commit 73aaa22d5ffb2630456bac2f9a4ed9b81d0d7271 upstream.
This patch fixes races uncovered by xfstests testcase 068.
One race is the result of jfs_sync() trying to write a sync point to the
journal after it has been frozen (or possibly in the process). Since
freezing sync's the journal, there is no need to write a sync point so
we simply want to return.
The second involves jfs_write_inode() being called on a deleted inode.
It calls jfs_flush_journal which is held up by the jfs_commit thread
doing the final iput on the same deleted inode, which itself is
waiting for the I_SYNC flag to be cleared. jfs_write_inode need not
do anything when i_nlink is zero, which is the easy fix.
Reported-by: Michael L. Semon <mlsemon35@gmail.com>
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
commit 166faf21bd14bc5c5295a44874bf7f3930c30b20 upstream.
Consider the case where we have a very short ip= string in the original
mount options, and when we chase a referral we end up with a very long
IPv6 address. Be sure to allow for that possibility when estimating the
size of the string to allocate.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit 2962f5a5dcc56f69cbf62121a7be67cc15d6940b upstream.
XFS has failed to kill suid/sgid bits correctly when truncating
files of non-zero size since commit c4ed4243 ("xfs: split
xfs_setattr") introduced in the 3.1 kernel. Fix it.
Fix it.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit f448badd34700ae728a32ba024249626d49c10e1 upstream.
We need to pass the full open mode flags to nfs_may_open() when doing
a delegated open.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 136e8770cd5d1fe38b3c613100dd6dc4db6d4fa6 upstream.
nilfs2: fix issue of nilfs_set_page_dirty for page at EOF boundary
DESCRIPTION:
There are use-cases when NILFS2 file system (formatted with block size
lesser than 4 KB) can be remounted in RO mode because of encountering of
"broken bmap" issue.
The issue was reported by Anthony Doggett <Anthony2486@interfaces.org.uk>:
"The machine I've been trialling nilfs on is running Debian Testing,
Linux version 3.2.0-4-686-pae (debian-kernel@lists.debian.org) (gcc
version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Debian 3.2.35-2), but I've
also reproduced it (identically) with Debian Unstable amd64 and Debian
Experimental (using the 3.8-trunk kernel). The problematic partitions
were formatted with "mkfs.nilfs2 -b 1024 -B 8192"."
SYMPTOMS:
(1) System log contains error messages likewise:
[63102.496756] nilfs_direct_assign: invalid pointer: 0
[63102.496786] NILFS error (device dm-17): nilfs_bmap_assign: broken bmap (inode number=28)
[63102.496798]
[63102.524403] Remounting filesystem read-only
(2) The NILFS2 file system is remounted in RO mode.
REPRODUSING PATH:
(1) Create volume group with name "unencrypted" by means of vgcreate utility.
(2) Run script (prepared by Anthony Doggett <Anthony2486@interfaces.org.uk>):
----------------[BEGIN SCRIPT]--------------------
VG=unencrypted
lvcreate --size 2G --name ntest $VG
mkfs.nilfs2 -b 1024 -B 8192 /dev/mapper/$VG-ntest
mkdir /var/tmp/n
mkdir /var/tmp/n/ntest
mount /dev/mapper/$VG-ntest /var/tmp/n/ntest
mkdir /var/tmp/n/ntest/thedir
cd /var/tmp/n/ntest/thedir
sleep 2
date
darcs init
sleep 2
dmesg|tail -n 5
date
darcs whatsnew || true
date
sleep 2
dmesg|tail -n 5
----------------[END SCRIPT]--------------------
REPRODUCIBILITY: 100%
INVESTIGATION:
As it was discovered, the issue takes place during segment
construction after executing such sequence of user-space operations:
open("_darcs/index", O_RDWR|O_CREAT|O_NOCTTY, 0666) = 7
fstat(7, {st_mode=S_IFREG|0644, st_size=0, ...}) = 0
ftruncate(7, 60)
The error message "NILFS error (device dm-17): nilfs_bmap_assign: broken
bmap (inode number=28)" takes place because of trying to get block
number for third block of the file with logical offset #3072 bytes. As
it is possible to see from above output, the file has 60 bytes of the
whole size. So, it is enough one block (1 KB in size) allocation for
the whole file. Trying to operate with several blocks instead of one
takes place because of discovering several dirty buffers for this file
in nilfs_segctor_scan_file() method.
