837a6e7f5cdb ("fs: add generic UNRESVSP and ZERO_RANGE ioctl handlers") changed
ioctls XFS_IOC_UNRESVSP XFS_IOC_UNRESVSP64 and XFS_IOC_ZERO_RANGE to be generic
instead of xfs specific.
Because of this change, 36f11775da75 ("xfs: properly serialise fallocate against
AIO+DIO") needed adaptation, as 5.4 still uses the xfs specific ioctls.
Without this, xfstests xfs/242 and xfs/290 fail. Both of these tests test
XFS_IOC_ZERO_RANGE.
Fixes: 36f11775da75 ("xfs: properly serialise fallocate against AIO+DIO")
Tested-by: Andy Strohman <astroh@amazon.com>
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
commit da7d554f7c62d0c17c1ac3cc2586473c2d99f0bd upstream.
Commit fc0e38dae645 ("GFS2: Fix glock deallocation race") fixed a
sd_glock_disposal accounting bug by adding a missing atomic_dec
statement, but it failed to wake up sd_glock_wait when that decrement
causes sd_glock_disposal to reach zero. As a consequence,
gfs2_gl_hash_clear can now run into a 10-minute timeout instead of
being woken up. Add the missing wakeup.
Fixes: fc0e38dae645 ("GFS2: Fix glock deallocation race")
Cc: stable@vger.kernel.org # v2.6.39+
Signed-off-by: Alexander Aring <aahringo@redhat.com>
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
commit 9480b4e75b7108ee68ecf5bc6b4bd68e8031c521 upstream.
If ->readpage returns an error, it has already unlocked the page.
Fixes: 5e929b33c393 ("CacheFiles: Handle truncate unlocking the page we're reading")
Signed-off-by: Matthew Wilcox (Oracle) <willy@infradead.org>
commit 1322181170bb01bce3c228b82ae3d5c6b793164f upstream.
During the stability test, there are some errors:
ext4_lookup:1590: inode #6967: comm fsstress: iget: checksum invalid.
If the inode->i_iblocks too big and doesn't set huge file flag, checksum
will not be recalculated when update the inode information to it's buffer.
If other inode marks the buffer dirty, then the inconsistent inode will
be flushed to disk.
Fix this problem by checking i_blocks in advance.
Cc: stable@kernel.org
Signed-off-by: Luo Meng <luomeng12@huawei.com>
Link: https://lore.kernel.org/r/20201020013631.3796673-1-luomeng12@huawei.com
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit c9e87161cc621cbdcfc472fa0b2d81c63780c8f5 upstream.
When ext4_journal_get_write_access() fails, we should
terminate the execution flow and release n_group_desc,
iloc.bh, dind and gdb_bh.
Signed-off-by: Dinghao Liu <dinghao.liu@zju.edu.cn>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
Link: https://lore.kernel.org/r/20200829025403.3139-1-dinghao.liu@zju.edu.cn
commit cb8d53d2c97369029cc638c9274ac7be0a316c75 upstream.
ext4_unregister_sysfs() only deletes the kobject. The reference to it
needs to be put separately, like ext4_put_super() does.
This addresses the syzbot report
"memory leak in kobject_set_name_vargs (3)"
(https://syzkaller.appspot.com/bug?extid=9f864abad79fae7c17e1).
Reported-by: syzbot+9f864abad79fae7c17e1@syzkaller.appspotmail.com
Fixes: 72ba74508b28 ("ext4: release sysfs kobject when failing to enable quotas on mount")
Link: https://lore.kernel.org/r/20200922162456.93657-1-ebiggers@kernel.org
commit f5f7ab168b9a60e12a4b8f2bb6fcc91321dc23c1 upstream.
On 32-bit systems, this multiplication will overflow for files larger
than 4GB.
Link: http://lkml.kernel.org/r/20201004180428.14494-2-willy@infradead.org
Fixes: fb89b45cdfdc ("9P: introduction of a new cache=mmap model.")
Signed-off-by: Dominique Martinet <asmadeus@codewreck.org>
commit c403c3a2fbe24d4ed33e10cabad048583ebd4edf upstream.
On 32-bit systems, this shift will overflow for files larger than 4GB.
Fixes: 61f68816211e ("ceph: check caps in filemap_fault and page_mkwrite")
Reviewed-by: Jeff Layton <jlayton@kernel.org>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
commit e2a05cc7f8229e150243cdae40f2af9021d67a4a upstream.
Release the authentication related resource in some error handling
branches in mount_ubifs().
Signed-off-by: Zhihao Cheng <chengzhihao1@huawei.com>
Cc: <stable@vger.kernel.org> # 4.20+
Fixes: d8a22773a12c6d7 ("ubifs: Enable authentication support")
Reviewed-by: Sascha Hauer <s.hauer@pengutronix.de>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit bb674a4d4de1032837fcbf860a63939e66f0b7ad upstream.
There is no need to dump authentication options while remounting,
because authentication initialization can only be doing once in
the first mount process. Dumping authentication mount options in
remount process may cause memory leak if UBIFS has already been
mounted with old authentication mount options.
commit 47f6d9ce45b03a40c34b668a9884754c58122b39 upstream.
Fix a memory leak after dumping authentication mount options in error
handling branch.
commit 78c7d49f55d8631b67c09f9bfbe8155211a9ea06 upstream.
When removing the last reference of an inode the size of an auth node
is already part of write_len. So we must not call ubifs_add_auth_dirt().
Call it only when needed.
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Kristof Havasi <havasiefr@gmail.com>
Fixes: 6a98bc4614de ("ubifs: Add authentication nodes to journal")
Reported-and-tested-by: Kristof Havasi <havasiefr@gmail.com>
commit f2aae745b82c842221f4f233051f9ac641790959 upstream.
Fix some potential memory leaks in error handling branches while
iterating xattr entries. For example, function ubifs_tnc_remove_ino()
forgets to free pxent if it exists. Similar problems also exist in
ubifs_purge_xattrs(), ubifs_add_orphan() and ubifs_jnl_write_inode().
Fixes: 1e51764a3c2ac05a2 ("UBIFS: add new flash file system")
commit 58f6e78a65f1fcbf732f60a7478ccc99873ff3ba upstream.
iterating dent entries. For example, function dbg_check_dir()
forgets to free pdent if it exists.
commit 6b3dccd48de8a4c650b01499a0b09d1e2279649e upstream.
There's no protection in nfsd_dispatch() against a NULL .pc_func
helpers. A malicious NFS client can trigger a crash by invoking the
unused/unsupported NFSv2 ROOT or WRITECACHE procedures.
The current NFSD dispatcher does not support returning a void reply
to a non-NULL procedure, so the reply to both of these is wrong, for
the moment.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 8c39076c276be0b31982e44654e2c2357473258a upstream.
RFC 7862 introduced a new flag that either client or server is
allowed to set: EXCHGID4_FLAG_SUPP_FENCE_OPS.
Client needs to update its bitmask to allow for this flag value.
v2: changed minor version argument to unsigned int
Signed-off-by: Olga Kornievskaia <kolga@netapp.com>
CC: <stable@vger.kernel.org>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
commit b4868b44c5628995fdd8ef2e24dda73cef963a75 upstream.
Since commit 0e0cb35b417f ("NFSv4: Handle NFS4ERR_OLD_STATEID in
CLOSE/OPEN_DOWNGRADE") the following livelock may occur if a CLOSE races
with the update of the nfs_state:
Process 1 Process 2 Server
OPEN file
OPEN file
Reply OPEN (1)
Reply OPEN (2)
Update state (1)
CLOSE file (1)
Reply OLD_STATEID (1)
CLOSE file (2)
Reply CLOSE (-1)
Update state (2)
wait for state change
OPEN file
wake
CLOSE file
OPEN file
wake
CLOSE file
We can avoid this situation by not issuing an immediate retry with a bumped
seqid when CLOSE/OPEN_DOWNGRADE receives NFS4ERR_OLD_STATEID. Instead,
take the same approach used by OPEN and wait at least 5 seconds for
outstanding stateid updates to complete if we can detect that we're out of
sequence.
Note that after this change it is still possible (though unlikely) that
CLOSE waits a full 5 seconds, bumps the seqid, and retries -- and that
attempt races with another OPEN at the same time. In order to avoid this
race (which would result in the livelock), update
nfs_need_update_open_stateid() to handle the case where:
- the state is NFS_OPEN_STATE, and
- the stateid doesn't match the current open stateid
Finally, nfs_need_update_open_stateid() is modified to be idempotent and
renamed to better suit the purpose of signaling that the stateid passed
is the next stateid in sequence.
Fixes: 0e0cb35b417f ("NFSv4: Handle NFS4ERR_OLD_STATEID in CLOSE/OPEN_DOWNGRADE")
Cc: stable@vger.kernel.org # v5.4+
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
commit a7be300de800e755714c71103ae4a0d205e41e99 upstream.
udf_process_sequence() allocates temporary array for processing
partition descriptors on volume which it fails to free. Free the array
when it is not needed anymore.
Fixes: 7b78fd02fb19 ("udf: Fix handling of Partition Descriptors")
CC: stable@vger.kernel.org
Reported-by: syzbot+128f4dd6e796c98b3760@syzkaller.appspotmail.com
commit 66d204a16c94f24ad08290a7663ab67e7fc04e82 upstream.
Very sporadically I had test case btrfs/069 from fstests hanging (for
years, it is not a recent regression), with the following traces in
dmesg/syslog:
[162301.160628] BTRFS info (device sdc): dev_replace from /dev/sdd (devid 2) to /dev/sdg started
[162301.181196] BTRFS info (device sdc): scrub: finished on devid 4 with status: 0
[162301.287162] BTRFS info (device sdc): dev_replace from /dev/sdd (devid 2) to /dev/sdg finished
[162513.513792] INFO: task btrfs-transacti:1356167 blocked for more than 120 seconds.
[162513.514318] Not tainted 5.9.0-rc6-btrfs-next-69 #1
[162513.514522] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[162513.514747] task:btrfs-transacti state:D stack: 0 pid:1356167 ppid: 2 flags:0x00004000
[162513.514751] Call Trace:
[162513.514761] __schedule+0x5ce/0xd00
[162513.514765] ? _raw_spin_unlock_irqrestore+0x3c/0x60
[162513.514771] schedule+0x46/0xf0
[162513.514844] wait_current_trans+0xde/0x140 [btrfs]
[162513.514850] ? finish_wait+0x90/0x90
[162513.514864] start_transaction+0x37c/0x5f0 [btrfs]
[162513.514879] transaction_kthread+0xa4/0x170 [btrfs]
[162513.514891] ? btrfs_cleanup_transaction+0x660/0x660 [btrfs]
[162513.514894] kthread+0x153/0x170
[162513.514897] ? kthread_stop+0x2c0/0x2c0
[162513.514902] ret_from_fork+0x22/0x30
[162513.514916] INFO: task fsstress:1356184 blocked for more than 120 seconds.
[162513.515192] Not tainted 5.9.0-rc6-btrfs-next-69 #1
[162513.515431] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[162513.515680] task:fsstress state:D stack: 0 pid:1356184 ppid:1356177 flags:0x00004000
[162513.515682] Call Trace:
[162513.515688] __schedule+0x5ce/0xd00
[162513.515691] ? _raw_spin_unlock_irqrestore+0x3c/0x60
[162513.515697] schedule+0x46/0xf0
[162513.515712] wait_current_trans+0xde/0x140 [btrfs]
[162513.515716] ? finish_wait+0x90/0x90
[162513.515729] start_transaction+0x37c/0x5f0 [btrfs]
[162513.515743] btrfs_attach_transaction_barrier+0x1f/0x50 [btrfs]
[162513.515753] btrfs_sync_fs+0x61/0x1c0 [btrfs]
[162513.515758] ? __ia32_sys_fdatasync+0x20/0x20
[162513.515761] iterate_supers+0x87/0xf0
[162513.515765] ksys_sync+0x60/0xb0
[162513.515768] __do_sys_sync+0xa/0x10
[162513.515771] do_syscall_64+0x33/0x80
[162513.515774] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[162513.515781] RIP: 0033:0x7f5238f50bd7
[162513.515782] Code: Bad RIP value.
