commit 5fd364fee81a7888af806e42ed8a91c845894f2d upstream.
When running xfs/305, I noticed that quotacheck was flushing dquot
buffers that did not have the xfs_dquot_buf_ops verifiers attached:
XFS (vdb): _xfs_buf_ioapply: no ops on block 0x1dc8/0x1dc8
ffff880052489000: 44 51 01 04 00 00 65 b8 00 00 00 00 00 00 00 00 DQ....e.........
ffff880052489010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
ffff880052489020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
ffff880052489030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
CPU: 1 PID: 2376 Comm: mount Not tainted 3.16.0-rc2-dgc+ #306
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
ffff88006fe38000 ffff88004a0ffae8 ffffffff81cf1cca 0000000000000001
ffff88004a0ffb88 ffffffff814d50ca 000010004a0ffc70 0000000000000000
ffff88006be56dc4 0000000000000021 0000000000001dc8 ffff88007c773d80
Call Trace:
[<ffffffff81cf1cca>] dump_stack+0x45/0x56
[<ffffffff814d50ca>] _xfs_buf_ioapply+0x3ca/0x3d0
[<ffffffff810db520>] ? wake_up_state+0x20/0x20
[<ffffffff814d51f5>] ? xfs_bdstrat_cb+0x55/0xb0
[<ffffffff814d513b>] xfs_buf_iorequest+0x6b/0xd0
[<ffffffff814d51f5>] xfs_bdstrat_cb+0x55/0xb0
[<ffffffff814d53ab>] __xfs_buf_delwri_submit+0x15b/0x220
[<ffffffff814d6040>] ? xfs_buf_delwri_submit+0x30/0x90
[<ffffffff814d6040>] xfs_buf_delwri_submit+0x30/0x90
[<ffffffff8150f89d>] xfs_qm_quotacheck+0x17d/0x3c0
[<ffffffff81510591>] xfs_qm_mount_quotas+0x151/0x1e0
[<ffffffff814ed01c>] xfs_mountfs+0x56c/0x7d0
[<ffffffff814f0f12>] xfs_fs_fill_super+0x2c2/0x340
[<ffffffff811c9fe4>] mount_bdev+0x194/0x1d0
[<ffffffff814f0c50>] ? xfs_finish_flags+0x170/0x170
[<ffffffff814ef0f5>] xfs_fs_mount+0x15/0x20
[<ffffffff811ca8c9>] mount_fs+0x39/0x1b0
[<ffffffff811e4d67>] vfs_kern_mount+0x67/0x120
[<ffffffff811e757e>] do_mount+0x23e/0xad0
[<ffffffff8117abde>] ? __get_free_pages+0xe/0x50
[<ffffffff811e71e6>] ? copy_mount_options+0x36/0x150
[<ffffffff811e8103>] SyS_mount+0x83/0xc0
[<ffffffff81cfd40b>] tracesys+0xdd/0xe2
This was caused by dquot buffer readahead not attaching a verifier
structure to the buffer when readahead was issued, resulting in the
followup read of the buffer finding a valid buffer and so not
attaching new verifiers to the buffer as part of the read.
Also, when a verifier failure occurs, we then read the buffer
without verifiers. Attach the verifiers manually after this read so
that if the buffer is then written it will be verified that the
corruption has been repaired.
Further, when flushing a dquot we don't ask for a verifier when
reading in the dquot buffer the dquot belongs to. Most of the time
this isn't an issue because the buffer is still cached, but when it
is not cached it will result in writing the dquot buffer without
having the verfier attached.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
commit 67dc288c21064b31a98a53dc64f6b9714b819fd6 upstream.
Crash testing of CRC enabled filesystems has resulted in a number of
reports of bad CRCs being detected after the filesystem was mounted.
Errors such as the following were being seen:
XFS (sdb3): Mounting V5 Filesystem
XFS (sdb3): Starting recovery (logdev: internal)
XFS (sdb3): Metadata CRC error detected at xfs_agf_read_verify+0x5a/0x100 [xfs], block 0x1
XFS (sdb3): Unmount and run xfs_repair
XFS (sdb3): First 64 bytes of corrupted metadata buffer:
ffff880136ffd600: 58 41 47 46 00 00 00 01 00 00 00 00 00 0f aa 40 XAGF...........@
ffff880136ffd610: 00 02 6d 53 00 02 77 f8 00 00 00 00 00 00 00 01 ..mS..w.........
ffff880136ffd620: 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 03 ................
ffff880136ffd630: 00 00 00 04 00 08 81 d0 00 08 81 a7 00 00 00 00 ................
XFS (sdb3): metadata I/O error: block 0x1 ("xfs_trans_read_buf_map") error 74 numblks 1
The errors were typically being seen in AGF, AGI and their related
btree block buffers some time after log recovery had run. Often it
wasn't until later subsequent mounts that the problem was
discovered. The common symptom was a buffer with the correct
contents, but a CRC and an LSN that matched an older version of the
contents.
Some debug added to _xfs_buf_ioapply() indicated that buffers were
being written without verifiers attached to them from log recovery,
and Jan Kara isolated the cause to log recovery readahead an dit's
interactions with buffers that had a more recent LSN on disk than
the transaction being recovered. In this case, the buffer did not
get a verifier attached, and os when the second phase of log
recovery ran and recovered EFIs and unlinked inodes, the buffers
were modified and written without the verifier running. Hence they
had up to date contents, but stale LSNs and CRCs.
Fix it by attaching verifiers to buffers we skip due to future LSN
values so they don't escape into the buffer cache without the
correct verifier attached.
This patch is based on analysis and a patch from Jan Kara.
Reported-by: Jan Kara <jack@suse.cz>
Reported-by: Fanael Linithien <fanael4@gmail.com>
Reported-by: Grozdan <neutrino8@gmail.com>
commit 12a5b5294cb1896e9a3c9fca8ff5a7e3def4e8c6 upstream.
