path: root/fs
2006-03-01ocfs2: Respond to on-disk corruption in the extent map code.Joel Becker
The extent map code has long noticed when the on-disk extent information is corrupt. However, so far it has only returned an error. We should take the filesystem read-only, as it is corrupt. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-03-01ocfs2: Set .owner on masklog sysfs attributes.Joel Becker
2006-03-01[PATCH] ocfs2: fix orphan recovery deadlockMark Fasheh
Orphan dir recovery can deadlock with another process in ocfs2_delete_inode() in some corner cases. Fix this by tracking recovery state more closely and allowing it to handle inode wipes which might deadlock. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-03-01[PATCH] ocfs2: complete failure recovery for nodemanager initJeff Mahoney
This patch finishes cleaning up the node manager allocations if it fails to initialize. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-03-01[PATCH] ocfs2: remove non existing function prototypesMark Fasheh
Remove some prototypes from tcp.h for functions which have long been gone. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-03-01[PATCH] ocfs2: remove unused codeMark Fasheh
Remove some #ifdef'd out code which was inadvertantly introduced in our initial merge. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-03-01[PATCH] ocfs2: remove pointless max journal size limitMark Fasheh
2006-03-01[PATCH] ocfs2: fix -Wformat warnings when building UML on x86-64Jeff Mahoney
The check to determine which format string is appopriate for u64 and friends works in most cases, but UML on x86_64 doesn't define CONFIG_X86_64, so it results in screen fulls of compile-time warnings. This patch fixes it to handle that case. fs/ocfs2/cluster/masklog.h | 2 +- 1 files changed, 1 insertion(+), 1 deletion(-) Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-02-28[PATCH] Add mm->task_size and fix powerpc vdsoBenjamin Herrenschmidt
This patch adds mm->task_size to keep track of the task size of a given mm and uses that to fix the powerpc vdso so that it uses the mm task size to decide what pages to fault in instead of the current thread flags (which broke when ptracing). (akpm: I expect that mm_struct.task_size will become the way in which we finally sort out the confusion between 32-bit processes and 32-bit mm's. It may need tweaks, but at this stage this patch is powerpc-only.) Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-28[PATCH] fuse: fix bug in negative lookupMiklos Szeredi
If negative entries (nodeid == 0) were sent in reply to LOOKUP requests, two bugs could be triggered: - looking up a negative entry would return -EIO, - revaildate on an entry which turned negative would send a FORGET request with zero nodeid, which would cause an abort() in the library. The above would only happen if the 'negative_timeout=N' option was used, otherwise lookups reply -ENOENT, which worked correctly. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-28[XFS] Don't map non-uptodate buffers in xfs_probe_cluster; also fixesEric Sandeen
obscure corruption case SGI-PV: 942658 SGI-Modid: xfs-linux-melb:xfs-kern:207119a Signed-off-by: Eric Sandeen <sandeen@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-02-28[XFS] Reduce stack use during quota mounts (caused a panic). ThisNathan Scott
regressed recently via the fix for inherited quota inode attributes. SGI-PV: 947312 SGI-Modid: xfs-linux-melb:xfs-kern:25318a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-02-28[XFS] Fix a realtime allocator regression introduced by an old iget raceNathan Scott
fix. Noticed by Roger Willcocks. SGI-PV: 949821 SGI-Modid: xfs-linux-melb:xfs-kern:25257a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-02-26[PATCH] x86_64: Fix ioctl compat code for /dev/rtcAndi Kleen
RTC_IRQP_SET/RTC_EPOCH_SET don't take a pointer to an argument, but the argument itself. This actually simplifies the code and makes it work. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-26[PATCH] x86_64: Check for bad elf entry address.Suresh Siddha
Fixes a local DOS on Intel systems that lead to an endless recursive fault. AMD machines don't seem to be affected. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/aia21/ntfs-2.6Linus Torvalds
2006-02-24[PATCH] ramfs: update dir mtime and ctimeAndrew Morton
Phil Marek <philipp.marek@bmlv.gv.at> points out that ramfs forgets to update a directory's mtime and ctime when it is modified. Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] flags parameter for linkatUlrich Drepper
I'm currently at the POSIX meeting and one thing covered was the incompatibility of Linux's link() with the POSIX definition. The name. Linux does not follow symlinks, POSIX requires it does. Even if somebody thinks this is a good default behavior we cannot change this because it would break the ABI. But the fact remains that some application might want this behavior. We have one chance to help implementing this without breaking the behavior. For this we could use the new linkat interface which would need a new flags parameter. If the new parameter is AT_SYMLINK_FOLLOW the new behavior could be invoked. I do not want to introduce such a patch now. But we could add the parameter now, just don't use it. The patch below would do this. Can we get this late patch applied before the release more or less fixes the syscall API? Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24NTFS: Do more detailed reporting of why we cannot mount read-write byAnton Altaparmakov
special casing the VOLUME_MODIFIED_BY_CHKDSK flag. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2006-02-24NTFS: Implement support for sector sizes above 512 bytes (up to the maximumAnton Altaparmakov
supported by NTFS which is 4096 bytes).
