path: root/fs
2013-04-05nohz: stat: Fix CPU idle time accountingBo Yan
Since cpustat[CPUTIME_IDLE] is never connected to ts->idle_sleeptime, never read from cpustat[CPUTIME_IDLE] when reporting stats in /proc/stat. Note this was rejected by Michal Hocko when it was initially proposed by Martin Schwidefsky in LKML, so if you want to upstream it, better find an alternative (either completely disable cpustat[CPUTIME_IDLE] for CONFIG_NO_HZ or somehow connect them to keep them in sync.) bug 1190321 Change-Id: Idc92488910b826aff850a010016d8326c7ab9e6c Signed-off-by: Bo Yan <byan@nvidia.com> Reviewed-on: http://git-master/r/214638 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Liang Cheng (SW) <licheng@nvidia.com> Tested-by: Liang Cheng (SW) <licheng@nvidia.com>
2013-01-23NFS: Clear key construction data if the idmap upcall failsBryan Schumaker
idmap_pipe_downcall already clears this field if the upcall succeeds, but if it fails (rpc.idmapd isn't running) the field will still be set on the next call triggering a BUG_ON(). This patch tries to handle all possible ways that the upcall could fail and clear the idmap key data for each one. Bug 1217799 Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Preetham Chandru <pchandru@nvidia.com> (cherry picked from commit c5066945b7ea346a11424dbeb7830b7d7d00c206) Change-Id: Ie78c29df9b0af6a4906e86c53964f550b0f6b3d1 Reviewed-on: http://git-master/r/192868 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Kiran Adduri <kadduri@nvidia.com> Reviewed-by: Mursalin Akon <makon@nvidia.com> Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2012-11-30Revert "Revert "cpuquiet: Update averaging of nr_runnables""Peter Boonstoppel
This reverts commit 3bca5808dcc371ea4e1d6ce555e3eae76fbe0e7e. Bug 1050445 Bug 1050721 Change-Id: I6d51de129a10236e43c9ce262f879aa0f8361c77 Signed-off-by: Peter Boonstoppel <pboonstoppel@nvidia.com> Reviewed-on: http://git-master/r/163096 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Ilan Aelion <iaelion@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
2012-09-26Revert "cpuquiet: Update averaging of nr_runnables"Puneet Saxena
This reverts commit 8bd999a85354485af3cbee872816a9921d8bfffc. bug 1050721 Change-Id: I29fcff431e5427dfaa2524a12c5702154037018a Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: http://git-master/r/134307 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-09-14cpuquiet: Update averaging of nr_runnablesSai Charan Gurrappadi
Doing a Exponential moving average per nr_running++/-- does not guarantee a fixed sample rate which induces errors if there are lots of threads being enqueued/dequeued from the rq (Linpack mt). Instead of keeping track of the avg, the scheduler now keeps track of the integral of nr_running and allows the readers to perform filtering on top. Implemented a proper exponential moving average for the runnables governor and a straight 100ms average for the balanced governor. Tweaked the thresholds for the runnables governor to minimize latency. Also, decreased sample_rate for the runnables governor to the absolute minimum of 10msecs. Updated to K3.4 Change-Id: Ia25bf8baf2a1a015ba188b2c06e551e89b16c5f8 Signed-off-by: Sai Charan Gurrappadi <sgurrappadi@nvidia.com> Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Reviewed-on: http://git-master/r/131147 Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-08-30Merge commit 'v3.4.10' into android-t114-3.4Varun Wadekar
2012-08-26ext4: fix kernel BUG on large-scale rm -rf commandsTheodore Ts'o
commit 89a4e48f8479f8145eca9698f39fe188c982212f upstream. Commit 968dee7722: "ext4: fix hole punch failure when depth is greater than 0" introduced a regression in v3.5.1/v3.6-rc1 which caused kernel crashes when users ran run "rm -rf" on large directory hierarchy on ext4 filesystems on RAID devices: BUG: unable to handle kernel NULL pointer dereference at 0000000000000028 Process rm (pid: 18229, threadinfo ffff8801276bc000, task ffff880123631710) Call Trace: [<ffffffff81236483>] ? __ext4_handle_dirty_metadata+0x83/0x110 [<ffffffff812353d3>] ext4_ext_truncate+0x193/0x1d0 [<ffffffff8120a8cf>] ? ext4_mark_inode_dirty+0x7f/0x1f0 [<ffffffff81207e05>] ext4_truncate+0xf5/0x100 [<ffffffff8120cd51>] ext4_evict_inode+0x461/0x490 [<ffffffff811a1312>] evict+0xa2/0x1a0 [<ffffffff811a1513>] iput+0x103/0x1f0 [<ffffffff81196d84>] do_unlinkat+0x154/0x1c0 [<ffffffff8118cc3a>] ? sys_newfstatat+0x2a/0x40 [<ffffffff81197b0b>] sys_unlinkat+0x1b/0x50 [<ffffffff816135e9>] system_call_fastpath+0x16/0x1b Code: 8b 4d 20 0f b7 41 02 48 8d 04 40 48 8d 04 81 49 89 45 18 0f b7 49 02 48 83 c1 01 49 89 4d 00 e9 ae f8 ff ff 0f 1f 00 49 8b 45 28 <48> 8b 40 28 49 89 45 20 e9 85 f8 ff ff 0f 1f 80 00 00 00 RIP [<ffffffff81233164>] ext4_ext_remove_space+0xa34/0xdf0 This could be reproduced as follows: The problem in commit 968dee7722 was that caused the variable 'i' to be left uninitialized if the truncate required more space than was available in the journal. This resulted in the function ext4_ext_truncate_extend_restart() returning -EAGAIN, which caused ext4_ext_remove_space() to restart the truncate operation after starting a new jbd2 handle. Reported-by: Maciej Żenczykowski <maze@google.com> Reported-by: Marti Raudsepp <marti@juffo.org> Tested-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-26ext4: fix long mount times on very big file systemsTheodore Ts'o
