An allmodconfig compile on ppc64 with 2.6.32.17 currently gives this error
fs/cifs/dns_resolve.h:27: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'cifs_init_dns_resolver'
This adds the correct header file to fix this.
Signed-off-by: Michael Neuling <mikey@neuling.org>
commit 51c20fcced5badee0e2021c6c89f44aa3cbd72aa upstream.
Remove the __exit mark from cifs_exit_dns_resolver() as it's called by the
module init routine in case of error, and so may have been discarded during
linkage.
Acked-by: Jeff Layton <jlayton@redhat.com>
commit 728a756b8fcd22d80e2dbba8117a8a3aafd3f203 upstream.
This patch fixes a kernel Oops in the GFS2 rename code.
The problem was in the way the gfs2 directory code was trying
to re-use sentinel directory entries.
In the failing case, gfs2's rename function was renaming a
file to another name that had the same non-trivial length.
The file being renamed happened to be the first directory
entry on the leaf block.
First, the rename code (gfs2_rename in ops_inode.c) found the
original directory entry and decided it could do its job by
simply replacing the directory entry with another. Therefore
it determined correctly that no block allocations were needed.
Next, the rename code deleted the old directory entry prior to
replacing it with the new name. Therefore, the soon-to-be
replaced directory entry was temporarily made into a directory
entry "sentinel" or a place holder at the start of a leaf block.
Lastly, it went to re-add the replacement directory entry in
that leaf block. However, when gfs2_dirent_find_space was
looking for space in the leaf block, it used the wrong value
for the sentinel. That threw off its calculations so later
it decides it can't really re-use the sentinel and therefore
must allocate a new leaf block. But because it previously decided
to re-use the directory entry, it didn't waste the time to
grab a new block allocation for the inode. Therefore, the
inode's i_alloc pointer was still NULL and it crashes trying to
reference it.
In the case of sentinel directory entries, the entire dirent is
reused, not just the "free space" portion of it, and therefore
the function gfs2_dirent_find_space should use the value 0
rather than GFS2_DIRENT_SIZE(0) for the actual dirent size.
Fixing this calculation enables the reproducer programs to work
properly.
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
commit 1817176a86352f65210139d4c794ad2d19fc6b63 upstream.
This patch prevents user "foo" from using the SWAPEXT ioctl to swap
a write-only file owned by user "bar" into a file owned by "foo" and
subsequently reading it. It does so by checking that the file
descriptors passed to the ioctl are also opened for reading.
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
commit b608b283a962caaa280756bc8563016a71712acf upstream
See https://bugzilla.kernel.org/show_bug.cgi?id=16056
If other processes are blocked waiting for kswapd to free up some memory so
that they can make progress, then we cannot allow kswapd to block on those
processes.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit d327cf7449e6fd5cbac784c641770e9366faa386 upstream.
Subject: nfs: fix acl decoding
Commit 28f566942c6b1d929f5e240e69e7081b77b238d3 "NFS: use dynamically
computed compound_hdr.replen for xdr_inline_pages offset" accidentally
changed the amount of space to allow for the acl reply, resulting in an
IO error on attempts to get an acl.
Reported-by: Paul Rudin <paul@rudin.co.uk>
Cc: Benny Halevy <bhalevy@panasas.com>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
Cc: Jeremy Kerr <jeremy.kerr@canonical.com>
commit a6f80fb7b5986fda663d94079d3bba0937a6b6ff upstream.
The function ecryptfs_uid_hash wrongly assumes that the
second parameter to hash_long() is the number of hash
buckets instead of the number of hash bits.
This patch fixes that and renames the variable
ecryptfs_hash_buckets to ecryptfs_hash_bits to make it
clearer.
Fixes: CVE-2010-2492
Signed-off-by: Andre Osterhues <aosterhues@escrypt.com>
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
commit 2646a1f61a3b5525914757f10fa12b5b94713648 upstream.
