commit b31ff3cdf540110da4572e3e29bd172087af65cc upstream.
If using a kernel with CONFIG_XFS_RT=y and we set the RHINHERIT flag on
a directory in a filesystem that does not have a realtime device and
create a new file in that directory, it gets marked as a real time file.
When data is written and a fsync is issued, the filesystem attempts to
flush a non-existent rt device during the fsync process.
This results in a crash dereferencing a null buftarg pointer in
xfs_blkdev_issue_flush():
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: xfs_blkdev_issue_flush+0xd/0x20
Call Trace:
xfs_file_fsync+0x188/0x1c0
vfs_fsync_range+0x3b/0xa0
do_fsync+0x3d/0x70
SyS_fsync+0x10/0x20
do_syscall_64+0x4d/0xb0
entry_SYSCALL64_slow_path+0x25/0x25
Setting RT inode flags does not require special privileges so any
unprivileged user can cause this oops to occur. To reproduce, confirm
kernel is compiled with CONFIG_XFS_RT=y and run:
# mkfs.xfs -f /dev/pmem0
# mount /dev/pmem0 /mnt/test
# mkdir /mnt/test/foo
# xfs_io -c 'chattr +t' /mnt/test/foo
# xfs_io -f -c 'pwrite 0 5m' -c fsync /mnt/test/foo/bar
Or just run xfstests with MKFS_OPTIONS="-d rtinherit=1" and wait.
Kernels built with CONFIG_XFS_RT=n are not exposed to this bug.
Fixes: f538d4da8d52 ("[XFS] write barrier support")
Signed-off-by: Richard Wareing <rwareing@fb.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
commit 196639ebbe63a037fe9a80669140bd292d8bcd80 upstream.
The writeback code wants to send a commit after processing the pages,
which is why we want to delay releasing the struct path until after
that's done.
Also, the layout code expects that we do not free the inode before
we've put the layout segments in pnfs_writehdr_free() and
pnfs_readhdr_free()
Fixes: 919e3bd9a875 ("NFS: Ensure we commit after writeback is complete")
Fixes: 4714fb51fd03 ("nfs: remove pgio_header refcount, related cleanup")
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 6c6b5a39c4bf3dbd8cf629c9f5450e983c19dbb9 upstream.
Several distributions mount the "proper root" as ro during initrd and
then remount it as rw before pivot_root(2). Thus, if a rescan had been
aborted by a previous shutdown, the rescan would never be resumed.
This issue would manifest itself as several btrfs ioctl(2)s causing the
entire machine to hang when btrfs_qgroup_wait_for_completion was hit
(due to the fs_info->qgroup_rescan_running flag being set but the rescan
itself not being resumed). Notably, Docker's btrfs storage driver makes
regular use of BTRFS_QUOTA_CTL_DISABLE and BTRFS_IOC_QUOTA_RESCAN_WAIT
(causing this problem to be manifested on boot for some machines).
Cc: Jeff Mahoney <jeffm@suse.com>
Fixes: b382a324b60f ("Btrfs: fix qgroup rescan resume on mount")
Signed-off-by: Aleksa Sarai <asarai@suse.de>
Reviewed-by: Nikolay Borisov <nborisov@suse.com>
Tested-by: Nikolay Borisov <nborisov@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
commit 55acdd926f6b21a5cdba23da98a48aedf19ac9c3 upstream.
Can be reproduced when running dlm_controld (tested on 4.4.x, 4.12.4):
# seq 1 100 | xargs -P0 -n1 dlm_tool join
# seq 1 100 | xargs -P0 -n1 dlm_tool leave
misc_register fails due to duplicate sysfs entry, which causes
dlm_device_register to free ls->ls_device.name.
In dlm_device_deregister the name was freed again, causing memory
corruption.
According to the comment in dlm_device_deregister the name should've been
set to NULL when registration fails,
so this patch does that.
sysfs: cannot create duplicate filename '/dev/char/10:1'
warning: cpu: 1 pid: 4450 at fs/sysfs/dir.c:31 sysfs_warn_dup+0x56/0x70
modules linked in: msr rfcomm dlm ccm bnep dm_crypt uvcvideo
videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_core videodev
btusb media btrtl btbcm btintel bluetooth ecdh_generic intel_rapl
x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm
snd_hda_codec_hdmi irqbypass crct10dif_pclmul crc32_pclmul
ghash_clmulni_intel thinkpad_acpi pcbc nvram snd_seq_midi
snd_seq_midi_event aesni_intel snd_hda_codec_realtek snd_hda_codec_generic
snd_rawmidi aes_x86_64 crypto_simd glue_helper snd_hda_intel snd_hda_codec
cryptd intel_cstate arc4 snd_hda_core snd_seq snd_seq_device snd_hwdep
iwldvm intel_rapl_perf mac80211 joydev input_leds iwlwifi serio_raw
cfg80211 snd_pcm shpchp snd_timer snd mac_hid mei_me lpc_ich mei soundcore
sunrpc parport_pc ppdev lp parport autofs4 i915 psmouse
e1000e ahci libahci i2c_algo_bit sdhci_pci ptp drm_kms_helper sdhci
pps_core syscopyarea sysfillrect sysimgblt fb_sys_fops drm wmi video
cpu: 1 pid: 4450 comm: dlm_test.exe not tainted 4.12.4-041204-generic
hardware name: lenovo 232425u/232425u, bios g2et82ww (2.02 ) 09/11/2012
task: ffff96b0cbabe140 task.stack: ffffb199027d0000
rip: 0010:sysfs_warn_dup+0x56/0x70
rsp: 0018:ffffb199027d3c58 eflags: 00010282
rax: 0000000000000038 rbx: ffff96b0e2c49158 rcx: 0000000000000006
rdx: 0000000000000000 rsi: 0000000000000086 rdi: ffff96b15e24dcc0
rbp: ffffb199027d3c70 r08: 0000000000000001 r09: 0000000000000721
r10: ffffb199027d3c00 r11: 0000000000000721 r12: ffffb199027d3cd1
r13: ffff96b1592088f0 r14: 0000000000000001 r15: ffffffffffffffef
fs: 00007f78069c0700(0000) gs:ffff96b15e240000(0000)
knlgs:0000000000000000
cs: 0010 ds: 0000 es: 0000 cr0: 0000000080050033
cr2: 000000178625ed28 cr3: 0000000091d3e000 cr4: 00000000001406e0
call trace:
sysfs_do_create_link_sd.isra.2+0x9e/0xb0
sysfs_create_link+0x25/0x40
device_add+0x5a9/0x640
device_create_groups_vargs+0xe0/0xf0
device_create_with_groups+0x3f/0x60
? snprintf+0x45/0x70
misc_register+0x140/0x180
device_write+0x6a8/0x790 [dlm]
__vfs_write+0x37/0x160
? apparmor_file_permission+0x1a/0x20
? security_file_permission+0x3b/0xc0
vfs_write+0xb5/0x1a0
sys_write+0x55/0xc0
? sys_fcntl+0x5d/0xb0
entry_syscall_64_fastpath+0x1e/0xa9
rip: 0033:0x7f78083454bd
rsp: 002b:00007f78069bbd30 eflags: 00000293 orig_rax: 0000000000000001
rax: ffffffffffffffda rbx: 0000000000000006 rcx: 00007f78083454bd
rdx: 000000000000009c rsi: 00007f78069bee00 rdi: 0000000000000005
rbp: 00007f77f8000a20 r08: 000000000000fcf0 r09: 0000000000000032
r10: 0000000000000024 r11: 0000000000000293 r12: 00007f78069bde00
r13: 00007f78069bee00 r14: 000000000000000a r15: 00007f78069bbd70
code: 85 c0 48 89 c3 74 12 b9 00 10 00 00 48 89 c2 31 f6 4c 89 ef e8 2c c8
ff ff 4c 89 e2 48 89 de 48 c7 c7 b0 8e 0c a8 e8 41 e8 ed ff <0f> ff 48 89
df e8 00 d5 f4 ff 5b 41 5c 41 5d 5d c3 66 0f 1f 84
---[ end trace 40412246357cc9e0 ]---
dlm: 59f24629-ae39-44e2-9030-397ebc2eda26: leaving the lockspace group...
