mount
commit a41cbe86df3afbc82311a1640e20858c0cd7e065 upstream.
A test case is as the description says:
open(foobar, O_WRONLY);
sleep() --> reboot the server
close(foobar)
The bug is because in nfs4state.c in nfs4_reclaim_open_state() a few
line before going to restart, there is
clear_bit(NFS4CLNT_RECLAIM_NOGRACE, &state->flags).
NFS4CLNT_RECLAIM_NOGRACE is a flag for the client states not open
owner states. Value of NFS4CLNT_RECLAIM_NOGRACE is 4 which is the
value of NFS_O_WRONLY_STATE in nfs4_state->flags. So clearing it wipes
out state and when we go to close it, “call_close” doesn’t get set as
state flag is not set and CLOSE doesn’t go on the wire.
Signed-off-by: Olga Kornievskaia <aglo@umich.edu>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 646200a041203f440fb6fcf9cacd9efeda9de74c upstream.
The error paths in set_file_size for cifs and smb3 are incorrect.
In the unlikely event that a server did not support set file info
of the file size, the code incorrectly falls back to trying SMBWriteX
(note that only the original core SMB Write, used for example by DOS,
can set the file size this way - this actually does not work for the more
recent SMBWriteX). The idea was since the old DOS SMB Write could set
the file size if you write zero bytes at that offset then use that if
server rejects the normal set file info call.
Fortunately the SMBWriteX will never be sent on the wire (except when
file size is zero) since the length and offset fields were reversed
in the two places in this function that call SMBWriteX causing
the fall back path to return an error. It is also important to never call
an SMB request from an SMB2/sMB3 session (which theoretically would
be possible, and can cause a brief session drop, although the client
recovers) so this should be fixed. In practice this path does not happen
with modern servers but the error fall back to SMBWriteX is clearly wrong.
Removing the calls to SMBWriteX in the error paths in cifs_set_file_size
Pointed out by PaX/grsecurity team
Signed-off-by: Steve French <steve.french@primarydata.com>
Reported-by: PaX Team <pageexec@freemail.hu>
CC: Emese Revfy <re.emese@gmail.com>
CC: Brad Spengler <spender@grsecurity.net>
[bwh: Backported to 3.2: deleted code looks slightly different]
commit 841df7df196237ea63233f0f9eaa41db53afd70f upstream.
Commit 6f6a6fda2945 "jbd2: fix ocfs2 corrupt when updating journal
superblock fails" changed jbd2_cleanup_journal_tail() to return EIO
when the journal is aborted. That makes logic in
jbd2_log_do_checkpoint() bail out which is fine, except that
jbd2_journal_destroy() expects jbd2_log_do_checkpoint() to always make
a progress in cleaning the journal. Without it jbd2_journal_destroy()
just loops in an infinite loop.
Fix jbd2_journal_destroy() to cleanup journal checkpoint lists of
jbd2_log_do_checkpoint() fails with error.
Reported-by: Eryu Guan <guaneryu@gmail.com>
Tested-by: Eryu Guan <guaneryu@gmail.com>
Fixes: 6f6a6fda294506dfe0e3e0a253bb2d2923f28f0a
Signed-off-by: Jan Kara <jack@suse.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
[bwh: Backported to 3.2: adjust context]
Cc: Roland Dreier <roland@kernel.org>
commit 012572d4fc2e4ddd5c8ec8614d51414ec6cae02a upstream.
The order of the following three spinlocks should be:
dlm_domain_lock < dlm_ctxt->spinlock < dlm_lock_resource->spinlock
But dlm_dispatch_assert_master() is called while holding
dlm_ctxt->spinlock and dlm_lock_resource->spinlock, and then it calls
dlm_grab() which will take dlm_domain_lock.
Once another thread (for example, dlm_query_join_handler) has already
taken dlm_domain_lock, and tries to take dlm_ctxt->spinlock deadlock
happens.
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: "Junxiao Bi" <junxiao.bi@oracle.com>
commit 98ce94c8df762d413b3ecb849e2b966b21606d04 upstream.
Linux cifs mount with ntlmssp against an Mac OS X (Yosemite
10.10.5) share fails in case the clocks differ more than +/-2h:
digest-service: digest-request: od failed with 2 proto=ntlmv2
digest-service: digest-request: kdc failed with -1561745592 proto=ntlmv2
Fix this by (re-)using the given server timestamp for the
ntlmv2 authentication (as Windows 7 does).
A related problem was also reported earlier by Namjae Jaen (see below):
Windows machine has extended security feature which refuse to allow
authentication when there is time difference between server time and
client time when ntlmv2 negotiation is used. This problem is prevalent
in embedded enviornment where system time is set to default 1970.
