commit 8c20871998c082f6fbc963f1449a5ba5140ee39a upstream.
Commit df5e6223407e ("ext4: fix deadlock in ext4_symlink() in ENOSPC
conditions") recalculated the number of credits needed for a long
symlink, in the process of splitting it into two transactions. However,
the first credit calculation under-counted because if selinux is
enabled, credits are needed to create the selinux xattr as well.
Overrunning the reservation will result in an OOPS in
jbd2_journal_dirty_metadata() due to this assert:
J_ASSERT_JH(jh, handle->h_buffer_credits > 0);
Fix this by increasing the reservation size.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Acked-by: "Theodore Ts'o" <tytso@mit.edu>
commit d2db60df1e7eb39cf0f378dfc4dd8813666d46ef upstream.
Commit ae54870a1dc9 ("ext3: Fix lock inversion in ext3_symlink()")
recalculated the number of credits needed for a long symlink, in the
process of splitting it into two transactions. However, the first
credit calculation under-counted because if selinux is enabled, credits
commit f61500e000eedc0c7a0201200a7f00ba5529c002 upstream.
When an eCryptfs inode's lower file has been closed, and the pointer has
been set to NULL, return an error when trying to do a lower read or
write rather than calling BUG().
https://bugzilla.kernel.org/show_bug.cgi?id=37292
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
commit 764355487ea220fdc2faf128d577d7f679b91f97 upstream.
Close a TOCTOU race for mounts done via ecryptfs-mount-private. The mount
source (device) can be raced when the ownership test is done in userspace.
Provide Ecryptfs a means to force the uid check at mount time.
Signed-off-by: John Johansen <john.johansen@canonical.com>
commit f9e8c45002cacad536b338dfa9e910e341a49c31 upstream.
Regression from 2.6.39...
The delimiters in the prefixpath are not being converted based on
whether posix paths are in effect. Fixes:
https://bugzilla.redhat.com/show_bug.cgi?id=727834
Reported-and-Tested-by: Iain Arnell <iarnell@gmail.com>
Reported-by: Patrick Oltmann <patrick.oltmann@gmx.net>
Cc: Pavel Shilovsky <piastryyy@gmail.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit 80975d21aae2136ccae1ce914a1602dc1d8b0795 upstream.
The loop around lookup_one_len doesn't handle the case where it might
return a negative dentry, which can cause an oops on the next pass
through the loop. Check for that and break out of the loop with an
error of -ENOENT if there is one.
Fixes the panic reported here:
https://bugzilla.redhat.com/show_bug.cgi?id=727927
Reported-by: TR Bentley <home@trarbentley.net>
Reported-by: Iain Arnell <iarnell@gmail.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
commit 0193e072268fe62c4b19ad4b05cd0d4b23c43bb9 upstream.
if we failed on getting mid entry in cifs_call_async.
Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com>
commit 19237039919088781b4191a00bdc1284d8fea1dd upstream.
Depending upon the order of userspace/kernel during the
mount process, this can result in a hang without the
_all version of the completion.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
commit 293eb1e7772b25a93647c798c7b89bf26c2da2e0 upstream.
If an inode's mode permits opening /proc/PID/io and the resulting file
descriptor is kept across execve() of a setuid or similar binary, the
ptrace_may_access() check tries to prevent using this fd against the
task with escalated privileges.
Unfortunately, there is a race in the check against execve(). If
execve() is processed after the ptrace check, but before the actual io
information gathering, io statistics will be gathered from the
privileged process. At least in theory this might lead to gathering
sensible information (like ssh/ftp password length) that wouldn't be
available otherwise.
Holding task->signal->cred_guard_mutex while gathering the io
information should protect against the race.
The order of locking is similar to the one inside of ptrace_attach():
first goes cred_guard_mutex, then lock_task_sighand().
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
commit 0c0308066ca53fdf1423895f3a42838b67b3a5a8 upstream.
If the directory contents change, then we have to accept that the
file->f_pos value may shrink if we do a 'search-by-cookie'. In that
case, we should turn off the loop detection and let the NFS client
try to recover.
The patch also fixes a second loop detection bug by ensuring
that after turning on the ctx->duped flag, we read at least one new
cookie into ctx->dir_cookie before attempting to match with
ctx->dup_cookie.