This code has been shamelessly stolen from XFS at the suggestion
of Christoph Hellwig. I've not added support for cached ACLs so
far... watch for that in a later patch, although this is designed
in such a way that they should be easy to add.
commit 14ece1028b3ed53ffec1b1213ffc6acaf79ad77c upstream (as of v2.6.34-git13)
Add a new ext4 state to tell us when a file has been newly created; use
that state in ext4_sync_file in no-journal mode to tell us when we need
to sync the parent directory as well as the inode and data itself. This
fixes a problem in which a panic or power failure may lose the entire
file even when using fsync, since the parent directory entry is lost.
Addresses-Google-Bug: #2480057
Signed-off-by: Frank Mayhar <fmayhar@google.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 4d92dc0f00a775dc2e1267b0e00befb783902fe7 upstream (as of v2.6.34-git13)
struct ext4_new_group_input needs to be converted because u64 has
only 32-bit alignment on some 32-bit architectures, notably i386.
commit 899ad0cea6ad7ff4ba24b16318edbc3cbbe03fad upstream (as of v2.6.34-git13)
It is unnecessary, and in general impossible, to define the compat
ioctl numbers except when building the filesystem with CONFIG_COMPAT
defined.
commit 0617b83fa239db9743a18ce6cc0e556f4d0fd567 upstream (as of v2.6.34-git13)
If i_data_sem was internally dropped due to transaction restart, it is
necessary to restart path look-up because extents tree was possibly
modified by ext4_get_block().
https://bugzilla.kernel.org/show_bug.cgi?id=15827
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Acked-by: Jan Kara <jack@suse.cz>
commit 786ec7915e530936b9eb2e3d12274145cab7aa7d upstream (as of v2.6.34-git13)
Dimitry Monakhov discovered an edge case where it was possible for the
EXT4_EOFBLOCKS_FL flag could get cleared unnecessarily. This is true;
I have a test case that can be exercised via downloading and
decompressing the file:
wget ftp://ftp.kernel.org/pub/linux/kernel/people/tytso/ext4-testcases/eofblocks-fl-test-case.img.bz2
bunzip2 eofblocks-fl-test-case.img
dd if=/dev/zero of=eofblocks-fl-test-case.img bs=1k seek=17925 bs=1k count=1 conv=notrunc
However, triggering it in real life is highly unlikely since it
requires an extremely fragmented sparse file with a hole in exactly
the right place in the extent tree. (It actually took quite a bit of
work to generate this test case.) Still, it's nice to get even
extreme corner cases to be correct, so this patch makes sure that we
don't clear the EXT4_EOFBLOCKS_FL incorrectly even in this corner
case.
commit f70f362b4a6fe47c239dbfb3efc0cc2c10e4f09c upstream (as of v2.6.34-git13)
If the EOFBLOCK_FL flag is set when it should not be and the inode is
zero length, then eh_entries is zero, and ex is NULL, so dereferencing
ex to print ex->ee_block causes a kernel OOPS in
ext4_ext_map_blocks().
On top of that, the error message which is printed isn't very helpful.
So we fix this by printing something more explanatory which doesn't
involve trying to print ex->ee_block.
Addresses-Google-Bug: #2655740
commit 12e9b892002d9af057655d35b44db8ee9243b0dc upstream (as of v2.6.34-git13)
At several places we modify EXT4_I(inode)->i_flags without holding
i_mutex (ext4_do_update_inode, ...). These modifications are racy and
we can lose updates to i_flags. So convert handling of i_flags to use
bitops which are atomic.
https://bugzilla.kernel.org/show_bug.cgi?id=15792
commit 39a4bade8c1826b658316d66ee81c09b0a4d7d42 upstream (as of v2.6.34-git13)
We failed to show journal_checksum option in /proc/mounts. Fix it.
commit 8a57d9d61a6e361c7bb159dda797672c1df1a691 upstream (as of v2.6.34-git13)
This adds a new field in ext4_group_info to cache the largest available
block range in a block group; and don't load the buddy pages until *after*
we've done a sanity check on the block group.
With large allocation requests (e.g., fallocate(), 8MiB) and relatively full
partitions, it's easy to have no block groups with a block extent large
enough to satisfy the input request length. This currently causes the loop
during cr == 0 in ext4_mb_regular_allocator() to load the buddy bitmap pages
for EVERY block group. That can be a lot of pages. The patch below allows
us to call ext4_mb_good_group() BEFORE we load the buddy pages (although we
have check again after we lock the block group).
