commit 0b760113a3a155269a3fba93a409c640031dd68f upstream.
If the NLM daemon is killed on the NFS server, we can currently end up
hanging forever on an 'unlock' request, instead of aborting. Basically,
if the rpcbind request fails, or the server keeps returning garbage, we
really want to quit instead of retrying.
Tested-by: Vasily Averin <vvs@sw.ru>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit c902ce1bfb40d8b049bd2319b388b4b68b04bc27 upstream.
Add an FS-Cache helper to bulk uncache pages on an inode. This will
only work for the circumstance where the pages in the cache correspond
1:1 with the pages attached to an inode's page cache.
This is required for CIFS and NFS: When disabling inode cookie, we were
returning the cookie and setting cifsi->fscache to NULL but failed to
invalidate any previously mapped pages. This resulted in "Bad page
state" errors and manifested in other kind of errors when running
fsstress. Fix it by uncaching mapped pages when we disable the inode
cookie.
This patch should fix the following oops and "Bad page state" errors
seen during fsstress testing.
kernel BUG at fs/cachefiles/namei.c:201!
invalid opcode: 0000 [#1] SMP
Pid: 5, comm: kworker/u:0 Not tainted 2.6.38.7-30.fc15.x86_64 #1 Bochs Bochs
RIP: 0010: cachefiles_walk_to_object+0x436/0x745 [cachefiles]
RSP: 0018:ffff88002ce6dd00 EFLAGS: 00010282
RAX: ffff88002ef165f0 RBX: ffff88001811f500 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000100 RDI: 0000000000000282
RBP: ffff88002ce6dda0 R08: 0000000000000100 R09: ffffffff81b3a300
R10: 0000ffff00066c0a R11: 0000000000000003 R12: ffff88002ae54840
R13: ffff88002ae54840 R14: ffff880029c29c00 R15: ffff88001811f4b0
FS: 00007f394dd32720(0000) GS:ffff88002ef00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00007fffcb62ddf8 CR3: 000000001825f000 CR4: 00000000000006e0
Process kworker/u:0 (pid: 5, threadinfo ffff88002ce6c000, task ffff88002ce55cc0)
Stack:
0000000000000246 ffff88002ce55cc0 ffff88002ce6dd58 ffff88001815dc00
ffff8800185246c0 ffff88001811f618 ffff880029c29d18 ffff88001811f380
ffff88002ce6dd50 ffffffff814757e4 ffff88002ce6dda0 ffffffff8106ac56
Call Trace:
cachefiles_lookup_object+0x78/0xd4 [cachefiles]
fscache_lookup_object+0x131/0x16d [fscache]
fscache_object_work_func+0x1bc/0x669 [fscache]
process_one_work+0x186/0x298
worker_thread+0xda/0x15d
kthread+0x84/0x8c
kernel_thread_helper+0x4/0x10
RIP cachefiles_walk_to_object+0x436/0x745 [cachefiles]
---[ end trace 1d481c9af1804caa ]---
I tested the uncaching by the following means:
(1) Create a big file on my NFS server (104857600 bytes).
(2) Read the file into the cache with md5sum on the NFS client. Look in
/proc/fs/fscache/stats:
Pages : mrk=25601 unc=0
(3) Open the file for read/write ("bash 5<>/warthog/bigfile"). Look in proc
again:
Pages : mrk=25601 unc=25601
Reported-by: Jeff Layton <jlayton@redhat.com>
Reviewed-and-Tested-by: Suresh Jayaraman <sjayaraman@suse.de>
commit a51cb91d81f8e6fc4e5e08b772cc3ceb13ac9d37 upstream.
locks_alloc_lock() assumed that the allocated struct file_lock is
already initialized to zero members. This is only true for the first
allocation of the structure, after reuse some of the members will have
random values.
This will for example result in passing random fl_start values to
userspace in fuse for FL_FLOCK locks, which is an information leak at
best.
Fix by reinitializing those members which may be non-zero after freeing.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 50176ddefa4a942419cb693dd2d8345bfdcde67c upstream.
hfsplus leaks bio objects by failing to call bio_put() on the bios
it allocates. Add the missing call to fix the leak.
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
commit d4c208b86b8be4254eba0e74071496e599f94639 upstream.