Modern servers send the server timestamp in the TargetInfo Av_Pair
structure in the challenge message [see MS-NLMP 2.2.2.1]
In [MS-NLMP 3.1.5.1.2] it is explicitly mentioned that the client must
use the server provided timestamp if present OR current time if it is
not
Reported-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Peter Seiderer <ps.report@gmx.net>
Signed-off-by: Steve French <smfrench@gmail.com>
commit a30e577c96f59b1e1678ea5462432b09bf7d5cbc upstream.
In btrfs_evict_inode, we properly truncate the page cache for evicted
inodes but then we call btrfs_wait_ordered_range for every inode as well.
It's the right thing to do for regular files but results in incorrect
behavior for device inodes for block devices.
filemap_fdatawrite_range gets called with inode->i_mapping which gets
resolved to the block device inode before getting passed to
wbc_attach_fdatawrite_inode and ultimately to inode_to_bdi. What happens
next depends on whether there's an open file handle associated with the
inode. If there is, we write to the block device, which is unexpected
behavior. If there isn't, we through normally and inode->i_data is used.
We can also end up racing against open/close which can result in crashes
when i_mapping points to a block device inode that has been closed.
Since there can't be any page cache associated with special file inodes,
it's safe to skip the btrfs_wait_ordered_range call entirely and avoid
the problem.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=100911
Tested-by: Christoph Biedl <linux-kernel.bfrz@manchmal.in-ulm.de>
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Reviewed-by: Filipe Manana <fdmanana@suse.com>
commit 005efedf2c7d0a270ffbe28d8997b03844f3e3e7 upstream.
If a file has a range pointing to a compressed extent, followed by
another range that points to the same compressed extent and a read
operation attempts to read both ranges (either completely or part of
them), the pages that correspond to the second range are incorrectly
filled with zeroes.
Consider the following example:
File layout
[0 - 8K] [8K - 24K]
points to extent X, points to extent X,
offset 4K, length of 8K offset 0, length 16K
[extent X, compressed length = 4K uncompressed length = 16K]
If a readpages() call spans the 2 ranges, a single bio to read the extent
is submitted - extent_io.c:submit_extent_page() would only create a new
bio to cover the second range pointing to the extent if the extent it
points to had a different logical address than the extent associated with
the first range. This has a consequence of the compressed read end io
handler (compression.c:end_compressed_bio_read()) finish once the extent
is decompressed into the pages covering the first range, leaving the
remaining pages (belonging to the second range) filled with zeroes (done
by compression.c:btrfs_clear_biovec_end()).
So fix this by submitting the current bio whenever we find a range
pointing to a compressed extent that was preceded by a range with a
different extent map. This is the simplest solution for this corner
case. Making the end io callback populate both ranges (or more, if we
have multiple pointing to the same extent) is a much more complex
solution since each bio is tightly coupled with a single extent map and
the extent maps associated to the ranges pointing to the shared extent
can have different offsets and lengths.
The following test case for fstests triggers the issue:
seq=`basename $0`
seqres=$RESULT_DIR/$seq
echo "QA output created by $seq"
tmp=/tmp/$$
status=1 # failure is the default!
trap "_cleanup; exit \$status" 0 1 2 3 15
_cleanup()
rm -f $tmp.*
# get standard environment, filters and checks
. ./common/rc
. ./common/filter
# real QA test starts here
_need_to_be_root
_supported_fs btrfs
_supported_os Linux
_require_scratch
_require_cloner
rm -f $seqres.full
test_clone_and_read_compressed_extent()
local mount_opts=$1
_scratch_mkfs >>$seqres.full 2>&1
_scratch_mount $mount_opts
# Create a test file with a single extent that is compressed (the
# data we write into it is highly compressible no matter which
# compression algorithm is used, zlib or lzo).
$XFS_IO_PROG -f -c "pwrite -S 0xaa 0K 4K" \
-c "pwrite -S 0xbb 4K 8K" \
-c "pwrite -S 0xcc 12K 4K" \
$SCRATCH_MNT/foo | _filter_xfs_io
# Now clone our extent into an adjacent offset.
$CLONER_PROG -s $((4 * 1024)) -d $((16 * 1024)) -l $((8 * 1024)) \
$SCRATCH_MNT/foo $SCRATCH_MNT/foo
# Same as before but for this file we clone the extent into a lower
# file offset.
$XFS_IO_PROG -f -c "pwrite -S 0xaa 8K 4K" \
-c "pwrite -S 0xbb 12K 8K" \
-c "pwrite -S 0xcc 20K 4K" \
$SCRATCH_MNT/bar | _filter_xfs_io
$CLONER_PROG -s $((12 * 1024)) -d 0 -l $((8 * 1024)) \
$SCRATCH_MNT/bar $SCRATCH_MNT/bar
echo "File digests before unmounting filesystem:"
md5sum $SCRATCH_MNT/foo | _filter_scratch
md5sum $SCRATCH_MNT/bar | _filter_scratch
# Evicting the inode or clearing the page cache before reading
# again the file would also trigger the bug - reads were returning
# all bytes in the range corresponding to the second reference to
# the extent with a value of 0, but the correct data was persisted
# (it was a bug exclusively in the read path). The issue happened
# only if the same readpages() call targeted pages belonging to the
# first and second ranges that point to the same compressed extent.
_scratch_remount
echo "File digests after mounting filesystem again:"
# Must match the same digests we got before.
echo -e "\nTesting with zlib compression..."
