CVE-2006-5753 is for a case where an inode can be marked bad, switching
the ops to bad_inode_ops, which are all connected as:
static int return_EIO(void)
return -EIO;
#define EIO_ERROR ((void *) (return_EIO))
static struct inode_operations bad_inode_ops =
.create = bad_inode_create
...etc...
The problem here is that the void cast causes return types to not be
promoted, and for ops such as listxattr which expect more than 32 bits of
return value, the 32-bit -EIO is interpreted as a large positive 64-bit
number, i.e. 0x00000000fffffffa instead of 0xfffffffa.
This goes particularly badly when the return value is taken as a number of
bytes to copy into, say, a user's buffer for example...
I originally had coded up the fix by creating a return_EIO_<TYPE> macro
for each return type, like this:
static int return_EIO_int(void)
return -EIO;
#define EIO_ERROR_INT ((void *) (return_EIO_int))
.create = EIO_ERROR_INT,
...etc...
but Al felt that it was probably better to create an EIO-returner for each
actual op signature. Since so few ops share a signature, I just went ahead
& created an EIO function for each individual file & inode op that returns
a value.
Adrian Bunk:
backported to 2.6.16
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Due to type confusion, when an nfsacl verison 2 'ACCESS' request
finishes and tries to clean up, it calls fh_put on entiredly the
wrong thing and this can cause an oops.
This also adds he required page "writeback" flag handling, that cifs
hasn't been doing and that the page dirty flag changes made obvious.
Acked-by: Steve French <smfltc@us.ibm.com>
Fix insecure default behaviour reported by Tigran Aivazian: if an
ext2 or ext3 filesystem is tuned to mount with "acl", but mounted by
a kernel built without ACL support, then umask was ignored when creating
inodes - though root or user has umask 022, touch creates files as 0666,
and mkdir creates directories as 0777.
This appears to have worked right until 2.6.11, when a fix to the default
mode on symlinks (always 0777) assumed VFS applies umask: which it does,
unless the mount is marked for ACLs; but ext[23] set MS_POSIXACL in
s_flags according to s_mount_opt set according to def_mount_opts.
We could revert to the 2.6.10 ext[23]_init_acl (adding an S_ISLNK test);
but other filesystems only set MS_POSIXACL when ACLs are configured. We
could fix this at another level; but it seems most robust to avoid setting
the s_mount_opt flag in the first place (at the expense of more ifdefs).
Likewise don't set the XATTR_USER flag when built without XATTR support.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
This patch fixes a confusion reiserfs has for a long time.
On release file operation reiserfs used to try to pack file data stored in
last incomplete page of some files into metadata blocks. After packing the
page got cleared with clear_page_dirty. It did not take into account that
the page may be mmaped into other process's address space. Recent
replacement for clear_page_dirty cancel_dirty_page found the confusion with
sanity check that page has to be not mapped.
The patch fixes the confusion by making reiserfs avoid tail packing if an
inode was ever mmapped. reiserfs_mmap and reiserfs_file_release are
serialized with mutex in reiserfs specific inode. reiserfs_mmap locks the
mutex and sets a bit in reiserfs specific inode flags.
reiserfs_file_release checks the bit having the mutex locked. If bit is
set - tail packing is avoided. This eliminates a possibility that mmapped
page gets cancel_page_dirty-ed.
Signed-off-by: Vladimir Saveliev <vs@namesys.com>
Fix filenames on adfs discs being terminated at the first character greater
than 128 (adfs filenames are Latin 1). I saw this problem when using a
loopback adfs image on a 2.6.17-rc5 x86_64 machine, and the patch fixed it
there.
This was triggered, but not the fault of, the dirty page accounting
patches. Suitable for -stable as well, after it goes upstream.
Unable to handle kernel NULL pointer dereference at virtual address 0000004c
EIP is at _spin_lock+0x12/0x66
Call Trace:
[<401766e7>] __set_page_dirty_buffers+0x15/0xc0
[<401401e7>] set_page_dirty+0x2c/0x51
[<40140db2>] set_page_dirty_balance+0xb/0x3b
[<40145d29>] __do_fault+0x1d8/0x279
[<40147059>] __handle_mm_fault+0x125/0x951
[<401133f1>] do_page_fault+0x440/0x59f
[<4034d0c1>] error_code+0x39/0x40
[<08048a33>] 0x8048a33
Signed-off-by: Nick Piggin <npiggin@suse.de>
OpenVZ Linux kernel team has found a problem with mounting in compat mode.