[162513.515784] RSP: 002b:00007fff67b978e8 EFLAGS: 00000206 ORIG_RAX: 00000000000000a2
[162513.515786] RAX: ffffffffffffffda RBX: 000055b1fad2c560 RCX: 00007f5238f50bd7
[162513.515788] RDX: 00000000ffffffff RSI: 000000000daf0e74 RDI: 000000000000003a
[162513.515789] RBP: 0000000000000032 R08: 000000000000000a R09: 00007f5239019be0
[162513.515791] R10: fffffffffffff24f R11: 0000000000000206 R12: 000000000000003a
[162513.515792] R13: 00007fff67b97950 R14: 00007fff67b97906 R15: 000055b1fad1a340
[162513.515804] INFO: task fsstress:1356185 blocked for more than 120 seconds.
[162513.516064] Not tainted 5.9.0-rc6-btrfs-next-69 #1
[162513.516329] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[162513.516617] task:fsstress state:D stack: 0 pid:1356185 ppid:1356177 flags:0x00000000
[162513.516620] Call Trace:
[162513.516625] __schedule+0x5ce/0xd00
[162513.516628] ? _raw_spin_unlock_irqrestore+0x3c/0x60
[162513.516634] schedule+0x46/0xf0
[162513.516647] wait_current_trans+0xde/0x140 [btrfs]
[162513.516650] ? finish_wait+0x90/0x90
[162513.516662] start_transaction+0x4d7/0x5f0 [btrfs]
[162513.516679] btrfs_setxattr_trans+0x3c/0x100 [btrfs]
[162513.516686] __vfs_setxattr+0x66/0x80
[162513.516691] __vfs_setxattr_noperm+0x70/0x200
[162513.516697] vfs_setxattr+0x6b/0x120
[162513.516703] setxattr+0x125/0x240
[162513.516709] ? lock_acquire+0xb1/0x480
[162513.516712] ? mnt_want_write+0x20/0x50
[162513.516721] ? rcu_read_lock_any_held+0x8e/0xb0
[162513.516723] ? preempt_count_add+0x49/0xa0
[162513.516725] ? __sb_start_write+0x19b/0x290
[162513.516727] ? preempt_count_add+0x49/0xa0
[162513.516732] path_setxattr+0xba/0xd0
[162513.516739] __x64_sys_setxattr+0x27/0x30
[162513.516741] do_syscall_64+0x33/0x80
[162513.516743] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[162513.516745] RIP: 0033:0x7f5238f56d5a
[162513.516746] Code: Bad RIP value.
[162513.516748] RSP: 002b:00007fff67b97868 EFLAGS: 00000202 ORIG_RAX: 00000000000000bc
[162513.516750] RAX: ffffffffffffffda RBX: 0000000000000001 RCX: 00007f5238f56d5a
[162513.516751] RDX: 000055b1fbb0d5a0 RSI: 00007fff67b978a0 RDI: 000055b1fbb0d470
[162513.516753] RBP: 000055b1fbb0d5a0 R08: 0000000000000001 R09: 00007fff67b97700
[162513.516754] R10: 0000000000000004 R11: 0000000000000202 R12: 0000000000000004
[162513.516756] R13: 0000000000000024 R14: 0000000000000001 R15: 00007fff67b978a0
[162513.516767] INFO: task fsstress:1356196 blocked for more than 120 seconds.
[162513.517064] Not tainted 5.9.0-rc6-btrfs-next-69 #1
[162513.517365] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[162513.517763] task:fsstress state:D stack: 0 pid:1356196 ppid:1356177 flags:0x00004000
[162513.517780] Call Trace:
[162513.517786] __schedule+0x5ce/0xd00
[162513.517789] ? _raw_spin_unlock_irqrestore+0x3c/0x60
[162513.517796] schedule+0x46/0xf0
[162513.517810] wait_current_trans+0xde/0x140 [btrfs]
[162513.517814] ? finish_wait+0x90/0x90
[162513.517829] start_transaction+0x37c/0x5f0 [btrfs]
[162513.517845] btrfs_attach_transaction_barrier+0x1f/0x50 [btrfs]
[162513.517857] btrfs_sync_fs+0x61/0x1c0 [btrfs]
[162513.517862] ? __ia32_sys_fdatasync+0x20/0x20
[162513.517865] iterate_supers+0x87/0xf0
[162513.517869] ksys_sync+0x60/0xb0
[162513.517872] __do_sys_sync+0xa/0x10
[162513.517875] do_syscall_64+0x33/0x80
[162513.517878] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[162513.517881] RIP: 0033:0x7f5238f50bd7
[162513.517883] Code: Bad RIP value.
[162513.517885] RSP: 002b:00007fff67b978e8 EFLAGS: 00000206 ORIG_RAX: 00000000000000a2
[162513.517887] RAX: ffffffffffffffda RBX: 000055b1fad2c560 RCX: 00007f5238f50bd7
[162513.517889] RDX: 0000000000000000 RSI: 000000007660add2 RDI: 0000000000000053
[162513.517891] RBP: 0000000000000032 R08: 0000000000000067 R09: 00007f5239019be0
[162513.517893] R10: fffffffffffff24f R11: 0000000000000206 R12: 0000000000000053
[162513.517895] R13: 00007fff67b97950 R14: 00007fff67b97906 R15: 000055b1fad1a340
[162513.517908] INFO: task fsstress:1356197 blocked for more than 120 seconds.
[162513.518298] Not tainted 5.9.0-rc6-btrfs-next-69 #1
[162513.518672] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[162513.519157] task:fsstress state:D stack: 0 pid:1356197 ppid:1356177 flags:0x00000000
[162513.519160] Call Trace:
[162513.519165] __schedule+0x5ce/0xd00
[162513.519168] ? _raw_spin_unlock_irqrestore+0x3c/0x60
[162513.519174] schedule+0x46/0xf0
[162513.519190] wait_current_trans+0xde/0x140 [btrfs]
[162513.519193] ? finish_wait+0x90/0x90
[162513.519206] start_transaction+0x4d7/0x5f0 [btrfs]
[162513.519222] btrfs_create+0x57/0x200 [btrfs]
[162513.519230] lookup_open+0x522/0x650
[162513.519246] path_openat+0x2b8/0xa50
[162513.519270] do_filp_open+0x91/0x100
[162513.519275] ? find_held_lock+0x32/0x90
[162513.519280] ? lock_acquired+0x33b/0x470
[162513.519285] ? do_raw_spin_unlock+0x4b/0xc0
[162513.519287] ? _raw_spin_unlock+0x29/0x40
[162513.519295] do_sys_openat2+0x20d/0x2d0
[162513.519300] do_sys_open+0x44/0x80
[162513.519304] do_syscall_64+0x33/0x80
[162513.519307] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[162513.519309] RIP: 0033:0x7f5238f4a903
[162513.519310] Code: Bad RIP value.
[162513.519312] RSP: 002b:00007fff67b97758 EFLAGS: 00000246 ORIG_RAX: 0000000000000055
[162513.519314] RAX: ffffffffffffffda RBX: 00000000ffffffff RCX: 00007f5238f4a903
[162513.519316] RDX: 0000000000000000 RSI: 00000000000001b6 RDI: 000055b1fbb0d470
[162513.519317] RBP: 00007fff67b978c0 R08: 0000000000000001 R09: 0000000000000002
[162513.519319] R10: 00007fff67b974f7 R11: 0000000000000246 R12: 0000000000000013
[162513.519320] R13: 00000000000001b6 R14: 00007fff67b97906 R15: 000055b1fad1c620
[162513.519332] INFO: task btrfs:1356211 blocked for more than 120 seconds.
[162513.519727] Not tainted 5.9.0-rc6-btrfs-next-69 #1
[162513.520115] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[162513.520508] task:btrfs state:D stack: 0 pid:1356211 ppid:1356178 flags:0x00004002
[162513.520511] Call Trace:
[162513.520516] __schedule+0x5ce/0xd00
[162513.520519] ? _raw_spin_unlock_irqrestore+0x3c/0x60
[162513.520525] schedule+0x46/0xf0
[162513.520544] btrfs_scrub_pause+0x11f/0x180 [btrfs]
[162513.520548] ? finish_wait+0x90/0x90
[162513.520562] btrfs_commit_transaction+0x45a/0xc30 [btrfs]
[162513.520574] ? start_transaction+0xe0/0x5f0 [btrfs]
[162513.520596] btrfs_dev_replace_finishing+0x6d8/0x711 [btrfs]
[162513.520619] btrfs_dev_replace_by_ioctl.cold+0x1cc/0x1fd [btrfs]
[162513.520639] btrfs_ioctl+0x2a25/0x36f0 [btrfs]
[162513.520643] ? do_sigaction+0xf3/0x240
[162513.520645] ? find_held_lock+0x32/0x90
[162513.520648] ? do_sigaction+0xf3/0x240
[162513.520651] ? lock_acquired+0x33b/0x470
[162513.520655] ? _raw_spin_unlock_irq+0x24/0x50
[162513.520657] ? lockdep_hardirqs_on+0x7d/0x100
[162513.520660] ? _raw_spin_unlock_irq+0x35/0x50
[162513.520662] ? do_sigaction+0xf3/0x240
[162513.520671] ? __x64_sys_ioctl+0x83/0xb0
[162513.520672] __x64_sys_ioctl+0x83/0xb0
[162513.520677] do_syscall_64+0x33/0x80
[162513.520679] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[162513.520681] RIP: 0033:0x7fc3cd307d87
[162513.520682] Code: Bad RIP value.
