path: root/fs
2015-01-29mm: non-atomically mark page accessed during page cache allocation where ↵Mel Gorman
possible commit 2457aec63745e235bcafb7ef312b182d8682f0fc upstream. aops->write_begin may allocate a new page and make it visible only to have mark_page_accessed called almost immediately after. Once the page is visible the atomic operations are necessary which is noticable overhead when writing to an in-memory filesystem like tmpfs but should also be noticable with fast storage. The objective of the patch is to initialse the accessed information with non-atomic operations before the page is visible. The bulk of filesystems directly or indirectly use grab_cache_page_write_begin or find_or_create_page for the initial allocation of a page cache page. This patch adds an init_page_accessed() helper which behaves like the first call to mark_page_accessed() but may called before the page is visible and can be done non-atomically. The primary APIs of concern in this care are the following and are used by most filesystems. find_get_page find_lock_page find_or_create_page grab_cache_page_nowait grab_cache_page_write_begin All of them are very similar in detail to the patch creates a core helper pagecache_get_page() which takes a flags parameter that affects its behavior such as whether the page should be marked accessed or not. Then old API is preserved but is basically a thin wrapper around this core function. Each of the filesystems are then updated to avoid calling mark_page_accessed when it is known that the VM interfaces have already done the job. There is a slight snag in that the timing of the mark_page_accessed() has now changed so in rare cases it's possible a page gets to the end of the LRU as PageReferenced where as previously it might have been repromoted. This is expected to be rare but it's worth the filesystem people thinking about it in case they see a problem with the timing change. It is also the case that some filesystems may be marking pages accessed that previously did not but it makes sense that filesystems have consistent behaviour in this regard. The test case used to evaulate this is a simple dd of a large file done multiple times with the file deleted on each iterations. The size of the file is 1/10th physical memory to avoid dirty page balancing. In the async case it will be possible that the workload completes without even hitting the disk and will have variable results but highlight the impact of mark_page_accessed for async IO. The sync results are expected to be more stable. The exception is tmpfs where the normal case is for the "IO" to not hit the disk. The test machine was single socket and UMA to avoid any scheduling or NUMA artifacts. Throughput and wall times are presented for sync IO, only wall times are shown for async as the granularity reported by dd and the variability is unsuitable for comparison. As async results were variable do to writback timings, I'm only reporting the maximum figures. The sync results were stable enough to make the mean and stddev uninteresting. The performance results are reported based on a run with no profiling. Profile data is based on a separate run with oprofile running. async dd 3.15.0-rc3 3.15.0-rc3 vanilla accessed-v2 ext3 Max elapsed 13.9900 ( 0.00%) 11.5900 ( 17.16%) tmpfs Max elapsed 0.5100 ( 0.00%) 0.4900 ( 3.92%) btrfs Max elapsed 12.8100 ( 0.00%) 12.7800 ( 0.23%) ext4 Max elapsed 18.6000 ( 0.00%) 13.3400 ( 28.28%) xfs Max elapsed 12.5600 ( 0.00%) 2.0900 ( 83.36%) The XFS figure is a bit strange as it managed to avoid a worst case by sheer luck but the average figures looked reasonable. samples percentage ext3 86107 0.9783 vmlinux-3.15.0-rc4-vanilla mark_page_accessed ext3 23833 0.2710 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed ext3 5036 0.0573 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed ext4 64566 0.8961 vmlinux-3.15.0-rc4-vanilla mark_page_accessed ext4 5322 0.0713 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed ext4 2869 0.0384 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed xfs 62126 1.7675 vmlinux-3.15.0-rc4-vanilla mark_page_accessed xfs 1904 0.0554 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed xfs 103 0.0030 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed btrfs 10655 0.1338 vmlinux-3.15.0-rc4-vanilla mark_page_accessed btrfs 2020 0.0273 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed btrfs 587 0.0079 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed tmpfs 59562 3.2628 vmlinux-3.15.0-rc4-vanilla mark_page_accessed tmpfs 1210 0.0696 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed tmpfs 94 0.0054 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed [akpm@linux-foundation.org: don't run init_page_accessed() against an uninitialised pointer] Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Tested-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29fs: buffer: do not use unnecessary atomic operations when discarding buffersMel Gorman
commit e7470ee89f003634a88e7b5e5a7b65b3025987de upstream. Discarding buffers uses a bunch of atomic operations when discarding buffers because ...... I can't think of a reason. Use a cmpxchg loop to clear all the necessary flags. In most (all?) cases this will be a single atomic operations. [akpm@linux-foundation.org: move BUFFER_FLAGS_DISCARD into the .c file] Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: page_alloc: convert hot/cold parameter and immediate callers to boolMel Gorman
commit b745bc85f21ea707e4ea1a91948055fa3e72c77b upstream. cold is a bool, make it one. Make the likely case the "if" part of the block instead of the else as according to the optimisation manual this is preferred. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29fix deadlock in cifs_ioctl_clone()Al Viro
commit 378ff1a53b5724f3ac97b0aba3c9ecac072f6fcd upstream. It really needs to check that src is non-directory *and* use {un,}lock_two_nodirectories(). As it is, it's trivial to cause double-lock (ioctl(fd, CIFS_IOC_COPYCHUNK_FILE, fd)) and if the last argument is an fd of directory, we are asking for trouble by violating the locking order - all directories go before all non-directories. If the last argument is an fd of parent directory, it has 50% odds of locking child before parent, which will cause AB-BA deadlock if we race with unlink(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-27fsnotify: next_i is freed during fsnotify_unmount_inodes.Jerry Hoemann