test_clone_and_read_compressed_extent "-o compress=zlib"
_scratch_unmount
echo -e "\nTesting with lzo compression..."
test_clone_and_read_compressed_extent "-o compress=lzo"
status=0
exit
Signed-off-by: Filipe Manana <fdmanana@suse.com>
Reviewed-by: Qu Wenruo<quwenruo@cn.fujitsu.com>
Reviewed-by: Liu Bo <bo.li.liu@oracle.com>
- Maintain prev_em_start in both functions calling __extent_read_full_page()
in a loop
- Adjust context and order]
commit b4cc0efea4f0bfa2477c56af406cfcf3d3e58680 upstream.
Fix B-tree corruption when a new record is inserted at position 0 in the
node in hfs_brec_insert().
This is an identical change to the corresponding hfs b-tree code to Sergei
Antonov's "hfsplus: fix B-tree corruption after insertion at position 0",
to keep similar code paths in the hfs and hfsplus drivers in sync, where
appropriate.
Signed-off-by: Hin-Tak Leung <htl10@users.sourceforge.net>
Cc: Sergei Antonov <saproj@gmail.com>
Cc: Joe Perches <joe@perches.com>
Reviewed-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Anton Altaparmakov <anton@tuxera.com>
commit 7cb74be6fd827e314f81df3c5889b87e4c87c569 upstream.
Pages looked up by __hfs_bnode_create() (called by hfs_bnode_create() and
hfs_bnode_find() for finding or creating pages corresponding to an inode)
are immediately kmap()'ed and used (both read and write) and kunmap()'ed,
and should not be page_cache_release()'ed until hfs_bnode_free().
This patch fixes a problem I first saw in July 2012: merely running "du"
on a large hfsplus-mounted directory a few times on a reasonably loaded
system would get the hfsplus driver all confused and complaining about
B-tree inconsistencies, and generates a "BUG: Bad page state". Most
recently, I can generate this problem on up-to-date Fedora 22 with shipped
kernel 4.0.5, by running "du /" (="/" + "/home" + "/mnt" + other smaller
mounts) and "du /mnt" simultaneously on two windows, where /mnt is a
lightly-used QEMU VM image of the full Mac OS X 10.9:
$ df -i / /home /mnt
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/mapper/fedora-root 3276800 551665 2725135 17% /
/dev/mapper/fedora-home 52879360 716221 52163139 2% /home
/dev/nbd0p2 4294967295 1387818 4293579477 1% /mnt
After applying the patch, I was able to run "du /" (60+ times) and "du
/mnt" (150+ times) continuously and simultaneously for 6+ hours.
There are many reports of the hfsplus driver getting confused under load
and generating "BUG: Bad page state" or other similar issues over the
years. [1]
The unpatched code [2] has always been wrong since it entered the kernel
tree. The only reason why it gets away with it is that the
kmap/memcpy/kunmap follow very quickly after the page_cache_release() so
the kernel has not had a chance to reuse the memory for something else,
most of the time.
The current RW driver appears to have followed the design and development
of the earlier read-only hfsplus driver [3], where-by version 0.1 (Dec
2001) had a B-tree node-centric approach to
read_cache_page()/page_cache_release() per bnode_get()/bnode_put(),
migrating towards version 0.2 (June 2002) of caching and releasing pages
per inode extents. When the current RW code first entered the kernel [2]
in 2005, there was an REF_PAGES conditional (and "//" commented out code)
to switch between B-node centric paging to inode-centric paging. There
was a mistake with the direction of one of the REF_PAGES conditionals in
__hfs_bnode_create(). In a subsequent "remove debug code" commit [4], the
read_cache_page()/page_cache_release() per bnode_get()/bnode_put() were
removed, but a page_cache_release() was mistakenly left in (propagating
the "REF_PAGES <-> !REF_PAGE" mistake), and the commented-out
page_cache_release() in bnode_release() (which should be spanned by
!REF_PAGES) was never enabled.
