path: root/fs
2010-10-14Export dump_{write,seek} to binary loader modulesLinus Torvalds
If you build aout support as a module, you'll want these exported. Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-14Un-inline the core-dump helper functionsLinus Torvalds
Tony Luck reports that the addition of the access_ok() check in commit 0eead9ab41da ("Don't dump task struct in a.out core-dumps") broke the ia64 compile due to missing the necessary header file includes. Rather than add yet another include (<asm/unistd.h>) to make everything happy, just uninline the silly core dump helper functions and move the bodies to fs/exec.c where they make a lot more sense. dump_seek() in particular was too big to be an inline function anyway, and none of them are in any way performance-critical. And we really don't need to mess up our include file headers more than they already are. Reported-and-tested-by: Tony Luck <tony.luck@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-14Don't dump task struct in a.out core-dumpsLinus Torvalds
akiphie points out that a.out core-dumps have that odd task struct dumping that was never used and was never really a good idea (it goes back into the mists of history, probably the original core-dumping code). Just remove it. Also do the access_ok() check on dump_write(). It probably doesn't matter (since normal filesystems all seem to do it anyway), but he points out that it's normally done by the VFS layer, so ... [ I suspect that we should possibly do "vfs_write()" instead of calling ->write directly. That also does the whole fsnotify and write statistics thing, which may or may not be a good idea. ] And just to be anal, do this all for the x86-64 32-bit a.out emulation code too, even though it's not enabled (and won't currently even compile) Reported-by: akiphie <akiphie@lavabit.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-13Merge branch 'for-2.6.36' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.36' of git://linux-nfs.org/~bfields/linux: nfsd: fix BUG at fs/nfsd/nfsfh.h:199 on unlink
2010-10-13nfsd: fix BUG at fs/nfsd/nfsfh.h:199 on unlinkJ. Bruce Fields
As of commit 43a9aa64a2f4330a9cb59aaf5c5636566bce067c "NFSD: Fill in WCC data for REMOVE, RMDIR, MKNOD, and MKDIR", we sometimes call fh_unlock on a filehandle that isn't fully initialized. We should fix up the callers, but as a quick fix it is also sufficient just to remove this assertion. Reported-by: Marius Tolzmann <tolzmann@molgen.mpg.de> Cc: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-10-11fanotify: disable fanotify syscallsEric Paris
This patch disables the fanotify syscalls by just not building them and letting the cond_syscall() statements in kernel/sys_ni.c redirect them to sys_ni_syscall(). It was pointed out by Tvrtko Ursulin that the fanotify interface did not include an explicit prioritization between groups. This is necessary for fanotify to be usable for hierarchical storage management software, as they must get first access to the file, before inotify-like notifiers see the file. This feature can be added in an ABI compatible way in the next release (by using a number of bits in the flags field to carry the info) but it was suggested by Alan that maybe we should just hold off and do it in the next cycle, likely with an (new) explicit argument to the syscall. I don't like this approach best as I know people are already starting to use the current interface, but Alan is all wise and noone on list backed me up with just using what we have. I feel this is needlessly ripping the rug out from under people at the last minute, but if others think it needs to be a new argument it might be the best way forward. Three choices: Go with what we got (and implement the new feature next cycle). Add a new field right now (and implement the new feature next cycle). Wait till next cycle to release the ABI (and implement the new feature next cycle). This is number 3. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: update issue_seq on cap grant ceph: send cap release message early on failed revoke. ceph: Update max_len with minimum required size ceph: Fix return value of encode_fh function ceph: avoid null deref in osd request error path ceph: fix list_add usage on unsafe_writes list