commit 0548bbb85337e532ca2ed697c3e9b227ff2ed4b4 upstream. Commit 8aeb00ff85a: "ext4: fix overhead calculation used by ext4_statfs()" introduced a O(n**2) calculation which makes very large file systems take forever to mount. Fix this with an optimization for non-bigalloc file systems. (For bigalloc file systems the overhead needs to be set in the the superblock.) Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-26ext4: avoid kmemcheck complaint from reading uninitialized memoryTheodore Ts'o
commit 7e731bc9a12339f344cddf82166b82633d99dd86 upstream. Commit 03179fe923 introduced a kmemcheck complaint in ext4_da_get_block_prep() because we save and restore ei->i_da_metadata_calc_last_lblock even though it is left uninitialized in the case where i_da_metadata_calc_len is zero. This doesn't hurt anything, but silencing the kmemcheck complaint makes it easier for people to find real bugs. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=45631 (which is marked as a regression). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-26ext4: make sure the journal sb is written in ext4_clear_journal_err()Theodore Ts'o
commit d796c52ef0b71a988364f6109aeb63d79c5b116b upstream. After we transfer set the EXT4_ERROR_FS bit in the file system superblock, it's not enough to call jbd2_journal_clear_err() to clear the error indication from journal superblock --- we need to call jbd2_journal_update_sb_errno() as well. Otherwise, when the root file system is mounted read-only, the journal is replayed, and the error indicator is transferred to the superblock --- but the s_errno field in the jbd2 superblock is left set (since although we cleared it in memory, we never flushed it out to disk). This can end up confusing e2fsck. We should make e2fsck more robust in this case, but the kernel shouldn't be leaving things in this confused state, either. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-26fuse: verify all ioctl retry iov elementsZach Brown
commit fb6ccff667712c46b4501b920ea73a326e49626a upstream. Commit 7572777eef78ebdee1ecb7c258c0ef94d35bad16 attempted to verify that the total iovec from the client doesn't overflow iov_length() but it only checked the first element. The iovec could still overflow by starting with a small element. The obvious fix is to check all the elements. The overflow case doesn't look dangerous to the kernel as the copy is limited by the length after the overflow. This fix restores the intention of returning an error instead of successfully copying less than the iovec represented. I found this by code inspection. I built it but don't have a test case. I'm cc:ing stable because the initial commit did as well. Signed-off-by: Zach Brown <zab@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-23Merge commit 'v3.4.9' into android-t114-3.4Varun Wadekar
Linux v3.4.9 Conflicts: arch/arm/kernel/smp.c arch/arm/vfp/entry.S Change-Id: I731e815ed35ba9280374a5a3e5a6a8b6b805d695 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-08-15ore: Fix out-of-bounds access in _ios_obj()Boaz Harrosh
commit 9e62bb4458ad2cf28bd701aa5fab380b846db326 upstream. _ios_obj() is accessed by group_index not device_table index. The oc->comps array is only a group_full of devices at a time it is not like ore_comp_dev() which is indexed by a global device_table index. This did not BUG until now because exofs only uses a single COMP for all devices. But with other FSs like PanFS this is not true. This bug was only in the write_path, all other users were using it correctly [This is a bug since 3.2 Kernel] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15nilfs2: fix deadlock issue between chcp and thaw ioctlsRyusuke Konishi
commit 572d8b3945a31bee7c40d21556803e4807fd9141 upstream. An fs-thaw ioctl causes deadlock with a chcp or mkcp -s command: chcp D ffff88013870f3d0 0 1325 1324 0x00000004 ... Call Trace: nilfs_transaction_begin+0x11c/0x1a0 [nilfs2] wake_up_bit+0x20/0x20 copy_from_user+0x18/0x30 [nilfs2] nilfs_ioctl_change_cpmode+0x7d/0xcf [nilfs2] nilfs_ioctl+0x252/0x61a [nilfs2] do_page_fault+0x311/0x34c get_unmapped_area+0x132/0x14e do_vfs_ioctl+0x44b/0x490 __set_task_blocked+0x5a/0x61 vm_mmap_pgoff+0x76/0x87 __set_current_blocked+0x30/0x4a sys_ioctl+0x4b/0x6f system_call_fastpath+0x16/0x1b thaw D ffff88013870d890 0 1352 1351 0x00000004 ... Call Trace: rwsem_down_failed_common+0xdb/0x10f call_rwsem_down_write_failed+0x13/0x20 down_write+0x25/0x27 thaw_super+0x13/0x9e do_vfs_ioctl+0x1f5/0x490 vm_mmap_pgoff+0x76/0x87 sys_ioctl+0x4b/0x6f filp_close+0x64/0x6c system_call_fastpath+0x16/0x1b where the thaw ioctl deadlocked at thaw_super() when called while chcp was waiting at nilfs_transaction_begin() called from nilfs_ioctl_change_cpmode(). This deadlock is 100% reproducible. This is because nilfs_ioctl_change_cpmode() first locks sb->s_umount in read mode and then waits for unfreezing in nilfs_transaction_begin(), whereas thaw_super() locks sb->s_umount in write mode. The locking of sb->s_umount here was intended to make snapshot mounts and the downgrade of snapshots to checkpoints exclusive. This fixes the deadlock issue by replacing the sb->s_umount usage in nilfs_ioctl_change_cpmode() with a dedicated mutex which protects snapshot mounts. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-13Merge commit 'v3.4.8' into android-t114-3.4-rebasedVarun Wadekar
Linux v3.4.8 Conflicts: drivers/net/tun.c kernel/power/suspend.c Change-Id: Ia26546425cd20f127dbf4dd58cfca41bda47d23d Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-08-09ext4: undo ext4_calc_metadata_amount if we fail to claim spaceTheodore Ts'o