The root cause of this issue is in nilfs_set_page_dirty function which
is called just before writing to an mmapped page.
When nilfs_page_mkwrite function handles a page at EOF boundary, it
fills hole blocks only inside EOF through __block_page_mkwrite().
The __block_page_mkwrite() function calls set_page_dirty() after filling
hole blocks, thus nilfs_set_page_dirty function (=
a_ops->set_page_dirty) is called. However, the current implementation
of nilfs_set_page_dirty() wrongly marks all buffers dirty even for page
at EOF boundary.
As a result, buffers outside EOF are inconsistently marked dirty and
queued for write even though they are not mapped with nilfs_get_block
function.
FIX:
This modifies nilfs_set_page_dirty() not to mark hole blocks dirty.
Thanks to Vyacheslav Dubeyko for his effort on analysis and proposals
for this issue.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Reported-by: Anthony Doggett <Anthony2486@interfaces.org.uk>
Reported-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Vyacheslav Dubeyko <slava@dubeyko.com>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit b4ca2b4b577c3530e34dcfaafccb2cc680ce95d1 upstream.
Last time we found there is lock/unlock bug in ocfs2_file_aio_write, and
then we did a thorough search for all lock resources in
ocfs2_inode_info, including rw, inode and open lockres and found this
bug. My kernel version is 3.0.13, and it is also in the lastest version
3.9. In ocfs2_fiemap, once ocfs2_get_clusters_nocache failed, it should
goto out_unlock instead of out, because we need release buffer head, up
read alloc sem and unlock inode.
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Reviewed-by: Jie Liu <jeff.liu@oracle.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Acked-by: Sunil Mushran <sunil.mushran@gmail.com>
commit 7b92d03c3239f43e5b86c9cc9630f026d36ee995 upstream.
Intermediate value of fat_clusters can be overflowed on 32bits arch.
Reported-by: Krzysztof Strasburger <strasbur@chkw386.ch.pwr.wroc.pl>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
commit c2b93e0699723700f886ce17bb65ffd771195a6d upstream.
It's generally not safe to reset the inode ops once they've been set. In
the case where the inode was originally thought to be a directory and
then later found to be a DFS referral, this can lead to an oops when we
try to trigger an inode op on it after changing the ops to the blank
referral operations.
Reported-and-Tested-by: Sachin Prabhu <sprabhu@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 03b71c6ca6286625d8f1ed44aabab9b5bf5dac10 upstream.
The search ioctl skips items that are too large for a result buffer, but
inline items of a certain size occuring before any search result is
found would trigger an overflow and stop the search entirely.
Bug: https://bugzilla.kernel.org/show_bug.cgi?id=57641
Signed-off-by: Gabriel de Perthuis <g2p.code+btrfs@gmail.com>
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
commit af73e4d9506d3b797509f3c030e7dcd554f7d9c4 upstream.
The current kernel returns -EINVAL unless a given mmap length is
"almost" hugepage aligned. This is because in sys_mmap_pgoff() the
given length is passed to vm_mmap_pgoff() as it is without being aligned
with hugepage boundary.
This is a regression introduced in commit 40716e29243d ("hugetlbfs: fix
alignment of huge page requests"), where alignment code is pushed into
hugetlb_file_setup() and the variable len in caller side is not changed.
To fix this, this patch partially reverts that commit, and adds
alignment code in caller side. And it also introduces hstate_sizelog()
in order to get proper hstate to specified hugepage size.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=56881
[akpm@linux-foundation.org: fix warning when CONFIG_HUGETLB_PAGE=n]
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reported-by: <iceman_dvd@yahoo.com>
Cc: Steven Truelove <steven.truelove@utoronto.ca>
Cc: Jianguo Wu <wujianguo@huawei.com>
Cc: <stable@vger.kernel.org>
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
commit e6155736ad76b2070652745f9e54cdea3f0d8567 upstream.
In the case where we are allocating for a non-extent file,
we must limit the groups we allocate from to those below
2^32 blocks, and ext4_mb_regular_allocator() attempts to
do this initially by putting a cap on ngroups for the
subsequent search loop.
However, the initial target group comes in from the
allocation context (ac), and it may already be beyond
the artificially limited ngroups. In this case,
the limit
if (group == ngroups)
group = 0;
at the top of the loop is never true, and the loop will
run away.
Catch this case inside the loop and reset the search to
start at group 0.
