path: root/fs
2009-10-12IMA: open new file for readMimi Zohar
commit 6c1488fd581a447ec87c4b59f0d33f95f0aa441b upstream. When creating a new file, ima_path_check() assumed the new file was being opened for write. Call ima_path_check() with the appropriate acc_mode so that the read/write counters are incremented correctly. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-12ima: ecryptfs fix imbalance messageMimi Zohar
commit 36520be8e32b49bd85a63b7b8b40cd07c3da59a5 upstream. The unencrypted files are being measured. Update the counters to get rid of the ecryptfs imbalance message. (http://bugzilla.redhat.com/519737) Reported-by: Sachin Garg Cc: Eric Paris <eparis@redhat.com> Cc: Dustin Kirkland <kirkland@canonical.com> Cc: James Morris <jmorris@namei.org> Cc: David Safford <safford@watson.ibm.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05Fix idle time field in /proc/uptimeMichael Abbott
commit 96830a57de1197519b62af6a4c9ceea556c18c3d upstream. Git commit 79741dd changes idle cputime accounting, but unfortunately the /proc/uptime file hasn't caught up. Here the idle time calculation from /proc/stat is copied over. Signed-off-by: Michael Abbott <michael.abbott@diamond.ac.uk> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05/proc/kcore: work around a BUG()KAMEZAWA Hiroyuki
Not upstream due to other fixes in .32 Works around a BUG() which is triggered when the kernel accesses holes in vmalloc regions. BUG: unable to handle kernel paging request at fa54c000 IP: [<c04f687a>] read_kcore+0x260/0x31a *pde = 3540b067 *pte = 00000000 Oops: 0000 [#1] SMP last sysfs file: /sys/devices/pci0000:00/0000:00:1c.2/0000:03:00.0/ieee80211/phy0/rfkill0/state Modules linked in: fuse sco bridge stp llc bnep l2cap bluetooth sunrpc nf_conntrack_ftp ip6t_REJECT nf_conntrack_ipv6 ip6table_filter ip6_tables ipv6 cpufreq_ondemand acpi_cpufreq dm_multipath uinput usb_storage arc4 ecb snd_hda_codec_realtek snd_hda_intel ath5k snd_hda_codec snd_hwdep iTCO_wdt snd_pcm iTCO_vendor_support pcspkr i2c_i801 mac80211 joydev snd_timer serio_raw r8169 snd soundcore mii snd_page_alloc ath cfg80211 ata_generic i915 drm i2c_algo_bit i2c_core video output [last unloaded: scsi_wait_scan] Sep 4 12:45:16 tuxedu kernel: Pid: 2266, comm: cat Not tainted (2.6.31-rc8 #2) Joybook Lite U101 EIP: 0060:[<c04f687a>] EFLAGS: 00010286 CPU: 0 EIP is at read_kcore+0x260/0x31a EAX: f5e5ea00 EBX: fa54d000 ECX: 00000400 EDX: 00001000 ESI: fa54c000 EDI: f44ad000 EBP: e4533f4c ESP: e4533f24 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process cat (pid: 2266, ti=e4532000 task=f09d19a0 task.ti=e4532000) Stack: 00005000 00000000 f44ad000 09d9c000 00003000 fa54c000 00001000 f6d16f60 e4520b80 fffffffb e4533f70 c04ef8eb e4533f98 00008000 09d97000 c04f661a e4520b80 09d97000 c04ef88c e4533f8c c04ba531 e4533f98 c04c0930 e4520b80 Call Trace: [<c04ef8eb>] ? proc_reg_read+0x5f/0x73 [<c04f661a>] ? read_kcore+0x0/0x31a [<c04ef88c>] ? proc_reg_read+0x0/0x73 [<c04ba531>] ? vfs_read+0x82/0xe1 [<c04c0930>] ? path_put+0x1a/0x1d [<c04ba62e>] ? sys_read+0x40/0x62 [<c0403298>] ? sysenter_do_call+0x12/0x2d Code: 39 f3 89 ca 0f 43 f3 89 fb 29 f2 29 f3 39 cf 0f 46 d3 29 55 dc 8d 1c 32 f6 40 0c 01 75 18 89 d1 89 f7 c1 e9 02 2b 7d ec 03 7d e0 <f3> a5 89 d1 83 e1 03 74 02 f3 a4 8b 00 83 7d dc 00 74 04 85 c0 EIP: [<c04f687a>] read_kcore+0x260/0x31a SS:ESP 0068:e4533f24 CR2: 00000000fa54c000 To access vmalloc area which may have memory holes, copy_from_user is useful. So this: # cat /proc/kcore > /dev/null will not panic. This is a minimal fix, suitable for 2.6.30.x and 2.6.31. More extensive /proc/kcore changes are planned for 2.6.32. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Nick Craig-Wood <nick@craig-wood.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Reported-by: <kbowa@tuxedu.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05nfsd4: fix null dereference creating nfsv4 callback clientJ. Bruce Fields