References:
[1]:
Michael Fox, Apr 2013
http://www.spinics.net/lists/linux-fsdevel/msg63807.html
("hfsplus volume suddenly inaccessable after 'hfs: recoff %d too large'")
Sasha Levin, Feb 2015
http://lkml.org/lkml/2015/2/20/85 ("use after free")
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/740814
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1027887
https://bugzilla.kernel.org/show_bug.cgi?id=42342
https://bugzilla.kernel.org/show_bug.cgi?id=63841
https://bugzilla.kernel.org/show_bug.cgi?id=78761
[2]:
http://git.kernel.org/cgit/linux/kernel/git/tglx/history.git/commit/\
fs/hfs/bnode.c?id=d1081202f1d0ee35ab0beb490da4b65d4bc763db
commit d1081202f1d0ee35ab0beb490da4b65d4bc763db
Author: Andrew Morton <akpm@osdl.org>
Date: Wed Feb 25 16:17:36 2004 -0800
[PATCH] HFS rewrite
fs/hfsplus/bnode.c?id=91556682e0bf004d98a529bf829d339abb98bbbd
commit 91556682e0bf004d98a529bf829d339abb98bbbd
Date: Wed Feb 25 16:17:48 2004 -0800
[PATCH] HFS+ support
[3]:
http://sourceforge.net/projects/linux-hfsplus/
http://sourceforge.net/projects/linux-hfsplus/files/Linux%202.4.x%20patch/hfsplus%200.1/
http://sourceforge.net/projects/linux-hfsplus/files/Linux%202.4.x%20patch/hfsplus%200.2/
http://linux-hfsplus.cvs.sourceforge.net/viewvc/linux-hfsplus/linux/\
fs/hfsplus/bnode.c?r1=1.4&r2=1.5
Date: Thu Jun 6 09:45:14 2002 +0000
Use buffer cache instead of page cache in bnode.c. Cache inode extents.
[4]:
http://git.kernel.org/cgit/linux/kernel/git/\
stable/linux-stable.git/commit/?id=a5e3985fa014029eb6795664c704953720cc7f7d
commit a5e3985fa014029eb6795664c704953720cc7f7d
Author: Roman Zippel <zippel@linux-m68k.org>
Date: Tue Sep 6 15:18:47 2005 -0700
[PATCH] hfs: remove debug code
Signed-off-by: Sergei Antonov <saproj@gmail.com>
Reviewed-by: Anton Altaparmakov <anton@tuxera.com>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Cc: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Sougata Santra <sougata@tuxera.com>
commit 1c90308e7a77af6742a97d1021cca923b23b7f0d upstream.
This patch makes pagemap readable for normal users and hides physical
addresses from them. For some use-cases PFN isn't required at all.
See http://lkml.kernel.org/r/1425935472-17949-1-git-send-email-kirill@shutemov.name
Fixes: ab676b7d6fbf ("pagemap: do not leak physical addresses to non-privileged userspace")
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Mark Williamson <mwilliamson@undo-software.com>
Tested-by: Mark Williamson <mwilliamson@undo-software.com>
- Add the same check in the places where we look up a PFN
- Add struct pagemapread * parameters where necessary
- Open-code file_ns_capable()
- Delete pagemap_open() entirely, as it would always return 0]
commit a068acf2ee77693e0bf39d6e07139ba704f461c3 upstream.
Many file systems that implement the show_options hook fail to correctly
escape their output which could lead to unescaped characters (e.g. new
lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This
could lead to confusion, spoofed entries (resulting in things like
systemd issuing false d-bus "mount" notifications), and who knows what
else. This looks like it would only be the root user stepping on
themselves, but it's possible weird things could happen in containers or
in other situations with delegated mount privileges.
Here's an example using overlay with setuid fusermount trusting the
contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use
of "sudo" is something more sneaky:
$ BASE="ovl"
$ MNT="$BASE/mnt"
$ LOW="$BASE/lower"
$ UP="$BASE/upper"
$ WORK="$BASE/work/ 0 0
none /proc fuse.pwn user_id=1000"
$ mkdir -p "$LOW" "$UP" "$WORK"
$ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt
$ cat /proc/mounts
none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0
none /proc fuse.pwn user_id=1000 0 0
$ fusermount -u /proc
$ cat /proc/mounts
cat: /proc/mounts: No such file or directory
This fixes the problem by adding new seq_show_option and
seq_show_option_n helpers, and updating the vulnerable show_option
handlers to use them as needed. Some, like SELinux, need to be open
coded due to unusual existing escape mechanisms.
[akpm@linux-foundation.org: add lost chunk, per Kees]
[keescook@chromium.org: seq_show_option should be using const parameters]
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: J. R. Okajima <hooanon05g@gmail.com>
- Drop changes to overlayfs, reiserfs
- Drop vers option from cifs
- ceph changes are all in one file
- Adjust context]
commit c9eb256eda4420c06bb10f5e8fbdbe1a34bc98e0 upstream.
There is an issue with xfs's error reporting in some cases of I/O partially
failing and partially succeeding. Calls like fsync() can report success even
though not all I/O was successful in partial-failure cases such as one disk of
a RAID0 array being offline.
The issue can occur when there are more than one bio per xfs_ioend struct.
Each call to xfs_end_bio() for a bio completing will write a value to
ioend->io_error. If a successful bio completes after any failed bio, no
error is reported do to it writing 0 over the error code set by any failed bio.
