commit 8d238027b87e654be552eabdf492042a34c5c300 upstream.
We display a list of supplementary group for each process in
/proc/<pid>/status. However, we show only the first 32 groups, not all of
them.
Although this is rare, but sometimes processes do have more than 32
supplementary groups, and this kernel limitation breaks user-space apps
that rely on the group list in /proc/<pid>/status.
Number 32 comes from the internal NGROUPS_SMALL macro which defines the
length for the internal kernel "small" groups buffer. There is no
apparent reason to limit to this value.
This patch removes the 32 groups printing limit.
The Linux kernel limits the amount of supplementary groups by NGROUPS_MAX,
which is currently set to 65536. And this is the maximum count of groups
we may possibly print.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
[bwh: Backported to 3.2: adjust context]
Cc: Qiang Huang <h.huangqiang@huawei.com>
Cc: Li Zefan <lizefan@huawei.com>
Cc: Jianguo Wu <wujianguo@huawei.com>
commit 00a1a053ebe5febcfc2ec498bd894f035ad2aa06 upstream.
Use cmpxchg() to atomically set i_flags instead of clearing out the
S_IMMUTABLE, S_APPEND, etc. flags and then setting them from the
EXT4_IMMUTABLE_FL, EXT4_APPEND_FL flags, since this opens up a race
where an immutable file has the immutable flag cleared for a brief
window of time.
Reported-by: John Sullivan <jsrhbz@kanargh.force9.co.uk>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit a2aa75e18a21b21952dc6daa9bac7c9f4426f81f upstream.
When using a mix of compressed file extents and prealloc extents, it
is possible to fill a page of a file with random, garbage data from
some unrelated previous use of the page, instead of a sequence of zeroes.
A simple sequence of steps to get into such case, taken from the test
case I made for xfstests, is:
_scratch_mkfs
_scratch_mount "-o compress-force=lzo"
$XFS_IO_PROG -f -c "pwrite -S 0x06 -b 18670 266978 18670" $SCRATCH_MNT/foobar
$XFS_IO_PROG -c "falloc 26450 665194" $SCRATCH_MNT/foobar
$XFS_IO_PROG -c "truncate 542872" $SCRATCH_MNT/foobar
$XFS_IO_PROG -c "fsync" $SCRATCH_MNT/foobar
This results in the following file items in the fs tree:
item 4 key (257 INODE_ITEM 0) itemoff 15879 itemsize 160
inode generation 6 transid 6 size 542872 block group 0 mode 100600
item 5 key (257 INODE_REF 256) itemoff 15863 itemsize 16
inode ref index 2 namelen 6 name: foobar
item 6 key (257 EXTENT_DATA 0) itemoff 15810 itemsize 53
extent data disk byte 0 nr 0 gen 6
extent data offset 0 nr 24576 ram 266240
extent compression 0
item 7 key (257 EXTENT_DATA 24576) itemoff 15757 itemsize 53
prealloc data disk byte 12849152 nr 241664 gen 6
prealloc data offset 0 nr 241664
item 8 key (257 EXTENT_DATA 266240) itemoff 15704 itemsize 53
extent data disk byte 12845056 nr 4096 gen 6
extent data offset 0 nr 20480 ram 20480
extent compression 2
item 9 key (257 EXTENT_DATA 286720) itemoff 15651 itemsize 53
prealloc data disk byte 13090816 nr 405504 gen 6
prealloc data offset 0 nr 258048
The on disk extent at offset 266240 (which corresponds to 1 single disk block),
contains 5 compressed chunks of file data. Each of the first 4 compress 4096
bytes of file data, while the last one only compresses 3024 bytes of file data.
Therefore a read into the file region [285648 ; 286720[ (length = 4096 - 3024 =
1072 bytes) should always return zeroes (our next extent is a prealloc one).
The solution here is the compression code path to zero the remaining (untouched)
bytes of the last page it uncompressed data into, as the information about how
much space the file data consumes in the last page is not known in the upper layer
fs/btrfs/extent_io.c:__do_readpage(). In __do_readpage we were correctly zeroing
the remainder of the page but only if it corresponds to the last page of the inode
and if the inode's size is not a multiple of the page size.
This would cause not only returning random data on reads, but also permanently
storing random data when updating parts of the region that should be zeroed.
For the example above, it means updating a single byte in the region [285648 ; 286720[
would store that byte correctly but also store random data on disk.
A test case for xfstests follows soon.
Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com>
Signed-off-by: Chris Mason <clm@fb.com>
commit 70335abb2689c8cd5df91bf2d95a65649addf50b upstream.
The expected logic of proc_map_files_get_link() is either to return 0
and initialize 'path' or return an error and leave 'path' uninitialized.
By the time dname_to_vma_addr() returns 0 the corresponding vma may have
already be gone. In this case the path is not initialized but the
return value is still 0. This results in 'general protection fault'
inside d_path().
Steps to reproduce:
CONFIG_CHECKPOINT_RESTORE=y
fd = open(...);
while (1) {
mmap(fd, ...);
munmap(fd, ...);
ls -la /proc/$PID/map_files
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=68991
Signed-off-by: Artem Fetishev <artem_fetishev@epam.com>
Signed-off-by: Aleksandr Terekhov <aleksandr_terekhov@epam.com>
Reported-by: <wiebittewas@gmail.com>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
Acked-by: Cyrill Gorcunov <gorcunov@openvz.org>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
commit 755a48a7a4eb05b9c8424e3017d947b2961a60e0 upstream.
The clean-up in commit 36281caa839f ended up removing a NULL pointer check
that is needed in order to prevent an Oops in
nfs_async_inode_return_delegation().
Reported-by: "Yan, Zheng" <zheng.z.yan@intel.com>
Link: http://lkml.kernel.org/r/5313E9F6.2020405@intel.com
Fixes: 36281caa839f (NFSv4: Further clean-ups of delegation stateid validation)
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 1b56e98990bcdbb20b9fab163654b9315bf158e8 upstream.
commit 15c34a760630ca2c803848fba90ca0646a9907dd upstream.