[sandeen@redhat.com: add commit msg & comments]
Signed-off-by: Lachlan McIlroy <lmcilroy@redhat.com>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 9f415eb25574db4b73a9a712a4438e41dc284922 upstream.
The Linux client is using CLAIM_FH to implement regular opens, not just
recovery cases, so it depends on the server to check permissions
correctly.
Therefore the owner override, which may make sense in the delegation
recovery case, isn't right in the CLAIM_FH case.
Symptoms: on a client with 49f9a0fafd844c32f2abada047c0b9a5ba0d6255
"NFSv4.1: Enable open-by-filehandle", Bryan noticed this:
touch test.txt
chmod 000 test.txt
echo test > test.txt
succeeding.
Reported-by: Bryan Schumaker <bjschuma@netapp.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 3f8a6411fbada1fa482276591e037f3b1adcf55b upstream.
Addresses-Red-Hat-Bugzilla: #913245
Reported-by: Eric Sandeen <sandeen@redhat.com>
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
Signed-off-by: Lingzhu Xiang <lxiang@redhat.com>
commit ce8a5dbdf9e709bdaf4618d7ef8cceb91e8adc69 upstream.
When checking if an autofs mount point is busy it isn't sufficient to
only check if it's a mount point.
For example, if the mount of an offset mountpoint in a tree is denied
for this host by its export and the dentry becomes a process working
directory the check incorrectly returns the mount as not in use at
expire.
This can happen since the default when mounting within a tree is
nostrict, which means ingnore mount fails on mounts within the tree and
continue. The nostrict option is meant to allow mounting in this case.
Signed-off-by: David Jeffery <djeffery@redhat.com>
Signed-off-by: Ian Kent <raven@themaw.net>
commit 7f3e3c7cfcec148ccca9c0dd2dbfd7b00b7ac10f upstream.
Fox the Kconfig documentation for CONFIG_EXT4_DEBUG to match the
change made by commit a0b30c1229: ext4: use module parameters instead
of debugfs for mballoc_debug
commit c5c72d814cf0f650010337c73638b25e6d14d2d4 upstream.
Commit fb0a387dcdc restricts block allocations for indirect-mapped
files to block groups less than s_blockfile_groups. However, the
online resizing code wasn't setting s_blockfile_groups, so the newly
added block groups were not available for non-extent mapped files.
commit 5d3ee20855e28169d711b394857ee608a5023094 upstream.
It is incorrect to use list_for_each_entry_safe() for journal callback
traversial because ->next may be removed by other task:
->ext4_mb_free_metadata()
->ext4_journal_callback_del()
This results in the following issue:
WARNING: at lib/list_debug.c:62 __list_del_entry+0x1c0/0x250()
Hardware name:
list_del corruption. prev->next should be ffff88019a4ec198, but was 6b6b6b6b6b6b6b6b
Modules linked in: cpufreq_ondemand acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel ghash_clmulni_intel microcode sg xhci_hcd button sd_mod crc_t10dif aesni_intel ablk_helper cryptd lrw aes_x86_64 xts gf128mul ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_mod
Pid: 16400, comm: jbd2/dm-1-8 Tainted: G W 3.8.0-rc3+ #107
Call Trace:
[<ffffffff8106fb0d>] warn_slowpath_common+0xad/0xf0
[<ffffffff8106fc06>] warn_slowpath_fmt+0x46/0x50
[<ffffffff813637e9>] ? ext4_journal_commit_callback+0x99/0xc0
[<ffffffff8148cae0>] __list_del_entry+0x1c0/0x250
[<ffffffff813637bf>] ext4_journal_commit_callback+0x6f/0xc0
[<ffffffff813ca336>] jbd2_journal_commit_transaction+0x23a6/0x2570
[<ffffffff8108aa42>] ? try_to_del_timer_sync+0x82/0xa0
[<ffffffff8108b491>] ? del_timer_sync+0x91/0x1e0
[<ffffffff813d3ecf>] kjournald2+0x19f/0x6a0
[<ffffffff810ad630>] ? wake_up_bit+0x40/0x40
[<ffffffff813d3d30>] ? bit_spin_lock+0x80/0x80
[<ffffffff810ac6be>] kthread+0x10e/0x120
[<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70
[<ffffffff818ff6ac>] ret_from_fork+0x7c/0xb0
This patch fix the issue as follows:
- ext4_journal_commit_callback() make list truly traversial safe
simply by always starting from list_head
- fix race between two ext4_journal_callback_del() and
ext4_journal_callback_try_del()
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
commit 794446c6946513c684d448205fbd76fa35f38b72 upstream.