The I/O error information is now lost and when the ioend is completed
only success is reported back up the filesystem stack.
xfs_end_bio() should only set ioend->io_error in the case of BIO_UPTODATE
being clear. ioend->io_error is initialized to 0 at allocation so only needs
to be updated by a failed bio. Also check that ioend->io_error is 0 so that
the first error reported will be the error code returned.
Signed-off-by: David Jeffery <djeffery@redhat.com>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
commit ffeecc5213024ae663377b442eedcfbacf6d0c5d upstream.
struct xfs_attr_leafblock contains 'entries' array which is declared
with size 1 altough it can in fact contain much more entries. Since this
array is followed by further struct members, gcc (at least in version
4.8.3) thinks that the array has the fixed size of 1 element and thus
may optimize away all accesses beyond the end of array resulting in
non-working code. This problem was only observed with userspace code in
xfsprogs, however it's better to be safe in kernel as well and have
matching kernel and xfsprogs definitions.
[bwh: Backported to 3.2: adjust filename]
commit 5556e7e6d30e8e9b5ee51b0e5edd526ee80e5e36 upstream.
Consider eCryptfs dcache entries to be stale when the corresponding
lower inode's i_nlink count is zero. This solves a problem caused by the
lower inode being directly modified, without going through the eCryptfs
mount, leaving stale eCryptfs dentries cached and the eCryptfs inode's
i_nlink count not being cleared.
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Reported-by: Richard Weinberger <richard@nod.at>
- Test d_revalidate pointer directly rather than a DCACHE_OP flag
- Open-code d_inode()
- Adjust context]
commit efcbc04e16dfa95fef76309f89710dd1d99a5453 upstream.
It is unusual to combine the open flags O_RDONLY and O_EXCL, but
it appears that libre-office does just that.
[pid 3250] stat("/home/USER/.config", {st_mode=S_IFDIR|0700, st_size=8192, ...}) = 0
[pid 3250] open("/home/USER/.config/libreoffice/4-suse/user/extensions/buildid", O_RDONLY|O_EXCL <unfinished ...>
NFSv4 takes O_EXCL as a sign that a setattr command should be sent,
probably to reset the timestamps.
When it was an O_RDONLY open, the SETATTR command does not
identify any actual attributes to change.
If no delegation was provided to the open, the SETATTR uses the
all-zeros stateid and the request is accepted (at least by the
Linux NFS server - no harm, no foul).
If a read-delegation was provided, this is used in the SETATTR
request, and a Netapp filer will justifiably claim
NFS4ERR_BAD_STATEID, which the Linux client takes as a sign
to retry - indefinitely.
So only treat O_EXCL specially if O_CREAT was also given.
Signed-off-by: NeilBrown <neilb@suse.com>
[bwh: Backported to 3.2: we only check open_flags, not createmode as well]
commit 397d425dc26da728396e66d392d5dcb8dac30c37 upstream.
In rare cases a directory can be renamed out from under a bind mount.
In those cases without special handling it becomes possible to walk up
the directory tree to the root dentry of the filesystem and down
from the root dentry to every other file or directory on the filesystem.
Like division by zero .. from an unconnected path can not be given
a useful semantic as there is no predicting at which path component
the code will realize it is unconnected. We certainly can not match
the current behavior as the current behavior is a security hole.
Therefore when encounting .. when following an unconnected path
return -ENOENT.
- Add a function path_connected to verify path->dentry is reachable
from path->mnt.mnt_root. AKA to validate that rename did not do
something nasty to the bind mount.
To avoid races path_connected must be called after following a path
component to it's next path component.
commit cde93be45a8a90d8c264c776fab63487b5038a65 upstream.
A rename can result in a dentry that by walking up d_parent
will never reach it's mnt_root. For lack of a better term
I call this an escaped path.
prepend_path is called by four different functions __d_path,
d_absolute_path, d_path, and getcwd.
__d_path only wants to see paths are connected to the root it passes
in. So __d_path needs prepend_path to return an error.
d_absolute_path similarly wants to see paths that are connected to
some root. Escaped paths are not connected to any mnt_root so
d_absolute_path needs prepend_path to return an error greater
than 1. So escaped paths will be treated like paths on lazily
unmounted mounts.
getcwd needs to prepend "(unreachable)" so getcwd also needs
d_path is the interesting hold out. d_path just wants to print
something, and does not care about the weird cases. Which raises
the question what should be printed?
Given that <escaped_path>/<anything> should result in -ENOENT I
believe it is desirable for escaped paths to be printed as empty
paths. As there are not really any meaninful path components when
considered from the perspective of a mount tree.
So tweak prepend_path to return an empty path with an new error
code of 3 when it encounters an escaped path.
commit 209f7512d007980fd111a74a064d70a3656079cf upstream.