commit 03179fe92318e7934c180d96f12eff2cb36ef7b6 upstream. The function ext4_calc_metadata_amount() has side effects, although it's not obvious from its function name. So if we fail to claim space, regardless of whether we retry to claim the space again, or return an error, we need to undo these side effects. Otherwise we can end up incorrectly calculating the number of metadata blocks needed for the operation, which was responsible for an xfstests failure for test #271 when using an ext2 file system with delalloc enabled. Reported-by: Brian Foster <bfoster@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09ext4: don't let i_reserved_meta_blocks go negativeBrian Foster
commit 97795d2a5b8d3c8dc4365d4bd3404191840453ba upstream. If we hit a condition where we have allocated metadata blocks that were not appropriately reserved, we risk underflow of ei->i_reserved_meta_blocks. In turn, this can throw sbi->s_dirtyclusters_counter significantly out of whack and undermine the nondelalloc fallback logic in ext4_nonda_switch(). Warn if this occurs and set i_allocated_meta_blocks to avoid this problem. This condition is reproduced by xfstests 270 against ext2 with delalloc enabled: Mar 28 08:58:02 localhost kernel: [ 171.526344] EXT4-fs (loop1): delayed block allocation failed for inode 14 at logical offset 64486 with max blocks 64 with error -28 Mar 28 08:58:02 localhost kernel: [ 171.526346] EXT4-fs (loop1): This should not happen!! Data will be lost 270 ultimately fails with an inconsistent filesystem and requires an fsck to repair. The cause of the error is an underflow in ext4_da_update_reserve_space() due to an unreserved meta block allocation. Signed-off-by: Brian Foster <bfoster@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09ext4: fix hole punch failure when depth is greater than 0Ashish Sangwan
commit 968dee77220768a5f52cf8b21d0bdb73486febef upstream. Whether to continue removing extents or not is decided by the return value of function ext4_ext_more_to_rm() which checks 2 conditions: a) if there are no more indexes to process. b) if the number of entries are decreased in the header of "depth -1". In case of hole punch, if the last block to be removed is not part of the last extent index than this index will not be deleted, hence the number of valid entries in the extent header of "depth - 1" will remain as it is and ext4_ext_more_to_rm will return 0 although the required blocks are not yet removed. This patch fixes the above mentioned problem as instead of removing the extents from the end of file, it starts removing the blocks from the particular extent from which removing blocks is actually required and continue backward until done. Signed-off-by: Ashish Sangwan <ashish.sangwan2@gmail.com> Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Reviewed-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09ext4: fix overhead calculation used by ext4_statfs()Theodore Ts'o
commit 952fc18ef9ec707ebdc16c0786ec360295e5ff15 upstream. Commit f975d6bcc7a introduced bug which caused ext4_statfs() to miscalculate the number of file system overhead blocks. This causes the f_blocks field in the statfs structure to be larger than it should be. This would in turn cause the "df" output to show the number of data blocks in the file system and the number of data blocks used to be larger than they should be. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09ext4: pass a char * to ext4_count_free() instead of a buffer_head ptrTheodore Ts'o
commit f6fb99cadcd44660c68e13f6eab28333653621e6 upstream. Make it possible for ext4_count_free to operate on buffers and not just data in buffer_heads. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09NFS: Fix a number of bugs in the idmapperDavid Howells
commit a427b9ec4eda8cd6e641ea24541d30b641fc3140 upstream. Fix a number of bugs in the NFS idmapper code: (1) Only registered key types can be passed to the core keys code, so register the legacy idmapper key type. This is a requirement because the unregister function cleans up keys belonging to that key type so that there aren't dangling pointers to the module left behind - including the key->type pointer. (2) Rename the legacy key type. You can't have two key types with the same name, and (1) would otherwise require that. (3) complete_request_key() must be called in the error path of nfs_idmap_legacy_upcall(). (4) There is one idmap struct for each nfs_client struct. This means that idmap->idmap_key_cons is shared without the use of a lock. This is a problem because key_instantiate_and_link() - as called indirectly by idmap_pipe_downcall() - releases anyone waiting for the key to be instantiated. What happens is that idmap_pipe_downcall() running in the rpc.idmapd thread, releases the NFS filesystem in whatever thread that is running in to continue. This may then make another idmapper call, overwriting idmap_key_cons before idmap_pipe_downcall() gets the chance to call complete_request_key(). I *think* that reading idmap_key_cons only once, before key_instantiate_and_link() is called, and then caching the result in a variable is sufficient. Bug (4) is the cause of: BUG: unable to handle kernel NULL pointer dereference at (null) IP: [< (null)>] (null) PGD 0 Oops: 0010 [#1] SMP CPU 1 Modules linked in: ppdev parport_pc lp parport ip6table_filter ip6_tables ebtable_nat ebtables ipt_MASQUERADE iptable_nat nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 xt_state nf_conntrack nfs fscache xt_CHECKSUM auth_rpcgss iptable_mangle nfs_acl bridge stp llc lockd be2iscsi iscsi_boot_sysfs bnx2i cnic uio cxgb4i cxgb4 cxgb3i libcxgbi cxgb3 mdio ib_iser rdma_cm ib_cm iw_cm ib_sa ib_mad ib_core ib_addr iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi snd_hda_codec_realtek snd_usb_audio snd_hda_intel snd_hda_codec snd_seq snd_pcm snd_hwdep snd_usbmidi_lib snd_rawmidi snd_timer uvcvideo videobuf2_core videodev media videobuf2_vmalloc snd_seq_device videobuf2_memops e1000e vhost_net iTCO_wdt joydev coretemp snd soundcore macvtap macvlan i2c_i801 snd_page_alloc tun iTCO_vendor_support microcode kvm_intel kvm sunrpc hid_logitech_dj usb_storage i915 drm_kms_helper drm i2c_algo_bit i2c_core video [last unloaded: scsi_wait_scan] Pid: 1229, comm: rpc.idmapd Not tainted 3.4.2-1.fc16.x86_64 #1 Gateway DX4710-UB801A/G33M05G1 RIP: 0010:[<0000000000000000>] [< (null)>] (null) RSP: 0018:ffff8801a3645d40 EFLAGS: 00010246 RAX: ffff880077707e30 RBX: ffff880077707f50 RCX: ffff8801a18ccd80 RDX: 0000000000000006 RSI: ffff8801a3645e75 RDI: ffff880077707f50 RBP: ffff8801a3645d88 R08: ffff8801a430f9c0 R09: ffff8801a3645db0 R10: 000000000000000a R11: 0000000000000246 R12: ffff8801a18ccd80 R13: ffff8801a3645e75 R14: ffff8801a430f9c0 R15: 0000000000000006 FS: 00007fb6fb51a700(0000) GS:ffff8801afc80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000000 CR3: 00000001a49b0000 CR4: 00000000000027e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process rpc.idmapd (pid: 1229, threadinfo ffff8801a3644000, task ffff8801a3bf9710) Stack: ffffffff81260878 ffff8801a3645db0 ffff8801a3645db0 ffff880077707a90 ffff880077707f50 ffff8801a18ccd80 0000000000000006 ffff8801a3645e75 ffff8801a430f9c0 ffff8801a3645dd8 ffffffff81260983 ffff8801a3645de8 Call Trace: [<ffffffff81260878>] ? __key_instantiate_and_link+0x58/0x100 [<ffffffff81260983>] key_instantiate_and_link+0x63/0xa0 [<ffffffffa057062b>] idmap_pipe_downcall+0x1cb/0x1e0 [nfs] [<ffffffffa0107f57>] rpc_pipe_write+0x67/0x90 [sunrpc] [<ffffffff8117f833>] vfs_write+0xb3/0x180 [<ffffffff8117fb5a>] sys_write+0x4a/0x90 [<ffffffff81600329>] system_call_fastpath+0x16/0x1b Code: Bad RIP value. RIP [< (null)>] (null) RSP <ffff8801a3645d40> CR2: 0000000000000000 Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Steve Dickson <steved@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09nfs: skip commit in releasepage if we're freeing memory for fs-related reasonsJeff Layton
commit 5cf02d09b50b1ee1c2d536c9cf64af5a7d433f56 upstream. We've had some reports of a deadlock where rpciod ends up with a stack trace like this: PID: 2507 TASK: ffff88103691ab40 CPU: 14 COMMAND: "rpciod/14" #0 [ffff8810343bf2f0] schedule at ffffffff814dabd9 #1 [ffff8810343bf3b8] nfs_wait_bit_killable at ffffffffa038fc04 [nfs] #2 [ffff8810343bf3c8] __wait_on_bit at ffffffff814dbc2f #3 [ffff8810343bf418] out_of_line_wait_on_bit at ffffffff814dbcd8 #4 [ffff8810343bf488] nfs_commit_inode at ffffffffa039e0c1 [nfs] #5 [ffff8810343bf4f8] nfs_release_page at ffffffffa038bef6 [nfs] #6 [ffff8810343bf528] try_to_release_page at ffffffff8110c670 #7 [ffff8810343bf538] shrink_page_list.clone.0 at ffffffff81126271 #8 [ffff8810343bf668] shrink_inactive_list at ffffffff81126638 #9 [ffff8810343bf818] shrink_zone at ffffffff8112788f #10 [ffff8810343bf8c8] do_try_to_free_pages at ffffffff81127b1e #11 [ffff8810343bf958] try_to_free_pages at ffffffff8112812f #12 [ffff8810343bfa08] __alloc_pages_nodemask at ffffffff8111fdad #13 [ffff8810343bfb28] kmem_getpages at ffffffff81159942 #14 [ffff8810343bfb58] fallback_alloc at ffffffff8115a55a #15 [ffff8810343bfbd8] ____cache_alloc_node at ffffffff8115a2d9 #16 [ffff8810343bfc38] kmem_cache_alloc at ffffffff8115b09b #17 [ffff8810343bfc78] sk_prot_alloc at ffffffff81411808 #18 [ffff8810343bfcb8] sk_alloc at ffffffff8141197c #19 [ffff8810343bfce8] inet_create at ffffffff81483ba6 #20 [ffff8810343bfd38] __sock_create at ffffffff8140b4a7 #21 [ffff8810343bfd98] xs_create_sock at ffffffffa01f649b [sunrpc] #22 [ffff8810343bfdd8] xs_tcp_setup_socket at ffffffffa01f6965 [sunrpc] #23 [ffff8810343bfe38] worker_thread at ffffffff810887d0 #24 [ffff8810343bfee8] kthread at ffffffff8108dd96 #25 [ffff8810343bff48] kernel_thread at ffffffff8100c1ca rpciod is trying to allocate memory for a new socket to talk to the server. The VM ends up calling ->releasepage to get more memory, and it tries to do a blocking commit. That commit can't succeed however without a connected socket, so we deadlock. Fix this by setting PF_FSTRANS on the workqueue task prior to doing the socket allocation, and having nfs_release_page check for that flag when deciding whether to do a commit call. Also, set PF_FSTRANS unconditionally in rpc_async_schedule since that function can also do allocations sometimes. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09nfsd4: our filesystems are normally case sensitiveJ. Bruce Fields
commit 2930d381d22b9c56f40dd4c63a8fa59719ca2c3c upstream. Actually, xfs and jfs can optionally be case insensitive; we'll handle that case in later patches. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09pnfs-obj: Fix __r4w_get_page when offset is beyond i_sizeBoaz Harrosh
commit c999ff68029ebd0f56ccae75444f640f6d5a27d2 upstream. It is very common for the end of the file to be unaligned on stripe size. But since we know it's beyond file's end then the XOR should be preformed with all zeros. Old code used to just read zeros out of the OSD devices, which is a great waist. But what scares me more about this situation is that, we now have pages attached to the file's mapping that are beyond i_size. I don't like the kind of bugs this calls for. Fix both birds, by returning a global zero_page, if offset is beyond i_size. TODO: Change the API to ->__r4w_get_page() so a NULL can be returned without being considered as error, since XOR API treats NULL entries as zero_pages. [Bug since 3.2. Should apply the same way to all Kernels since] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> [bwh: Backported to 3.2: adjust for lack of wdata->header] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09posix_types.h: Cleanup stale __NFDBITS and related definitionsJosh Boyer