Since 3.14 we had copy_tree() get the shadowing wrong - if we had one
vfsmount shadowing another (i.e. if A is a slave of B, C is mounted
on A/foo, then D got mounted on B/foo creating D' on A/foo shadowed
by C), copy_tree() of A would make a copy of D' shadow the the copy of
C, not the other way around.
It's easy to fix, fortunately - just make sure that mount follows
the one that shadows it in mnt_child as well as in mnt_hash, and when
copy_tree() decides to attach a new mount, check if the last child
it has added to the same parent should be shadowing the new one.
And if it should, just use the same logics commit_tree() has - put the
new mount into the hash and children lists right after the one that
should shadow it.
commit 81b6b06197606b4bef4e427a197aeb808e8d89e1 upstream.
We need the parents of victims alive until namespace_unlock() gets to
dput() of the (ex-)mountpoints. However, that screws up the "is it
busy" checks in case when we have shrinkable mounts that need to be
killed. Solution: go ahead and decrement refcounts of parents right
in umount_tree(), increment them again just before dropping rwsem in
namespace_unlock() (and let the loop in the end of namespace_unlock()
finally drop those references for good, as we do now). Parents can't
get freed until we drop rwsem - at least one reference is kept until
then, both in case when parent is among the victims and when it is
not. So they'll still be around when we get to namespace_unlock().
commit 88b368f27a094277143d8ecd5a056116f6a41520 upstream.
The check in __propagate_umount() ("has somebody explicitly mounted
something on that slave?") is done *before* taking the already doomed
victims out of the child lists.
commit ffbc6f0ead47fa5a1dc9642b0331cb75c20a640e upstream.
Since March 2009 the kernel has treated the state that if no
MS_..ATIME flags are passed then the kernel defaults to relatime.
Defaulting to relatime instead of the existing atime state during a
remount is silly, and causes problems in practice for people who don't
specify any MS_...ATIME flags and to get the default filesystem atime
setting. Those users may encounter a permission error because the
default atime setting does not work.
A default that does not work and causes permission problems is
ridiculous, so preserve the existing value to have a default
atime setting that is always guaranteed to work.
Using the default atime setting in this way is particularly
interesting for applications built to run in restricted userspace
environments without /proc mounted, as the existing atime mount
options of a filesystem can not be read from /proc/mounts.
In practice this fixes user space that uses the default atime
setting on remount that are broken by the permission checks
keeping less privileged users from changing more privileged users
atime settings.
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
commit 9566d6742852c527bf5af38af5cbb878dad75705 upstream.
While invesgiating the issue where in "mount --bind -oremount,ro ..."
would result in later "mount --bind -oremount,rw" succeeding even if
the mount started off locked I realized that there are several
additional mount flags that should be locked and are not.
In particular MNT_NOSUID, MNT_NODEV, MNT_NOEXEC, and the atime
flags in addition to MNT_READONLY should all be locked. These
flags are all per superblock, can all be changed with MS_BIND,
and should not be changable if set by a more privileged user.
The following additions to the current logic are added in this patch.
- nosuid may not be clearable by a less privileged user.
- nodev may not be clearable by a less privielged user.
- noexec may not be clearable by a less privileged user.
- atime flags may not be changeable by a less privileged user.
The logic with atime is that always setting atime on access is a
global policy and backup software and auditing software could break if
atime bits are not updated (when they are configured to be updated),
and serious performance degradation could result (DOS attack) if atime
updates happen when they have been explicitly disabled. Therefore an
unprivileged user should not be able to mess with the atime bits set
The additional restrictions are implemented with the addition of
MNT_LOCK_NOSUID, MNT_LOCK_NODEV, MNT_LOCK_NOEXEC, and MNT_LOCK_ATIME
mnt flags.
Taken together these changes and the fixes for MNT_LOCK_READONLY
should make it safe for an unprivileged user to create a user
namespace and to call "mount --bind -o remount,... ..." without
the danger of mount flags being changed maliciously.
commit 07b645589dcda8b7a5249e096fece2a67556f0f4 upstream.
There are no races as locked mount flags are guaranteed to never change.
Moving the test into do_remount makes it more visible, and ensures all
filesystem remounts pass the MNT_LOCK_READONLY permission check. This
second case is not an issue today as filesystem remounts are guarded
by capable(CAP_DAC_ADMIN) and thus will always fail in less privileged
mount namespaces, but it could become an issue in the future.
commit a6138db815df5ee542d848318e5dae681590fccd upstream.
Kenton Varda <kenton@sandstorm.io> discovered that by remounting a
read-only bind mount read-only in a user namespace the
MNT_LOCK_READONLY bit would be cleared, allowing an unprivileged user
to the remount a read-only mount read-write.
Correct this by replacing the mask of mount flags to preserve
with a mask of mount flags that may be changed, and preserve
all others. This ensures that any future bugs with this mask and
remount will fail in an easy to detect way where new mount flags
simply won't change.
commit 2b462638e41ea62230297c21c4da9955937b7a3c upstream.
If we failed to copy from the structure, writing back the flags leaks 31
bits of kernel memory (the rest of the ir_flags field).
In any case, if we cannot copy from/to the structure, why should we
expect putting just the flags to work?
Also make sure ocfs2_info_handle_freeinode() returns the right error
code if the copy_to_user() fails.
Fixes: ddee5cdb70e6 ('Ocfs2: Add new OCFS2_IOC_INFO ioctl for ocfs2 v8.')
Acked-by: Mark Fasheh <mfasheh@suse.com>
commit 5838d4442bd5971687b72221736222637e03140d upstream.
Commit 85816794240b ("fanotify: Fix use after free for permission
events") introduced a double free issue for permission events which are
pending in group's notification queue while group is being destroyed.
These events are freed from fanotify_handle_event() but they are not
removed from groups notification queue and thus they get freed again
from fsnotify_flush_notify().