Simple command "mount -t smbfs ..." on Fedora Core 5 distro in 32-bit mode
leads to oops:
Unable to handle kernel NULL pointer dereference at 0000000000000000 RIP:
[<ffffffff802bc7c6>] compat_sys_mount+0xd6/0x290
PGD 34d48067 PUD 34d03067 PMD 0
Oops: 0000 [1] SMP
CPU: 0
Modules linked in: iptable_nat simfs smbfs ip_nat ip_conntrack vzdquota
parport_pc lp parport 8021q bridge llc vznetdev vzmon nfs lockd sunrpc vzdev
iptable_filter af_packet xt_length ipt_ttl xt_tcpmss ipt_TCPMSS
iptable_mangle xt_limit ipt_tos ipt_REJECT ip_tables x_tables thermal
processor fan button battery asus_acpi ac uhci_hcd ehci_hcd usbcore i2c_i801
i2c_core e100 mii floppy ide_cd cdrom
Pid: 14656, comm: mount
RIP: 0060:[<ffffffff802bc7c6>] [<ffffffff802bc7c6>]
RSP: 0000:ffff810034d31f38 EFLAGS: 00010292
RAX: 000000000000002c RBX: 0000000000000000 RCX: 0000000000000000
RDX: ffff810034c86bc0 RSI: 0000000000000096 RDI: ffffffff8061fc90
RBP: ffff810034d31f78 R08: 0000000000000000 R09: 000000000000000d
R10: ffff810034d31e58 R11: 0000000000000001 R12: ffff810039dc3000
R13: 000000000805ea48 R14: 0000000000000000 R15: 00000000c0ed0000
FS: 0000000000000000(0000) GS:ffffffff80749000(0033) knlGS:00000000b7d556b0
CS: 0060 DS: 007b ES: 007b CR0: 000000008005003b
CR2: 0000000000000000 CR3: 0000000034d43000 CR4: 00000000000006e0
Process mount (pid: 14656, veid=300, threadinfo ffff810034d30000, task
ffff810034c86bc0)
Stack: 0000000000000000 ffff810034dd0000 ffff810034e4a000 000000000805ea48
0000000000000000 0000000000000000 0000000000000000 0000000000000000
000000000805ea48 ffffffff8021e64e 0000000000000000 0000000000000000
Call Trace:
[<ffffffff8021e64e>] ia32_sysret+0x0/0xa
Code: 83 3b 06 0f 85 41 01 00 00 0f b7 43 0c 89 43 14 0f b7 43 0a
RIP [<ffffffff802bc7c6>] compat_sys_mount+0xd6/0x290
RSP <ffff810034d31f38>
The problem is that data_page pointer can be NULL, so we should skip data
conversion in this case.
Signed-off-by: Andrey Mirkin <amirkin@openvz.org>
Steve Grubb's fzfuzzer tool (http://people.redhat.com/sgrubb/files/
fsfuzzer-0.6.tar.gz) generates corrupt Cramfs filesystems which cause
Cramfs to kernel oops in cramfs_uncompress_block(). The cause of the oops
is an unchecked corrupted block length field read by cramfs_readpage().
This patch adds a sanity check to cramfs_readpage() which checks that the
block length field is sensible. The (PAGE_CACHE_SIZE << 1) size check is
intentional, even though the uncompressed data is not going to be larger
than PAGE_CACHE_SIZE, gzip sometimes generates compressed data larger than
the original source data. Mkcramfs checks that the compressed size is
always less than or equal to PAGE_CACHE_SIZE << 1. Of course Cramfs could
use the original uncompressed data in this case, but it doesn't.
Signed-off-by: Phillip Lougher <phillip@lougher.org.uk>
I've been using Steve Grubb's purely evil "fsfuzzer" tool, at
http://people.redhat.com/sgrubb/files/fsfuzzer-0.4.tar.gz
Basically it makes a filesystem, splats some random bits over it, then
tries to mount it and do some simple filesystem actions.