bug: unable to handle kernel null pointer dereference at 0000000000000001
ip: [<ffffffff811a3b4a>] kmem_cache_alloc+0x7a/0x140
pgd 0
oops: 0000 [#1] smp
modules linked in: dlm 8021q garp mrp stp llc openvswitch nf_defrag_ipv6
nf_conntrack libcrc32c iptable_filter dm_multipath crc32_pclmul dm_mod
aesni_intel psmouse aes_x86_64 sg ablk_helper cryptd lrw gf128mul
glue_helper i2c_piix4 nls_utf8 tpm_tis tpm isofs nfsd auth_rpcgss
oid_registry nfs_acl lockd grace sunrpc xen_wdt ip_tables x_tables autofs4
hid_generic usbhid hid sr_mod cdrom sd_mod ata_generic pata_acpi 8139too
serio_raw ata_piix 8139cp mii uhci_hcd ehci_pci ehci_hcd libata
scsi_dh_rdac scsi_dh_hp_sw scsi_dh_emc scsi_dh_alua scsi_mod ipv6
cpu: 0 pid: 394 comm: systemd-udevd tainted: g w 4.4.0+0 #1
hardware name: xen hvm domu, bios 4.7.2-2.2 05/11/2017
task: ffff880002410000 ti: ffff88000243c000 task.ti: ffff88000243c000
rip: e030:[<ffffffff811a3b4a>] [<ffffffff811a3b4a>]
rsp: e02b:ffff88000243fd90 eflags: 00010202
rax: 0000000000000000 rbx: ffff8800029864d0 rcx: 000000000007b36c
rdx: 000000000007b36b rsi: 00000000024000c0 rdi: ffff880036801c00
rbp: ffff88000243fdc0 r08: 0000000000018880 r09: 0000000000000054
r10: 000000000000004a r11: ffff880034ace6c0 r12: 00000000024000c0
r13: ffff880036801c00 r14: 0000000000000001 r15: ffffffff8118dcc2
fs: 00007f0ab77548c0(0000) gs:ffff880036e00000(0000) knlgs:0000000000000000
cs: e033 ds: 0000 es: 0000 cr0: 0000000080050033
cr2: 0000000000000001 cr3: 000000000332d000 cr4: 0000000000040660
stack:
ffffffff8118dc90 ffff8800029864d0 0000000000000000 ffff88003430b0b0
ffff880034b78320 ffff88003430b0b0 ffff88000243fdf8 ffffffff8118dcc2
ffff8800349c6700 ffff8800029864d0 000000000000000b 00007f0ab7754b90
call trace:
[<ffffffff8118dc90>] ? anon_vma_fork+0x60/0x140
[<ffffffff8118dcc2>] anon_vma_fork+0x92/0x140
[<ffffffff8107033e>] copy_process+0xcae/0x1a80
[<ffffffff8107128b>] _do_fork+0x8b/0x2d0
[<ffffffff81071579>] sys_clone+0x19/0x20
[<ffffffff815a30ae>] entry_syscall_64_fastpath+0x12/0x71
] code: f6 75 1c 4c 89 fa 44 89 e6 4c 89 ef e8 a7 e4 00 00 41 f7 c4 00 80
00 00 49 89 c6 74 47 eb 32 49 63 45 20 48 8d 4a 01 4d 8b 45 00 <49> 8b 1c
06 4c 89 f0 65 49 0f c7 08 0f 94 c0 84 c0 74 ac 49 63
rip [<ffffffff811a3b4a>] kmem_cache_alloc+0x7a/0x140
rsp <ffff88000243fd90>
--[ end trace 70cb9fd1b164a0e8 ]--
Signed-off-by: Edwin Török <edvin.torok@citrix.com>
Signed-off-by: David Teigland <teigland@redhat.com>
commit 138e4ad67afd5c6c318b056b4d17c17f2c0ca5c0 upstream.
The race was introduced by me in commit 971316f0503a ("epoll:
ep_unregister_pollwait() can use the freed pwq->whead"). I did not
realize that nothing can protect eventpoll after ep_poll_callback() sets
->whead = NULL, only whead->lock can save us from the race with
ep_free() or ep_remove().
Move ->whead = NULL to the end of ep_poll_callback() and add the
necessary barriers.
TODO: cleanup the ewake/EPOLLEXCLUSIVE logic, it was confusing even
before this patch.
Hopefully this explains use-after-free reported by syzcaller:
BUG: KASAN: use-after-free in debug_spin_lock_before
_raw_spin_lock_irqsave+0x4a/0x60 kernel/locking/spinlock.c:159
ep_poll_callback+0x29f/0xff0 fs/eventpoll.c:1148
this is spin_lock(eventpoll->lock),
Freed by task 17774:
kfree+0xe8/0x2c0 mm/slub.c:3883
ep_free+0x22c/0x2a0 fs/eventpoll.c:865
Fixes: 971316f0503a ("epoll: ep_unregister_pollwait() can use the freed pwq->whead")
Reported-by: 范龙飞 <long7573@126.com>
commit 6e3c1529c39e92ed64ca41d53abadabbaa1d5393 upstream.
Recent patch had an endian warning ie
cifs: return ENAMETOOLONG for overlong names in cifs_open()/cifs_lookup()
Signed-off-by: Steve French <smfrench@gmail.com>
CC: Ronnie Sahlberg <lsahlber@redhat.com>
Acked-by: Pavel Shilovsky <pshilov@microsoft.com>
commit 9e37b1784f2be9397a903307574ee565bbadfd75 upstream.
Currently the maximum size of SMB2/3 header is set incorrectly which
leads to hanging of directory listing operations on encrypted SMB3
connections. Fix this by setting the maximum size to 170 bytes that
is calculated as RFC1002 length field size (4) + transform header
size (52) + SMB2 header size (64) + create response size (56).
Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com>
Acked-by: Sachin Prabhu <sprabhu@redhat.com>
commit dd2bc473482eedc60c29cf00ad12568ce40ce511 upstream.
ceph_readpage() unlocks page prematurely prematurely in the case
that page is reading from fscache. Caller of readpage expects that
page is uptodate when it get unlocked. So page shoule get locked
by completion callback of fscache_read_or_alloc_pages()
Signed-off-by: "Yan, Zheng" <zyan@redhat.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
commit fb75d857a31d600cc0c37b8c7d914014f7fa3f9a upstream.
duplicate const is redundant so remove it
commit fc788f64f1f3eb31e87d4f53bcf1ab76590d5838 upstream.
When processing an NFSv4 WRITE operation, argp->end should never
point past the end of the data in the final page of the page list.
Otherwise, nfsd4_decode_compound can walk into uninitialized memory.
More critical, nfsd4_decode_write is failing to increment argp->pagelen
when it increments argp->pagelist. This can cause later xdr decoders
to assume more data is available than really is, which can cause server
crashes on malformed requests.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit d3edede29f74d335f81d95a4588f5f136a9f7dcf upstream.
Add checking for the path component length and verify it is <= the maximum
that the server advertizes via FileFsAttributeInformation.
