 upstream.
If we attempt to clone a 0 length region into a file we can end up
inserting a range in the inode's extent_io tree with a start offset
that is greater then the end offset, which triggers immediately the
following warning:
[ 3914.619057] WARNING: CPU: 17 PID: 4199 at fs/btrfs/extent_io.c:435 insert_state+0x4b/0x10b [btrfs]()
[ 3914.620886] BTRFS: end < start 4095 4096
[ 3914.638093] Call Trace:
[ 3914.638636] [<ffffffff81425fd9>] dump_stack+0x4c/0x65
[ 3914.639620] [<ffffffff81045390>] warn_slowpath_common+0xa1/0xbb
[ 3914.640789] [<ffffffffa03ca44f>] ? insert_state+0x4b/0x10b [btrfs]
[ 3914.642041] [<ffffffff810453f0>] warn_slowpath_fmt+0x46/0x48
[ 3914.643236] [<ffffffffa03ca44f>] insert_state+0x4b/0x10b [btrfs]
[ 3914.644441] [<ffffffffa03ca729>] __set_extent_bit+0x107/0x3f4 [btrfs]
[ 3914.645711] [<ffffffffa03cb256>] lock_extent_bits+0x65/0x1bf [btrfs]
[ 3914.646914] [<ffffffff8142b2fb>] ? _raw_spin_unlock+0x28/0x33
[ 3914.648058] [<ffffffffa03cbac4>] ? test_range_bit+0xcc/0xde [btrfs]
[ 3914.650105] [<ffffffffa03cb3c3>] lock_extent+0x13/0x15 [btrfs]
[ 3914.651361] [<ffffffffa03db39e>] lock_extent_range+0x3d/0xcd [btrfs]
[ 3914.652761] [<ffffffffa03de1fe>] btrfs_ioctl_clone+0x278/0x388 [btrfs]
[ 3914.654128] [<ffffffff811226dd>] ? might_fault+0x58/0xb5
[ 3914.655320] [<ffffffffa03e0909>] btrfs_ioctl+0xb51/0x2195 [btrfs]
[ 3914.669271] ---[ end trace 14843d3e2e622fc1 ]---
This later makes the inode eviction handler enter an infinite loop that
keeps dumping the following warning over and over:
[ 3915.117629] WARNING: CPU: 22 PID: 4228 at fs/btrfs/extent_io.c:435 insert_state+0x4b/0x10b [btrfs]()
[ 3915.119913] BTRFS: end < start 4095 4096
[ 3915.137394] Call Trace:
[ 3915.137913] [<ffffffff81425fd9>] dump_stack+0x4c/0x65
[ 3915.139154] [<ffffffff81045390>] warn_slowpath_common+0xa1/0xbb
[ 3915.140316] [<ffffffffa03ca44f>] ? insert_state+0x4b/0x10b [btrfs]
[ 3915.141505] [<ffffffff810453f0>] warn_slowpath_fmt+0x46/0x48
[ 3915.142709] [<ffffffffa03ca44f>] insert_state+0x4b/0x10b [btrfs]
[ 3915.143849] [<ffffffffa03ca729>] __set_extent_bit+0x107/0x3f4 [btrfs]
[ 3915.145120] [<ffffffffa038c1e3>] ? btrfs_kill_super+0x17/0x23 [btrfs]
[ 3915.146352] [<ffffffff811548f6>] ? deactivate_locked_super+0x3b/0x50
[ 3915.147565] [<ffffffffa03cb256>] lock_extent_bits+0x65/0x1bf [btrfs]
[ 3915.148785] [<ffffffff8142b7e2>] ? _raw_write_unlock+0x28/0x33
[ 3915.149931] [<ffffffffa03bc325>] btrfs_evict_inode+0x196/0x482 [btrfs]
[ 3915.151154] [<ffffffff81168904>] evict+0xa0/0x148
[ 3915.152094] [<ffffffff811689e5>] dispose_list+0x39/0x43
[ 3915.153081] [<ffffffff81169564>] evict_inodes+0xdc/0xeb
[ 3915.154062] [<ffffffff81154418>] generic_shutdown_super+0x49/0xef
[ 3915.155193] [<ffffffff811546d1>] kill_anon_super+0x13/0x1e
[ 3915.156274] [<ffffffffa038c1e3>] btrfs_kill_super+0x17/0x23 [btrfs]
[ 3915.167404] ---[ end trace 14843d3e2e622fc2 ]---
So just bail out of the clone ioctl if the length of the region to clone
is zero, without locking any extent range, in order to prevent this issue
(same behaviour as a pwrite with a 0 length for example).