commit 886e3b7fe6054230c89ae078a09565ed183ecc73 upstream. On setting up the callback to the client, we attempt to use the same authentication flavor the client did. We find an rpc cred to use by calling rpcauth_lookup_credcache(), which assumes that the given authentication flavor has a credentials cache. However, this is not required to be true--in particular, auth_null does not use one. Instead, we should call the auth's lookup_cred() method. Without this, a client attempting to mount using nfsv4 and auth_null triggers a null dereference. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05nilfs2: fix missing zero-fill initialization of btree node cacheRyusuke Konishi
commit 1f28fcd925b2b3157411bbd08f0024b55b70d8dd upstream. This will fix file system corruption which infrequently happens after mount. The problem was reported from users with the title "[NILFS users] Fail to mount NILFS." (Message-ID: <200908211918.34720.yuri@itinteg.net>), and so forth. I've also experienced the corruption multiple times on kernel 2.6.30 and 2.6.31. The problem turned out to be caused due to discordance between mapping->nrpages of a btree node cache and the actual number of pages hung on the cache; if the mapping->nrpages becomes zero even as it has pages, truncate_inode_pages() returns without doing anything. Usually this is harmless except it may cause page leak, but garbage collection fairly infrequently sees a stale page remained in the btree node cache of DAT (i.e. disk address translation file of nilfs), and induces the corruption. I identified a missing initialization in btree node caches was the root cause. This corrects the bug. I've tested this for kernel 2.6.30 and 2.6.31. Reported-by: Yuri Chislov <yuri@itinteg.net> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05Re-enable Lanman securityChuck Ebbert
commit 20d1752f3d6bd32beb90949559e0d14a0b234445 upstream. commit ac68392460ffefed13020967bae04edc4d3add06 ("[CIFS] Allow raw ntlmssp code to be enabled with sec=ntlmssp") added a new bit to the allowed security flags mask but seems to have inadvertently removed Lanman security from the allowed flags. Add it back. Signed-off-by: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05eCryptfs: Prevent lower dentry from going negative during unlinkTyler Hicks
commit 9c2d2056647790c5034d722bd24e9d913ebca73c upstream. When calling vfs_unlink() on the lower dentry, d_delete() turns the dentry into a negative dentry when the d_count is 1. This eventually caused a NULL pointer deref when a read() or write() was done and the negative dentry's d_inode was dereferenced in ecryptfs_read_update_atime() or ecryptfs_getxattr(). Placing mutt's tmpdir in an eCryptfs mount is what initially triggered the oops and I was able to reproduce it with the following sequence: open("/tmp/upper/foo", O_RDWR|O_CREAT|O_EXCL|O_NOFOLLOW, 0600) = 3 link("/tmp/upper/foo", "/tmp/upper/bar") = 0 unlink("/tmp/upper/foo") = 0 open("/tmp/upper/bar", O_RDWR|O_CREAT|O_NOFOLLOW, 0600) = 4 unlink("/tmp/upper/bar") = 0 write(4, "eCryptfs test\n"..., 14 <unfinished ...> +++ killed by SIGKILL +++ https://bugs.launchpad.net/ecryptfs/+bug/387073 Reported-by: Loïc Minier <loic.minier@canonical.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: ecryptfs-devel@lists.launchpad.net Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05eCryptfs: Validate global auth tok keysTyler Hicks
commit 3891959846709a19f76628e33478cd85edb0e79f upstream. When searching through the global authentication tokens for a given key signature, verify that a matching key has not been revoked and has not expired. This allows the `keyctl revoke` command to be properly used on keys in use by eCryptfs. Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: ecryptfs-devel@lists.launchpad.net Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05eCryptfs: Filename encryption only supports password auth tokensTyler Hicks