With this patch cifs.ko will now return ENAMETOOLONG instead of ENOENT
when users to access an overlong path.
To test this, try to cd into a (non-existing) directory on a CIFS share
that has a too long name:
cd /mnt/aaaaaaaaaaaaaaa...
and it now should show a good error message from the shell:
bash: cd: /mnt/aaaaaaaaaaaaaaaa...aaaaaa: File name too long
rh bz 1153996
Signed-off-by: Ronnie Sahlberg <lsahlber@redhat.com>
commit 42bec214d8bd432be6d32a1acb0a9079ecd4d142 upstream.
The df for a SMB2 share triggers a GetInfo call for
FS_FULL_SIZE_INFORMATION. The values returned are used to populate
struct statfs.
The problem is that none of the information returned by the call
contains the total blocks available on the filesystem. Instead we use
the blocks available to the user ie. quota limitation when filling out
statfs.f_blocks. The information returned does contain Actual free units
on the filesystem and is used to populate statfs.f_bfree. For users with
quota enabled, it can lead to situations where the total free space
reported is more than the total blocks on the system ending up with df
reports like the following
# df -h /mnt/a
Filesystem Size Used Avail Use% Mounted on
//192.168.22.10/a 2.5G -2.3G 2.5G - /mnt/a
To fix this problem, we instead populate both statfs.f_bfree with the
same value as statfs.f_bavail ie. CallerAvailableAllocationUnits. This
is similar to what is done already in the code for cifs and df now
reports the quota information for the user used to mount the share.
# df --si /mnt/a
//192.168.22.10/a 2.7G 101M 2.6G 4% /mnt/a
Signed-off-by: Sachin Prabhu <sprabhu@redhat.com>
Signed-off-by: Pierguido Lambri <plambri@redhat.com>
commit 8a9d6e964d318533ba3d2901ce153ba317c99a89 upstream.
The blocklayout code does not compile cleanly for a 32-bit sector_t,
and also has no reliable checks for devices sizes, which makes it
unsafe to use with a kernel that doesn't support large block devices.
Fixes: 5c83746a0cf2 ("pnfs/blocklayout: in-kernel GETDEVICEINFO XDR parsing")
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
commit 1feb26162bee7b2f110facfec71b5c7bdbc7d14d upstream.
The client was freeing the nfs4_ff_layout_ds, but not the contained
nfs4_ff_ds_version array.
Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
commit 68227c03cba84a24faf8a7277d2b1a03c8959c2c upstream.
Before the patch, the flock flag could remain uninitialized for the
lifespan of the fuse_file allocation. Unless set to true in
fuse_file_flock(), it would remain in an indeterminate state until read in
an if statement in fuse_release_common(). This could consequently lead to
taking an unexpected branch in the code.
The bug was discovered by a runtime instrumentation designed to detect use
of uninitialized memory in the kernel.
Signed-off-by: Mateusz Jurczyk <mjurczyk@google.com>
Fixes: 37fb3a30b462 ("fuse: fix flock")
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
commit 15d3042a937c13f5d9244241c7a9c8416ff6e82a upstream.
Make sure segno and blkoff read from raw image are valid.
Cc: stable@vger.kernel.org
Signed-off-by: Jin Qian <jinqian@google.com>
[Jaegeuk Kim: adjust minor coding style]
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
[AmitP: Found in Android Security bulletin for Aug'17, fixes CVE-2017-10663]
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit aec51758ce10a9c847a62a48a168f8c804c6e053 upstream.
On a 32-bit platform, the value of n_blcoks_count may be wrong during
the file system is resized to size larger than 2^32 blocks. This may
caused the superblock being corrupted with zero blocks count.
Fixes: 1c6bd7173d66
Signed-off-by: Jerry Lee <jerrylee@qnap.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit fcf5ea10992fbac3c7473a1db33d56a139333cd1 upstream.
ext4_find_unwritten_pgoff() does not properly handle a situation when
starting index is in the middle of a page and blocksize < pagesize. The
following command shows the bug on filesystem with 1k blocksize:
xfs_io -f -c "falloc 0 4k" \
-c "pwrite 1k 1k" \
-c "pwrite 3k 1k" \
-c "seek -a -r 0" foo
In this example, neither lseek(fd, 1024, SEEK_HOLE) nor lseek(fd, 2048,
SEEK_DATA) will return the correct result.
Fix the problem by neglecting buffers in a page before starting offset.
Reported-by: Andreas Gruenbacher <agruenba@redhat.com>
[ Upstream commit c2931667c83ded6504b3857e99cc45b21fa496fb ]
Currently how btrfs dio deals with split dio write is not good
enough if dio write is split into several segments due to the
lack of contiguous space, a large dio write like 'dd bs=1G count=1'
can end up with incorrect outstanding_extents counter and endio
would complain loudly with an assertion.
This fixes the problem by compensating the outstanding_extents
counter in inode if a large dio write gets split.
Reported-by: Anand Jain <anand.jain@oracle.com>
Tested-by: Anand Jain <anand.jain@oracle.com>
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
commit e9a330c4289f2ba1ca4bf98c2b430ab165a8931b upstream.
The per-prz spinlock should be using the dynamic initializer so that
lockdep can correctly track it. Without this, under lockdep, we get a
warning at boot that the lock is in non-static memory.
Fixes: 109704492ef6 ("pstore: Make spinlock per zone instead of global")
Fixes: 76d5692a5803 ("pstore: Correctly initialize spinlock and flags")
commit 76d5692a58031696e282384cbd893832bc92bd76 upstream.
The ram backend wasn't always initializing its spinlock correctly. Since
it was coming from kzalloc memory, though, it was harmless on
architectures that initialize unlocked spinlocks to 0 (at least x86 and
ARM). This also fixes a possibly ignored flag setting too.