This is trivial to reproduce. For example, the steps for the test I just
made for fstests:
mkfs.btrfs -f SCRATCH_DEV
mount SCRATCH_DEV $SCRATCH_MNT
touch $SCRATCH_MNT/foo
touch $SCRATCH_MNT/bar
$CLONER_PROG -s 0 -d 4096 -l 0 $SCRATCH_MNT/foo $SCRATCH_MNT/bar
umount $SCRATCH_MNT
A test case for fstests follows soon.
commit 3c3b04d10ff1811a27f86684ccd2f5ba6983211d upstream.
Due to insufficient check in btrfs_is_valid_xattr, this unexpectedly
works:
$ touch file
$ setfattr -n user. -v 1 file
$ getfattr -d file
user.="1"
ie. the missing attribute name after the namespace.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=94291
Reported-by: William Douglas <william.douglas@intel.com>
Signed-off-by: David Sterba <dsterba@suse.cz>
commit dcc82f4783ad91d4ab654f89f37ae9291cdc846a upstream.
While committing a transaction we free the log roots before we write the
new super block. Freeing the log roots implies marking the disk location
of every node/leaf (metadata extent) as pinned before the new super block
is written. This is to prevent the disk location of log metadata extents
from being reused before the new super block is written, otherwise we
would have a corrupted log tree if before the new super block is written
a crash/reboot happens and the location of any log tree metadata extent
ended up being reused and rewritten.
Even though we pinned the log tree's metadata extents, we were issuing a
discard against them if the fs was mounted with the -o discard option,
resulting in corruption of the log tree if a crash/reboot happened before
writing the new super block - the next time the fs was mounted, during
the log replay process we would find nodes/leafs of the log btree with
a content full of zeroes, causing the process to fail and require the
use of the tool btrfs-zero-log to wipeout the log tree (and all data
previously fsynced becoming lost forever).
Fix this by not doing a discard when pinning an extent. The discard will
be done later when it's safe (after the new super block is committed) at
extent-tree.c:btrfs_finish_extent_commit().
Fixes: e688b7252f78 (Btrfs: fix extent pinning bugs in the tree log)
commit 05fbf357d94152171bc50f8a369390f1f16efd89 upstream.
Lockless access to pte in pagemap_pte_range() might race with page
migration and trigger BUG_ON(!PageLocked()) in migration_entry_to_page():
CPU A (pagemap) CPU B (migration)
lock_page()
try_to_unmap(page, TTU_MIGRATION...)
make_migration_entry()
set_pte_at()
<read *pte>
pte_to_pagemap_entry()
remove_migration_ptes()
unlock_page()
if(is_migration_entry())
BUG_ON(!PageLocked(page))
Also lockless read might be non-atomic if pte is larger than wordsize.
Other pte walkers (smaps, numa_maps, clear_refs) already lock ptes.
Fixes: 052fb0d635df ("proc: report file/anon bit in /proc/pid/pagemap")
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Reported-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Reviewed-by: Cyrill Gorcunov <gorcunov@openvz.org>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: <stable@vger.kernel.org> [3.5+]
commit 81d0fa623c5b8dbd5279d9713094b0f9b0a00fb4 upstream.
If a /proc/pid/pagemap read spans a [VMA, an unmapped region, then a
VM_SOFTDIRTY VMA], the virtual pages in the unmapped region are reported
as softdirty. Here's a program to demonstrate the bug:
int main() {
const uint64_t PAGEMAP_SOFTDIRTY = 1ul << 55;
uint64_t pme[3];
int fd = open("/proc/self/pagemap", O_RDONLY);;
char *m = mmap(NULL, 3 * getpagesize(), PROT_READ,
MAP_ANONYMOUS | MAP_SHARED, -1, 0);
munmap(m + getpagesize(), getpagesize());
pread(fd, pme, 24, (unsigned long) m / getpagesize() * 8);
assert(pme[0] & PAGEMAP_SOFTDIRTY); /* passes */
assert(!(pme[1] & PAGEMAP_SOFTDIRTY)); /* fails */
assert(pme[2] & PAGEMAP_SOFTDIRTY); /* passes */
return 0;
(Note that all pages in new VMAs are softdirty until cleared).