Global quota files are accessed from different nodes. Thus we cannot
cache offset of quota structure in the quota file after we drop our node
reference count to it because after that moment quota structure may be
freed and reallocated elsewhere by a different node resulting in
corruption of quota file.
Fix the problem by clearing dq_off when we are releasing dquot structure.
We also remove the DB_READ_B handling because it is useless -
DQ_ACTIVE_B is set iff DQ_READ_B is set.
Cc: Goldwyn Rodrigues <rgoldwyn@suse.de>
Reviewed-by: Mark Fasheh <mfasheh@suse.de>
commit 860d21e2c585f7ee8a4ecc06f474fdc33c9474f4 upstream.
The only reason for sb_getblk() failing is if it can't allocate the
buffer_head. So ENOMEM is more appropriate than EIO. In addition,
make sure that the file system is marked as being inconsistent if
sb_getblk() fails.
[xr: Backported to 3.4:
- Drop change to inline.c
- Call to ext4_ext_check() from ext4_ext_find_extent() is conditional]
Signed-off-by: Rui Xiang <rui.xiang@huawei.com>
commit 31efee60f489c759c341454d755a9fd13de8c03d upstream.
When a call goes out, the signing code adjusts the sequence number
upward by two to account for the request and the response. An NT_CANCEL
however doesn't get a response of its own, it just hurries the server
along to get it to respond to the original request more quickly.
Therefore, we must adjust the sequence number back down by one after
signing a NT_CANCEL request.
Reported-by: Tim Perry <tdparmor-sambabugs@yahoo.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
[bwh: Backported to 3.2: adjust filename]
Cc: Rui Xiang <rui.xiang@huawei.com>
commit 091e26dfc156aeb3b73bc5c5f277e433ad39331c upstream.
Running AIO is pinning inode in memory using file reference. Once AIO
is completed using aio_complete(), file reference is put and inode can
be freed from memory. So we have to be sure that calling aio_complete()
is the last thing we do with the inode.
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
commit 8afd500cb52a5d00bab4525dd5a560d199f979b9 upstream.
The last orphan in the dnext list has its dnext set to NULL. Because
of that, ubifs_delete_orphan assumes that it is not on the dnext list
and frees it immediately instead ignoring it as a second delete. The
orphan is later freed again by erase_deleted.
This change adds an explicit flag to ubifs_orphan indicating whether
it is pending delete.
Signed-off-by: Adam Thomas <adamthomas1111@gmail.com>
commit d76a3a77113db020d9bb1e894822869410450bd9 upstream.
In the case where an inode has a very stale transaction id (tid) in
i_datasync_tid or i_sync_tid, it's possible that after a very large
(2**31) number of transactions, that the tid number space might wrap,
causing tid_geq()'s calculations to fail.
Commit deeeaf13 "jbd2: fix fsync() tid wraparound bug", later modified
by commit e7b04ac0 "jbd2: don't wake kjournald unnecessarily",
attempted to fix this problem, but it only avoided kjournald spinning
forever by fixing the logic in jbd2_log_start_commit().
Unfortunately, in the codepaths in fs/ext4/fsync.c and fs/ext4/inode.c
that might call jbd2_log_start_commit() with a stale tid, those
functions will subsequently call jbd2_log_wait_commit() with the same
stale tid, and then wait for a very long time. To fix this, we
replace the calls to jbd2_log_start_commit() and
jbd2_log_wait_commit() with a call to a new function,
jbd2_complete_transaction(), which will correctly handle stale tid's.
As a bonus, jbd2_complete_transaction() will avoid locking
j_state_lock for writing unless a commit needs to be started. This
should have a small (but probably not measurable) improvement for
ext4's scalability.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Reported-by: George Barnett <gbarnett@atlassian.com>
commit 698b8223631472bf982ed570b0812faa61955683 upstream.
1d2ef5901483004d74947bbf78d5146c24038fe7 caused a regression in ncpfs such that
directories could no longer be removed. This was because ncp_rmdir checked
to see if a dentry could be unhashed before allowing it to be removed. Since
1d2ef5901483004d74947bbf78d5146c24038fe7 introduced a change that incremented
dentry->d_count causing it to always be greater than 1 unhash would always
fail. Thus causing the error path in ncp_rmdir to always be taken. Removing
this error path is safe as unhashing is still accomplished by calls to dput
from vfs_rmdir.
Signed-off-by: Dave Chiluk <chiluk@canonical.com>
Signed-off-by: Petr Vandrovec <petr@vandrovec.name>
revalidated immediately
commit 757c4f6260febff982276818bb946df89c1105aa upstream.
David reported that commit c2b93e06 (cifs: only set ops for inodes in
I_NEW state) caused a regression with mfsymlinks. Prior to that patch,
if a mfsymlink dentry was instantiated at readdir time, the inode would
get a new set of ops when it was revalidated. After that patch, this
did not occur.
This patch addresses this by simply skipping instantiating dentries in
the readdir codepath when we know that they will need to be immediately
revalidated. The next attempt to use that dentry will cause a new lookup
to occur (which is basically what we want to happen anyway).
Cc: "Stefan (metze) Metzmacher" <metze@samba.org>
Cc: Sachin Prabhu <sprabhu@redhat.com>
Reported-and-Tested-by: David McBride <dwm37@cam.ac.uk>
[bwh: Backported to 3.2: need to return NULL]
commit 06a7c3c2781409af95000c60a5df743fd4e2f8b4 upstream.