The following race is possible:
[kjournald2] other_task
jbd2_journal_commit_transaction()
j_state = T_FINISHED;
spin_unlock(&journal->j_list_lock);
->jbd2_journal_remove_checkpoint()
->jbd2_journal_free_transaction();
->kmem_cache_free(transaction)
->j_commit_callback(journal, transaction);
-> USE_AFTER_FREE
Hardware name:
Call Trace:
In order to demonstrace this issue one should mount ext4 with mount -o
discard option on SSD disk. This makes callback longer and race
window becomes wider.
In order to fix this we should mark transaction as finished only after
callbacks have completed
commit bf8d909705e9d9bac31d9b8eac6734d2b51332a7 upstream.
The seconds field of an nfstime4 structure is 64bit, but we are assuming
that the first 32bits are zero-filled. So if the client tries to set
atime to a value before the epoch (touch -t 196001010101), then the
server will save the wrong value on disk.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
commit 0c7c3e67ab91ec6caa44bdf1fc89a48012ceb0c5 upstream.
Don't actually close any opens until we don't need them at all.
This means being left with write access when it's not really necessary,
but that's better than putting a file that might still have posix locks
held on it, as we have been.
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
commit 8b6cc4d6f841d31f72fe7478453759166d366274 upstream.
A server shouldn't normally return NFS4ERR_GRACE if the client holds a
delegation, since no conflicting lock reclaims can be granted, however
the spec does not require the server to grant the open in this
instance
commit 1dfd89af8697a299e7982ae740d4695ecd917eef upstream.
After a server reboot, the reclaimer thread will recover all the existing
locks. For locks that are blocked, however, it will change the value
of block->b_status to nlm_lck_denied_grace_period in order to signal that
they need to wake up and resend the original blocking lock request.
Due to a bug, however, the block->b_status never gets reset after the
blocked locks have been woken up, and so the process goes into an
infinite loop of resends until the blocked lock is satisfied.
Reported-by: Marc Eshel <eshel@us.ibm.com>
commit 421348f1ca0bf17769dee0aed4d991845ae0536d upstream.
Call cond_resched() in shrink_dcache_parent() to maintain interactivity.
Before this patch:
void shrink_dcache_parent(struct dentry * parent)
while ((found = select_parent(parent, &dispose)) != 0)
shrink_dentry_list(&dispose);
select_parent() populates the dispose list with dentries which
shrink_dentry_list() then deletes. select_parent() carefully uses
need_resched() to avoid doing too much work at once. But neither
shrink_dcache_parent() nor its called functions call cond_resched(). So
once need_resched() is set select_parent() will return single dentry
dispose list which is then deleted by shrink_dentry_list(). This is
inefficient when there are a lot of dentry to process. This can cause
softlockup and hurts interactivity on non preemptable kernels.
This change adds cond_resched() in shrink_dcache_parent(). The benefit
of this is that need_resched() is quickly cleared so that future calls
to select_parent() are able to efficiently return a big batch of dentry.
These additional cond_resched() do not seem to impact performance, at
least for the workload below.
Here is a program which can cause soft lockup if other system activity
sets need_resched().
int main()
struct rlimit rlim;
int i;
int f[100000];
char buf[20];
struct timeval t1, t2;
double diff;
/* cleanup past run */
system("rm -rf x");
/* boost nfile rlimit */
rlim.rlim_cur = 200000;
rlim.rlim_max = 200000;
if (setrlimit(RLIMIT_NOFILE, &rlim))
err(1, "setrlimit");
/* make directory for files */
if (mkdir("x", 0700))
err(1, "mkdir");
if (gettimeofday(&t1, NULL))
err(1, "gettimeofday");
/* populate directory with open files */
for (i = 0; i < 100000; i++) {
snprintf(buf, sizeof(buf), "x/%d", i);
f[i] = open(buf, O_CREAT);
if (f[i] == -1)
err(1, "open");
/* close some of the files */
for (i = 0; i < 85000; i++)
close(f[i]);
/* unlink all files, even open ones */
system("rm -rf x");
if (gettimeofday(&t2, NULL))
diff = (((double)t2.tv_sec * 1000000 + t2.tv_usec) -
((double)t1.tv_sec * 1000000 + t1.tv_usec));
printf("done: %g elapsed\n", diff/1e6);
return 0;
Signed-off-by: Greg Thelen <gthelen@google.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
commit 6ee8630e02be6dd89926ca0fbc21af68b23dc087 upstream.