Tested:
Used the program given above. I'm going to include this code in
a selftest in the future.
[n-horiguchi@ah.jp.nec.com: prevent pagemap_pte_range() from overrunning]
Signed-off-by: Peter Feiner <pfeiner@google.com>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Jamie Liu <jamieliu@google.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream.
move d_rcu from overlapping d_child to overlapping d_alias
- Apply name changes in all the different places we use d_alias and d_child
- Move the WARN_ON() in __d_free() to d_free() as we don't have dentry_free()]
commit deeb8525f9bcea60f5e86521880c1161de7a5829 upstream.
If we fail past the aio_setup_ring(), we need to destroy the
mapping. We don't need to care about anybody having found ctx,
or added requests to it, since the last failure exit is exactly
the failure to make ctx visible to lookups.
Reproducer (based on one by Joe Mario <jmario@redhat.com>):
void count(char *p)
char s[80];
printf("%s: ", p);
fflush(stdout);
sprintf(s, "/bin/cat /proc/%d/maps|/bin/fgrep -c '/[aio] (deleted)'", getpid());
system(s);
int main()
io_context_t *ctx;
int created, limit, i, destroyed;
FILE *f;
count("before");
if ((f = fopen("/proc/sys/fs/aio-max-nr", "r")) == NULL)
perror("opening aio-max-nr");
else if (fscanf(f, "%d", &limit) != 1)
fprintf(stderr, "can't parse aio-max-nr\n");
else if ((ctx = calloc(limit, sizeof(io_context_t))) == NULL)
perror("allocating aio_context_t array");
else {
for (i = 0, created = 0; i < limit; i++) {
if (io_setup(1000, ctx + created) == 0)
created++;
for (i = 0, destroyed = 0; i < created; i++)
if (io_destroy(ctx[i]) == 0)
destroyed++;
printf("created %d, failed %d, destroyed %d\n",
created, limit - created, destroyed);
count("after");
Found-by: Joe Mario <jmario@redhat.com>
commit 64b4e2526d1cf6e6a4db6213d6e2b6e6ab59479a upstream.
"ocfs2 syncs the wrong range" had been broken; prior to it the
code was doing the wrong thing in case of O_APPEND, all right,
but _after_ it we were syncing the wrong range in 100% cases.
*ppos, aka iocb->ki_pos is incremented prior to that point,
so we are always doing sync on the area _after_ the one we'd
written to.
Spotted by Joseph Qi <joseph.qi@huawei.com> back in January;
unfortunately, I'd missed his mail back then ;-/
commit e1e9bda22d7ddf88515e8fe401887e313922823e upstream.
Under intermittent network outages, find_writable_file() is susceptible
to the following race condition, which results in a user-after-free in
the cifs_writepages code-path:
Thread 1 Thread 2
inv_file = NULL
refind = 0
spin_lock(&cifs_file_list_lock)
// invalidHandle found on openFileList
inv_file = open_file
// inv_file->count currently 1
cifsFileInfo_get(inv_file)
// inv_file->count = 2
spin_unlock(&cifs_file_list_lock);
cifs_reopen_file() cifs_close()
// fails (rc != 0) ->cifsFileInfo_put()
// inv_file->count = 1
spin_lock(&cifs_file_list_lock);
list_move_tail(&inv_file->flist,
&cifs_inode->openFileList);
cifsFileInfo_put(inv_file);
->spin_lock(&cifs_file_list_lock)
// inv_file->count = 0
list_del(&cifs_file->flist);
// cleanup!!
kfree(cifs_file);
++refind;
// refind = 1
goto refind_writable;
At this point we loop back through with an invalid inv_file pointer
and a refind value of 1. On second pass, inv_file is not overwritten on
openFileList traversal, and is subsequently dereferenced.