Addresses-Google-Bug: #2578108
Addresses-Google-Bug: #2704453
Signed-off-by: Curt Wohlgemuth <curtw@google.com>
commit 6d19c42b7cf81c39632b6d4dbc514e8449bcd346 upstream (as of v2.6.34-git13)
Currently using posix_fallocate one can bypass an RLIMIT_FSIZE limit
and create a file larger than the limit. Add a check for that.
Signed-off-by: Nikanth Karthikesan <knikanth@suse.de>
Signed-off-by: Amit Arora <aarora@in.ibm.com>
commit fbe845ddf368f77f86aa7500f8fd2690f54c66a8 upstream (as of v2.6.34-git13)
Addresses-Google-Bug: #2562325
commit 84061e07c5fbbbf9dc8aef8fb750fc3a2dfc31f3 upstream (as of v2.6.34-git13)
Currently block/inode/dir counters initialized before journal was
recovered. In fact after journal recovery this info will probably
change. And freeblocks it critical for correct delalloc mode
accounting.
https://bugzilla.kernel.org/show_bug.cgi?id=15768
commit d17413c08cd2b1dd2bf2cfdbb0f7b736b2b2b15c upstrea (as of v2..34-git13)
- Reorganize locking scheme to batch two atomic operation in to one.
This also allow us to state what healthy group must obey following rule
ext4_free_inodes_count(sb, gdp) == ext4_count_free(inode_bitmap, NUM);
- Fix possible undefined pointer dereference.
- Even if group descriptor stats aren't accessible we have to update
inode bitmaps.
- Move non-group members update out of group_lock.
Note: this commit has been observed to fix fs corruption problems
under heavy fs load
commit 21ca087a3891efab4d45488db8febee474d26c68 upstream (as of v2.6.34-git13)
The extents code will sometimes zero out blocks and mark them as
initialized instead of splitting an extent into several smaller ones.
This optimization however, causes problems if the extent is beyond
i_size because fsck will complain if there are uninitialized blocks
after i_size as this can not be distinguished from an inode that has
an incorrect i_size field.
https://bugzilla.kernel.org/show_bug.cgi?id=15742
commit c445e3e0a5c2804524dec6e55f66d63f6bc5bc3e upstream (as of v2.6.34-git13)
There was a bug reported on RHEL5 that a 10G dd on a 12G box
had a very, very slow sync after that.
At issue was the loop in write_cache_pages scanning all the way
to the end of the 10G file, even though the subsequent call
to mpage_da_submit_io would only actually write a smallish amt; then
we went back to the write_cache_pages loop ... wasting tons of time
in calling __mpage_da_writepage for thousands of pages we would
just revisit (many times) later.
Upstream it's not such a big issue for sys_sync because we get
to the loop with a much smaller nr_to_write, which limits the loop.
However, talking with Aneesh he realized that fsync upstream still
gets here with a very large nr_to_write and we face the same problem.
This patch makes mpage_add_bh_to_extent stop the loop after we've
accumulated 2048 pages, by setting mpd->io_done = 1; which ultimately
causes the write_cache_pages loop to break.
Repeating the test with a dirty_ratio of 80 (to leave something for
fsync to do), I don't see huge IO performance gains, but the reduction
in cpu usage is striking: 80% usage with stock, and 2% with the
below patch. Instrumenting the loop in write_cache_pages clearly
shows that we are wasting time here.
Eventually we need to change mpage_da_map_pages() also submit its I/O
to the block layer, subsuming mpage_da_submit_io(), and then change it
call ext4_get_blocks() multiple times.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
commit a30eec2a8650a77f754e84b2e15f062fe652baa7 upstream (as of v2.6.34-git13)
Turn off issuance of discard requests if the device does
not support it - similar to the action we take for barriers.
This will save a little computation time if a non-discardable
device is mounted with -o discard, and also makes it obvious
that it's not doing what was asked at mount time ...
commit 6b0310fbf087ad6e9e3b8392adca97cd77184084 upstream (as of v2.6.34-git13)
ext4_freeze() used jbd2_journal_lock_updates() which takes
the j_barrier mutex, and then returns to userspace. The
kernel does not like this:
[ BUG: lock held when returning to user space! ]
lvcreate/1075 is leaving the kernel with locks still held!