At best, the filesystem catches the corruption gracefully. At worst,
things spin out of control.
As you might guess, we found a couple places in ext3 where things spin out
of control :)
First, we had a corrupted directory that was never checked for
consistency... it was corrupt, and pointed to another bad "entry" of
length 0. The for() loop looped forever, since the length of
ext3_next_entry(de) was 0, and we kept looking at the same pointer over and
over and over and over... I modeled this check and subsequent action on
what is done for other directory types in ext3_readdir...
(adding this check adds some computational expense; I am testing a followup
patch to reduce the number of times we check and re-check these directory
entries, in all cases. Thanks for the idea, Andreas).
Next we had a root directory inode which had a corrupted size, claimed to
be > 200M on a 4M filesystem. There was only really 1 block in the
directory, but because the size was so large, readdir kept coming back for
more, spewing thousands of printk's along the way.
Per Andreas' suggestion, if we're in this read error condition and we're
trying to read an offset which is greater than i_blocks worth of bytes,
stop trying, and break out of the loop.
With these two changes fsfuzz test survives quite well on ext3.
This one was pointed out on the MOKB site:
http://kernelfun.blogspot.com/2006/11/mokb-09-11-2006-linux-26x-ext2checkpage.html
If a directory's i_size is corrupted, ext2_find_entry() will keep processing
pages until the i_size is reached, even if there are no more blocks associated
with the directory inode. This patch puts in some minimal sanity-checking
so that we don't keep checking pages (and issuing errors) if we know there
can be no more data to read, based on the block count of the directory inode.
This is somewhat similar in approach to the ext3 patch I sent earlier this
year.
http://kernelfun.blogspot.com/2006/11/mokb-14-11-2006-linux-26x-selinux.html
mount that image...
fs: filesystem was not cleanly unmounted, running fsck.hfs is recommended. mounting read-only.
hfs: get root inode failed.
BUG: unable to handle kernel NULL pointer dereference at virtual address 00000018
printing eip
EIP is at superblock_doinit+0x21/0x767
[] selinux_sb_kern_mount+0xc/0x4b
[] vfs_kern_mount+0x99/0xf6
[] do_kern_mount+0x2d/0x3e
[] do_mount+0x5fa/0x66d
[] sys_mount+0x77/0xae
[] syscall_call+0x7/0xb
DWARF2 unwinder stuck at syscall_call+0x7/0xb
hfs_fill_super() returns success even if
root_inode = hfs_iget(sb, &fd.search_key->cat, &rec);
or
sb->s_root = d_alloc_root(root_inode);
fails. This superblock finds its way to superblock_doinit() which does:
struct dentry *root = sb->s_root;
struct inode *inode = root->d_inode;
and boom. Need to make sure the error cases return an error, I think.
[akpm@osdl.org: return -ENOMEM on oom]
If grow_buffers() is for some reason passed a block number which wants to li
outside the maximum-addressable pagecache range (PAGE_SIZE * 4G bytes) then
will accidentally truncate `index' and will then instnatiate a page at the
wrong pagecache offset. This causes __getblk_slow() to go into an infinite
loop.
This can happen with corrupted disks, or with software errors elsewhere.
Detect that, and handle it.
Fuse didn't always call i_size_write() with i_mutex held which caused
rare hangs on SMP/32bit. This bug has been present since fuse-2.2,
well before being merged into mainline.
The simplest solution is to protect i_size_write() with the
per-connection spinlock. Using i_mutex for this purpose would require
some restructuring of the code and I'm not even sure it's always safe
to acquire i_mutex in all places i_size needs to be set.
Since most of vmtruncate is already duplicated for other reasons,
duplicate the remaining part as well, making all i_size_write() calls
internal to fuse.
Using i_size_write() was unnecessary in fuse_init_inode(), since this
function is only called on a newly created locked inode.
Reported by a few people over the years, but special thanks to Dana
Henriksen who was persistent enough in helping me debug it.
Adrian Bunk:
Backported to 2.6.16.
Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
If the open intents tell us that a given lookup is going to result in a,
exclusive create, we currently optimize away the lookup call itself. The
reason is that the lookup would not be atomic with the create RPC call, so
why do it in the first place?