2010-10-09Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
* 'for-linus' of git://git.open-osd.org/linux-open-osd: exofs: Fix double page_unlock BUG in write_begin/end
2010-10-08exofs: Fix double page_unlock BUG in write_begin/endBoaz Harrosh
This BUG is there since the first submit of the code, but only triggered in last Kernel. It's timing related do to the asynchronous object-creation behaviour of exofs. (Which should be investigated farther) The bug is obvious hence the fixed. Signed-off-by: Boaz Harrosh <Boaz Harrosh bharrosh@panasas.com>
2010-10-07Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: properly account for reclaimed inodes
2010-10-07ceph: update issue_seq on cap grantSage Weil
We need to update the issue_seq on any grant operation, be it via an MDS reply or a separate grant message. The update in the grant path was missing. This broke cap release for inodes in which the MDS sent an explicit grant message that was not soon after followed by a successful MDS reply on the same inode. Also fix the signedness on seq locals. Signed-off-by: Sage Weil <sage@newdream.net>
2010-10-07ceph: send cap release message early on failed revoke.Greg Farnum
If an MDS tries to revoke caps that we don't have, we want to send releases early since they probably contain the caps message the MDS is looking for. Previously, we only sent the messages if we didn't have the inode either. But in a multi-mds system we can retain the inode after dropping all caps for a single MDS. Signed-off-by: Greg Farnum <gregf@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2010-10-07ceph: Update max_len with minimum required sizeAneesh Kumar K.V
encode_fh on error should update max_len with minimum required size, so that caller can redo the call with the reallocated buffer. This is required with open by handle patch series Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Sage Weil <sage@newdream.net>
2010-10-07ceph: Fix return value of encode_fh functionAneesh Kumar K.V
encode_fh function should return 255 on error as done by other file system to indicate EOVERFLOW. Also max_len is in sizeof(u32) units and not in bytes. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Sage Weil <sage@newdream.net>
2010-10-07ceph: avoid null deref in osd request error pathSage Weil
If we interrupt an osd request, we call __cancel_request, but it wasn't verifying that req->r_osd was non-NULL before dereferencing it. This could cause a crash if osds were flapping and we aborted a request on said osd. Reported-by: Henry C Chang <henry_c_chang@tcloudcomputing.com> Signed-off-by: Sage Weil <sage@newdream.net>
2010-10-07ceph: fix list_add usage on unsafe_writes listHenry C Chang
Fix argument order. Signed-off-by: Henry C Chang <henry_c_chang@tcloudcomputing.com> Signed-off-by: Sage Weil <sage@newdream.net>
2010-10-06xfs: properly account for reclaimed inodesJohannes Weiner
When marking an inode reclaimable, a per-AG counter is increased, the inode is tagged reclaimable in its per-AG tree, and, when this is the first reclaimable inode in the AG, the AG entry in the per-mount tree is also tagged. When an inode is finally reclaimed, however, it is only deleted from the per-AG tree. Neither the counter is decreased, nor is the parent tree's AG entry untagged properly. Since the tags in the per-mount tree are not cleared, the inode shrinker iterates over all AGs that have had reclaimable inodes at one point in time. The counters on the other hand signal an increasing amount of slab objects to reclaim. Since "70e60ce xfs: convert inode shrinker to per-filesystem context" this is not a real issue anymore because the shrinker bails out after one iteration. But the problem was observable on a machine running v2.6.34, where the reclaimable work increased and each process going into direct reclaim eventually got stuck on the xfs inode shrinking path, trying to scan several million objects. Fix this by properly unwinding the reclaimable-state tracking of an inode when it is reclaimed. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: stable@kernel.org Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-10-06Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: writeback: always use sb->s_bdi for writeback purposes