commit 6424babfd68dd8a83d9c60a5242d27038856599f upstream. During file system stress testing on 3.10 and 3.12 based kernels, the umount command occasionally hung in fsnotify_unmount_inodes in the section of code: spin_lock(&inode->i_lock); if (inode->i_state & (I_FREEING|I_WILL_FREE|I_NEW)) { spin_unlock(&inode->i_lock); continue; } As this section of code holds the global inode_sb_list_lock, eventually the system hangs trying to acquire the lock. Multiple crash dumps showed: The inode->i_state == 0x60 and i_count == 0 and i_sb_list would point back at itself. As this is not the value of list upon entry to the function, the kernel never exits the loop. To help narrow down problem, the call to list_del_init in inode_sb_list_del was changed to list_del. This poisons the pointers in the i_sb_list and causes a kernel to panic if it transverse a freed inode. Subsequent stress testing paniced in fsnotify_unmount_inodes at the bottom of the list_for_each_entry_safe loop showing next_i had become free. We believe the root cause of the problem is that next_i is being freed during the window of time that the list_for_each_entry_safe loop temporarily releases inode_sb_list_lock to call fsnotify and fsnotify_inode_delete. The code in fsnotify_unmount_inodes attempts to prevent the freeing of inode and next_i by calling __iget. However, the code doesn't do the __iget call on next_i if i_count == 0 or if i_state & (I_FREEING | I_WILL_FREE) The patch addresses this issue by advancing next_i in the above two cases until we either find a next_i which we can __iget or we reach the end of the list. This makes the handling of next_i more closely match the handling of the variable "inode." The time to reproduce the hang is highly variable (from hours to days.) We ran the stress test on a 3.10 kernel with the proposed patch for a week without failure. During list_for_each_entry_safe, next_i is becoming free causing the loop to never terminate. Advance next_i in those cases where __iget is not done. Signed-off-by: Jerry Hoemann <jerry.hoemann@hp.com> Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Cc: Ken Helias <kenhelias@firemail.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-27LOCKD: Fix a race when initialising nlmsvc_timeoutTrond Myklebust
commit 06bed7d18c2c07b3e3eeadf4bd357f6e806618cc upstream. This commit fixes a race whereby nlmclnt_init() first starts the lockd daemon, and then calls nlm_bind_host() with the expectation that nlmsvc_timeout has already been initialised. Unfortunately, there is no no synchronisation between lockd() and lockd_up() to guarantee that this is the case. Fix is to move the initialisation of nlmsvc_timeout into lockd_create_svc Fixes: 9a1b6bf818e74 ("LOCKD: Don't call utsname()->nodename...") Cc: Bruce Fields <bfields@fieldses.org> Cc: stable@vger.kernel.org # 3.10.x Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-27NFSv4.1: Fix client id trunking on LinuxTrond Myklebust
commit 1fc0703af3143914a389bfa081c7acb09502ed5d upstream. Currently, our trunking code will check for session trunking, but will fail to detect client id trunking. This is a problem, because it means that the client will fail to recognise that the two connections represent shared state, even if they do not permit a shared session. By removing the check for the server minor id, and only checking the major id, we will end up doing the right thing in both cases: we close down the new nfs_client and fall back to using the existing one. Fixes: 05f4c350ee02e ("NFS: Discover NFSv4 server trunking when mounting") Cc: Chuck Lever <chuck.lever@oracle.com> Tested-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-27genirq: Prevent proc race against freeing of irq descriptorsThomas Gleixner
commit c291ee622165cb2c8d4e7af63fffd499354a23be upstream. Since the rework of the sparse interrupt code to actually free the unused interrupt descriptors there exists a race between the /proc interfaces to the irq subsystem and the code which frees the interrupt descriptor. CPU0 CPU1 show_interrupts() desc = irq_to_desc(X); free_desc(desc) remove_from_radix_tree(); kfree(desc); raw_spinlock_irq(&desc->lock); /proc/interrupts is the only interface which can actively corrupt kernel memory via the lock access. /proc/stat can only read from freed memory. Extremly hard to trigger, but possible. The interfaces in /proc/irq/N/ are not affected by this because the removal of the proc file is serialized in procfs against concurrent readers/writers. The removal happens before the descriptor is freed. For architectures which have CONFIG_SPARSE_IRQ=n this is a non issue as the descriptor is never freed. It's merely cleared out with the irq descriptor lock held. So any concurrent proc access will either see the old correct value or the cleared out ones. Protect the lookup and access to the irq descriptor in show_interrupts() with the sparse_irq_lock. Provide kstat_irqs_usr() which is protecting the lookup and access with sparse_irq_lock and switch /proc/stat to use it. Document the existing kstat_irqs interfaces so it's clear that the caller needs to take care about protection. The users of these interfaces are either not affected due to SPARSE_IRQ=n or already protected against removal. Fixes: 1f5a5b87f78f "genirq: Implement a sane sparse_irq allocator" Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16Btrfs: don't delay inode ref updates during log replayChris Mason
commit 6f8960541b1eb6054a642da48daae2320fddba93 upstream. Commit 1d52c78afbb (Btrfs: try not to ENOSPC on log replay) added a check to skip delayed inode updates during log replay because it confuses the enospc code. But the delayed processing will end up ignoring delayed refs from log replay because the inode itself wasn't put through the delayed code. This can end up triggering a warning at commit time: WARNING: CPU: 2 PID: 778 at fs/btrfs/delayed-inode.c:1410 btrfs_assert_delayed_root_empty+0x32/0x34() Which is repeated for each commit because we never process the delayed inode ref update. The fix used here is to change btrfs_delayed_delete_inode_ref to return an error if we're currently in log replay. The caller will do the ref deletion immediately and everything will work properly. Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16nilfs2: fix the nilfs_iget() vs. nilfs_new_inode() racesRyusuke Konishi
commit 705304a863cc41585508c0f476f6d3ec28cf7e00 upstream. Same story as in commit 41080b5a2401 ("nfsd race fixes: ext2") (similar ext2 fix) except that nilfs2 needs to use insert_inode_locked4() instead of insert_inode_locked() and a bug of a check for dead inodes needs to be fixed. If nilfs_iget() is called from nfsd after nilfs_new_inode() calls insert_inode_locked4(), nilfs_iget() will wait for unlock_new_inode() at the end of nilfs_mkdir()/nilfs_create()/etc to unlock the inode. If nilfs_iget() is called before nilfs_new_inode() calls insert_inode_locked4(), it will create an in-core inode and read its data from the on-disk inode. But, nilfs_iget() will find i_nlink equals zero and fail at nilfs_read_inode_common(), which will lead it to call iget_failed() and cleanly fail. However, this sanity check doesn't work as expected for reused on-disk inodes because they leave a non-zero value in i_mode field and it hinders the test of i_nlink. This patch also fixes the issue by removing the test on i_mode that nilfs2 doesn't need. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16ceph: fix null pointer dereference in discard_cap_releases()Yan, Zheng
commit 00bd8edb861eb41d274938cfc0338999d9c593a3 upstream. send_mds_reconnect() may call discard_cap_releases() after all release messages have been dropped by cleanup_cap_releases() Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com> Reviewed-by: Sage Weil <sage@inktank.com> Cc: Markus Blank-Burian <burian@muenster.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16ceph: do_sync is never initializedDan Carpenter