[162513.520684] RSP: 002b:00007ffe30a56bb8 EFLAGS: 00000202 ORIG_RAX: 0000000000000010
[162513.520686] RAX: ffffffffffffffda RBX: 0000000000000004 RCX: 00007fc3cd307d87
[162513.520687] RDX: 00007ffe30a57a30 RSI: 00000000ca289435 RDI: 0000000000000003
[162513.520689] RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000
[162513.520690] R10: 0000000000000008 R11: 0000000000000202 R12: 0000000000000003
[162513.520692] R13: 0000557323a212e0 R14: 00007ffe30a5a520 R15: 0000000000000001
[162513.520703]
Showing all locks held in the system:
[162513.520712] 1 lock held by khungtaskd/54:
[162513.520713] #0: ffffffffb40a91a0 (rcu_read_lock){....}-{1:2}, at: debug_show_all_locks+0x15/0x197
[162513.520728] 1 lock held by in:imklog/596:
[162513.520729] #0: ffff8f3f0d781400 (&f->f_pos_lock){+.+.}-{3:3}, at: __fdget_pos+0x4d/0x60
[162513.520782] 1 lock held by btrfs-transacti/1356167:
[162513.520784] #0: ffff8f3d810cc848 (&fs_info->transaction_kthread_mutex){+.+.}-{3:3}, at: transaction_kthread+0x4a/0x170 [btrfs]
[162513.520798] 1 lock held by btrfs/1356190:
[162513.520800] #0: ffff8f3d57644470 (sb_writers#15){.+.+}-{0:0}, at: mnt_want_write_file+0x22/0x60
[162513.520805] 1 lock held by fsstress/1356184:
[162513.520806] #0: ffff8f3d576440e8 (&type->s_umount_key#62){++++}-{3:3}, at: iterate_supers+0x6f/0xf0
[162513.520811] 3 locks held by fsstress/1356185:
[162513.520812] #0: ffff8f3d57644470 (sb_writers#15){.+.+}-{0:0}, at: mnt_want_write+0x20/0x50
[162513.520815] #1: ffff8f3d80a650b8 (&type->i_mutex_dir_key#10){++++}-{3:3}, at: vfs_setxattr+0x50/0x120
[162513.520820] #2: ffff8f3d57644690 (sb_internal#2){.+.+}-{0:0}, at: start_transaction+0x40e/0x5f0 [btrfs]
[162513.520833] 1 lock held by fsstress/1356196:
[162513.520834] #0: ffff8f3d576440e8 (&type->s_umount_key#62){++++}-{3:3}, at: iterate_supers+0x6f/0xf0
[162513.520838] 3 locks held by fsstress/1356197:
[162513.520839] #0: ffff8f3d57644470 (sb_writers#15){.+.+}-{0:0}, at: mnt_want_write+0x20/0x50
[162513.520843] #1: ffff8f3d506465e8 (&type->i_mutex_dir_key#10){++++}-{3:3}, at: path_openat+0x2a7/0xa50
[162513.520846] #2: ffff8f3d57644690 (sb_internal#2){.+.+}-{0:0}, at: start_transaction+0x40e/0x5f0 [btrfs]
[162513.520858] 2 locks held by btrfs/1356211:
[162513.520859] #0: ffff8f3d810cde30 (&fs_info->dev_replace.lock_finishing_cancel_unmount){+.+.}-{3:3}, at: btrfs_dev_replace_finishing+0x52/0x711 [btrfs]
[162513.520877] #1: ffff8f3d57644690 (sb_internal#2){.+.+}-{0:0}, at: start_transaction+0x40e/0x5f0 [btrfs]
This was weird because the stack traces show that a transaction commit,
triggered by a device replace operation, is blocking trying to pause any
running scrubs but there are no stack traces of blocked tasks doing a
scrub.
After poking around with drgn, I noticed there was a scrub task that was
constantly running and blocking for shorts periods of time:
>>> t = find_task(prog, 1356190)
>>> prog.stack_trace(t)
#0 __schedule+0x5ce/0xcfc
#1 schedule+0x46/0xe4
#2 schedule_timeout+0x1df/0x475
#3 btrfs_reada_wait+0xda/0x132
#4 scrub_stripe+0x2a8/0x112f
#5 scrub_chunk+0xcd/0x134
#6 scrub_enumerate_chunks+0x29e/0x5ee
#7 btrfs_scrub_dev+0x2d5/0x91b
#8 btrfs_ioctl+0x7f5/0x36e7
#9 __x64_sys_ioctl+0x83/0xb0
#10 do_syscall_64+0x33/0x77
#11 entry_SYSCALL_64+0x7c/0x156
Which corresponds to:
int btrfs_reada_wait(void *handle)
struct reada_control *rc = handle;
struct btrfs_fs_info *fs_info = rc->fs_info;
while (atomic_read(&rc->elems)) {
if (!atomic_read(&fs_info->reada_works_cnt))
reada_start_machine(fs_info);
wait_event_timeout(rc->wait, atomic_read(&rc->elems) == 0,
(HZ + 9) / 10);
So the counter "rc->elems" was set to 1 and never decreased to 0, causing
the scrub task to loop forever in that function. Then I used the following
script for drgn to check the readahead requests:
$ cat dump_reada.py
import sys
import drgn
from drgn import NULL, Object, cast, container_of, execscript, \
reinterpret, sizeof
from drgn.helpers.linux import *
mnt_path = b"/home/fdmanana/btrfs-tests/scratch_1"
mnt = None
for mnt in for_each_mount(prog, dst = mnt_path):
pass
if mnt is None:
sys.stderr.write(f'Error: mount point {mnt_path} not found\n')
sys.exit(1)
fs_info = cast('struct btrfs_fs_info *', mnt.mnt.mnt_sb.s_fs_info)
def dump_re(re):
nzones = re.nzones.value_()
print(f're at {hex(re.value_())}')
print(f'\t logical {re.logical.value_()}')
print(f'\t refcnt {re.refcnt.value_()}')
print(f'\t nzones {nzones}')
for i in range(nzones):
dev = re.zones[i].device
name = dev.name.str.string_()
print(f'\t\t dev id {dev.devid.value_()} name {name}')
print()
for _, e in radix_tree_for_each(fs_info.reada_tree):
re = cast('struct reada_extent *', e)
dump_re(re)
$ drgn dump_reada.py
re at 0xffff8f3da9d25ad8
logical 38928384
refcnt 1
nzones 1
dev id 0 name b'/dev/sdd'
So there was one readahead extent with a single zone corresponding to the
source device of that last device replace operation logged in dmesg/syslog.
Also the ID of that zone's device was 0 which is a special value set in
the source device of a device replace operation when the operation finishes
(constant BTRFS_DEV_REPLACE_DEVID set at btrfs_dev_replace_finishing()),
confirming again that device /dev/sdd was the source of a device replace
operation.
Normally there should be as many zones in the readahead extent as there are
devices, and I wasn't expecting the extent to be in a block group with a
'single' profile, so I went and confirmed with the following drgn script
that there weren't any single profile block groups:
$ cat dump_block_groups.py
import sys
import drgn
reinterpret, sizeof
mnt = None
pass
if mnt is None:
sys.exit(1)
BTRFS_BLOCK_GROUP_DATA = (1 << 0)
BTRFS_BLOCK_GROUP_SYSTEM = (1 << 1)
BTRFS_BLOCK_GROUP_METADATA = (1 << 2)
BTRFS_BLOCK_GROUP_RAID0 = (1 << 3)
BTRFS_BLOCK_GROUP_RAID1 = (1 << 4)
BTRFS_BLOCK_GROUP_DUP = (1 << 5)
BTRFS_BLOCK_GROUP_RAID10 = (1 << 6)
BTRFS_BLOCK_GROUP_RAID5 = (1 << 7)
BTRFS_BLOCK_GROUP_RAID6 = (1 << 8)
BTRFS_BLOCK_GROUP_RAID1C3 = (1 << 9)
BTRFS_BLOCK_GROUP_RAID1C4 = (1 << 10)
def bg_flags_string(bg):
flags = bg.flags.value_()
ret = ''
if flags & BTRFS_BLOCK_GROUP_DATA:
ret = 'data'
if flags & BTRFS_BLOCK_GROUP_METADATA:
if len(ret) > 0:
ret += '|'
ret += 'meta'
if flags & BTRFS_BLOCK_GROUP_SYSTEM:
if len(ret) > 0:
ret += '|'
ret += 'system'
if flags & BTRFS_BLOCK_GROUP_RAID0:
ret += ' raid0'
elif flags & BTRFS_BLOCK_GROUP_RAID1:
ret += ' raid1'
elif flags & BTRFS_BLOCK_GROUP_DUP:
ret += ' dup'
elif flags & BTRFS_BLOCK_GROUP_RAID10:
ret += ' raid10'
elif flags & BTRFS_BLOCK_GROUP_RAID5:
ret += ' raid5'
elif flags & BTRFS_BLOCK_GROUP_RAID6:
ret += ' raid6'
elif flags & BTRFS_BLOCK_GROUP_RAID1C3:
ret += ' raid1c3'
elif flags & BTRFS_BLOCK_GROUP_RAID1C4:
ret += ' raid1c4'
else:
ret += ' single'
return ret
def dump_bg(bg):
print()
print(f'block group at {hex(bg.value_())}')
print(f'\t start {bg.start.value_()} length {bg.length.value_()}')
print(f'\t flags {bg.flags.value_()} - {bg_flags_string(bg)}')
bg_root = fs_info.block_group_cache_tree.address_of_()
for bg in rbtree_inorder_for_each_entry('struct btrfs_block_group', bg_root, 'cache_node'):
dump_bg(bg)
$ drgn dump_block_groups.py
block group at 0xffff8f3d673b0400
start 22020096 length 16777216
flags 258 - system raid6
block group at 0xffff8f3d53ddb400
start 38797312 length 536870912
flags 260 - meta raid6
block group at 0xffff8f3d5f4d9c00
start 575668224 length 2147483648
flags 257 - data raid6
block group at 0xffff8f3d08189000
start 2723151872 length 67108864
block group at 0xffff8f3db70ff000
start 2790260736 length 1073741824
block group at 0xffff8f3d5f4dd800
start 3864002560 length 67108864
block group at 0xffff8f3d67037000
start 3931111424 length 2147483648
So there were only 2 reasons left for having a readahead extent with a
single zone: reada_find_zone(), called when creating a readahead extent,
returned NULL either because we failed to find the corresponding block
group or because a memory allocation failed. With some additional and
custom tracing I figured out that on every further ocurrence of the
problem the block group had just been deleted when we were looping to
create the zones for the readahead extent (at reada_find_extent()), so we
ended up with only one zone in the readahead extent, corresponding to a
device that ends up getting replaced.
So after figuring that out it became obvious why the hang happens:
1) Task A starts a scrub on any device of the filesystem, except for
device /dev/sdd;
2) Task B starts a device replace with /dev/sdd as the source device;
3) Task A calls btrfs_reada_add() from scrub_stripe() and it is currently
starting to scrub a stripe from block group X. This call to
btrfs_reada_add() is the one for the extent tree. When btrfs_reada_add()
calls reada_add_block(), it passes the logical address of the extent
tree's root node as its 'logical' argument - a value of 38928384;
4) Task A then enters reada_find_extent(), called from reada_add_block().
It finds there isn't any existing readahead extent for the logical
address 38928384, so it proceeds to the path of creating a new one.
It calls btrfs_map_block() to find out which stripes exist for the block
group X. On the first iteration of the for loop that iterates over the
stripes, it finds the stripe for device /dev/sdd, so it creates one
zone for that device and adds it to the readahead extent. Before getting
into the second iteration of the loop, the cleanup kthread deletes block
group X because it was empty. So in the iterations for the remaining
stripes it does not add more zones to the readahead extent, because the
calls to reada_find_zone() returned NULL because they couldn't find
block group X anymore.
As a result the new readahead extent has a single zone, corresponding to
the device /dev/sdd;
4) Before task A returns to btrfs_reada_add() and queues the readahead job
for the readahead work queue, task B finishes the device replace and at
btrfs_dev_replace_finishing() swaps the device /dev/sdd with the new
device /dev/sdg;
5) Task A returns to reada_add_block(), which increments the counter
"->elems" of the reada_control structure allocated at btrfs_reada_add().
Then it returns back to btrfs_reada_add() and calls
reada_start_machine(). This queues a job in the readahead work queue to
run the function reada_start_machine_worker(), which calls
__reada_start_machine().
At __reada_start_machine() we take the device list mutex and for each
device found in the current device list, we call
reada_start_machine_dev() to start the readahead work. However at this
point the device /dev/sdd was already freed and is not in the device
list anymore.
This means the corresponding readahead for the extent at 38928384 is
never started, and therefore the "->elems" counter of the reada_control
structure allocated at btrfs_reada_add() never goes down to 0, causing
the call to btrfs_reada_wait(), done by the scrub task, to wait forever.
Note that the readahead request can be made either after the device replace
started or before it started, however in pratice it is very unlikely that a
device replace is able to start after a readahead request is made and is
able to complete before the readahead request completes - maybe only on a
very small and nearly empty filesystem.
