arch/arm/mm/cache-v6.S
Change-Id: I1a2063218dd705a762a40f4a9dfe504ce1a1d491
commit 462e635e5b73ba9a4c03913b77138cd57ce4b050 upstream.
The install_special_mapping routine (used, for example, to setup the
vdso) skips the security check before insert_vm_struct, allowing a local
attacker to bypass the mmap_min_addr security restriction by limiting
the available pages for special mappings.
bprm_mm_init() also skips the check, and although I don't think this can
be used to bypass any restrictions, I don't see any reason not to have
the security check.
$ uname -m
x86_64
$ cat /proc/sys/vm/mmap_min_addr
65536
$ cat install_special_mapping.s
section .bss
resb BSS_SIZE
section .text
global _start
_start:
mov eax, __NR_pause
int 0x80
$ nasm -D__NR_pause=29 -DBSS_SIZE=0xfffed000 -f elf -o install_special_mapping.o install_special_mapping.s
$ ld -m elf_i386 -Ttext=0x10000 -Tbss=0x11000 -o install_special_mapping install_special_mapping.o
$ ./install_special_mapping &
[1] 14303
$ cat /proc/14303/maps
0000f000-00010000 r-xp 00000000 00:00 0 [vdso]
00010000-00011000 r-xp 00001000 00:19 2453665 /home/taviso/install_special_mapping
00011000-ffffe000 rwxp 00000000 00:00 0 [stack]
It's worth noting that Red Hat are shipping with mmap_min_addr set to
4096.
Signed-off-by: Tavis Ormandy <taviso@google.com>
Acked-by: Kees Cook <kees@ubuntu.com>
Acked-by: Robert Swiecki <swiecki@google.com>
[ Changed to not drop the error code - akpm ]
Reviewed-by: James Morris <jmorris@namei.org>
commit a2ae4cc9a16e211c8a128ba10d22a85431f093ab upstream.
If inotify_init is unable to allocate a new file for the new inotify
group we leak the new group. This patch drops the reference on the
group on file allocation failure.
Reported-by: Vegard Nossum <vegard.nossum@gmail.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
commit 21ac19d484a8ffb66f64487846c8d53afef04d2b upstream.
The commit 129a84de2347002f09721cda3155ccfd19fade40 (locks: fix F_GETLK
regression (failure to find conflicts)) fixed the posix_test_lock()
function by itself, however, its usage in NFS changed by the commit
9d6a8c5c213e34c475e72b245a8eb709258e968c (locks: give posix_test_lock
same interface as ->lock) remained broken - subsequent NFS-specific
locking code received F_UNLCK instead of the user-specified lock type.
To fix the problem, fl->fl_type needs to be saved before the
posix_test_lock() call and restored if no local conflicts were reported.
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=23892
Tested-by: Alexander Morozov <amorozov@etersoft.ru>
Signed-off-by: Sergey Vlasov <vsu@altlinux.ru>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit c1ac3ffcd0bc7e9617f62be8c7043d53ab84deac upstream.
If vfs_getattr in fill_post_wcc returns an error, we don't
set fh_post_change.
For NFSv4, this can result in set_change_info triggering a BUG_ON.
i.e. fh_post_saved being zero isn't really a bug.
So:
- instead of BUGging when fh_post_saved is zero, just clear ->atomic.
- if vfs_getattr fails in fill_post_wcc, take a copy of i_ctime anyway.
This will be used i seg_change_info, but not overly trusted.
- While we are there, remove the pointless 'if' statements in set_change_info.
There is no harm setting all the values.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 5b362ac3799ff4225c40935500f520cad4d7ed66 upstream.
After a few unsuccessful NFS mount attempts in which the client and
server cannot agree on an authentication flavor both support, the
client panics. nfs_umount() is invoked in the kernel in this case.
Turns out nfs_umount()'s UMNT RPC invocation causes the RPC client to
write off the end of the rpc_clnt's iostat array. This is because the
mount client's nrprocs field is initialized with the count of defined
procedures (two: MNT and UMNT), rather than the size of the client's
proc array (four).
The fix is to use the same initialization technique used by most other
upper layer clients in the kernel.
Introduced by commit 0b524123, which failed to update nrprocs when
support was added for UMNT in the kernel.
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=24302
BugLink: http://bugs.launchpad.net/bugs/683938
Reported-by: Stefan Bader <stefan.bader@canonical.com>
Tested-by: Stefan Bader <stefan.bader@canonical.com>
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
commit d9d318d39dd5cb686660504a3565aac453709ccc upstream.