Fix the problem by removing permission events from notification queue
before freeing them if we skip processing access response. Also expand
comments in fanotify_release() to explain group shutdown in detail.
Fixes: 85816794240b9659e66e4d9b0df7c6e814e5f603
Reported-by: Douglas Leeder <douglas.leeder@sophos.com>
Tested-by: Douglas Leeder <douglas.leeder@sophos.com>
Reported-by: Heinrich Schuchard <xypron.glpk@gmx.de>
commit 7d8b6c63751cfbbe5eef81a48c22978b3407a3ad upstream.
This is effectively a revert of 7b9a7ec565505699f503b4fcf61500dceb36e744
plus fixing it a different way...
We found, when trying to run an application from an application which
had dropped privs that the kernel does security checks on undefined
capability bits. This was ESPECIALLY difficult to debug as those
undefined bits are hidden from /proc/$PID/status.
Consider a root application which drops all capabilities from ALL 4
capability sets. We assume, since the application is going to set
eff/perm/inh from an array that it will clear not only the defined caps
less than CAP_LAST_CAP, but also the higher 28ish bits which are
undefined future capabilities.
The BSET gets cleared differently. Instead it is cleared one bit at a
time. The problem here is that in security/commoncap.c::cap_task_prctl()
we actually check the validity of a capability being read. So any task
which attempts to 'read all things set in bset' followed by 'unset all
things set in bset' will not even attempt to unset the undefined bits
higher than CAP_LAST_CAP.
So the 'parent' will look something like:
CapInh: 0000000000000000
CapPrm: 0000000000000000
CapEff: 0000000000000000
CapBnd: ffffffc000000000
All of this 'should' be fine. Given that these are undefined bits that
aren't supposed to have anything to do with permissions. But they do...
So lets now consider a task which cleared the eff/perm/inh completely
and cleared all of the valid caps in the bset (but not the invalid caps
it couldn't read out of the kernel). We know that this is exactly what
the libcap-ng library does and what the go capabilities library does.
They both leave you in that above situation if you try to clear all of
you capapabilities from all 4 sets. If that root task calls execve()
the child task will pick up all caps not blocked by the bset. The bset
however does not block bits higher than CAP_LAST_CAP. So now the child
task has bits in eff which are not in the parent. These are
'meaningless' undefined bits, but still bits which the parent doesn't
have.
The problem is now in cred_cap_issubset() (or any operation which does a
subset test) as the child, while a subset for valid cap bits, is not a
subset for invalid cap bits! So now we set durring commit creds that
the child is not dumpable. Given it is 'more priv' than its parent. It
also means the parent cannot ptrace the child and other stupidity.
The solution here:
1) stop hiding capability bits in status
This makes debugging easier!
2) stop giving any task undefined capability bits. it's simple, it you
don't put those invalid bits in CAP_FULL_SET you won't get them in init
and you won't get them in any other task either.
This fixes the cap_issubset() tests and resulting fallout (which
made the init task in a docker container untraceable among other
things)
3) mask out undefined bits when sys_capset() is called as it might use
~0, ~0 to denote 'all capabilities' for backward/forward compatibility.
This lets 'capsh --caps="all=eip" -- -c /bin/bash' run.
4) mask out undefined bit when we read a file capability off of disk as
again likely all bits are set in the xattr for forward/backward
compatibility.
This lets 'setcap all+pe /bin/bash; /bin/bash' run
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: Andrew Vagin <avagin@openvz.org>
Cc: Andrew G. Morgan <morgan@kernel.org>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Steve Grubb <sgrubb@redhat.com>
Cc: Dan Walsh <dwalsh@redhat.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 01777836c87081e4f68c4a43c9abe6114805f91e upstream.
If do_journal_release() races with do_journal_end() which requeues
delayed works for transaction flushing, we can leave work items for
flushing outstanding transactions queued while freeing them. That
results in use after free and possible crash in run_timers_softirq().
Fix the problem by not requeueing works if superblock is being shut down
(MS_ACTIVE not set) and using cancel_delayed_work_sync() in
do_journal_release().
commit 27d0e5bc85f3341b9ba66f0c23627cf9d7538c9d upstream.
Commits f1f007c308e (reiserfs: balance_leaf refactor, pull out
balance_leaf_insert_left) and cf22df182bf (reiserfs: balance_leaf
refactor, pull out balance_leaf_paste_left) missed that the `body'
pointer was getting repositioned. Subsequent users of the pointer
would expect it to be repositioned, and as a result, parts of the
tree would get overwritten. The most common observed corruption
is indirect block pointers being overwritten.
Since the body value isn't actually used anymore in the called routines,
we can pass back the offset it should be shifted. We constify the body
and ih pointers in the balance_leaf as a mostly-free preventative measure.
Reported-and-tested-by: Jeff Chua <jeff.chua.linux@gmail.com>
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit aee7af356e151494d5014f57b33460b162f181b5 upstream.
In the presence of delegations, we can no longer assume that the
state->n_rdwr, state->n_rdonly, state->n_wronly reflect the open
stateid share mode, and so we need to calculate the initial value
for calldata->arg.fmode using the state->flags.
Reported-by: James Drews <drews@engr.wisc.edu>
Fixes: 88069f77e1ac5 (NFSv41: Fix a potential state leakage when...)
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 412f6c4c26fb1eba8844290663837561ac53fa6e upstream.
If we did an OPEN_DOWNGRADE, then the right thing to do on success, is
to apply the new open mode to the struct nfs4_state. Instead, we were
unconditionally clearing the state, making it appear to our state
machinery as if we had just performed a CLOSE.
Fixes: 226056c5c312b (NFSv4: Use correct locking when updating nfs4_state...)
commit f87d928f6d98644d39809a013a22f981d39017cf upstream.
When creating a new object on the NFS server, we should not be sending
posix setacl requests unless the preceding posix_acl_create returned a
non-trivial acl. Doing so, causes Solaris servers in particular to
return an EINVAL.