On architectures where a pgd entry may be shared between user and kernel
(e.g. ARM+LPAE), freeing page tables needs a ceiling other than 0.
This patch introduces a generic USER_PGTABLES_CEILING that arch code can
override. It is the responsibility of the arch code setting the ceiling
to ensure the complete freeing of the page tables (usually in
pgd_free()).
[catalin.marinas@arm.com: commit log; shift_arg_pages(), asm-generic/pgtables.h changes]
commit ec686c9239b4d472052a271c505d04dae84214cc upstream.
There is a kernel memory leak observed when the proc file
/proc/fs/fscache/stats is read.
The reason is that in fscache_stats_open, single_open is called and the
respective release function is not called during release. Hence fix
with correct release function - single_release().
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=57101
Signed-off-by: Anurup m <anurup.m@huawei.com>
Cc: shyju pv <shyju.pv@huawei.com>
Cc: Sanil kumar <sanil.kumar@huawei.com>
Cc: Nataraj m <nataraj.m@huawei.com>
Cc: Li Zefan <lizefan@huawei.com>
commit f7db5e7660b122142410dcf36ba903c73d473250 upstream.
The inode->i_mutex isn't hold when updating filp->f_pos
in read()/write(), so the filp->f_pos might be read as
0 or 1 in readdir() when there is concurrent read()/write()
on this same file, then may cause use after free in readdir().
The bug can be reproduced with Li Zefan's test code on the
link:
https://patchwork.kernel.org/patch/2160771/
This patch fixes the use after free under this situation.
Reported-by: Li Zefan <lizefan@huawei.com>
Signed-off-by: Ming Lei <ming.lei@canonical.com>
commit 91d80a84bbc8f28375cca7e65ec666577b4209ad upstream.
dprintk() shouldn't access @ring after it's unmapped.
Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com>
commit 4bc4bee4595662d8bff92180d5c32e3313a704b0 upstream.
While trying to track down a tree log replay bug I noticed that fsck was always
complaining about nbytes not being right for our fsynced file. That is because
the new fsync stuff doesn't wait for ordered extents to complete, so the inodes
nbytes are not necessarily updated properly when we log it. So to fix this we
need to set nbytes to whatever it is on the inode that is on disk, so when we
replay the extents we can just add the bytes that are being added as we replay
the extent. This makes it work for the case that we have the wrong nbytes or
the case that we logged everything and nbytes is actually correct. With this
I'm no longer getting nbytes errors out of btrfsck.
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
Reviewed-by: CAI Qian <caiqian@redhat.com>
commit 12f267a20aecf8b84a2a9069b9011f1661c779b4 upstream.
Change a u32 to loff_t hfsplus_file_truncate().
Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Hin-Tak Leung <htl10@users.sourceforge.net>
commit 5b55d708335a9e3e4f61f2dadf7511502205ccd1 upstream.
Revert commit 62a3ddef6181 ("vfs: fix spinning prevention in prune_icache_sb").
This commit doesn't look right: since we are looking at the tail of the
list (sb->s_inode_lru.prev) if we want to skip an inode, we should put
it back at the head of the list instead of the tail, otherwise we will
keep spinning on it.
Discovered when investigating why prune_icache_sb came top in perf
reports of a swapping load.
Signed-off-by: Suleiman Souhlal <suleiman@google.com>
commit c369c9a4a7c82d33329d869cbaf93304cc7a0c40 upstream.
Fixes a regression in cifs_parse_mount_options where a password
which begins with a delimitor is parsed incorrectly as being a blank
password.
Signed-off-by: Sachin Prabhu <sprabhu@redhat.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
commit 35e5cbc0af240778e61113286c019837e06aeec6 upstream.
After commit 21d8a15a (lookup_one_len: don't accept . and ..) reiserfs
started failing to delete xattrs from inode. This was due to a buggy
test for '.' and '..' in fill_with_dentries() which resulted in passing
'.' and '..' entries to lookup_one_len() in some cases. That returned
error and so we failed to iterate over all xattrs of and inode.
Fix the test in fill_with_dentries() along the lines of the one in
lookup_one_len().
Reported-by: Pawel Zawora <pzawora@gmail.com>
commit 67e753ca41782913d805ff4a8a2b0f60b26b7915 upstream.