A problem occurs, however, if the VFS aborts the exclusive create operation
after the lookup, but before the call to create the file/directory: in this
case we will end up with a hashed negative dentry in the dcache that has
never been looked up.
Fix this by only actually hashing the dentry once the create operation has
been successfully completed.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Fix check for bad address; use macro instead of open-coding two checks.
Taken from RHEL4 kernel update.
For background, the BAD_ADDR() macro should return TRUE if the address is
TASK_SIZE, because that's the lowest address that is *not* valid for
user-space mappings. The macro was correct in binfmt_aout.c but was wrong
for the "equal to" case in binfmt_elf.c. There were two in-line validations
of user-space addresses in binfmt_elf.c, which have been appropriately
converted to use the corrected BAD_ADDR() macro in the patch you posted
yesterday. Note that the size checks against TASK_SIZE are okay as coded.
The additional changes that I propose are below. These are in the error
paths for bad ELF entry addresses once load_elf_binary() has already
committed to exec'ing the new image (following the tearing down of the
task's original address space).
The 1st hunk deals with the interp-side of the outer "if". There were two
problems here. The printk() should be removed because this path can be
triggered at will by a bogus interpreter image created and used by a
malicious user. Further, the error code should not be ENOEXEC, because that
causes the loop in search_binary_handler() to continue trying other exec
handlers (twice, in fact). But it's too late for this to work correctly,
because the user address space has already been torn down, and an exec()
failure cannot be returned to the user code because the code no longer
exists. The only recovery is to force a SIGSEGV, but it's best to terminate
the search loop immediately. I somewhat arbitrarily chose EINVAL as a
fallback error code, but any error returned by load_elf_interp() will
override that (but this value will never be seen by user-space).
The 2nd hunk deals with the non-interp-side of the outer "if". There were
two problems here as well. The SIGSEGV needs to be forced, because a prior
sigaction() syscall might have set the associated disposition to SIG_IGN.
And the ENOEXEC should be changed to EINVAL as described above.
Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com>
fcntl(F_SETSIG) no longer works on leases because
lease_release_private_callback() gets called as the lease is copied in
order to initialise it.
The problem is that lease_alloc() performs an unnecessary initialisation,
which sets the lease_manager_ops. Avoid the problem by allocating the
target lease structure using locks_alloc_lock().
diRead and diWrite are representing the page number as an unsigned int.
This causes file system corruption on volumes larger than 16TB.
Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
Commit 7b2fd697427e73c81d5fa659efd91bd07d303b0e in the historical GIT tree
stopped calling the readdir member of a file_operations struct with the big
kernel lock held, and fixed up all the readdir functions to do their own
locking. However, that change added calls to unlock_kernel() in
vxfs_readdir, but no call to lock_kernel(). Fix this by adding a call to
lock_kernel().
Signed-off-by: Josh Triplett <josh@freedesktop.org>
sbi->s_group_desc is an array of pointers to buffer_head. memcpy() of
buffer size from address of buffer_head is a bad idea - it will generate
junk in any case, may oops if buffer_head is close to the end of slab
page and next page is not mapped and isn't what was intended there.
IOW, ->b_data is missing in that call. Fortunately, result doesn't go
into the primary on-disk data structures, so only backup ones get crap
written to them; that had allowed this bug to remain unnoticed until
now.
Fixes Samba bugzilla bug # 4182
Rename by handle failures (retry after rename by path) were not
being returned back.
Signed-off-by: Steve French <sfrench@us.ibm.com>
Following function can drops d_count twice against one reference
by lookup_one_len.
<SOURCE>
* sysfs_update_file - update the modified timestamp on an object attribute.
* @kobj: object we're acting for.