2010-10-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: Initialize total_len in fuse_retrieve()
2010-10-04writeback: always use sb->s_bdi for writeback purposesChristoph Hellwig
We currently use struct backing_dev_info for various different purposes. Originally it was introduced to describe a backing device which includes an unplug and congestion function and various bits of readahead information and VM-relevant flags. We're also using for tracking dirty inodes for writeback. To make writeback properly find all inodes we need to only access the per-filesystem backing_device pointed to by the superblock in ->s_bdi inside the writeback code, and not the instances pointeded to by inode->i_mapping->backing_dev which can be overriden by special devices or might not be set at all by some filesystems. Long term we should split out the writeback-relevant bits of struct backing_device_info (which includes more than the current bdi_writeback) and only point to it from the superblock while leaving the traditional backing device as a separate structure that can be overriden by devices. The one exception for now is the block device filesystem which really wants different writeback contexts for it's different (internal) inodes to handle the writeout more efficiently. For now we do this with a hack in fs-writeback.c because we're so late in the cycle, but in the future I plan to replace this with a superblock method that allows for multiple writeback contexts per filesystem. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-04fuse: Initialize total_len in fuse_retrieve()Geert Uytterhoeven
fs/fuse/dev.c:1357: warning: ‘total_len’ may be used uninitialized in this function Initialize total_len to zero, else its value will be undefined. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2010-10-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: prevent infinite recursion in cifs_reconnect_tcon cifs: set backing_dev_info on new S_ISREG inodes
2010-10-01reiserfs: fix unwanted reiserfs lock recursionFrederic Weisbecker
Prevent from recursively locking the reiserfs lock in reiserfs_unpack() because we may call journal_begin() that requires the lock to be taken only once, otherwise it won't be able to release the lock while taking other mutexes, ending up in inverted dependencies between the journal mutex and the reiserfs lock for example. This fixes: ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.35.4.4a #3 ------------------------------------------------------- lilo/1620 is trying to acquire lock: (&journal->j_mutex){+.+...}, at: [<d0325bff>] do_journal_begin_r+0x7f/0x340 [reiserfs] but task is already holding lock: (&REISERFS_SB(s)->lock){+.+.+.}, at: [<d032a278>] reiserfs_write_lock+0x28/0x40 [reiserfs] which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&REISERFS_SB(s)->lock){+.+.+.}: [<c10562b7>] lock_acquire+0x67/0x80 [<c12facad>] __mutex_lock_common+0x4d/0x410 [<c12fb0c8>] mutex_lock_nested+0x18/0x20 [<d032a278>] reiserfs_write_lock+0x28/0x40 [reiserfs] [<d0325c06>] do_journal_begin_r+0x86/0x340 [reiserfs] [<d0325f77>] journal_begin+0x77/0x140 [reiserfs] [<d0315be4>] reiserfs_remount+0x224/0x530 [reiserfs] [<c10b6a20>] do_remount_sb+0x60/0x110 [<c10cee25>] do_mount+0x625/0x790 [<c10cf014>] sys_mount+0x84/0xb0 [<c12fca3d>] syscall_call+0x7/0xb -> #0 (&journal->j_mutex){+.+...}: [<c10560f6>] __lock_acquire+0x1026/0x1180 [<c10562b7>] lock_acquire+0x67/0x80 [<c12facad>] __mutex_lock_common+0x4d/0x410 [<c12fb0c8>] mutex_lock_nested+0x18/0x20 [<d0325bff>] do_journal_begin_r+0x7f/0x340 [reiserfs] [<d0325f77>] journal_begin+0x77/0x140 [reiserfs] [<d0326271>] reiserfs_persistent_transaction+0x41/0x90 [reiserfs] [<d030d06c>] reiserfs_get_block+0x22c/0x1530 [reiserfs] [<c10db9db>] __block_prepare_write+0x1bb/0x3a0 [<c10dbbe6>] block_prepare_write+0x26/0x40 [<d030b738>] reiserfs_prepare_write+0x88/0x170 [reiserfs] [<d03294d6>] reiserfs_unpack+0xe6/0x120 [reiserfs] [<d0329782>] reiserfs_ioctl+0x272/0x320 [reiserfs] [<c10c3188>] vfs_ioctl+0x28/0xa0 [<c10c3bbd>] do_vfs_ioctl+0x32d/0x5c0 [<c10c3eb3>] sys_ioctl+0x63/0x70 [<c12fca3d>] syscall_call+0x7/0xb other info that might help us debug this: 2 locks held by lilo/1620: #0: (&sb->s_type->i_mutex_key#8){+.