When running under CONFIG_DEBUG_SPINLOCK, the following Oops was visible:
[ 0.760836] persistent_ram: found existing buffer, size 29988, start 29988
[ 0.765112] persistent_ram: found existing buffer, size 30105, start 30105
[ 0.769435] persistent_ram: found existing buffer, size 118542, start 118542
[ 0.785960] persistent_ram: found existing buffer, size 0, start 0
[ 0.786098] persistent_ram: found existing buffer, size 0, start 0
[ 0.786131] pstore: using zlib compression
[ 0.790716] BUG: spinlock bad magic on CPU#0, swapper/0/1
[ 0.790729] lock: 0xffffffc0d1ca9bb0, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0
[ 0.790742] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.10.0-rc2+ #913
[ 0.790747] Hardware name: Google Kevin (DT)
[ 0.790750] Call trace:
[ 0.790768] [<ffffff900808ae88>] dump_backtrace+0x0/0x2bc
[ 0.790780] [<ffffff900808b164>] show_stack+0x20/0x28
[ 0.790794] [<ffffff9008460ee0>] dump_stack+0xa4/0xcc
[ 0.790809] [<ffffff9008113cfc>] spin_dump+0xe0/0xf0
[ 0.790821] [<ffffff9008113d3c>] spin_bug+0x30/0x3c
[ 0.790834] [<ffffff9008113e28>] do_raw_spin_lock+0x50/0x1b8
[ 0.790846] [<ffffff9008a2d2ec>] _raw_spin_lock_irqsave+0x54/0x6c
[ 0.790862] [<ffffff90083ac3b4>] buffer_size_add+0x48/0xcc
[ 0.790875] [<ffffff90083acb34>] persistent_ram_write+0x60/0x11c
[ 0.790888] [<ffffff90083aab1c>] ramoops_pstore_write_buf+0xd4/0x2a4
[ 0.790900] [<ffffff90083a9d3c>] pstore_console_write+0xf0/0x134
[ 0.790912] [<ffffff900811c304>] console_unlock+0x48c/0x5e8
[ 0.790923] [<ffffff900811da18>] register_console+0x3b0/0x4d4
[ 0.790935] [<ffffff90083aa7d0>] pstore_register+0x1a8/0x234
[ 0.790947] [<ffffff90083ac250>] ramoops_probe+0x6b8/0x7d4
[ 0.790961] [<ffffff90085ca548>] platform_drv_probe+0x7c/0xd0
[ 0.790972] [<ffffff90085c76ac>] driver_probe_device+0x1b4/0x3bc
[ 0.790982] [<ffffff90085c7ac8>] __device_attach_driver+0xc8/0xf4
[ 0.790996] [<ffffff90085c4bfc>] bus_for_each_drv+0xb4/0xe4
[ 0.791006] [<ffffff90085c7414>] __device_attach+0xd0/0x158
[ 0.791016] [<ffffff90085c7b18>] device_initial_probe+0x24/0x30
[ 0.791026] [<ffffff90085c648c>] bus_probe_device+0x50/0xe4
[ 0.791038] [<ffffff90085c35b8>] device_add+0x3a4/0x76c
[ 0.791051] [<ffffff90087d0e84>] of_device_add+0x74/0x84
[ 0.791062] [<ffffff90087d19b8>] of_platform_device_create_pdata+0xc0/0x100
[ 0.791073] [<ffffff90087d1a2c>] of_platform_device_create+0x34/0x40
[ 0.791086] [<ffffff900903c910>] of_platform_default_populate_init+0x58/0x78
[ 0.791097] [<ffffff90080831fc>] do_one_initcall+0x88/0x160
[ 0.791109] [<ffffff90090010ac>] kernel_init_freeable+0x264/0x31c
[ 0.791123] [<ffffff9008a25bd0>] kernel_init+0x18/0x11c
[ 0.791133] [<ffffff9008082ec0>] ret_from_fork+0x10/0x50
[ 0.793717] console [pstore-1] enabled
[ 0.797845] pstore: Registered ramoops as persistent store backend
[ 0.804647] ramoops: attached 0x100000@0xf7edc000, ecc: 0/0
Fixes: 663deb47880f ("pstore: Allow prz to control need for locking")
Reported-by: Brian Norris <briannorris@chromium.org>
commit 663deb47880f2283809669563c5a52ac7c6aef1a upstream.
In preparation of not locking at all for certain buffers depending on if
there's contention, make locking optional depending on the initialization
of the prz.
Signed-off-by: Joel Fernandes <joelaf@google.com>
[kees: moved locking flag into prz instead of via caller arguments]
commit 34dbbcdbf63360661ff7bda6c5f52f99ac515f92 upstream.
A lot of seqfile users seem to be using things like %pK that uses the
credentials of the current process, but that is actually completely
wrong for filesystem interfaces.
The unix semantics for permission checking files is to check permissions
at _open_ time, not at read or write time, and that is not just a small
detail: passing off stdin/stdout/stderr to a suid application and making
the actual IO happen in privileged context is a classic exploit
technique.
So if we want to be able to look at permissions at read time, we need to
use the file open credentials, not the current ones. Normal file
accesses can just use "f_cred" (or any of the helper functions that do
that, like file_ns_capable()), but the seqfile interfaces do not have
any such options.
It turns out that seq_file _does_ save away the user_ns information of
the file, though. Since user_ns is just part of the full credential
information, replace that special case with saving off the cred pointer
instead, and suddenly seq_file has all the permission information it
needs.
[sumits: this is used in Ubuntu as a fix for CVE-2015-8944]
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
commit 49d31c2f389acfe83417083e1208422b4091cd9e upstream.
take_dentry_name_snapshot() takes a safe snapshot of dentry name;
if the name is a short one, it gets copied into caller-supplied
structure, otherwise an extra reference to external name is grabbed
(those are never modified). In either case the pointer to stable
string is stored into the same structure.
dentry must be held by the caller of take_dentry_name_snapshot(),
but may be freely dropped afterwards - the snapshot will stay
until destroyed by release_dentry_name_snapshot().
Intended use:
struct name_snapshot s;
take_dentry_name_snapshot(&s, dentry);
access s.name
release_dentry_name_snapshot(&s);
Replaces fsnotify_oldname_...(), gets used in fsnotify to obtain the name
to pass down with event.
commit 04197b341f23b908193308b8d63d17ff23232598 upstream.
We've had reports of generic/095 causing XFS to BUG() in
__xfs_get_blocks() due to the existence of delalloc blocks on a
direct I/O read. generic/095 issues a mix of various types of I/O,
including direct and memory mapped I/O to a single file. This is
clearly not supported behavior and is known to lead to such
problems. E.g., the lack of exclusion between the direct I/O and
write fault paths means that a write fault can allocate delalloc
blocks in a region of a file that was previously a hole after the
direct read has attempted to flush/inval the file range, but before
it actually reads the block mapping. In turn, the direct read
discovers a delalloc extent and cannot proceed.
While the appropriate solution here is to not mix direct and memory
mapped I/O to the same regions of the same file, the current
BUG_ON() behavior is probably overkill as it can crash the entire
system. Instead, localize the failure to the I/O in question by
returning an error for a direct I/O that cannot be handled safely
due to delalloc blocks. Be careful to allow the case of a direct
write to post-eof delalloc blocks. This can occur due to speculative
preallocation and is safe as post-eof blocks are not accompanied by
dirty pages in pagecache (conversely, preallocation within eof must
have been zeroed, and thus dirtied, before the inode size could have
been increased beyond said blocks).
Finally, provide an additional warning if a direct I/O write occurs
while the file is memory mapped. This may not catch all problematic
scenarios, but provides a hint that some known-to-be-problematic I/O
methods are in use.
Signed-off-by: Brian Foster <bfoster@redhat.com>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
Acked-by: Darrick J. Wong <darrick.wong@oracle.com>
commit 109704492ef637956265ec2eb72ae7b3b39eb6f4 upstream.
Currently pstore has a global spinlock for all zones. Since the zones
are independent and modify different areas of memory, there's no need
to have a global lock, so we should use a per-zone lock as introduced
here. Also, when ramoops's ftrace use-case has a FTRACE_PER_CPU flag
introduced later, which splits the ftrace memory area into a single zone
per CPU, it will eliminate the need for locking. In preparation for this,
make the locking optional.
[kees: updated commit message]
Cc: Leo Yan <leo.yan@linaro.org>
commit 84583cfb973c4313955c6231cc9cb3772d280b15 upstream.
For a large directory, program needs to issue multiple readdir
syscalls to get all dentries. When there are multiple programs
read the directory concurrently. Following sequence of events
can happen.
- program calls readdir with pos = 2. ceph sends readdir request
to mds. The reply contains N1 entries. ceph adds these N1 entries
to readdir cache.
- program calls readdir with pos = N1+2. The readdir is satisfied
by the readdir cache, N2 entries are returned. (Other program
calls readdir in the middle, which fills the cache)
- program calls readdir with pos = N1+N2+2. ceph sends readdir
request to mds. The reply contains N3 entries and it reaches
directory end. ceph adds these N3 entries to the readdir cache
and marks directory complete.
The second readdir call does not update fi->readdir_cache_idx.
ceph add the last N3 entries to wrong places.
commit f2e95355891153f66d4156bf3a142c6489cd78c6 upstream.
udf_setsize() called truncate_setsize() with i_data_sem held. Thus
truncate_pagecache() called from truncate_setsize() could lock a page
under i_data_sem which can deadlock as page lock ranks below
i_data_sem - e. g. writeback can hold page lock and try to acquire
i_data_sem to map a block.