The "BUG_ON(list_empty(&osb->blocked_lock_list))" in
ocfs2_downconvert_thread_do_work can be triggered in the following case:
ocfs2dc has firstly saved osb->blocked_lock_count to local varibale
processed, and then processes the dentry lockres. During the dentry
put, it calls iput and then deletes rw, inode and open lockres from
blocked list in ocfs2_mark_lockres_freeing. And this causes the
variable `processed' to not reflect the number of blocked lockres to be
processed, which triggers the BUG.
commit a78bb11d7acd525623c6a0c2ff4e213d527573fa upstream.
There are some log tail updates that are not protected by j_checkpoint_mutex.
Some of these are harmless because they happen during startup or shutdown but
updates in jbd2_journal_commit_transaction() and jbd2_journal_flush() can
really race with other log tail updates (e.g. someone doing
jbd2_journal_flush() with someone running jbd2_cleanup_journal_tail()). So
protect all log tail updates with j_checkpoint_mutex.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
- Adjust context
- Add unlock on the error path in jbd2_journal_flush()]
Cc: Bartosz Kwitniewski <zerg2000@astral.org.pl>
commit ed958762644b404654a6f5d23e869f496fe127c6 upstream.
Using the clone ioctl (or extent_same ioctl, which calls the same extent
cloning function as well) we end up allowing copy an inline extent from
the source file into a non-zero offset of the destination file. This is
something not expected and that the btrfs code is not prepared to deal
with - all inline extents must be at a file offset equals to 0.
For example, the following excerpt of a test case for fstests triggers
a crash/BUG_ON() on a write operation after an inline extent is cloned
into a non-zero offset:
_scratch_mount
# Create our test files. File foo has the same 2K of data at offset 4K
# as file bar has at its offset 0.
$XFS_IO_PROG -f -s -c "pwrite -S 0xaa 0 4K" \
-c "pwrite -S 0xbb 4k 2K" \
-c "pwrite -S 0xcc 8K 4K" \
# File bar consists of a single inline extent (2K size).
$XFS_IO_PROG -f -s -c "pwrite -S 0xbb 0 2K" \
# Now call the clone ioctl to clone the extent of file bar into file
# foo at its offset 4K. This made file foo have an inline extent at
# offset 4K, something which the btrfs code can not deal with in future
# IO operations because all inline extents are supposed to start at an
# offset of 0, resulting in all sorts of chaos.
# So here we validate that clone ioctl returns an EOPNOTSUPP, which is
# what it returns for other cases dealing with inlined extents.
$CLONER_PROG -s 0 -d $((4 * 1024)) -l $((2 * 1024)) \
$SCRATCH_MNT/bar $SCRATCH_MNT/foo
# Because of the inline extent at offset 4K, the following write made
# the kernel crash with a BUG_ON().
$XFS_IO_PROG -c "pwrite -S 0xdd 6K 2K" $SCRATCH_MNT/foo | _filter_xfs_io
status=0
exit
The stack trace of the BUG_ON() triggered by the last write is:
[152154.035903] ------------[ cut here ]------------
[152154.036424] kernel BUG at mm/page-writeback.c:2286!
[152154.036424] invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
[152154.036424] Modules linked in: btrfs dm_flakey dm_mod crc32c_generic xor raid6_pq nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc loop fuse parport_pc acpi_cpu$
[152154.036424] CPU: 2 PID: 17873 Comm: xfs_io Tainted: G W 4.1.0-rc6-btrfs-next-11+ #2
[152154.036424] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.8.1-0-g4adadbd-20150316_085822-nilsson.home.kraxel.org 04/01/2014
[152154.036424] task: ffff880429f70990 ti: ffff880429efc000 task.ti: ffff880429efc000
[152154.036424] RIP: 0010:[<ffffffff8111a9d5>] [<ffffffff8111a9d5>] clear_page_dirty_for_io+0x1e/0x90
[152154.036424] RSP: 0018:ffff880429effc68 EFLAGS: 00010246
[152154.036424] RAX: 0200000000000806 RBX: ffffea0006a6d8f0 RCX: 0000000000000001
[152154.036424] RDX: 0000000000000000 RSI: ffffffff81155d1b RDI: ffffea0006a6d8f0
[152154.036424] RBP: ffff880429effc78 R08: ffff8801ce389fe0 R09: 0000000000000001
[152154.036424] R10: 0000000000002000 R11: ffffffffffffffff R12: ffff8800200dce68
[152154.036424] R13: 0000000000000000 R14: ffff8800200dcc88 R15: ffff8803d5736d80
[152154.036424] FS: 00007fbf119f6700(0000) GS:ffff88043d280000(0000) knlGS:0000000000000000
[152154.036424] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[152154.036424] CR2: 0000000001bdc000 CR3: 00000003aa555000 CR4: 00000000000006e0