commit 8ded2bbc1845e19c771eb55209aab166ef011243 upstream. Recently, glibc made a change to suppress sign-conversion warnings in FD_SET (glibc commit ceb9e56b3d1). This uncovered an issue with the kernel's definition of __NFDBITS if applications #include <linux/types.h> after including <sys/select.h>. A build failure would be seen when passing the -Werror=sign-compare and -D_FORTIFY_SOURCE=2 flags to gcc. It was suggested that the kernel should either match the glibc definition of __NFDBITS or remove that entirely. The current in-kernel uses of __NFDBITS can be replaced with BITS_PER_LONG, and there are no uses of the related __FDELT and __FDMASK defines. Given that, we'll continue the cleanup that was started with commit 8b3d1cda4f5f ("posix_types: Remove fd_set macros") and drop the remaining unused macros. Additionally, linux/time.h has similar macros defined that expand to nothing so we'll remove those at the same time. Reported-by: Jeff Law <law@redhat.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Josh Boyer <jwboyer@redhat.com> [ .. and fix up whitespace as per akpm ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09cifs: reinstate sec=ntlmv2 mount optionJeff Layton
commit 7659624ffb550d69c87f9af9ae63e717daa874bd upstream. sec=ntlmv2 as a mount option got dropped in the mount option overhaul. Cc: Sachin Prabhu <sprabhu@redhat.com> Reported-by: Günter Kukkukk <linux@kukkukk.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09Btrfs: call the ordered free operation without any locks heldChris Mason
commit e9fbcb42201c862fd6ab45c48ead4f47bb2dea9d upstream. Each ordered operation has a free callback, and this was called with the worker spinlock held. Josef made the free callback also call iput, which we can't do with the spinlock. This drops the spinlock for the free operation and grabs it again before moving through the rest of the list. We'll circle back around to this and find a cleaner way that doesn't bounce the lock around so much. Signed-off-by: Chris Mason <chris.mason@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09udf: Improve table length check to avoid possible overflowJan Kara
commit 57b9655d01ef057a523e810d29c37ac09b80eead upstream. When a partition table length is corrupted to be close to 1 << 32, the check for its length may overflow on 32-bit systems and we will think the length is valid. Later on the kernel can crash trying to read beyond end of buffer. Fix the check to avoid possible overflow. Reported-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09locks: fix checking of fcntl_setlease argumentJ. Bruce Fields
commit 0ec4f431eb56d633da3a55da67d5c4b88886ccc7 upstream. The only checks of the long argument passed to fcntl(fd,F_SETLEASE,.) are done after converting the long to an int. Thus some illegal values may be let through and cause problems in later code. [ They actually *don't* cause problems in mainline, as of Dave Jones's commit 8d657eb3b438 "Remove easily user-triggerable BUG from generic_setlease", but we should fix this anyway. And this patch will be necessary to fix real bugs on earlier kernels. ] Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-29cifs: when CONFIG_HIGHMEM is set, serialize the read/write kmapsJeff Layton
commit 3cf003c08be785af4bee9ac05891a15bcbff856a upstream. [The async read code was broadened to include uncached reads in 3.5, so the mainline patch did not apply directly. This patch is just a backport to account for that change.] Jian found that when he ran fsx on a 32 bit arch with a large wsize the process and one of the bdi writeback kthreads would sometimes deadlock with a stack trace like this: crash> bt PID: 2789 TASK: f02edaa0 CPU: 3 COMMAND: "fsx" #0 [eed63cbc] schedule at c083c5b3 #1 [eed63d80] kmap_high at c0500ec8 #2 [eed63db0] cifs_async_writev at f7fabcd7 [cifs] #3 [eed63df0] cifs_writepages at f7fb7f5c [cifs] #4 [eed63e50] do_writepages at c04f3e32 #5 [eed63e54] __filemap_fdatawrite_range at c04e152a #6 [eed63ea4] filemap_fdatawrite at c04e1b3e #7 [eed63eb4] cifs_file_aio_write at f7fa111a [cifs] #8 [eed63ecc] do_sync_write at c052d202 #9 [eed63f74] vfs_write at c052d4ee #10 [eed63f94] sys_write at c052df4c #11 [eed63fb0] ia32_sysenter_target at c0409a98 EAX: 00000004 EBX: 00000003 ECX: abd73b73 EDX: 012a65c6 DS: 007b ESI: 012a65c6 ES: 007b EDI: 00000000 SS: 007b ESP: bf8db178 EBP: bf8db1f8 GS: 0033 CS: 0073 EIP: 40000424 ERR: 00000004 EFLAGS: 00000246 Each task would kmap part of its address array before getting stuck, but not enough to actually issue the write. This patch fixes this by serializing the marshal_iov operations for async reads and writes. The idea here is to ensure that cifs aggressively tries to populate a request before attempting to fulfill another one. As soon as all of the pages are kmapped for a request, then we can unlock and allow another one to proceed. There's no need to do this serialization on non-CONFIG_HIGHMEM arches however, so optimize all of this out when CONFIG_HIGHMEM isn't set. Reported-by: Jian Li <jiali@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-29pnfs-obj: don't leak objio_state if ore_write/read failsBoaz Harrosh