6b4517a791 (block: implement bd_claiming and claiming block)
introduced claiming block to support O_EXCL blkdev opens properly.
bd_start_claiming() looks up the part 0 bdev and starts claiming
block. The function assumed that there is only one part 0 bdev and
always used bdget_disk(disk, 0) to look it up; unfortunately, this
isn't true for some drivers (floppy) which use multiple block devices
to denote different operating parameters for the same physical device.
There can be multiple part 0 bdev's for the same device number.
This incorrect assumption caused the wrong bdev to be used during
claiming leading to unbalanced bd_holders as reported in the following
bug.
https://bugzilla.kernel.org/show_bug.cgi?id=28522
This patch updates bd_start_claiming() such that it uses the bdev
specified as argument if its partno is zero.
Note that this means that different bdev's can be used for the same
device and O_EXCL check can be effectively bypassed. It has always
been broken that way and floppy is fortunately on its way out. Leave
that breakage alone.
Reported-by: Alex Villacis Lasso <avillaci@ceibo.fiec.espol.edu.ec>
Tested-by: Alex Villacis Lasso <avillaci@ceibo.fiec.espol.edu.ec>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit ee7b75fc4f3ae49e1f25bf56219bb5de3c29afaf upstream.
Commit 7ebb9315 (NFS: use secinfo when crossing mountpoints) introduces
a regression when decoding an NFSv4 readdir entry that sets the
rdattr_error field.
By treating the resulting value as if it is a decoding error, the current
code may cause us to skip valid readdir entries.
Reported-by: Andy Adamson <andros@netapp.com>
commit cec765cf5891c7fc3d905832b481bfb6fd55825d upstream.
Signed-off-by: Andy Adamson <andros@netapp.com>
commit 533eb4611c9eea53072eb6a61d5a6393b6a77ed7 upstream.
Commit 28331a46d88459788c8fca72dbb0415cd7f514c9 "Ensure we request the
ordinary fileid when doing readdirplus"
changed the meaning of NFS_ATTR_FATTR_FILEID which used to be set when
FATTR4_WORD1_MOUNTED_ON_FILED was requested.
Allow nfs_fhget to succeed with only a mounted on fileid when crossing
a mountpoint or a referral.
Ask for the fileid of the absent file system if mounted_on_fileid is not
supported.
commit 105f4622104848ff1ee1f644d661bef9dec3eb27 upstream.
Thanks to Casey Bodley for pointing out that on a read open we pass 0,
instead of O_RDONLY, to break_lease, with the result that a read open is
treated like a write open for the purposes of lease breaking!
Reported-by: Casey Bodley <cbodley@citi.umich.edu>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 7d751f6f8c679f51b73d01a1b5269347a929004c upstream.
fix for commit 4795bb37effb7b8fe77e2d2034545d062d3788a8, nfsd: break
lease on unlink, link, and rename
if the LINK operation breaks a delegation, it returns NFS4ERR_NOENT
(which is not a valid error in rfc 5661) instead of NFS4ERR_DELAY.
the return value of nfsd_break_lease() in nfsd_link() must be
converted from host_err to err
Signed-off-by: Casey Bodley <cbodley@citi.umich.edu>
commit b084f598df36b62dfae83c10ed17f0b66b50f442 upstream.
Commit b0b0c0a26e84 "nfsd: add proc file listing kernel's gss_krb5
enctypes" added an nunnecessary dependency of nfsd on the auth_rpcgss
module.
It's a little ad hoc, but since the only piece of information nfsd needs
from rpcsec_gss_krb5 is a single static string, one solution is just to
share it with an include file.
Reported-by: Michael Guntsche <mike@it-loops.com>
Cc: Kevin Coffman <kwc@citi.umich.edu>
commit be1f4084b4824301e640e81d63b6275cd99ee6a1 upstream.
nfsd V4 support uses crypto interfaces, so select CRYPTO
to fix build errors in 2.6.39:
ERROR: "crypto_destroy_tfm" [fs/nfsd/nfsd.ko] undefined!
ERROR: "crypto_alloc_base" [fs/nfsd/nfsd.ko] undefined!