+.+.}, at: [<d032945a>] reiserfs_unpack+0x6a/0x120 [reiserfs] #1: (&REISERFS_SB(s)->lock){+.+.+.}, at: [<d032a278>] reiserfs_write_lock+0x28/0x40 [reiserfs] stack backtrace: Pid: 1620, comm: lilo Not tainted 2.6.35.4.4a #3 Call Trace: [<c10560f6>] __lock_acquire+0x1026/0x1180 [<c10562b7>] lock_acquire+0x67/0x80 [<c12facad>] __mutex_lock_common+0x4d/0x410 [<c12fb0c8>] mutex_lock_nested+0x18/0x20 [<d0325bff>] do_journal_begin_r+0x7f/0x340 [reiserfs] [<d0325f77>] journal_begin+0x77/0x140 [reiserfs] [<d0326271>] reiserfs_persistent_transaction+0x41/0x90 [reiserfs] [<d030d06c>] reiserfs_get_block+0x22c/0x1530 [reiserfs] [<c10db9db>] __block_prepare_write+0x1bb/0x3a0 [<c10dbbe6>] block_prepare_write+0x26/0x40 [<d030b738>] reiserfs_prepare_write+0x88/0x170 [reiserfs] [<d03294d6>] reiserfs_unpack+0xe6/0x120 [reiserfs] [<d0329782>] reiserfs_ioctl+0x272/0x320 [reiserfs] [<c10c3188>] vfs_ioctl+0x28/0xa0 [<c10c3bbd>] do_vfs_ioctl+0x32d/0x5c0 [<c10c3eb3>] sys_ioctl+0x63/0x70 [<c12fca3d>] syscall_call+0x7/0xb Reported-by: Jarek Poplawski <jarkao2@gmail.com> Tested-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: All since 2.6.32 <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-01reiserfs: fix dependency inversion between inode and reiserfs mutexesFrederic Weisbecker
The reiserfs mutex already depends on the inode mutex, so we can't lock the inode mutex in reiserfs_unpack() without using the safe locking API, because reiserfs_unpack() is always called with the reiserfs mutex locked. This fixes: ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.35c #13 ------------------------------------------------------- lilo/1606 is trying to acquire lock: (&sb->s_type->i_mutex_key#8){+.+.+.}, at: [<d0329450>] reiserfs_unpack+0x60/0x110 [reiserfs] but task is already holding lock: (&REISERFS_SB(s)->lock){+.+.+.}, at: [<d032a268>] reiserfs_write_lock+0x28/0x40 [reiserfs] which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&REISERFS_SB(s)->lock){+.+.+.}: [<c1056347>] lock_acquire+0x67/0x80 [<c12f083d>] __mutex_lock_common+0x4d/0x410 [<c12f0c58>] mutex_lock_nested+0x18/0x20 [<d032a268>] reiserfs_write_lock+0x28/0x40 [reiserfs] [<d0329e9a>] reiserfs_lookup_privroot+0x2a/0x90 [reiserfs] [<d0316b81>] reiserfs_fill_super+0x941/0xe60 [reiserfs] [<c10b7d17>] get_sb_bdev+0x117/0x170 [<d0313e21>] get_super_block+0x21/0x30 [reiserfs] [<c10b74ba>] vfs_kern_mount+0x6a/0x1b0 [<c10b7659>] do_kern_mount+0x39/0xe0 [<c10cebe0>] do_mount+0x340/0x790 [<c10cf0b4>] sys_mount+0x84/0xb0 [<c12f25cd>] syscall_call+0x7/0xb -> #0 (&sb->s_type->i_mutex_key#8){+.+.+.}: [<c1056186>] __lock_acquire+0x1026/0x1180 [<c1056347>] lock_acquire+0x67/0x80 [<c12f083d>] __mutex_lock_common+0x4d/0x410 [<c12f0c58>] mutex_lock_nested+0x18/0x20 [<d0329450>] reiserfs_unpack+0x60/0x110 [reiserfs] [<d0329772>] reiserfs_ioctl+0x272/0x320 [reiserfs] [<c10c3228>] vfs_ioctl+0x28/0xa0 [<c10c3c5d>] do_vfs_ioctl+0x32d/0x5c0 [<c10c3f53>] sys_ioctl+0x63/0x70 [<c12f25cd>] syscall_call+0x7/0xb other info that might help us debug this: 1 lock held by lilo/1606: #0: (&REISERFS_SB(s)->lock){+.+.+.}, at: [<d032a268>] reiserfs_write_lock+0x28/0x40 [reiserfs] stack backtrace: Pid: 1606, comm: lilo Not tainted 2.6.35c #13 Call Trace: [<c1056186>] __lock_acquire+0x1026/0x1180 [<c1056347>] lock_acquire+0x67/0x80 [<c12f083d>] __mutex_lock_common+0x4d/0x410 [<c12f0c58>] mutex_lock_nested+0x18/0x20 [<d0329450>] reiserfs_unpack+0x60/0x110 [reiserfs] [<d0329772>] reiserfs_ioctl+0x272/0x320 [reiserfs] [<c10c3228>] vfs_ioctl+0x28/0xa0 [<c10c3c5d>] do_vfs_ioctl+0x32d/0x5c0 [<c10c3f53>] sys_ioctl+0x63/0x70 [<c12f25cd>] syscall_call+0x7/0xb Reported-by: Jarek Poplawski <jarkao2@gmail.com> Tested-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: <stable@kernel.org> [2.6.32 and later] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-01proc: make /proc/pid/limits world readableJiri Olsa