This hang however is not the only problem we can have with readahead and
device removals. When the readahead extent has other zones other than the
one corresponding to the device that is being removed (either by a device
replace or a device remove operation), we risk having a use-after-free on
the device when dropping the last reference of the readahead extent.
For example if we create a readahead extent with two zones, one for the
device /dev/sdd and one for the device /dev/sde:
1) Before the readahead worker starts, the device /dev/sdd is removed,
and the corresponding btrfs_device structure is freed. However the
readahead extent still has the zone pointing to the device structure;
2) When the readahead worker starts, it only finds device /dev/sde in the
current device list of the filesystem;
3) It starts the readahead work, at reada_start_machine_dev(), using the
device /dev/sde;
4) Then when it finishes reading the extent from device /dev/sde, it calls
__readahead_hook() which ends up dropping the last reference on the
readahead extent through the last call to reada_extent_put();
5) At reada_extent_put() it iterates over each zone of the readahead extent
and attempts to delete an element from the device's 'reada_extents'
radix tree, resulting in a use-after-free, as the device pointer of the
zone for /dev/sdd is now stale. We can also access the device after
dropping the last reference of a zone, through reada_zone_release(),
also called by reada_extent_put().
And a device remove suffers the same problem, however since it shrinks the
device size down to zero before removing the device, it is very unlikely to
still have readahead requests not completed by the time we free the device,
the only possibility is if the device has a very little space allocated.
While the hang problem is exclusive to scrub, since it is currently the
only user of btrfs_reada_add() and btrfs_reada_wait(), the use-after-free
problem affects any path that triggers readhead, which includes
btree_readahead_hook() and __readahead_hook() (a readahead worker can
trigger readahed for the children of a node) for example - any path that
ends up calling reada_add_block() can trigger the use-after-free after a
device is removed.
So fix this by waiting for any readahead requests for a device to complete
before removing a device, ensuring that while waiting for existing ones no
new ones can be made.
This problem has been around for a very long time - the readahead code was
added in 2011, device remove exists since 2008 and device replace was
introduced in 2013, hard to pick a specific commit for a git Fixes tag.
CC: stable@vger.kernel.org # 4.4+
Reviewed-by: Josef Bacik <josef@toxicpanda.com>
Signed-off-by: Filipe Manana <fdmanana@suse.com>
Reviewed-by: David Sterba <dsterba@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
commit 83bc1560e02e25c6439341352024ebe8488f4fbd upstream.
If we fail to find suitable zones for a new readahead extent, we end up
leaving a stale pointer in the global readahead extents radix tree
(fs_info->reada_tree), which can trigger the following trace later on:
[13367.696354] BUG: kernel NULL pointer dereference, address: 00000000000000b0
[13367.696802] #PF: supervisor read access in kernel mode
[13367.697249] #PF: error_code(0x0000) - not-present page
[13367.697721] PGD 0 P4D 0
[13367.698171] Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC PTI
[13367.698632] CPU: 6 PID: 851214 Comm: btrfs Tainted: G W 5.9.0-rc6-btrfs-next-69 #1
[13367.699100] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.13.0-0-gf21b5a4aeb02-prebuilt.qemu.org 04/01/2014
[13367.700069] RIP: 0010:__lock_acquire+0x20a/0x3970
[13367.700562] Code: ff 1f 0f b7 c0 48 0f (...)
[13367.701609] RSP: 0018:ffffb14448f57790 EFLAGS: 00010046
[13367.702140] RAX: 0000000000000000 RBX: 29b935140c15e8cf RCX: 0000000000000000
[13367.702698] RDX: 0000000000000002 RSI: ffffffffb3d66bd0 RDI: 0000000000000046
[13367.703240] RBP: ffff8a52ba8ac040 R08: 00000c2866ad9288 R09: 0000000000000001
[13367.703783] R10: 0000000000000001 R11: 00000000b66d9b53 R12: ffff8a52ba8ac9b0
[13367.704330] R13: 0000000000000000 R14: ffff8a532b6333e8 R15: 0000000000000000
[13367.704880] FS: 00007fe1df6b5700(0000) GS:ffff8a5376600000(0000) knlGS:0000000000000000
[13367.705438] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[13367.705995] CR2: 00000000000000b0 CR3: 000000022cca8004 CR4: 00000000003706e0
[13367.706565] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[13367.707127] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[13367.707686] Call Trace:
[13367.708246] ? ___slab_alloc+0x395/0x740
[13367.708820] ? reada_add_block+0xae/0xee0 [btrfs]
[13367.709383] lock_acquire+0xb1/0x480
[13367.709955] ? reada_add_block+0xe0/0xee0 [btrfs]
[13367.710537] ? reada_add_block+0xae/0xee0 [btrfs]
[13367.711097] ? rcu_read_lock_sched_held+0x5d/0x90
[13367.711659] ? kmem_cache_alloc_trace+0x8d2/0x990
[13367.712221] ? lock_acquired+0x33b/0x470
[13367.712784] _raw_spin_lock+0x34/0x80
[13367.713356] ? reada_add_block+0xe0/0xee0 [btrfs]
[13367.713966] reada_add_block+0xe0/0xee0 [btrfs]
[13367.714529] ? btrfs_root_node+0x15/0x1f0 [btrfs]
[13367.715077] btrfs_reada_add+0x117/0x170 [btrfs]
[13367.715620] scrub_stripe+0x21e/0x10d0 [btrfs]
[13367.716141] ? kvm_sched_clock_read+0x5/0x10
[13367.716657] ? __lock_acquire+0x41e/0x3970
[13367.717184] ? scrub_chunk+0x60/0x140 [btrfs]
[13367.717697] ? find_held_lock+0x32/0x90
[13367.718254] ? scrub_chunk+0x60/0x140 [btrfs]
[13367.718773] ? lock_acquired+0x33b/0x470
[13367.719278] ? scrub_chunk+0xcd/0x140 [btrfs]
[13367.719786] scrub_chunk+0xcd/0x140 [btrfs]
[13367.720291] scrub_enumerate_chunks+0x270/0x5c0 [btrfs]
[13367.720787] ? finish_wait+0x90/0x90
[13367.721281] btrfs_scrub_dev+0x1ee/0x620 [btrfs]
[13367.721762] ? rcu_read_lock_any_held+0x8e/0xb0
[13367.722235] ? preempt_count_add+0x49/0xa0
[13367.722710] ? __sb_start_write+0x19b/0x290
[13367.723192] btrfs_ioctl+0x7f5/0x36f0 [btrfs]
[13367.723660] ? __fget_files+0x101/0x1d0
[13367.724118] ? find_held_lock+0x32/0x90
[13367.724559] ? __fget_files+0x101/0x1d0
[13367.724982] ? __x64_sys_ioctl+0x83/0xb0
[13367.725399] __x64_sys_ioctl+0x83/0xb0
[13367.725802] do_syscall_64+0x33/0x80
[13367.726188] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[13367.726574] RIP: 0033:0x7fe1df7add87
[13367.726948] Code: 00 00 00 48 8b 05 09 91 (...)
[13367.727763] RSP: 002b:00007fe1df6b4d48 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[13367.728179] RAX: ffffffffffffffda RBX: 000055ce1fb596a0 RCX: 00007fe1df7add87
[13367.728604] RDX: 000055ce1fb596a0 RSI: 00000000c400941b RDI: 0000000000000003
[13367.729021] RBP: 0000000000000000 R08: 00007fe1df6b5700 R09: 0000000000000000
[13367.729431] R10: 00007fe1df6b5700 R11: 0000000000000246 R12: 00007ffd922b07de
[13367.729842] R13: 00007ffd922b07df R14: 00007fe1df6b4e40 R15: 0000000000802000
[13367.730275] Modules linked in: btrfs blake2b_generic xor (...)
[13367.732638] CR2: 00000000000000b0
[13367.733166] ---[ end trace d298b6805556acd9 ]---
What happens is the following:
1) At reada_find_extent() we don't find any existing readahead extent for
the metadata extent starting at logical address X;
2) So we proceed to create a new one. We then call btrfs_map_block() to get
information about which stripes contain extent X;
3) After that we iterate over the stripes and create only one zone for the
readahead extent - only one because reada_find_zone() returned NULL for
all iterations except for one, either because a memory allocation failed
or it couldn't find the block group of the extent (it may have just been
deleted);
4) We then add the new readahead extent to the readahead extents radix
tree at fs_info->reada_tree;
5) Then we iterate over each zone of the new readahead extent, and find
that the device used for that zone no longer exists, because it was
removed or it was the source device of a device replace operation.
Since this left 'have_zone' set to 0, after finishing the loop we jump
to the 'error' label, call kfree() on the new readahead extent and
return without removing it from the radix tree at fs_info->reada_tree;
6) Any future call to reada_find_extent() for the logical address X will
find the stale pointer in the readahead extents radix tree, increment
its reference counter, which can trigger the use-after-free right
away or return it to the caller reada_add_block() that results in the
use-after-free of the example trace above.
So fix this by making sure we delete the readahead extent from the radix
tree if we fail to setup zones for it (when 'have_zone = 0').
Fixes: 319450211842ba ("btrfs: reada: bypass adding extent when all zone failed")
CC: stable@vger.kernel.org # 4.9+
Reviewed-by: Johannes Thumshirn <johannes.thumshirn@wdc.com>
commit 85d07fbe09efd1c529ff3e025e2f0d2c6c96a1b7 upstream.
If there's no parity and num_stripes < ncopies, a crafted image can
trigger a division by zero in calc_stripe_length().
The image was generated through fuzzing.
CC: stable@vger.kernel.org # 5.4+
Reviewed-by: Qu Wenruo <wqu@suse.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=209587
Signed-off-by: Daniel Xu <dxu@dxuuu.xyz>
commit 572c83acdcdafeb04e70aa46be1fa539310be20c upstream.