Reported-by: Wakko Warner <wakko@animx.eu.org>
commit 0f66b5984df2fe1617c05900a39a7ef493ca9de9 upstream.
nfs_update_inode will update isize if there is no queued pages. For pNFS,
layoutcommit is supposed to change file size on server, the same effect as queued
pages. nfs_update_inode may be called when dirty pages are written back (nfsi->npages==0)
but layoutcommit is not sent, and it will change client file size according to server
file size. Then client ends up losing what it just writes back in pNFS path.
So we should skip updating client file size if file needs layoutcommit.
Signed-off-by: Peng Tao <peng_tao@emc.com>
commit fe47ae7f53e179d2ef6771024feb000cbb86640f upstream.
The lockdep warning below detects a possible A->B/B->A locking
dependency of mm->mmap_sem and dcookie_mutex. The order in
sync_buffer() is mm->mmap_sem/dcookie_mutex, while in
sys_lookup_dcookie() it is vice versa.
Fixing it in sys_lookup_dcookie() by unlocking dcookie_mutex before
copy_to_user().
oprofiled/4432 is trying to acquire lock:
(&mm->mmap_sem){++++++}, at: [<ffffffff810b444b>] might_fault+0x53/0xa3
but task is already holding lock:
(dcookie_mutex){+.+.+.}, at: [<ffffffff81124d28>] sys_lookup_dcookie+0x45/0x149
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (dcookie_mutex){+.+.+.}:
[<ffffffff8106557f>] lock_acquire+0xf8/0x11e
[<ffffffff814634f0>] mutex_lock_nested+0x63/0x309
[<ffffffff81124e5c>] get_dcookie+0x30/0x144
[<ffffffffa0000fba>] sync_buffer+0x196/0x3ec [oprofile]
[<ffffffffa0001226>] task_exit_notify+0x16/0x1a [oprofile]
[<ffffffff81467b96>] notifier_call_chain+0x37/0x63
[<ffffffff8105803d>] __blocking_notifier_call_chain+0x50/0x67
[<ffffffff81058068>] blocking_notifier_call_chain+0x14/0x16
[<ffffffff8105a718>] profile_task_exit+0x1a/0x1c
[<ffffffff81039e8f>] do_exit+0x2a/0x6fc
[<ffffffff8103a5e4>] do_group_exit+0x83/0xae
[<ffffffff8103a626>] sys_exit_group+0x17/0x1b
[<ffffffff8146ad4b>] system_call_fastpath+0x16/0x1b
-> #0 (&mm->mmap_sem){++++++}:
[<ffffffff81064dfb>] __lock_acquire+0x1085/0x1711
[<ffffffff810b4478>] might_fault+0x80/0xa3
[<ffffffff81124de7>] sys_lookup_dcookie+0x104/0x149
1 lock held by oprofiled/4432:
#0: (dcookie_mutex){+.+.+.}, at: [<ffffffff81124d28>] sys_lookup_dcookie+0x45/0x149
stack backtrace:
Pid: 4432, comm: oprofiled Not tainted 2.6.39-00008-ge5a450d #9
Call Trace:
[<ffffffff81063193>] print_circular_bug+0xae/0xbc
[<ffffffff8102ef13>] ? get_parent_ip+0x11/0x42
[<ffffffff810b444b>] ? might_fault+0x53/0xa3
[<ffffffff810d7d54>] ? path_put+0x22/0x27
References: https://bugzilla.kernel.org/show_bug.cgi?id=13809
Signed-off-by: Robert Richter <robert.richter@amd.com>
commit 7fdbaa1b8daa1009b705985b903e3d2ebccad456 upstream.
It's possible for the following set of events to happen:
cifsd calls cifs_reconnect which reconnects the socket. A userspace
process then calls cifs_negotiate_protocol to handle the NEGOTIATE and
gets a reply. But, while processing the reply, cifsd calls
cifs_reconnect again. Eventually the GlobalMid_Lock is dropped and the
reply from the earlier NEGOTIATE completes and the tcpStatus is set to
CifsGood. cifs_reconnect then goes through and closes the socket and sets the
pointer to zero, but because the status is now CifsGood, the new socket
is not created and cifs_reconnect exits with the socket pointer set to
NULL.
Fix this by only setting the tcpStatus to CifsGood if the tcpStatus is
CifsNeedNegotiate, and by making sure that generic_ip_connect is always
called at least once in cifs_reconnect.