1 lock held by lvcreate/1075:
#0: (&journal->j_barrier){+.+...}, at: [<ffffffff811c6214>]
jbd2_journal_lock_updates+0xe1/0xf0
Use vfs_check_frozen() added to ext4_journal_start_sb() and
ext4_force_commit() instead.
Addresses-Red-Hat-Bugzilla: #568503
commit 42007efd569f1cf3bfb9a61da60ef6c2179508ca upstream (as of v2.6.34-git13)
If groups_per_flex < 2, sbi->s_flex_groups[] doesn't get filled out,
and every other access to this first tests s_log_groups_per_flex;
same thing needs to happen in resize or we'll wander off into
a null pointer when doing an online resize of the file system.
Thanks to Christoph Biedl, who came up with the trivial testcase:
# truncate --size 128M fsfile
# mkfs.ext3 -F fsfile
# tune2fs -O extents,uninit_bg,dir_index,flex_bg,huge_file,dir_nlink,extra_isize fsfile
# e2fsck -yDf -C0 fsfile
# truncate --size 132M fsfile
# losetup /dev/loop0 fsfile
# mount /dev/loop0 mnt
# resize2fs -p /dev/loop0
https://bugzilla.kernel.org/show_bug.cgi?id=13549
Reported-by: Alessandro Polverini <alex@nibbles.it>
Test-case-by: Christoph Biedl <bugzilla.kernel.bpeb@manchmal.in-ulm.de>
commit 35121c9860316d7799cea0fbc359a9186e7c2747 upstream (as of v2.6.34-git13)
allocated_meta_data is already included in 'used' variable.
commit b684b2ee9409f2890a8b3aea98525bbe5f84e276 upstream (as of v2.6.34-git13)
I have an x86_64 kernel with i386 userspace. e4defrag fails on the
EXT4_IOC_MOVE_EXT ioctl because it is not wired up for the compat
case. It seems that struct move_extent is compat save, only types
with fixed widths are used:
__u32 reserved; /* should be zero */
__u32 donor_fd; /* donor file descriptor */
__u64 orig_start; /* logical start offset in block for orig */
__u64 donor_start; /* logical start offset in block for donor */
__u64 len; /* block length to be moved */
__u64 moved_len; /* moved block length */
Lets just wire up EXT4_IOC_MOVE_EXT for the compat case.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
CC: Akira Fujita <a-fujita@rs.jp.nec.com>
commit e39e07fdfd98be8650385f12a7b81d6adc547510 upstream (as of v2.6.34-git13)
This function cleans up after ext4_mb_load_buddy(), so the renaming
makes the code clearer.
Signed-off-by: Jing Zhang <zj.barak@gmail.com>
commit 62e823a2cba18509ee826d775270e8ef9071b5bc upstream (as of v2.6.34-git13)
commit b720303df7352d4a7a1f61e467e0a124913c0d41 upstream (as of v2.6.34-git13)
When EIO occurs after bio is submitted, there is no memory free
operation for bio, which results in memory leakage. And there is also
no check against bio_alloc() for bio.
Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
commit 0671e704658b9f26f85e78d51176daa861f955c7 upstream (as of v2.6.34-git13)
commit b90f687018e6d6c77d981b09203780f7001407e5 upstream (as of v2.6.34-rc6)
Otherwise, we can end up having data corruption because the blocks
could get reused and then discarded!
https://bugzilla.kernel.org/show_bug.cgi?id=15579
commit fd2dd9fbaf9e498ec63eef298921e36556f7214c upstream (as of v2.6.34-rc6)
Calls to ext4_get_inode_loc() returns with a reference to a buffer
head in iloc->bh. The callers of this function in ext4_write_inode()
when in no journal mode and in ext4_xattr_fiemap() don't release the
buffer head after using it.