* @attr: attribute descriptor.
int sysfs_update_file(struct kobject * kobj, const struct attribute * attr)
struct dentry * dir = kobj->dentry;
struct dentry * victim;
int res = -ENOENT;
mutex_lock(&dir->d_inode->i_mutex);
victim = lookup_one_len(attr->name, dir, strlen(attr->name));
if (!IS_ERR(victim)) {
/* make sure dentry is really there */
if (victim->d_inode &&
(victim->d_parent->d_inode == dir->d_inode)) {
victim->d_inode->i_mtime = CURRENT_TIME;
fsnotify_modify(victim);
* Drop reference from initial sysfs_get_dentry().
dput(victim);
res = 0;
} else
d_drop(victim);
* Drop the reference acquired from sysfs_get_dentry() above.
dput(victim);
mutex_unlock(&dir->d_inode->i_mutex);
return res;
</SOURCE>
PCI-hotplug (drivers/pci/hotplug/pci_hotplug_core.c) is only user of
this function. I confirmed that dentry of /sys/bus/pci/slots/XXX/*
have negative d_count value.
This patch removes unnecessary dput().
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
In bugzilla #6941, Jens Kilian reported:
"The function befs_utf2nls (in fs/befs/linuxvfs.c) writes a 0 byte past the
end of a block of memory allocated via kmalloc(), leading to memory
corruption. This happens only for filenames which are pure ASCII and a
multiple of 4 bytes in length. [...]
Without DEBUG_SLAB, this leads to further corruption and hard lockups; I
believe this is the bug which has made kernels later than 2.6.8 unusable
for me. (This must be due to changes in memory management, the bug has
been in the BeFS driver since the time it was introduced (AFAICT).)
Steps to reproduce:
Create a directory (in BeOS, naturally :-) with files named, e.g.,
"1", "22", "333", "4444", ... Mount it in Linux and do an "ls" or "find""
This patch implements the suggested fix. Credits to Jens Kilian for
debugging the problem and finding the right fix.
Signed-off-by: Diego Calleja <diegocg@gmail.com>
For files other than IFREG, nobh option doesn't make sense. Modifications
to them are journalled and needs buffer heads to do that. Without this
patch, we get kernel oops in page_buffers().
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
The current sun disklabel code uses a signed int for the sector count.
When partitions larger than 1 TB are used, the cast to a sector_t causes
the partition sizes to be invalid:
# cat /proc/paritions | grep sdan
66 112 2146435072 sdan
66 115 9223372036853660736 sdan3
66 120 9223372036853660736 sdan8
This patch switches the sector count to an unsigned int to fix this.
Eric Sandeen also submitted the same patch.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
This just turns off chmod() on the /proc/<pid>/ files, since there is no
good reason to allow it, and had we disallowed it originally, the nasty
/proc race exploit wouldn't have been possible.
The other patches already fixed the problem chmod() could cause, so this
is really just some final mop-up..
This particular version is based off a patch by Eugene and Marcel which
had much better naming than my original equivalent one.
Signed-off-by: Eugene Teo <eteo@redhat.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Else a subsequent bio_clone might make a mess.
Signed-off-by: Neil Brown <neilb@suse.de>
Acked-by: Jens Axboe <axboe@suse.de>
Make cifsd allow us to suspend if it has lost the connection with a server
Ref: http://bugzilla.kernel.org/show_bug.cgi?id=6811
Since cifs_unlink can also be called from rename path and there
was one report of oops am making the extra check for null inode.
heavy stress.
When found, it is obvious. nfds calculated when allocating fdsets is
rewritten by calculation of size of fdtable, and when we are unlucky, we
try to free fdsets of wrong size.
Found due to OpenVZ resource management (User Beancounters).
Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Signed-off-by: Kirill Korotaev <dev@openvz.org>
This prevents bad inode numbers from triggering errors in
ext2_get_inode.
2.6.16 leaks like hell. While testing, I found massive filp leakage
(reproduced in openvz) in the bowels of namei.c.
blatantly ripped off from Neil Brown's ext2 patch.
Signed-off-by: Eric Sandeen <sandeen@sandeen.net>
Acked-by: "Theodore Ts'o" <tytso@mit.edu>
The inode number out of an NFS file handle gets passed eventually to
ext3_get_inode_block() without any checking. If ext3_get_inode_block()
allows it to trigger an error, then bad filehandles can have unpleasant
effect - ext3_error() will usually cause a forced read-only remount, or a
panic if `errors=panic' was used.
So remove the call to ext3_error there and put a matching check in
ext3/namei.c where inode numbers are read off storage.
Andrew Morton fixed an off-by-one error.