commit df6ad33ba1b9846bd5f0e2b9016c30c20bc2d948 upstream. Returns -ENOTSUPP when attempting to use filename encryption with something other than a password authentication token, such as a private token from openssl. Using filename encryption with a userspace eCryptfs key module is a future goal. Until then, this patch handles the situation a little better than simply using a BUG_ON(). Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: ecryptfs-devel@lists.launchpad.net Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05eCryptfs: Check for O_RDONLY lower inodes when opening lower filesTyler Hicks
commit ac22ba23b659e34a5961aec8c945608e471b0d5b upstream. If the lower inode is read-only, don't attempt to open the lower file read/write and don't hand off the open request to the privileged eCryptfs kthread for opening it read/write. Instead, only try an unprivileged, read-only open of the file and give up if that fails. This patch fixes an oops when eCryptfs is mounted on top of a read-only mount. Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Eric Sandeen <esandeen@redhat.com> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: ecryptfs-devel@lists.launchpad.net Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05eCryptfs: Handle unrecognized tag 3 cipher codesTyler Hicks
commit b0105eaefa7cce8f4a941d0fc6354b250d30e745 upstream. Returns an error when an unrecognized cipher code is present in a tag 3 packet or an ecryptfs_crypt_stat cannot be initialized. Also sets an crypt_stat->tfm error pointer to NULL to ensure that it will not be incorrectly freed in ecryptfs_destroy_crypt_stat(). Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: ecryptfs-devel@lists.launchpad.net Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05fs: make sure data stored into inode is properly seen before unlocking new inodeJan Kara
commit 580be0837a7a59b207c3d5c661d044d8dd0a6a30 upstream. In theory it could happen that on one CPU we initialize a new inode but clearing of I_NEW | I_LOCK gets reordered before some of the initialization. Thus on another CPU we return not fully uptodate inode from iget_locked(). This seems to fix a corruption issue on ext3 mounted over NFS. [akpm@linux-foundation.org: add some commentary] Signed-off-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-24binfmt_elf: fix PT_INTERP bss handlingRoland McGrath
commit 9f0ab4a3f0fdb1ff404d150618ace2fa069bb2e1 upstream. In fs/binfmt_elf.c, load_elf_interp() calls padzero() for .bss even if the PT_LOAD has no PROT_WRITE and no .bss. This generates EFAULT. Here is a small test case. (Yes, there are other, useful PT_INTERP which have only .text and no .data/.bss.) ----- ptinterp.S _start: .globl _start nop int3 ----- $ gcc -m32 -nostartfiles -nostdlib -o ptinterp ptinterp.S $ gcc -m32 -Wl,--dynamic-linker=ptinterp -o hello hello.c $ ./hello Segmentation fault # during execve() itself After applying the patch: $ ./hello Trace trap # user-mode execution after execve() finishes If the ELF headers are actually self-inconsistent, then dying is fine. But having no PROT_WRITE segment is perfectly normal and correct if there is no segment with p_memsz > p_filesz (i.e. bss). John Reiser suggested checking for PROT_WRITE in the bss logic. I think it makes most sense to simply apply the bss logic only when there is bss. This patch looks less trivial than it is due to some reindentation. It just moves the "if (last_bss > elf_bss) {" test up to include the partial-page bss logic as well as the more-pages bss logic. Reported-by: John Reiser <jreiser@bitwagon.com> Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-07IMA: update ima_counts_putMimi Zohar
- As ima_counts_put() may be called after the inode has been freed, verify that the inode is not NULL, before dereferencing it. - Maintain the IMA file counters in may_open() properly, decrementing any counter increments on subsequent errors. Reported-by: Ciprian Docan <docan@eden.rutgers.edu> Reported-by: J.R. Okajima <hooanon05@yahoo.co.jp> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Eric Paris <eparis@redhat.com Signed-off-by: James Morris <jmorris@namei.org>