Addresses-Google-Bug: #2548165
commit 8b472d739b2ddd8ab7fb278874f696cd95b25a5e upstream (as of v2.6.34-rc6)
In the no-journal case, ext4_write_inode() will fetch the bh and call
sync_dirty_buffer() on it. However, if the bh has already been
written and the bh reclaimed for some other purpose, AND if the inode
is the only one in the inode table block in use, then
ext4_get_inode_loc() will not read the inode table block from disk,
but as an optimization, fill the block with zero's assuming that its
caller will copy in the on-disk version of the inode. This is not
done by ext4_write_inode(), so the contents of the inode can simply
get lost. The fix is to use __ext4_get_inode_loc() with in_mem set to
0, instead of ext4_get_inode_loc(). Long term the API needs to be
fixed so it's obvious why latter is not safe.
Addresses-Google-Bug: #2526446
commit c4caae25187ff3f5e837c6f04eb1acc2723c72d3 upstream (as of v2.6.34-rc3)
When used_dirs was introduced for the flex_groups struct, it looks
like the accounting was not put into place properly, in some places
manipulating free_inodes rather than used_dirs.
commit d330a5befb88875a9b3d2db62f9b74dadf660b13 upstream (as of v2.6.34-rc3)
http://bugzilla.kernel.org/show_bug.cgi?id=15420
commit c437b2733520599a2c6e0dbcdeae611319f84707 upstream (as of v2.6.33-git11)
a) Fix sparse warning in ext4_ioctl()
b) Remove unneeded variable in mext_leaf_block()
c) Fix spelling typo in mext_check_arguments()
Signed-off-by: Akira Fujita <a-fujita@rs.jp.nec.com>
commit 7247c0caa23d94a1cb6b307edba9dc45fb0798d4 upstream (as of v2.6.33-git11)
If EXT4_IOC_MOVE_EXT ioctl is called with NULL donor_fd, fget() in
ext4_ioctl() gets inappropriate file structure for donor; so we need
to do this check earlier, before calling double_down_write_data_sem().
commit 5fd5249aa36fad98c9fd5edced352939e54f9324 upstream (as of v2.6.33-git11)
If the leaf node has 2 extent space or fewer and EXT4_IOC_MOVE_EXT
ioctl is called with the file offset where after the 2nd extent
covers, mext_insert_across_blocks() always tries to insert extent into
the first extent. As a result, the file gets corrupted because of
wrong extent order. The patch fixes this problem.
commit b8b8afe236e97b6359d46d3a3f8c46455e192271 upstream (as of v2.6.33-git11)
The callers of ext4_check_dir_entry() usually pass in the "file
offset" (ext4_readdir, htree_dirblock_to_tree, search_dirblock,
ext4_dx_find_entry, empty_dir), but a few callers (add_dirent_to_buf,
ext4_delete_entry) only pass in the buffer offset.
To accomodate those last two (which would be hard to fix otherwise),
this patch changes ext4_check_dir_entry() to print the physical block
number and the relative offset as well as the passed-in offset.
Signed-off-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
commit 6e3617e579e070d3655a93ee9ed7149113e795e0 upstream (as of v2.6.33-git11)
In case of truncate errors we explicitly remove inode from in-core
orphan list via orphan_del(NULL, inode) without modifying the on-disk list.
But later on, the same inode may be inserted in the orphan list again
which will result the on-disk linked list getting corrupted. If inode
i_dtime contains valid value, then skip on-disk list modification.
commit da1dafca84413145f5ac59998b4cdd06fb89f721 upstream (as of v2.6.33-git11)
Otherwise non-empty orphan list will be triggered on umount.
commit f39490bcd1691d65dc33689222a12e1fc13dd824 upstream (as of v2.6.33-git11)
Set i_nlink to zero for temporary inode from very beginning.
otherwise we may fail to start new journal handle and this
inode will be unreferenced but with i_nlink == 1
Since we hold inode reference it can not be pruned.
Also add missed journal_start retval check.
commit cc483f102c3f703e853c96f95a654f0106fb2603 upstream (as of v2.6.33-git11)
The ext4 multiblock allocator decides whether to use group or file
preallocation based on the file size. When the file size reaches
s_mb_stream_request (default is 16 blocks), it changes to use a
file-specific preallocation. This is cool, but it has a tiny problem.