Fix the problem by moving truncate_setsize() calls from under
i_data_sem. It is safe for us to change i_size without holding
i_data_sem as all the places that depend on i_size being stable already
hold inode_lock.
Fixes: 7e49b6f2480cb9a9e7322a91592e56a5c85361f5
commit cc89684c9a265828ce061037f1f79f4a68ccd3f7 upstream.
Since commit bafc9b754f75 ("vfs: More precise tests in d_invalidate")
in v3.18, a return of '0' from ->d_revalidate() will cause the dentry
to be invalidated even if it has filesystems mounted on or it or on a
descendant. The mounted filesystem is unmounted.
This means we need to be careful not to return 0 unless the directory
referred to truly is invalid. So -ESTALE or -ENOENT should invalidate
the directory. Other errors such a -EPERM or -ERESTARTSYS should be
returned from ->d_revalidate() so they are propagated to the caller.
A particular problem can be demonstrated by:
1/ mount an NFS filesystem using NFSv3 on /mnt
2/ mount any other filesystem on /mnt/foo
3/ ls /mnt/foo
4/ turn off network, or otherwise make the server unable to respond
5/ ls /mnt/foo &
6/ cat /proc/$!/stack # note that nfs_lookup_revalidate is in the call stack
7/ kill -9 $! # this results in -ERESTARTSYS being returned
8/ observe that /mnt/foo has been unmounted.
This patch changes nfs_lookup_revalidate() to only treat
-ESTALE from nfs_lookup_verify_inode() and
-ESTALE or -ENOENT from ->lookup()
as indicating an invalid inode. Other errors are returned.
Also nfs_check_inode_attributes() is changed to return -ESTALE rather
than -EIO. This is consistent with the error returned in similar
circumstances from nfs_update_inode().
As this bug allows any user to unmount a filesystem mounted on an NFS
filesystem, this fix is suitable for stable kernels.
Fixes: bafc9b754f75 ("vfs: More precise tests in d_invalidate")
Signed-off-by: NeilBrown <neilb@suse.com>
commit c925dc162f770578ff4a65ec9b08270382dba9e6 upstream.
This patch copies commit b7f8a09f80:
"btrfs: Don't clear SGID when inheriting ACLs" written by Jan.
Fixes: 073931017b49d9458aa351605b43a7e34598caef
Reviewed-by: Chao Yu <yuchao0@huawei.com>
commit 296990deb389c7da21c78030376ba244dc1badf5 upstream.
Andrei Vagin pointed out that time to executue propagate_umount can go
non-linear (and take a ludicrious amount of time) when the mount
propogation trees of the mounts to be unmunted by a lazy unmount
overlap.
Make the walk of the mount propagation trees nearly linear by
remembering which mounts have already been visited, allowing
subsequent walks to detect when walking a mount propgation tree or a
subtree of a mount propgation tree would be duplicate work and to skip
them entirely.
Walk the list of mounts whose propgatation trees need to be traversed
from the mount highest in the mount tree to mounts lower in the mount
tree so that odds are higher that the code will walk the largest trees
first, allowing later tree walks to be skipped entirely.
Add cleanup_umount_visitation to remover the code's memory of which
mounts have been visited.
Add the functions last_slave and skip_propagation_subtree to allow
skipping appropriate parts of the mount propagation tree without
needing to change the logic of the rest of the code.
A script to generate overlapping mount propagation trees:
$ cat runs.h
set -e
mount -t tmpfs zdtm /mnt
mkdir -p /mnt/1 /mnt/2
mount -t tmpfs zdtm /mnt/1
mount --make-shared /mnt/1
mkdir /mnt/1/1
iteration=10
if [ -n "$1" ] ; then
iteration=$1
fi
for i in $(seq $iteration); do
mount --bind /mnt/1/1 /mnt/1/1
done
mount --rbind /mnt/1 /mnt/2
TIMEFORMAT='%Rs'
nr=$(( ( 2 ** ( $iteration + 1 ) ) + 1 ))
echo -n "umount -l /mnt/1 -> $nr "
time umount -l /mnt/1
nr=$(cat /proc/self/mountinfo | grep zdtm | wc -l )
time umount -l /mnt/2
$ for i in $(seq 9 19); do echo $i; unshare -Urm bash ./run.sh $i; done
Here are the performance numbers with and without the patch:
mhash | 8192 | 8192 | 1048576 | 1048576
mounts | before | after | before | after
1025 | 0.040s | 0.016s | 0.038s | 0.019s
2049 | 0.094s | 0.017s | 0.080s | 0.018s
4097 | 0.243s | 0.019s | 0.206s | 0.023s
8193 | 1.202s | 0.028s | 1.562s | 0.032s
16385 | 9.635s | 0.036s | 9.952s | 0.041s
32769 | 60.928s | 0.063s | 44.321s | 0.064s
65537 | | 0.097s | | 0.097s
131073 | | 0.233s | | 0.176s
262145 | | 0.653s | | 0.344s
524289 | | 2.305s | | 0.735s
1048577 | | 7.107s | | 2.603s
Andrei Vagin reports fixing the performance problem is part of the
work to fix CVE-2016-6213.
Fixes: a05964f3917c ("[PATCH] shared mounts handling: umount")
Reported-by: Andrei Vagin <avagin@openvz.org>
Reviewed-by: Andrei Vagin <avagin@virtuozzo.com>
commit 99b19d16471e9c3faa85cad38abc9cbbe04c6d55 upstream.
While investigating some poor umount performance I realized that in
the case of overlapping mount trees where some of the mounts are locked
the code has been failing to unmount all of the mounts it should
have been unmounting.
This failure to unmount all of the necessary
mounts can be reproduced with:
$ cat locked_mounts_test.sh
mount -t tmpfs test-base /mnt
mkdir -p /mnt/b
mount -t tmpfs test1 /mnt/b
mount --make-shared /mnt/b
mkdir -p /mnt/b/10
mount -t tmpfs test2 /mnt/b/10
mount --make-shared /mnt/b/10
mkdir -p /mnt/b/10/20
mount --rbind /mnt/b /mnt/b/10/20
unshare -Urm --propagation unchaged /bin/sh -c 'sleep 5; if [ $(grep test /proc/self/mountinfo | wc -l) -eq 1 ] ; then echo SUCCESS ; else echo FAILURE ; fi'
sleep 1
umount -l /mnt/b
wait %%
$ unshare -Urm ./locked_mounts_test.sh
This failure is corrected by removing the prepass that marks mounts
that may be umounted.
A first pass is added that umounts mounts if possible and if not sets
mount mark if they could be unmounted if they weren't locked and adds
them to a list to umount possibilities. This first pass reconsiders
the mounts parent if it is on the list of umount possibilities, ensuring
that information of umoutability will pass from child to mount parent.
A second pass then walks through all mounts that are umounted and processes
their children unmounting them or marking them for reparenting.
A last pass cleans up the state on the mounts that could not be umounted
and if applicable reparents them to their first parent that remained
mounted.
While a bit longer than the old code this code is much more robust
as it allows information to flow up from the leaves and down
from the trunk making the order in which mounts are encountered
in the umount propgation tree irrelevant.
Fixes: 0c56fe31420c ("mnt: Don't propagate unmounts to locked mounts")
commit 570487d3faf2a1d8a220e6ee10f472163123d7da upstream.
It was observed that in some pathlogical cases that the current code
does not unmount everything it should. After investigation it
was determined that the issue is that mnt_change_mntpoint can
can change which mounts are available to be unmounted during mount
propagation which is wrong.