In fstest btrfs/064 a transaction abort in __btrfs_cow_block could lead
to a system lockup. It gets stuck trying to write back inodes, and the
write back thread was trying to lock an extent buffer:
$ cat /proc/2143497/stack
[<0>] __btrfs_tree_lock+0x108/0x250
[<0>] lock_extent_buffer_for_io+0x35e/0x3a0
[<0>] btree_write_cache_pages+0x15a/0x3b0
[<0>] do_writepages+0x28/0xb0
[<0>] __writeback_single_inode+0x54/0x5c0
[<0>] writeback_sb_inodes+0x1e8/0x510
[<0>] wb_writeback+0xcc/0x440
[<0>] wb_workfn+0xd7/0x650
[<0>] process_one_work+0x236/0x560
[<0>] worker_thread+0x55/0x3c0
[<0>] kthread+0x13a/0x150
[<0>] ret_from_fork+0x1f/0x30
This is because we got an error while COWing a block, specifically here
if (test_bit(BTRFS_ROOT_SHAREABLE, &root->state)) {
ret = btrfs_reloc_cow_block(trans, root, buf, cow);
if (ret) {
btrfs_abort_transaction(trans, ret);
return ret;
[16402.241552] BTRFS: Transaction aborted (error -2)
[16402.242362] WARNING: CPU: 1 PID: 2563188 at fs/btrfs/ctree.c:1074 __btrfs_cow_block+0x376/0x540
[16402.249469] CPU: 1 PID: 2563188 Comm: fsstress Not tainted 5.9.0-rc6+ #8
[16402.249936] Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS 1.13.0-2.fc32 04/01/2014
[16402.250525] RIP: 0010:__btrfs_cow_block+0x376/0x540
[16402.252417] RSP: 0018:ffff9cca40e578b0 EFLAGS: 00010282
[16402.252787] RAX: 0000000000000025 RBX: 0000000000000002 RCX: ffff9132bbd19388
[16402.253278] RDX: 00000000ffffffd8 RSI: 0000000000000027 RDI: ffff9132bbd19380
[16402.254063] RBP: ffff9132b41a49c0 R08: 0000000000000000 R09: 0000000000000000
[16402.254887] R10: 0000000000000000 R11: ffff91324758b080 R12: ffff91326ef17ce0
[16402.255694] R13: ffff91325fc0f000 R14: ffff91326ef176b0 R15: ffff9132815e2000
[16402.256321] FS: 00007f542c6d7b80(0000) GS:ffff9132bbd00000(0000) knlGS:0000000000000000
[16402.256973] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[16402.257374] CR2: 00007f127b83f250 CR3: 0000000133480002 CR4: 0000000000370ee0
[16402.257867] Call Trace:
[16402.258072] btrfs_cow_block+0x109/0x230
[16402.258356] btrfs_search_slot+0x530/0x9d0
[16402.258655] btrfs_lookup_file_extent+0x37/0x40
[16402.259155] __btrfs_drop_extents+0x13c/0xd60
[16402.259628] ? btrfs_block_rsv_migrate+0x4f/0xb0
[16402.259949] btrfs_replace_file_extents+0x190/0x820
[16402.260873] btrfs_clone+0x9ae/0xc00
[16402.261139] btrfs_extent_same_range+0x66/0x90
[16402.261771] btrfs_remap_file_range+0x353/0x3b1
[16402.262333] vfs_dedupe_file_range_one.part.0+0xd5/0x140
[16402.262821] vfs_dedupe_file_range+0x189/0x220
[16402.263150] do_vfs_ioctl+0x552/0x700
[16402.263662] __x64_sys_ioctl+0x62/0xb0
[16402.264023] do_syscall_64+0x33/0x40
[16402.264364] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[16402.264862] RIP: 0033:0x7f542c7d15cb
[16402.266901] RSP: 002b:00007ffd35944ea8 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[16402.267627] RAX: ffffffffffffffda RBX: 00000000009d1968 RCX: 00007f542c7d15cb
[16402.268298] RDX: 00000000009d2490 RSI: 00000000c0189436 RDI: 0000000000000003
[16402.268958] RBP: 00000000009d2520 R08: 0000000000000036 R09: 00000000009d2e64
[16402.269726] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000002
[16402.270659] R13: 000000000001f000 R14: 00000000009d1970 R15: 00000000009d2e80
[16402.271498] irq event stamp: 0
[16402.271846] hardirqs last enabled at (0): [<0000000000000000>] 0x0
[16402.272497] hardirqs last disabled at (0): [<ffffffff910dbf59>] copy_process+0x6b9/0x1ba0
[16402.273343] softirqs last enabled at (0): [<ffffffff910dbf59>] copy_process+0x6b9/0x1ba0
[16402.273905] softirqs last disabled at (0): [<0000000000000000>] 0x0
[16402.274338] ---[ end trace 737874a5a41a8236 ]---
[16402.274669] BTRFS: error (device dm-9) in __btrfs_cow_block:1074: errno=-2 No such entry
[16402.276179] BTRFS info (device dm-9): forced readonly
[16402.277046] BTRFS: error (device dm-9) in btrfs_replace_file_extents:2723: errno=-2 No such entry
[16402.278744] BTRFS: error (device dm-9) in __btrfs_cow_block:1074: errno=-2 No such entry
[16402.279968] BTRFS: error (device dm-9) in __btrfs_cow_block:1074: errno=-2 No such entry
[16402.280582] BTRFS info (device dm-9): balance: ended with status: -30
The problem here is that as soon as we allocate the new block it is
locked and marked dirty in the btree inode. This means that we could
attempt to writeback this block and need to lock the extent buffer.
However we're not unlocking it here and thus we deadlock.
Fix this by unlocking the cow block if we have any errors inside of
__btrfs_cow_block, and also free it so we do not leak it.
Reviewed-by: Filipe Manana <fdmanana@suse.com>
Signed-off-by: Josef Bacik <josef@toxicpanda.com>
commit 1465af12e254a68706e110846f59cf0f09683184 upstream.
Commit 259ee7754b67 ("btrfs: tree-checker: Add ROOT_ITEM check")
introduced btrfs root item size check, however btrfs root item has two
versions, the legacy one which just ends before generation_v2 member, is
smaller than current btrfs root item size.
This caused btrfs kernel to reject valid but old tree root leaves.
Fix this problem by also allowing legacy root item, since kernel can
already handle them pretty well and upgrade to newer root item format
when needed.
Reported-by: Martin Steigerwald <martin@lichtvoll.de>
Fixes: 259ee7754b67 ("btrfs: tree-checker: Add ROOT_ITEM check")
Tested-By: Martin Steigerwald <martin@lichtvoll.de>
Signed-off-by: Qu Wenruo <wqu@suse.com>
commit 8eb2fd00153a3a96a19c62ac9c6d48c2efebe5e8 upstream.
btrfs_ioctl_send() used open-coded kvzalloc implementation earlier.
The code was accidentally replaced with kzalloc() call [1]. Restore
the original code by using kvzalloc() to allocate sctx->clone_roots.
[1] https://patchwork.kernel.org/patch/9757891/#20529627
Fixes: 818e010bf9d0 ("btrfs: replace opencoded kvzalloc with the helper")
CC: stable@vger.kernel.org # 4.14+
Signed-off-by: Denis Efremov <efremov@linux.com>
commit 9c2b4e0347067396ceb3ae929d6888c81d610259 upstream.
During an incremental send, when an inode has multiple new references we
might end up emitting rename operations for orphanizations that have a
source path that is no longer valid due to a previous orphanization of
some directory inode. This causes the receiver to fail since it tries
to rename a path that does not exists.
Example reproducer:
$ cat reproducer.sh
#!/bin/bash
mkfs.btrfs -f /dev/sdi >/dev/null
mount /dev/sdi /mnt/sdi
touch /mnt/sdi/f1
touch /mnt/sdi/f2
mkdir /mnt/sdi/d1
mkdir /mnt/sdi/d1/d2
# Filesystem looks like:
# . (ino 256)
# |----- f1 (ino 257)
# |----- f2 (ino 258)
# |----- d1/ (ino 259)
# |----- d2/ (ino 260)
btrfs subvolume snapshot -r /mnt/sdi /mnt/sdi/snap1
btrfs send -f /tmp/snap1.send /mnt/sdi/snap1
# Now do a series of changes such that:
# *) inode 258 has one new hardlink and the previous name changed
# *) both names conflict with the old names of two other inodes:
# 1) the new name "d1" conflicts with the old name of inode 259,
# under directory inode 256 (root)
# 2) the new name "d2" conflicts with the old name of inode 260
# under directory inode 259
# *) inodes 259 and 260 now have the old names of inode 258
# *) inode 257 is now located under inode 260 - an inode with a number
# smaller than the inode (258) for which we created a second hard
# link and swapped its names with inodes 259 and 260
ln /mnt/sdi/f2 /mnt/sdi/d1/f2_link
mv /mnt/sdi/f1 /mnt/sdi/d1/d2/f1
# Swap d1 and f2.
mv /mnt/sdi/d1 /mnt/sdi/tmp
mv /mnt/sdi/f2 /mnt/sdi/d1
mv /mnt/sdi/tmp /mnt/sdi/f2
# Swap d2 and f2_link
mv /mnt/sdi/f2/d2 /mnt/sdi/tmp
mv /mnt/sdi/f2/f2_link /mnt/sdi/f2/d2
mv /mnt/sdi/tmp /mnt/sdi/f2/f2_link
# Filesystem now looks like:
# . (ino 256)
# |----- d1 (ino 258)
# |----- f2/ (ino 259)
# |----- f2_link/ (ino 260)
# | |----- f1 (ino 257)
# |----- d2 (ino 258)
btrfs subvolume snapshot -r /mnt/sdi /mnt/sdi/snap2
btrfs send -f /tmp/snap2.send -p /mnt/sdi/snap1 /mnt/sdi/snap2
mkfs.btrfs -f /dev/sdj >/dev/null
mount /dev/sdj /mnt/sdj
btrfs receive -f /tmp/snap1.send /mnt/sdj
btrfs receive -f /tmp/snap2.send /mnt/sdj
umount /mnt/sdi
umount /mnt/sdj
When executed the receive of the incremental stream fails:
$ ./reproducer.sh
Create a readonly snapshot of '/mnt/sdi' in '/mnt/sdi/snap1'
At subvol /mnt/sdi/snap1
Create a readonly snapshot of '/mnt/sdi' in '/mnt/sdi/snap2'
At subvol /mnt/sdi/snap2
At subvol snap1
At snapshot snap2
ERROR: rename d1/d2 -> o260-6-0 failed: No such file or directory
This happens because:
1) When processing inode 257 we end up computing the name for inode 259
because it is an ancestor in the send snapshot, and at that point it
still has its old name, "d1", from the parent snapshot because inode
259 was not yet processed. We then cache that name, which is valid
until we start processing inode 259 (or set the progress to 260 after
processing its references);
2) Later we start processing inode 258 and collecting all its new
references into the list sctx->new_refs. The first reference in the
list happens to be the reference for name "d1" while the reference for
name "d2" is next (the last element of the list).
We compute the full path "d1/d2" for this second reference and store
it in the reference (its ->full_path member). The path used for the
new parent directory was "d1" and not "f2" because inode 259, the
new parent, was not yet processed;
3) When we start processing the new references at process_recorded_refs()
we start with the first reference in the list, for the new name "d1".
Because there is a conflicting inode that was not yet processed, which
is directory inode 259, we orphanize it, renaming it from "d1" to
"o259-6-0";
4) Then we start processing the new reference for name "d2", and we
realize it conflicts with the reference of inode 260 in the parent
snapshot. So we issue an orphanization operation for inode 260 by
emitting a rename operation with a destination path of "o260-6-0"
and a source path of "d1/d2" - this source path is the value we
stored in the reference earlier at step 2), corresponding to the
->full_path member of the reference, however that path is no longer
valid due to the orphanization of the directory inode 259 in step 3).
This makes the receiver fail since the path does not exists, it should
have been "o259-6-0/d2".
Fix this by recomputing the full path of a reference before emitting an
orphanization if we previously orphanized any directory, since that
directory could be a parent in the new path. This is a rare scenario so
keeping it simple and not checking if that previously orphanized directory
is in fact an ancestor of the inode we are trying to orphanize.
A test case for fstests follows soon.
commit 98272bb77bf4cc20ed1ffca89832d713e70ebf09 upstream.
When doing an incremental send it is possible that when processing the new
references for an inode we end up issuing rename or link operations that
have an invalid path, which contains the orphanized name of a directory
before we actually orphanized it, causing the receiver to fail.