Note that this is not a perfect fix for this issue. It's still possible
that the NEGOTIATE reply is handled after the socket has been closed and
reconnected. In that case, the socket state will look correct but it no
NEGOTIATE was performed on it be for the wrong socket. In that situation
though the server should just shut down the socket on the next attempted
send, rather than causing the oops that occurs today.
Reported-and-Tested-by: Ben Greear <greearb@candelatech.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit dac853ae89043f1b7752875300faf614de43c74b upstream.
Unconditionally changing the address limit to USER_DS and not restoring
it to its old value in the error path is wrong because it prevents us
using kernel memory on repeated calls to this function. This, in fact,
breaks the fallback of hard coded paths to the init program from being
ever successful if the first candidate fails to load.
With this patch applied switching to USER_DS is delayed until the point
of no return is reached which makes it possible to have a multi-arch
rootfs with one arch specific init binary for each of the (hard coded)
probed paths.
Since the address limit is already set to USER_DS when start_thread()
will be invoked, this redundancy can be safely removed.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit 9c4843ea576107a3c1fb94f2f758f198e9fe9e54 upstream.
When signing is enabled, the first session that's established on a
socket will cause a printk like this to pop:
CIFS VFS: Unexpected SMB signature
This is because the key exchange hasn't happened yet, so the signature
field is bogus. Don't try to check the signature on the socket until the
first session has been established. Also, eliminate the specific check
for SMB_COM_NEGOTIATE since this check covers that case too.
Cc: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
commit 1adffbae22332bb558c2a29de19d9aca391869f6 upstream.
We are clearly missing '~' in fat_ioctl_set_attributes().
Reported-by: Dmitry Dmitriev <dimondmm@yandex.ru>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
commit 4c49ff3fe128ca68dabd07537415c419ad7f82f9 upstream.
d4dc210f69 (block: don't block events on excl write for non-optical
devices) added dereferencing of bdev->bd_disk to test
GENHD_FL_BLOCK_EVENTS_ON_EXCL_WRITE; however, bdev->bd_disk can be
%NULL if open failed which can lead to an oops.
Test the flag after testing open was successful, not before.
Reported-by: David Miller <davem@davemloft.net>
Tested-by: David Miller <davem@davemloft.net>
commit 812eb258311f89bcd664a34a620f249d54a2cd83 upstream.
UBIFS leaks memory on error path in 'ubifs_jnl_update()' in case of write
failure because it forgets to free the 'struct ubifs_dent_node *dent' object.
Although the object is small, the alignment can make it large - e.g., 2KiB
if the min. I/O unit is 2KiB.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
commit cf610bf4199770420629d3bc273494bd27ad6c1d upstream.
Sometimes VM asks the shrinker to return amount of objects it can shrink,
and we return the ubifs_clean_zn_cnt in that case. However, it is possible
that this counter is negative for a short period of time, due to the way
UBIFS TNC code updates it. And I can observe the following warnings sometimes:
shrink_slab: ubifs_shrinker+0x0/0x2b7 [ubifs] negative objects to delete nr=-8541616642706119788
This patch makes sure UBIFS never returns negative count of objects.
commit 4ed5c033c11b33149d993734a6a8de1016e8f03f upstream.
In order to make lazyinit eat approx. 10% of io bandwidth at max, we
are sleeping between zeroing each single inode table. For that purpose
we are using timer which wakes up thread when it expires. It is set
via add_timer() and this may cause troubles in the case that thread
has been woken up earlier and in next iteration we call add_timer() on
still running timer hence hitting BUG_ON in add_timer(). We could fix
that by using mod_timer() instead however we can use
schedule_timeout_interruptible() for waiting and hence simplifying
things a lot.
This commit exchange the old "waiting mechanism" with simple
schedule_timeout_interruptible(), setting the time to sleep. Hence we
do not longer need li_wait_daemon waiting queue and others, so get rid
of it.
Addresses-Red-Hat-Bugzilla: #699708
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
commit 1bb933fb1fa8e4cb337a0d5dfd2ff4c0dc2073e8 upstream.
We need to take reference to the s_li_request after we take a mutex,
because it might be freed since then, hence result in accessing old
already freed memory. Also we should protect the whole
ext4_remove_li_request() because ext4_li_info might be in the process of
being freed in ext4_lazyinit_thread().
commit d4dc210f69bcb0b4bef5a83b1c323817be89bad1 upstream.