Signed-off-by: David Disseldorp <ddiss@suse.de>
Reviewed-by: Jeff Layton <jlayton@samba.org>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 2477bc58d49edb1c0baf59df7dc093dce682af2b upstream.
While attempting to clone a file on a samba server, we receive a
STATUS_INVALID_DEVICE_REQUEST. This is mapped to -EOPNOTSUPP which
isn't handled in smb2_clone_range(). We end up looping in the while loop
making same call to the samba server over and over again.
The proposed fix is to exit and return the error value when encountered
with an unhandled error.
Signed-off-by: Sachin Prabhu <sprabhu@redhat.com>
Signed-off-by: Steve French <steve.french@primarydata.com>
commit 9c4f61f01d269815bb7c37be3ede59c5587747c6 upstream.
We can search and add the orphan item in one go,
btrfs_insert_orphan_item will find out if the item already exists.
Cc: Chris Mason <clm@fb.com>
Cc: Roman Mamedov <rm@romanrm.net>
commit 98cf21c61a7f5419d82f847c4d77bf6e96a76f5f upstream.
Fix B-tree corruption when a new record is inserted at position 0 in the
node in hfs_brec_insert(). In this case a hfs_brec_update_parent() is
called to update the parent index node (if exists) and it is passed
hfs_find_data with a search_key containing a newly inserted key instead
of the key to be updated. This results in an inconsistent index node.
The bug reproduces on my machine after an extents overflow record for
the catalog file (CNID=4) is inserted into the extents overflow B-tree.
Because of a low (reserved) value of CNID=4, it has to become the first
record in the first leaf node.
The resulting first leaf node is correct:
| key0.CNID=4 | key1.CNID=123 | key2.CNID=456, ... |
But the parent index key0 still contains the previous key CNID=123:
| key0.CNID=123 | ... |
A change in hfs_brec_insert() makes hfs_brec_update_parent() work
correctly by preventing it from getting fd->record=-1 value from
__hfs_brec_find().
Along the way, I removed duplicate code with unification of the if
condition. The resulting code is equivalent to the original code
because node is never 0.
Also hfs_brec_update_parent() will now return an error after getting a
negative fd->record value. However, the return value of
hfs_brec_update_parent() is not checked anywhere in the file and I'm
leaving it unchanged by this patch. brec.c lacks error checking after
some other calls too, but this issue is of less importance than the one
being fixed by this patch.
Signed-off-by: Sergei Antonov <saproj@gmail.com>
Cc: Joe Perches <joe@perches.com>
Reviewed-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Acked-by: Hin-Tak Leung <htl10@users.sourceforge.net>
Cc: Anton Altaparmakov <aia21@cam.ac.uk>
commit ab676b7d6fbf4b294bf198fb27ade5b0e865c7ce upstream.
As pointed by recent post[1] on exploiting DRAM physical imperfection,
/proc/PID/pagemap exposes sensitive information which can be used to do
attacks.
This disallows anybody without CAP_SYS_ADMIN to read the pagemap.
[1] http://googleprojectzero.blogspot.com/2015/03/exploiting-dram-rowhammer-bug-to-gain.html
[ Eventually we might want to do anything more finegrained, but for now
this is the simple model. - Linus ]
Acked-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Acked-by: Andy Lutomirski <luto@amacapital.net>
Cc: Mark Seaborn <mseaborn@chromium.org>
commit 283ee1482f349d6c0c09dfb725db5880afc56813 upstream.
According to a report from Yuxuan Shui, nilfs2 in kernel 3.19 got stuck
during recovery at mount time. The code path that caused the deadlock was
as follows:
nilfs_fill_super()
load_nilfs()
nilfs_salvage_orphan_logs()
* Do roll-forwarding, attach segment constructor for recovery,
and kick it.
