path: root/fs
2010-09-20NFS: Fix a typo in nfs_sockaddr_match_ipaddr6Trond Myklebust
commit b20d37ca9561711c6a3c4b859c2855f49565e061 upstream. Reported-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20binfmt_misc: fix binfmt_misc priorityJan Sembera
commit ee3aebdd8f5f8eac41c25c80ceee3d728f920f3b upstream. Commit 74641f584da ("alpha: binfmt_aout fix") (May 2009) introduced a regression - binfmt_misc is now consulted after binfmt_elf, which will unfortunately break ia32el. ia32 ELF binaries on ia64 used to be matched using binfmt_misc and executed using wrapper. As 32bit binaries are now matched by binfmt_elf before bindmt_misc kicks in, the wrapper is ignored. The fix increases precedence of binfmt_misc to the original state. Signed-off-by: Jan Sembera <jsembera@suse.cz> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20sysfs: checking for NULL instead of ERR_PTRDan Carpenter
commit 57f9bdac2510cd7fda58e4a111d250861eb1ebeb upstream. d_path() returns an ERR_PTR and it doesn't return NULL. Signed-off-by: Dan Carpenter <error27@gmail.com> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20ocfs2: Fix incorrect checksum validation errorSunil Mushran
commit f5ce5a08a40f2086435858ddc80cb40394b082eb upstream. For local mounts, ocfs2_read_locked_inode() calls ocfs2_read_blocks_sync() to read the inode off the disk. The latter first checks to see if that block is cached in the journal, and, if so, returns that block. That is ok. But ocfs2_read_locked_inode() goes wrong when it tries to validate the checksum of such blocks. Blocks that are cached in the journal may not have had their checksum computed as yet. We should not validate the checksums of such blocks. Fixes ossbz#1282 http://oss.oracle.com/bugzilla/show_bug.cgi?id=1282 Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Singed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20fuse: flush background queue on connection closeMiklos Szeredi
commit 595afaf9e6ee1b48e13ec4b8bcc8c7dee888161a upstream. David Bartly reported that fuse can hang in fuse_get_req_nofail() when the connection to the filesystem server is no longer active. If bg_queue is not empty then flush_bg_queue() called from request_end() can put more requests on to the pending queue. If this happens while ending requests on the processing queue then those background requests will be queued to the pending list and never ended. Another problem is that fuse_dev_release() didn't wake up processes sleeping on blocked_waitq. Solve this by: a) flushing the background queue before calling end_requests() on the pending and processing queues b) setting blocked = 0 and waking up processes waiting on blocked_waitq() Thanks to David for an excellent bug report. Reported-by: David Bartley <andareed@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26ext4: consolidate in_range() definitionsAkinobu Mita
commit 731eb1a03a8445cde2cb23ecfb3580c6fa7bb690 upstream. There are duplicate macro definitions of in_range() in mballoc.h and balloc.c. This consolidates these two definitions into ext4.h, and changes extents.c to use in_range() as well. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger@sun.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26nfs: Add "lookupcache" to displayed mount optionsPatrick J. LoPresti
commit 9b00c64318cc337846a7a08a5678f5f19aeff188 upstream. Running "cat /proc/mounts" fails to display the "lookupcache" option. This oversight cost me a bunch of wasted time recently. The following simple patch fixes it. Signed-off-by: Patrick LoPresti <lopresti@gmail.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26Fix the nested PR lock calling issue in ACLJiaju Zhang
commit 845b6cf34150100deb5f58c8a37a372b111f2918 upstream. Hi, Thanks a lot for all the review and comments so far;) I'd like to send the improved (V4) version of this patch. This patch fixes a deadlock in OCFS2 ACL. We found this bug in OCFS2 and Samba integration using scenario, the symptom is several smbd processes will be hung under heavy workload. Finally we found out it is the nested PR lock calling that leads to this deadlock: node1 node2 gr PR | V PR(EX)---> BAST:OCFS2_LOCK_BLOCKED | V rq PR | V wait=1 After requesting the 2nd PR lock, the process "smbd" went into D state. It can only be woken up when the 1st PR lock's RO holder equals zero. There should be an ocfs2_inode_unlock