Fixes: 013cdf1088d72 (nfs: use generic posix ACL infrastructure,,,)
Resolves: https://bugzilla.redhat.com/show_bug.cgi?id=1132786
commit 3c45ddf823d679a820adddd53b52c6699c9a05ac upstream.
The current code always selects XPRT_TRANSPORT_BC_TCP for the back
channel, even when the forward channel was not TCP (eg, RDMA). When
a 4.1 mount is attempted with RDMA, the server panics in the TCP BC
code when trying to send CB_NULL.
Instead, construct the transport protocol number from the forward
channel transport or'd with XPRT_TRANSPORT_BC. Transports that do
not support bi-directional RPC will not have registered a "BC"
transport, causing create_backchannel_client() to fail immediately.
Fixes: https://bugzilla.linux-nfs.org/show_bug.cgi?id=265
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 71a6ec8ac587418ceb6b420def1ca44b334c1ff7 upstream.
Commit c8e47028 made it possible to change resvport/noresvport and
sharecache/nosharecache via a remount operation, neither of which should be
allowed.
Signed-off-by: Scott Mayhew <smayhew@redhat.com>
Fixes: c8e47028 (nfs: Apply NFS_MOUNT_CMP_FLAGMASK to nfs_compare_remount_data)
commit 7a9e75a185e6b3a3860e6a26fb6e88691fc2c9d9 upstream.
There was a check for result being not NULL. But get_acl() may return
NULL, or ERR_PTR, or actual pointer.
The purpose of the function where current change is done is to "list
ACLs only when they are available", so any error condition of get_acl()
mustn't be elevated, and returning 0 there is still valid.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81111
Signed-off-by: Andrey Utkin <andrey.krieger.utkin@gmail.com>
Fixes: 74adf83f5d77 (nfs: only show Posix ACLs in listxattr if actually...)
commit d9499a95716db0d4bc9b67e88fd162133e7d6b08 upstream.
A memory allocation failure could cause nfsd_startup_generic to fail, in
which case nfsd_users wouldn't be incorrectly left elevated.
After nfsd restarts nfsd_startup_generic will then succeed without doing
anything--the first consequence is likely nfs4_start_net finding a bad
laundry_wq and crashing.
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
Fixes: 4539f14981ce "nfsd: replace boolean nfsd_up flag by users counter"
commit db9ee220361de03ee86388f9ea5e529eaad5323c upstream.
It turns out that there are some serious problems with the on-disk
format of journal checksum v2. The foremost is that the function to
calculate descriptor tag size returns sizes that are too big. This
causes alignment issues on some architectures and is compounded by the
fact that some parts of jbd2 use the structure size (incorrectly) to
determine the presence of a 64bit journal instead of checking the
feature flags.
Therefore, introduce journal checksum v3, which enlarges the
descriptor block tag format to allow for full 32-bit checksums of
journal blocks, fix the journal tag function to return the correct
sizes, and fix the jbd2 recovery code to use feature flags to
determine 64bitness.
Add a few function helpers so we don't have to open-code quite so
many pieces.
Switching to a 16-byte block size was found to increase journal size
overhead by a maximum of 0.1%, to convert a 32-bit journal with no
checksumming to a 32-bit journal with checksum v3 enabled.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Reported-by: TR Reardon <thomas_reardon@hotmail.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 022eaa7517017efe4f6538750c2b59a804dc7df7 upstream.
When recovering the journal, don't fall into an infinite loop if we
encounter a corrupt journal block. Instead, just skip the block and
return an error, which fails the mount and thus forces the user to run
a full filesystem fsck.
commit d80d448c6c5bdd32605b78a60fe8081d82d4da0f upstream.
When performing a same-directory rename, it's possible that adding or
setting the new directory entry will cause the directory to overflow
the inline data area, which causes the directory to be converted to an
extent-based directory. Under this circumstance it is necessary to
re-read the directory when deleting the old dirent because the "old
directory" context still points to i_block in the inode table, which
is now an extent tree root! The delete fails with an FS error, and
the subsequent fsck complains about incorrect link counts and
hardlinked directories.
Test case (originally found with flat_dir_test in the metadata_csum
test program):
# mkfs.ext4 -O inline_data /dev/sda
# mount /dev/sda /mnt
# mkdir /mnt/x
# touch /mnt/x/changelog.gz /mnt/x/copyright /mnt/x/README.Debian
# sync
# for i in /mnt/x/*; do mv $i $i.longer; done
# ls -la /mnt/x/
total 0
-rw-r--r-- 1 root root 0 Aug 25 12:03 changelog.gz.longer
-rw-r--r-- 1 root root 0 Aug 25 12:03 copyright
-rw-r--r-- 1 root root 0 Aug 25 12:03 copyright.longer
-rw-r--r-- 1 root root 0 Aug 25 12:03 README.Debian.longer
(Hey! Why are there four files now??)
commit 6603120e96eae9a5d6228681ae55c7fdc998d1bb upstream.
In case of delalloc block i_disksize may be less than i_size. So we
have to update i_disksize each time we allocated and submitted some
blocks beyond i_disksize. We weren't doing this on the error paths,
so fix this.
testcase: xfstest generic/019
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
commit c174e6d6979a04b7b77b93f244396be4b81f8bfb upstream.
After commit f282ac19d86f we use different transactions for
preallocation and i_disksize update which result in complain from fsck
after power-failure. spotted by generic/019. IMHO this is regression
because fs becomes inconsistent, even more 'e2fsck -p' will no longer
works (which drives admins go crazy) Same transaction requirement
applies ctime,mtime updates
commit 69dc9536405213c1d545fcace1fc15c481d00aae upstream.
Currently we reserve only 4 blocks but in worst case scenario
ext4_zero_partial_blocks() may want to zeroout and convert two
non adjacent blocks.
commit 4631dbf677ded0419fee35ca7408285dabfaef1a upstream.
commit 9e0af23764344f7f1b68e4eefbe7dc865018b63d upstream.