2009-09-05Merge git://git.infradead.org/~dwmw2/mtd-2.6.31Linus Torvalds
* git://git.infradead.org/~dwmw2/mtd-2.6.31: JFFS2: add missing verify buffer allocation/deallocation mtd: nftl: fix offset alignments mtd: nftl: write support is broken mtd: m25p80: fix null pointer dereference bug
2009-09-05Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: actually enable the swapext compat handler
2009-09-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: nilfs2: fix preempt count underflow in nilfs_btnode_prepare_change_key
2009-09-05ext2: fix unbalanced kmap()/kunmap()Nicolas Pitre
In ext2_rename(), dir_page is acquired through ext2_dotdot(). It is then released through ext2_set_link() but only if old_dir != new_dir. Failing that, the pkmap reference count is never decremented and the page remains pinned forever. Repeat that a couple times with highmem pages and all pkmap slots get exhausted, and every further kmap() calls end up stalling on the pkmap_map_wait queue at which point the whole system comes to a halt. Signed-off-by: Nicolas Pitre <nico@marvell.com> Acked-by: Theodore Ts'o <tytso@mit.edu> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-05Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: ocfs2: ocfs2_write_begin_nolock() should handle len=0 ocfs2: invalidate dentry if its dentry_lock isn't initialized.
2009-09-05exec: do not sleep in TASK_TRACED under ->cred_guard_mutexOleg Nesterov
Tom Horsley reports that his debugger hangs when it tries to read /proc/pid_of_tracee/maps, this happens since "mm_for_maps: take ->cred_guard_mutex to fix the race with exec" 04b836cbf19e885f8366bccb2e4b0474346c02d commit in 2.6.31. But the root of the problem lies in the fact that do_execve() path calls tracehook_report_exec() which can stop if the tracer sets PT_TRACE_EXEC. The tracee must not sleep in TASK_TRACED holding this mutex. Even if we remove ->cred_guard_mutex from mm_for_maps() and proc_pid_attr_write(), another task doing PTRACE_ATTACH should not hang until it is killed or the tracee resumes. With this patch do_execve() does not use ->cred_guard_mutex directly and we do not hold it throughout, instead: - introduce prepare_bprm_creds() helper, it locks the mutex and calls prepare_exec_creds() to initialize bprm->cred. - install_exec_creds() drops the mutex after commit_creds(), and thus before tracehook_report_exec()->ptrace_stop(). or, if exec fails, free_bprm() drops this mutex when bprm->cred != NULL which indicates install_exec_creds() was not called. Reported-by: Tom Horsley <tom.horsley@att.net> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-04ocfs2: ocfs2_write_begin_nolock() should handle len=0Sunil Mushran
Bug introduced by mainline commit e7432675f8ca868a4af365759a8d4c3779a3d922 The bug causes ocfs2_write_begin_nolock() to oops when len=0. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Cc: stable@kernel.org Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-03JFFS2: add missing verify buffer allocation/deallocationMassimo Cirillo
The function jffs2_nor_wbuf_flash_setup() doesn't allocate the verify buffer if CONFIG_JFFS2_FS_WBUF_VERIFY is defined, so causing a kernel panic when that macro is enabled and the verify function is called. Similarly the jffs2_nor_wbuf_flash_cleanup() must free the buffer if CONFIG_JFFS2_FS_WBUF_VERIFY is enabled. The following patch fixes the problem. The following patch applies to 2.6.30 kernel. Signed-off-by: Massimo Cirillo <maxcir@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Cc: stable@kernel.org
2009-09-01xfs: actually enable the swapext compat handlerChristoph Hellwig
Fix a small typo in the compat ioctl handler that cause the swapext compat handler to never be called. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Torsten Kaiser <just.for.lkml@googlemail.com> Tested-by: Torsten Kaiser <just.for.lkml@googlemail.com> Reviewed-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Felix Blyakher <felixb@sgi.com> Signed-off-by: Felix Blyakher <felixb@sgi.com>