in the calling path later on, which can decrement the RO holder. But since it has been in uninterruptible sleep, the unlock function has no chance to be called. The related stack trace is: smbd D ffff8800013d0600 0 9522 5608 0x00000000 ffff88002ca7fb18 0000000000000282 ffff88002f964500 ffff88002ca7fa98 ffff8800013d0600 ffff88002ca7fae0 ffff88002f964340 ffff88002f964340 ffff88002ca7ffd8 ffff88002ca7ffd8 ffff88002f964340 ffff88002f964340 Call Trace: [<ffffffff80350425>] schedule_timeout+0x175/0x210 [<ffffffff8034f580>] wait_for_common+0xf0/0x210 [<ffffffffa03e12b9>] __ocfs2_cluster_lock+0x3b9/0xa90 [ocfs2] [<ffffffffa03e7665>] ocfs2_inode_lock_full_nested+0x255/0xdb0 [ocfs2] [<ffffffffa0446019>] ocfs2_get_acl+0x69/0x120 [ocfs2] [<ffffffffa0446368>] ocfs2_check_acl+0x28/0x80 [ocfs2] [<ffffffff800e3507>] acl_permission_check+0x57/0xb0 [<ffffffff800e357d>] generic_permission+0x1d/0xc0 [<ffffffffa03eecea>] ocfs2_permission+0x10a/0x1d0 [ocfs2] [<ffffffff800e3f65>] inode_permission+0x45/0x100 [<ffffffff800d86b3>] sys_chdir+0x53/0x90 [<ffffffff80007458>] system_call_fastpath+0x16/0x1b [<00007f34a4ef6927>] 0x7f34a4ef6927 For details, please see: https://bugzilla.novell.com/show_bug.cgi?id=614332 and http://oss.oracle.com/bugzilla/show_bug.cgi?id=1278 Signed-off-by: Jiaju Zhang <jjzhang@suse.de> Acked-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26ocfs2/dlm: remove potential deadlock -V3Wengang Wang
commit b11f1f1ab73fd358b1b734a9427744802202ba68 upstream. When we need to take both dlm_domain_lock and dlm->spinlock, we should take them in order of: dlm_domain_lock then dlm->spinlock. There is pathes disobey this order. That is calling dlm_lockres_put() with dlm->spinlock held in dlm_run_purge_list. dlm_lockres_put() calls dlm_put() at the ref and dlm_put() locks on dlm_domain_lock. Fix: Don't grab/put the dlm when the initialising/releasing lockres. That grab is not required because we don't call dlm_unregister_domain() based on refcount. Signed-off-by: Wengang Wang <wen.gang.wang@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26ocfs2/dlm: avoid incorrect bit set in refmap on recovery masterWengang Wang
commit a524812b7eaa7783d7811198921100f079034e61 upstream. In the following situation, there remains an incorrect bit in refmap on the recovery master. Finally the recovery master will fail at purging the lockres due to the incorrect bit in refmap. 1) node A has no interest on lockres A any longer, so it is purging it. 2) the owner of lockres A is node B, so node A is sending de-ref message to node B. 3) at this time, node B crashed. node C becomes the recovery master. it recovers lockres A(because the master is the dead node B). 4) node A migrated lockres A to node C with a refbit there. 5) node A failed to send de-ref message to node B because it crashed. The failure is ignored. no other action is done for lockres A any more. For mormal, re-send the deref message to it to recovery master can fix it. Well, ignoring the failure of deref to the original master and not recovering the lockres to recovery master has the same effect. And the later is simpler. Signed-off-by: Wengang Wang <wen.gang.wang@oracle.com> Acked-by: Srinivas Eeda <srinivas.eeda@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26ocfs2: Count more refcount records in file system fragmentation.Tao Ma
commit 8a2e70c40ff58f82dde67770e6623ca45f0cb0c8 upstream. The refcount record calculation in ocfs2_calc_refcount_meta_credits is too optimistic that we can always allocate contiguous clusters and handle an already existed refcount rec as a whole. Actually because of file system fragmentation, we may have the chance to split a refcount record into 3 parts during the transaction. So consider the worst case in record calculation. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26ocfs2 fix o2dlm dlm run purgelist (rev 3)Srinivas Eeda
commit 7beaf243787f85a2ef9213ccf13ab4a243283fde upstream. This patch fixes two problems in dlm_run_purgelist 1. If a lockres is found to be in use, dlm_run_purgelist keeps trying to purge the same lockres instead of trying the next lockres. 2. When a lockres is found unused, dlm_run_purgelist releases lockres spinlock before setting DLM_LOCK_RES_DROPPING_REF and calls dlm_purge_lockres. spinlock is reacquired but in this window lockres can get reused. This leads to BUG. This patch modifies dlm_run_purgelist to skip lockres if it's in use and purge next lockres. It also sets DLM_LOCK_RES_DROPPING_REF before releasing the lockres spinlock protecting it from getting reused. Signed-off-by: Srinivas Eeda <srinivas.eeda@oracle.com> Acked-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26ocfs2/dlm: fix a dead lockWengang Wang