Disk event code automatically blocks events on excl write. This is
primarily to avoid issuing polling commands while burning is in
progress. This behavior doesn't fit other types of devices with
removeable media where polling commands don't have adverse side
effects and door locking usually doesn't exist.
This patch introduces new genhd flag which controls the auto-blocking
behavior and uses it to enable auto-blocking only on optical devices.
Note for stable: 2.6.38 and later only
Reported-by: Kay Sievers <kay.sievers@vrfy.org>
commit 4b8ee2b82e8b0b6e17ee33feb74fcdb5c6d8dbdd upstream.
A client sends offset to MDS as it was seen by DS. As result,
file size after copy is only half of original file size in case
of 2 DS.
Signed-off-by: Vitaliy Gusev <gusev.vitaliy@nexenta.com>
commit 444f72fe7e7b5f4db34cee933fa3546ebb8e9122 upstream.
Currently, the call to nfs4_schedule_session_recovery() will actually just
result in a test of the lease when what we really want is to force a
session reset.
commit 0ced63d1a245ac11241a5d37932e6d04d9c8040d upstream.
Currently, if the server returns NFS4ERR_EXPIRED in reply to a READ or
WRITE, but the RENEW test determines that the lease is still active, we
fail to recover and end up looping forever in a READ/WRITE + RENEW death
spiral.
commit eaeee242c531cd4b0a4a46e8b5dd7ef504380c42 upstream.
When re-mounting from R/O mode to R/W mode and the LEB count in the superblock
is not up-to date, because for the underlying UBI volume became larger, we
re-write the superblock. We allocate RAM for these purposes, but never free it.
So this is a memory leak, although very rare one.
commit 8d08dab786ad5cc2aca2bf870de370144b78c85a upstream.
The buffers allocated while encrypting and decrypting long filenames can
sometimes straddle two pages. In this situation, virt_to_scatterlist()
will return -ENOMEM, causing the operation to fail and the user will get
scary error messages in their logs:
kernel: ecryptfs_write_tag_70_packet: Internal error whilst attempting
to convert filename memory to scatterlist; expected rc = 1; got rc =
[-12]. block_aligned_filename_size = [272]
kernel: ecryptfs_encrypt_filename: Error attempting to generate tag 70
packet; rc = [-12]
kernel: ecryptfs_encrypt_and_encode_filename: Error attempting to
encrypt filename; rc = [-12]
kernel: ecryptfs_lookup: Error attempting to encrypt and encode
The solution is to allow up to 2 scatterlist entries to be used.
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
commit 07850552b92b3637fa56767b5e460b4238014447 upstream.
eCryptfs wasn't clearing the eCryptfs inode's i_nlink after a successful
vfs_rmdir() on the lower directory. This resulted in the inode evict and
destroy paths to be missed.
https://bugs.launchpad.net/ecryptfs/+bug/723518
commit cae13fe4cc3f24820ffb990c09110626837e85d4 upstream.
As Ben Hutchings discovered [1], the patch for CVE-2011-1017 (buffer
overflow in ldm_frag_add) is not sufficient. The original patch in
commit c340b1d64000 ("fs/partitions/ldm.c: fix oops caused by corrupted
partition table") does not consider that, for subsequent fragments,
previously allocated memory is used.
[1] http://lkml.org/lkml/2011/5/6/407
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Signed-off-by: Timo Warns <warns@pre-sense.de>
commit 6848b7334b24b47aa3d0e70342ff839ffa95d5fa upstream.
When mandatory encryption is configured in samba server on a
share (smb.conf parameter "smb encrypt = mandatory") the
server will hang up the tcp session when we try to send
the first frame after the tree connect if it is not a
QueryFSUnixInfo, this causes cifs mount to hang (it must
be killed with ctl-c). Move the QueryFSUnixInfo call
earlier in the mount sequence, and check whether the SetFSUnixInfo
fails due to mandatory encryption so we can return a sensible
error (EACCES) on mount.
In a future patch (for 2.6.40) we will support mandatory
encryption.
Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru>
commit 26626f1172fb4f3f323239a6a5cf4e082643fa46 upstream.
Add missing page_cache_release in the error path of ext4_mb_load_buddy
Signed-off-by: Yang Ruirui <ruirui.r.yang@tieto.com>
commit d9b01934d56a96d9f4ae2d6204d4ea78a36f5f36 upstream.