2006-02-24Merge ../ntfs-2.6-develAnton Altaparmakov
2006-02-24NTFS: - Cope with attribute list attribute having invalid flags.Anton Altaparmakov
Windows copes with this and even chkdsk does not detect or fix this so we have to cope with it, too. Thanks to Pawel Kot for reporting the problem. - Miscellaneous updates to layout.h. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2006-02-24Merge branch 'master' of /home/src/linux-2.6/Anton Altaparmakov
2006-02-22[PATCH] CIFS: CIFSSMBRead was returning an invalid pointer in buf on socket ↵Steve French
error Thanks to Adrian Bunk for debugging the problem and to Shaggy for helping find the solution. Also added a fix for 64K pages we found in loosely-related testing Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-22Revert mount/umount uevent removalGreg Kroah-Hartman
This change reverts the 033b96fd30db52a710d97b06f87d16fc59fee0f1 commit from Kay Sievers that removed the mount/umount uevents from the kernel. Some older versions of HAL still depend on these events to detect when a new device has been mounted. These events are not correctly emitted, and are broken by design, and so, should not be relied upon by any future program. Instead, the /proc/mounts file should be polled to properly detect this kind of event. A feature-removal-schedule.txt entry has been added, noting when this interface will be removed from the kernel. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-20Merge branch 'fixes.b8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/bird
2006-02-20[PATCH] v9fs: update documentation and fix debug flagEric Van Hensbergen
Minor updates to the documentation to bring them into sync with current websites and available features. The debug flag was switched back to hex to match the documentation. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-18[PATCH] fix handling of st_nlink on procfs rootAl Viro
1) it should use nr_processes(), not nr_threads; otherwise we are getting very confused find(1) and friends, among other things. 2) better do that at stat() time than at every damn lookup in procfs root. Patch had been sitting in FC4 kernels for many months now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-02-17[PATCH] select: time comparison fixesAndrew Morton
I got all of these backwards. We want to return min(input timeout, new timeout) to userspace to prevent increasing the time-remaining value. Thanks to Ernst Herzberg <earny@net4u.de> for reporting and diagnosing. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] fuse: fix bug in aborted fuse_release_end()Miklos Szeredi
There's a rather theoretical case of the BUG triggering in fuse_reset_request(): - iget() fails because of OOM after a successful CREATE_OPEN request - during IO on the resulting RELEASE request the connection is aborted Fix and add warning to fuse_reset_request(). Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] fix deadlock in ext2Peter Staubach
Fix a deadlock possible in the ext2 file system implementation. This deadlock occurs when a file is removed from an ext2 file system which was mounted with the "sync" mount option. The problem is that ext2_xattr_delete_inode() was invoking the routine, sync_dirty_buffer(), using a buffer head which was previously locked via lock_buffer(). The first thing that sync_dirty_buffer() does is to lock the buffer head that it was passed. It does this via lock_buffer(). Oops. The solution is to unlock the buffer head in ext2_xattr_delete_inode() before invoking sync_dirty_buffer(). This makes the code in ext2_xattr_delete_inode() obey the same locking rules as all other callers of sync_dirty_buffer() in the ext2 file system implementation. Signed-off-by: Peter Staubach <staubach@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-16[PATCH] ocfs2: detach from heartbeat events before freeing mleKurt Hackel
Signed-off-by: Kurt Hackel <Kurt.Hackel@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-02-16[PATCH] ocfs2: only checkpoint journal when asked toMark Fasheh
Disable automatic checkpointing of the journal - this is a relic from older ocfs2 days. Worth quite a bit of performance on longer running single node tests. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-02-16[PATCH] ocfs2: manually grant remote recovery lockKurt Hackel
* fix a hang in recovery that occurred in dlmlock_remote. the $RECOVERY lock was never moved to the granted queue even after getting DLM_NORMAL back from the master node. Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-02-16[PATCH] ocfs2: add dlm_wait_for_node_deathKurt Hackel
* add dlm_wait_for_node_death function to be used after receiving a network error. this will wait for the given timeout to allow the heartbeat callbacks to update the domain map. without this, some paths may spin and consume enough cpu that the heartbeat gets starved and never updates. Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-02-16[PATCH] ocfs2: fix release of ast never reservedKurt Hackel
* fix a bug in dlm_convert_lock_handler where dlm_lockres_release_ast was being called even if no ast was ever reserved Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-02-16[PATCH] ocfs2: recheck recovery state after getting lockKurt Hackel
* after successfully taking the $RECOVERY lock in EX mode, recheck to make sure that recovery has not already begun or completed on another node Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-02-15[PATCH] fix zap_thread's ptrace related problemsOleg Nesterov
1. The tracee can go from ptrace_stop() to do_signal_stop() after __ptrace_unlink(p). 2. It is unsafe to __ptrace_unlink(p) while p->parent may wait for tasklist_lock in ptrace_detach(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christoph Hellwig <hch@lst.de> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[PATCH] CIFS: fix cifs_user_read oops when null SMB response on ↵Steve French