commit 6d98c3ccb52f692f1a60339dde7c700686a5568b upstream. When we have to take both dlm->master_lock and lockres->spinlock, take them in order lockres->spinlock and then dlm->master_lock. The patch fixes a violation of the rule. We can simply move taking dlm->master_lock to where we have dropped res->spinlock since when we access res->state and free mle memory we don't need master_lock's protection. Signed-off-by: Wengang Wang <wen.gang.wang@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26ocfs2: do not overwrite error codes in ocfs2_init_aclTiger Yang
commit 6eda3dd33f8a0ce58ee56a11351758643a698db4 upstream. Setting the acl while creating a new inode depends on the error codes of posix_acl_create_masq. This patch fix a issue of overwriting the error codes of it. Reported-by: Pawel Zawora <pzawora@gmail.com> Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-20mm: fix up some user-visible effects of the stack guard pageLinus Torvalds
commit d7824370e26325c881b665350ce64fb0a4fde24a upstream. This commit makes the stack guard page somewhat less visible to user space. It does this by: - not showing the guard page in /proc/<pid>/maps It looks like lvm-tools will actually read /proc/self/maps to figure out where all its mappings are, and effectively do a specialized "mlockall()" in user space. By not showing the guard page as part of the mapping (by just adding PAGE_SIZE to the start for grows-up pages), lvm-tools ends up not being aware of it. - by also teaching the _real_ mlock() functionality not to try to lock the guard page. That would just expand the mapping down to create a new guard page, so there really is no point in trying to lock it in place. It would perhaps be nice to show the guard page specially in /proc/<pid>/maps (or at least mark grow-down segments some way), but let's not open ourselves up to more breakage by user space from programs that depends on the exact deails of the 'maps' file. Special thanks to Henrique de Moraes Holschuh for diving into lvm-tools source code to see what was going on with the whole new warning. Reported-and-tested-by: François Valenduc <francois.valenduc@tvcablenet.be Reported-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Skip check for mandatory locks when unlockingSachin Prabhu
commit ee860b6a650360c91f5d5f9a94262aad9be90015 upstream. ocfs2_lock() will skip locks on file which has mode set to 02666. This is a problem in cases where the mode of the file is changed after a process has obtained a lock on the file. ocfs2_lock() should skip the check for mandatory locks when unlocking a file. Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13ocfs2: Set MS_POSIXACL on remountJan Kara
commit 57b09bb5e492c37c1e4273fe4e435ffd1d2ddbe0 upstream. We have to set MS_POSIXACL on remount as well. Otherwise VFS would not know we started supporting ACLs after remount and thus ACLs would not work. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13ocfs2: Find proper end cpos for a leaf refcount block.Tao Ma
commit 38a04e432768ec0b016f3c687b4de31ac111ae59 upstream. ocfs2 refcount tree is stored as an extent tree while the leaf ocfs2_refcount_rec points to a refcount block. The following step can trip a kernel panic. mkfs.ocfs2 -b 512 -C 1M --fs-features=refcount $DEVICE mount -t ocfs2 $DEVICE $MNT_DIR FILE_NAME=$RANDOM FILE_NAME_1=$RANDOM FILE_REF="${FILE_NAME}_ref" FILE_REF_1="${FILE_NAME}_ref_1" for((i=0;i<305;i++)) do # /mnt/1048576 is a file with 1048576 sizes. cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME_1 done for((i=0;i<3;i++)) do cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME done for((i=0;i<2;i++)) do cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME_1 done cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME for((i=0;i<11;i++)) do cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME_1 done reflink $MNT_DIR/$FILE_NAME $MNT_DIR/$FILE_REF # write_f is a program which will write some bytes to a file at offset. # write_f -f file_name -l