The trivial reproducer is:
$ cat ./pathological.sh
cd /mnt
mkdir 1 2 1/1
mount --bind 1 1
mount --make-shared 1
mount --bind 1 2
mount --bind 1/1 1/1
echo
grep test-base /proc/self/mountinfo
umount 1/1
echo
$ unshare -Urm ./pathological.sh
The expected output looks like:
46 31 0:25 / /mnt rw,relatime - tmpfs test-base rw,uid=1000,gid=1000
47 46 0:25 /1 /mnt/1 rw,relatime shared:1 - tmpfs test-base rw,uid=1000,gid=1000
48 46 0:25 /1 /mnt/2 rw,relatime shared:1 - tmpfs test-base rw,uid=1000,gid=1000
49 54 0:25 /1/1 /mnt/1/1 rw,relatime shared:1 - tmpfs test-base rw,uid=1000,gid=1000
50 53 0:25 /1/1 /mnt/2/1 rw,relatime shared:1 - tmpfs test-base rw,uid=1000,gid=1000
51 49 0:25 /1/1 /mnt/1/1 rw,relatime shared:1 - tmpfs test-base rw,uid=1000,gid=1000
54 47 0:25 /1/1 /mnt/1/1 rw,relatime shared:1 - tmpfs test-base rw,uid=1000,gid=1000
53 48 0:25 /1/1 /mnt/2/1 rw,relatime shared:1 - tmpfs test-base rw,uid=1000,gid=1000
52 50 0:25 /1/1 /mnt/2/1 rw,relatime shared:1 - tmpfs test-base rw,uid=1000,gid=1000
The output without the fix looks like:
52 48 0:25 /1/1 /mnt/2/1 rw,relatime shared:1 - tmpfs test-base rw,uid=1000,gid=1000
That last mount in the output was in the propgation tree to be unmounted but
was missed because the mnt_change_mountpoint changed it's parent before the walk
through the mount propagation tree observed it.
Fixes: 1064f874abc0 ("mnt: Tuck mounts under others instead of creating shadow/side mounts.")
Acked-by: Andrei Vagin <avagin@virtuozzo.com>
Reviewed-by: Ram Pai <linuxram@us.ibm.com>
commit da029c11e6b12f321f36dac8771e833b65cec962 upstream.
To avoid pathological stack usage or the need to special-case setuid
execs, just limit all arg stack usage to at most 75% of _STK_LIM (6MB).
commit eab09532d40090698b05a07c1c87f39fdbc5fab5 upstream.
The ELF_ET_DYN_BASE position was originally intended to keep loaders
away from ET_EXEC binaries. (For example, running "/lib/ld-linux.so.2
/bin/cat" might cause the subsequent load of /bin/cat into where the
loader had been loaded.)
With the advent of PIE (ET_DYN binaries with an INTERP Program Header),
ELF_ET_DYN_BASE continued to be used since the kernel was only looking
at ET_DYN. However, since ELF_ET_DYN_BASE is traditionally set at the
top 1/3rd of the TASK_SIZE, a substantial portion of the address space
is unused.
For 32-bit tasks when RLIMIT_STACK is set to RLIM_INFINITY, programs are
loaded above the mmap region. This means they can be made to collide
(CVE-2017-1000370) or nearly collide (CVE-2017-1000371) with
pathological stack regions.
Lowering ELF_ET_DYN_BASE solves both by moving programs below the mmap
region in all cases, and will now additionally avoid programs falling
back to the mmap region by enforcing MAP_FIXED for program loads (i.e.
if it would have collided with the stack, now it will fail to load
instead of falling back to the mmap region).
To allow for a lower ELF_ET_DYN_BASE, loaders (ET_DYN without INTERP)
are loaded into the mmap region, leaving space available for either an
ET_EXEC binary with a fixed location or PIE being loaded into mmap by
the loader. Only PIE programs are loaded offset from ELF_ET_DYN_BASE,
which means architectures can now safely lower their values without risk
of loaders colliding with their subsequently loaded programs.
For 64-bit, ELF_ET_DYN_BASE is best set to 4GB to allow runtimes to use
the entire 32-bit address space for 32-bit pointers.
Thanks to PaX Team, Daniel Micay, and Rik van Riel for inspiration and
suggestions on how to implement this solution.
Fixes: d1fd836dcf00 ("mm: split ET_DYN ASLR from mmap ASLR")
Link: http://lkml.kernel.org/r/20170621173201.GA114489@beast
Cc: Daniel Micay <danielmicay@gmail.com>
Cc: Qualys Security Advisory <qsa@qualys.com>
Cc: Dmitry Safonov <dsafonov@virtuozzo.com>
Cc: Grzegorz Andrejczuk <grzegorz.andrejczuk@intel.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Pratyush Anand <panand@redhat.com>
Cc: Russell King <linux@armlinux.org.uk>
commit b17c070fb624cf10162cf92ea5e1ec25cd8ac176 upstream.
__list_lru_walk_one() acquires nlru spin lock (nlru->lock) for longer
duration if there are more number of items in the lru list. As per the
current code, it can hold the spin lock for upto maximum UINT_MAX
entries at a time. So if there are more number of items in the lru
list, then "BUG: spinlock lockup suspected" is observed in the below
path:
spin_bug+0x90
do_raw_spin_lock+0xfc
_raw_spin_lock+0x28
list_lru_add+0x28
dput+0x1c8
path_put+0x20
terminate_walk+0x3c
path_lookupat+0x100
filename_lookup+0x6c
user_path_at_empty+0x54
SyS_faccessat+0xd0
el0_svc_naked+0x24
This nlru->lock is acquired by another CPU in this path -
d_lru_shrink_move+0x34
dentry_lru_isolate_shrink+0x48
__list_lru_walk_one.isra.10+0x94
list_lru_walk_node+0x40
shrink_dcache_sb+0x60
do_remount_sb+0xbc
do_emergency_remount+0xb0
process_one_work+0x228
worker_thread+0x2e0
kthread+0xf4
ret_from_fork+0x10
Fix this lockup by reducing the number of entries to be shrinked from
the lru list to 1024 at once. Also, add cond_resched() before
processing the lru list again.
Link: http://marc.info/?t=149722864900001&r=1&w=2
Link: http://lkml.kernel.org/r/1498707575-2472-1-git-send-email-stummala@codeaurora.org
Signed-off-by: Sahitya Tummala <stummala@codeaurora.org>
Suggested-by: Jan Kara <jack@suse.cz>
Suggested-by: Vladimir Davydov <vdavydov.dev@gmail.com>
Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com>
Cc: Alexander Polakov <apolyakov@beget.ru>
commit 1ea1516fbbab2b30bf98c534ecaacba579a35208 upstream.
kstrtoull returns 0 on success, however, in reserved_clusters_store we
will return -EINVAL if kstrtoull returns 0, it makes us fail to update
reserved_clusters value through sysfs.
Fixes: 76d33bca5581b1dd5c3157fa168db849a784ada4
Signed-off-by: Chao Yu <yuchao0@huawei.com>
Signed-off-by: Miao Xie <miaoxie@huawei.com>
commit 961ae1d83d055a4b9ebbfb4cc8ca62ec1a7a3b74 upstream.
Before commit 88ffbf3e03 "GFS2: Use resizable hash table for glocks",
glocks were freed via call_rcu to allow reading the glock hashtable
locklessly using rcu. This was then changed to free glocks immediately,
which made reading the glock hashtable unsafe. Bring back the original
code for freeing glocks via call_rcu.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
commit 629e014bb8349fcf7c1e4df19a842652ece1c945 upstream.