The following reproducer triggers such scenario:
$ cat reproducer.sh
#!/bin/bash
touch /mnt/sdi/a
touch /mnt/sdi/b
mkdir /mnt/sdi/testdir
# We want "a" to have a lower inode number then "testdir" (257 vs 259).
mv /mnt/sdi/a /mnt/sdi/testdir/a
# . (ino 256)
# |----- testdir/ (ino 259)
# | |----- a (ino 257)
# |----- b (ino 258)
# Now rename 259 to "testdir_2", then change the name of 257 to
# "testdir" and make it a direct descendant of the root inode (256).
# Also create a new link for inode 257 with the old name of inode 258.
# By swapping the names and location of several inodes and create a
# nasty dependency chain of rename and link operations.
mv /mnt/sdi/testdir/a /mnt/sdi/a2
touch /mnt/sdi/testdir/a
mv /mnt/sdi/b /mnt/sdi/b2
ln /mnt/sdi/a2 /mnt/sdi/b
mv /mnt/sdi/testdir /mnt/sdi/testdir_2
mv /mnt/sdi/a2 /mnt/sdi/testdir
# . (ino 256)
# |----- testdir_2/ (ino 259)
# | |----- a (ino 260)
# |----- testdir (ino 257)
# |----- b (ino 257)
# |----- b2 (ino 258)
umount /mnt/sdi
umount /mnt/sdj
When running the reproducer, the receive of the incremental send stream
fails:
$ ./reproducer.sh
At subvol snap1
At snapshot snap2
ERROR: link b -> o259-6-0/a failed: No such file or directory
The problem happens because of the following:
1) Before we start iterating the list of new references for inode 257,
we generate its current path and store it at @valid_path, done at
the very beginning of process_recorded_refs(). The generated path
is "o259-6-0/a", containing the orphanized name for inode 259;
2) Then we iterate over the list of new references, which has the
references "b" and "testdir" in that specific order;
3) We process reference "b" first, because it is in the list before
reference "testdir". We then issue a link operation to create
the new reference "b" using a target path corresponding to the
content at @valid_path, which corresponds to "o259-6-0/a".
However we haven't yet orphanized inode 259, its name is still
"testdir", and not "o259-6-0". The orphanization of 259 did not
happen yet because we will process the reference named "testdir"
for inode 257 only in the next iteration of the loop that goes
over the list of new references.
Fix the issue by having a preliminar iteration over all the new references
at process_recorded_refs(). This iteration is responsible only for doing
the orphanization of other inodes that have and old reference that
conflicts with one of the new references of the inode we are currently
processing. The emission of rename and link operations happen now in the
next iteration of the new references.
A test case for fstests will follow soon.
commit bb56f02f26fe23798edb1b2175707419b28c752a upstream.
Logging directories with many entries can take a significant amount of
time, and in some cases monopolize a cpu/core for a long time if the
logging task doesn't happen to block often enough.
Johannes and Lu Fengqi reported test case generic/041 triggering a soft
lockup when the kernel has CONFIG_SOFTLOCKUP_DETECTOR=y. For this test
case we log an inode with 3002 hard links, and because the test removed
one hard link before fsyncing the file, the inode logging causes the
parent directory do be logged as well, which has 6004 directory items to
log (3002 BTRFS_DIR_ITEM_KEY items plus 3002 BTRFS_DIR_INDEX_KEY items),
so it can take a significant amount of time and trigger the soft lockup.
So just make tree-log.c:log_dir_items() reschedule when necessary,
releasing the current search path before doing so and then resume from
where it was before the reschedule.
The stack trace produced when the soft lockup happens is the following:
[10480.277653] watchdog: BUG: soft lockup - CPU#2 stuck for 22s! [xfs_io:28172]
[10480.279418] Modules linked in: dm_thin_pool dm_persistent_data (...)
[10480.284915] irq event stamp: 29646366
[10480.285987] hardirqs last enabled at (29646365): [<ffffffff85249b66>] __slab_alloc.constprop.0+0x56/0x60
[10480.288482] hardirqs last disabled at (29646366): [<ffffffff8579b00d>] irqentry_enter+0x1d/0x50
[10480.290856] softirqs last enabled at (4612): [<ffffffff85a00323>] __do_softirq+0x323/0x56c
[10480.293615] softirqs last disabled at (4483): [<ffffffff85800dbf>] asm_call_on_stack+0xf/0x20
[10480.296428] CPU: 2 PID: 28172 Comm: xfs_io Not tainted 5.9.0-rc4-default+ #1248
[10480.298948] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.12.0-59-gc9ba527-rebuilt.opensuse.org 04/01/2014
[10480.302455] RIP: 0010:__slab_alloc.constprop.0+0x19/0x60
[10480.304151] Code: 86 e8 31 75 21 00 66 66 2e 0f 1f 84 00 00 00 (...)
[10480.309558] RSP: 0018:ffffadbe09397a58 EFLAGS: 00000282
[10480.311179] RAX: ffff8a495ab92840 RBX: 0000000000000282 RCX: 0000000000000006
[10480.313242] RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffffffff85249b66
[10480.315260] RBP: ffff8a497d04b740 R08: 0000000000000001 R09: 0000000000000001
[10480.317229] R10: ffff8a497d044800 R11: ffff8a495ab93c40 R12: 0000000000000000
[10480.319169] R13: 0000000000000000 R14: 0000000000000c40 R15: ffffffffc01daf70
[10480.321104] FS: 00007fa1dc5c0e40(0000) GS:ffff8a497da00000(0000) knlGS:0000000000000000
[10480.323559] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[10480.325235] CR2: 00007fa1dc5befb8 CR3: 0000000004f8a006 CR4: 0000000000170ea0
[10480.327259] Call Trace:
[10480.328286] ? overwrite_item+0x1f0/0x5a0 [btrfs]
[10480.329784] __kmalloc+0x831/0xa20
[10480.331009] ? btrfs_get_32+0xb0/0x1d0 [btrfs]
[10480.332464] overwrite_item+0x1f0/0x5a0 [btrfs]
[10480.333948] log_dir_items+0x2ee/0x570 [btrfs]
[10480.335413] log_directory_changes+0x82/0xd0 [btrfs]
[10480.336926] btrfs_log_inode+0xc9b/0xda0 [btrfs]
[10480.338374] ? init_once+0x20/0x20 [btrfs]
[10480.339711] btrfs_log_inode_parent+0x8d3/0xd10 [btrfs]
[10480.341257] ? dget_parent+0x97/0x2e0
[10480.342480] btrfs_log_dentry_safe+0x3a/0x50 [btrfs]
[10480.343977] btrfs_sync_file+0x24b/0x5e0 [btrfs]
[10480.345381] do_fsync+0x38/0x70
[10480.346483] __x64_sys_fsync+0x10/0x20
[10480.347703] do_syscall_64+0x2d/0x70
[10480.348891] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[10480.350444] RIP: 0033:0x7fa1dc80970b
[10480.351642] Code: 0f 05 48 3d 00 f0 ff ff 77 45 c3 0f 1f 40 00 48 (...)
[10480.356952] RSP: 002b:00007fffb3d081d0 EFLAGS: 00000293 ORIG_RAX: 000000000000004a
[10480.359458] RAX: ffffffffffffffda RBX: 0000562d93d45e40 RCX: 00007fa1dc80970b
[10480.361426] RDX: 0000562d93d44ab0 RSI: 0000562d93d45e60 RDI: 0000000000000003
[10480.363367] RBP: 0000000000000001 R08: 0000000000000000 R09: 00007fa1dc7b2a40
[10480.365317] R10: 0000562d93d0e366 R11: 0000000000000293 R12: 0000000000000001
[10480.367299] R13: 0000562d93d45290 R14: 0000562d93d45e40 R15: 0000562d93d45e60
Link: https://lore.kernel.org/linux-btrfs/20180713090216.GC575@fnst.localdomain/
Reported-by: Johannes Thumshirn <johannes.thumshirn@wdc.com>
Tested-by: Johannes Thumshirn <johannes.thumshirn@wdc.com>
commit 79dae17d8d44b2d15779e332180080af45df5352 upstream.
Systems booting without the initramfs seems to scan an unusual kind
of device path (/dev/root). And at a later time, the device is updated
to the correct path. We generally print the process name and PID of the
process scanning the device but we don't capture the same information if
the device path is rescanned with a different pathname.
The current message is too long, so drop the unnecessary UUID and add
process name and PID.
While at this also update the duplicate device warning to include the
process name and PID so the messages are consistent
CC: stable@vger.kernel.org # 4.19+
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=89721
Signed-off-by: Anand Jain <anand.jain@oracle.com>
commit b4c5d8fdfff3e2b6c4fa4a5043e8946dff500f8c upstream.
For delayed inode facility, qgroup metadata is reserved for it, and
later freed.
However we're freeing more bytes than we reserved.
In btrfs_delayed_inode_reserve_metadata():
num_bytes = btrfs_calc_metadata_size(fs_info, 1);
ret = btrfs_qgroup_reserve_meta_prealloc(root,
fs_info->nodesize, true);
if (!ret) {
node->bytes_reserved = num_bytes;
But in btrfs_delayed_inode_release_metadata():
if (qgroup_free)
btrfs_qgroup_free_meta_prealloc(node->root,
node->bytes_reserved);
else
btrfs_qgroup_convert_reserved_meta(node->root,
This means, we're always releasing more qgroup metadata rsv than we have
reserved.
This won't trigger selftest warning, as btrfs qgroup metadata rsv has
extra protection against cases like quota enabled half-way.
But we still need to fix this problem any way.
This patch will use the same num_bytes for qgroup metadata rsv so we
could handle it correctly.
Fixes: f218ea6c4792 ("btrfs: delayed-inode: Remove wrong qgroup meta reservation calls")
commit 247db73560bc3e5aef6db50c443c3c0db115bc93 upstream.
We are generating incorrect path in case of rename retry because
we are restarting from wrong dentry. We should restart from the
dentry which was received in the call to nfs_path.
Signed-off-by: Ashish Sangwan <ashishsangwan2@gmail.com>
commit 6dbf7bb555981fb5faf7b691e8f6169fc2b2e63b upstream.
If block_write_full_page() is called for a page that is beyond current
inode size, it will truncate page buffers for the page and return 0.
This logic has been added in 2.5.62 in commit 81eb69062588 ("fix ext3
BUG due to race with truncate") in history.git tree to fix a problem
with ext3 in data=ordered mode. This particular problem doesn't exist
anymore because ext3 is long gone and ext4 handles ordered data
differently. Also normally buffers are invalidated by truncate code and
there's no need to specially handle this in ->writepage() code.
This invalidation of page buffers in block_write_full_page() is causing
issues to filesystems (e.g. ext4 or ocfs2) when block device is shrunk
under filesystem's hands and metadata buffers get discarded while being
tracked by the journalling layer. Although it is obviously "not
supported" it can cause kernel crashes like:
[ 7986.689400] BUG: unable to handle kernel NULL pointer dereference at
+0000000000000008
[ 7986.697197] PGD 0 P4D 0
[ 7986.699724] Oops: 0002 [#1] SMP PTI
[ 7986.703200] CPU: 4 PID: 203778 Comm: jbd2/dm-3-8 Kdump: loaded Tainted: G
+O --------- - - 4.18.0-147.5.0.5.h126.eulerosv2r9.x86_64 #1
[ 7986.716438] Hardware name: Huawei RH2288H V3/BC11HGSA0, BIOS 1.57 08/11/2015
[ 7986.723462] RIP: 0010:jbd2_journal_grab_journal_head+0x1b/0x40 [jbd2]
[ 7986.810150] Call Trace:
[ 7986.812595] __jbd2_journal_insert_checkpoint+0x23/0x70 [jbd2]
[ 7986.818408] jbd2_journal_commit_transaction+0x155f/0x1b60 [jbd2]
[ 7986.836467] kjournald2+0xbd/0x270 [jbd2]
which is not great. The crash happens because bh->b_private is suddently
NULL although BH_JBD flag is still set (this is because
block_invalidatepage() cleared BH_Mapped flag and subsequent bh lookup
found buffer without BH_Mapped set, called init_page_buffers() which has
rewritten bh->b_private). So just remove the invalidation in
block_write_full_page().
Note that the buffer cache invalidation when block device changes size
is already careful to avoid similar problems by using
invalidate_mapping_pages() which skips busy buffers so it was only this
odd block_write_full_page() behavior that could tear down bdev buffers
under filesystem's hands.