offset -w write_bytes. ./write_f -f $MNT_DIR/$FILE_REF -l $[310*1048576] -w 4096 ./write_f -f $MNT_DIR/$FILE_REF -l $[306*1048576] -w 4096 ./write_f -f $MNT_DIR/$FILE_REF -l $[311*1048576] -w 4096 ./write_f -f $MNT_DIR/$FILE_NAME -l $[310*1048576] -w 4096 ./write_f -f $MNT_DIR/$FILE_NAME -l $[311*1048576] -w 4096 reflink $MNT_DIR/$FILE_NAME $MNT_DIR/$FILE_REF_1 ./write_f -f $MNT_DIR/$FILE_NAME -l $[311*1048576] -w 4096 #kernel panic here. The reason is that if the ocfs2_extent_rec is the last record in a leaf extent block, the old solution fails to find the suitable end cpos. So this patch try to walk through the b-tree, find the next sub root and get the c_pos the next sub-tree starts from. btw, I have runned tristan's test case against the patched kernel for several days and this type of kernel panic never happens again. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13dlm: send reply before bastDavid Teigland
commit cf6620acc0f6fac57968aafef79ab372bdcf6157 upstream. When the lock master processes a successful operation (request, convert, cancel, or unlock), it will process the effects of the change before sending the reply for the operation. The "effects" of the operation are: - blocking callbacks (basts) for any newly granted locks - waiting or converting locks that can now be granted The cast is queued on the local node when the reply from the lock master is received. This means that a lock holder can receive a bast for a lock mode that is doesn't yet know has been granted. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13dlm: fix ordering of bast and castDavid Teigland
commit 7fe2b3190b8b299409f13cf3a6f85c2bd371f8bb upstream. When both blocking and completion callbacks are queued for lock, the dlm would always deliver the completion callback (cast) first. In some cases the blocking callback (bast) is queued before the cast, though, and should be delivered first. This patch keeps track of the order in which they were queued and delivers them in that order. This patch also keeps track of the granted mode in the last cast and eliminates the following bast if the bast mode is compatible with the preceding cast mode. This happens when a remotely mastered lock is demoted, e.g. EX->NL, in which case the local node queues a cast immediately after sending the demote message. In this way a cast can be queued for a mode, e.g. NL, that makes an in-transit bast extraneous. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13dlm: always use GFP_NOFSDavid Teigland
commit 573c24c4af6664ffcd9aa7ba617a35fde2b95534 upstream. Replace all GFP_KERNEL and ls_allocation with GFP_NOFS. ls_allocation would be GFP_KERNEL for userland lockspaces and GFP_NOFS for file system lockspaces. It was discovered that any lockspaces on the system can affect all others by triggering memory reclaim in the file system which could in turn call back into the dlm to acquire locks, deadlocking dlm threads that were shared by all lockspaces, like dlm_recv. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13reiserfs: fix oops while creating privroot with selinux enabledJeff Mahoney
commit 6cb4aff0a77cc0e6bae9475d62205319e3ebbf3f upstream. Commit 57fe60df ("reiserfs: add atomic addition of selinux attributes during inode creation") contains a bug that will cause it to oops when mounting a file system that didn't previously contain extended attributes on a system using security.* xattrs. The issue is that while creating the privroot during mount reiserfs_security_init calls reiserfs_xattr_jcreate_nblocks which dereferences the xattr root. The xattr root doesn't exist, so we get an oops. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=15309 Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13reiserfs: properly honor read-only devicesJeff Mahoney