Currently we just stash anything we got into file->f_flags, and the
report it in fcntl(F_GETFD). This patch just clears out all unknown
flags so that we don't pass them to the fs or report them.
commit 80f18379a7c350c011d30332658aa15fe49a8fa5 upstream.
Add a central define for all valid open flags, and use it in the uniqueness
check.
commit 33496c3c3d7b88dcbe5e55aa01288b05646c6aca upstream.
Configfs is the interface for ocfs2-tools to set configure to kernel and
$configfs_dir/cluster/$clustername/heartbeat/dead_threshold is the one
used to configure heartbeat dead threshold. Kernel has a default value
of it but user can set O2CB_HEARTBEAT_THRESHOLD in /etc/sysconfig/o2cb
to override it.
Commit 45b997737a80 ("ocfs2/cluster: use per-attribute show and store
methods") changed heartbeat dead threshold name while ocfs2-tools did
not, so ocfs2-tools won't set this configurable and the default value is
always used. So revert it.
Fixes: 45b997737a80 ("ocfs2/cluster: use per-attribute show and store methods")
Link: http://lkml.kernel.org/r/1490665245-15374-1-git-send-email-junxiao.bi@oracle.com
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Acked-by: Joseph Qi <jiangqi903@gmail.com>
Cc: Mark Fasheh <mfasheh@versity.com>
[ Upstream commit 4d22c75d4c7b5c5f4bd31054f09103ee490878fd ]
If the last section of a core file ends with an unmapped or zero page,
the size of the file does not correspond with the last dump_skip() call.
gdb complains that the file is truncated and can be confusing to users.
After all of the vma sections are written, make sure that the file size
is no smaller than the current file position.
This problem can be demonstrated with gdb's bigcore testcase on the
sparc architecture.
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Cc: linux-fsdevel@vger.kernel.org
[ Upstream commit 91298eec05cd8d4e828cf7ee5d4a6334f70cf69a ]
For such a file mapping,
[0-4k][hole][8k-12k]
In NO_HOLES mode, we don't have the [hole] extent any more.
Commit c1aa45759e90 ("Btrfs: fix shrinking truncate when the no_holes feature is enabled")
fixed disk isize not being updated in NO_HOLES mode when data is not flushed.
However, even if data has been flushed, we can still have trouble
in updating disk isize since we updated disk isize to 'start' of
the last evicted extent.
Reviewed-by: Chris Mason <clm@fb.com>
commit 366a1569bff3fe14abfdf9285e31e05e091745f5 upstream.
Because nfs4_opendata_access() has close the state when access is denied,
so the state isn't leak.
Rather than revert the commit a974deee47, I'd like clean the strange state close.
[ 1615.094218] ------------[ cut here ]------------
[ 1615.094607] WARNING: CPU: 0 PID: 23702 at lib/list_debug.c:31 __list_add_valid+0x8e/0xa0
[ 1615.094913] list_add double add: new=ffff9d7901d9f608, prev=ffff9d7901d9f608, next=ffff9d7901ee8dd0.
[ 1615.095458] Modules linked in: nfsv4(E) nfs(E) nfsd(E) tun bridge stp llc fuse ip_set nfnetlink vmw_vsock_vmci_transport vsock f2fs snd_seq_midi snd_seq_midi_event fscrypto coretemp ppdev crct10dif_pclmul crc32_pclmul ghash_clmulni_intel intel_rapl_perf vmw_balloon snd_ens1371 joydev gameport snd_ac97_codec ac97_bus snd_seq snd_pcm snd_rawmidi snd_timer snd_seq_device snd soundcore nfit parport_pc parport acpi_cpufreq tpm_tis tpm_tis_core tpm i2c_piix4 vmw_vmci shpchp auth_rpcgss nfs_acl lockd(E) grace sunrpc(E) xfs libcrc32c vmwgfx drm_kms_helper ttm drm crc32c_intel mptspi e1000 serio_raw scsi_transport_spi mptscsih mptbase ata_generic pata_acpi fjes [last unloaded: nfs]
[ 1615.097663] CPU: 0 PID: 23702 Comm: fstest Tainted: G W E 4.11.0-rc1+ #517
[ 1615.098015] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 07/02/2015
[ 1615.098807] Call Trace:
[ 1615.099183] dump_stack+0x63/0x86
[ 1615.099578] __warn+0xcb/0xf0
[ 1615.099967] warn_slowpath_fmt+0x5f/0x80
[ 1615.100370] __list_add_valid+0x8e/0xa0
[ 1615.100760] nfs4_put_state_owner+0x75/0xc0 [nfsv4]
[ 1615.101136] __nfs4_close+0x109/0x140 [nfsv4]
[ 1615.101524] nfs4_close_state+0x15/0x20 [nfsv4]
[ 1615.101949] nfs4_close_context+0x21/0x30 [nfsv4]
[ 1615.102691] __put_nfs_open_context+0xb8/0x110 [nfs]
[ 1615.103155] put_nfs_open_context+0x10/0x20 [nfs]
[ 1615.103586] nfs4_file_open+0x13b/0x260 [nfsv4]
[ 1615.103978] do_dentry_open+0x20a/0x2f0
[ 1615.104369] ? nfs4_copy_file_range+0x30/0x30 [nfsv4]
[ 1615.104739] vfs_open+0x4c/0x70
[ 1615.105106] ? may_open+0x5a/0x100
[ 1615.105469] path_openat+0x623/0x1420
[ 1615.105823] do_filp_open+0x91/0x100
[ 1615.106174] ? __alloc_fd+0x3f/0x170
[ 1615.106568] do_sys_open+0x130/0x220
[ 1615.106920] ? __put_cred+0x3d/0x50
[ 1615.107256] SyS_open+0x1e/0x20
[ 1615.107588] entry_SYSCALL_64_fastpath+0x1a/0xa9
[ 1615.107922] RIP: 0033:0x7fab599069b0
[ 1615.108247] RSP: 002b:00007ffcf0600d78 EFLAGS: 00000246 ORIG_RAX: 0000000000000002
[ 1615.108575] RAX: ffffffffffffffda RBX: 00007fab59bcfae0 RCX: 00007fab599069b0
[ 1615.108896] RDX: 0000000000000200 RSI: 0000000000000200 RDI: 00007ffcf060255e
[ 1615.109211] RBP: 0000000000040010 R08: 0000000000000000 R09: 0000000000000016
[ 1615.109515] R10: 00000000000006a1 R11: 0000000000000246 R12: 0000000000041000
[ 1615.109806] R13: 0000000000040010 R14: 0000000000001000 R15: 0000000000002710
[ 1615.110152] ---[ end trace 96ed63b1306bf2f3 ]---
Fixes: a974deee47 ("NFSv4: Fix memory and state leak in...")
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
Cc: Trond Myklebust <trond.myklebust@primarydata.com>
commit dcd87838c06f05ab7650b249ebf0d5b57ae63e1e upstream.
Downgrade the loglevel for SMB2 to prevent filling the log
with messages if e.g. readdir was interrupted. Also make SMB2
and SMB1 codepaths do the same logging during readdir.
commit 9fa4eb8e490a28de40964b1b0e583d8db4c7e57c upstream.
If a positive status is passed with the AUTOFS_DEV_IOCTL_FAIL ioctl,
autofs4_d_automount() will return
ERR_PTR(status)
with that status to follow_automount(), which will then dereference an
invalid pointer.
So treat a positive status the same as zero, and map to ENOENT.
See comment in systemd src/core/automount.c::automount_send_ready().
Link: http://lkml.kernel.org/r/871sqwczx5.fsf@notabene.neil.brown.name
Cc: Ian Kent <raven@themaw.net>
commit 98da7d08850fb8bdeb395d6368ed15753304aa0c upstream.