Reported-by: Ye Bin <yebin10@huawei.com>
[ Upstream commit c6cc4c5a72505a0ecefc9b413f16bec512f38078 ]
RHBZ: 1848178
Some calls that set attributes, like utimensat(), are not supposed to return
-EINTR and thus do not have handlers for this in glibc which causes us
to leak -EINTR to the applications which are also unprepared to handle it.
For example tar will break if utimensat() return -EINTR and abort unpacking
the archive. Other applications may break too.
To handle this we add checks, and retry, for -EINTR in cifs_setattr()
Signed-off-by: Ronnie Sahlberg <lsahlber@redhat.com>
Signed-off-by: Steve French <stfrench@microsoft.com>
[ Upstream commit 0ddc5154b24c96f20e94d653b0a814438de6032b ]
In gfs2_check_sb(), no validation checks are performed with regards to
the size of the superblock.
syzkaller detected a slab-out-of-bounds bug that was primarily caused
because the block size for a superblock was set to zero.
A valid size for a superblock is a power of 2 between 512 and PAGE_SIZE.
Performing validation checks and ensuring that the size of the superblock
is valid fixes this bug.
Reported-by: syzbot+af90d47a37376844e731@syzkaller.appspotmail.com
Tested-by: syzbot+af90d47a37376844e731@syzkaller.appspotmail.com
Suggested-by: Andrew Price <anprice@redhat.com>
Signed-off-by: Anant Thazhemadam <anant.thazhemadam@gmail.com>
[Minor code reordering.]
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
[ Upstream commit c2a04b02c060c4858762edce4674d5cba3e5a96f ]
syzkaller found the following splat with CONFIG_DEBUG_KOBJECT_RELEASE=y:
Read of size 1 at addr ffff000028e896b8 by task kworker/1:2/228
CPU: 1 PID: 228 Comm: kworker/1:2 Tainted: G S 5.9.0-rc8+ #101
Hardware name: linux,dummy-virt (DT)
Workqueue: events kobject_delayed_cleanup
Call trace:
dump_backtrace+0x0/0x4d8
show_stack+0x34/0x48
dump_stack+0x174/0x1f8
print_address_description.constprop.0+0x5c/0x550
kasan_report+0x13c/0x1c0
__asan_report_load1_noabort+0x34/0x60
memcmp+0xd0/0xd8
gfs2_uevent+0xc4/0x188
kobject_uevent_env+0x54c/0x1240
kobject_uevent+0x2c/0x40
__kobject_del+0x190/0x1d8
kobject_delayed_cleanup+0x2bc/0x3b8
process_one_work+0x96c/0x18c0
worker_thread+0x3f0/0xc30
kthread+0x390/0x498
ret_from_fork+0x10/0x18
Allocated by task 1110:
kasan_save_stack+0x28/0x58
__kasan_kmalloc.isra.0+0xc8/0xe8
kasan_kmalloc+0x10/0x20
kmem_cache_alloc_trace+0x1d8/0x2f0
alloc_super+0x64/0x8c0
sget_fc+0x110/0x620
get_tree_bdev+0x190/0x648
gfs2_get_tree+0x50/0x228
vfs_get_tree+0x84/0x2e8
path_mount+0x1134/0x1da8
do_mount+0x124/0x138
__arm64_sys_mount+0x164/0x238
el0_svc_common.constprop.0+0x15c/0x598
do_el0_svc+0x60/0x150
el0_svc+0x34/0xb0
el0_sync_handler+0xc8/0x5b4
el0_sync+0x15c/0x180
Freed by task 228:
kasan_set_track+0x28/0x40
kasan_set_free_info+0x24/0x48
__kasan_slab_free+0x118/0x190
kasan_slab_free+0x14/0x20
slab_free_freelist_hook+0x6c/0x210
kfree+0x13c/0x460
Use the same pattern as f2fs + ext4 where the kobject destruction must
complete before allowing the FS itself to be freed. This means that we
need an explicit free_sbd in the callers.
Cc: Bob Peterson <rpeterso@redhat.com>
Cc: Andreas Gruenbacher <agruenba@redhat.com>
Signed-off-by: Jamie Iles <jamie@nuviainc.com>
[Also go to fail_free when init_names fails.]
[ Upstream commit e0770e91424f694b461141cbc99adf6b23006b60 ]
When we try to use file already used as a quota file again (for the same
or different quota type), strange things can happen. At the very least
lockdep annotations may be wrong but also inode flags may be wrongly set
/ reset. When the file is used for two quota types at once we can even
corrupt the file and likely crash the kernel. Catch all these cases by
checking whether passed file is already used as quota file and bail
early in that case.
This fixes occasional generic/219 failure due to lockdep complaint.
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
Reported-by: Ritesh Harjani <riteshh@linux.ibm.com>
Link: https://lore.kernel.org/r/20201015110330.28716-1-jack@suse.cz
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
[ Upstream commit c6a5d954950c5031444173ad2195efc163afcac9 ]
If you replace a seed device in a sprouted fs, it appears to have
successfully replaced the seed device, but if you look closely, it
didn't. Here is an example.
$ mkfs.btrfs /dev/sda
$ btrfstune -S1 /dev/sda
$ mount /dev/sda /btrfs
$ btrfs device add /dev/sdb /btrfs
$ umount /btrfs
$ btrfs device scan --forget
$ mount -o device=/dev/sda /dev/sdb /btrfs
$ btrfs replace start -f /dev/sda /dev/sdc /btrfs
$ echo $?
0
BTRFS info (device sdb): dev_replace from /dev/sda (devid 1) to /dev/sdc started
BTRFS info (device sdb): dev_replace from /dev/sda (devid 1) to /dev/sdc finished
$ btrfs fi show
Label: none uuid: ab2c88b7-be81-4a7e-9849-c3666e7f9f4f
Total devices 2 FS bytes used 256.00KiB
devid 1 size 3.00GiB used 520.00MiB path /dev/sdc
devid 2 size 3.00GiB used 896.00MiB path /dev/sdb
Label: none uuid: 10bd3202-0415-43af-96a8-d5409f310a7e
Total devices 1 FS bytes used 128.00KiB
devid 1 size 3.00GiB used 536.00MiB path /dev/sda
So as per the replace start command and kernel log replace was successful.
Now let's try to clean mount.
$ umount /btrfs
$ mount -o device=/dev/sdc /dev/sdb /btrfs
mount: /btrfs: wrong fs type, bad option, bad superblock on /dev/sdb, missing codepage or helper program, or other error.
[ 636.157517] BTRFS error (device sdc): failed to read chunk tree: -2
[ 636.180177] BTRFS error (device sdc): open_ctree failed
That's because per dev items it is still looking for the original seed
device.
$ btrfs inspect-internal dump-tree -d /dev/sdb
item 0 key (DEV_ITEMS DEV_ITEM 1) itemoff 16185 itemsize 98
devid 1 total_bytes 3221225472 bytes_used 545259520
io_align 4096 io_width 4096 sector_size 4096 type 0
generation 6 start_offset 0 dev_group 0
seek_speed 0 bandwidth 0
uuid 59368f50-9af2-4b17-91da-8a783cc418d4 <--- seed uuid
fsid 10bd3202-0415-43af-96a8-d5409f310a7e <--- seed fsid
item 1 key (DEV_ITEMS DEV_ITEM 2) itemoff 16087 itemsize 98
devid 2 total_bytes 3221225472 bytes_used 939524096
generation 0 start_offset 0 dev_group 0
uuid 56a0a6bc-4630-4998-8daf-3c3030c4256a <- sprout uuid
fsid ab2c88b7-be81-4a7e-9849-c3666e7f9f4f <- sprout fsid
But the replaced target has the following uuid+fsid in its superblock
which doesn't match with the expected uuid+fsid in its devitem.
$ btrfs in dump-super /dev/sdc | egrep '^generation|dev_item.uuid|dev_item.fsid|devid'
generation 20
dev_item.uuid 59368f50-9af2-4b17-91da-8a783cc418d4
dev_item.fsid ab2c88b7-be81-4a7e-9849-c3666e7f9f4f [match]
dev_item.devid 1
So if you provide the original seed device the mount shall be
successful. Which so long happening in the test case btrfs/163.
Fix in this patch:
If a seed is not sprouted then there is no replacement of it, because of
its read-only filesystem with a read-only device. Similarly, in the case
of a sprouted filesystem, the seed device is still read only. So, mark
it as you can't replace a seed device, you can only add a new device and
then delete the seed device. If replace is attempted then returns
-EINVAL.
[ Upstream commit 8df0fa39bdd86ca81a8d706a6ed9d33cc65ca625 ]
When callers pass XFS_BMAPI_REMAP into xfs_bunmapi, they want the extent
to be unmapped from the given file fork without the extent being freed.
We do this for non-rt files, but we forgot to do this for realtime
files. So far this isn't a big deal since nobody makes a bunmapi call
to a rt file with the REMAP flag set, but don't leave a logic bomb.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
[ Upstream commit f4c32e87de7d66074d5612567c5eac7325024428 ]
The realtime bitmap and summary files are regular files that are hidden
away from the directory tree. Since they're regular files, inode
inactivation will try to purge what it thinks are speculative
preallocations beyond the incore size of the file. Unfortunately,
xfs_growfs_rt forgets to update the incore size when it resizes the
inodes, with the result that inactivating the rt inodes at unmount time
will cause their contents to be truncated.
Fix this by updating the incore size when we change the ondisk size as
part of updating the superblock. Note that we don't do this when we're
allocating blocks to the rt inodes because we actually want those blocks
to get purged if the growfs fails.
This fixes corruption complaints from the online rtsummary checker when
running xfs/233. Since that test requires rmap, one can also trigger
this by growing an rt volume, cycling the mount, and creating rt files.
Reviewed-by: Chandan Babu R <chandanrlinux@gmail.com>
[ Upstream commit d8a6ad913c286d4763ae20b14c02fe6f39d7cd9f ]
The following oops is seen during xfstest/565 when the 'test'
(source of the copy) is NFS4.0 and 'scratch' (destination) is NFS4.2
[ 59.692458] run fstests generic/565 at 2020-08-01 05:50:35
[ 60.613588] BUG: kernel NULL pointer dereference, address: 0000000000000008
[ 60.624970] #PF: supervisor read access in kernel mode
[ 60.627671] #PF: error_code(0x0000) - not-present page
[ 60.630347] PGD 0 P4D 0
[ 60.631853] Oops: 0000 [#1] SMP PTI
[ 60.634086] CPU: 6 PID: 2828 Comm: xfs_io Kdump: loaded Not tainted 5.8.0-rc3 #1
[ 60.637676] Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2011
[ 60.639901] RIP: 0010:nfs4_check_serverowner_major_id+0x5/0x30 [nfsv4]
[ 60.642719] Code: 89 ff e8 3e b3 b8 e1 e9 71 fe ff ff 41 bc da d8 ff ff e9 c3 fe ff ff e8 e9 9d 08 e2 66 0f 1f 84 00 00 00 00 00 66 66 66 66 90 <8b> 57 08 31 c0 3b 56 08 75 12 48 83 c6 0c 48 83 c7 0c e8 c4 97 bb
[ 60.652629] RSP: 0018:ffffc265417f7e10 EFLAGS: 00010287
[ 60.655379] RAX: ffffa0664b066400 RBX: 0000000000000000 RCX: 0000000000000001
[ 60.658754] RDX: ffffa066725fb000 RSI: ffffa066725fd000 RDI: 0000000000000000
[ 60.662292] RBP: 0000000000020000 R08: 0000000000020000 R09: 0000000000000000
[ 60.666189] R10: 0000000000000003 R11: 0000000000000000 R12: ffffa06648258d00
[ 60.669914] R13: 0000000000000000 R14: 0000000000000000 R15: ffffa06648258100
[ 60.673645] FS: 00007faa9fb35800(0000) GS:ffffa06677d80000(0000) knlGS:0000000000000000
[ 60.677698] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 60.680773] CR2: 0000000000000008 CR3: 0000000203f14000 CR4: 00000000000406e0
[ 60.684476] Call Trace:
[ 60.685809] nfs4_copy_file_range+0xfc/0x230 [nfsv4]
[ 60.688704] vfs_copy_file_range+0x2ee/0x310
[ 60.691104] __x64_sys_copy_file_range+0xd6/0x210
[ 60.693527] do_syscall_64+0x4d/0x90
[ 60.695512] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 60.698006] RIP: 0033:0x7faa9febc1bd
Signed-off-by: Dave Wysochanski <dwysocha@redhat.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
[ Upstream commit 86f33603f8c51537265ff7ac0320638fd2cbdb1b ]
First problem is we hit BUG_ON() in f2fs_get_sum_page given EIO on
f2fs_get_meta_page_nofail().