If an application program does not make any changes to the indirect
blocks or extent tree, i_datasync_tid will not get updated. If there
are enough commits (i.e., 2**31) such that tid_geq()'s calculations
wrap, and there isn't a currently active transaction at the time of
the fdatasync() call, this can end up triggering a BUG_ON in
fs/jbd/commit.c:
J_ASSERT(journal->j_running_transaction != NULL);
It's pretty rare that this can happen, since it requires the use of
fdatasync() plus *very* frequent and excessive use of fsync(). But
with the right workload, it can.
We fix this by replacing the use of tid_geq() with an equality test,
since there's only one valid transaction id that is valid for us to
start: namely, the currently running transaction (if it exists).
Reported-by: Martin_Zielinski@McAfee.com
commit 2842bb20eed2e25cde5114298edc62c8883a1d9a upstream.
In do_get_write_access() we wait on BH_Unshadow bit for buffer to get
from shadow state. The waking code in journal_commit_transaction() has
a bug because it does not issue a memory barrier after the buffer is moved
from the shadow state and before wake_up_bit() is called. Thus a waitqueue
check can happen before the buffer is actually moved from the shadow state
and waiting process may never be woken. Fix the problem by issuing proper
barrier.
Reported-by: Tao Ma <boyu.mt@taobao.com>
commit 86c4f6d85595cd7da635dc6985d27bfa43b1ae10 upstream.
When make_indexed_dir() fails (e.g. because of ENOSPC) after it has allocated
block for index tree root, we did not properly mark all changed buffers dirty.
This lead to only some of these buffers being written out and thus effectively
corrupting the directory.
Fix the issue by marking all changed data dirty even in the error failure case.
commit 1a4022f88d40e1255920b017556092ab926d7f66 upstream.
This solves a serious VFS-level bug in nested_symlink (which was
rewritten from do_follow_link), and follows the order of depth tests
that existed before.
The bug triggers a BUG_ON in fs/namei.c:1381, when running racer with
symlink and rename ops.
Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu>
Acked-by: Miklos Szeredi <mszeredi@suse.cz>
commit 7e69723fef8771a9d57bd27d36281d756130b4b5 upstream.
02e352287a4 (block: rescan partitions on invalidated devices on
-ENOMEDIA too) relocated partition rescan above explicit bd_set_size()
to simplify condition check. As rescan_partitions() does its own bdev
size setting, this doesn't break anything; however,
rescan_partitions() prints out the following messages when adjusting
bdev size, which can be confusing.
sda: detected capacity change from 0 to 146815737856
sdb: detected capacity change from 0 to 146815737856
This patch restores the original order and remove the warning
messages.
stable: Please apply together with 02e352287a4 (block: rescan
partitions on invalidated devices on -ENOMEDIA too).
Reported-by: Tony Luck <tony.luck@gmail.com>
Tested-by: Tony Luck <tony.luck@gmail.com>
commit 39db00f1c45e770856264bdb3ceca27980b01965 upstream.
In the bio completion routine, we should not be setting
PageUptodate at all -- it's set at sys_write() time, and is
unaffected by success/failure of the write to disk.
This can cause a page corruption bug when the file system's
block size is less than the architecture's VM page size.
if we have only written a single block -- we might end up
setting the page's PageUptodate flag, indicating that page
is completely read into memory, which may not be true.
This could cause subsequent reads to get bad data.
This commit also takes the opportunity to clean up error
handling in ext4_end_bio(), and remove some extraneous code:
- fixes ext4_end_bio() to set AS_EIO in the
page->mapping->flags on error, which was left out by
mistake. This is needed so that fsync() will
return an error if there was an I/O error.
- remove the clear_buffer_dirty() call on unmapped
buffers for each page.
- consolidate page/buffer error handling in a single
section.