This has been reported and discussed for a long time, and this hang occurs in
both 3.15 and 3.16.
Btrfs now migrates to use kernel workqueue, but it introduces this hang problem.
Btrfs has a kind of work queued as an ordered way, which means that its
ordered_func() must be processed in the way of FIFO, so it usually looks like --
normal_work_helper(arg)
work = container_of(arg, struct btrfs_work, normal_work);
work->func() <---- (we name it work X)
for ordered_work in wq->ordered_list
ordered_work->ordered_func()
ordered_work->ordered_free()
The hang is a rare case, first when we find free space, we get an uncached block
group, then we go to read its free space cache inode for free space information,
so it will
file a readahead request
btrfs_readpages()
for page that is not in page cache
__do_readpage()
submit_extent_page()
btrfs_submit_bio_hook()
btrfs_bio_wq_end_io()
submit_bio()
end_workqueue_bio() <--(ret by the 1st endio)
queue a work(named work Y) for the 2nd
also the real endio()
So the hang occurs when work Y's work_struct and work X's work_struct happens
to share the same address.
A bit more explanation,
A,B,C -- struct btrfs_work
arg -- struct work_struct
kthread:
worker_thread()
pick up a work_struct from @worklist
process_one_work(arg)
worker->current_work = arg; <-- arg is A->normal_work
worker->current_func(arg)
A = container_of(arg, struct btrfs_work, normal_work);
A->func()
A->ordered_func()
A->ordered_free() <-- A gets freed
B->ordered_func()
submit_compressed_extents()
find_free_extent()
load_free_space_inode()
... <-- (the above readhead stack)
end_workqueue_bio()
btrfs_queue_work(work C)
B->ordered_free()
As if work A has a high priority in wq->ordered_list and there are more ordered
works queued after it, such as B->ordered_func(), its memory could have been
freed before normal_work_helper() returns, which means that kernel workqueue
code worker_thread() still has worker->current_work pointer to be work
A->normal_work's, ie. arg's address.
Meanwhile, work C is allocated after work A is freed, work C->normal_work
and work A->normal_work are likely to share the same address(I confirmed this
with ftrace output, so I'm not just guessing, it's rare though).
When another kthread picks up work C->normal_work to process, and finds our
kthread is processing it(see find_worker_executing_work()), it'll think
work C as a collision and skip then, which ends up nobody processing work C.
So the situation is that our kthread is waiting forever on work C.
Besides, there're other cases that can lead to deadlock, but the real problem
is that all btrfs workqueue shares one work->func, -- normal_work_helper,
so this makes each workqueue to have its own helper function, but only a
wraper pf normal_work_helper.
With this patch, I no long hit the above hang.
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
Signed-off-by: Chris Mason <clm@fb.com>
commit f6dc45c7a93a011dff6eb9b2ffda59c390c7705a upstream.
We should only be flushing on close if the file was flagged as needing
it during truncate. I broke this with my ordered data vs transaction
commit deadlock fix.
Thanks to Miao Xie for catching this.
Reported-by: Miao Xie <miaox@cn.fujitsu.com>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
commit 38c1c2e44bacb37efd68b90b3f70386a8ee370ee upstream.
The crash is
kernel BUG at fs/btrfs/extent_io.c:2124!
Workqueue: btrfs-endio normal_work_helper [btrfs]
RIP: 0010:[<ffffffffa02d6055>] [<ffffffffa02d6055>] end_bio_extent_readpage+0xb45/0xcd0 [btrfs]
This is in fact a regression.
It is because we forgot to increase @offset properly in reading corrupted block,
so that the @offset remains, and this leads to checksum errors while reading
left blocks queued up in the same bio, and then ends up with hiting the above
BUG_ON.
Reported-by: Chris Murphy <lists@colorremedies.com>
commit 8d875f95da43c6a8f18f77869f2ef26e9594fecc upstream.
Truncates and renames are often used to replace old versions of a file
with new versions. Applications often expect this to be an atomic
replacement, even if they haven't done anything to make sure the new
version is fully on disk.
Btrfs has strict flushing in place to make sure that renaming over an
old file with a new file will fully flush out the new file before
allowing the transaction commit with the rename to complete.
This ordering means the commit code needs to be able to lock file pages,
and there are a few paths in the filesystem where we will try to end a
transaction with the page lock held. It's rare, but these things can
deadlock.
This patch removes the ordered flushes and switches to a best effort
filemap_flush like ext4 uses. It's not perfect, but it should fix the
deadlocks.
commit ce62003f690dff38d3164a632ec69efa15c32cbf upstream.
When failing to allocate space for the whole compressed extent, we'll
fallback to uncompressed IO, but we've forgotten to redirty the pages
which belong to this compressed extent, and these 'clean' pages will
simply skip 'submit' part and go to endio directly, at last we got data
corruption as we write nothing.
Tested-By: Martin Steigerwald <martin@lichtvoll.de>
commit 6f7ff6d7832c6be13e8c95598884dbc40ad69fb7 upstream.
Before processing the extent buffer, acquire a read lock on it, so
that we're safe against concurrent updates on the extent buffer.
Signed-off-by: Filipe Manana <fdmanana@suse.com>
commit 27b9a8122ff71a8cadfbffb9c4f0694300464f3b upstream.
Under rare circumstances we can end up leaving 2 versions of a checksum
for the same file extent range.
The reason for this is that after calling btrfs_next_leaf we process
slot 0 of the leaf it returns, instead of processing the slot set in
path->slots[0]. Most of the time (by far) path->slots[0] is 0, but after
btrfs_next_leaf() releases the path and before it searches for the next
leaf, another task might cause a split of the next leaf, which migrates
some of its keys to the leaf we were processing before calling
btrfs_next_leaf(). In this case btrfs_next_leaf() returns again the
same leaf but with path->slots[0] having a slot number corresponding
to the first new key it got, that is, a slot number that didn't exist
before calling btrfs_next_leaf(), as the leaf now has more keys than
it had before. So we must really process the returned leaf starting at
path->slots[0] always, as it isn't always 0, and the key at slot 0 can
have an offset much lower than our search offset/bytenr.