commit 9909d45a8557455ca5f8ee7af0f253debc851f1a upstream. [Bug since 3.2 Kernel] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-29ore: Remove support of partial IO request (NFS crash)Boaz Harrosh
commit 62b62ad873f2accad9222a4d7ffbe1e93f6714c1 upstream. Do to OOM situations the ore might fail to allocate all resources needed for IO of the full request. If some progress was possible it would proceed with a partial/short request, for the sake of forward progress. Since this crashes NFS-core and exofs is just fine without it just remove this contraption, and fail. TODO: Support real forward progress with some reserved allocations of resources, such as mem pools and/or bio_sets [Bug since 3.2 Kernel] CC: Benny Halevy <bhalevy@tonian.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-29ore: Fix NFS crash by supporting any unaligned RAID IOBoaz Harrosh
commit 9ff19309a9623f2963ac5a136782ea4d8b5d67fb upstream. In RAID_5/6 We used to not permit an IO that it's end byte is not stripe_size aligned and spans more than one stripe. .i.e the caller must check if after submission the actual transferred bytes is shorter, and would need to resubmit a new IO with the remainder. Exofs supports this, and NFS was supposed to support this as well with it's short write mechanism. But late testing has exposed a CRASH when this is used with none-RPC layout-drivers. The change at NFS is deep and risky, in it's place the fix at ORE to lift the limitation is actually clean and simple. So here it is below. The principal here is that in the case of unaligned IO on both ends, beginning and end, we will send two read requests one like old code, before the calculation of the first stripe, and also a new site, before the calculation of the last stripe. If any "boundary" is aligned or the complete IO is within a single stripe. we do a single read like before. The code is clean and simple by splitting the old _read_4_write into 3 even parts: 1._read_4_write_first_stripe 2. _read_4_write_last_stripe 3. _read_4_write_execute And calling 1+3 at the same place as before. 2+3 before last stripe, and in the case of all in a single stripe then 1+2+3 is preformed additively. Why did I not think of it before. Well I had a strike of genius because I have stared at this code for 2 years, and did not find this simple solution, til today. Not that I did not try. This solution is much better for NFS than the previous supposedly solution because the short write was dealt with out-of-band after IO_done, which would cause for a seeky IO pattern where as in here we execute in order. At both solutions we do 2 separate reads, only here we do it within a single IO request. (And actually combine two writes into a single submission) NFS/exofs code need not change since the ORE API communicates the new shorter length on return, what will happen is that this case would not occur anymore. hurray!! [Stable this is an NFS bug since 3.2 Kernel should apply cleanly] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-29UBIFS: fix a bug in empty space fix-upArtem Bityutskiy
commit c6727932cfdb13501108b16c38463c09d5ec7a74 upstream. UBIFS has a feature called "empty space fix-up" which is a quirk to work-around limitations of dumb flasher programs. Namely, of those flashers that are unable to skip NAND pages full of 0xFFs while flashing, resulting in empty space at the end of half-filled eraseblocks to be unusable for UBIFS. This feature is relatively new (introduced in v3.0). The fix-up routine (fixup_free_space()) is executed only once at the very first mount if the superblock has the 'space_fixup' flag set (can be done with -F option of mkfs.ubifs). It basically reads all the UBIFS data and metadata and writes it back to the same LEB. The routine assumes the image is pristine and does not have anything in the journal. There was a bug in 'fixup_free_space()' where it fixed up the log incorrectly. All but one LEB of the log of a pristine file-system are empty. And one contains just a commit start node. And 'fixup_free_space()' just unmapped this LEB, which resulted in wiping the commit start node. As a result, some users were unable to mount the file-system next time with the following symptom: UBIFS error (pid 1): replay_log_leb: first log node at LEB 3:0 is not CS node UBIFS error (pid 1): replay_log_leb: log error detected while replaying the log at LEB 3:0 The root-cause of this bug was that 'fixup_free_space()' wrongly assumed that the beginning of empty space in the log head (c->lhead_offs) was known on mount. However, it is not the case - it was always 0. UBIFS does not store in it the master node and finds out by scanning the log on every mount. The fix is simple - just pass commit start node size instead of 0 to 'fixup_leb()'. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com> Reported-by: Iwo Mergler <Iwo.Mergler@netcommwireless.com> Tested-by: Iwo Mergler <Iwo.Mergler@netcommwireless.com> Reported-by: James Nute <newten82@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-29ext4: fix duplicated mnt_drop_write call in EXT4_IOC_MOVE_EXTAl Viro
commit 331ae4962b975246944ea039697a8f1cadce42bb upstream. Caused, AFAICS, by mismerge in commit ff9cb1c4eead ("Merge branch 'for_linus' into for_linus_merged") Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-29cifs: on CONFIG_HIGHMEM machines, limit the rsize/wsize to the kmap spaceJeff Layton