2009-08-31autofs4 - fix missed case when changing to use struct pathIan Kent
In the recent change by Al Viro that changes verious subsystems to use "struct path" one case was missed in the autofs4 module which causes mounts to no longer expire. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-31nilfs2: fix preempt count underflow in nilfs_btnode_prepare_change_keyRyusuke Konishi
This will fix the following preempt count underflow reported from users with the title "[NILFS users] segctord problem" (Message-ID: <949415.6494.qm@web58808.mail.re1.yahoo.com> and Message-ID: <debc30fc0908270825v747c1734xa59126623cfd5b05@mail.gmail.com>): WARNING: at kernel/sched.c:4890 sub_preempt_count+0x95/0xa0() Hardware name: HP Compaq 6530b (KR980UT#ABC) Modules linked in: bridge stp llc bnep rfcomm l2cap xfs exportfs nilfs2 cowloop loop vboxnetadp vboxnetflt vboxdrv btusb bluetooth uvcvideo videodev v4l1_compat v4l2_compat_ioctl32 arc4 snd_hda_codec_analog ecb iwlagn iwlcore rfkill lib80211 mac80211 snd_hda_intel snd_hda_codec ehci_hcd uhci_hcd usbcore snd_hwdep snd_pcm tg3 cfg80211 psmouse snd_timer joydev libphy ohci1394 snd_page_alloc hp_accel lis3lv02d ieee1394 led_class i915 drm i2c_algo_bit video backlight output i2c_core dm_crypt dm_mod Pid: 4197, comm: segctord Not tainted 2.6.30-gentoo-r4-64 #7 Call Trace: [<ffffffff8023fa05>] ? sub_preempt_count+0x95/0xa0 [<ffffffff802470f8>] warn_slowpath_common+0x78/0xd0 [<ffffffff8024715f>] warn_slowpath_null+0xf/0x20 [<ffffffff8023fa05>] sub_preempt_count+0x95/0xa0 [<ffffffffa04ce4db>] nilfs_btnode_prepare_change_key+0x11b/0x190 [nilfs2] [<ffffffffa04d01ad>] nilfs_btree_assign_p+0x19d/0x1e0 [nilfs2] [<ffffffffa04d10ad>] nilfs_btree_assign+0xbd/0x130 [nilfs2] [<ffffffffa04cead7>] nilfs_bmap_assign+0x47/0x70 [nilfs2] [<ffffffffa04d9bc6>] nilfs_segctor_do_construct+0x956/0x20f0 [nilfs2] [<ffffffff805ac8e2>] ? _spin_unlock_irqrestore+0x12/0x40 [<ffffffff803c06e0>] ? __up_write+0xe0/0x150 [<ffffffff80262959>] ? up_write+0x9/0x10 [<ffffffffa04ce9f3>] ? nilfs_bmap_test_and_clear_dirty+0x43/0x60 [nilfs2] [<ffffffffa04cd627>] ? nilfs_mdt_fetch_dirty+0x27/0x60 [nilfs2] [<ffffffffa04db5fc>] nilfs_segctor_construct+0x8c/0xd0 [nilfs2] [<ffffffffa04dc3dc>] nilfs_segctor_thread+0x15c/0x3a0 [nilfs2] [<ffffffffa04dbe20>] ? nilfs_construction_timeout+0x0/0x10 [nilfs2] [<ffffffff80252633>] ? add_timer+0x13/0x20 [<ffffffff802370da>] ? __wake_up_common+0x5a/0x90 [<ffffffff8025e960>] ? autoremove_wake_function+0x0/0x40 [<ffffffffa04dc280>] ? nilfs_segctor_thread+0x0/0x3a0 [nilfs2] [<ffffffffa04dc280>] ? nilfs_segctor_thread+0x0/0x3a0 [nilfs2] [<ffffffff8025e556>] kthread+0x56/0x90 [<ffffffff8020cdea>] child_rip+0xa/0x20 [<ffffffff8025e500>] ? kthread+0x0/0x90 [<ffffffff8020cde0>] ? child_rip+0x0/0x20 This problem was caused due to a missing radix_tree_preload() call in the retry path of nilfs_btnode_prepare_change_key() function. Reported-by: Eric A <eric225125@yahoo.com> Reported-by: Jerome Poulin <jeromepoulin@gmail.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Jerome Poulin <jeromepoulin@gmail.com> Cc: stable@kernel.org
2009-08-28inotify: update the group mask on mark additionEric Paris
Seperating the addition and update of marks in inotify resulted in a regression in that inotify never gets events. The inotify group mask is always 0. This mask should be updated any time a new mark is added. Signed-off-by: Eric Paris <eparis@redhat.com>
2009-08-28inotify: fix length reporting and size checkingEric Paris
0db501bd0610ee0c0 introduced a regresion in that it now sends a nul terminator but the length accounting when checking for space or reporting to userspace did not take this into account. This corrects all of the rounding logic. Signed-off-by: Eric Paris <eparis@redhat.com>
2009-08-28inotify: do not send a block of zeros when no pathname is availableBrian Rogers