Reported-by: Petr Vandrovec <petr@vandrovec.name>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit ed1e6211a0a134ff23592c6f057af982ad5dab52 upstream.
nfs_mark_return_delegation() is usually called without any locking, and
so it is not safe to dereference delegation->inode. Since the inode is
only used to discover the nfs_client anyway, it makes more sense to
have the callers pass a valid pointer to the nfs_server as a parameter.
Reported-by: Ian Kent <raven@themaw.net>
commit f197c27196a5e7631b89e2e92daa096fcf7c302c upstream.
Stateid's hold a read reference for a read open, a write reference for a
write open, and an additional one of each for each read+write open. The
latter wasn't getting put on a downgrade, so something like:
open RW
open R
downgrade to R
was resulting in a file leak.
Also fix an imbalance in an error path.
Regression from 7d94784293096c0a46897acdb83be5abd9278ece "nfsd4: fix
downgrade/lock logic".
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 499f3edc23ca0431f3a0a6736b3a40944c81bf3b upstream.
Without this, for example,
open read
open read+write
close
will result in a struct file leak.
commit 0c12eaffdf09466f36a9ffe970dda8f4aeb6efc0 upstream.
CLAIM_DELEGATE_CUR is used in response to a broken lease; allowing it
to break the lease and return EAGAIN leaves the client unable to make
progress in returning the delegation
nfs4_get_vfs_file() now takes struct nfsd4_open for access to the
claim type, and calls nfsd_open() with NFSD_MAY_NOT_BREAK_LEASE when
claim type is CLAIM_DELEGATE_CUR
Signed-off-by: Casey Bodley <cbodley@citi.umich.edu>
commit b2987a5e05ec7a1af7ca42e5d5349d7a22753031 upstream.
Fixes a regression caused by b5695d04634fa4ccca7dcbc05bb4a66522f02e0b
Kernel keyring keys containing eCryptfs authentication tokens should not
be write locked when calling out to ecryptfsd to wrap and unwrap file
encryption keys. The eCryptfs kernel code can not hold the key's write
lock because ecryptfsd needs to request the key after receiving such a
request from the kernel.
Without this fix, all file opens and creates will timeout and fail when
using the eCryptfs PKI infrastructure. This is not an issue when using
passphrase-based mount keys, which is the most widely deployed eCryptfs
configuration.
Acked-by: Roberto Sassu <roberto.sassu@polito.it>
Tested-by: Roberto Sassu <roberto.sassu@polito.it>
Tested-by: Alexis Hafner1 <haf@zurich.ibm.com>
commit 985ca0e626e195ea08a1a82b8dbeb6719747429a upstream.
Make the inode mapping bdi consistent with the superblock bdi so that
dirty pages are flushed properly.
Signed-off-by: Thieu Le <thieule@chromium.org>
commit ad95c5e9bc8b5885f94dce720137cac8fa8da4c9 upstream.
Block allocation is called from two places: ext3_get_blocks_handle() and
ext3_xattr_block_set(). These two callers are not necessarily synchronized
because xattr code holds only xattr_sem and i_mutex, and
ext3_get_blocks_handle() may hold only truncate_mutex when called from
writepage() path. Block reservation code does not expect two concurrent
allocations to happen to the same inode and thus assertions can be triggered
or reservation structure corruption can occur.
Fix the problem by taking truncate_mutex in xattr code to serialize
allocations.
CC: Sage Weil <sage@newdream.net>
Reported-by: Fyodor Ustinov <ufm@ufm.su>
commit 575a1d4bdfa2ea9fc10733013136145b497e1be0 upstream.
Upon corrupted inode or disk failures, we may fail after we already
allocate some blocks from the inode or take some blocks from the
inode's preallocation list, but before we successfully insert the
corresponding extent to the extent tree. In this case, we should free
any allocated blocks and discard the inode's preallocated blocks
because the entries in the inode's preallocation list may be in an
inconsistent state.
Signed-off-by: Jiaying Zhang <jiayingz@google.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 7132de744ba76930d13033061018ddd7e3e8cd91 upstream.
The current implementation of ext4_free_blocks() always calls
dquot_free_block This looks quite sensible in the most cases: blocks
to be freed are associated with inode and were accounted in quota and
i_blocks some time ago.