commit 3ae629d98bd5ed77585a878566f04f310adbc591 upstream. We currently rely on being able to kmap all of the pages in an async read or write request. If you're on a machine that has CONFIG_HIGHMEM set then that kmap space is limited, sometimes to as low as 512 slots. With 512 slots, we can only support up to a 2M r/wsize, and that's assuming that we can get our greedy little hands on all of them. There are other users however, so it's possible we'll end up stuck with a size that large. Since we can't handle a rsize or wsize larger than that currently, cap those options at the number of kmap slots we have. We could consider capping it even lower, but we currently default to a max of 1M. Might as well allow those luddites on 32 bit arches enough rope to hang themselves. A more robust fix would be to teach the send and receive routines how to contend with an array of pages so we don't need to marshal up a kvec array at all. That's a fairly significant overhaul though, so we'll need this limit in place until that's ready. Reported-by: Jian Li <jiali@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-29cifs: always update the inode cache with the results from a FIND_*Jeff Layton
commit cd60042cc1392e79410dc8de9e9c1abb38a29e57 upstream. When we get back a FIND_FIRST/NEXT result, we have some info about the dentry that we use to instantiate a new inode. We were ignoring and discarding that info when we had an existing dentry in the cache. Fix this by updating the inode in place when we find an existing dentry and the uniqueid is the same. Reported-and-Tested-by: Andrew Bartlett <abartlet@samba.org> Reported-by: Bill Robertson <bill_robertson@debortoli.com.au> Reported-by: Dion Edwards <dion_edwards@debortoli.com.au> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-25Merge commit 'v3.4.6' into android-t114-3.4Varun Wadekar
Linux v3.4.6 Change-Id: I4518a173ca2852188ebd48121723c8be29d0c682 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-07-23epoll: Fix user space breakage related to EPOLLWAKEUPRafael J. Wysocki
Commit 4d7e30d (epoll: Add a flag, EPOLLWAKEUP, to prevent suspend while epoll events are ready) caused some applications to malfunction, because they set the bit corresponding to the new EPOLLWAKEUP flag in their eventpoll flags and they don't have the new CAP_EPOLLWAKEUP capability. To prevent that from happening, change epoll_ctl() to clear EPOLLWAKEUP in epds.events if the caller doesn't have the CAP_EPOLLWAKEUP capability instead of failing and returning an error code, which allows the affected applications to function normally. Reported-and-tested-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-07-23epoll: Add a flag, EPOLLWAKEUP, to prevent suspend while epoll events are readyArve Hjønnevåg
When an epoll_event, that has the EPOLLWAKEUP flag set, is ready, a wakeup_source will be active to prevent suspend. This can be used to handle wakeup events from a driver that support poll, e.g. input, if that driver wakes up the waitqueue passed to epoll before allowing suspend. Signed-off-by: Arve Hjønnevåg <arve@android.com> Reviewed-by: NeilBrown <neilb@suse.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-07-19fifo: Do not restart open() if it already found a partnerAnders Kaseorg
commit 05d290d66be6ef77a0b962ebecf01911bd984a78 upstream. If a parent and child process open the two ends of a fifo, and the child immediately exits, the parent may receive a SIGCHLD before its open() returns. In that case, we need to make sure that open() will return successfully after the SIGCHLD handler returns, instead of throwing EINTR or being restarted. Otherwise, the restarted open() would incorrectly wait for a second partner on the other end. The following test demonstrates the EINTR that was wrongly thrown from the parent’s open(). Change .sa_flags = 0 to .sa_flags = SA_RESTART to see a deadlock instead, in which the restarted open() waits for a second reader that will never come. (On my systems, this happens pretty reliably within about 5 to 500 iterations. Others report that it manages to loop ~forever sometimes; YMMV.) #include <sys/stat.h> #include <sys/types.h> #include <sys/wait.h> #include <fcntl.h> #include <signal.h> #include <stdio.h> #include <stdlib.h> #include <unistd.h> #define CHECK(x) do if ((x) == -1) {perror(#x); abort();} while(0) void handler(int signum) {} int main() { struct sigaction act = {.sa_handler = handler, .sa_flags = 0}; CHECK(sigaction(SIGCHLD, &act, NULL)); CHECK(mknod("fifo", S_IFIFO | S_IRWXU, 0)); for (;;) { int fd; pid_t pid; putc('.', stderr); CHECK(pid = fork()); if (pid == 0) { CHECK(fd = open("fifo", O_RDONLY)); _exit(0); } CHECK(fd = open("fifo", O_WRONLY)); CHECK(close(fd)); CHECK(waitpid(pid, NULL, 0)); } } This is what I suspect was causing the Git test suite to fail in t9010-svn-fe.sh: http://bugs.debian.org/678852 Signed-off-by: Anders Kaseorg <andersk@mit.edu> Reviewed-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-19block: fix infinite loop in __getblk_slowJeff Moyer