commit 3f8b5ee33293d43ca360771b535dfae8c57259dc upstream. The reiserfs journal behaves inconsistently when determining whether to allow a mount of a read-only device. This is due to the use of the continue_replay variable to short circuit the journal scanning. If it's set, it's assumed that there are transactions to replay, but there may not be. If it's unset, it's assumed that there aren't any, and that may not be the case either. I've observed two failure cases: 1) Where a clean file system on a read-only device refuses to mount 2) Where a clean file system on a read-only device passes the optimization and then tries writing the journal header to update the latest mount id. The former is easily observable by using a freshly created file system on a read-only loopback device. This patch moves the check into journal_read_transaction, where it can bail out before it's about to replay a transaction. That way it can go through and skip transactions where appropriate, yet still refuse to mount a file system with outstanding transactions. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13ext4: Fix optional-arg mount optionsEric Sandeen
commit 15121c18a22ae483279f76dc9e554334b800d0f7 upstream. We have 2 mount options, "barrier" and "auto_da_alloc" which may or may not take a 1/0 argument. This causes the ext4 superblock mount code to subtract uninitialized pointers and pass the result to kmalloc, which results in very noisy failures. Per Ted's suggestion, initialize the args struct so that we know whether match_token() found an argument for the option, and skip match_int() if not. Also, return error (0) from parse_options if we thought we found an argument, but match_int() Fails. Reported-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13ext4: Make sure the MOVE_EXT ioctl can't overwrite append-only filesTheodore Ts'o
commit 1f5a81e41f8b1a782c68d3843e9ec1bfaadf7d72 upstream. Dan Roseberg has reported a problem with the MOVE_EXT ioctl. If the donor file is an append-only file, we should not allow the operation to proceed, lest we end up overwriting the contents of an append-only file. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Dan Rosenberg <dan.j.rosenberg@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13sched, cputime: Introduce thread_group_times()Hidetoshi Seto
commit 0cf55e1ec08bb5a22e068309e2d8ba1180ab4239 upstream. This is a real fix for problem of utime/stime values decreasing described in the thread: http://lkml.org/lkml/2009/11/3/522 Now cputime is accounted in the following way: - {u,s}time in task_struct are increased every time when the thread is interrupted by a tick (timer interrupt). - When a thread exits, its {u,s}time are added to signal->{u,s}time, after adjusted by task_times(). - When all threads in a thread_group exits, accumulated {u,s}time (and also c{u,s}time) in signal struct are added to c{u,s}time in signal struct of the group's parent. So {u,s}time in task struct are "raw" tick count, while {u,s}time and c{u,s}time in signal struct are "adjusted" values. And accounted values are used by: - task_times(), to get cputime of a thread: This function returns adjusted values that originates from raw {u,s}time and scaled by sum_exec_runtime that accounted by CFS. - thread_group_cputime(), to get cputime of a thread group: This function returns sum of all {u,s}time of living threads in the group, plus {u,s}time in the signal struct that is sum of adjusted cputimes of all exited threads belonged to the group. The problem is the return value of thread_group_cputime(), because it is mixed sum of "raw" value and "adjusted" value: group's {u,s}time = foreach(thread){{u,s}time} + exited({u,s}time) This misbehavior can break {u,s}time monotonicity. Assume that if there is a thread that have raw values greater than adjusted values (e.g. interrupted by 1000Hz ticks 50 times but only runs 45ms) and if it exits, cputime will decrease (e.g. -5ms). To fix this, we could do: group's {u,s}time = foreach(t){task_times(t)} + exited({u,s}time) But task_times() contains hard divisions, so applying it for every thread should be avoided. This patch fixes the above problem in the following way: - Modify thread's exit (= __exit_signal()) not to use task_times(). It means {u,s}time in signal struct accumulates raw values instead of adjusted values. As the result it makes thread_group_cputime() to return pure sum of "raw" values. - Introduce a new function thread_group_times(*task, *utime, *stime) that converts "raw" values of thread_group_cputime() to "adjusted" values, in same calculation procedure as task_times(). - Modify group's exit (= wait_task_zombie()) to use this introduced thread_group_times(). It make c{u,s}time in signal struct to have adjusted values like before this patch. - Replace some thread_group_cputime() by thread_group_times(). This replacements are only applied where conveys the "adjusted" cputime to users, and where already uses task_times() near by it. (i.e. sys_times(), getrusage(), and /proc/<PID>/stat.) This patch have a positive side effect: - Before this patch, if a group contains many short-life threads (e.g. runs 0.9ms and not interrupted by ticks), the group's cputime could be invisible since thread's cputime was accumulated after adjusted: imagine adjustment function as adj(ticks, runtime), {adj(0, 0.9) + adj(0, 0.9) + ....