The UBIFS space fixup is a useful feature which allows to fixup the "broken"
flash space at the time of the first mount. The "broken" space is usually the
result of using a "dumb" industrial flasher which is not able to skip empty
NAND pages and just writes all 0xFFs to the empty space, which has grave
side-effects for UBIFS when UBIFS trise to write useful data to those empty
pages.
The fix-up feature works roughly like this:
1. mkfs.ubifs sets the fixup flag in UBIFS superblock when creating the image
(see -F option)
2. when the file-system is mounted for the first time, UBIFS notices the fixup
flag and re-writes the entire media atomically, which may take really a lot
of time.
3. UBIFS clears the fixup flag in the superblock.
This works fine when the file system is mounted R/W for the very first time.
But it did not really work in the case when we first mount the file-system R/O,
and then re-mount R/W. The reason was that we started the fixup procedure too
late, which we cannot really do because we have to fixup the space before it
starts being used.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Reported-by: Mark Jackson <mpfj-list@mimc.co.uk>
commit 90ba983f6889e65a3b506b30dc606aa9d1d46cd2 upstream.
A user who was using a 8TB+ file system and with a very large flexbg
size (> 65536) could cause the atomic_t used in the struct flex_groups
to overflow. This was detected by PaX security patchset:
http://forums.grsecurity.net/viewtopic.php?f=3&t=3289&p=12551#p12551
This bug was introduced in commit 9f24e4208f7e, so it's been around
since 2.6.30. :-(
Fix this by using an atomic64_t for struct orlav_stats's
free_clusters.
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
commit 810da240f221d64bf90020f25941b05b378186fe upstream.
We're using macro EXT4_B2C() to convert number of blocks to number of
clusters for bigalloc file systems. However, we should be using
EXT4_NUM_B2C().
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: CAI Qian <caiqian@redhat.com>
commit f4881bc7a83eff263789dd524b7c269d138d4af5 upstream.
Dave reported a warning when running xfstest 275. We have been leaking delalloc
metadata space when our reservations fail. This is because we were improperly
calculating how much space to free for our checksum reservations. The problem
is we would sometimes free up space that had already been freed in another
thread and we would end up with negative usage for the delalloc space. This
patch fixes the problem by calculating how much space the other threads would
have already freed, and then calculate how much space we need to free had we not
done the reservation at all, and then freeing any excess space. This makes
xfstests 275 no longer have leaked space. Thanks
Reported-by: David Sterba <dsterba@suse.cz>
commit 64a817cfbded8674f345d1117b117f942a351a69 upstream.
Since we only enforce an upper bound, not a lower bound, a "negative"
length can get through here.
The symptom seen was a warning when we attempt to a kmalloc with an
excessive size.
commit c1681bf8a7b1b98edee8b862a42c19c4e53205fd upstream.
struct block_device lifecycle is defined by its inode (see fs/block_dev.c) -
block_device allocated first time we access /dev/loopXX and deallocated on
bdev_destroy_inode. When we create the device "losetup /dev/loopXX afile"
we want that block_device stay alive until we destroy the loop device
with "losetup -d".
But because we do not hold /dev/loopXX inode its counter goes 0, and
inode/bdev can be destroyed at any moment. Usually it happens at memory
pressure or when user drops inode cache (like in the test below). When later in
loop_clr_fd() we want to use bdev we have use-after-free error with following
stack:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000280
bd_set_size+0x10/0xa0
loop_clr_fd+0x1f8/0x420 [loop]
lo_ioctl+0x200/0x7e0 [loop]
lo_compat_ioctl+0x47/0xe0 [loop]
compat_blkdev_ioctl+0x341/0x1290
do_filp_open+0x42/0xa0
compat_sys_ioctl+0xc1/0xf20
do_sys_open+0x16e/0x1d0
sysenter_dispatch+0x7/0x1a
To prevent use-after-free we need to grab the device in loop_set_fd()
and put it later in loop_clr_fd().
The issue is reprodusible on current Linus head and v3.3. Here is the test:
dd if=/dev/zero of=loop.file bs=1M count=1
while [ true ]; do
losetup /dev/loop0 loop.file
echo 2 > /proc/sys/vm/drop_caches
losetup -d /dev/loop0
done
[ Doing bdgrab/bput in loop_set_fd/loop_clr_fd is safe, because every
time we call loop_set_fd() we check that loop_device->lo_state is
Lo_unbound and set it to Lo_bound If somebody will try to set_fd again
it will get EBUSY. And if we try to loop_clr_fd() on unbound loop
device we'll get ENXIO.
loop_set_fd/loop_clr_fd (and any other loop ioctl) is called under
loop_device->lo_ctl_mutex. ]
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
commit d8fe29e9dea8d7d61fd140d8779326856478fc62 upstream.