nilfs_segctor_thread()
nilfs_segctor_thread_construct()
* A lock is held with nilfs_transaction_lock()
nilfs_segctor_do_construct()
nilfs_segctor_drop_written_files()
iput()
iput_final()
write_inode_now()
writeback_single_inode()
__writeback_single_inode()
do_writepages()
nilfs_writepage()
nilfs_construct_dsync_segment()
nilfs_transaction_lock() --> deadlock
This can happen if commit 7ef3ff2fea8b ("nilfs2: fix deadlock of segment
constructor over I_SYNC flag") is applied and roll-forward recovery was
performed at mount time. The roll-forward recovery can happen if datasync
write is done and the file system crashes immediately after that. For
instance, we can reproduce the issue with the following steps:
< nilfs2 is mounted on /nilfs (device: /dev/sdb1) >
# dd if=/dev/zero of=/nilfs/test bs=4k count=1 && sync
# dd if=/dev/zero of=/nilfs/test conv=notrunc oflag=dsync bs=4k
count=1 && reboot -nfh
< the system will immediately reboot >
# mount -t nilfs2 /dev/sdb1 /nilfs
The deadlock occurs because iput() can run segment constructor through
writeback_single_inode() if MS_ACTIVE flag is not set on sb->s_flags. The
above commit changed segment constructor so that it calls iput()
asynchronously for inodes with i_nlink == 0, but that change was
imperfect.
This fixes the another deadlock by deferring iput() in segment constructor
even for the case that mount is not finished, that is, for the case that
MS_ACTIVE flag is not set.
Reported-by: Yuxuan Shui <yshuiv7@gmail.com>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit 0d2783626a53d4c922f82d51fa675cb5d13f0d36 upstream.
fuse_try_move_page() is not prepared for replacing pages that have already
been read.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit aa991b3b267e24f578bac7b09cc57579b660304b upstream.
Regular pipe buffers' ->steal method (generic_pipe_buf_steal()) doesn't set
PG_uptodate.
Don't warn on this condition, just set the uptodate flag.
commit 7c0af9ffb7bb4e5355470fa60b3eb711ddf226fa upstream.
put_rpccred() can sleep.
Fixes: 8f649c3762547 ("NFSv4: Fix the locking in nfs_inode_reclaim_delegation()")
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 957ed60b53b519064a54988c4e31e0087e47d091 upstream.
Each inode of nilfs2 stores a root node of a b-tree, and it turned out to
have a memory overrun issue:
Each b-tree node of nilfs2 stores a set of key-value pairs and the number
of them (in "bn_nchildren" member of nilfs_btree_node struct), as well as
a few other "bn_*" members.
Since the value of "bn_nchildren" is used for operations on the key-values
within the b-tree node, it can cause memory access overrun if a large
number is incorrectly set to "bn_nchildren".
For instance, nilfs_btree_node_lookup() function determines the range of
binary search with it, and too large "bn_nchildren" leads
nilfs_btree_node_get_key() in that function to overrun.
As for intermediate b-tree nodes, this is prevented by a sanity check
performed when each node is read from a drive, however, no sanity check
has been done for root nodes stored in inodes.
This patch fixes the issue by adding missing sanity check against b-tree
root nodes so that it's called when on-memory inodes are read from ifile,
inode metadata file.
commit 7e0e953bb0cf649f93277ac8fb67ecbb7f7b04a9 upstream.
use_pde()/unuse_pde() in ->follow_link()/->put_link() resp.
commit 0db59e59299f0b67450c5db21f7f316c8fb04e84 upstream.
As it is, we have debugfs_remove() racing with symlink traversals.
Supply ->evict_inode() and do freeing there - inode will remain
pinned until we are done with the symlink body.
And rip the idiocy with checking if dentry is positive right after
we'd verified debugfs_positive(), which is a stronger check...
commit 0a280962dc6e117e0e4baa668453f753579265d9 upstream.
X-Coverup: just ask spender
commit dd9ef135e3542ffc621c4eb7f0091870ec7a1504 upstream.
Improper arithmetics when calculting the address of the extended ref could
lead to an out of bounds memory read and kernel panic.
Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com>
commit 3a8b36f378060d20062a0918e99fae39ff077bf0 upstream.
When using the fast file fsync code path we can miss the fact that new
writes happened since the last file fsync and therefore return without
waiting for the IO to finish and write the new extents to the fsync log.