When an event has no pathname, there's no need to pad it with a null byte and therefore generate an inotify_event sized block of zeros. This fixes a regression introduced by commit 0db501bd0610ee0c0aca84d927f90bcccd09e2bd where my system wouldn't finish booting because some process was being confused by this. Signed-off-by: Brian Rogers <brian@xyzw.org> Signed-off-by: Eric Paris <eparis@redhat.com>
2009-08-27ocfs2: invalidate dentry if its dentry_lock isn't initialized.Tao Ma
In commit a5a0a630922a2f6a774b6dac19f70cb5abd86bb0, when ocfs2_attch_dentry_lock fails, we call an extra iput and reset dentry->d_fsdata to NULL. This resolve a bug, but it isn't completed and the dentry is still there. When we want to use it again, ocfs2_dentry_revalidate doesn't catch it and return true. That make future ocfs2_dentry_lock panic out. One bug is http://oss.oracle.com/bugzilla/show_bug.cgi?id=1162. The resolution is to add a check for dentry->d_fsdata in revalidate process and return false if dentry->d_fsdata is NULL, so that a new ocfs2_lookup will be called again. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-08-27Merge branch 'for-linus' of git://git.infradead.org/users/eparis/notifyLinus Torvalds
* 'for-linus' of git://git.infradead.org/users/eparis/notify: inotify: Ensure we alwasy write the terminating NULL. inotify: fix locking around inotify watching in the idr inotify: do not BUG on idr entries at inotify destruction inotify: seperate new watch creation updating existing watches
2009-08-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: update documentation pointers 9p: remove unnecessary v9fses->options which duplicates the mount string net/9p: insulate the client against an invalid error code sent by a 9p server 9p: Add missing cast for the error return value in v9fs_get_inode 9p: Remove redundant inode uid/gid assignment 9p: Fix possible regressions when ->get_sb fails. 9p: Fix v9fs show_options 9p: Fix possible memleak in v9fs_inode_from fid. 9p: minor comment fixes 9p: Fix possible inode leak in v9fs_get_inode. 9p: Check for error in return value of v9fs_fid_add
2009-08-27AFS: Stop readlink() on AFS crashing due to NULL 'file' ptrDavid Howells
kAFS crashes when asked to read a symbolic link because page_getlink() passes a NULL file pointer to read_mapping_page(), but afs_readpage() expects a file pointer from which to extract a key. Modify afs_readpage() to request the appropriate key from the calling process's keyrings if a file struct is not supplied with one attached. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Anton Blanchard <anton@samba.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-27inotify: Ensure we alwasy write the terminating NULL.Eric W. Biederman
Before the rewrite copy_event_to_user always wrote a terqminating '\0' byte to user space after the filename. Since the rewrite that terminating byte was skipped if your filename is exactly a multiple of event_size. Ouch! So add one byte to name_size before we round up and use clear_user to set userspace to zero like /dev/zero does instead of copying the strange nul_inotify_event. I can't quite convince myself len_to_zero will never exceed 16 and even if it doesn't clear_user should be more efficient and a more accurate reflection of what the code is trying to do. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2009-08-27inotify: fix locking around inotify watching in the idrEric Paris
The are races around the idr storage of inotify watches. It's possible that a watch could be found from sys_inotify_rm_watch() in the idr, but it could be removed from the idr before that code does it's removal. Move the locking and the refcnt'ing so that these have to happen atomically. Signed-off-by: Eric Paris <eparis@redhat.com>
2009-08-27inotify: do not BUG on idr entries at inotify destructionEric Paris
If an inotify watch is left in the idr when an fsnotify group is destroyed this will lead to a BUG. This is not a dangerous situation and really indicates a programming bug and leak of memory. This patch changes it to use a WARN and a printk rather than killing people's boxes. Signed-off-by: Eric Paris <eparis@redhat.com>