For example, consider the following scenario, where we have:
sums->bytenr: 40157184, sums->len: 16384, sums end: 40173568
four 4kb file data blocks with offsets 40157184, 40161280, 40165376, 40169472
Leaf N:
slot = 0 slot = btrfs_header_nritems() - 1
| [(CSUM CSUM 39239680), size 8] ... [(CSUM CSUM 40116224), size 4] |
Leaf N + 1:
| [(CSUM CSUM 40161280), size 32] ... [((CSUM CSUM 40615936), size 8 |
Because we are at the last slot of leaf N, we call btrfs_next_leaf() to
find the next highest key, which releases the current path and then searches
for that next key. However after releasing the path and before finding that
next key, the item at slot 0 of leaf N + 1 gets moved to leaf N, due to a call
to ctree.c:push_leaf_left() (via ctree.c:split_leaf()), and therefore
btrfs_next_leaf() will returns us a path again with leaf N but with the slot
pointing to its new last key (CSUM CSUM 40161280). This new version of leaf N
is then:
slot = 0 slot = btrfs_header_nritems() - 2 slot = btrfs_header_nritems() - 1
| [(CSUM CSUM 39239680), size 8] ... [(CSUM CSUM 40116224), size 4] [(CSUM CSUM 40161280), size 32] |
And incorrecly using slot 0, makes us set next_offset to 39239680 and we jump
into the "insert:" label, which will set tmp to:
tmp = min((sums->len - total_bytes) >> blocksize_bits,
(next_offset - file_key.offset) >> blocksize_bits) =
min((16384 - 0) >> 12, (39239680 - 40157184) >> 12) =
min(4, (u64)-917504 = 18446744073708634112 >> 12) = 4
and
ins_size = csum_size * tmp = 4 * 4 = 16 bytes.
In other words, we insert a new csum item in the tree with key
(CSUM_OBJECTID CSUM_KEY 40157184 = sums->bytenr) that contains the checksums
for all the data (4 blocks of 4096 bytes each = sums->len). Which is wrong,
because the item with key (CSUM CSUM 40161280) (the one that was moved from
leaf N + 1 to the end of leaf N) contains the old checksums of the last 12288
bytes of our data and won't get those old checksums removed.
So this leaves us 2 different checksums for 3 4kb blocks of data in the tree,
and breaks the logical rule:
Key_N+1.offset >= Key_N.offset + length_of_data_its_checksums_cover
An obvious bad effect of this is that a subsequent csum tree lookup to get
the checksum of any of the blocks with logical offset of 40161280, 40165376
or 40169472 (the last 3 4kb blocks of file data), will get the old checksums.
commit 4eb1f66dce6c4dc28dd90a7ffbe6b2b1cb08aa4e upstream.
We've got bug reports that btrfs crashes when quota is enabled on
32bit kernel, typically with the Oops like below:
BUG: unable to handle kernel NULL pointer dereference at 00000004
IP: [<f9234590>] find_parent_nodes+0x360/0x1380 [btrfs]
*pde = 00000000
Oops: 0000 [#1] SMP
CPU: 0 PID: 151 Comm: kworker/u8:2 Tainted: G S W 3.15.2-1.gd43d97e-default #1
Workqueue: btrfs-qgroup-rescan normal_work_helper [btrfs]
task: f1478130 ti: f147c000 task.ti: f147c000
EIP: 0060:[<f9234590>] EFLAGS: 00010213 CPU: 0
EIP is at find_parent_nodes+0x360/0x1380 [btrfs]
EAX: f147dda8 EBX: f147ddb0 ECX: 00000011 EDX: 00000000
ESI: 00000000 EDI: f147dda4 EBP: f147ddf8 ESP: f147dd38
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
CR0: 8005003b CR2: 00000004 CR3: 00bf3000 CR4: 00000690
Stack:
00000000 00000000 f147dda4 00000050 00000001 00000000 00000001 00000050
00000001 00000000 d3059000 00000001 00000022 000000a8 00000000 00000000
00000000 000000a1 00000000 00000000 00000001 00000000 00000000 11800000
Call Trace:
[<f923564d>] __btrfs_find_all_roots+0x9d/0xf0 [btrfs]
[<f9237bb1>] btrfs_qgroup_rescan_worker+0x401/0x760 [btrfs]
[<f9206148>] normal_work_helper+0xc8/0x270 [btrfs]
[<c025e38b>] process_one_work+0x11b/0x390
[<c025eea1>] worker_thread+0x101/0x340
[<c026432b>] kthread+0x9b/0xb0
[<c0712a71>] ret_from_kernel_thread+0x21/0x30
[<c0264290>] kthread_create_on_node+0x110/0x110
This indicates a NULL corruption in prefs_delayed list. The further
investigation and bisection pointed that the call of ulist_add_merge()
results in the corruption.
ulist_add_merge() takes u64 as aux and writes a 64bit value into
old_aux. The callers of this function in backref.c, however, pass a
pointer of a pointer to old_aux. That is, the function overwrites
64bit value on 32bit pointer. This caused a NULL in the adjacent
variable, in this case, prefs_delayed.
Here is a quick attempt to band-aid over this: a new function,
ulist_add_merge_ptr() is introduced to pass/store properly a pointer
value instead of u64. There are still ugly void ** cast remaining
in the callers because void ** cannot be taken implicitly. But, it's
safer than explicit cast to u64, anyway.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=887046
commit c99d1e6e83b06744c75d9f5e491ed495a7086b7b upstream.