[152154.036424] Stack:
[152154.036424] ffff8803d5736d80 0000000000000001 ffff880429effcd8 ffffffffa04e97c1
[152154.036424] ffff880429effd68 ffff880429effd60 0000000000000001 ffff8800200dc9c8
[152154.036424] 0000000000000001 ffff8800200dcc88 0000000000000000 0000000000001000
[152154.036424] Call Trace:
[152154.036424] [<ffffffffa04e97c1>] lock_and_cleanup_extent_if_need+0x147/0x18d [btrfs]
[152154.036424] [<ffffffffa04ea82c>] __btrfs_buffered_write+0x245/0x4c8 [btrfs]
[152154.036424] [<ffffffffa04ed14b>] ? btrfs_file_write_iter+0x150/0x3e0 [btrfs]
[152154.036424] [<ffffffffa04ed15a>] ? btrfs_file_write_iter+0x15f/0x3e0 [btrfs]
[152154.036424] [<ffffffffa04ed2c7>] btrfs_file_write_iter+0x2cc/0x3e0 [btrfs]
[152154.036424] [<ffffffff81165a4a>] __vfs_write+0x7c/0xa5
[152154.036424] [<ffffffff81165f89>] vfs_write+0xa0/0xe4
[152154.036424] [<ffffffff81166855>] SyS_pwrite64+0x64/0x82
[152154.036424] [<ffffffff81465197>] system_call_fastpath+0x12/0x6f
[152154.036424] Code: 48 89 c7 e8 0f ff ff ff 5b 41 5c 5d c3 0f 1f 44 00 00 55 48 89 e5 41 54 53 48 89 fb e8 ae ef 00 00 49 89 c4 48 8b 03 a8 01 75 02 <0f> 0b 4d 85 e4 74 59 49 8b 3c 2$
[152154.036424] RIP [<ffffffff8111a9d5>] clear_page_dirty_for_io+0x1e/0x90
[152154.036424] RSP <ffff880429effc68>
[152154.242621] ---[ end trace e3d3376b23a57041 ]---
Fix this by returning the error EOPNOTSUPP if an attempt to copy an
inline extent into a non-zero offset happens, just like what is done for
other scenarios that would require copying/splitting inline extents,
which were introduced by the following commits:
00fdf13a2e9f ("Btrfs: fix a crash of clone with inline extents's split")
3f9e3df8da3c ("btrfs: replace error code from btrfs_drop_extents")
[bwh: Backported to 3.2: test new_key.offset as last_dest_end isn't defined
in this function]
commit 0a73d0a204a4a04a1e110539c5a524ae51f91d6d upstream.
commit 7444a072c387a93ebee7066e8aee776954ab0e41 upstream.
ext4_free_blocks is looping around the allocation request and mimics
__GFP_NOFAIL behavior without any allocation fallback strategy. Let's
remove the open coded loop and replace it with __GFP_NOFAIL. Without the
flag the allocator has no way to find out never-fail requirement and
cannot help in any way.
- Adjust context
- s/ext4_free_data_cachep/ext4_free_ext_cachep/]
commit c45653c341f5c8a0ce19c8f0ad4678640849cb86 upstream.
Switch ext4 to using sb_getblk_gfp with GFP_NOFS added to fix possible
deadlocks in the page writeback path.
Signed-off-by: Nikolay Borisov <kernel@kyup.com>
commit 3b5e6454aaf6b4439b19400d8365e2ec2d24e411 upstream.
A buffer cache is allocated from movable area because it is referred
for a while and released soon. But some filesystems are taking buffer
cache for a long time and it can disturb page migration.
New APIs are introduced to allocate buffer cache with user specific
flag. *_gfp APIs are for user want to set page allocation flag for
page cache allocation. And *_unmovable APIs are for the user wants to
allocate page cache from non-movable area.
Signed-off-by: Gioh Kim <gioh.kim@lge.com>
[bwh: Prerequisite for "bufferhead: Add _gfp version for sb_getblk()".
commit 0ad0b3255a08020eaf50e34ef0d6df5bdf5e09ed upstream.
fc->release is called from fuse_conn_put() which was used in the error
cleanup before fc->release was initialized.
[Jeremiah Mahler <jmmahler@gmail.com>: assign fc->release after calling
fuse_conn_init(fc) instead of before.]
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Fixes: a325f9b92273 ("fuse: update fuse_conn_init() and separate out fuse_conn_kill()")
commit ae9d8f17118551bedd797406a6768b87c2146234 upstream.
While the inode cache caching kthread is calling btrfs_unpin_free_ino(),
we could have a concurrent call to btrfs_return_ino() that adds a new
entry to the root's free space cache of pinned inodes. This concurrent
call does not acquire the fs_info->commit_root_sem before adding a new
entry if the caching state is BTRFS_CACHE_FINISHED, which is a problem
because the caching kthread calls btrfs_unpin_free_ino() after setting
the caching state to BTRFS_CACHE_FINISHED and therefore races with
the task calling btrfs_return_ino(), which is adding a new entry, while
the former (caching kthread) is navigating the cache's rbtree, removing
and freeing nodes from the cache's rbtree without acquiring the spinlock
that protects the rbtree.
