(cherry picked from commit fab3a549e204172236779f502eccb4f9bf0dc87d)
Fix the following potential circular locking dependency between
mm->mmap_sem and ei->i_data_sem:
[ INFO: possible circular locking dependency detected ]
2.6.32-04115-gec044c5 #37
ureadahead/1855 is trying to acquire lock:
(&mm->mmap_sem){++++++}, at: [<ffffffff81107224>] might_fault+0x5c/0xac
but task is already holding lock:
(&ei->i_data_sem){++++..}, at: [<ffffffff811be1fd>] ext4_fiemap+0x11b/0x159
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&ei->i_data_sem){++++..}:
[<ffffffff81099bfa>] __lock_acquire+0xb67/0xd0f
[<ffffffff81099e7e>] lock_acquire+0xdc/0x102
[<ffffffff81516633>] down_read+0x51/0x84
[<ffffffff811a2414>] ext4_get_blocks+0x50/0x2a5
[<ffffffff811a3453>] ext4_get_block+0xab/0xef
[<ffffffff81154f39>] do_mpage_readpage+0x198/0x48d
[<ffffffff81155360>] mpage_readpages+0xd0/0x114
[<ffffffff811a104b>] ext4_readpages+0x1d/0x1f
[<ffffffff810f8644>] __do_page_cache_readahead+0x12f/0x1bc
[<ffffffff810f86f2>] ra_submit+0x21/0x25
[<ffffffff810f0cfd>] filemap_fault+0x19f/0x32c
[<ffffffff81107b97>] __do_fault+0x55/0x3a2
[<ffffffff81109db0>] handle_mm_fault+0x327/0x734
[<ffffffff8151aaa9>] do_page_fault+0x292/0x2aa
[<ffffffff81518205>] page_fault+0x25/0x30
[<ffffffff812a34d8>] clear_user+0x38/0x3c
[<ffffffff81167e16>] padzero+0x20/0x31
[<ffffffff81168b47>] load_elf_binary+0x8bc/0x17ed
[<ffffffff81130e95>] search_binary_handler+0xc2/0x259
[<ffffffff81166d64>] load_script+0x1b8/0x1cc
[<ffffffff8113255f>] do_execve+0x1ce/0x2cf
[<ffffffff81027494>] sys_execve+0x43/0x5a
[<ffffffff8102918a>] stub_execve+0x6a/0xc0
-> #0 (&mm->mmap_sem){++++++}:
[<ffffffff81099aa4>] __lock_acquire+0xa11/0xd0f
[<ffffffff81107251>] might_fault+0x89/0xac
[<ffffffff81139382>] fiemap_fill_next_extent+0x95/0xda
[<ffffffff811bcb43>] ext4_ext_fiemap_cb+0x138/0x157
[<ffffffff811be069>] ext4_ext_walk_space+0x178/0x1f1
[<ffffffff811be21e>] ext4_fiemap+0x13c/0x159
[<ffffffff811390e6>] do_vfs_ioctl+0x348/0x4d6
[<ffffffff811392ca>] sys_ioctl+0x56/0x79
[<ffffffff81028cb2>] system_call_fastpath+0x16/0x1b
1 lock held by ureadahead/1855:
#0: (&ei->i_data_sem){++++..}, at: [<ffffffff811be1fd>] ext4_fiemap+0x11b/0x159
stack backtrace:
Pid: 1855, comm: ureadahead Not tainted 2.6.32-04115-gec044c5 #37
Call Trace:
[<ffffffff81098c70>] print_circular_bug+0xa8/0xb7
[<ffffffff8102f229>] ? sched_clock+0x9/0xd
[<ffffffff81107224>] ? might_fault+0x5c/0xac
[<ffffffff81124b44>] ? __kmalloc+0x13b/0x18c
[<ffffffff811bca0b>] ? ext4_ext_fiemap_cb+0x0/0x157
[<ffffffff8129f6d0>] ? __up_read+0x8d/0x95
[<ffffffff81517fb5>] ? retint_swapgs+0x13/0x1b
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
(cherry picked from commit 4a58579b9e4e2a35d57e6c9c8483e52f6f1b7fd6)
This patch fixes three problems in the handling of the
EXT4_IOC_MOVE_EXT ioctl:
1. In current EXT4_IOC_MOVE_EXT, there are read access mode checks for
original and donor files, but they allow the illegal write access to
donor file, since donor file is overwritten by original file data. To
fix this problem, change access mode checks of original (r->r/w) and
donor (r->w) files.