The way how fuse calls truncate_pagecache() from fuse_change_attributes()
is completely wrong. Because, w/o i_mutex held, we never sure whether
'oldsize' and 'attr->size' are valid by the time of execution of
truncate_pagecache(inode, oldsize, attr->size). In fact, as soon as we
released fc->lock in the middle of fuse_change_attributes(), we completely
loose control of actions which may happen with given inode until we reach
truncate_pagecache. The list of potentially dangerous actions includes
mmap-ed reads and writes, ftruncate(2) and write(2) extending file size.
The typical outcome of doing truncate_pagecache() with outdated arguments
is data corruption from user point of view. This is (in some sense)
acceptable in cases when the issue is triggered by a change of the file on
the server (i.e. externally wrt fuse operation), but it is absolutely
intolerable in scenarios when a single fuse client modifies a file without
any external intervention. A real life case I discovered by fsx-linux
looked like this:
1. Shrinking ftruncate(2) comes to fuse_do_setattr(). The latter sends
FUSE_SETATTR to the server synchronously, but before getting fc->lock ...
2. fuse_dentry_revalidate() is asynchronously called. It sends FUSE_LOOKUP
to the server synchronously, then calls fuse_change_attributes(). The
latter updates i_size, releases fc->lock, but before comparing oldsize vs
attr->size..
3. fuse_do_setattr() from the first step proceeds by acquiring fc->lock and
updating attributes and i_size, but now oldsize is equal to
outarg.attr.size because i_size has just been updated (step 2). Hence,
fuse_do_setattr() returns w/o calling truncate_pagecache().
4. As soon as ftruncate(2) completes, the user extends file size by
write(2) making a hole in the middle of file, then reads data from the hole
either by read(2) or mmap-ed read. The user expects to get zero data from
the hole, but gets stale data because truncate_pagecache() is not executed
yet.
The scenario above illustrates one side of the problem: not truncating the
page cache even though we should. Another side corresponds to truncating
page cache too late, when the state of inode changed significantly.
Theoretically, the following is possible:
1. As in the previous scenario fuse_dentry_revalidate() discovered that
i_size changed (due to our own fuse_do_setattr()) and is going to call
truncate_pagecache() for some 'new_size' it believes valid right now. But
by the time that particular truncate_pagecache() is called ...
2. fuse_do_setattr() returns (either having called truncate_pagecache() or
not -- it doesn't matter).
3. The file is extended either by write(2) or ftruncate(2) or fallocate(2).
4. mmap-ed write makes a page in the extended region dirty.
The result will be the lost of data user wrote on the fourth step.
The patch is a hotfix resolving the issue in a simplistic way: let's skip
dangerous i_size update and truncate_pagecache if an operation changing
file size is in progress. This simplistic approach looks correct for the
cases w/o external changes. And to handle them properly, more sophisticated
and intrusive techniques (e.g. NFS-like one) would be required. I'd like to
postpone it until the issue is well discussed on the mailing list(s).
Changed in v2:
- improved patch description to cover both sides of the issue.
Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
[bwh: Backported to 3.2: add the fuse_inode::state field which we didn't have]
commit efeb9e60d48f7778fdcad4a0f3ad9ea9b19e5dfd upstream.
Userspace can add names containing a slash character to the directory
listing. Don't allow this as it could cause all sorts of trouble.
[bwh: Backported to 3.2: drop changes to parse_dirplusfile() which we
don't have]
dirty blocks
commit 7f42ec3941560f0902fe3671e36f2c20ffd3af0a upstream.
Many NILFS2 users were reported about strange file system corruption
(for example):
NILFS: bad btree node (blocknr=185027): level = 0, flags = 0x0, nchildren = 768
NILFS error (device sda4): nilfs_bmap_last_key: broken bmap (inode number=11540)
But such error messages are consequence of file system's issue that takes
place more earlier. Fortunately, Jerome Poulin <jeromepoulin@gmail.com>
and Anton Eliasson <devel@antoneliasson.se> were reported about another
issue not so recently. These reports describe the issue with segctor
thread's crash:
BUG: unable to handle kernel paging request at 0000000000004c83
IP: nilfs_end_page_io+0x12/0xd0 [nilfs2]
Call Trace:
nilfs_segctor_do_construct+0xf25/0x1b20 [nilfs2]
nilfs_segctor_construct+0x17b/0x290 [nilfs2]
nilfs_segctor_thread+0x122/0x3b0 [nilfs2]
kthread+0xc0/0xd0
ret_from_fork+0x7c/0xb0
These two issues have one reason. This reason can raise third issue
too. Third issue results in hanging of segctor thread with eating of
100% CPU.
REPRODUCING PATH:
One of the possible way or the issue reproducing was described by
Jermoe me Poulin <jeromepoulin@gmail.com>:
1. init S to get to single user mode.
2. sysrq+E to make sure only my shell is running
3. start network-manager to get my wifi connection up
4. login as root and launch "screen"
5. cd /boot/log/nilfs which is a ext3 mount point and can log when NILFS dies.
6. lscp | xz -9e > lscp.txt.xz
7. mount my snapshot using mount -o cp=3360839,ro /dev/vgUbuntu/root /mnt/nilfs
8. start a screen to dump /proc/kmsg to text file since rsyslog is killed
9. start a screen and launch strace -f -o find-cat.log -t find
/mnt/nilfs -type f -exec cat {} > /dev/null \;
10. start a screen and launch strace -f -o apt-get.log -t apt-get update
11. launch the last command again as it did not crash the first time
12. apt-get crashes
13. ps aux > ps-aux-crashed.log
13. sysrq+W
14. sysrq+E wait for everything to terminate
15. sysrq+SUSB
Simplified way of the issue reproducing is starting kernel compilation
task and "apt-get update" in parallel.
REPRODUCIBILITY:
The issue is reproduced not stable [60% - 80%]. It is very important to
have proper environment for the issue reproducing. The critical
conditions for successful reproducing:
(1) It should have big modified file by mmap() way.
(2) This file should have the count of dirty blocks are greater that
several segments in size (for example, two or three) from time to time
during processing.