If a 32bit CUSE server is run on 64bit this results in EIO being
returned to the caller.
The reason is that FUSE_IOCTL_RETRY reply was defined to use 'struct
iovec', which is different on 32bit and 64bit archs.
Work around this by looking at the size of the reply to determine
which struct was used. This is only needed if CONFIG_COMPAT is
defined.
A more permanent fix for the interface will be to use the same struct
on both 32bit and 64bit.
Reported-by: "ccmail111" <ccmail111@yahoo.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
CC: Tejun Heo <tj@kernel.org>
commit 7572777eef78ebdee1ecb7c258c0ef94d35bad16 upstream.
Verify that the total length of the iovec returned in FUSE_IOCTL_RETRY
doesn't overflow iov_length().
drivers/usb/gadget/composite.c
Change-Id: I1a332ec21da62aea98912df9a01cf0282ed50ee1
commit 72083646528d4887b920deb71b37e09bc7d227bb upstream.
This avoids some include-file hell, and the function isn't really
important enough to be inlined anyway.
Reported-by: Ingo Molnar <mingo@elte.hu>
commit c66fb347946ebdd5b10908866ecc9fa05ee2cf3d upstream.
And in particular, use it in 'pipe_fcntl()'.
The other pipe functions do not need to use the 'careful' version, since
they are only ever called for things that are already known to be pipes.
The normal read/write/ioctl functions are called through the file
operations structures, so if a file isn't a pipe, they'd never get
called. But pipe_fcntl() is special, and called directly from the
generic fcntl code, and needs to use the same careful function that the
splice code is using.
Cc: Jens Axboe <jaxboe@fusionio.com>
Cc: Dave Jones <davej@redhat.com>
commit 71993e62a47dabddf10302807d6aa260455503f4 upstream.
.. and change it to take the 'file' pointer instead of an inode, since
that's what all users want anyway.
The renaming is preparatory to exporting it to other users. The old
'pipe_info()' name was too generic and is already used elsewhere, so
before making the function public we need to use a more specific name.
commit a1c6c5698d53db4c47a25c3a8d11731a4d7b8370 upstream.
Fix NULL pointer dereference in print_daily_error_info, when
called on unmounted fs (EXT4_SB(sb) returns NULL), by removing error
reporting timer in ext4_put_super.
Google-Bug-Id: 3017663
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: Thomas Meyer <thomas@m3y3r.de>
commit 7b2a69ba7055da9a04eb96aa7b38c8e3280aaaa5 upstream.
Because it caused a chroot ttyname regression in 2.6.36.
As of 2.6.36 ttyname does not work in a chroot. It has already been
reported that screen breaks, and for me this breaks an automated
distribution testsuite, that I need to preserve the ability to run the
existing binaries on for several more years. glibc 2.11.3 which has a
fix for this is not an option.
The root cause of this breakage is:
commit 8df9d1a4142311c084ffeeacb67cd34d190eff74
Author: Miklos Szeredi <mszeredi@suse.cz>
Date: Tue Aug 10 11:41:41 2010 +0200
vfs: show unreachable paths in getcwd and proc
Prepend "(unreachable)" to path strings if the path is not reachable
from the current root.
Two places updated are
- the return string from getcwd()
- and symlinks under /proc/$PID.
Other uses of d_path() are left unchanged (we know that some old
software crashes if /proc/mounts is changed).
So remove the nice sounding, but ultimately ill advised change to how
/proc/fd symlinks work.
commit ba03864872691c0bb580a7fb47388da337ef4aa2 upstream.
The DFS referral parsing code does a memchr() call to find the '\\'
delimiter that separates the hostname in the referral UNC from the
sharename. It then uses that value to set the length of the hostname via
pointer subtraction. Instead of subtracting the start of the hostname
however, it subtracts the start of the UNC, which causes the code to
pass in a hostname length that is 2 bytes too long.
Regression introduced in commit 1a4240f4.
Reported-and-Tested-by: Robbert Kouprie <robbert@exx.nl>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Cc: Wang Lei <wang840925@gmail.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit a7851ce73b9fdef53f251420e6883cf4f3766534 upstream.
cifs_root_iget allocates full_path through
cifs_build_path_to_root, but fails to kfree it upon
cifs_get_inode_info* failure.
Make all failure exit paths traverse clean up
handling at the end of the function.