Here's an example scenario where the fsync will miss the fact that new
file data exists that wasn't yet durably persisted:
1. fs_info->last_trans_committed == N - 1 and current transaction is
transaction N (fs_info->generation == N);
2. do a buffered write;
3. fsync our inode, this clears our inode's full sync flag, starts
an ordered extent and waits for it to complete - when it completes
at btrfs_finish_ordered_io(), the inode's last_trans is set to the
value N (via btrfs_update_inode_fallback -> btrfs_update_inode ->
btrfs_set_inode_last_trans);
4. transaction N is committed, so fs_info->last_trans_committed is now
set to the value N and fs_info->generation remains with the value N;
5. do another buffered write, when this happens btrfs_file_write_iter
sets our inode's last_trans to the value N + 1 (that is
fs_info->generation + 1 == N + 1);
6. transaction N + 1 is started and fs_info->generation now has the
value N + 1;
7. transaction N + 1 is committed, so fs_info->last_trans_committed
is set to the value N + 1;
8. fsync our inode - because it doesn't have the full sync flag set,
we only start the ordered extent, we don't wait for it to complete
(only in a later phase) therefore its last_trans field has the
value N + 1 set previously by btrfs_file_write_iter(), and so we
have:
inode->last_trans <= fs_info->last_trans_committed
(N + 1) (N + 1)
Which made us not log the last buffered write and exit the fsync
handler immediately, returning success (0) to user space and resulting
in data loss after a crash.
This can actually be triggered deterministically and the following excerpt
from a testcase I made for xfstests triggers the issue. It moves a dummy
file across directories and then fsyncs the old parent directory - this
is just to trigger a transaction commit, so moving files around isn't
directly related to the issue but it was chosen because running 'sync' for
example does more than just committing the current transaction, as it
flushes/waits for all file data to be persisted. The issue can also happen
at random periods, since the transaction kthread periodicaly commits the
current transaction (about every 30 seconds by default).
The body of the test is:
_scratch_mkfs >> $seqres.full 2>&1
_init_flakey
_mount_flakey
# Create our main test file 'foo', the one we check for data loss.
# By doing an fsync against our file, it makes btrfs clear the 'needs_full_sync'
# bit from its flags (btrfs inode specific flags).
$XFS_IO_PROG -f -c "pwrite -S 0xaa 0 8K" \
-c "fsync" $SCRATCH_MNT/foo | _filter_xfs_io
# Now create one other file and 2 directories. We will move this second file
# from one directory to the other later because it forces btrfs to commit its
# currently open transaction if we fsync the old parent directory. This is
# necessary to trigger the data loss bug that affected btrfs.
mkdir $SCRATCH_MNT/testdir_1
touch $SCRATCH_MNT/testdir_1/bar
mkdir $SCRATCH_MNT/testdir_2
# Make sure everything is durably persisted.
sync
# Write more 8Kb of data to our file.
$XFS_IO_PROG -c "pwrite -S 0xbb 8K 8K" $SCRATCH_MNT/foo | _filter_xfs_io
# Move our 'bar' file into a new directory.
mv $SCRATCH_MNT/testdir_1/bar $SCRATCH_MNT/testdir_2/bar
# Fsync our first directory. Because it had a file moved into some other
# directory, this made btrfs commit the currently open transaction. This is
# a condition necessary to trigger the data loss bug.
$XFS_IO_PROG -c "fsync" $SCRATCH_MNT/testdir_1
# Now fsync our main test file. If the fsync succeeds, we expect the 8Kb of
# data we wrote previously to be persisted and available if a crash happens.
# This did not happen with btrfs, because of the transaction commit that
# happened when we fsynced the parent directory.
$XFS_IO_PROG -c "fsync" $SCRATCH_MNT/foo
# Simulate a crash/power loss.
_load_flakey_table $FLAKEY_DROP_WRITES
_unmount_flakey
_load_flakey_table $FLAKEY_ALLOW_WRITES
_mount_flakey
# Now check that all data we wrote before are available.
echo "File content after log replay:"
od -t x1 $SCRATCH_MNT/foo
status=0
exit
The expected golden output for the test, which is what we get with this
fix applied (or when running against ext3/4 and xfs), is:
wrote 8192/8192 bytes at offset 0
XXX Bytes, X ops; XX:XX:XX.X (XXX YYY/sec and XXX ops/sec)
wrote 8192/8192 bytes at offset 8192
0000000 aa aa aa aa aa aa aa aa aa aa aa aa aa aa aa aa
0020000 bb bb bb bb bb bb bb bb bb bb bb bb bb bb bb bb
0040000
Without this fix applied, the output shows the test file does not have
the second 8Kb extent that we successfully fsynced:
0020000
So fix this by skipping the fsync only if we're doing a full sync and
if the inode's last_trans is <= fs_info->last_trans_committed, or if
the inode is already in the log. Also remove setting the inode's
last_trans in btrfs_file_write_iter since it's useless/unreliable.