2. Disallow the use of donor files that have a setuid or setgid bits.
3. Call mnt_want_write() and mnt_drop_write() before and after
ext4_move_extents() calling to get write access to a mount.
Signed-off-by: Akira Fujita <a-fujita@rs.jp.nec.com>
(cherry picked from commit b436b9bef84de6893e86346d8fbf7104bc520645)
We cannot rely on buffer dirty bits during fsync because pdflush can come
before fsync is called and clear dirty bits without forcing a transaction
commit. What we do is that we track which transaction has last changed
the inode and which transaction last changed allocation and force it to
disk on fsync.
(cherry picked from commit 194074acacebc169ded90a4657193f5180015051)
Inside ->setattr() call both ATTR_UID and ATTR_GID may be valid
This means that we may end-up with transferring all quotas. Add
we have to reserve QUOTA_DEL_BLOCKS for all quotas, as we do in
case of QUOTA_INIT_BLOCKS.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Reviewed-by: Mingming Cao <cmm@us.ibm.com>
(cherry picked from commit 5aca07eb7d8f14d90c740834d15ca15277f4820c)
Currently all quota block reservation macros contains hard-coded "2"
aka MAXQUOTAS value. This is no good because in some places it is not
obvious to understand what does this digit represent. Let's introduce
new macro with self descriptive name.
Acked-by: Mingming Cao <cmm@us.ibm.com>
(cherry picked from commit 8aa6790f876e81f5a2211fe1711a5fe3fe2d7b20)
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
(cherry picked from commit b844167edc7fcafda9623955c05e4c1b3c32ebc7)
This fixes a leak of blocks in an inode prealloc list if device failures
cause ext4_mb_mark_diskspace_used() to fail.
Signed-off-by: Curt Wohlgemuth <curtw@google.com>
Acked-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
(cherry picked from commit d4edac314e9ad0b21ba20ba8bc61b61f186f79e1)
There is a potential race when a transaction is committing right when
the file system is being umounting. This could reduce in a race
because EXT4_SB(sb)->s_group_info could be freed in ext4_put_super
before the commit code calls a callback so the mballoc code can
release freed blocks in the transaction, resulting in a panic trying
to access the freed s_group_info.
The fix is to wait for the transaction to finish committing before we
shutdown the multiblock allocator.
Signed-off-by: Josef Bacik <josef@redhat.com>
(cherry picked from commit b9a4207d5e911b938f73079a83cc2ae10524ec7f)
When ext4_write_begin fails after allocating some blocks or
generic_perform_write fails to copy data to write, we truncate blocks
already instantiated beyond i_size. Although these blocks were never
inside i_size, we have to truncate the pagecache of these blocks so
that corresponding buffers get unmapped. Otherwise subsequent
__block_prepare_write (called because we are retrying the write) will
find the buffers mapped, not call ->get_block, and thus the page will
be backed by already freed blocks leading to filesystem and data
corruption.
(cherry picked from commit c09eef305dd43846360944ad072f051f964fa383)
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
(cherry picked from commit e6ec116b67f46e0e7808276476554727b2e6240b)
OOM happens.
(cherry picked from commit ac48b0a1d068887141581bea8285de5fcab182b0)
Integrate duplicate lines (acquire/release semaphore and invalidate
extent cache in move_extent_per_page()) into mext_replace_branches(),
to reduce source and object code size.
(cherry picked from commit 446aaa6e7e993b38a6f21c6acfa68f3f1af3dbe3)
The move_extent.moved_len is used to pass back the number of exchanged
blocks count to user space. Currently the caller must clear this
field; but we spend more code space checking for this requirement than
simply zeroing the field ourselves, so let's just make life easier for
everyone all around.
Signed-off-by: Kazuya Mio <k-mio@sx.jp.nec.com>
(cherry picked from commit 94d7c16cbbbd0e03841fcf272bcaf0620ad39618)
At the beginning of ext4_move_extent(), we call
ext4_discard_preallocations() to discard inode PAs of orig and donor
inodes. But in the following case, blocks can be double freed, so
move ext4_discard_preallocations() to the end of ext4_move_extents().
1. Discard inode PAs of orig and donor inodes with
ext4_discard_preallocations() in ext4_move_extents().
orig : [ DATA1 ]
donor: [ DATA2 ]
2. While data blocks are exchanging between orig and donor inodes, new
inode PAs is created to orig by other process's block allocation.