Dann Frazier ported the patch to 2.6.16.
UDF code is not really ready to handle extents larger that 1GB. This is
the easy way to forbid creating those.
Also truncation code did not count with the case when there are no
extents in the file and we are extending the file.
Looking at the reiser4 crash, I found a leak in debugfs. In
debugfs_mknod(), we create the inode before checking if the dentry
already has one attached. We don't free it if that is the case.
Signed-off-by: Jens Axboe <axboe@suse.de>
If get_user_pages() returns less pages than what we asked for, we
jump to out_unmap which will return ERR_PTR(ret). But ret can contain
a positive number just smaller than local_nr_pages, so be sure to set
it to -EFAULT always.
Problem found and diagnosed by Damien Le Moal <damien@sdl.hitachi.co.jp>
Relax /proc fix a bit
Clearign all of i_mode was a bit draconian. We only really care about
S_ISUID/ISGID, after all.
Fix nasty /proc vulnerability
We have a bad interaction with both the kernel and user space being able
to change some of the /proc file status. This fixes the most obvious
part of it, but I expect we'll also make it harder for users to modify
even their "own" files in /proc.
It fixes a crash in NTFS on architectures where flush_dcache_page()
is a real function. I never noticed this as all my testing is done on
i386 where flush_dcache_page() is NULL.
http://bugzilla.kernel.org/show_bug.cgi?id=6700
Many thanks to Pauline Ng for the detailed bug report and analysis!
Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
Cc: <stable@kernel.org>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
It looks like metapage_releasepage was making in invalid assumption that
the releasepage method would not be called on a dirty page. Instead of
issuing a warning and releasing the metapage, it should return 0, indicating
that the private data for the page cannot be released.
I also realized that metapage_releasepage had the return code all wrong. If
it is successful in releasing the private data, it should return 1, otherwise
it needs to return 0.
Lastly, there is no need to call wait_on_page_writeback, since
try_to_release_page will not call us with a page in writback state.
do_lookup_path()
We're presently running lock_kernel() under fs_lock via nfs's ->permission
handler. That's a ranking bug and sometimes a sleep-in-spinlock bug. This
problem was introduced in the openat() patchset.
We should not need to hold the current->fs->lock for a codepath that doesn't
use current->fs.
[vsu@altlinux.ru: fix error path]
Cc: Al Viro <viro@ftp.linux.org.uk>
Signed-off-by: Sergey Vlasov <vsu@altlinux.ru>
It seems there is error check missing in open_namei for errors returned
through intent.open.file (from lookup_instantiate_filp).
If there is plain open performed, then such a check done inside
__path_lookup_intent_open called from path_lookup_open(), but when the open
is performed with O_CREAT flag set, then __path_lookup_intent_open is only
called with LOOKUP_PARENT set where no file opening can occur yet.
Later on lookup_hash is called where exact opening might take place and
intent.open.file may be filled. If it is filled with error value of some
sort, then we get kernel attempting to dereference this error value as
address (and corresponding oops) in nameidata_to_filp() called from
filp_open().
While this is relatively simple to workaround in ->lookup() method by just
checking lookup_instantiate_filp() return value and returning error as
needed, this is not so easy in ->d_revalidate(), where we can only return
"yes, dentry is valid" or "no, dentry is invalid, perform full lookup
again", and just returning 0 on error would cause extra lookup (with
potential extra costly RPCs).
So in short, I believe that there should be no difference in error handling
for opening a file and creating a file in open_namei() and propose this
simple patch as a solution.
Mentioned by Mark Armbrust somewhere on Usenet.
Cc: Ulrich Drepper <drepper@redhat.com>
Yesterday, I got the following error with 2.6.16.13 during a file copy from
a smb filesystem over a wireless link. I guess there was some error on the
wireless link, which in turn caused an error condition for the smb
filesystem.
In the log, smb_file_read reports error=4294966784 (0xfffffe00), which also
shows up in the slab dumps, and also is -ERESTARTSYS. Error code 27499
corresponds to 0x6b6b, so the rq_errno field seems to be the only one being
set after freeing the slab.