However, there is a case when blocks to free were not accounted by the
time calling ext4_free_blocks() yet:
1. delalloc is on, write_begin pre-allocated some space in quota
2. write-back happens, ext4 allocates some blocks in ext4_ext_map_blocks()
3. then ext4_ext_map_blocks() gets an error (e.g. ENOSPC) from
ext4_ext_insert_extent() and calls ext4_free_blocks().
In this scenario, ext4_free_blocks() calls dquot_free_block() who, in
turn, decrements i_blocks for blocks which were not accounted yet (due
to delalloc) After clean umount, e2fsck reports something like:
> Inode 21, i_blocks is 5080, should be 5128. Fix<y>?
because i_blocks was erroneously decremented as explained above.
The patch fixes the problem by passing the new flag
EXT4_FREE_BLOCKS_NO_QUOT_UPDATE to ext4_free_blocks(), to request
that the dquot_free_block() call be skipped.
Signed-off-by: Maxim Patlasov <maxim.patlasov@gmail.com>
commit 3557c6c3be5b2ca0b11365db7f8a813253eb520b upstream.
Using NFS4_MAX_UINT64 will break current protocol.
[Needed in v3.0]
Signed-off-by: Peng Tao <peng_tao@emc.com>
Signed-off-by: Jim Rees <rees@umich.edu>
commit a9bae5666d0510ad69bdb437371c9a3e6b770705 upstream.
There can be multiple lseg per file, so layoutcommit should be
able to handle it.
[Needed in v3.0]
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
commit 9fa4075878a5faac872a63f4a97ce79c776264e9 upstream.
No need to save it for every lseg.
No need to save it at every pnfs_set_layoutcommit.
[Needed in v3.0]
commit acff5880539fe33897d016c0f3dcf062e67c61b6 upstream.
[Needed in v3.0]
commit f5bc1e755d23d022bf948904386337fc3e5e29a8 upstream.
commit fec11dd9a0109fe52fd631e5c510778d6cbff6cc caused
a regression when we have already mounted //server/share/a
and want to mount //server/share/a/b.
The problem is that lookup_one_len calls __lookup_hash
with nd pointer as NULL. Then __lookup_hash calls
do_revalidate in the case when dentry exists and we end
up with NULL pointer deference in cifs_d_revalidate:
if (nd->flags & LOOKUP_RCU)
return -ECHILD;
Fix this by checking nd for NULL.
Reviewed-by: Shirish Pargaonkar <shirishp@us.ibm.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6:
CIFS: Fix wrong length in cifs_iovec_read
It seems to hurt performance in real life. Yes, the inode will be used
later, but the conditional doesn't seem to predict all that well
(negative dentries are not uncommon) and it looks like the cost of
prefetching is simply higher than depending on the cache doing the right
thing.
As usual.
The compiler, at least for ix86 and m68k, validly warns that the
comparison:
next <= (loff_t)-1
is always true (and it's always true also for x86-64 and probably all
other arches - as long as pgoff_t isn't wider than loff_t). The
intention appears to be to avoid wrapping of "next", so rather than
eliminating the pointless comparison, fix the loop to indeed get exited
when "next" would otherwise wrap.
On m68k the following warning is observed:
fs/fscache/page.c: In function '__fscache_uncache_all_inode_pages':
fs/fscache/page.c:979: warning: comparison is always false due to limited range of data type
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Reported-by: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: Suresh Jayaraman <sjayaraman@suse.de>
Cc: stable@kernel.org
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Assume that /sys/kernel/debug/dummy64 is debugfs file created by
debugfs_create_x64().
# cd /sys/kernel/debug
# echo 0x1234567812345678 > dummy64
# cat dummy64
0x0000000012345678
# echo 0x80000000 > dummy64
# cat dummy64
0xffffffff80000000
A value larger than INT_MAX cannot be written to the debugfs file created
by debugfs_create_u64 or debugfs_create_x64 on 32bit machine. Because
simple_attr_write() uses simple_strtol() for the conversion.
To fix this, use simple_strtoll() instead.
Cc: Greg Kroah-Hartman <gregkh@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
vfs: fix race in rcu lookup of pruned dentry
Fix cifs_get_root()
[ Edited the last commit to get rid of a 'unused variable "seq"'
warning due to Al editing the patch. - Linus ]
Don't update *inode in __follow_mount_rcu() until we'd verified that
there is mountpoint there. Kudos to Hugh Dickins for catching that
one in the first place and eventually figuring out the solution (and
catching a braino in the earlier version of patch).