} = {0 + 0 + ....} = 0. After this patch it will not happen because the adjustment is applied after accumulated. v2: - remove if()s, put new variables into signal_struct. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Spencer Candland <spencer@bluehost.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> LKML-Reference: <4B162517.8040909@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: kfree correct pointer during mount option parsingJosef Bacik
commit da495ecc0fb096b383754952a1c152147bc95b52 upstream. We kstrdup the options string, but then strsep screws with the pointer, so when we kfree() it, we're not giving it the right pointer. Tested-by: Andy Lutomirski <luto@mit.edu> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: btrfs_mark_extent_written uses the wrong slotShaohua Li
commit 3f6fae9559225741c91f1320090b285da1413290 upstream. My test do: fallocate a big file and do write. The file is 512M, but after file write is done btrfs-debug-tree shows: item 6 key (257 EXTENT_DATA 0) itemoff 3516 itemsize 53 extent data disk byte 1103101952 nr 536870912 extent data offset 0 nr 399634432 ram 536870912 extent compression 0 Looks like a regression introducted by 6c7d54ac87f338c479d9729e8392eca3f76e11e1, where we set wrong slot. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: apply updated fallocate i_size fixAneesh Kumar K.V
commit 23b5c50945f2294add0137799400329c0ebba290 upstream. This version of the i_size fix for fallocate makes sure we only update the i_size when the current fallocate is really operating outside of i_size. Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: do not try and lookup the file extent when finishing ordered ioJosef Bacik
commit efd049fb26a162c3830fd3cb1001fdc09b147f3b upstream. When running the following fio job [torrent] filename=torrent-test rw=randwrite size=4g filesize=4g bs=4k ioengine=sync you would see long stalls where no work was being done. That is because we were doing all this extra work to read in the file extent outside of the transaction, however in the random io case this ends up hurting us because the file extents are not there to begin with. So axe this logic, since we end up reading in the file extent when we go to update it anyway. This took the fio job from 11 mb/s with several ~10 second stalls to 24 mb/s to a couple of 1-2 second stalls. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: Fix oopsen when dropping empty tree.Yan, Zheng
commit 7a7965f83e89f0be506a96769938a721e4e5ae50 upstream. When dropping a empty tree, walk_down_tree() skips checking extent information for the tree root. This will triggers a BUG_ON in walk_up_proc(). Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: remove BUG_ON() due to mounting bad filesystemMiao Xie
commit d7ce5843bb28ada6845ab2ae8510ba3f12d33154 upstream. Mounting a bad filesystem caused a BUG_ON(). The following is steps to reproduce it. # mkfs.btrfs /dev/sda2 # mount /dev/sda2 /mnt # mkfs.btrfs /dev/sda1 /dev/sda2 (the program says that /dev/sda2 was mounted, and then exits. ) # umount /mnt # mount /dev/sda1 /mnt At the third step, mkfs.btrfs exited in the way of make filesystem. So the initialization of the filesystem didn't finish. So the filesystem was bad, and it caused BUG_ON() when mounting it. But BUG_ON() should be called by the wrong code, not user's operation, so I think it is a bug of btrfs. This patch fixes it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: make error return negative in btrfs_sync_file()Roel Kluin
commit 014e4ac4f7d9c981750491fa40ea35efadc9ed49 upstream. It appears the error return should be negative Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: fix race between allocate and release extent buffer.Yan, Zheng
commit f044ba7835b84e69c68b620ca8fa27e5ef67759d upstream. Increase extent buffer's reference count while holding the lock. Otherwise it can race with try_release_extent_buffer. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: check total number of devices when removing missingJosef Bacik