Signed-off-by: Oskar Schirmer <oskar@scara.com>
Reviewed-by: Jesper Juhl <jj@chaosbits.net>
commit a0822c55779d9319939eac69f00bb729ea9d23da upstream.
The attribute cache for a file was not being cleared when a file is opened
with O_TRUNC.
If the filesystem's open operation truncates the file ("atomic_o_trunc"
feature flag is set) then the kernel should invalidate the cached st_mtime
and st_ctime attributes.
Also i_size should be explicitly be set to zero as it is used sometimes
without refreshing the cache.
Signed-off-by: Ken Sumrall <ksumrall@android.com>
Cc: Anfei <anfei.zhou@gmail.com>
Cc: "Anand V. Avati" <avati@gluster.com>
Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
commit 114279be2120a916e8a04feeb2ac976a10016f2f upstream.
Note: this patch targets 2.6.37 and tries to be as simple as possible.
That is why it adds more copy-and-paste horror into fs/compat.c and
uglifies fs/exec.c, this will be cleanuped later.
compat_copy_strings() plays with bprm->vma/mm directly and thus has
two problems: it lacks the RLIMIT_STACK check and argv/envp memory
is not visible to oom killer.
Export acct_arg_size() and get_arg_page(), change compat_copy_strings()
to use get_arg_page(), change compat_do_execve() to do acct_arg_size(0)
as do_execve() does.
Add the fatal_signal_pending/cond_resched checks into compat_count() and
compat_copy_strings(), this matches the code in fs/exec.c and certainly
makes sense.
commit 3c77f845722158206a7209c45ccddc264d19319c upstream.
Brad Spengler published a local memory-allocation DoS that
evades the OOM-killer (though not the virtual memory RLIMIT):
http://www.grsecurity.net/~spender/64bit_dos.c
execve()->copy_strings() can allocate a lot of memory, but
this is not visible to oom-killer, nobody can see the nascent
bprm->mm and take it into account.
With this patch get_arg_page() increments current's MM_ANONPAGES
counter every time we allocate the new page for argv/envp. When
do_execve() succeds or fails, we change this counter back.
Technically this is not 100% correct, we can't know if the new
page is swapped out and turn MM_ANONPAGES into MM_SWAPENTS, but
I don't think this really matters and everything becomes correct
once exec changes ->mm or fails.
Reported-by: Brad Spengler <spender@grsecurity.net>
Reviewed-and-discussed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
commit cb4644cac4a2797afc847e6c92736664d4b0ea34 upstream.
If the iovec is being set up in a way that causes uaddr + PAGE_SIZE
to overflow, we could end up attempting to map a huge number of
pages. Check for this invalid input type.
Reported-by: Dan Rosenberg <drosenberg@vsecurity.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit 015f0212d51d85bd281a831639a769b4a1a3307a upstream.
nfs_get_lock_context can return NULL on an allocation failure.
Regression introduced by commit f11ac8db.
Reported-by: Steve Dickson <steved@redhat.com>
commit 48b512e6857139393cdfce26348c362b87537018 upstream.
Ecryptfs is a stackable filesystem which relies on lower filesystems the
ability of setting/getting extended attributes.
If there is a security module enabled on the system it updates the
'security' field of inodes according to the owned extended attribute set
with the function vfs_setxattr(). When this function is performed on a
ecryptfs filesystem the 'security' field is not updated for the lower
filesystem since the call security_inode_post_setxattr() is missing for
the lower inode.
Further, the call security_inode_setxattr() is missing for the lower inode,
leading to policy violations in the security module because specific
checks for this hook are not performed (i. e. filesystem
'associate' permission on SELinux is not checked for the lower filesystem).
This patch replaces the call of the setxattr() method of the lower inode
in the function ecryptfs_setxattr() with vfs_setxattr().
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
Cc: Dustin Kirkland <kirkland@canonical.com>
Acked-by: James Morris <jmorris@namei.org>
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
commit 2e21b3f124eceb6ab5a07c8a061adce14ac94e14 upstream.
eCryptfs was passing the LOOKUP_OPEN flag through to the lower file
system, even though ecryptfs_create() doesn't support the flag. A valid
filp for the lower filesystem could be returned in the nameidata if the
lower file system's create() function supported LOOKUP_OPEN, possibly
resulting in unencrypted writes to the lower file.
However, this is only a potential problem in filesystems (FUSE, NFS,
CIFS, CEPH, 9p) that eCryptfs isn't known to support today.
https://bugs.launchpad.net/ecryptfs/+bug/641703
Reported-by: Kevin Buhr
commit 1b627d5771312c92404b66f0a0b16f66036dd2e1 upstream.