2009-08-27inotify: seperate new watch creation updating existing watchesEric Paris
There is nothing known wrong with the inotify watch addition/modification but this patch seperates the two code paths to make them each easy to verify as correct. Signed-off-by: Eric Paris <eparis@redhat.com>
2009-08-25Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: ext3: Improve error message that changing journaling mode on remount is not possible ext3: Update Kconfig description of EXT3_DEFAULTS_TO_ORDERED
2009-08-24NFSv4: Fix an infinite looping problem with the nfs4_state_managerTrond Myklebust
Commit 76db6d9500caeaa774a3e32a997eba30bbdc176b (nfs41: add session setup to the state manager) introduces an infinite loop possibility in the NFSv4 state manager. By first checking nfs4_has_session() before clearing the NFS4CLNT_SESSION_SETUP flag, it allows for a situation where someone sets that flag, but it never gets cleared, and so the state manager loops. In fact commit c3fad1b1aaf850bf692642642ace7cd0d64af0a3 (nfs41: add session reset to state manager) causes this to happen every time we get a network partition error. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Tested-by: Daniel J Blueman <daniel.blueman@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-24Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: ocfs2/dlm: Wait on lockres instead of erroring cancel requests ocfs2: Add missing lock name ocfs2: Don't oops in ocfs2_kill_sb on a failed mount ocfs2: release the buffer head in ocfs2_do_truncate. ocfs2: Handle quota file corruption more gracefully
2009-08-24mm: fix hugetlb bug due to user_shm_unlock callHugh Dickins
2.6.30's commit 8a0bdec194c21c8fdef840989d0d7b742bb5d4bc removed user_shm_lock() calls in hugetlb_file_setup() but left the user_shm_unlock call in shm_destroy(). In detail: Assume that can_do_hugetlb_shm() returns true and hence user_shm_lock() is not called in hugetlb_file_setup(). However, user_shm_unlock() is called in any case in shm_destroy() and in the following atomic_dec_and_lock(&up->__count) in free_uid() is executed and if up->__count gets zero, also cleanup_user_struct() is scheduled. Note that sched_destroy_user() is empty if CONFIG_USER_SCHED is not set. However, the ref counter up->__count gets unexpectedly non-positive and the corresponding structs are freed even though there are live references to them, resulting in a kernel oops after a lots of shmget(SHM_HUGETLB)/shmctl(IPC_RMID) cycles and CONFIG_USER_SCHED set. Hugh changed Stefan's suggested patch: can_do_hugetlb_shm() at the time of shm_destroy() may give a different answer from at the time of hugetlb_file_setup(). And fixed newseg()'s no_id error path, which has missed user_shm_unlock() ever since it came in 2.6.9. Reported-by: Stefan Huber <shuber2@gmail.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Tested-by: Stefan Huber <shuber2@gmail.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-24ext3: Improve error message that changing journaling mode on remount is not ↵Jan Kara
possible This patch makes the error message about changing journaling mode on remount more descriptive. Some people are going to hit this error now due to commit bbae8bcc49bc4d002221dab52c79a50a82e7cd1f if they configure a kernel to default to data=writeback mode. The problem happens if they have data=ordered set for the root filesystem in /etc/fstab but not in the kernel command line (and they don't use initrd). Their filesystem then gets mounted as data=writeback by kernel but then their boot fails because init scripts won't be able to remount the filesystem rw. Better error message will hopefully make it easier for them to find the error in their setup and bother us less with error reports :). Signed-off-by: Jan Kara <jack@suse.cz>
2009-08-24ext3: Update Kconfig description of EXT3_DEFAULTS_TO_ORDEREDTheodore Ts'o