If we suffer a block allocation failure (for example due to a memory
allocation failure), it's possible that we will call
ext4_discard_allocated_blocks() before we've actually allocated any
blocks. In that case, fe_len and fe_start in ac->ac_f_ex will still
be zero, and this will result in mb_free_blocks(inode, e4b, 0, 0)
triggering the BUG_ON on mb_free_blocks():
BUG_ON(last >= (sb->s_blocksize << 3));
Fix this by bailing out of ext4_discard_allocated_blocks() if fs_len
is zero.
Also fix a missing ext4_mb_unload_buddy() call in
ext4_discard_allocated_blocks().
Google-Bug-Id: 16844242
Fixes: 86f0afd463215fc3e58020493482faa4ac3a4d69
commit 485d44022a152c0254dd63445fdb81c4194cbf0e upstream.
[ I'm currently running my tests on it now, and so far, after a few
hours it has yet to blow up. I'll run it for 24 hours which it never
succeeded in the past. ]
The tracing code has a way to make directories within the debugfs file
system as well as deleting them using mkdir/rmdir in the instance
directory. This is very limited in functionality, such as there is
no renames, and the parent directory "instance" can not be modified.
The tracing code creates the instance directory from the debugfs code
and then replaces the dentry->d_inode->i_op with its own to allow
for mkdir/rmdir to work.
When these are called, the d_entry and inode locks need to be released
to call the instance creation and deletion code. That code has its own
accounting and locking to serialize everything to prevent multiple
users from causing harm. As the parent "instance" directory can not
be modified this simplifies things.
I created a stress test that creates several threads that randomly
creates and deletes directories thousands of times a second. The code
stood up to this test and I submitted it a while ago.
Recently I added a new test that adds readers to the mix. While the
instance directories were being added and deleted, readers would read
from these directories and even enable tracing within them. This test
was able to trigger a bug:
general protection fault: 0000 [#1] PREEMPT SMP
Modules linked in: ...
CPU: 3 PID: 17789 Comm: rmdir Tainted: G W 3.15.0-rc2-test+ #41
Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007
task: ffff88003786ca60 ti: ffff880077018000 task.ti: ffff880077018000
RIP: 0010:[<ffffffff811ed5eb>] [<ffffffff811ed5eb>] debugfs_remove_recursive+0x1bd/0x367
RSP: 0018:ffff880077019df8 EFLAGS: 00010246
RAX: 0000000000000002 RBX: ffff88006f0fe490 RCX: 0000000000000000
RDX: dead000000100058 RSI: 0000000000000246 RDI: ffff88003786d454
RBP: ffff88006f0fe640 R08: 0000000000000628 R09: 0000000000000000
R10: 0000000000000628 R11: ffff8800795110a0 R12: ffff88006f0fe640
R13: ffff88006f0fe640 R14: ffffffff81817d0b R15: ffffffff818188b7
FS: 00007ff13ae24700(0000) GS:ffff88007d580000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000003054ec7be0 CR3: 0000000076d51000 CR4: 00000000000007e0
Stack:
ffff88007a41ebe0 dead000000100058 00000000fffffffe ffff88006f0fe640
0000000000000000 ffff88006f0fe678 ffff88007a41ebe0 ffff88003793a000
00000000fffffffe ffffffff810bde82 ffff88006f0fe640 ffff88007a41eb28
Call Trace:
[<ffffffff810bde82>] ? instance_rmdir+0x15b/0x1de
[<ffffffff81132e2d>] ? vfs_rmdir+0x80/0xd3
[<ffffffff81132f51>] ? do_rmdir+0xd1/0x139
[<ffffffff8124ad9e>] ? trace_hardirqs_on_thunk+0x3a/0x3c
[<ffffffff814fea62>] ? system_call_fastpath+0x16/0x1b
Code: fe ff ff 48 8d 75 30 48 89 df e8 c9 fd ff ff 85 c0 75 13 48 c7 c6 b8 cc d2 81 48 c7 c7 b0 cc d2 81 e8 8c 7a f5 ff 48 8b 54 24 08 <48> 8b 82 a8 00 00 00 48 89 d3 48 2d a8 00 00 00 48 89 44 24 08
RIP [<ffffffff811ed5eb>] debugfs_remove_recursive+0x1bd/0x367
RSP <ffff880077019df8>
It took a while, but every time it triggered, it was always in the
same place:
list_for_each_entry_safe(child, next, &parent->d_subdirs, d_u.d_child) {
Where the child->d_u.d_child seemed to be corrupted. I added lots of
trace_printk()s to see what was wrong, and sure enough, it was always
the child's d_u.d_child field. I looked around to see what touches
it and noticed that in __dentry_kill() which calls dentry_free():
static void dentry_free(struct dentry *dentry)
/* if dentry was never visible to RCU, immediate free is OK */
if (!(dentry->d_flags & DCACHE_RCUACCESS))
__d_free(&dentry->d_u.d_rcu);
else
call_rcu(&dentry->d_u.d_rcu, __d_free);
I also noticed that __dentry_kill() unlinks the child->d_u.child
under the parent->d_lock spin_lock.
Looking back at the loop in debugfs_remove_recursive() it never takes the
parent->d_lock to do the list walk. Adding more tracing, I was able to
prove this was the issue:
ftrace-t-15385 1.... 246662024us : dentry_kill <ffffffff81138b91>: free ffff88006d573600
rmdir-15409 2.... 246662024us : debugfs_remove_recursive <ffffffff811ec7e5>: child=ffff88006d573600 next=dead000000100058
The dentry_kill freed ffff88006d573600 just as the remove recursive was walking
it.
In order to fix this, the list walk needs to be modified a bit to take
the parent->d_lock. The safe version is no longer necessary, as every
time we remove a child, the parent->d_lock must be released and the
list walk must start over. Each time a child is removed, even though it
may still be on the list, it should be skipped by the first check
in the loop:
if (!debugfs_positive(child))
continue;
commit 86f0afd463215fc3e58020493482faa4ac3a4d69 upstream.