(Since there are semaphore gaps in ext4_move_extents().) And new
inode PAs is used partially (2-1).
2-1 Create new inode PAs to orig inode
orig : [ DATA1 | used PA1 | free PA1 ]
donor: [ DATA2 ]
3. Donor inode which has old orig inode's blocks is deleted after
EXT4_IOC_MOVE_EXT finished (3-1, 3-2). So the block bitmap
corresponds to old orig inode's blocks are freed.
3-1 After EXT4_IOC_MOVE_EXT finished
orig : [ DATA2 | free PA1 ]
donor: [ DATA1 | used PA1 ]
3-2 Delete donor inode
donor: [ FREE SPACE(DATA1) | FREE SPACE(used PA1) ]
4. The double-free of blocks is occurred, when close() is called to
orig inode. Because ext4_discard_preallocations() for orig inode
frees used PA1 and free PA1, though used PA1 is already freed in 3.
4-1 Double-free of blocks is occurred
orig : [ DATA2 | FREE SPACE(free PA1) ]
donor: [ FREE SPACE(DATA1) | DOUBLE FREE(used PA1) ]
(cherry picked from commit e3bb52ae2bb9573e84c17b8e3560378d13a5c798)
Users on the linux-ext4 list recently complained about differences
across filesystems w.r.t. how to mount without a journal replay.
In the discussion it was noted that xfs's "norecovery" option is
perhaps more descriptively accurate than "noload," so let's make
that an alias for ext4.
Also show this status in /proc/mounts
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
(cherry picked from commit 5328e635315734d42080de9a5a1ee87bf4cae0a4)
It is anticipated that when sb_issue_discard starts doing
real work on trim-capable devices, we may see issues. Make
this mount-time optional, and default it to off until we know
that things are working out OK.
(cherry picked from commit 2bba702d4f88d7b010ec37e2527b552588404ae7)
When an error happened in ext4_splice_branch we failed to notice that
in ext4_ind_get_blocks and mapped the buffer anyway. Fix the problem
by checking for error properly.
(cherry picked from commit 6b17d902fdd241adfa4ce780df20547b28bf5801)
We don't to issue an I/O barrier on an error or if we force commit
because we are doing data journaling.
Cc: Jan Kara <jack@suse.cz>
(cherry picked from commit 1032988c71f3f85483b2b4319684d1205a704c02)
The block validity checks used by ext4_data_block_valid() wasn't
correctly written to check file systems with the meta_bg feature. Fix
this.
(cherry picked from commit 8dadb198cb70ef811916668fe67eeec82e8858dd)
The number of old-style block group descriptor blocks is
s_meta_first_bg when the meta_bg feature flag is set.
(cherry picked from commit 3f8fb9490efbd300887470a2a880a64e04dcc3f5)
commit a71ce8c6c9bf269b192f352ea555217815cf027e updated ext4_statfs()
to update the on-disk superblock counters, but modified this buffer
directly without any journaling of the change. This is one of the
accesses that was causing the crc errors in journal replay as seen in
kernel.org bugzilla #14354.
(cherry picked from commit 86ebfd08a1930ccedb8eac0aeb1ed4b8b6a41dbc)
ext4_xattr_set_handle() was zeroing out an inode outside
of journaling constraints; this is one of the accesses that
Reviewed-by: Andreas Dilger <adilger@sun.com>
(cherry picked from commit 30c6e07a92ea4cb87160d32ffa9bce172576ae4c)
We need to be testing the i_flags field in the ext4 specific portion
of the inode, instead of the (confusingly aliased) i_flags field in
the generic struct inode.
(cherry picked from commit 50689696867d95b38d9c7be640a311494a04fb86)
When an inode gets unlinked, the functions ext4_clear_blocks() and
ext4_remove_blocks() call ext4_forget() for all the buffer heads
corresponding to the deleted inode's data blocks. If the inode is a
directory or a symlink, the is_metadata parameter must be non-zero so
ext4_forget() will revoke them via jbd2_journal_revoke(). Otherwise,
if these blocks are reused for a data file, and the system crashes
before a journal checkpoint, the journal replay could end up
corrupting these data blocks.
Thanks to Curt Wohlgemuth for pointing out potential problems in this
area.
(cherry picked from commit 567f3e9a70d71e5c9be03701b8578be77857293b)
One of the invalid error paths in ext4_iget() forgot to brelse() the
inode buffer head. Fix it by adding a brelse() in the common error
return path, which also simplifies function.