Having the limits file world readable will ease the task of system management on systems where root privileges might be restricted. Having admin restricted with root priviledges, he/she could not check other users process' limits. Also it'd align with most of the /proc stat files. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Cc: Eugene Teo <eugene@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-01cifs: prevent infinite recursion in cifs_reconnect_tconJeff Layton
cifs_reconnect_tcon is called from smb_init. After a successful reconnect, cifs_reconnect_tcon will call reset_cifs_unix_caps. That function will, in turn call CIFSSMBQFSUnixInfo and CIFSSMBSetFSUnixInfo. Those functions also call smb_init. It's possible for the session and tcon reconnect to succeed, and then for another cifs_reconnect to occur before CIFSSMBQFSUnixInfo or CIFSSMBSetFSUnixInfo to be called. That'll cause those functions to call smb_init and cifs_reconnect_tcon again, ad infinitum... Break the infinite recursion by having those functions use a new smb_init variant that doesn't attempt to perform a reconnect. Reported-and-Tested-by: Michal Suchanek <hramrach@centrum.cz> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: ocfs2: Don't walk off the end of fast symlinks.
2010-09-29ocfs2: Don't walk off the end of fast symlinks.Joel Becker
ocfs2 fast symlinks are NUL terminated strings stored inline in the inode data area. However, disk corruption or a local attacker could, in theory, remove that NUL. Because we're using strlen() (my fault, introduced in a731d1 when removing vfs_follow_link()), we could walk off the end of that string. Signed-off-by: Joel Becker <joel.becker@oracle.com> Cc: stable@kernel.org
2010-09-29cifs: set backing_dev_info on new S_ISREG inodesJeff Layton
Testing on very recent kernel (2.6.36-rc6) made this warning pop: WARNING: at fs/fs-writeback.c:87 inode_to_bdi+0x65/0x70() Hardware name: Dirtiable inode bdi default != sb bdi cifs ...the following patch fixes it and seems to be the obviously correct thing to do for cifs. Cc: stable@kernel.org Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29xfs: force background CIL push under sustained loadDave Chinner
I have been seeing occasional pauses in transaction throughput up to 30s long under heavy parallel workloads. The only notable thing was that the xfsaild was trying to be active during the pauses, but making no progress. It was running exactly 20 times a second (on the 50ms no-progress backoff), and the number of pushbuf events was constant across this time as well. IOWs, the xfsaild appeared to be stuck on buffers that it could not push out. Further investigation indicated that it was trying to push out inode buffers that were pinned and/or locked. The xfsbufd was also getting woken at the same frequency (by the xfsaild, no doubt) to push out delayed write buffers. The xfsbufd was not making any progress because all the buffers in the delwri queue were pinned. This scan- and-make-no-progress dance went one in the trace for some seconds, before the xfssyncd came along an issued a log force, and then things started going again. However, I noticed something strange about the log force - there were way too many IO's issued. 516 log buffers were written, to be exact. That added up to 129MB of log IO, which got me very interested because it's almost exactly 25% of the size of the log. He delayed logging code is suppose to aggregate the minimum of 25% of the log or 8MB worth of changes before flushing. That's what really puzzled me - why did a log force write 129MB instead of only 8MB? Essentially what has happened is that no CIL pushes had occurred since the previous tail push which cleared out 25% of the log space. That caused all the new transactions to block because there wasn't log space for them, but they kick the xfsaild to push the tail. However, the xfsaild was not making progress because there were buffers it could not lock and flush, and the xfsbufd could not flush them because