Signed-off-by: Curt Wohlgemuth <curtw@google.com>
Reported-by: Jim Meyering <jim@meyering.net>
Reported-by: Hugh Dickins <hughd@google.com>
Cc: Mingming Cao <cmm@us.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2:
configfs: Fix race between configfs_readdir() and configfs_d_iput()
configfs: Don't try to d_delete() negative dentries.
ocfs2/dlm: Target node death during resource migration leads to thread spin
ocfs2: Skip mount recovery for hard-ro mounts
ocfs2/cluster: Heartbeat mismatch message improved
ocfs2/cluster: Increase the live threshold for global heartbeat
ocfs2/dlm: Use negotiated o2dlm protocol version
ocfs2: skip existing hole when removing the last extent_rec in punching-hole codes.
ocfs2: Initialize data_ac (might be used uninitialized)
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
block: don't delay blk_run_queue_async
scsi: remove performance regression due to async queue run
blk-throttle: Use task_subsys_state() to determine a task's blkio_cgroup
block: rescan partitions on invalidated devices on -ENOMEDIA too
cdrom: always check_disk_change() on open
block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe drivers
configfs_readdir() will use the existing inode numbers of inodes in the
dcache, but it makes them up for attribute files that aren't currently
instantiated. There is a race where a closing attribute file can be
tearing down at the same time as configfs_readdir() is trying to get its
inode number.
We want to get the inode number of open attribute files, because they
should match while instantiated. We can't lock down the transition
where dentry->d_inode is set to NULL, so we just check for NULL there.
We can, however, ensure that an inode we find isn't iput() in
configfs_d_iput() until after we've accessed it.
Signed-off-by: Joel Becker <jlbec@evilplan.org>
When configfs is faking mkdir() on its subsystem or default group
objects, it starts by adding a negative dentry. It then tries to
instantiate the group. If that should fail, it must clean up after
itself.
I was using d_delete() here, but configfs_attach_group() promises to
return an empty dentry on error. d_delete() explodes with the entry
dentry. Let's try d_drop() instead. The unhashing is what we want for
our dentry.
As Metze pointed out, commit 84cdf74e broke mapchars option:
Commit "cifs: fix unaligned accesses in cifsConvertToUCS"
(84cdf74e8096a10dd6acbb870dd404b92f07a756) does multiple steps
in just one commit (moving the function and changing it without
testing).
put_unaligned_le16(temp, &target[j]); is never called for any
codepoint the goes via the 'default' switch statement. As a result
we put just zero (or maybe uninitialized) bytes into the target
buffer.
His proposed patch looks correct, but doesn't apply to the current head
of the tree. This patch should also fix it.
Cc: <stable@kernel.org> # .38.x: 581ade4: cifs: clean up various nits in unicode routines (try #2)
Reported-by: Stefan Metzmacher <metze@samba.org>
The is_path_accessible check uses a QPathInfo call, which isn't
supported by ancient win9x era servers. Fall back to an older
SMBQueryInfo call if it fails with the magic error codes.
Cc: stable@kernel.org
Reported-and-Tested-by: Sandro Bonazzola <sandro.bonazzola@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable:
Btrfs: fix FS_IOC_SETFLAGS ioctl
Btrfs: fix FS_IOC_GETFLAGS ioctl
fs: remove FS_COW_FL
Btrfs: fix easily get into ENOSPC in mixed case
Prevent oopsing in posix_acl_valid()
Steps to reproduce the bug:
- Call FS_IOC_SETLFAGS ioctl with flags=FS_COMPR_FL
- Call FS_IOC_SETFLAGS ioctl with flags=0
- Call FS_IOC_GETFLAGS ioctl, and you'll see FS_COMPR_FL is still set!
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Signed-off-by: Chris Mason <chris.mason@oracle.com>
As we've added per file compression/cow support.
FS_COW_FL and FS_NOCOW_FL were newly introduced to control per file
COW in btrfs, but FS_NOCOW_FL is sufficient.
The fact is we don't have corresponding BTRFS_INODE_COW flag.
COW is default, and FS_NOCOW_FL can be used to switch off COW for
a single file.
If we mount btrfs with nodatacow, a newly created file will be set with
the FS_NOCOW_FL flag. So to turn on COW for it, we can just clear the
FS_NOCOW_FL flag.
When a btrfs disk is created by mixed data & metadata option, it will have no
pure data or pure metadata space info.
In btrfs's for-linus branch, commit 78b1ea13838039cd88afdd62519b40b344d6c920
(Btrfs: fix OOPS of empty filesystem after balance) initializes space infos at
the very beginning. The problem is this initialization does not take the mixed
case into account, which will cause btrfs will easily get into ENOSPC in mixed
case.
Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com>