Thanks to Andi Kleen <ak@linux.intel.com> reporting the problem.
(cherry picked from commit 49bd22bc4d603a2a4fc2a6a60e156cbea52eb494)
If CONFIG_PROVE_LOCKING is enabled, the double_down_write_data_sem()
will trigger a false-positive warning of a recursive lock. Since we
take i_data_sem for the two inodes ordered by their inode numbers,
this isn't a problem. Use of down_write_nested() will notify the lock
dependency checker machinery that there is no problem here.
This problem was reported by Brian Rogers:
http://marc.info/?l=linux-ext4&m=125115356928011&w=1
Reported-by: Brian Rogers <brian@xyzw.org>
(cherry picked from commit fc04cb49a898c372a22b21fffc47f299d8710801)
ext4_move_extents() checks the logical block contiguousness
of original file with ext4_find_extent() and mext_next_extent().
Therefore the extent which ext4_ext_path structure indicates
must not be changed between above functions.
But in current implementation, there is no i_data_sem protection
between ext4_ext_find_extent() and mext_next_extent(). So the extent
which ext4_ext_path structure indicates may be overwritten by
delalloc. As a result, ext4_move_extents() will exchange wrong blocks
between original and donor files. I change the place where
acquire/release i_data_sem to solve this problem.
Moreover, I changed move_extent_per_page() to start transaction first,
and then acquire i_data_sem. Without this change, there is a
possibility of the deadlock between mmap() and ext4_move_extents():
* NOTE: "A", "B" and "C" mean different processes
A-1: ext4_ext_move_extents() acquires i_data_sem of two inodes.
B: do_page_fault() starts the transaction (T),
and then tries to acquire i_data_sem.
But process "A" is already holding it, so it is kept waiting.
C: While "A" and "B" running, kjournald2 tries to commit transaction (T)
but it is under updating, so kjournald2 waits for it.
A-2: Call ext4_journal_start with holding i_data_sem,
but transaction (T) is locked.
(cherry picked from commit f868a48d06f8886cb0367568a12367fa4f21ea0d)
If the EXT4_IOC_MOVE_EXT ioctl fails, the number of blocks that were
exchanged before the failure should be returned to the userspace
caller. Unfortunately, currently if the block size is not the same as
the page size, the returned block count that is returned is the
page-aligned block count instead of the actual block count. This
commit addresses this bug.
(cherry picked from commit 503358ae01b70ce6909d19dd01287093f6b6271c)
If s_log_groups_per_flex is greater than 31, then groups_per_flex will
will overflow and cause a divide by zero error. This can cause kernel
BUG if such a file system is mounted.
Thanks to Nageswara R Sastry for analyzing the failure and providing
an initial patch.
http://bugzilla.kernel.org/show_bug.cgi?id=14287
(cherry picked from commit 2de770a406b06dfc619faabbf5d85c835ed3f2e1)
Previously add_dirent_to_buf() did not free its passed-in buffer head
in the case of ENOSPC, since in some cases the caller still needed it.
However, this led to potential buffer head leaks since not all callers
dealt with this correctly. Fix this by making simplifying the freeing
convention; now add_dirent_to_buf() *never* frees the passed-in buffer
head, and leaves that to the responsibility of its caller. This makes
things cleaner and easier to prove that the code is neither leaking
buffer heads or calling brelse() one time too many.
Cc: Curt Wohlgemuth <curtw@google.com>
When IMA is active, using dentry_open without updating the
IMA counters will result in free/open imbalance errors when
fput is eventually called.
Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com>
While building 2.6.32-rc8-git2 for Fedora I noticed the following thinko
in commit 201a15428bd54f83eccec8b7c64a04b8f9431204 ("FS-Cache: Handle
pages pending storage that get evicted under OOM conditions"):
fs/9p/cache.c: In function '__v9fs_fscache_release_page':
fs/9p/cache.c:346: error: 'vnode' undeclared (first use in this function)
fs/9p/cache.c:346: error: (Each undeclared identifier is reported only once
fs/9p/cache.c:346: error: for each function it appears in.)
make[2]: *** [fs/9p/cache.o] Error 1
Fix the 9P filesystem to correctly construct the argument to
fscache_maybe_release_page().