(3) It should be intensive background activity of files modification
in another thread.
INVESTIGATION:
First of all, it is possible to see that the reason of crash is not valid
page address:
NILFS [nilfs_segctor_complete_write]:2100 bh->b_count 0, bh->b_blocknr 13895680, bh->b_size 13897727, bh->b_page 0000000000001a82
NILFS [nilfs_segctor_complete_write]:2101 segbuf->sb_segnum 6783
Moreover, value of b_page (0x1a82) is 6786. This value looks like segment
number. And b_blocknr with b_size values look like block numbers. So,
buffer_head's pointer points on not proper address value.
Detailed investigation of the issue is discovered such picture:
[-----------------------------SEGMENT 6783-------------------------------]
NILFS [nilfs_segctor_do_construct]:2310 nilfs_segctor_begin_construction
NILFS [nilfs_segctor_do_construct]:2321 nilfs_segctor_collect
NILFS [nilfs_segctor_do_construct]:2336 nilfs_segctor_assign
NILFS [nilfs_segctor_do_construct]:2367 nilfs_segctor_update_segusage
NILFS [nilfs_segctor_do_construct]:2371 nilfs_segctor_prepare_write
NILFS [nilfs_segctor_do_construct]:2376 nilfs_add_checksums_on_logs
NILFS [nilfs_segctor_do_construct]:2381 nilfs_segctor_write
NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111149024, segbuf->sb_segnum 6783
[-----------------------------SEGMENT 6784-------------------------------]
NILFS [nilfs_lookup_dirty_data_buffers]:782 bh->b_count 1, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824
NILFS [nilfs_lookup_dirty_data_buffers]:783 bh->b_assoc_buffers.next ffff8802174a6798, bh->b_assoc_buffers.prev ffff880221cffee8
NILFS [nilfs_segbuf_submit_bh]:575 bh->b_count 1, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824
NILFS [nilfs_segbuf_submit_bh]:576 segbuf->sb_segnum 6784
NILFS [nilfs_segbuf_submit_bh]:577 bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880218bcdf50
NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111150080, segbuf->sb_segnum 6784, segbuf->sb_nbio 0
[----------] ditto
NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111164416, segbuf->sb_segnum 6784, segbuf->sb_nbio 15
[-----------------------------SEGMENT 6785-------------------------------]
NILFS [nilfs_lookup_dirty_data_buffers]:782 bh->b_count 2, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824
NILFS [nilfs_lookup_dirty_data_buffers]:783 bh->b_assoc_buffers.next ffff880219277e80, bh->b_assoc_buffers.prev ffff880221cffc88
NILFS [nilfs_segbuf_submit_bh]:575 bh->b_count 2, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824
NILFS [nilfs_segbuf_submit_bh]:576 segbuf->sb_segnum 6785
NILFS [nilfs_segbuf_submit_bh]:577 bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880222cc7ee8
NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111165440, segbuf->sb_segnum 6785, segbuf->sb_nbio 0
[----------] ditto
NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111177728, segbuf->sb_segnum 6785, segbuf->sb_nbio 12
NILFS [nilfs_segctor_do_construct]:2399 nilfs_segctor_wait
NILFS [nilfs_segbuf_wait]:676 segbuf->sb_segnum 6783
NILFS [nilfs_segbuf_wait]:676 segbuf->sb_segnum 6784
NILFS [nilfs_segbuf_wait]:676 segbuf->sb_segnum 6785
BUG: unable to handle kernel paging request at 0000000000001a82
IP: [<ffffffffa024d0f2>] nilfs_end_page_io+0x12/0xd0 [nilfs2]
Usually, for every segment we collect dirty files in list. Then, dirty
blocks are gathered for every dirty file, prepared for write and
submitted by means of nilfs_segbuf_submit_bh() call. Finally, it takes
place complete write phase after calling nilfs_end_bio_write() on the
block layer. Buffers/pages are marked as not dirty on final phase and
processed files removed from the list of dirty files.
It is possible to see that we had three prepare_write and submit_bio
phases before segbuf_wait and complete_write phase. Moreover, segments
compete between each other for dirty blocks because on every iteration
of segments processing dirty buffer_heads are added in several lists of
payload_buffers:
[SEGMENT 6784]: bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880218bcdf50
[SEGMENT 6785]: bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880222cc7ee8
The next pointer is the same but prev pointer has changed. It means
that buffer_head has next pointer from one list but prev pointer from
another. Such modification can be made several times. And, finally, it
can be resulted in various issues: (1) segctor hanging, (2) segctor
crashing, (3) file system metadata corruption.
FIX:
This patch adds:
(1) setting of BH_Async_Write flag in nilfs_segctor_prepare_write()
for every proccessed dirty block;
(2) checking of BH_Async_Write flag in
nilfs_lookup_dirty_data_buffers() and
nilfs_lookup_dirty_node_buffers();
(3) clearing of BH_Async_Write flag in nilfs_segctor_complete_write(),
nilfs_abort_logs(), nilfs_forget_buffer(), nilfs_clear_dirty_page().
Reported-by: Jerome Poulin <jeromepoulin@gmail.com>
Reported-by: Anton Eliasson <devel@antoneliasson.se>
Cc: Paul Fertser <fercerpav@gmail.com>
Cc: ARAI Shun-ichi <hermes@ceres.dti.ne.jp>
Cc: Piotr Szymaniak <szarpaj@grubelek.pl>
Cc: Juan Barry Manuel Canham <Linux@riotingpacifist.net>
Cc: Zahid Chowdhury <zahid.chowdhury@starsolutions.com>
Cc: Elmer Zhang <freeboy6716@gmail.com>
Cc: Kenneth Langga <klangga@gmail.com>
Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
[bwh: Backported to 3.2: nilfs_clear_dirty_page() has not been separated
from nilfs_clear_dirty_pages()]
commit 1362f4ea20fa63688ba6026e586d9746ff13a846 upstream.