The old description for this configuration option was perhaps not completely balanced in terms of describing the tradeoffs of using a default of data=writeback vs. data=ordered. Despite the fact that old description very strongly recomended disabling this feature, all of the major distributions have elected to preserve the existing 'legacy' default, which is a strong hint that it perhaps wasn't telling the whole story. This revised description has been vetted by a number of ext3 developers as being better at informing the user about the tradeoffs of enabling or disabling this configuration feature. Cc: linux-ext4@vger.kernel.org Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Jan Kara <jack@suse.cz>
2009-08-24kernel_read: redefine offset typeMimi Zohar
vfs_read() offset is defined as loff_t, but kernel_read() offset is only defined as unsigned long. Redefine kernel_read() offset as loff_t. Cc: stable@kernel.org Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-21Re-introduce page mapping check in mark_buffer_dirty()Linus Torvalds
In commit a8e7d49aa7be728c4ae241a75a2a124cdcabc0c5 ("Fix race in create_empty_buffers() vs __set_page_dirty_buffers()"), I removed a test for a NULL page mapping unintentionally when some of the code inside __set_page_dirty() was moved to the callers. That removal generally didn't matter, since a filesystem would serialize truncation (which clears the page mapping) against writing (which marks the buffer dirty), so locking at a higher level (either per-page or an inode at a time) should mean that the buffer page would be stable. And indeed, nothing bad seemed to happen. Except it turns out that apparently reiserfs does something odd when under load and writing out the journal, and we have a number of bugzilla entries that look similar: http://bugzilla.kernel.org/show_bug.cgi?id=13556 http://bugzilla.kernel.org/show_bug.cgi?id=13756 http://bugzilla.kernel.org/show_bug.cgi?id=13876 and it looks like reiserfs depended on that check (the common theme seems to be "data=journal", and a journal writeback during a truncate). I suspect reiserfs should have some additional locking, but in the meantime this should get us back to the pre-2.6.29 behavior. Pattern-pointed-out-by: Roland Kletzing <devzero@web.de> Cc: stable@kernel.org (2.6.29 and 2.6.30) Cc: Jeff Mahoney <jeffm@suse.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-21Merge branch 'btrfs' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'btrfs' of git://git.kernel.dk/linux-2.6-block: btrfs: fix inode rbtree corruption
2009-08-21btrfs: fix inode rbtree corruptionFrom: Nick Piggin
Node may not be inserted over existing node. This causes inode tree corruption and I was seeing crashes in inode_tree_del which I can not reproduce after this patch. The other way to fix this would be to tie inode lifetime in the rbtree with inode while not in freeing state. I had a look at this but it is not so trivial at this point. At least this patch gets things working again. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Chris Mason <chris.mason@oracle.com> Acked-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-08-20ocfs2/dlm: Wait on lockres instead of erroring cancel requestsGoldwyn Rodrigues
In case a downconvert is queued, and a flock receives a signal, BUG_ON(lockres->l_action != OCFS2_AST_INVALID) is triggered because a lock cancel triggers a dlmunlock while an AST is scheduled. To avoid this, allow a LKM_CANCEL to pass through, and let it wait on __dlm_wait_on_lockres(). Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de> Acked-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-08-20ocfs2: Add missing lock nameJan Kara
There is missing name for NFSSync cluster lock. This makes lockdep unhappy because we end up passing NULL to lockdep when initializing lock key. Fix it. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-08-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: nilfs2: fix oopses with doubly mounted snapshots nilfs2: missing a read lock for segment writer in nilfs_attach_checkpoint()