commit 021b77bee210843bed1ea91b5cad58235ff9c8e5 upstream. Probably this code was syncing a lot more often then intended because the do_sync variable wasn't set to zero. Fixes: c62988ec0910 ('ceph: avoid meaningless calling ceph_caps_revoking if sync_mode == WB_SYNC_ALL.') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Ilya Dryomov <idryomov@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16nfsd4: fix xdr4 inclusion of escaped charBenjamin Coddington
commit 5a64e56976f1ba98743e1678c0029a98e9034c81 upstream. Fix a bug where nfsd4_encode_components_esc() includes the esc_end char as an additional string encoding. Signed-off-by: Benjamin Coddington <bcodding@redhat.com> Fixes: e7a0444aef4a "nfsd: add IPv6 addr escaping to fs_location hosts" Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16fs: nfsd: Fix signedness bug in compare_blobRasmus Villemoes
commit ef17af2a817db97d42dd2ec0a425231748e23dbc upstream. Bugs similar to the one in acbbe6fbb240 (kcmp: fix standard comparison bug) are in rich supply. In this variant, the problem is that struct xdr_netobj::len has type unsigned int, so the expression o1->len - o2->len _also_ has type unsigned int; it has completely well-defined semantics, and the result is some non-negative integer, which is always representable in a long long. But this means that if the conditional triggers, we are guaranteed to return a positive value from compare_blob. In this case it could be fixed by - res = o1->len - o2->len; + res = (long long)o1->len - (long long)o2->len; but I'd rather eliminate the usually broken 'return a - b;' idiom. Reviewed-by: Jeff Layton <jlayton@primarydata.com> Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16writeback: fix a subtle race condition in I_DIRTY clearingTejun Heo
commit 9c6ac78eb3521c5937b2dd8a7d1b300f41092f45 upstream. After invoking ->dirty_inode(), __mark_inode_dirty() does smp_mb() and tests inode->i_state locklessly to see whether it already has all the necessary I_DIRTY bits set. The comment above the barrier doesn't contain any useful information - memory barriers can't ensure "changes are seen by all cpus" by itself. And it sure enough was broken. Please consider the following scenario. CPU 0 CPU 1 ------------------------------------------------------------------------------- enters __writeback_single_inode() grabs inode->i_lock tests PAGECACHE_TAG_DIRTY which is clear enters __set_page_dirty() grabs mapping->tree_lock sets PAGECACHE_TAG_DIRTY releases mapping->tree_lock leaves __set_page_dirty() enters __mark_inode_dirty() smp_mb() sees I_DIRTY_PAGES set leaves __mark_inode_dirty() clears I_DIRTY_PAGES releases inode->i_lock Now @inode has dirty pages w/ I_DIRTY_PAGES clear. This doesn't seem to lead to an immediately critical problem because requeue_inode() later checks PAGECACHE_TAG_DIRTY instead of I_DIRTY_PAGES when deciding whether the inode needs to be requeued for IO and there are enough unintentional memory barriers inbetween, so while the inode ends up with inconsistent I_DIRTY_PAGES flag, it doesn't fall off the IO list. The lack of explicit barrier may also theoretically affect the other I_DIRTY bits which deal with metadata dirtiness. There is no guarantee that a strong enough barrier exists between I_DIRTY_[DATA]SYNC clearing and write_inode() writing out the dirtied inode. Filesystem inode writeout path likely has enough stuff which can behave as full barrier but it's theoretically possible that the writeout may not see all the updates from ->dirty_inode(). Fix it by adding an explicit smp_mb() after I_DIRTY clearing. Note that I_DIRTY_PAGES needs a special treatment as it always needs to be cleared to be interlocked with the lockless test on __mark_inode_dirty() side. It's cleared unconditionally and reinstated after smp_mb() if the mapping still has dirty pages. Also add comments explaining how and why the barriers are paired. Lightly tested. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jan Kara <jack@suse.cz> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16pstore-ram: Allow optional mapping with pgprot_noncachedTony Lindgren
commit 027bc8b08242c59e19356b4b2c189f2d849ab660 upstream. On some ARMs the memory can be mapped pgprot_noncached() and still be working for atomic operations. As pointed out by Colin Cross <ccross@android.com>, in some cases you do want to use pgprot_noncached() if the SoC supports it to see a debug printk just before a write hanging the system. On ARMs, the atomic operations on strongly ordered memory are implementation defined. So let's provide an optional kernel parameter for configuring pgprot_noncached(), and use pgprot_writecombine() by default. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Rob Herring <robherring2@gmail.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Anton Vorontsov <anton@enomsg.org> Cc: Colin Cross <ccross@android.com> Cc: Olof Johansson <olof@lixom.net> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16pstore-ram: Fix hangs by using write-combine mappingsRob Herring
commit 7ae9cb81933515dc7db1aa3c47ef7653717e3090 upstream. Currently trying to use pstore on at least ARMs can hang as we're mapping the peristent RAM with pgprot_noncached(). On ARMs, pgprot_noncached() will actually make the memory strongly ordered, and as the atomic operations pstore uses are implementation defined for strongly ordered memory, they may not work. So basically atomic operations have undefined behavior on ARM for device or strongly ordered memory types. Let's fix the issue by using write-combine variants for mappings. This corresponds to normal, non-cacheable memory on ARM. For many other architectures, this change does not change the mapping type as by default we have: #define pgprot_writecombine pgprot_noncached The reason why pgprot_noncached() was originaly used for pstore is because Colin Cross <ccross@android.com> had observed lost debug prints right before a device hanging write operation on some systems. For the platforms supporting pgprot_noncached(), we can add a an optional configuration option to support that. But let's get pstore working first before adding new features. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Anton Vorontsov <cbouatmailru@gmail.com> Cc: Colin Cross <ccross@android.com> Cc: Olof Johansson <olof@lixom.net> Cc: linux-kernel@vger.kernel.org Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Rob Herring <rob.herring@calxeda.com> [tony@atomide.com: updated description] Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16ocfs2: fix the wrong directory passed to ocfs2_lookup_ino_from_name() when ↵Xue jiufei