Signed-off-by: Kyle McMartin <kyle@redhat.com>
Signed-off-by: Xiaotian Feng <dfeng@redhat.com> [from identical patch]
Signed-off-by: Stefan Lippers-Hollmann <s.l-h@gmx.de> [from identical patch]
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6:
[CIFS] Fix sparse warning
[CIFS] Duplicate data on appending to some Samba servers
[CIFS] fix oops in cifs_lookup during net boot
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: reject O_DIRECT flag also in fuse_create
In 2.6.23 kernel, commit a32ea1e1f925399e0d81ca3f7394a44a6dafa12c
("Fix read/truncate race") fixed a race in the generic code, and as a
side effect, now do_generic_file_read() can ask us to readpage() past
the i_size. This seems to be correctly handled by the block routines
(e.g. block_read_full_page() fills the page with zeroes in case if
somebody is trying to read past the last inode's block).
JFFS2 doesn't handle this; it assumes that it won't be asked to read
pages which don't exist -- and thus that there will be at least _one_
valid 'frag' on the page it's being asked to read. It will fill any
holes with the following memset:
memset(buf, 0, min(end, frag->ofs + frag->size) - offset);
When the 'closest smaller match' returned by jffs2_lookup_node_frag() is
actually on a previous page and ends before 'offset', that results in:
memset(buf, 0, <huge unsigned negative>);
Hopefully, in most cases the corruption is fatal, and quickly causing
random oopses, like this:
root@10.0.0.4:~/ltp-fs-20090531# ./testcases/kernel/fs/ftest/ftest01
Unable to handle kernel paging request for data at address 0x00000008
Faulting instruction address: 0xc01cd980
Oops: Kernel access of bad area, sig: 11 [#1]
NIP [c01cd980] rb_insert_color+0x38/0x184
LR [c0043978] enqueue_hrtimer+0x88/0xc4
Call Trace:
[c6c63b60] [c004f9a8] tick_sched_timer+0xa0/0xe4 (unreliable)
[c6c63b80] [c0043978] enqueue_hrtimer+0x88/0xc4
[c6c63b90] [c0043a48] __run_hrtimer+0x94/0xbc
[c6c63bb0] [c0044628] hrtimer_interrupt+0x140/0x2b8
[c6c63c10] [c000f8e8] timer_interrupt+0x13c/0x254
[c6c63c30] [c001352c] ret_from_except+0x0/0x14
--- Exception: 901 at memset+0x38/0x5c
LR = jffs2_read_inode_range+0x144/0x17c
[c6c63cf0] [00000000] (null) (unreliable)
This patch fixes the issue, plus fixes all LTP tests on NAND/UBI with
JFFS2 filesystem that were failing since 2.6.23 (seems like the bug
above also broke the truncation).
Reported-By: Anton Vorontsov <avorontsov@ru.mvista.com>
Tested-By: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: stable@kernel.org
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-fscache: (31 commits)
FS-Cache: Provide nop fscache_stat_d() if CONFIG_FSCACHE_STATS=n
SLOW_WORK: Fix GFS2 to #include <linux/module.h> before using THIS_MODULE
SLOW_WORK: Fix CIFS to pass THIS_MODULE to slow_work_register_user()
CacheFiles: Don't log lookup/create failing with ENOBUFS
CacheFiles: Catch an overly long wait for an old active object
CacheFiles: Better showing of debugging information in active object problems
CacheFiles: Mark parent directory locks as I_MUTEX_PARENT to keep lockdep happy
CacheFiles: Handle truncate unlocking the page we're reading
CacheFiles: Don't write a full page if there's only a partial page to cache
FS-Cache: Actually requeue an object when requested
FS-Cache: Start processing an object's operations on that object's death
FS-Cache: Make sure FSCACHE_COOKIE_LOOKING_UP cleared on lookup failure
FS-Cache: Add a retirement stat counter
FS-Cache: Handle pages pending storage that get evicted under OOM conditions
FS-Cache: Handle read request vs lookup, creation or other cache failure
FS-Cache: Don't delete pending pages from the page-store tracking tree
FS-Cache: Fix lock misorder in fscache_write_op()
FS-Cache: The object-available state can't rely on the cookie to be available
FS-Cache: Permit cache retrieval ops to be interrupted in the initial wait phase
FS-Cache: Use radix tree preload correctly in tracking of pages to be stored
The comment in fuse_open about O_DIRECT:
"VFS checks this, but only _after_ ->open()"
also holds for fuse_create, however, the same kind of check was missing there.