they were pinned. As a result, both the xfsaild and the xfsbufd could not move the tail of the log forward without the CIL first committing. The cause of the problem was that the background CIL push, which should happen when 8MB of aggregated changes have been committed, is being held off by the concurrent transaction commit load. The background push does a down_write_trylock() which will fail if there is a concurrent transaction commit holding the push lock in read mode. With 8 CPUs all doing transactions as fast as they can, there was enough concurrent transaction commits to hold off the background push until tail-pushing could no longer free log space, and the halt would occur. It should be noted that there is no reason why it would halt at 25% of log space used by a single CIL checkpoint. This bug could definitely violate the "no transaction should be larger than half the log" requirement and hence result in corruption if the system crashed under heavy load. This sort of bug is exactly the reason why delayed logging was tagged as experimental.... The fix is to start blocking background pushes once the threshold has been exceeded. Rework the threshold calculations to keep the amount of log space a CIL checkpoint can use to below that of the AIL push threshold to avoid the problem completely. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-09-24Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: o2dlm: force free mles during dlm exit ocfs2: Sync inode flags with ext2. ocfs2: Move 'wanted' into parens of ocfs2_resmap_resv_bits. ocfs2: Use cpu_to_le16 for e_leaf_clusters in ocfs2_bg_discontig_add_extent. ocfs2: update ctime when changing the file's permission by setfacl ocfs2/net: fix uninitialized ret in o2net_send_message_vec() Ocfs2: Handle empty list in lockres_seq_start() for dlmdebug.c Ocfs2: Re-access the journal after ocfs2_insert_extent() in dxdir codes. ocfs2: Fix lockdep warning in reflink. ocfs2/lockdep: Move ip_xattr_sem out of ocfs2_xattr_get_nolock.
2010-09-23o2dlm: force free mles during dlm exitSrinivas Eeda
While umounting, a block mle doesn't get freed if dlm is shutdown after master request is received but before assert master. This results in unclean shutdown of dlm domain. This patch frees all mles that lie around after other nodes were notified about exiting the dlm and marking dlm state as leaving. Only block mles are expected to be around, so we log ERROR for other mles but still free them. Signed-off-by: Srinivas Eeda <srinivas.eeda@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-09-23ocfs2: Sync inode flags with ext2.Tao Ma
We sync our inode flags with ext2 and define them by hex values. But actually in commit 3669567(4 years ago), all these values are moved to include/linux/fs.h. So we'd better also use them as what ext2 did. So sync our inode flags with ext2 by using FS_*. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-09-23ocfs2: Move 'wanted' into parens of ocfs2_resmap_resv_bits.Tao Ma
The first time I read the function ocfs2_resmap_resv_bits, I consider about what 'wanted' will be used and consider about the comments. Then I find it is only used if the reservation is empty. ;) So we'd better move it to the parens so that it make the code more readable, what's more, ocfs2_resmap_resv_bits is used so frequently and we should save some cpus. Acked-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-09-23ocfs2: Use cpu_to_le16 for e_leaf_clusters in ocfs2_bg_discontig_add_extent.Tao Ma
e_leaf_clusters is a le16, so use cpu_to_le16 instead of cpu_to_le32. What's more, we change 'clusters' to unsigned int to signify that the size of 'clusters' isn't important here. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-09-23ocfs2: update ctime when changing the file's permission by setfaclTao Ma
In commit 30e2bab, ext3 fixed it. So change it accordingly in ocfs2. Steps to reproduce: # touch aaa # stat -c %Z aaa 1283760364 # setfacl -m 'u::x,g::x,o::x' aaa # stat -c %Z aaa 1283760364 Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-09-22/proc/pid/smaps: fix dirty pages accountingKOSAKI Motohiro