A user reported a panic where we were panicing somewhere in
tree_backref_for_extent from scrub_print_warning. He only captured the trace
but looking at scrub_print_warning we drop the path right before we mess with
the extent buffer to print out a bunch of stuff, which isn't right. So fix this
by dropping the path after we use the eb if we need to. Thanks,
commit fdf30d1c1b386e1b73116cc7e0fb14e962b763b0 upstream.
A user reported a problem where he was getting early ENOSPC with hundreds of
gigs of free data space and 6 gigs of free metadata space. This is because the
global block reserve was taking up the entire free metadata space. This is
ridiculous, we have infrastructure in place to throttle if we start using too
much of the global reserve, so instead of letting it get this huge just limit it
to 512mb so that users can still get work done. This allowed the user to
complete his rsync without issues. Thanks
Reported-and-tested-by: Stefan Priebe <s.priebe@profihost.ag>
commit 4adaa611020fa6ac65b0ac8db78276af4ec04e63 upstream.
Btrfs uses page_mkwrite to ensure stable pages during
crc calculations and mmap workloads. We call clear_page_dirty_for_io
before we do any crcs, and this forces any application with the file
mapped to wait for the crc to finish before it is allowed to change
the file.
With compression on, the clear_page_dirty_for_io step is happening after
we've compressed the pages. This means the applications might be
changing the pages while we are compressing them, and some of those
modifications might not hit the disk.
This commit adds the clear_page_dirty_for_io before compression starts
and makes sure to redirty the page if we have to fallback to
uncompressed IO as well.
Reported-by: Alexandre Oliva <oliva@gnu.org>
commit 4376c94618c26225e69e17b7c91169c45a90b292 upstream.
when pnfs block using device mapper,if umounting later,it maybe
cause oops. we apply "1 + sizeof(bl_umount_request)" memory for
msg->data, the memory maybe overflow when we do "memcpy(&dataptr
[sizeof(bl_msg)], &bl_umount_request, sizeof(bl_umount_request))",
because the size of bl_msg is more than 1 byte.
Signed-off-by: fanchaoting<fanchaoting@cn.fujitsu.com>
commit e5110f411d2ee35bf8d202ccca2e89c633060dca upstream.
In case of 'if (filp->f_pos == 0 or 1)' of sysfs_readdir(),
the failure from filldir() isn't handled, and the reference counter
of the sysfs_dirent object pointed by filp->private_data will be
released without clearing filp->private_data, so use after free
bug will be triggered later.
This patch returns immeadiately under the situation for fixing the bug,
and it is reasonable to return from readdir() when filldir() fails.
Reported-by: Dave Jones <davej@redhat.com>
Tested-by: Sasha Levin <levinsasha928@gmail.com>
commit 991f76f837bf22c5bb07261cfd86525a0a96650c upstream.
While readdir() is running, lseek() may set filp->f_pos as zero,
then may leave filp->private_data pointing to one sysfs_dirent
object without holding its reference counter, so the sysfs_dirent
object may be used after free in next readdir().
This patch holds inode->i_mutex to avoid the problem since
the lock is always held in readdir path.
commit d740269867021faf4ce38a449353d2b986c34a67 upstream.
To avoid an explosion of request_module calls on a chain of abusive
scripts, fail maximum recursion with -ELOOP instead of -ENOEXEC. As soon
as maximum recursion depth is hit, the error will fail all the way back
up the chain, aborting immediately.
This also has the side-effect of stopping the user's shell from attempting
to reexecute the top-level file as a shell script. As seen in the
dash source:
if (cmd != path_bshell && errno == ENOEXEC) {
*argv-- = cmd;
*argv = cmd = path_bshell;
goto repeat;
The above logic was designed for running scripts automatically that lacked
the "#!" header, not to re-try failed recursion. On a legitimate -ENOEXEC,
things continue to behave as the shell expects.
Additionally, when tracking recursion, the binfmt handlers should not be
involved. The recursion being tracked is the depth of calls through
search_binary_handler(), so that function should be exclusively responsible
for tracking the depth.
Cc: halfdog <me@halfdog.net>
Cc: P J P <ppandit@redhat.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 0143fc5e9f6f5aad4764801015bc8d4b4a278200 upstream.