As an impact of this bug, open(newfile, O_RDWR|O_CREAT|O_DIRECT) fails, but a
stub newfile will remain if the fuse server handled the implied FUSE_CREATE
request appropriately.
Other impact: in the above situation ima_file_free() will complain to open/free
imbalance if CONFIG_IMA is set.
Signed-off-by: Csaba Henk <csaba@gluster.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Cc: Harshavardhana <harsha@gluster.com>
Also update CHANGES file
Signed-off-by: Steve French <sfrench@us.ibm.com>
SMB writes are sent with a starting offset and length. When the server
supports the newer SMB trans2 posix open (rather than using the SMB
NTCreateX) a file can be opened with SMB_O_APPEND flag, and for that
case Samba server assumes that the offset sent in SMBWriteX is unneeded
since the write should go to the end of the file - which can cause
problems if the write was cached (since the beginning part of a
page could be written twice by the client mm). Jeff suggested that
masking the flag on posix open on the client is easiest for the time
being. Note that recent Samba server also had an unrelated problem with
SMB NTCreateX and append (see samba bugzilla bug number 6898) which
should not affect current Linux clients (unless cifs Unix Extensions
are disabled).
The cifs client did not send the O_APPEND flag on posix open
before 2.6.29 so the fix is unneeded on early kernels.
In the future, for the non-cached case (O_DIRECT, and forcedirectio mounts)
it would be possible and useful to send O_APPEND on posix open (for Windows
case: FILE_APPEND_DATA but not FILE_WRITE_DATA on SMB NTCreateX) but for
cached writes although the vfs sets the offset to end of file it
may fragment a write across pages - so we can't send O_APPEND on
open (could result in sending part of a page twice).
CC: Stable <stable@kernel.org>
Reviewed-by: Shirish Pargaonkar <shirishp@us.ibm.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Fixes bugzilla.kernel.org bug number 14641
Lookup called during network boot (network root filesystem
for diskless workstation) has case where nd is null in
lookup. This patch fixes that in cifs_lookup.
(Shirish noted that 2.6.30 and 2.6.31 stable need the same check)
Signed-off-by: Shirish Pargaonkar <shirishp@us.ibm.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
Tested-by: Vladimir Stavrinov <vs@inist.ru>
Provide nop fscache_stat_d() macro if CONFIG_FSCACHE_STATS=n lest errors like
the following occur:
fs/fscache/cache.c: In function 'fscache_withdraw_cache':
fs/fscache/cache.c:386: error: implicit declaration of function 'fscache_stat_d'
fs/fscache/cache.c:386: error: 'fscache_n_cop_sync_cache' undeclared (first use in this function)
fs/fscache/cache.c:386: error: (Each undeclared identifier is reported only once
fs/fscache/cache.c:386: error: for each function it appears in.)
fs/fscache/cache.c:392: error: 'fscache_n_cop_dissociate_pages' undeclared (first use in this function)
GFS2 has been altered to pass THIS_MODULE to slow_work_register_user(), but
hasn't been altered to #include <linux/module.h> to provide it, resulting in
the following error:
fs/gfs2/recovery.c:596: error: 'THIS_MODULE' undeclared here (not in a function)
Add the missing #include.
As of the patch:
SLOW_WORK: Wait for outstanding work items belonging to a module to clear
Wait for outstanding slow work items belonging to a module to clear
when unregistering that module as a user of the facility. This
prevents the put_ref code of a work item from being taken away before
it returns.
slow_work_register_user() takes a module pointer as an argument. CIFS must now
pass THIS_MODULE as that argument, lest the following error be observed:
fs/cifs/cifsfs.c: In function 'init_cifs':
fs/cifs/cifsfs.c:1040: error: too few arguments to function 'slow_work_register_user'
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2:
ocfs2: Trivial cleanup of jbd compatibility layer removal
ocfs2: Refresh documentation
ocfs2: return f_fsid info in ocfs2_statfs()
ocfs2: duplicate inline data properly during reflink.
ocfs2: Move ocfs2_complete_reflink to the right place.
ocfs2: Return -EINVAL when a device is not ocfs2.
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
SUNRPC: Address buffer overrun in rpc_uaddr2sockaddr()
NFSv4: Fix a cache validation bug which causes getcwd() to return ENOENT
Don't log the CacheFiles lookup/create object routined failing with ENOBUFS as
under high memory load or high cache load they can do this quite a lot. This
error simply means that the requested object cannot be created on disk due to
lack of space, or due to failure of the backing filesystem to find sufficient
resources.