Currently last dqput() can race with dquot_scan_active() causing it to
call callback for an already deactivated dquot. The race is as follows:
CPU1 CPU2
dqput()
spin_lock(&dq_list_lock);
if (atomic_read(&dquot->dq_count) > 1) {
- not taken
if (test_bit(DQ_ACTIVE_B, &dquot->dq_flags)) {
spin_unlock(&dq_list_lock);
->release_dquot(dquot);
- not taken
dquot_scan_active()
if (!test_bit(DQ_ACTIVE_B, &dquot->dq_flags))
- not taken
atomic_inc(&dquot->dq_count);
- proceeds to release dquot
ret = fn(dquot, priv);
- called for inactive dquot
Fix the problem by making sure possible ->release_dquot() is finished by
the time we call the callback and new calls to it will notice reference
dquot_scan_active() has taken and bail out.
commit 5d81de8e8667da7135d3a32a964087c0faf5483f upstream.
It's possible for userland to pass down an iovec via writev() that has a
bogus user pointer in it. If that happens and we're doing an uncached
write, then we can end up getting less bytes than we expect from the
call to iov_iter_copy_from_user. This is CVE-2014-0069
cifs_iovec_write isn't set up to handle that situation however. It'll
blindly keep chugging through the page array and not filling those pages
with anything useful. Worse yet, we'll later end up with a negative
number in wdata->tailsz, which will confuse the sending routines and
cause an oops at the very least.
Fix this by having the copy phase of cifs_iovec_write stop copying data
in this situation and send the last write as a short one. At the same
time, we want to avoid sending a zero-length write to the server, so
break out of the loop and set rc to -EFAULT if that happens. This also
allows us to handle the case where no address in the iovec is valid.
[Note: Marking this for stable on v3.4+ kernels, but kernels as old as
v2.6.38 may have a similar problem and may need similar fix]
Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru>
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
commit 19ea80603715d473600cd993b9987bc97d042e02 upstream.
If the i_crtime field is not present in the inode, don't leave the
field uninitialized.
Fixes: ef7f38359 ("ext4: Add nanosecond timestamps")
Reported-by: Vegard Nossum <vegard.nossum@oracle.com>
Tested-by: Vegard Nossum <vegard.nossum@oracle.com>
commit 3d2660d0c9c2f296837078c189b68a47f6b2e3b5 upstream.
The set_flexbg_block_bitmap() function assumed that the number of
blocks in a blockgroup was sb->blocksize * 8, which is normally true,
but not always! Use EXT4_BLOCKS_PER_GROUP(sb) instead, to fix block
bitmap corruption after:
mke2fs -t ext4 -g 3072 -i 4096 /dev/vdd 1G
mount -t ext4 /dev/vdd /vdd
resize2fs /dev/vdd 8G
Reported-by: Jon Bernard <jbernard@tuxion.com>
commit 23301410972330c0ae9a8afc379ba2005e249cc6 upstream.
If an ext4 file system is created by some tool other than mke2fs
(perhaps by someone who has a pathalogical fear of the GPL) that
doesn't set one or the other of the EXT2_FLAGS_{UN}SIGNED_HASH flags,
and that file system is then mounted read-only, don't try to modify
the s_flags field. Otherwise, if dm_verity is in use, the superblock
will change, causing an dm_verity failure.
commit 2ec197db1a56c9269d75e965f14c344b58b2a4f6 upstream.
If an NFS client attempts to get a lock (using NLM) and the lock is
not available, the server will remember the request and when the lock
becomes available it will send a GRANT request to the client to
provide the lock.
If the client already held an adjacent lock, the GRANT callback will
report the union of the existing and new locks, which can confuse the
client.
This happens because __posix_lock_file (called by vfs_lock_file)
updates the passed-in file_lock structure when adjacent or
over-lapping locks are found.
To avoid this problem we take a copy of the two fields that can
be changed (fl_start and fl_end) before the call and restore them
afterwards.
An alternate would be to allocate a 'struct file_lock', initialise it,
use locks_copy_lock() to take a copy, then locks_release_private()
after the vfs_lock_file() call. But that is a lot more work.
Reported-by: Olaf Kirch <okir@suse.com>
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
v1 had a couple of issues (large on-stack struct and didn't really work properly).
This version is much better tested.
commit 96c7a2ff21501691587e1ae969b83cbec8b78e08 upstream.
Recently due to a spike in connections per second memcached on 3
separate boxes triggered the OOM killer from accept. At the time the
OOM killer was triggered there was 4GB out of 36GB free in zone 1. The
problem was that alloc_fdtable was allocating an order 3 page (32KiB) to
hold a bitmap, and there was sufficient fragmentation that the largest
page available was 8KiB.
I find the logic that PAGE_ALLOC_COSTLY_ORDER can't fail pretty dubious
but I do agree that order 3 allocations are very likely to succeed.
There are always pathologies where order > 0 allocations can fail when
there are copious amounts of free memory available. Using the pigeon
hole principle it is easy to show that it requires 1 page more than 50%
of the pages being free to guarantee an order 1 (8KiB) allocation will
succeed, 1 page more than 75% of the pages being free to guarantee an
order 2 (16KiB) allocation will succeed and 1 page more than 87.5% of
the pages being free to guarantee an order 3 allocate will succeed.
A server churning memory with a lot of small requests and replies like
memcached is a common case that if anything can will skew the odds
against large pages being available.
Therefore let's not give external applications a practical way to kill
linux server applications, and specify __GFP_NORETRY to the kmalloc in
alloc_fdmem. Unless I am misreading the code and by the time the code
reaches should_alloc_retry in __alloc_pages_slowpath (where
__GFP_NORETRY becomes signification). We have already tried everything
reasonable to allocate a page and the only thing left to do is wait. So
not waiting and falling back to vmalloc immediately seems like the
reasonable thing to do even if there wasn't a chance of triggering the
OOM killer.