Quick fix was not to give any error with infinite loop, but syzbot caught
a case where it goes to that loop from fuzzed image. In turned out we abused
f2fs_get_meta_page_nofail() like in the below call stack.
- f2fs_fill_super
- f2fs_build_segment_manager
- build_sit_entries
- get_current_sit_page
INFO: task syz-executor178:6870 can't die for more than 143 seconds.
task:syz-executor178 state:R
stack:26960 pid: 6870 ppid: 6869 flags:0x00004006
Call Trace:
1 lock held by khungtaskd/1179:
#0: ffffffff8a554da0 (rcu_read_lock){....}-{1:2}, at: debug_show_all_locks+0x53/0x260 kernel/locking/lockdep.c:6242
1 lock held by systemd-journal/3920:
1 lock held by in:imklog/6769:
#0: ffff88809eebc130 (&f->f_pos_lock){+.+.}-{3:3}, at: __fdget_pos+0xe9/0x100 fs/file.c:930
1 lock held by syz-executor178/6870:
#0: ffff8880925120e0 (&type->s_umount_key#47/1){+.+.}-{3:3}, at: alloc_super+0x201/0xaf0 fs/super.c:229
Actually, we didn't have to use _nofail in this case, since we could return
error to mount(2) already with the error handler.
As a result, this patch tries to 1) remove _nofail callers as much as possible,
2) deal with error case in last remaining caller, f2fs_get_sum_page().
Reported-by: syzbot+ee250ac8137be41d7b13@syzkaller.appspotmail.com
Reviewed-by: Chao Yu <yuchao0@huawei.com>
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
[ Upstream commit 6a257471fa42c8c9c04a875cd3a2a22db148e0f0 ]
As syzbot reported:
kernel BUG at fs/f2fs/segment.h:657!
invalid opcode: 0000 [#1] PREEMPT SMP KASAN
CPU: 1 PID: 16220 Comm: syz-executor.0 Not tainted 5.9.0-rc5-syzkaller #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
RIP: 0010:f2fs_ra_meta_pages+0xa51/0xdc0 fs/f2fs/segment.h:657
Call Trace:
build_sit_entries fs/f2fs/segment.c:4195 [inline]
f2fs_build_segment_manager+0x4b8a/0xa3c0 fs/f2fs/segment.c:4779
f2fs_fill_super+0x377d/0x6b80 fs/f2fs/super.c:3633
mount_bdev+0x32e/0x3f0 fs/super.c:1417
legacy_get_tree+0x105/0x220 fs/fs_context.c:592
vfs_get_tree+0x89/0x2f0 fs/super.c:1547
do_new_mount fs/namespace.c:2875 [inline]
path_mount+0x1387/0x2070 fs/namespace.c:3192
do_mount fs/namespace.c:3205 [inline]
__do_sys_mount fs/namespace.c:3413 [inline]
__se_sys_mount fs/namespace.c:3390 [inline]
__x64_sys_mount+0x27f/0x300 fs/namespace.c:3390
do_syscall_64+0x2d/0x70 arch/x86/entry/common.c:46
@blkno in f2fs_ra_meta_pages could exceed max segment count, causing panic
in following sanity check in current_sit_addr(), add check condition to
avoid this issue.
Reported-by: syzbot+3698081bcf0bb2d12174@syzkaller.appspotmail.com
Signed-off-by: Chao Yu <yuchao0@huawei.com>
[ Upstream commit 6d7ab88a98c1b7a47c228f8ffb4f44d631eaf284 ]
As syzbot reported:
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x21c/0x280 lib/dump_stack.c:118
kmsan_report+0xf7/0x1e0 mm/kmsan/kmsan_report.c:122
__msan_warning+0x58/0xa0 mm/kmsan/kmsan_instr.c:219
f2fs_lookup+0xe05/0x1a80 fs/f2fs/namei.c:503
lookup_open fs/namei.c:3082 [inline]
open_last_lookups fs/namei.c:3177 [inline]
path_openat+0x2729/0x6a90 fs/namei.c:3365
do_filp_open+0x2b8/0x710 fs/namei.c:3395
do_sys_openat2+0xa88/0x1140 fs/open.c:1168
do_sys_open fs/open.c:1184 [inline]
__do_compat_sys_openat fs/open.c:1242 [inline]
__se_compat_sys_openat+0x2a4/0x310 fs/open.c:1240
__ia32_compat_sys_openat+0x56/0x70 fs/open.c:1240
do_syscall_32_irqs_on arch/x86/entry/common.c:80 [inline]
__do_fast_syscall_32+0x129/0x180 arch/x86/entry/common.c:139
do_fast_syscall_32+0x6a/0xc0 arch/x86/entry/common.c:162
do_SYSENTER_32+0x73/0x90 arch/x86/entry/common.c:205
entry_SYSENTER_compat_after_hwframe+0x4d/0x5c
In f2fs_lookup(), @res_page could be used before being initialized,
because in __f2fs_find_entry(), once F2FS_I(dir)->i_current_depth was
been fuzzed to zero, then @res_page will never be initialized, causing
this kmsan warning, relocating @res_page initialization place to fix
this bug.
Reported-by: syzbot+0eac6f0bbd558fd866d7@syzkaller.appspotmail.com
[ Upstream commit 9b66482282888d02832b7d90239e1cdb18e4b431 ]
Missing the trace exit in f2fs_sync_dirty_inodes
Signed-off-by: Zhang Qilong <zhangqilong3@huawei.com>
[ Upstream commit d53c3dfb23c45f7d4f910c3a3ca84bf0a99c6143 ]
Reading and modifying current->mm and current->active_mm and switching
mm should be done with irqs off, to prevent races seeing an intermediate
state.
This is similar to commit 38cf307c1f20 ("mm: fix kthread_use_mm() vs TLB
invalidate"). At exec-time when the new mm is activated, the old one
should usually be single-threaded and no longer used, unless something
else is holding an mm_users reference (which may be possible).
Absent other mm_users, there is also a race with preemption and lazy tlb
switching. Consider the kernel_execve case where the current thread is
using a lazy tlb active mm:
call_usermodehelper()
kernel_execve()
old_mm = current->mm;
active_mm = current->active_mm;
*** preempt *** --------------------> schedule()
prev->active_mm = NULL;
mmdrop(prev active_mm);
<-------------------- schedule()
current->mm = mm;
current->active_mm = mm;
if (!old_mm)
mmdrop(active_mm);
If we switch back to the kernel thread from a different mm, there is a
double free of the old active_mm, and a missing free of the new one.
Closing this race only requires interrupts to be disabled while ->mm
and ->active_mm are being switched, but the TLB problem requires also
holding interrupts off over activate_mm. Unfortunately not all archs
can do that yet, e.g., arm defers the switch if irqs are disabled and
expects finish_arch_post_lock_switch() to be called to complete the
flush; um takes a blocking lock in activate_mm().
So as a first step, disable interrupts across the mm/active_mm updates
to close the lazy tlb preempt race, and provide an arch option to
extend that to activate_mm which allows architectures doing IPI based
TLB shootdowns to close the second race.
This is a bit ugly, but in the interest of fixing the bug and backporting
before all architectures are converted this is a compromise.
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Link: https://lore.kernel.org/r/20200914045219.3736466-2-npiggin@gmail.com
commit d78092e4937de9ce55edcb4ee4c5e3c707be0190 upstream.
After unlock_request() pages from the ap->pages[] array may be put (e.g. by
aborting the connection) and the pages can be freed.
Prevent use after free by grabbing a reference to the page before calling
unlock_request().
The original patch was created by Pradeep P V K.
Reported-by: Pradeep P V K <ppvk@codeaurora.org>
Cc: <stable@vger.kernel.org>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
commit d578b46db69d125a654f509bdc9091d84e924dc8 upstream.
Don't recheck it since xattr_permission() already
checks CAP_SYS_ADMIN capability.
Just follow 5d3ce4f70172 ("f2fs: avoid duplicated permission check for "trusted." xattrs")
Reported-by: Hongyu Jin <hongyu.jin@unisoc.com>
[ Gao Xiang: since it could cause some complex Android overlay
permission issue as well on android-5.4+, it'd be better to
backport to 5.4+ rather than pure cleanup on mainline. ]
Cc: <stable@vger.kernel.org> # 5.4+
Link: https://lore.kernel.org/r/20200811070020.6339-1-hsiangkao@redhat.com
Signed-off-by: Gao Xiang <hsiangkao@redhat.com>
commit 336af6a4686d885a067ecea8c3c3dd129ba4fc75 upstream.
Without this patch efivarfs_alloc_dentry creates dentries with slashes in
their name if the respective EFI variable has slashes in its name. This in
turn causes EIO on getdents64, which prevents a complete directory listing
of /sys/firmware/efi/efivars/.
This patch replaces the invalid shlashes with exclamation marks like
kobject_set_name_vargs does for /sys/firmware/efi/vars/ to have consistently
named dentries under /sys/firmware/efi/vars/ and /sys/firmware/efi/efivars/.
Signed-off-by: Michael Schaller <misch@google.com>
Link: https://lore.kernel.org/r/20200925074502.150448-1-misch@google.com
Signed-off-by: Ard Biesheuvel <ardb@kernel.org>
Signed-off-by: dann frazier <dann.frazier@canonical.com>
[ Upstream commit e9d4709fcc26353df12070566970f080e651f0c9 ]
When a usrjquota or grpjquota mount option is used multiple times, we
will leak memory allocated for the file name. Make sure the last setting
is used and all the previous ones are properly freed.
Reported-by: syzbot+c9e294bbe0333a6b7640@syzkaller.appspotmail.com
[ Upstream commit a805c111650cdba6ee880f528abdd03c1af82089 ]
It is trivial to trigger a WARN_ON_ONCE(1) in iomap_dio_actor() by
unprivileged users which would taint the kernel, or worse - panic if
panic_on_warn or panic_on_taint is set. Hence, just convert it to
pr_warn_ratelimited() to let users know their workloads are racing.
Thank Dave Chinner for the initial analysis of the racing reproducers.
Signed-off-by: Qian Cai <cai@lca.pw>
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
[ Upstream commit 2a6ca4baed620303d414934aa1b7b0a8e7bab05f ]
There's an overflow bug in the realtime allocator. If the rt volume is
large enough to handle a single allocation request that is larger than
the maximum bmap extent length and the rt bitmap ends exactly on a
bitmap block boundary, it's possible that the near allocator will try to
check the freeness of a range that extends past the end of the bitmap.
This fails with a corruption error and shuts down the fs.
Therefore, constrain maxlen so that the range scan cannot run off the
end of the rt bitmap.