Currently, /proc/<pid>/smaps has wrong dirty pages accounting. Shared_Dirty and Private_Dirty output only pte dirty pages and ignore PG_dirty page flag. It is difference against documentation, but also inconsistent against Referenced field. (Referenced checks both pte and page flags) This patch fixes it. Test program: large-array.c --------------------------------------------------- #include <stdio.h> #include <stdlib.h> #include <string.h> #include <unistd.h> char array[1*1024*1024*1024L]; int main(void) { memset(array, 1, sizeof(array)); pause(); return 0; } --------------------------------------------------- Test case: 1. run ./large-array 2. cat /proc/`pidof large-array`/smaps 3. swapoff -a 4. cat /proc/`pidof large-array`/smaps again Test result: <before patch> 00601000-40601000 rw-p 00000000 00:00 0 Size: 1048576 kB Rss: 1048576 kB Pss: 1048576 kB Shared_Clean: 0 kB Shared_Dirty: 0 kB Private_Clean: 218992 kB <-- showed pages as clean incorrectly Private_Dirty: 829584 kB Referenced: 388364 kB Swap: 0 kB KernelPageSize: 4 kB MMUPageSize: 4 kB <after patch> 00601000-40601000 rw-p 00000000 00:00 0 Size: 1048576 kB Rss: 1048576 kB Pss: 1048576 kB Shared_Clean: 0 kB Shared_Dirty: 0 kB Private_Clean: 0 kB Private_Dirty: 1048576 kB <-- fixed Referenced: 388480 kB Swap: 0 kB KernelPageSize: 4 kB MMUPageSize: 4 kB Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-22aio: do not return ERESTARTSYS as a result of AIOJan Kara
OCFS2 can return ERESTARTSYS from its write function when the process is signalled while waiting for a cluster lock (and the filesystem is mounted with intr mount option). Generally, it seems reasonable to allow filesystems to return this error code from its IO functions. As we must not leak ERESTARTSYS (and similar error codes) to userspace as a result of an AIO operation, we have to properly convert it to EINTR inside AIO code (restarting the syscall isn't really an option because other AIO could have been already submitted by the same io_submit syscall). Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Zach Brown <zach.brown@oracle.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-22/proc/vmcore: fix seekingArnd Bergmann
Commit 73296bc611 ("procfs: Use generic_file_llseek in /proc/vmcore") broke seeking on /proc/vmcore. This changes it back to use default_llseek in order to restore the original behaviour. The problem with generic_file_llseek is that it only allows seeks up to inode->i_sb->s_maxbytes, which is zero on procfs and some other virtual file systems. We should merge generic_file_llseek and default_llseek some day and clean this up in a proper way, but for 2.6.35/36, reverting vmcore is the safer solution. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Reported-by: CAI Qian <caiqian@redhat.com> Tested-by: CAI Qian <caiqian@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-22Prevent freeing uninitialized pointer in compat_do_readv_writevDan Rosenberg
In 32-bit compatibility mode, the error handling for compat_do_readv_writev() may free an uninitialized pointer, potentially leading to all sorts of ugly memory corruption. This is reliably triggerable by unprivileged users by invoking the readv()/writev() syscalls with an invalid iovec pointer. The below patch fixes this to emulate the non-compat version. Introduced by commit b83733639a49 ("compat: factor out compat_rw_copy_check_uvector from compat_do_readv_writev") Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Cc: stable@kernel.org (2.6.35) Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-22Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: bdi: Fix warnings in __mark_inode_dirty for /dev/zero and friends char: Mark /dev/zero and /dev/kmem as not capable of writeback bdi: Initialize noop_backing_dev_info properly cfq-iosched: fix a kernel OOPs when usb key is inserted block: fix blk_rq_map_kern bio direction flag cciss: freeing uninitialized data on error path
2010-09-22bdi: Fix warnings in __mark_inode_dirty for /dev/zero and friendsJan Kara