Acked-by: David Rientjes <rientjes@google.com>
Cc: Cong Wang <cwang@twopensource.com>
commit 3dd4765fce04c0b4af1e0bc4c0b10f906f95fabc upstream.
...and ensure that we tear down the nfs_commit_data cache too when
unloading the module.
Cc: Bryan Schumaker <bjschuma@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
[bwh: Backported to 3.2: drop the nfs_cdata_cachep cleanup; it doesn't exist]
commit 6f2e9f0e7d795214b9cf5a47724a273b705fd113 upstream.
Now when we set the group inode free count, we don't have a proper
group lock so that multiple threads may decrease the inode free
count at the same time. And e2fsck will complain something like:
Free inodes count wrong for group #1 (1, counted=0).
Fix? no
Free inodes count wrong for group #2 (3, counted=0).
Fix? no
Directories count wrong for group #2 (780, counted=779).
Fix? no
Free inodes count wrong for group #3 (2272, counted=2273).
Fix? no
So this patch try to protect it with the ext4_lock_group.
btw, it is found by xfstests test case 269 and the volume is
mkfsed with the parameter
"-O ^resize_inode,^uninit_bg,extent,meta_bg,flex_bg,ext_attr"
and I have run it 100 times and the error in e2fsck doesn't
show up again.
Signed-off-by: Tao Ma <boyu.mt@taobao.com>
Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
commit 227d53b397a32a7614667b3ecaf1d89902fb6c12 upstream.
To use spin_{un}lock_irq is dangerous if caller disabled interrupt.
During aio buffer migration, we have a possibility to see the following
call stack.
aio_migratepage [disable interrupt]
migrate_page_copy
clear_page_dirty_for_io
set_page_dirty
__set_page_dirty_buffers
__set_page_dirty
spin_lock_irq
This mean, current aio migration is a deadlockable. spin_lock_irqsave
is a safer alternative and we should use it.
Reported-by: David Rientjes rientjes@google.com>
commit 31abdab9c11bb1694ecd1476a7edbe8e964d94ac upstream.
For one thing, there's an ABBA deadlock on hpfs fs-wide lock and i_mutex
in hpfs_dir_lseek() - there's a lot of methods that grab the former with
the caller already holding the latter, so it must take i_mutex first.
For another, locking the damn thing, carefully validating the offset,
then dropping locks and assigning the offset is obviously racy.
Moreover, we _must_ do hpfs_add_pos(), or the machinery in dnode.c
won't modify the sucker on B-tree surgeries.
Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
commit 78b19bae0813bd6f921ca58490196abd101297bd upstream.
Don't check for -NFS4ERR_NOTSUPP, it's already been mapped to -ENOTSUPP
by nfs4_stat_to_errno.
This allows the client to mount v4.1 servers that don't support
SECINFO_NO_NAME by falling back to the "guess and check" method of
nfs4_find_root_sec.
Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
commit c7848f69ec4a8c03732cde5c949bd2aa711a9f4b upstream.
decode_op_hdr() cannot distinguish between an XDR decoding error and
the perfectly valid errorcode NFS4ERR_IO. This is normally not a
problem, but for the particular case of OPEN, we need to be able
to increment the NFSv4 open sequence id when the server returns
a valid response.
Reported-by: J Bruce Fields <bfields@fieldses.org>
Link: http://lkml.kernel.org/r/20131204210356.GA19452@fieldses.org
commit aad560b7f63b495f48a7232fd086c5913a676e6f upstream.
At IO preparation we calculate the max pages at each device and
allocate a BIO per device of that size. The calculation was wrong
on some unaligned corner cases offset/length combination and would
make prepare return with -ENOMEM. This would be bad for pnfs-objects
that would in that case IO through MDS. And fatal for exofs were it
would fail writes with EIO.
Fix it by doing the proper math, that will work in all cases. (I
ran a test with all possible offset/length combinations this time
round).
Also when reading we do not need to allocate for the parity units
since we jump over them.
Also lower the max_io_length to take into account the parity pages
so not to allocate BIOs bigger than PAGE_SIZE
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
commit 90515e7f5d7d24cbb2a4038a3f1b5cfa2921aa17 upstream.
We may return early in btrfs_drop_snapshot(), we shouldn't
call btrfs_std_err() for this case, fix it.
Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com>
Signed-off-by: Josef Bacik <jbacik@fb.com>
commit 70f2fe3a26248724d8a5019681a869abdaf3e89a upstream.
There is a bug in the function nilfs_segctor_collect, which results in
active data being written to a segment, that is marked as clean. It is
possible, that this segment is selected for a later segment
construction, whereby the old data is overwritten.
The problem shows itself with the following kernel log message:
nilfs_sufile_do_cancel_free: segment 6533 must be clean
Usually a few hours later the file system gets corrupted:
NILFS: bad btree node (blocknr=8748107): level = 0, flags = 0x0, nchildren = 0
NILFS error (device sdc1): nilfs_bmap_last_key: broken bmap (inode number=114660)
The issue can be reproduced with a file system that is nearly full and
with the cleaner running, while some IO intensive task is running.
Although it is quite hard to reproduce.
This is what happens:
1. The cleaner starts the segment construction
2. nilfs_segctor_collect is called
3. sc_stage is on NILFS_ST_SUFILE and segments are freed
4. sc_stage is on NILFS_ST_DAT current segment is full
5. nilfs_segctor_extend_segments is called, which
allocates a new segment
6. The new segment is one of the segments freed in step 3
7. nilfs_sufile_cancel_freev is called and produces an error message
8. Loop around and the collection starts again
9. sc_stage is on NILFS_ST_SUFILE and segments are freed
including the newly allocated segment, which will contain active
data and can be allocated at a later time
10. A few hours later another segment construction allocates the
segment and causes file system corruption
This can be prevented by simply reordering the statements. If
nilfs_sufile_cancel_freev is called before nilfs_segctor_extend_segments
the freed segments are marked as dirty and cannot be allocated any more.