forcedirectio mount This patch fixes an oops reported by Adrian Bunk in cifs_user_read when a null read response is returned on a forcedirectio mount. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[PATCH] NLM: Fix the NLM_GRANTED callback checksTrond Myklebust
If 2 threads attached to the same process are blocking on different locks on different files (maybe even on different servers) but have the same lock arguments (i.e. same offset+length - actually quite common, since most processes try to lock the entire file) then the first GRANTED call that wakes one up will also wake the other. Currently when the NLM_GRANTED callback comes in, lockd walks the list of blocked locks in search of a match to the lock that the NLM server has granted. Although it checks the lock pid, start and end, it fails to check the filehandle and the server address. By checking the filehandle and server IP address, we ensure that this only happens if the locks truly are referencing the same file. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[PATCH] jbd: revert checkpoint list changesMark Fasheh
This patch reverts commit f93ea411b73594f7d144855fd34278bcf34a9afc: [PATCH] jbd: split checkpoint lists This broke journal_flush() for OCFS2, which is its method of being sure that metadata is sent to disk for another node. And two related commits 8d3c7fce2d20ecc3264c8d8c91ae3beacdeaed1b and 43c3e6f5abdf6acac9b90c86bf03f995bf7d3d92 with the subjects: [PATCH] jbd: log_do_checkpoint fix [PATCH] jbd: remove_transaction fix These seem to be incremental bugfixes on the original patch and as such are no longer needed. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-13[PATCH] reiserfs: fix potential (unlikely) oops in reiserfs_get_aclJeff Mahoney
This fixes a potential oops if there is an error reported by posix_acl_from_disk(). This is mostly theoretical due to the use of magics and checksums in xattrs, but is still possible. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-12[PATCH] reiserfs: disable automatic enabling of reiserfs inode attributesJeff Mahoney
Unfortunately, the reiserfs_attrs_cleared bit in the superblock flag can lie. File systems have been observed with the bit set, yet still contain garbage in the stat data field, causing unpredictable results. This patch backs out the enable-by-default behavior. It eliminates the changes from: d50a5cd860ce721dbeac6a4f3c6e42abcde68cd8, and ef5e5414e7a83eb9b4295bbaba5464410b11e030. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-11[PATCH] select: fix returned timevalAndrew Morton
With David Woodhouse <dwmw2@infradead.org> select() presently has a habit of increasing the value of the user's `timeout' argument on return. We were writing back a timeout larger than the original. We _deliberately_ round up, since we know we must wait at _least_ as long as the caller asks us to. The patch adds a couple of helper functions for magnitude comparison of timespecs and of timevals, and uses them to prevent the various poll and select functions from returning a timeout which is larger than the one which was passed in. The patch also fixes a bug in compat_sys_pselect7(): it was adding the new timeout value to the old one and was returning that. It should just return the new timeout value. (We have various handy timespec/timeval-to-from-nsec conversion functions in time.h. But this code open-codes it all). Cc: "David S. Miller" <davem@davemloft.net> Cc: Andi Kleen <ak@muc.de> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: george anzinger <george@mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-11[PATCH] fstatat64 supportUlrich Drepper
The *at patches introduced fstatat and, due to inusfficient research, I used the newfstat functions generally as the guideline. The result is that on 32-bit platforms we don't have all the information needed to implement fstatat64. This patch modifies the code to pass up 64-bit information if __ARCH_WANT_STAT64 is defined. I renamed the syscall entry point to make this clear. Other archs will continue to use the existing code. On x86-64 the compat code is implemented using a new sys32_ function. this is what is done for the other stat syscalls as well. This patch might break some other archs (those which define __ARCH_WANT_STAT64 and which already wired up the syscall). Yet others might need changes to accomodate the compatibility mode. I really don't want to do that work because all this stat handling is a mess (more so in glibc, but the kernel is also affected). It should be done by the arch maintainers. I'll provide some stand-alone test shortly. Those who are eager could compile glibc and run 'make check' (no installation needed). The patch below has been tested on x86 and x86-64. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-08[PATCH] compat_ioctl __user annotationsAl Viro
2006-02-07[PATCH] umount_tree() decrements mount count on wrong dentryAl Viro
2006-02-07[PATCH] nfsroot port= parameter fix [backport of 2.4 fix]Al Viro
Direct backport of 2.4 fix that didn't get propagated to 2.6; original comment follows: <quote> When I specify the NFS port for nfsroot (e.g., nfsroot=<dir>,port=2049), the kernel uses the wrong port. In my case it tries to use 264 (0x108) instead of 2049 (0x801). This patch adds the missing htons(). Eric </quote> Patch got applied in 2.4.21-pre6. Author: Eric Lammerts (<eric@lammerts.org>, AFAICS). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-02-07[PATCH] fix __user annotations in fs/select.cAl Viro
2006-02-07[PATCH] remove bogus asm/bug.h includes.Al Viro
A bunch of asm/bug.h includes are both not needed (since it will get pulled anyway) and bogus (since they are done too early). Removed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