commit 035fe03a7ad56982b30ab3a522b7b08d58feccd0 upstream. If you have a disk failure in RAID1 and then add a new disk to the array, and then try to remove the missing volume, it will fail. The reason is the sanity check only looks at the total number of rw devices, which is just 2 because we have 2 good disks and 1 bad one. Instead check the total number of devices in the array to make sure we can actually remove the device. Tested this with a failed disk setup and with this test we can now run btrfs-vol -r missing /mount/point and it works fine. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: check return value of open_bdev_exclusive properlyJosef Bacik
commit 7f59203abeaf18bf3497b308891f95a4489810ad upstream. Hit this problem while testing RAID1 failure stuff. open_bdev_exclusive returns ERR_PTR(), not NULL. So change the return value properly. This is important if you accidently specify a device that doesn't exist when trying to add a new device to an array, you will panic the box dereferencing bdev. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: do not mark the chunk as readonly if in degraded modeJosef Bacik
commit f48b90756bd834dda852ff514f2690d3175b1f44 upstream. If a RAID setup has chunks that span multiple disks, and one of those disks has failed, btrfs_chunk_readonly will return 1 since one of the disks in that chunk's stripes is dead and therefore not writeable. So instead if we are in degraded mode, return 0 so we can go ahead and allocate stuff. Without this patch all of the block groups in a RAID1 setup will end up read-only, which will mean we can't add new disks to the array since we won't be able to make allocations. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: run orphan cleanup on default fs rootJosef Bacik
commit e3acc2a6850efff647f1c5458524eb3a8bcba20a upstream. This patch revert's commit 6c090a11e1c403b727a6a8eff0b97d5fb9e95cb5 Since it introduces this problem where we can run orphan cleanup on a volume that can have orphan entries re-added. Instead of my original fix, Yan Zheng pointed out that we can just revert my original fix and then run the orphan cleanup in open_ctree after we look up the fs_root. I have tested this with all the tests that gave me problems and this patch fixes both problems. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: fix a memory leak in btrfs_init_aclYang Hongyang
commit f858153c367a397235d3e81136741e40e44faf1d upstream. In btrfs_init_acl() cloned acl is not released Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: Use correct values when updating inode i_size on fallocateAneesh Kumar K.V
commit d1ea6a61454e7d7ff0873d0ad1ae27d5807da0d3 upstream. commit f2bc9dd07e3424c4ec5f3949961fe053d47bc825 Author: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Date: Wed Jan 20 12:57:53 2010 +0530 Btrfs: Use correct values when updating inode i_size on fallocate Even though we allocate more, we should be updating inode i_size as per the arguments passed Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: fix possible panic on unmountJosef Bacik
commit 11dfe35a0108097f2df1f042c485fa7f758c2cdf upstream. We can race with the unmount of an fs and the stopping of a kthread where we will free the block group before we're done using it. The reason for this is because we do not hold a reference on the block group while its caching, since the allocator drops its reference once it exits or moves on to the next block group. This patch fixes the problem by taking a reference to the block group before we start caching and dropping it when we're done to make sure all accesses to the block group are safe. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: deal with NULL acl sent to btrfs_set_aclChris Mason
commit a9cc71a60c29a09174bee2fcef8f924c529fd4b7 upstream. It is legal for btrfs_set_acl to be sent a NULL acl. This makes sure we don't dereference it. A similar patch was sent by Johannes Hirte <johannes.hirte@fem.tu-ilmenau.de> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: fix regression in orphan cleanupJosef Bacik