commit 91f68c89d8f35fe98ea04159b9a3b42d0149478f upstream. Commit 080399aaaf35 ("block: don't mark buffers beyond end of disk as mapped") exposed a bug in __getblk_slow that causes mount to hang as it loops infinitely waiting for a buffer that lies beyond the end of the disk to become uptodate. The problem was initially reported by Torsten Hilbrich here: https://lkml.org/lkml/2012/6/18/54 and also reported independently here: http://www.sysresccd.org/forums/viewtopic.php?f=13&t=4511 and then Richard W.M. Jones and Marcos Mello noted a few separate bugzillas also associated with the same issue. This patch has been confirmed to fix: https://bugzilla.redhat.com/show_bug.cgi?id=835019 The main problem is here, in __getblk_slow: for (;;) { struct buffer_head * bh; int ret; bh = __find_get_block(bdev, block, size); if (bh) return bh; ret = grow_buffers(bdev, block, size); if (ret < 0) return NULL; if (ret == 0) free_more_memory(); } __find_get_block does not find the block, since it will not be marked as mapped, and so grow_buffers is called to fill in the buffers for the associated page. I believe the for (;;) loop is there primarily to retry in the case of memory pressure keeping grow_buffers from succeeding. However, we also continue to loop for other cases, like the block lying beond the end of the disk. So, the fix I came up with is to only loop when grow_buffers fails due to memory allocation issues (return value of 0). The attached patch was tested by myself, Torsten, and Rich, and was found to resolve the problem in call cases. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Reported-and-Tested-by: Torsten Hilbrich <torsten.hilbrich@secunet.com> Tested-by: Richard W.M. Jones <rjones@redhat.com> Reviewed-by: Josh Boyer <jwboyer@redhat.com> [ Jens is on vacation, taking this directly - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-19Remove easily user-triggerable BUG from generic_setleaseDave Jones
commit 8d657eb3b43861064d36241e88d9d61c709f33f0 upstream. This can be trivially triggered from userspace by passing in something unexpected. kernel BUG at fs/locks.c:1468! invalid opcode: 0000 [#1] SMP RIP: 0010:generic_setlease+0xc2/0x100 Call Trace: __vfs_setlease+0x35/0x40 fcntl_setlease+0x76/0x150 sys_fcntl+0x1c6/0x810 system_call_fastpath+0x1a/0x1f Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-18Merge commit 'v3.4.5' into android-t114-3.4-rebasedVarun Wadekar
Linux v3.4.5 Conflicts: drivers/base/power/main.c Change-Id: I782e650a89665caea8aed9e5598234888dc11088 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-07-16ocfs2: fix NULL pointer dereference in __ocfs2_change_file_space()Luis Henriques
commit a4e08d001f2e50bb8b3c4eebadcf08e5535f02ee upstream. As ocfs2_fallocate() will invoke __ocfs2_change_file_space() with a NULL as the first parameter (file), it may trigger a NULL pointer dereferrence due to a missing check. Addresses http://bugs.launchpad.net/bugs/1006012 Signed-off-by: Luis Henriques <luis.henriques@canonical.com> Reported-by: Bret Towe <magnade@gmail.com> Tested-by: Bret Towe <magnade@gmail.com> Cc: Sunil Mushran <sunil.mushran@oracle.com> Acked-by: Joel Becker <jlbec@evilplan.org> Acked-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16fs: ramfs: file-nommu: add SetPageUptodate()Bob Liu
commit fea9f718b3d68147f162ed2d870183ce5e0ad8d8 upstream. There is a bug in the below scenario for !CONFIG_MMU: 1. create a new file 2. mmap the file and write to it 3. read the file can't get the correct value Because sys_read() -> generic_file_aio_read() -> simple_readpage() -> clear_page() which causes the page to be zeroed. Add SetPageUptodate() to ramfs_nommu_expand_for_mapping() so that generic_file_aio_read() do not call simple_readpage(). Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16splice: fix racy pipe->buffers usesEric Dumazet
commit 047fe3605235888f3ebcda0c728cb31937eadfe6 upstream. Dave Jones reported a kernel BUG at mm/slub.c:3474! triggered by splice_shrink_spd() called from vmsplice_to_pipe() commit 35f3d14dbbc5 (pipe: add support for shrinking and growing pipes) added capability to adjust pipe->buffers. Problem is some paths don't hold pipe mutex and assume pipe->buffers doesn't change for their duration. Fix this by adding nr_pages_max field in struct splice_pipe_desc, and use it in place of pipe->buffers where appropriate. splice_shrink_spd() loses its struct pipe_inode_info argument. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Tom Herbert <therbert@google.com> Tested-by: Dave Jones <davej@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> [bwh: Backported to 3.2: - Adjust context in vmsplice_to_pipe() - Update one more call to splice_shrink_spd(), from skb_splice_bits()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16NFS: hard-code init_net for NFS callback transportsStanislav Kinsbursky
upstream commit 12918b10d59e975fd5241eef03ef9e6d5ea3dcfe. In case of destroying mount namespace on child reaper exit, nsproxy is zeroed to the point already. So, dereferencing of it is invalid. This patch hard-code "init_net" for all network namespace references for NFS callback services. This will be fixed with proper NFS callback containerization. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16SUNRPC: move per-net operations from svc_destroy()Stanislav Kinsbursky
upstream commit 786185b5f8abefa6a8a16695bb4a59c164d5a071. The idea is to separate service destruction and per-net operations, because these are two different things and the mix looks ugly. Notes: 1) For NFS server this patch looks ugly (sorry for that). But these place will be rewritten soon during NFSd containerization. 2) LockD per-net counter increase int lockd_up() was moved prior to make_socks() to make lockd_down_net() call safe in case of error. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16SUNRPC: new svc_bind() routine introducedStanislav Kinsbursky
upstream commit 9793f7c88937e7ac07305ab1af1a519225836823. This new routine is responsible for service registration in a specified network context. The idea is to separate service creation from per-net operations. Note also: since registering service with svc_bind() can fail, the service will be destroyed and during destruction it will try to unregister itself from rpcbind. In this case unregistration has to be skipped. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