When limiting the argv/envp strings during exec to 1/4 of the stack limit,
the storage of the pointers to the strings was not included. This means
that an exec with huge numbers of tiny strings could eat 1/4 of the stack
limit in strings and then additional space would be later used by the
pointers to the strings.
For example, on 32-bit with a 8MB stack rlimit, an exec with 1677721
single-byte strings would consume less than 2MB of stack, the max (8MB /
4) amount allowed, but the pointers to the strings would consume the
remaining additional stack space (1677721 * 4 == 6710884).
The result (1677721 + 6710884 == 8388605) would exhaust stack space
entirely. Controlling this stack exhaustion could result in
pathological behavior in setuid binaries (CVE-2017-1000365).
[akpm@linux-foundation.org: additional commenting from Kees]
Fixes: b6a2fea39318 ("mm: variable length argument support")
Link: http://lkml.kernel.org/r/20170622001720.GA32173@beast
commit 1be7107fbe18eed3e319a6c3e83c78254b693acb upstream.
Stack guard page is a useful feature to reduce a risk of stack smashing
into a different mapping. We have been using a single page gap which
is sufficient to prevent having stack adjacent to a different mapping.
But this seems to be insufficient in the light of the stack usage in
userspace. E.g. glibc uses as large as 64kB alloca() in many commonly
used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX]
which is 256kB or stack strings with MAX_ARG_STRLEN.
This will become especially dangerous for suid binaries and the default
no limit for the stack size limit because those applications can be
tricked to consume a large portion of the stack and a single glibc call
could jump over the guard page. These attacks are not theoretical,
unfortunatelly.
Make those attacks less probable by increasing the stack guard gap
to 1MB (on systems with 4k pages; but make it depend on the page size
because systems with larger base pages might cap stack allocations in
the PAGE_SIZE units) which should cover larger alloca() and VLA stack
allocations. It is obviously not a full fix because the problem is
somehow inherent, but it should reduce attack space a lot.
One could argue that the gap size should be configurable from userspace,
but that can be done later when somebody finds that the new 1MB is wrong
for some special case applications. For now, add a kernel command line
option (stack_guard_gap) to specify the stack gap size (in page units).
Implementation wise, first delete all the old code for stack guard page:
because although we could get away with accounting one extra page in a
stack vma, accounting a larger gap can break userspace - case in point,
a program run with "ulimit -S -v 20000" failed when the 1MB gap was
counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK
and strict non-overcommit mode.
Instead of keeping gap inside the stack vma, maintain the stack guard
gap as a gap between vmas: using vm_start_gap() in place of vm_start
(or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few
places which need to respect the gap - mainly arch_get_unmapped_area(),
and and the vma tree's subtree_gap support for that.
Original-patch-by: Oleg Nesterov <oleg@redhat.com>
Original-patch-by: Michal Hocko <mhocko@suse.com>
Tested-by: Helge Deller <deller@gmx.de> # parisc
[wt: backport to 4.11: adjust context]
[wt: backport to 4.9: adjust context ; kernel doc was not in admin-guide]
[wt: backport to 4.4: adjust context ; drop ppc hugetlb_radix changes]
Signed-off-by: Willy Tarreau <w@1wt.eu>
[gkh: minor build fixes for 4.4]
commit ba80aa909c99802c428682c352b0ee0baac0acd3 upstream.
This patch closes a long standing race in configfs between
the creation of a new symlink in create_link(), while the
symlink target's config_item is being concurrently removed
via configfs_rmdir().
This can happen because the symlink target's reference
is obtained by config_item_get() in create_link() before
the CONFIGFS_USET_DROPPING bit set by configfs_detach_prep()
during configfs_rmdir() shutdown is actually checked..
This originally manifested itself on ppc64 on v4.8.y under
heavy load using ibmvscsi target ports with Novalink API:
[ 7877.289863] rpadlpar_io: slot U8247.22L.212A91A-V1-C8 added
[ 7879.893760] ------------[ cut here ]------------
[ 7879.893768] WARNING: CPU: 15 PID: 17585 at ./include/linux/kref.h:46 config_item_get+0x7c/0x90 [configfs]
[ 7879.893811] CPU: 15 PID: 17585 Comm: targetcli Tainted: G O 4.8.17-customv2.22 #12
[ 7879.893812] task: c00000018a0d3400 task.stack: c0000001f3b40000
[ 7879.893813] NIP: d000000002c664ec LR: d000000002c60980 CTR: c000000000b70870
[ 7879.893814] REGS: c0000001f3b43810 TRAP: 0700 Tainted: G O (4.8.17-customv2.22)
[ 7879.893815] MSR: 8000000000029033 <SF,EE,ME,IR,DR,RI,LE> CR: 28222242 XER: 00000000
[ 7879.893820] CFAR: d000000002c664bc SOFTE: 1
GPR00: d000000002c60980 c0000001f3b43a90 d000000002c70908 c0000000fbc06820
GPR04: c0000001ef1bd900 0000000000000004 0000000000000001 0000000000000000
GPR08: 0000000000000000 0000000000000001 d000000002c69560 d000000002c66d80
GPR12: c000000000b70870 c00000000e798700 c0000001f3b43ca0 c0000001d4949d40
GPR16: c00000014637e1c0 0000000000000000 0000000000000000 c0000000f2392940
GPR20: c0000001f3b43b98 0000000000000041 0000000000600000 0000000000000000
GPR24: fffffffffffff000 0000000000000000 d000000002c60be0 c0000001f1dac490
GPR28: 0000000000000004 0000000000000000 c0000001ef1bd900 c0000000f2392940
[ 7879.893839] NIP [d000000002c664ec] config_item_get+0x7c/0x90 [configfs]
[ 7879.893841] LR [d000000002c60980] check_perm+0x80/0x2e0 [configfs]
[ 7879.893842] Call Trace:
[ 7879.893844] [c0000001f3b43ac0] [d000000002c60980] check_perm+0x80/0x2e0 [configfs]
[ 7879.893847] [c0000001f3b43b10] [c000000000329770] do_dentry_open+0x2c0/0x460
[ 7879.893849] [c0000001f3b43b70] [c000000000344480] path_openat+0x210/0x1490
[ 7879.893851] [c0000001f3b43c80] [c00000000034708c] do_filp_open+0xfc/0x170
[ 7879.893853] [c0000001f3b43db0] [c00000000032b5bc] do_sys_open+0x1cc/0x390
[ 7879.893856] [c0000001f3b43e30] [c000000000009584] system_call+0x38/0xec
[ 7879.893856] Instruction dump:
[ 7879.893858] 409d0014 38210030 e8010010 7c0803a6 4e800020 3d220000 e94981e0 892a0000
[ 7879.893861] 2f890000 409effe0 39200001 992a0000 <0fe00000> 4bffffd0 60000000 60000000
[ 7879.893866] ---[ end trace 14078f0b3b5ad0aa ]---
To close this race, go ahead and obtain the symlink's target
config_item reference only after the existing CONFIGFS_USET_DROPPING
check succeeds.
This way, if configfs_rmdir() wins create_link() will return -ENONET,
and if create_link() wins configfs_rmdir() will return -EBUSY.
Reported-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com>
Tested-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com>
[ Upstream commit 3ba4bceef23206349d4130ddf140819b365de7c8 ]
We have seen proc_pid_readdir() invocations holding cpu for more than 50
ms. Add a cond_resched() to be gentle with other tasks.
[akpm@linux-foundation.org: coding style fix]
Link: http://lkml.kernel.org/r/1484238380.15816.42.camel@edumazet-glaptop3.roam.corp.google.com