Catch an overly long wait for an old, dying active object when we want to
replace it with a new one. The probability is that all the slow-work threads
are hogged, and the delete can't get a look in.
What we do instead is:
(1) if there's nothing in the slow work queue, we sleep until either the dying
object has finished dying or there is something in the slow work queue
behind which we can queue our object.
(2) if there is something in the slow work queue, we return ETIMEDOUT to
fscache_lookup_object(), which then puts us back on the slow work queue,
presumably behind the deletion that we're blocked by. We are then
deferred for a while until we work our way back through the queue -
without blocking a slow-work thread unnecessarily.
A backtrace similar to the following may appear in the log without this patch:
INFO: task kslowd004:5711 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
kslowd004 D 0000000000000000 0 5711 2 0x00000080
ffff88000340bb80 0000000000000046 ffff88002550d000 0000000000000000
ffff88002550d000 0000000000000007 ffff88000340bfd8 ffff88002550d2a8
000000000000ddf0 00000000000118c0 00000000000118c0 ffff88002550d2a8
Call Trace:
[<ffffffff81058e21>] ? trace_hardirqs_on+0xd/0xf
[<ffffffffa011c4d8>] ? cachefiles_wait_bit+0x0/0xd [cachefiles]
[<ffffffffa011c4e1>] cachefiles_wait_bit+0x9/0xd [cachefiles]
[<ffffffff81353153>] __wait_on_bit+0x43/0x76
[<ffffffff8111ae39>] ? ext3_xattr_get+0x1ec/0x270
[<ffffffff813531ef>] out_of_line_wait_on_bit+0x69/0x74
[<ffffffff8104c125>] ? wake_bit_function+0x0/0x2e
[<ffffffffa011bc79>] cachefiles_mark_object_active+0x203/0x23b [cachefiles]
[<ffffffffa011c209>] cachefiles_walk_to_object+0x558/0x827 [cachefiles]
[<ffffffffa011a429>] cachefiles_lookup_object+0xac/0x12a [cachefiles]
[<ffffffffa00aa1e9>] fscache_lookup_object+0x1c7/0x214 [fscache]
[<ffffffffa00aafc5>] fscache_object_state_machine+0xa5/0x52d [fscache]
[<ffffffffa00ab4ac>] fscache_object_slow_work_execute+0x5f/0xa0 [fscache]
[<ffffffff81082093>] slow_work_execute+0x18f/0x2d1
[<ffffffff8108239a>] slow_work_thread+0x1c5/0x308
[<ffffffff8104c0f1>] ? autoremove_wake_function+0x0/0x34
[<ffffffff810821d5>] ? slow_work_thread+0x0/0x308
[<ffffffff8104be91>] kthread+0x7a/0x82
[<ffffffff8100beda>] child_rip+0xa/0x20
[<ffffffff8100b87c>] ? restore_args+0x0/0x30
[<ffffffff8104be17>] ? kthread+0x0/0x82
[<ffffffff8100bed0>] ? child_rip+0x0/0x20
1 lock held by kslowd004/5711:
#0: (&sb->s_type->i_mutex_key#7/1){+.+.+.}, at: [<ffffffffa011be64>] cachefiles_walk_to_object+0x1b3/0x827 [cachefiles]
Show more debugging information if cachefiles_mark_object_active() is asked to
activate an active object.
This may happen, for instance, if the netfs tries to register an object with
the same key multiple times.
The code is changed to (a) get the appropriate object lock to protect the
cookie pointer whilst we dereference it, and (b) get and display the cookie key
if available.