In smb_add_request (which is the only place in smbfs where I found
ERESTARTSYS), I found the following:
if (!timeleft || signal_pending(current)) {
* On timeout or on interrupt we want to try and remove the
* request from the recvq/xmitq.
smb_lock_server(server);
if (!(req->rq_flags & SMB_REQ_RECEIVED)) {
list_del_init(&req->rq_queue);
smb_rput(req);
smb_unlock_server(server);
if (signal_pending(current))
req->rq_errno = -ERESTARTSYS;
I guess that some codepath like smbiod_flush() caused the request to be
removed from the queue, and smb_rput(req) be called, without
SMB_REQ_RECEIVED being set. This violates an asumption made by the quoted
code.
Then, the above code calls smb_rput(req) again, the req gets freed, and
req->rq_errno = -ERESTARTSYS writes into the already freed slab. As
list_del_init doesn't cause an error if called multiple times, that does
cause the observed behaviour (freed slab with rq_errno=-ERESTARTSYS).
If this observation is correct, the following patch should fix it.
I wonder why the smb code uses list_del_init everywhere - using list_del
instead would catch such situations by poisoning the next and prev
pointers.
May 4 23:29:21 knautsch kernel: [17180085.456000] ipw2200: Firmware error detected. Restarting.
May 4 23:29:21 knautsch kernel: [17180085.456000] ipw2200: Sysfs 'error' log captured.
May 4 23:33:02 knautsch kernel: [17180306.316000] ipw2200: Firmware error detected. Restarting.
May 4 23:33:02 knautsch kernel: [17180306.316000] ipw2200: Sysfs 'error' log already exists.
May 4 23:33:02 knautsch kernel: [17180306.968000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:34:18 knautsch kernel: [17180383.256000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:34:18 knautsch kernel: [17180383.284000] SMB connection re-established (-5)
May 4 23:37:19 knautsch kernel: [17180563.956000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:40:09 knautsch kernel: [17180733.636000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:40:26 knautsch kernel: [17180750.700000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:43:02 knautsch kernel: [17180907.304000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:43:08 knautsch kernel: [17180912.324000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:43:34 knautsch kernel: [17180938.416000] smb_errno: class Unknown, code 27499 from command 0x6b
May 4 23:43:34 knautsch kernel: [17180938.416000] Slab corruption: start=c4ebe09c, len=244
May 4 23:43:34 knautsch kernel: [17180938.416000] Redzone: 0x5a2cf071/0x5a2cf071.
May 4 23:43:34 knautsch kernel: [17180938.416000] Last user: [<e087b903>](smb_rput+0x53/0x90 [smbfs])
May 4 23:43:34 knautsch kernel: [17180938.416000] 000: 6b 6b 6b 6b 6b 6b 6b 6b 6a 6b 6b 6b 6b 6b 6b 6b
May 4 23:43:34 knautsch kernel: [17180938.416000] 0f0: 00 fe ff ff
May 4 23:43:34 knautsch kernel: [17180938.416000] Next obj: start=c4ebe19c, len=244
May 4 23:43:34 knautsch kernel: [17180938.416000] Last user: [<00000000>](_stext+0x3feffde0/0x30)
May 4 23:43:34 knautsch kernel: [17180938.416000] 000: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b
May 4 23:43:34 knautsch kernel: [17180938.416000] 010: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b
May 4 23:43:34 knautsch kernel: [17180938.460000] SMB connection re-established (-5)
May 4 23:43:42 knautsch kernel: [17180946.292000] ipw2200: Firmware error detected. Restarting.
May 4 23:43:42 knautsch kernel: [17180946.292000] ipw2200: Sysfs 'error' log already exists.
May 4 23:45:04 knautsch kernel: [17181028.752000] ipw2200: Firmware error detected. Restarting.
May 4 23:45:04 knautsch kernel: [17181028.752000] ipw2200: Sysfs 'error' log already exists.
May 4 23:45:05 knautsch kernel: [17181029.868000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:45:36 knautsch kernel: [17181060.984000] smb_errno: class Unknown, code 27499 from command 0x6b
May 4 23:45:36 knautsch kernel: [17181060.984000] Slab corruption: start=c4ebe09c, len=244
May 4 23:45:36 knautsch kernel: [17181060.984000] Redzone: 0x5a2cf071/0x5a2cf071.