365b1818 ("add f_flags to struct statfs(64)") resized f_spare within
struct statfs which caused a UML crash. There is no need to copy f_spare.
Signed-off-by: Richard Weinberger <richard@nod.at>
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
Tested-by: Toralf Förster <toralf.foerster@gmx.de>
Cc: Jeff Dike <jdike@addtoit.com>
commit 238af8751f64a75f8b638193353b1c31ea32e738 upstream.
reiserfs_acl_chmod() can be called by reiserfs_set_attr() and then take
the reiserfs lock a second time. Thereafter it may call journal_begin()
that definitely requires the lock not to be nested in order to release
it before taking the journal mutex because the reiserfs lock depends on
the journal mutex already.
So, aviod nesting the lock in reiserfs_acl_chmod().
Reported-by: Pawel Zawora <pzawora@gmail.com>
Tested-by: Pawel Zawora <pzawora@gmail.com>
Cc: Jeff Mahoney <jeffm@suse.com>
commit da905873effecd1c0166e578bc4b5006f041b18b upstream.
reiserfs_unpack() locks the inode mutex with reiserfs_mutex_lock_safe()
to protect against reiserfs lock dependency. However this protection
requires to have the reiserfs lock to be locked.
This is the case if reiserfs_unpack() is called by reiserfs_ioctl but
not from reiserfs_quota_on() when it tries to unpack tails of quota
files.
Fix the ordering of the two locks in reiserfs_unpack() to fix this
issue.
Reported-by: Markus Gapp <markus.gapp@gmx.net>
Reported-by: Jan Kara <jack@suse.cz>
commit bc4866b6e0b44f8ea0df22a16e5927714beb4983 upstream.
In the case where we lock the page, and then find out that the page has
been thrown out of the page cache, we should just return VM_FAULT_NOPAGE.
This is what block_page_mkwrite() does in these situations.
commit b0ed9dbc24f1fd912b2dd08b995153cafc1d5b1c upstream.
NFSv4 open recovery is currently broken: since we do not clear the
state->flags states before attempting recovery, we end up with the
'can_open_cached()' function triggering. This again leads to no OPEN call
being put on the wire.
Reported-by: Sachin Prabhu <sprabhu@redhat.com>
commit ae1007d37e00144b72906a4bdc47d517ae91bcc1 upstream.
In the case of a server reboot, the state recovery thread starts by calling
nfs4_state_end_reclaim_reboot() in order to avoid edge conditions when
the server reboots while the client is in the middle of recovery.
However, if the client has already marked the nfs4_state as requiring
reboot recovery, then the above behaviour will cause the recovery thread to
treat the open as if it was part of such an edge condition: the open will
be recovered as if it was part of a lease expiration (and all the locks
will be lost).
Fix is to remove the call to nfs4_state_mark_reclaim_reboot from
nfs4_async_handle_error(), and nfs4_handle_exception(). Instead we leave it
to the recovery thread to do this for us.
commit 6eaa61496fb3b93cceface7a296415fc4c030bce upstream.
If the server sends us an NFS4ERR_STALE_CLIENTID while the state management
thread is busy reclaiming state, we do want to treat all state that wasn't
reclaimed before the STALE_CLIENTID as if a network partition occurred (see
the edge conditions described in RFC3530 and RFC5661).
What we do not want to do is to send an nfs4_reclaim_complete(), since we
haven't yet even started reclaiming state after the server rebooted.
commit f3f63c1c28bc861a931fac283b5bc3585efb8967 upstream.
We now initialize the percpu counters before replaying the journal,
but after the journal, we recalculate the global counters, to deal
with the possibility of the per-blockgroup counts getting updated by
the journal replay.
with O_TRUNC.
Cc: <stable@kernel.org>
commit 568a810d7edd58bd505222dd1c7e48895532290b upstream.
A typo, introduced by commit f11ac8db, in the nfs_direct_write()
routine causes writes with O_DIRECT set to fail with a ENOMEM error.
Found-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve Dickson <steved@redhat.com>
commit e5953cbdff26f7cbae7eff30cd9b18c4e19b7594 upstream.