Signed-off-by: Andreas Rohner <andreas.rohner@gmx.net>
Reviewed-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Andreas Rohner <andreas.rohner@gmx.net>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit f6c07cad081ba222d63623d913aafba5586c1d2c upstream.
If a handle runs out of space, we currently stop the kernel with a BUG
in jbd2_journal_dirty_metadata(). This makes it hard to figure out
what might be going on. So return an error of ENOSPC, so we can let
the file system layer figure out what is going on, to make it more
likely we can get useful debugging information). This should make it
easier to debug problems such as the one which was reported by:
https://bugzilla.kernel.org/show_bug.cgi?id=44731
The only two callers of this function are ext4_handle_dirty_metadata()
and ocfs2_journal_dirty(). The ocfs2 function will trigger a
BUG_ON(), which means there will be no change in behavior. The ext4
function will call ext4_error_inode() which will print the useful
debugging information and then handle the situation using ext4's error
handling mechanisms (i.e., which might mean halting the kernel or
remounting the file system read-only).
Also, since both file systems already call WARN_ON(), drop the WARN_ON
from jbd2_journal_dirty_metadata() to avoid two stack traces from
being displayed.
Cc: ocfs2-devel@oss.oracle.com
Acked-by: Joel Becker <jlbec@evilplan.org>
commit dfd11184d894cd0a92397b25cac18831a1a6a5bc upstream.
In patch 209806aba9d540dde3db0a5ce72307f85f33468f we allowed
local deferred locks to be granted against a cached exclusive
lock. That opened up a corner case which this patch now
fixes.
The solution to the problem is to check whether we have cached
pages each time we do direct I/O and if so to unmap, flush
and invalidate those pages. Since the glock state machine
normally does that for us, mostly the code will be a no-op.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
commit dfe5b9ad83a63180f358b27d1018649a27b394a9 upstream.
This is a GFS2 version of Tejun's patch:
4f331f01b9c43bf001d3ffee578a97a1e0633eac
vfs: don't hold s_umount over close_bdev_exclusive() call
In this case its blkdev_put itself that is the issue and this
patch uses the same solution of dropping and retaking s_umount.
Reported-by: Tejun Heo <tj@kernel.org>
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
commit 56f91aad69444d650237295f68c195b74d888d95 upstream.
If the length of data to be read in readpage() is exactly
PAGE_CACHE_SIZE, the original code does not flush d-cache
for data consistency after finishing reading. This patches fixes
this.
Signed-off-by: Li Wang <liwang@ubuntukylin.com>
Signed-off-by: Sage Weil <sage@inktank.com>
commit 5946d089379a35dda0e531710b48fca05446a196 upstream.
A corrupted ext4 may have out of order leaf extents, i.e.
extent: lblk 0--1023, len 1024, pblk 9217, flags: LEAF UNINIT
extent: lblk 1000--2047, len 1024, pblk 10241, flags: LEAF UNINIT
^^^^ overlap with previous extent
Reading such extent could hit BUG_ON() in ext4_es_cache_extent().
BUG_ON(end < lblk);
The problem is that __read_extent_tree_block() tries to cache holes as
well but assumes 'lblk' is greater than 'prev' and passes underflowed
length to ext4_es_cache_extent(). Fix it by checking for overlapping
extents in ext4_valid_extent_entries().
I hit this when fuzz testing ext4, and am able to reproduce it by
modifying the on-disk extent by hand.
Also add the check for (ee_block + len - 1) in ext4_valid_extent() to
make sure the value is not overflow.
Ran xfstests on patched ext4 and no regression.
Cc: Lukáš Czerner <lczerner@redhat.com>
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
commit 4e8d2139802ce4f41936a687f06c560b12115247 upstream.
ext4_mb_put_pa should hold pa->pa_lock before accessing pa->pa_count.
While ext4_mb_use_preallocated checks pa->pa_deleted first and then
increments pa->count later, ext4_mb_put_pa decrements pa->pa_count
before holding pa->pa_lock and then sets pa->pa_deleted.
* Free sequence
ext4_mb_put_pa (1): atomic_dec_and_test pa->pa_count
ext4_mb_put_pa (2): lock pa->pa_lock
ext4_mb_put_pa (3): check pa->pa_deleted
ext4_mb_put_pa (4): set pa->pa_deleted=1
ext4_mb_put_pa (5): unlock pa->pa_lock
ext4_mb_put_pa (6): remove pa from a list
ext4_mb_pa_callback: free pa
* Use sequence
ext4_mb_use_preallocated (1): iterate over preallocation
ext4_mb_use_preallocated (2): lock pa->pa_lock
ext4_mb_use_preallocated (3): check pa->pa_deleted
ext4_mb_use_preallocated (4): increase pa->pa_count
ext4_mb_use_preallocated (5): unlock pa->pa_lock
ext4_mb_release_context: access pa
* Use-after-free sequence
[initial status] <pa->pa_deleted = 0, pa_count = 1>
[pa_count decremented] <pa->pa_deleted = 0, pa_count = 0>
[pa_count incremented] <pa->pa_deleted = 0, pa_count = 1>
[race condition!] <pa->pa_deleted = 1, pa_count = 1>
AddressSanitizer has detected use-after-free in ext4_mb_new_blocks
Bug report: http://goo.gl/rG1On3
Signed-off-by: Junho Ryu <jayr@google.com>
commit fc55d2c9448b34218ca58733a6f51fbede09575b upstream.
We also need to wake up 'safe' waiters if error occurs or request
aborted. Otherwise sync(2)/fsync(2) may hang forever.
Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
commit eb1b8af33c2e42a9a57fc0a7588f4a7b255d2e79 upstream.
Aborted requests usually get cleared when the reply is received.
If MDS crashes, no reply will be received. So we need to cleanup
aborted requests when re-sending requests.
Reviewed-by: Greg Farnum <greg@inktank.com>
commit bbd465df73f0d8ba41b8a0732766a243d0f5b356 upstream.
This patch fixes warnings due to missing lock on write error path.
WARNING: at fs/hpfs/hpfs_fn.h:353 hpfs_truncate+0x75/0x80 [hpfs]()
Hardware name: empty
Pid: 26563, comm: dd Tainted: P O 3.9.4 #12
Call Trace:
hpfs_write_begin+0x84/0x90 [hpfs]
_hpfs_bmap+0x10/0x10 [hpfs]
generic_file_buffered_write+0x121/0x2c0
__generic_file_aio_write+0x1c7/0x3f0
generic_file_aio_write+0x7c/0x100
do_sync_write+0x98/0xd0
hpfs_file_write+0xd/0x50 [hpfs]
vfs_write+0xa2/0x160
sys_write+0x51/0xa0
page_fault+0x22/0x30
system_call_fastpath+0x1a/0x1f
Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
commit 3873d064b8538686bbbd4b858dc8a07db1f7f43a upstream.
When compiling a 32bit kernel with CONFIG_LBDAF=n the compiler complains like
shown below. Fix this warning by instead using sector_div() which is provided
by the kernel.h header file.
fs/nfs/blocklayout/extents.c: In function ‘normalize’:
include/asm-generic/div64.h:43:28: warning: comparison of distinct pointer types lacks a cast [enabled by default]
fs/nfs/blocklayout/extents.c:47:13: note: in expansion of macro ‘do_div’
nfs/blocklayout/extents.c:47:2: warning: right shift count >= width of type [enabled by default]
fs/nfs/blocklayout/extents.c:47:2: warning: passing argument 1 of ‘__div64_32’ from incompatible pointer type [enabled by default]
include/asm-generic/div64.h:35:17: note: expected ‘uint64_t *’ but argument is of type ‘sector_t *’
extern uint32_t __div64_32(uint64_t *dividend, uint32_t divisor);
Signed-off-by: Helge Deller <deller@gmx.de>
commit 31978b5cc66b8ba8a7e8eef60b12395d41b7b890 upstream.
If we allocate less than sizeof(struct attrlist) then we end up
corrupting memory or doing a ZERO_PTR_SIZE dereference.
This can only be triggered with CAP_SYS_ADMIN.
Reported-by: Nico Golde <nico@ngolde.de>
Reported-by: Fabian Yamaguchi <fabs@goesec.de>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit c97cf606e43b85a6cf158b810375dd77312024db upstream.
If the DELEGRETURN errors out with something like NFS4ERR_BAD_STATEID
then there is no recovery possible. Just quit without returning an error.
Also, note that the client must not assume that the NFSv4 lease has been
renewed when it sees an error on DELEGRETURN.
commit f7fb86c6e639360ad9c253cec534819ef928a674 upstream.
There could be a situation, when NFSd was started in one network namespace, but
stopped in another one.
This will trigger kernel panic, because RPCBIND client is stored on per-net
NFSd data, and will be NULL on NFSd shutdown.
Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
Signed-off-by: Weng Meiling <wengmeiling.weng@huawei.com>
commit dcb9917ba041866686fe152850364826c4622a36 upstream.
Reported-by: Dave Jones <davej@redhat.com>
commit 66da0e1f9034140ae2f571ef96e254a25083906c upstream.
When devpts is unmounted, there may be a no-longer-used IDR tree hanging
off the superblock we are about to kill. This needs to be cleaned up
before destroying the SB.
The leak is usually not a big deal because unmounting devpts is typically
done when shutting down the whole machine. However, shutting down an LXC
container instead of a physical machine exposes the problem (the garbage
is detectable with kmemleak).
Signed-off-by: Ilija Hadzic <ihadzic@research.bell-labs.com>
Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
commit 76ae281f6307331aa063288edb6422ae99f435f0 upstream.
A race window in configfs, it starts from one dentry is UNHASHED and end
before configfs_d_iput is called. In this window, if a lookup happen,
since the original dentry was UNHASHED, so a new dentry will be
allocated, and then in configfs_attach_attr(), sd->s_dentry will be
updated to the new dentry. Then in configfs_d_iput(),
BUG_ON(sd->s_dentry != dentry) will be triggered and system panic.
sys_open: sys_close:
... fput
dput
dentry_kill
__d_drop <--- dentry unhashed here,
but sd->dentry still point
to this dentry.
lookup_real
configfs_lookup
configfs_attach_attr---> update sd->s_dentry
to new allocated dentry here.
d_kill
configfs_d_iput <--- BUG_ON(sd->s_dentry != dentry)
triggered here.
To fix it, change configfs_d_iput to not update sd->s_dentry if
sd->s_count > 2, that means there are another dentry is using the sd
beside the one that is going to be put. Use configfs_dirent_lock in
configfs_attach_attr to sync with configfs_d_iput.
With the following steps, you can reproduce the bug.
1. enable ocfs2, this will mount configfs at /sys/kernel/config and
fill configure in it.
2. run the following script.
while [ 1 ]; do cat /sys/kernel/config/cluster/$your_cluster_name/idle_timeout_ms > /dev/null; done &
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
commit 987da4791052fa298b7cfcde4dea9f6f2bbc786b upstream.
Use a straight goto error label style in nfsd_setattr to make sure
we always do the put_write_access call after we got it earlier.
Note that the we have been failing to do that in the case
nfsd_break_lease() returns an error, a bug introduced into 2.6.38 with
6a76bebefe15d9a08864f824d7f8d5beaf37c997 "nfsd4: break lease on nfsd
setattr".