Also because btrfs_file_write_iter no longer sets inode->last_trans to
fs_info->generation + 1, don't set last_trans to 0 if we bail out and don't
bail out if last_trans is 0, otherwise something as simple as the following
example wouldn't log the second write on the last fsync:
1. write to file
2. fsync file
3. fsync file
|--> btrfs_inode_in_log() returns true and it set last_trans to 0
4. write to file
|--> btrfs_file_write_iter() no longers sets last_trans, so it
remained with a value of 0
5. fsync
|--> inode->last_trans == 0, so it bails out without logging the
second write
A test case for xfstests will be sent soon.
commit 1932b7be973b554ffe20a5bba6ffaed6fa995cdc upstream.
A block-local variable stores error code but btrfs_get_blocks_direct may
not return it in the end as there's a ret defined in the function scope.
Fixes: d187663ef24c ("Btrfs: lock extents as we map them in DIO")
commit 4e7c22d447bb6d7e37bfe39ff658486ae78e8d77 upstream.
The issue is that the stack for processes is not properly randomized on
64 bit architectures due to an integer overflow.
The affected function is randomize_stack_top() in file
"fs/binfmt_elf.c":
static unsigned long randomize_stack_top(unsigned long stack_top)
unsigned int random_variable = 0;
if ((current->flags & PF_RANDOMIZE) &&
!(current->personality & ADDR_NO_RANDOMIZE)) {
random_variable = get_random_int() & STACK_RND_MASK;
random_variable <<= PAGE_SHIFT;
return PAGE_ALIGN(stack_top) + random_variable;
return PAGE_ALIGN(stack_top) - random_variable;
Note that, it declares the "random_variable" variable as "unsigned int".
Since the result of the shifting operation between STACK_RND_MASK (which
is 0x3fffff on x86_64, 22 bits) and PAGE_SHIFT (which is 12 on x86_64):
then the two leftmost bits are dropped when storing the result in the
"random_variable". This variable shall be at least 34 bits long to hold
the (22+12) result.
These two dropped bits have an impact on the entropy of process stack.
Concretely, the total stack entropy is reduced by four: from 2^28 to
2^30 (One fourth of expected entropy).
This patch restores back the entropy by correcting the types involved
in the operations in the functions randomize_stack_top() and
stack_maxrandom_size().
The successful fix can be tested with:
$ for i in `seq 1 10`; do cat /proc/self/maps | grep stack; done
7ffeda566000-7ffeda587000 rw-p 00000000 00:00 0 [stack]
7fff5a332000-7fff5a353000 rw-p 00000000 00:00 0 [stack]
7ffcdb7a1000-7ffcdb7c2000 rw-p 00000000 00:00 0 [stack]
7ffd5e2c4000-7ffd5e2e5000 rw-p 00000000 00:00 0 [stack]
Once corrected, the leading bytes should be between 7ffc and 7fff,
rather than always being 7fff.
Signed-off-by: Hector Marco-Gisbert <hecmargi@upv.es>
Signed-off-by: Ismael Ripoll <iripoll@upv.es>
[ Rebased, fixed 80 char bugs, cleaned up commit message, added test example and CVE ]
Fixes: CVE-2015-1593
Link: http://lkml.kernel.org/r/20150214173350.GA18393@www.outflux.net
commit 381cf6587f8a8a8e981bc0c1aaaa8859b51dc756 upstream.
If btrfs_find_item is called with NULL path it allocates one locally but
does not free it. Affected paths are inserting an orphan item for a file
and for a subvol root.
Move the path allocation to the callers.
Fixes: 3f870c289900 ("btrfs: expand btrfs_find_item() to include find_orphan_item functionality")
commit 5efa0490cc94aee06cd8d282683e22a8ce0a0026 upstream.
This has been confusing people for too long, the message is really just
informative.