See a simple script:
mkfs.ext4 -b 1024 /dev/sda8 1000000
mount -t ext4 -o nodelalloc /dev/sda8 /mnt/ext4
for((i=0;i<5;i++))
do
cat /mnt/4096>>/mnt/ext4/a #4096 is a file with 4096 characters.
cat /mnt/4096>>/mnt/ext4/b
done
debuge4fs -R 'stat a' /dev/sda8|grep BLOCKS -A 1
And you get
BLOCKS:
(0-14):8705-8719, (15):2356, (16-19):8465-8468
So there are 3 extents, a bit strange for the lonely 15th logical
block. As we write to the 16 blocks, we choose file preallocation in
ext4_mb_group_or_file, but in ext4_mb_normalize_request, we meet with
the 16*1024 range, so no preallocation will be carried. file b then
reserves the space after '2356', so when when write 16, we start from
another part.
This patch just change the check in ext4_mb_group_or_file, so
that for the lonely 15 we will still use group preallocation.
After the patch, we will get:
BLOCKS:
(0-15):8705-8720, (16-19):8465-8468
Looks more sane. Thanks.
Signed-off-by: Tao Ma <tao.ma@oracle.com>
commit c8d46e41bc744c8fa0092112af3942fcd46c8b18 upstream (as of v2.6.33-git11)
fallocate() may potentially instantiate blocks past EOF, depending
on the flags used when it is called.
e2fsck currently has a test for blocks past i_size, and it
sometimes trips up - noticeably on xfstests 013 which runs fsstress.
This patch from Jiayang does fix it up - it (along with
e2fsprogs updates and other patches recently from Aneesh) has
survived many fsstress runs in a row.
Signed-off-by: Jiaying Zhang <jiayingz@google.com>
commit 73b50c1c92666d326b5fa2c945d46509f2f6d91f upstream (as of v2.6.33-git11)
Calls to ext4_handle_dirty_metadata should only pass in an inode
pointer for inode-specific metadata, and not for shared metadata
blocks such as inode table blocks, block group descriptors, the
superblock, etc.
The BUG_ON can get tripped when updating a special device (such as a
block device) that is opened (so that i_mapping is set in
fs/block_dev.c) and the file system is mounted in no journal mode.
Addresses-Google-Bug: #2404870
commit 19f5fb7ad679bb361222c7916086435020c37cce upstream (as of v2.6.33-git11)
At several places we modify EXT4_I(inode)->i_state without holding
i_mutex (ext4_release_file, ext4_bmap, ext4_journalled_writepage,
ext4_do_update_inode, ...). These modifications are racy and we can
lose updates to i_state. So convert handling of i_state to use bitops
which are atomic.
Cc: Jan Kara <jack@suse.cz>
commit 1296cc85c26e94eb865d03f82140f27d598de467 upstream (as of v2.6.33-rc6)
We should update reserve space if it is delalloc buffer
and that is indicated by EXT4_GET_BLOCKS_DELALLOC_RESERVE flag.
So use EXT4_GET_BLOCKS_DELALLOC_RESERVE in place of
EXT4_GET_BLOCKS_UPDATE_RESERVE_SPACE
[ Stable note: This fixes a corruption cuased by the following
reproduction case:
rm -f $TEST_FN
touch $TEST_FN
fallocate -n -o 656712 -l 858907 $TEST_FN
dd if=/dev/zero of=$TEST_FN conv=notrunc bs=1 seek=1011020 count=36983
sync
dd if=/dev/zero of=$TEST_FN conv=notrunc bs=1 seek=332121 count=24005
dd if=/dev/zero of=$TEST_FN conv=notrunc bs=1 seek=1040179 count=93319
If the filesystem is then unmounted and e2fsck run forced, the
i_blocks field for the file $TEST_FN will be found to be incorrect. ]
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit 5f634d064c709ea02c3cdaa850a08323a4a4bf28 upstream (as of v2.6.33-rc6)
When we fallocate a region of the file which we had recently written,
and which is still in the page cache marked as delayed allocated blocks
we need to make sure we don't do the quota update on writepage path.
This is because the needed quota updated would have already be done
by fallocate.