Mark parent directory locks as I_MUTEX_PARENT in the callers of
cachefiles_bury_object() so that lockdep doesn't complain when that invokes
vfs_unlink():
[ INFO: possible recursive locking detected ]
2.6.32-rc6-cachefs #47
kslowd002/3089 is trying to acquire lock:
(&sb->s_type->i_mutex_key#7){+.+.+.}, at: [<ffffffff810bbf72>] vfs_unlink+0x8b/0x128
(&sb->s_type->i_mutex_key#7){+.+.+.}, at: [<ffffffffa00e4e61>] cachefiles_walk_to_object+0x1b0/0x831 [cachefiles]
1 lock held by kslowd002/3089:
#0: (&sb->s_type->i_mutex_key#7){+.+.+.}, at: [<ffffffffa00e4e61>] cachefiles_walk_to_object+0x1b0/0x831 [cachefiles]
stack backtrace:
Pid: 3089, comm: kslowd002 Not tainted 2.6.32-rc6-cachefs #47
Call Trace:
[<ffffffff8105ad7b>] __lock_acquire+0x1649/0x16e3
[<ffffffff8118170e>] ? inode_has_perm+0x5f/0x61
[<ffffffff8105ae6c>] lock_acquire+0x57/0x6d
[<ffffffff810bbf72>] ? vfs_unlink+0x8b/0x128
[<ffffffff81353ac3>] mutex_lock_nested+0x54/0x292
[<ffffffff8118179e>] ? selinux_inode_permission+0x8e/0x90
[<ffffffff8117e271>] ? security_inode_permission+0x1c/0x1e
[<ffffffff810bb4fb>] ? inode_permission+0x99/0xa5
[<ffffffff810adb19>] ? kfree+0xed/0xf9
[<ffffffffa00e3f00>] cachefiles_bury_object+0xb6/0x420 [cachefiles]
[<ffffffffa00e7e24>] ? cachefiles_check_object_xattr+0x233/0x293 [cachefiles]
[<ffffffffa00e51b0>] cachefiles_walk_to_object+0x4ff/0x831 [cachefiles]
[<ffffffff81032238>] ? finish_task_switch+0x0/0xb2
[<ffffffffa00e3429>] cachefiles_lookup_object+0xac/0x12a [cachefiles]
[<ffffffffa00741e9>] fscache_lookup_object+0x1c7/0x214 [fscache]
[<ffffffffa0074fc5>] fscache_object_state_machine+0xa5/0x52d [fscache]
[<ffffffffa00754ac>] fscache_object_slow_work_execute+0x5f/0xa0 [fscache]
Signed-off-by: Daivd Howells <dhowells@redhat.com>
Handle truncate unlocking the page we're attempting to read from the backing
device before the read has completed.
This was causing reports like the following to occur:
Pid: 4765, comm: kslowd Not tainted 2.6.30.1 #1
Call Trace:
[<ffffffffa0331d7a>] ? cachefiles_read_waiter+0xd9/0x147 [cachefiles]
[<ffffffff804b74bd>] ? __wait_on_bit+0x60/0x6f
[<ffffffff8022bbbb>] ? __wake_up_common+0x3f/0x71
[<ffffffff8022cc32>] ? __wake_up+0x30/0x44
[<ffffffff8024a41f>] ? __wake_up_bit+0x28/0x2d
[<ffffffffa003a793>] ? ext3_truncate+0x4d7/0x8ed [ext3]
[<ffffffff80281f90>] ? pagevec_lookup+0x17/0x1f
[<ffffffff8028c2ff>] ? unmap_mapping_range+0x59/0x1ff
[<ffffffff8028e286>] ? vmtruncate+0xc2/0xe2
[<ffffffff802b82cf>] ? inode_setattr+0x22/0x10a
[<ffffffffa003baa5>] ? ext3_setattr+0x17b/0x1e6 [ext3]
[<ffffffff802b853d>] ? notify_change+0x186/0x2c9
[<ffffffffa032d9de>] ? cachefiles_attr_changed+0x133/0x1cd [cachefiles]
[<ffffffffa032df7f>] ? cachefiles_lookup_object+0xcf/0x12a [cachefiles]
[<ffffffffa0318165>] ? fscache_lookup_object+0x110/0x122 [fscache]
[<ffffffffa03188c3>] ? fscache_object_slow_work_execute+0x590/0x6bc
[fscache]
[<ffffffff80278f82>] ? slow_work_thread+0x285/0x43a
[<ffffffff8024a446>] ? autoremove_wake_function+0x0/0x2e
[<ffffffff80278cfd>] ? slow_work_thread+0x0/0x43a
[<ffffffff8024a317>] ? kthread+0x54/0x81
[<ffffffff8020c93a>] ? child_rip+0xa/0x20
[<ffffffff8024a2c3>] ? kthread+0x0/0x81
[<ffffffff8020c930>] ? child_rip+0x0/0x20
CacheFiles: I/O Error: Readpage failed on backing file 200000000000810
FS-Cache: Cache cachefiles stopped due to I/O error
Reported-by: Christian Kujau <lists@nerdbynature.de>
Reported-by: Takashi Iwai <tiwai@suse.de>
Reported-by: Duc Le Minh <duclm.vn@gmail.com>