link file commit 53dc20b9a3d928b0744dad5aee65b610de1cc85d upstream. In ocfs2_link(), the parent directory inode passed to function ocfs2_lookup_ino_from_name() is wrong. Parameter dir is the parent of new_dentry not old_dentry. We should get old_dir from old_dentry and lookup old_dentry in old_dir in case another node remove the old dentry. With this change, hard linking works again, when paths are relative with at least one subdirectory. This is how the problem was reproducable: # mkdir a # mkdir b # touch a/test # ln a/test b/test ln: failed to create hard link `b/test' => `a/test': No such file or directory However when creating links in the same dir, it worked well. Now the link gets created. Fixes: 0e048316ff57 ("ocfs2: check existence of old dentry in ocfs2_link()") Signed-off-by: joyce.xue <xuejiufei@huawei.com> Reported-by: Szabo Aron - UBIT <aron@ubit.hu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Tested-by: Aron Szabo <aron@ubit.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16ocfs2: fix journal commit deadlockJunxiao Bi
commit 136f49b9171074872f2a14ad0ab10486d1ba13ca upstream. For buffer write, page lock will be got in write_begin and released in write_end, in ocfs2_write_end_nolock(), before it unlock the page in ocfs2_free_write_ctxt(), it calls ocfs2_run_deallocs(), this will ask for the read lock of journal->j_trans_barrier. Holding page lock and ask for journal->j_trans_barrier breaks the locking order. This will cause a deadlock with journal commit threads, ocfs2cmt will get write lock of journal->j_trans_barrier first, then it wakes up kjournald2 to do the commit work, at last it waits until done. To commit journal, kjournald2 needs flushing data first, it needs get the cache page lock. Since some ocfs2 cluster locks are holding by write process, this deadlock may hung the whole cluster. unlock pages before ocfs2_run_deallocs() can fix the locking order, also put unlock before ocfs2_commit_trans() to make page lock is unlocked before j_trans_barrier to preserve unlocking order. Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Reviewed-by: Wengang Wang <wen.gang.wang@oracle.com> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08Btrfs: fix fs corruption on transaction abort if device supports discardFilipe Manana
commit 678886bdc6378c1cbd5072da2c5a3035000214e3 upstream. When we abort a transaction we iterate over all the ranges marked as dirty in fs_info->freed_extents[0] and fs_info->freed_extents[1], clear them from those trees, add them back (unpin) to the free space caches and, if the fs was mounted with "-o discard", perform a discard on those regions. Also, after adding the regions to the free space caches, a fitrim ioctl call can see those ranges in a block group's free space cache and perform a discard on the ranges, so the same issue can happen without "-o discard" as well. This causes corruption, affecting one or multiple btree nodes (in the worst case leaving the fs unmountable) because some of those ranges (the ones in the fs_info->pinned_extents tree) correspond to btree nodes/leafs that are referred by the last committed super block - breaking the rule that anything that was committed by a transaction is untouched until the next transaction commits successfully. I ran into this while running in a loop (for several hours) the fstest that I recently submitted: [PATCH] fstests: add btrfs test to stress chunk allocation/removal and fstrim The corruption always happened when a transaction aborted and then fsck complained like this: _check_btrfs_filesystem: filesystem on /dev/sdc is inconsistent *** fsck.btrfs output *** Check tree block failed, want=94945280, have=0 Check tree block failed, want=94945280, have=0 Check tree block failed, want=94945280, have=0 Check tree block failed, want=94945280, have=0 Check tree block failed, want=94945280, have=0 read block failed check_tree_block Couldn't open file system In this case 94945280 corresponded to the root of a tree. Using frace what I observed was the following sequence of steps happened: 1) transaction N started, fs_info->pinned_extents pointed to fs_info->freed_extents[0]; 2) node/eb 94945280 is created; 3) eb is persisted to disk; 4) transaction N commit starts, fs_info->pinned_extents now points to fs_info->freed_extents[1], and transaction N completes; 5) transaction N + 1 starts; 6) eb is COWed, and btrfs_free_tree_block() called for this eb; 7) eb range (94945280 to 94945280 + 16Kb) is added to fs_info->pinned_extents (fs_info->freed_extents[1]); 8) Something goes wrong in transaction N + 1, like hitting ENOSPC for example, and the transaction is aborted, turning the fs into readonly mode. The stack trace I got for example: [112065.253935] [<ffffffff8140c7b6>] dump_stack+0x4d/0x66 [112065.254271] [<ffffffff81042984>] warn_slowpath_common+0x7f/0x98 [112065.254567] [<ffffffffa0325990>] ? __btrfs_abort_transaction+0x50/0x10b [btrfs] [112065.261674] [<ffffffff810429e5>] warn_slowpath_fmt+0x48/0x50 [112065.261922] [<ffffffffa032949e>] ? btrfs_free_path+0x26/0x29 [btrfs] [112065.262211] [<ffffffffa0325990>] __btrfs_abort_transaction+0x50/0x10b [btrfs] [112065.262545] [<ffffffffa036b1d6>] btrfs_remove_chunk+0x537/0x58b [btrfs] [112065.262771] [<ffffffffa033840f>] btrfs_delete_unused_bgs+0x1de/0x21b [btrfs] [112065.263105] [<ffffffffa0343106>] cleaner_kthread+0x100/0x12f [btrfs] (...) [112065.264493] ---[ end trace dd7903a975a31a08 ]--- [112065.264673] BTRFS: error (device sdc) in btrfs_remove_chunk:2625: errno=-28 No space left [112065.264997] BTRFS info (device sdc): forced readonly 9) The clear kthread sees that the BTRFS_FS_STATE_ERROR bit is set in fs_info->fs_state and calls btrfs_cleanup_transaction(), which in turn calls btrfs_destroy_pinned_extent(); 10) Then btrfs_destroy_pinned_extent() iterates over all the ranges marked as dirty in fs_info->freed_extents[], and for each one it calls discard, if the fs was mounted with "-o discard", and adds the range to the free space cache of the respective block group; 11) btrfs_trim_block_group(), invoked from the fitrim ioctl code path, sees the free space entries and performs a discard; 12) After an umount and mount (or fsck), our eb's location on disk was full of zeroes, and it should have been untouched, because it was marked as dirty in the fs_info->pinned_extents tree, and therefore used by the trees that the last committed superblock points to. Fix this by not performing a discard and not adding the ranges to the free space caches - it's useless from this point since the fs is now in readonly mode and we won't write free space caches to disk anymore (otherwise we would leak space) nor any new superblock. By not adding the ranges to the free space caches, it prevents other code paths from allocating that space and write to it as well, therefore being safer and simpler. This isn't a new problem, as it's been present since 2011 (git commit acce952b0263825da32cf10489413dec78053347). Signed-off-by: Filipe Manana <fdmanana@suse.com> Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08Btrfs: do not move em to modified list when unpinningJosef Bacik