If there is a failure while allocating the preallocation structure, a
number of blocks can end up getting marked in the in-memory buddy
bitmap, and then not getting released. This can result in the
following corruption getting reported by the kernel:
EXT4-fs error (device sda3): ext4_mb_generate_buddy:758: group 1126,
12793 clusters in bitmap, 12729 in gd
In that case, we need to release the blocks using mb_free_blocks().
Tested: fs smoke test; also demonstrated that with injected errors,
the file system is no longer getting corrupted
Google-Bug-Id: 16657874
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 4f579ae7de560e5f449587a6c3f02594d53d4d51 upstream.
Currently punch hole code on files with direct/indirect mapping has some
problems which may lead to a data loss. For example (from Jan Kara):
fallocate -n -p 10240000 4096
will punch the range 10240000 - 12632064 instead of the range 1024000 -
10244096.
Also the code is a bit weird and it's not using infrastructure provided
by indirect.c, but rather creating it's own way.
This patch fixes the issues as well as making the operation to run 4
times faster from my testing (punching out 60GB file). It uses similar
approach used in ext4_ind_truncate() which takes advantage of
ext4_free_branches() function.
Also rename the ext4_free_hole_blocks() to something more sensible, like
the equivalent we have for extent mapped files. Call it
ext4_ind_remove_space().
This has been tested mostly with fsx and some xfstests which are testing
punch hole but does not require unwritten extents which are not
supported with direct/indirect mapping. Not problems showed up even with
1024k block size.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
commit 410dd3cf4c9b36f27ed4542ee18b1af5e68645a4 upstream.
We did not check relocated directory in any way when processing Rock
Ridge 'CL' tag. Thus a corrupted isofs image can possibly have a CL
entry pointing to another CL entry leading to possibly unbounded
recursion in kernel code and thus stack overflow or deadlocks (if there
is a loop created from CL entries).
Fix the problem by not allowing CL entry to point to a directory entry
with CL entry (such use makes no good sense anyway) and by checking
whether CL entry doesn't point to itself.
Reported-by: Chris Evans <cevans@google.com>
Fix the broken check for calling sys_fallocate() on an active swapfile,
introduced by commit 0790b31b69374ddadefe ("fs: disallow all fallocate
operation on active swapfile").
Signed-off-by: Eric Biggers <ebiggers3@gmail.com>
The direct-io.c rewrite to use the iov_iter infrastructure stopped updating
the size field in struct dio_submit, and thus rendered the check for
allowing asynchronous completions to always return false. Fix this by
comparing it to the count of bytes in the iov_iter instead.
Reported-by: Tim Chen <tim.c.chen@linux.intel.com>
Tested-by: Tim Chen <tim.c.chen@linux.intel.com>
Correctly assemble the client UUID by OR'ing in the flags rather than
assigning them over the other components.
Reported-by: Himangi Saraogi <himangi774@gmail.com>
Pull vfs fixes from Christoph Hellwig:
"A vfsmount leak fix, and a compile warning fix"
* 'vfs-for-3.16' of git://git.infradead.org/users/hch/vfs:
fs: umount on symlink leaks mnt count
direct-io: fix uninitialized warning in do_direct_IO()
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
Pull fuse fixes from Miklos Szeredi:
"These two pathes fix issues with the kernel-userspace protocol changes
in v3.15"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: add FUSE_NO_OPEN_SUPPORT flag to INIT
fuse: s_time_gran fix
Currently umount on symlink blocks following umount:
/vz is separate mount
# ls /vz/ -al | grep test
drwxr-xr-x. 2 root root 4096 Jul 19 01:14 testdir
lrwxrwxrwx. 1 root root 11 Jul 19 01:16 testlink -> /vz/testdir
# umount -l /vz/testlink
umount: /vz/testlink: not mounted (expected)
# lsof /vz
# umount /vz
umount: /vz: device is busy. (unexpected)
In this case mountpoint_last() gets an extra refcount on path->mnt
Signed-off-by: Vasily Averin <vvs@openvz.org>
Acked-by: Ian Kent <raven@themaw.net>
Acked-by: Jeff Layton <jlayton@primarydata.com>
Cc: stable@vger.kernel.org
The following warnings:
fs/direct-io.c: In function ‘__blockdev_direct_IO’:
fs/direct-io.c:1011:12: warning: ‘to’ may be used uninitialized in this function [-Wmaybe-uninitialized]
fs/direct-io.c:913:16: note: ‘to’ was declared here
fs/direct-io.c:1011:12: warning: ‘from’ may be used uninitialized in this function [-Wmaybe-uninitialized]
fs/direct-io.c:913:10: note: ‘from’ was declared here
are false positive because dio_get_page() either fails, or sets both
'from' and 'to'.
Paul Bolle said ...
Maybe it's better to move initializing "to" and "from" out of
dio_get_page(). That _might_ make it easier for both the the reader and
the compiler to understand what's going on. Something like this:
Christoph Hellwig said ...
The fix of moving the code definitively looks nicer, while I think
uninitialized_var is horrible wart that won't get anywhere near my code.
Boaz Harrosh: I agree with Christoph and Paul
Signed-off-by: Boaz Harrosh <boaz@plexistor.com>
Pull nfsd bugfix from Bruce Fields:
"Another regression from the xdr encoding rewrite"
* 'for-3.16' of git://linux-nfs.org/~bfields/linux:
NFSD: Fix crash encoding lock reply on 32-bit
If a filesystem uses simple_xattr to support user extended attributes,
LTP setxattr01 and xfstests generic/062 fail with "Cannot allocate
memory": simple_xattr_alloc()'s wrap-around test mistakenly excludes
values of zero size. Fix that off-by-one (but apparently no filesystem
needs them yet).
Cc: Jeff Layton <jlayton@poochiereds.net>
Cc: Aristeu Rozanski <aris@redhat.com>