May 4 23:45:36 knautsch kernel: [17181060.984000] Last user: [<e087b903>](smb_rput+0x53/0x90 [smbfs])
May 4 23:45:36 knautsch kernel: [17181060.984000] 000: 6b 6b 6b 6b 6b 6b 6b 6b 6a 6b 6b 6b 6b 6b 6b 6b
May 4 23:45:36 knautsch kernel: [17181060.984000] 0f0: 00 fe ff ff
May 4 23:45:36 knautsch kernel: [17181060.984000] Next obj: start=c4ebe19c, len=244
May 4 23:45:36 knautsch kernel: [17181060.984000] Last user: [<00000000>](_stext+0x3feffde0/0x30)
May 4 23:45:36 knautsch kernel: [17181060.984000] 000: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b
May 4 23:45:36 knautsch kernel: [17181060.984000] 010: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b
May 4 23:45:36 knautsch kernel: [17181061.024000] SMB connection re-established (-5)
May 4 23:46:17 knautsch kernel: [17181102.132000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:47:46 knautsch kernel: [17181190.468000] smb_errno: class Unknown, code 27499 from command 0x6b
May 4 23:47:46 knautsch kernel: [17181190.468000] Slab corruption: start=c4ebe09c, len=244
May 4 23:47:46 knautsch kernel: [17181190.468000] Redzone: 0x5a2cf071/0x5a2cf071.
May 4 23:47:46 knautsch kernel: [17181190.468000] Last user: [<e087b903>](smb_rput+0x53/0x90 [smbfs])
May 4 23:47:46 knautsch kernel: [17181190.468000] 000: 6b 6b 6b 6b 6b 6b 6b 6b 6a 6b 6b 6b 6b 6b 6b 6b
May 4 23:47:46 knautsch kernel: [17181190.468000] 0f0: 00 fe ff ff
May 4 23:47:46 knautsch kernel: [17181190.468000] Next obj: start=c4ebe19c, len=244
May 4 23:47:46 knautsch kernel: [17181190.468000] Last user: [<00000000>](_stext+0x3feffde0/0x30)
May 4 23:47:46 knautsch kernel: [17181190.468000] 000: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b
May 4 23:47:46 knautsch kernel: [17181190.468000] 010: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b
May 4 23:47:46 knautsch kernel: [17181190.492000] SMB connection re-established (-5)
May 4 23:49:20 knautsch kernel: [17181284.828000] smb_file_read: //some_file validation failed, error=4294966784
May 4 23:49:39 knautsch kernel: [17181303.896000] smb_file_read: //some_file validation failed, error=4294966784
Signed-off-by: Jan Niehusmann <jan@gondor.com>
sys_flock() currently has a race which can result in a double free in the
multi-thread case.
Thread 1 Thread 2
sys_flock(file, LOCK_EX)
sys_flock(file, LOCK_UN)
If Thread 2 removes the lock from inode->i_lock before Thread 1 tests for
list_empty(&lock->fl_link) at the end of sys_flock, then both threads will
end up calling locks_free_lock for the same lock.
Fix is to make flock_lock_file() do the same as posix_lock_file(), namely
to make a copy of the request, so that the caller can always free the lock.
This also has the side-effect of fixing up a reference problem in the
lockd handling of flock.
It is insane to be giving lease_init() the task of freeing the lock it is
supposed to initialise, given that the lock is not guaranteed to be
allocated on the stack. This causes lockups in fcntl_setlease().
Problem diagnosed by Daniel Hokka Zakrisson <daniel@hozac.com>
Also fix a slab leak in __setlease() due to an uninitialised return value.
Problem diagnosed by Björn Steinbrink.
Tested-by: Daniel Hokka Zakrisson <daniel@hozac.com>
Cc: Björn Steinbrink <B.Steinbrink@gmx.de>
Mark Moseley reported that a chroot environment on a SMB share can be
left via "cd ..\\". Similar to CVE-2006-1863 issue with cifs, this fix
is for smbfs.
Steven French <sfrench@us.ibm.com> wrote:
Looks fine to me. This should catch the slash on lookup or equivalent,
which will be all obvious paths of interest.