The arguments were transposed, we want to assign the error code to
'ret', which is being returned.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
commit aa91c7e4ab9b0842b7d7a7cbf8cca18b20df89b5 upstream.
cifs_new_fileinfo() does not use the 'oplock' value from the callers. Instead,
it sets it to REQ_OPLOCK which seems wrong. We should be using the oplock value
obtained from the Server to set the inode's clientCanCacheAll or
clientCanCacheRead flags. Fix this by passing oplock from the callers to
cifs_new_fileinfo().
This change dates back to commit a6ce4932 (2.6.30-rc3). So, all the affected
versions will need this fix. Please Cc stable once reviewed and accepted.
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de>
Commit 84061e0 fixed an accounting bug only to introduce the
possibility of a kernel OOPS if the journal has a non-zero j_errno
field indicating that the file system had detected a fs inconsistency.
After the journal replay, if the journal superblock indicates that the
file system has an error, this indication is transfered to the file
system and then ext4_commit_super() is called to write this to the
disk.
But since the percpu counters are now initialized after the journal
replay, the call to ext4_commit_super() will cause a kernel oops since
it needs to use the percpu counters the ext4 superblock structure.
The fix is to skip setting the ext4 free block and free inode fields
if the percpu counter has not been set.
Thanks to Ken Sumrall for reporting and analyzing the root causes of
this bug.
Addresses-Google-Bug: #3054080
If you build aout support as a module, you'll want these exported.
Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Tony Luck reports that the addition of the access_ok() check in commit
0eead9ab41da ("Don't dump task struct in a.out core-dumps") broke the
ia64 compile due to missing the necessary header file includes.
Rather than add yet another include (<asm/unistd.h>) to make everything
happy, just uninline the silly core dump helper functions and move the
bodies to fs/exec.c where they make a lot more sense.
dump_seek() in particular was too big to be an inline function anyway,
and none of them are in any way performance-critical. And we really
don't need to mess up our include file headers more than they already
are.
Reported-and-tested-by: Tony Luck <tony.luck@gmail.com>
akiphie points out that a.out core-dumps have that odd task struct
dumping that was never used and was never really a good idea (it goes
back into the mists of history, probably the original core-dumping
code). Just remove it.
Also do the access_ok() check on dump_write(). It probably doesn't
matter (since normal filesystems all seem to do it anyway), but he
points out that it's normally done by the VFS layer, so ...
[ I suspect that we should possibly do "vfs_write()" instead of
calling ->write directly. That also does the whole fsnotify and write
statistics thing, which may or may not be a good idea. ]
And just to be anal, do this all for the x86-64 32-bit a.out emulation
code too, even though it's not enabled (and won't currently even
compile)
Reported-by: akiphie <akiphie@lavabit.com>
* 'for-2.6.36' of git://linux-nfs.org/~bfields/linux:
nfsd: fix BUG at fs/nfsd/nfsfh.h:199 on unlink
As of commit 43a9aa64a2f4330a9cb59aaf5c5636566bce067c "NFSD:
Fill in WCC data for REMOVE, RMDIR, MKNOD, and MKDIR", we sometimes call
fh_unlock on a filehandle that isn't fully initialized.
We should fix up the callers, but as a quick fix it is also sufficient
just to remove this assertion.
Reported-by: Marius Tolzmann <tolzmann@molgen.mpg.de>
Cc: Chuck Lever <chuck.lever@oracle.com>
Change-Id: Ib3f91913e69ca8d5a3bd644e3a01deca690067a8
Signed-off-by: Todd Poynor <toddpoynor@google.com>
This patch disables the fanotify syscalls by just not building them and
letting the cond_syscall() statements in kernel/sys_ni.c redirect them
to sys_ni_syscall().
It was pointed out by Tvrtko Ursulin that the fanotify interface did not
include an explicit prioritization between groups. This is necessary
for fanotify to be usable for hierarchical storage management software,
as they must get first access to the file, before inotify-like notifiers
see the file.
This feature can be added in an ABI compatible way in the next release
(by using a number of bits in the flags field to carry the info) but it
was suggested by Alan that maybe we should just hold off and do it in
the next cycle, likely with an (new) explicit argument to the syscall.
I don't like this approach best as I know people are already starting to
use the current interface, but Alan is all wise and noone on list backed
me up with just using what we have. I feel this is needlessly ripping
the rug out from under people at the last minute, but if others think it
needs to be a new argument it might be the best way forward.
Three choices:
Go with what we got (and implement the new feature next cycle). Add a
new field right now (and implement the new feature next cycle). Wait
till next cycle to release the ABI (and implement the new feature next
cycle). This is number 3.