commit a28046956c71985046474283fa3bcd256915fb72 upstream. We use the modified list to keep track of which extents have been modified so we know which ones are candidates for logging at fsync() time. Newly modified extents are added to the list at modification time, around the same time the ordered extent is created. We do this so that we don't have to wait for ordered extents to complete before we know what we need to log. The problem is when something like this happens log extent 0-4k on inode 1 copy csum for 0-4k from ordered extent into log sync log commit transaction log some other extent on inode 1 ordered extent for 0-4k completes and adds itself onto modified list again log changed extents see ordered extent for 0-4k has already been logged at this point we assume the csum has been copied sync log crash On replay we will see the extent 0-4k in the log, drop the original 0-4k extent which is the same one that we are replaying which also drops the csum, and then we won't find the csum in the log for that bytenr. This of course causes us to have errors about not having csums for certain ranges of our inode. So remove the modified list manipulation in unpin_extent_cache, any modified extents should have been added well before now, and we don't want them re-logged. This fixes my test that I could reliably reproduce this problem with. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08eCryptfs: Remove buggy and unnecessary write in file name decode routineMichael Halcrow
commit 942080643bce061c3dd9d5718d3b745dcb39a8bc upstream. Dmitry Chernenkov used KASAN to discover that eCryptfs writes past the end of the allocated buffer during encrypted filename decoding. This fix corrects the issue by getting rid of the unnecessary 0 write when the current bit offset is 2. Signed-off-by: Michael Halcrow <mhalcrow@google.com> Reported-by: Dmitry Chernenkov <dmitryc@google.com> Suggested-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08eCryptfs: Force RO mount when encrypted view is enabledTyler Hicks
commit 332b122d39c9cbff8b799007a825d94b2e7c12f2 upstream. The ecryptfs_encrypted_view mount option greatly changes the functionality of an eCryptfs mount. Instead of encrypting and decrypting lower files, it provides a unified view of the encrypted files in the lower filesystem. The presence of the ecryptfs_encrypted_view mount option is intended to force a read-only mount and modifying files is not supported when the feature is in use. See the following commit for more information: e77a56d [PATCH] eCryptfs: Encrypted passthrough This patch forces the mount to be read-only when the ecryptfs_encrypted_view mount option is specified by setting the MS_RDONLY flag on the superblock. Additionally, this patch removes some broken logic in ecryptfs_open() that attempted to prevent modifications of files when the encrypted view feature was in use. The check in ecryptfs_open() was not sufficient to prevent file modifications using system calls that do not operate on a file descriptor. Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Reported-by: Priya Bansal <p.bansal@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08udf: Verify symlink size before loading itJan Kara
commit a1d47b262952a45aae62bd49cfaf33dd76c11a2c upstream. UDF specification allows arbitrarily large symlinks. However we support only symlinks at most one block large. Check the length of the symlink so that we don't access memory beyond end of the symlink block. Reported-by: Carl Henrik Lunde <chlunde@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08ncpfs: return proper error from NCP_IOC_SETROOT ioctlJan Kara
commit a682e9c28cac152e6e54c39efcf046e0c8cfcf63 upstream. If some error happens in NCP_IOC_SETROOT ioctl, the appropriate error return value is then (in most cases) just overwritten before we return. This can result in reporting success to userspace although error happened. This bug was introduced by commit 2e54eb96e2c8 ("BKL: Remove BKL from ncpfs"). Propagate the errors correctly. Coverity id: 1226925. Fixes: 2e54eb96e2c80 ("BKL: Remove BKL from ncpfs") Signed-off-by: Jan Kara <jack@suse.cz> Cc: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08userns: Add a knob to disable setgroups on a per user namespace basisEric W. Biederman
commit 9cc46516ddf497ea16e8d7cb986ae03a0f6b92f8 upstream. - Expose the knob to user space through a proc file /proc/<pid>/setgroups A value of "deny" means the setgroups system call is disabled in the current processes user namespace and can not be enabled in the future in this user namespace. A value of "allow" means the segtoups system call is enabled. - Descendant user namespaces inherit the value of setgroups from their parents. - A proc file is used (instead of a sysctl) as sysctls currently do not allow checking the permissions at open time. - Writing to the proc file is restricted to before the gid_map for the user namespace is set. This ensures that disabling setgroups at a user namespace level will never remove the ability to call setgroups from a process that already has that ability. A process may opt in to the setgroups disable for itself by creating, entering and configuring a user namespace or by calling setns on an existing user namespace with setgroups disabled. Processes without privileges already can not call setgroups so this is a noop. Prodcess with privilege become processes without privilege when entering a user namespace and as with any other path to dropping privilege they would not have the ability to call setgroups. So this remains within the bounds of what is possible without a knob to disable setgroups permanently in a user namespace. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08umount: Disallow unprivileged mount forceEric W. Biederman
commit b2f5d4dc38e034eecb7987e513255265ff9aa1cf upstream. Forced unmount affects not just the mount namespace but the underlying superblock as well. Restrict forced unmount to the global root user for now. Otherwise it becomes possible a user in a less privileged mount namespace to force the shutdown of a superblock of a filesystem in a more privileged mount namespace, allowing a DOS attack on root. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08mnt: Implicitly add MNT_NODEV on remount when it was implicitly added by mountEric W. Biederman
commit 3e1866410f11356a9fd869beb3e95983dc79c067 upstream. Now that remount is properly enforcing the rule that you can't remove nodev at least sandstorm.io is breaking when performing a remount. It turns out that there is an easy intuitive solution implicitly add nodev on remount when nodev was implicitly added on mount. Tested-by: Cedric Bosdonnat <cbosdonnat@suse.com> Tested-by: Richard Weinberger <richard@nod.at> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08mnt: Fix a memory stomp in umountEric W. Biederman
commit c297abfdf15b4480704d6b566ca5ca9438b12456 upstream. While reviewing the code of umount_tree I realized that when we append to a preexisting unmounted list we do not change pprev of the former first item in the list. Which means later in namespace_unlock hlist_del_init(&mnt->mnt_hash) on the former first item of the list will stomp unmounted.first leaving it set to some random mount point which we are likely to free soon. This isn't likely to hit, but if it does I don't know how anyone could track it down. [ This happened because we don't have all the same operations for hlist's as we do for normal doubly-linked lists. In particular, list_splice() is easy on our standard doubly-linked lists, while hlist_splice() doesn't exist and needs both start/end entries of the hlist. And commit 38129a13e6e7 incorrectly open-coded that missing hlist_splice(). We should think about making these kinds of "mindless" conversions easier to get right by adding the missing hlist helpers - Linus ] Fixes: 38129a13e6e71f666e0468e99fdd932a687b4d7e switch mnt_hash to hlist Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08isofs: Fix unchecked printing of ER recordsJan Kara