Inodes of devices such as /dev/zero can get dirty for example via utime(2) syscall or due to atime update. Backing device of such inodes (zero_bdi, etc.) is however unable to handle dirty inodes and thus __mark_inode_dirty complains. In fact, inode should be rather dirtied against backing device of the filesystem holding it. This is generally a good rule except for filesystems such as 'bdev' or 'mtd_inodefs'. Inodes in these pseudofilesystems are referenced from ordinary filesystem inodes and carry mapping with real data of the device. Thus for these inodes we have to use inode->i_mapping->backing_dev_info as we did so far. We distinguish these filesystems by checking whether sb->s_bdi points to a non-trivial backing device or not. Example: Assume we have an ext3 filesystem on /dev/sda1 mounted on /. There's a device inode A described by a path "/dev/sdb" on this filesystem. This inode will be dirtied against backing device "8:0" after this patch. bdev filesystem contains block device inode B coupled with our inode A. When someone modifies a page of /dev/sdb, it's B that gets dirtied and the dirtying happens against the backing device "8:16". Thus both inodes get filed to a correct bdi list. Cc: stable@kernel.org Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-22char: Mark /dev/zero and /dev/kmem as not capable of writebackJan Kara
These devices don't do any writeback but their device inodes still can get dirty so mark bdi appropriately so that bdi code does the right thing and files inodes to lists of bdi carrying the device inodes. Cc: stable@kernel.org Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: select CRYPTO ceph: check mapping to determine if FILE_CACHE cap is used ceph: only send one flushsnap per cap_snap per mds session ceph: fix cap_snap and realm split ceph: stop sending FLUSHSNAPs when we hit a dirty capsnap ceph: correctly set 'follows' in flushsnap messages ceph: fix dn offset during readdir_prepopulate ceph: fix file offset wrapping at 4GB on 32-bit archs ceph: fix reconnect encoding for old servers ceph: fix pagelist kunmap tail ceph: fix null pointer deref on anon root dentry release
2010-09-19Coda: mount hangs because of missed REQ_WRITE renameJan Harkes
Coda's REQ_* defines were renamed to avoid clashes with the block layer (commit 4aeefdc69f7b: "coda: fixup clash with block layer REQ_* defines"). However one was missed and response messages are no longer matched with requests and waiting threads are no longer woken up. This patch fixes this. Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu> [ Also fixed up whitespace while at it -Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-18ocfs2/net: fix uninitialized ret in o2net_send_message_vec()Wu Fengguang
mmotm/fs/ocfs2/cluster/tcp.c: In function ‘o2net_send_message_vec’: mmotm/fs/ocfs2/cluster/tcp.c:980:6: warning: ‘ret’ may be used uninitialized in this function It seems a real bug introduced by commit 9af0b38ff3 (ocfs2/net: Use wait_event() in o2net_send_message_vec()). cc: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-09-17ceph: select CRYPTOSage Weil
We select CRYPTO_AES, but not CRYPTO. Signed-off-by: Sage Weil <sage@newdream.net>
2010-09-17ceph: check mapping to determine if FILE_CACHE cap is usedSage Weil
See if the i_data mapping has any pages to determine if the FILE_CACHE capability is currently in use, instead of assuming it is any time the rdcache_gen value is set (i.e., issued -> used). This allows the MDS RECALL_STATE process work for inodes that have cached pages. Signed-off-by: Sage Weil <sage@newdream.net>
2010-09-17ceph: only send one flushsnap per cap_snap per mds sessionSage Weil
Sending multiple flushsnap messages is problematic because we ignore the response if the tid doesn't match, and the server may only respond to each one once. It's also a waste. So, skip cap_snaps that are already on the flushing list, unless the caller tells us to resend (because we are reconnecting). Signed-off-by: Sage Weil <sage@newdream.net>
2010-09-17GFS2: gfs2_logd should be using interruptible waitsSteven Whitehouse
Looks like this crept in, in a recent update. Reported-by: Krzysztof Urbaniak <urban@bash.org.pl> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