commit 6c090a11e1c403b727a6a8eff0b97d5fb9e95cb5 upstream. Currently orphan cleanup only ever gets triggered if we cross subvolumes during a lookup, which means that if we just mount a plain jane fs that has orphans in it, they will never get cleaned up. This results in panic's like these http://www.kerneloops.org/oops.php?number=1109085 where adding an orphan entry results in -EEXIST being returned and we panic. In order to fix this, we check to see on lookup if our root has had the orphan cleanup done, and if not go ahead and do it. This is easily reproduceable by running this testcase #include <sys/types.h> #include <sys/stat.h> #include <fcntl.h> #include <string.h> #include <unistd.h> #include <stdio.h> int main(int argc, char **argv) { char data[4096]; char newdata[4096]; int fd1, fd2; memset(data, 'a', 4096); memset(newdata, 'b', 4096); while (1) { int i; fd1 = creat("file1", 0666); if (fd1 < 0) break; for (i = 0; i < 512; i++) write(fd1, data, 4096); fsync(fd1); close(fd1); fd2 = creat("file2", 0666); if (fd2 < 0) break; ftruncate(fd2, 4096 * 512); for (i = 0; i < 512; i++) write(fd2, newdata, 4096); close(fd2); i = rename("file2", "file1"); unlink("file1"); } return 0; } and then pulling the power on the box, and then trying to run that test again when the box comes back up. I've tested this locally and it fixes the problem. Thanks to Tomas Carnecky for helping me track this down initially. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: Fix race in btrfs_mark_extent_writtenYan, Zheng
commit 6c7d54ac87f338c479d9729e8392eca3f76e11e1 upstream. Fix bug reported by Johannes Hirte. The reason of that bug is btrfs_del_items is called after btrfs_duplicate_item and btrfs_del_items triggers tree balance. The fix is check that case and call btrfs_search_slot when needed. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs, fix memory leaks in error pathsJiri Slaby
commit 2423fdfb96e3f9ff3baeb6c4c78d74145547891d upstream. Stanse found 2 memory leaks in relocate_block_group and __btrfs_map_block. cluster and multi are not freed/assigned on all paths. Fix that. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: linux-btrfs@vger.kernel.org Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: align offsets for btrfs_ordered_update_i_sizeYan, Zheng
commit a038fab0cb873c75d6675e2bcffce8a3935bdce7 upstream. Some callers of btrfs_ordered_update_i_size can now pass in a NULL for the ordered extent to update against. This makes sure we properly align the offset they pass in when deciding how much to bump the on disk i_size. Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13btrfs: fix missing last-entry in readdir(3)Jan Engelhardt
commit 406266ab9ac8ed8b085c58aacd9e3161480dc5d5 upstream. parent 49313cdac7b34c9f7ecbb1780cfc648b1c082cd7 (v2.6.32-1-g49313cd) commit ff48c08e1c05c67e8348ab6f8a24de8034e0e34d Author: Jan Engelhardt <jengelh@medozas.de> Date: Wed Dec 9 22:57:36 2009 +0100 Btrfs: fix missing last-entry in readdir(3) When one does a 32-bit readdir(3), the last entry of a directory is missing. This is however not due to passing a large value to filldir, but it seems to have to do with glibc doing telldir or something quirky. In any case, this patch fixes it in practice. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: make sure fallocate properly starts a transactionChris Mason
commit 3a1abec9f6880cf406593c392636199ea1c6c917 upstream. The recent patch to make fallocate enospc friendly would send down a NULL trans handle to the allocator. This moves the transaction start to properly fix things. Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: make metadata chunks smallerJosef Bacik
commit 83d3c9696fed237a3d96fce18299e2fcf112109f upstream. This patch makes us a bit less zealous about making sure we have enough free metadata space by pearing down the size of new metadata chunks to 256mb instead of 1gb. Also, we used to try an allocate metadata chunks when allocating data, but that sort of thing is done elsewhere now so we can just remove it. With my -ENOSPC test I used to have 3gb reserved for metadata out of 75gb, now I have 1.7gb. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13Btrfs: Show discard option in /proc/mountsMatthew Wilcox
commit 20a5239a5d0f340e29827a6a2d28a138001c44b8 upstream. Christoph's patch e244a0aeb6a599c19a7c802cda6e2d67c847b154 doesn't display the discard option in /proc/mounts, leading to some confusion for me. Here's the missing bit. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