commit 4e2024624e678f0ebb916e6192bd23c1f9fdf696 upstream. We didn't check length of rock ridge ER records before printing them. Thus corrupted isofs image can cause us to access and print some memory behind the buffer with obvious consequences. Reported-and-tested-by: Carl Henrik Lunde <chlunde@ping.uio.no> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08nfs41: fix nfs4_proc_layoutget error handlingPeng Tao
commit 4bd5a980de87d2b5af417485bde97b8eb3d6cf6a upstream. nfs4_layoutget_release() drops layout hdr refcnt. Grab the refcnt early so that it is safe to call .release in case nfs4_alloc_pages fails. Signed-off-by: Peng Tao <tao.peng@primarydata.com> Fixes: a47970ff78147 ("NFSv4.1: Hold reference to layout hdr in layoutget") Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08isofs: Fix infinite looping over CE entriesJan Kara
commit f54e18f1b831c92f6512d2eedb224cd63d607d3d upstream. Rock Ridge extensions define so called Continuation Entries (CE) which define where is further space with Rock Ridge data. Corrupted isofs image can contain arbitrarily long chain of these, including a one containing loop and thus causing kernel to end in an infinite loop when traversing these entries. Limit the traversal to 32 entries which should be more than enough space to store all the Rock Ridge data. Reported-by: P J P <ppandit@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-06nfs: Don't busy-wait on SIGKILL in __nfs_iocounter_waitDavid Jeffery
commit 92a56555bd576c61b27a5cab9f38a33a1e9a1df5 upstream. If a SIGKILL is sent to a task waiting in __nfs_iocounter_wait, it will busy-wait or soft lockup in its while loop. nfs_wait_bit_killable won't sleep, and the loop won't exit on the error return. Stop the busy-wait by breaking out of the loop when nfs_wait_bit_killable returns an error. Signed-off-by: David Jeffery <djeffery@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> [ kamal: backport to 3.13-stable: context ] Cc: Moritz Mühlenhoff <muehlenhoff@univention.de> Signed-off-by: Kamal Mostafa <kamal@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-06locks: eliminate BUG() call when there's an unexpected lock on file closeJeff Layton
commit 8c3cac5e6a85f03602ffe09c44f14418699e31ec upstream. A leftover lock on the list is surely a sign of a problem of some sort, but it's not necessarily a reason to panic the box. Instead, just log a warning with some info about the lock, and then delete it like we would any other lock. In the event that the filesystem declares a ->lock f_op, we may end up leaking something, but that's generally preferable to an immediate panic. Acked-by: J. Bruce Fields <bfields@fieldses.org> Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: Markus Blank-Burian <burian@muenster.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-06nfsd: don't halt scanning the DRC LRU list when there's an RC_INPROG entryJeff Layton
commit 1b19453d1c6abcfa7c312ba6c9f11a277568fc94 upstream. Currently, the DRC cache pruner will stop scanning the list when it hits an entry that is RC_INPROG. It's possible however for a call to take a *very* long time. In that case, we don't want it to block other entries from being pruned if they are expired or we need to trim the cache to get back under the limit. Fix the DRC cache pruner to just ignore RC_INPROG entries. Signed-off-by: Jeff Layton <jlayton@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Cc: Joseph Salisbury <joseph.salisbury@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-06nfsd: Fix slot wake up race in the nfsv4.1 callback codeTrond Myklebust
commit c6c15e1ed303ffc47e696ea1c9a9df1761c1f603 upstream. The currect code for nfsd41_cb_get_slot() and nfsd4_cb_done() has no locking in order to guarantee atomicity, and so allows for races of the form. Task 1 Task 2 ====== ====== if (test_and_set_bit(0) != 0) { clear_bit(0) rpc_wake_up_next(queue) rpc_sleep_on(queue) return false; } This patch breaks the race condition by adding a retest of the bit after the call to rpc_sleep_on(). Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-06nfsd: correctly define v4.2 support attributesChristoph Hellwig
commit 6d0ba0432a5e10bc714ba9c5adc460e726e5fbb4 upstream. Even when security labels are disabled we support at least the same attributes as v4.1. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-06aio: fix uncorrent dirty pages accouting when truncating AIO ring bufferGu Zheng
commit 835f252c6debd204fcd607c79975089b1ecd3472 upstream. https://bugzilla.kernel.org/show_bug.cgi?id=86831 Markus reported that when shutting down mysqld (with AIO support, on a ext3 formatted Harddrive) leads to a negative number of dirty pages (underrun to the counter). The negative number results in a drastic reduction of the write performance because the page cache is not used, because the kernel thinks it is still 2 ^ 32 dirty pages open. Add a warn trace in __dec_zone_state will catch this easily: static inline void __dec_zone_state(struct zone *zone, enum zone_stat_item item) { atomic_long_dec(&zone->vm_stat[item]); + WARN_ON_ONCE(item == NR_FILE_DIRTY && atomic_long_read(&zone->vm_stat[item]) < 0); atomic_long_dec(&vm_stat[item]); } [ 21.341632] ------------[ cut here ]------------ [ 21.346294] WARNING: CPU: 0 PID: 309 at include/linux/vmstat.h:242 cancel_dirty_page+0x164/0x224() [ 21.355296] Modules linked in: wutbox_cp sata_mv [ 21.359968] CPU: 0 PID: 309 Comm: kworker/0:1 Not tainted 3.14.21-WuT #80 [ 21.366793] Workqueue: events free_ioctx [ 21.370760] [<c0016a64>] (unwind_backtrace) from [<c0012f88>] (show_stack+0x20/0x24) [ 21.378562] [<c0012f88>] (show_stack) from [<c03f8ccc>] (dump_stack+0x24/0x28) [ 21.385840] [<c03f8ccc>] (dump_stack) from [<c0023ae4>] (warn_slowpath_common+0x84/0x9c) [ 21.393976] [<c0023ae4>] (warn_slowpath_common) from [<c0023bb8>] (warn_slowpath_null+0x2c/0x34) [ 21.402800] [<c0023bb8>] (warn_slowpath_null) from [<c00c0688>] (cancel_dirty_page+0x164/0x224) [ 21.411524] [<c00c0688>] (cancel_dirty_page) from [<c00c080c>] (truncate_inode_page+0x8c/0x158) [ 21.420272] [<c00c080c>] (truncate_inode_page) from [<c00c0a94>] (truncate_inode_pages_range+0x11c/0x53c) [ 21.429890] [<c00c0a94>] (truncate_inode_pages_range) from [<c00c0f6c>] (truncate_pagecache+0x88/0xac) [ 21.439252] [<c00c0f6c>] (truncate_pagecache) from [<c00c0fec>] (truncate_setsize+0x5c/0x74) [ 21.447731] [<c00c0fec>] (truncate_setsize) from [<c013b3a8>] (put_aio_ring_file.isra.14+0x34/0x90) [ 21.456826] [<c013b3a8>] (put_aio_ring_file.isra.14) from [<c013b424>] (aio_free_ring+0x20/0xcc) [ 21.465660] [<c013b424>] (aio_free_ring) from [<c013b4f4>] (free_ioctx+0x24/0x44) [ 