For type 0x51 the udf.parent_partref member in struct fid gets copied
uninitialized to userland. Fix this by initializing it to 0.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit fe685aabf7c8c9f138e5ea900954d295bf229175 upstream.
For type 1 the parent_offset member in struct isofs_fid gets copied
commit 89b1f39eb4189de745fae554b0d614d87c8d5c63 upstream.
For large UDF filesystems with 512-byte blocks the number of necessary
bitmap blocks is larger than 2^16 so s_nr_groups in udf_bitmap overflows
(the number will overflow for filesystems larger than 128 GB with
512-byte blocks). That results in ENOSPC errors despite the filesystem
has plenty of free space.
Fix the problem by changing s_nr_groups' type to 'int'. That is enough
even for filesystems 2^32 blocks (UDF maximum) and 512-byte blocksize.
Reported-and-tested-by: v10lator@myway.de
Cc: Jim Trigg <jtrigg@spamcop.net>
commit 2b405bfa84063bfa35621d2d6879f52693c614b0 upstream.
In data=journal mode, if we unmount the file system before a
transaction has a chance to complete, when the journal inode is being
evicted, we can end up calling into jbd2_log_wait_commit() for the
last transaction, after the journalling machinery has been shut down.
Arguably we should adjust ext4_should_journal_data() to return FALSE
for the journal inode, but the only place it matters is
ext4_evict_inode(), and so to save a bit of CPU time, and to make the
patch much more obviously correct by inspection(tm), we'll fix it by
explicitly not trying to waiting for a journal commit when we are
evicting the journal inode, since it's guaranteed to never succeed in
this case.
This can be easily replicated via:
mount -t ext4 -o data=journal /dev/vdb /vdb ; umount /vdb
WARNING: at /usr/projects/linux/ext4/fs/jbd2/journal.c:542 __jbd2_log_start_commit+0xba/0xcd()
Hardware name: Bochs
JBD2: bad log_start_commit: 3005630206 3005630206 0 0
Modules linked in:
Pid: 2909, comm: umount Not tainted 3.8.0-rc3 #1020
Call Trace:
[<c015c0ef>] warn_slowpath_common+0x68/0x7d
[<c02b7e7d>] ? __jbd2_log_start_commit+0xba/0xcd
[<c015c177>] warn_slowpath_fmt+0x2b/0x2f
[<c02b7e7d>] __jbd2_log_start_commit+0xba/0xcd
[<c02b8075>] jbd2_log_start_commit+0x24/0x34
[<c0279ed5>] ext4_evict_inode+0x71/0x2e3
[<c021f0ec>] evict+0x94/0x135
[<c021f9aa>] iput+0x10a/0x110
[<c02b7836>] jbd2_journal_destroy+0x190/0x1ce
[<c0175284>] ? bit_waitqueue+0x50/0x50
[<c028d23f>] ext4_put_super+0x52/0x294
[<c020efe3>] generic_shutdown_super+0x48/0xb4
[<c020f071>] kill_block_super+0x22/0x60
[<c020f3e0>] deactivate_locked_super+0x22/0x49
[<c020f5d6>] deactivate_super+0x30/0x33
[<c0222795>] mntput_no_expire+0x107/0x10c
[<c02233a7>] sys_umount+0x2cf/0x2e0
[<c02233ca>] sys_oldumount+0x12/0x14
[<c08096b8>] syscall_call+0x7/0xb
---[ end trace 6a954cc790501c1f ]---
jbd2_log_wait_commit: error: j_commit_request=-1289337090, tid=0
commit 3a2256702e47f68f921dfad41b1764d05c572329 upstream.
This commit fixes a wrong return value of the number of the allocated
blocks in ext4_split_extent. When the length of blocks we want to
allocate is greater than the length of the current extent, we return a
wrong number. Let's see what happens in the following case when we
call ext4_split_extent().
map: [48, 72]
ex: [32, 64, u]
'ex' will be split into two parts:
ex1: [32, 47, u]
ex2: [48, 64, w]
'map->m_len' is returned from this function, and the value is 24. But
the real length is 16. So it should be fixed.
Meanwhile in this commit we use right length of the allocated blocks
when get_reserved_cluster_alloc in ext4_ext_handle_uninitialized_extents
is called.
Signed-off-by: Zheng Liu <wenqing.lz@taobao.com>
Cc: Dmitry Monakhov <dmonakhov@openvz.org>