Add missing ->i_mutex, convert to lookup_one_len() instead of
(broken) open-coded analog, cope with getting something like
a//b as relative pathname. Simplify the hell out of it, while
we are there...
hppfs_lookup(): don't open-code lookup_one_len()
hppfs: fix dentry leak
cramfs: get_cramfs_inode() returns ERR_PTR() on failure
ufs should use d_splice_alias()
fix exofs ->get_parent()
ceph analog of cifs build_path_from_dentry() race fix
cifs: build_path_from_dentry() race fix
... and it's getting it wrong, too - missing ->d_revalidate() calls when
it's dealing with filesystem (procfs) that has non-trivial ->d_revalidate()...
... and we want to report these failures in ->lookup() anyway.
it's NFS-exportable, so...
NULL is not a possible return value for that method, TYVM...
[CIFS] update cifs to version 1.74
[CIFS] update limit for snprintf in cifs_construct_tcon
cifs: Fix signing failure when server mandates signing for NTLMSSP
... unfortunately, cifs bug got copied. Fix is essentially the same.
deal with d_move() races properly; rename_lock read-retry loop,
rcu_read_lock() held while walking to root, d_lock held over
subtraction from namelen and copying the component to stabilize
->d_name.
fix loop checks in d_materialise_unique()
Fix ->d_lock locking order in unlazy_walk()
Both __d_unalias() and __d_materialise_dentry() need loop prevention.
Grab rename_lock in caller, check for loops there...
As a side benefit, we have dentry_lock_for_move() called only under
rename_lock, which seriously reduces deadlock potential of the
execrable "locking order" used for ->d_lock.
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixes:
GFS2: Resolve inode eviction and ail list interaction bug
GFS2: Fix race during filesystem mount
GFS2: force a log flush when invalidating the rindex glock
This patch contains a few misc fixes which resolve a recently
reported issue. This patch has been a real team effort and has
received a lot of testing.
The first issue is that the ail lock needs to be held over a few
more operations. The lock thats added into gfs2_releasepage() may
possibly be a candidate for replacing with RCU at some future
point, but at this stage we've gone for the obvious fix.
The second issue is that gfs2_write_inode() can end up calling
a glock recursively when called from gfs2_evict_inode() via the
syncing code, so it needs a guard added.
The third issue is that we either need to not truncate the metadata
pages of inodes which have zero link count, but which we cannot
deallocate due to them still being in use by other nodes, or we need
to ensure that those pages have all made it through the journal and
ail lists first. This patch takes the former approach, but the
latter has also been tested and there is nothing to choose between
them performance-wise. So again, we could revise that decision
in the future.
Also, the inode eviction process is now better documented.
Tested-by: Bob Peterson <rpeterso@redhat.com>
Tested-by: Abhijith Das <adas@redhat.com>
Reported-by: Barry J. Marson <bmarson@redhat.com>
Reported-by: David Teigland <teigland@redhat.com>
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
SUNRPC: Fix use of static variable in rpcb_getport_async
NFSv4.1: update nfs4_fattr_bitmap_maxsz
SUNRPC: Fix a race between work-queue and rpc_killall_tasks
pnfs: write: Set mds_offset in the generic layer - it is needed by all LDs
Make sure that child is still a child of parent before nested locking
of child->d_lock in unlazy_walk(); otherwise we are risking a violation
of locking order and deadlocks.
In 34c87901e113 "Shrink stack space usage in cifs_construct_tcon" we
change the size of the username name buffer from MAX_USERNAME_SIZE
(256) to 28. This call to snprintf() needs to be updated as well.
Reported by Dan Carpenter.
Reviewed-by: Dan Carpenter <error27@gmail.com>
When using NTLMSSP authentication mechanism, if server mandates
signing, keep the flags in type 3 messages of the NTLMSSP exchange
same as in type 1 messages (i.e. keep the indicated capabilities same).
Some of the servers such as Samba, expect the flags such as
Negotiate_Key_Exchange in type 3 message of NTLMSSP exchange as well.
Some servers like Windows do not.
https://bugzilla.samba.org/show_bug.cgi?id=8212
Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail>
Acked-by: Jeff Layton <jlayton@redhat.com>