21.473190] [<c013b4f4>] (free_ioctx) from [<c003d8d8>] (process_one_work+0x134/0x47c) [ 21.481132] [<c003d8d8>] (process_one_work) from [<c003e988>] (worker_thread+0x130/0x414) [ 21.489350] [<c003e988>] (worker_thread) from [<c00448ac>] (kthread+0xd4/0xec) [ 21.496621] [<c00448ac>] (kthread) from [<c000ec18>] (ret_from_fork+0x14/0x20) [ 21.503884] ---[ end trace 79c4bf42c038c9a1 ]--- The cause is that we set the aio ring file pages as *DIRTY* via SetPageDirty (bypasses the VFS dirty pages increment) when init, and aio fs uses *default_backing_dev_info* as the backing dev, which does not disable the dirty pages accounting capability. So truncating aio ring file will contribute to accounting dirty pages (VFS dirty pages decrement), then error occurs. The original goal is keeping these pages in memory (can not be reclaimed or swapped) in life-time via marking it dirty. But thinking more, we have already pinned pages via elevating the page's refcount, which can already achieve the goal, so the SetPageDirty seems unnecessary. In order to fix the issue, using the __set_page_dirty_no_writeback instead of the nop .set_page_dirty, and dropped the SetPageDirty (don't manually set the dirty flags, don't disable set_page_dirty(), rely on default behaviour). With the above change, the dirty pages accounting can work well. But as we known, aio fs is an anonymous one, which should never cause any real write-back, we can ignore the dirty pages (write back) accounting by disabling the dirty pages (write back) accounting capability. So we introduce an aio private backing dev info (disabled the ACCT_DIRTY/WRITEBACK/ACCT_WB capabilities) to replace the default one. Reported-by: Markus Königshaus <m.koenigshaus@wut.de> Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21fs/superblock: avoid locking counting inodes and dentries before reclaiming themTim Chen
commit d23da150a37c9fe3cc83dbaf71b3e37fd434ed52 upstream. We remove the call to grab_super_passive in call to super_cache_count. This becomes a scalability bottleneck as multiple threads are trying to do memory reclamation, e.g. when we are doing large amount of file read and page cache is under pressure. The cached objects quickly got reclaimed down to 0 and we are aborting the cache_scan() reclaim. But counting creates a log jam acquiring the sb_lock. We are holding the shrinker_rwsem which ensures the safety of call to list_lru_count_node() and s_op->nr_cached_objects. The shrinker is unregistered now before ->kill_sb() so the operation is safe when we are doing unmount. The impact will depend heavily on the machine and the workload but for a small machine using postmark tuned to use 4xRAM size the results were 3.15.0-rc5 3.15.0-rc5 vanilla shrinker-v1r1 Ops/sec Transactions 21.00 ( 0.00%) 24.00 ( 14.29%) Ops/sec FilesCreate 39.00 ( 0.00%) 44.00 ( 12.82%) Ops/sec CreateTransact 10.00 ( 0.00%) 12.00 ( 20.00%) Ops/sec FilesDeleted 6202.00 ( 0.00%) 6202.00 ( 0.00%) Ops/sec DeleteTransact 11.00 ( 0.00%) 12.00 ( 9.09%) Ops/sec DataRead/MB 25.97 ( 0.00%) 29.10 ( 12.05%) Ops/sec DataWrite/MB 49.99 ( 0.00%) 56.02 ( 12.06%) ffsb running in a configuration that is meant to simulate a mail server showed 3.15.0-rc5 3.15.0-rc5 vanilla shrinker-v1r1 Ops/sec readall 9402.63 ( 0.00%) 9567.97 ( 1.76%) Ops/sec create 4695.45 ( 0.00%) 4735.00 ( 0.84%) Ops/sec delete 173.72 ( 0.00%) 179.83 ( 3.52%) Ops/sec Transactions 14271.80 ( 0.00%) 14482.81 ( 1.48%) Ops/sec Read 37.00 ( 0.00%) 37.60 ( 1.62%) Ops/sec Write 18.20 ( 0.00%) 18.30 ( 0.55%) Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Chinner <david@fromorbit.com> Tested-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Jan Kara <jack@suse.cz> Acked-by: Rik van Riel <riel@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21fs/superblock: unregister sb shrinker before ->kill_sb()Dave Chinner
commit 28f2cd4f6da24a1aa06c226618ed5ad69e13df64 upstream. This series is aimed at regressions noticed during reclaim activity. The first two patches are shrinker patches that were posted ages ago but never merged for reasons that are unclear to me. I'm posting them again to see if there was a reason they were dropped or if they just got lost. Dave? Time? The last patch adjusts proportional reclaim. Yuanhan Liu, can you retest the vm scalability test cases on a larger machine? Hugh, does this work for you on the memcg test cases? Based on ext4, I get the following results but unfortunately my larger test machines are all unavailable so this is based on a relatively small machine. postmark 3.15.0-rc5 3.15.0-rc5 vanilla proportion-v1r4 Ops/sec Transactions 21.00 ( 0.00%) 25.00 ( 19.05%) Ops/sec FilesCreate 39.00 ( 0.00%) 45.00 ( 15.38%) Ops/sec CreateTransact 10.00 ( 0.00%) 12.00 ( 20.00%) Ops/sec FilesDeleted 6202.00 ( 0.00%) 6202.00 ( 0.00%) Ops/sec DeleteTransact 11.00 ( 0.00%) 12.00 ( 9.09%) Ops/sec DataRead/MB 25.97 ( 0.00%) 30.02 ( 15.59%) Ops/sec DataWrite/MB 49.99 ( 0.00%) 57.78 ( 15.58%) ffsb (mail server simulator) 3.15.0-rc5 3.15.0-rc5 vanilla proportion-v1r4 Ops/sec readall 9402.63 ( 0.00%) 9805.74 ( 4.29%) Ops/sec create 4695.45 ( 0.00%) 4781.39 ( 1.83%) Ops/sec delete 173.72 ( 0.00%) 177.23 ( 2.02%) Ops/sec Transactions 14271.80 ( 0.00%) 14764.37 ( 3.45%) Ops/sec Read 37.00 ( 0.00%) 38.50 ( 4.05%) Ops/sec Write 18.20 ( 0.00%) 18.50 ( 1.65%) dd of a large file 3.15.0-rc5 3.15.0-rc5 vanilla proportion-v1r4 WallTime DownloadTar 75.00 ( 0.00%) 61.00 ( 18.67%) WallTime DD 423.00 ( 0.00%) 401.00 ( 5.20%) WallTime Delete 2.00 ( 0.00%) 5.00 (-150.00%) stutter (times mmap latency during large amounts of IO) 3.15.0-rc5 3.15.0-rc5 vanilla proportion-v1r4 Unit >5ms Delays 80252.0000 ( 0.00%) 81523.0000 ( -1.58%) Unit Mmap min 8.2118 ( 0.00%) 8.3206 ( -1.33%) Unit Mmap mean 17.4614 ( 0.00%) 17.2868 ( 1.00%) Unit Mmap stddev 24.9059 ( 0.00%) 34.6771 (-39.23%) Unit Mmap max 2811.6433 ( 0.00%) 2645.1398 ( 5.92%) Unit Mmap 90% 20.5098 ( 0.00%) 18.3105 ( 10.72%) Unit Mmap 93% 22.9180 ( 0.00%) 20.1751 ( 11.97%) Unit Mmap 95% 25.2114 ( 0.00%) 22.4988 ( 10.76%) Unit Mmap 99% 46.1430 ( 0.00%) 43.5952 ( 5.52%) Unit Ideal Tput 85.2623 ( 0.00%) 78.8906 ( 7.47%) Unit Tput min 44.0666 ( 0.00%) 43.9609 ( 0.24%) Unit Tput mean 45.5646 ( 0.00%) 45.2009 ( 0.80%) Unit Tput stddev 0.9318 ( 0.00%) 1.1084 (-18.95%) Unit Tput max 46.7375 ( 0.00%) 46.7539 ( -0.04%) This patch (of 3): We will like to unregister the sb shrinker before ->kill_sb(). This will allow cached objects to be counted without call to grab_super_passive() to update ref count on sb. We want to avoid locking during memory reclamation especially when we are skipping the memory reclaim when we are out of cached objects. This is safe because grab_super_passive does a try-lock on the sb->s_umount now, and so if we are in the unmount process, it won't ever block. That means what used to be a deadlock and races we were avoiding by using grab_super_passive() is now: shrinker umount down_read(shrinker_rwsem) down_write(sb->s_umount) shrinker_unregister down_write(shrinker_rwsem) <blocks> grab_super_passive(sb) down_read_trylock(sb->s_umount) <fails> <shrinker aborts> .... <shrinkers finish running> up_read(shrinker_rwsem) <unblocks> <removes shrinker> up_write(shrinker_rwsem) ->kill_sb() .... So it is safe to deregister the shrinker before ->kill_sb(). Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Chinner <david@fromorbit.com> Tested-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Jan Kara <jack@suse.cz> Acked-by: Rik van Riel <riel@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21callers of iov_copy_from_user_atomic() don't need pagecache_disable()Al Viro
commit 9e8c2af96e0d2d5fe298dd796fb6bc16e888a48d upstream. ... it does that itself (via kmap_atomic()) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm: remove read_cache_page_async()Sasha Levin
commit 67f9fd91f93c582b7de2ab9325b6e179db77e4d5 upstream. This patch removes read_cache_page_async() which wasn't really needed anywhere and simplifies the code around it a bit. read_cache_page_async() is useful when we want to read a page into the cache without waiting for it to complete. This happens when the appropriate callback 'filler' doesn't complete its read operation and releases the page lock immediately, and instead queues a different completion routine to do that. This never actually happened anywhere in the code. read_cache_page_async() had 3 different callers: - read_cache_page() which is the sync version, it would just wait for the requested read to complete using wait_on_page_read(). - JFFS2 would call it from jffs2_gc_fetch_page(), but the filler function it supplied doesn't do any async reads, and would complete before the filler function returns - making it actually a sync read. - CRAMFS would call it using the read_mapping_page_async() wrapper, with a similar story to JFFS2 - the filler function doesn't do anything that reminds async reads and would always complete before the filler function returns. To sum it up, the code in mm/filemap.c never took advantage of having read_cache_page_async(). While there are filler callbacks that do async reads (such as the block one), we always called it with the read_cache_page(). This patch adds a mandatory wait for read to complete when adding a new page to the cache, and removes read_cache_page_async() and its wrappers. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm + fs: prepare for non-page entries in page cache radix treesJohannes Weiner
commit 0cd6144aadd2afd19d1aca880153530c52957604 upstream. shmem mappings already contain exceptional entries where swap slot information is remembered. To be able to store eviction information for regular page cache, prepare every site dealing with the radix trees directly to handle entries other than pages. The common lookup functions will filter out non-page entries and return NULL for page cache holes, just as before. But provide a raw version of the API which returns non-page entries as well, and switch shmem over to use it. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm: filemap: move radix tree hole searching hereJohannes Weiner
commit e7b563bb2a6f4d974208da46200784b9c5b5a47e upstream. The radix tree hole searching code is only used for page cache, for example the readahead code trying to get a a picture of the area surrounding a fault. It sufficed to rely on the radix tree definition of holes, which is "empty tree slot". But this is about to change, though, as shadow page descriptors will be stored in the page cache after the actual pages get evicted from memory. Move the functions over to mm/filemap.c and make them native page cache operations, where they can later be adapted to handle the new definition of "page cache hole". Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21GFS2: Fix address space from page functionSteven Whitehouse
commit 1b2ad41214c9bf6e8befa000f0522629194bf540 upstream. Now that rgrps use the address space which is part of the super block, we need to update gfs2_mapping2sbd() to take account of that. The only way to do that easily is to use a different set of address_space_operations for rgrps. Reported-by: Abhi Das <adas@redhat.com> Tested-by: Abhi Das <adas@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21NFSv4.1: nfs41_clear_delegation_stateid shouldn't trust NFS_DELEGATED_STATETrond Myklebust
commit 0c116cadd94b16b30b1dd90d38b2784d9b39b01a upstream. This patch removes the assumption made previously, that we only need to check the delegation stateid when it matches the stateid on a cached open. If we believe that we hold a delegation for this file, then we must assume that its stateid may have been revoked or expired too. If we don't test it then our state recovery process may end up caching open/lock state in a situation where it should not. We therefore rename the function nfs41_clear_delegation_stateid as nfs41_check_delegation_stateid, and change it to always run through the delegation stateid test and recovery process as outlined in RFC5661. http://lkml.kernel.org/r/CAN-5tyHwG=Cn2Q9KsHWadewjpTTy_K26ee+UnSvHvG4192p-Xw@mail.gmail.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21NFSv4: Fix races between nfs_remove_bad_delegation() and delegation returnTrond Myklebust
commit 869f9dfa4d6d57b79e0afc3af14772c2a023eeb1 upstream. Any attempt to call nfs_remove_bad_delegation() while a delegation is being returned is currently a no-op. This means that we can end up looping forever in nfs_end_delegation_return() if something causes the delegation to be revoked. This patch adds a mechanism whereby the state recovery code can communicate to the delegation return code that the delegation is no longer valid and that it should not be used when reclaiming state. It also changes the return value for nfs4_handle_delegation_recall_error() to ensure that nfs_end_delegation_return() does not reattempt the lock reclaim before state recovery is done. http://lkml.kernel.org/r/CAN-5tyHwG=Cn2Q9KsHWadewjpTTy_K26ee+UnSvHvG4192p-Xw@mail.gmail.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21nfs: Fix use of uninitialized variable in nfs_getattr()Jan Kara
commit 16caf5b6101d03335b386e77e9e14136f989be87 upstream. Variable 'err' needn't be initialized when nfs_getattr() uses it to check whether it should call generic_fillattr() or not. That can result in spurious error returns. Initialize 'err' properly. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21NFS: Don't try to reclaim delegation open state if recovery failedTrond Myklebust
commit f8ebf7a8ca35dde321f0cd385fee6f1950609367 upstream. If state recovery failed, then we should not attempt to reclaim delegated state. http://lkml.kernel.org/r/CAN-5tyHwG=Cn2Q9KsHWadewjpTTy_K26ee+UnSvHvG4192p-Xw@mail.gmail.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21NFSv4: Ensure that we remove NFSv4.0 delegations when state has expiredTrond Myklebust
commit 4dfd4f7af0afd201706ad186352ca423b0f17d4b upstream. NFSv4.0 does not have TEST_STATEID/FREE_STATEID functionality, so unlike NFSv4.1, the recovery procedure when stateids have expired or have been revoked requires us to just forget the delegation. http://lkml.kernel.org/r/CAN-5tyHwG=Cn2Q9KsHWadewjpTTy_K26ee+UnSvHvG4192p-Xw@mail.gmail.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