This race resulted in memory corruption due to double free of struct
btrfs_free_space objects because both tasks can end up doing freeing the
same objects. Note that adding a new entry can result in merging it with
other entries in the cache, in which case those entries are freed.
This is particularly important as btrfs_free_space structures are also
used for the block group free space caches.
This memory corruption can be detected by a debugging kernel, which
reports it with the following trace:
[132408.501148] slab error in verify_redzone_free(): cache `btrfs_free_space': double free detected
[132408.505075] CPU: 15 PID: 12248 Comm: btrfs-ino-cache Tainted: G W 4.1.0-rc5-btrfs-next-10+ #1
[132408.505075] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.8.1-0-g4adadbd-20150316_085822-nilsson.home.kraxel.org 04/01/2014
[132408.505075] ffff880023e7d320 ffff880163d73cd8 ffffffff8145eec7 ffffffff81095dce
[132408.505075] ffff880009735d40 ffff880163d73ce8 ffffffff81154e1e ffff880163d73d68
[132408.505075] ffffffff81155733 ffffffffa054a95a ffff8801b6099f00 ffffffffa0505b5f
[132408.505075] Call Trace:
[132408.505075] [<ffffffff8145eec7>] dump_stack+0x4f/0x7b
[132408.505075] [<ffffffff81095dce>] ? console_unlock+0x356/0x3a2
[132408.505075] [<ffffffff81154e1e>] __slab_error.isra.28+0x25/0x36
[132408.505075] [<ffffffff81155733>] __cache_free+0xe2/0x4b6
[132408.505075] [<ffffffffa054a95a>] ? __btrfs_add_free_space+0x2f0/0x343 [btrfs]
[132408.505075] [<ffffffffa0505b5f>] ? btrfs_unpin_free_ino+0x8e/0x99 [btrfs]
[132408.505075] [<ffffffff810f3b30>] ? time_hardirqs_off+0x15/0x28
[132408.505075] [<ffffffff81084d42>] ? trace_hardirqs_off+0xd/0xf
[132408.505075] [<ffffffff811563a1>] ? kfree+0xb6/0x14e
[132408.505075] [<ffffffff811563d0>] kfree+0xe5/0x14e
[132408.505075] [<ffffffffa0505b5f>] btrfs_unpin_free_ino+0x8e/0x99 [btrfs]
[132408.505075] [<ffffffffa0505e08>] caching_kthread+0x29e/0x2d9 [btrfs]
[132408.505075] [<ffffffffa0505b6a>] ? btrfs_unpin_free_ino+0x99/0x99 [btrfs]
[132408.505075] [<ffffffff8106698f>] kthread+0xef/0xf7
[132408.505075] [<ffffffff810f3b08>] ? time_hardirqs_on+0x15/0x28
[132408.505075] [<ffffffff810668a0>] ? __kthread_parkme+0xad/0xad
[132408.505075] [<ffffffff814653d2>] ret_from_fork+0x42/0x70
[132408.505075] ffff880023e7d320: redzone 1:0x9f911029d74e35b, redzone 2:0x9f911029d74e35b.
[132409.501654] slab: double free detected in cache 'btrfs_free_space', objp ffff880023e7d320
[132409.503355] ------------[ cut here ]------------
[132409.504241] kernel BUG at mm/slab.c:2571!
Therefore fix this by having btrfs_unpin_free_ino() acquire the lock
that protects the rbtree while doing the searches and removing entries.
Fixes: 1c70d8fb4dfa ("Btrfs: fix inode caching vs tree log")
Signed-off-by: Chris Mason <clm@fb.com>
commit c3f4a1685bb87e59c886ee68f7967eae07d4dffa upstream.
The free space entries are allocated using kmem_cache_zalloc(),
through __btrfs_add_free_space(), therefore we should use
kmem_cache_free() and not kfree() to avoid any confusion and
any potential problem. Looking at the kfree() definition at
mm/slab.c it has the following comment:
* Don't free memory not originally allocated by kmalloc()
* or you will run into trouble.
So better be safe and use kmem_cache_free().
Reviewed-by: David Sterba <dsterba@suse.cz>
commit 292db1bc6c105d86111e858859456bcb11f90f91 upstream.
ext4 isn't willing to map clusters to a non-extent file. Don't signal
this with an out of space error, since the FS will retry the
allocation (which didn't fail) forever. Instead, return EUCLEAN so
that the operation will fail immediately all the way back to userspace.
(The fix is either to run e2fsck -E bmap2extent, or to chattr +e the file.)
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
commit 89d96a6f8e6491f24fc8f99fd6ae66820e85c6c1 upstream.
Normally all of the buffers will have been forced out to disk before
we call invalidate_bdev(), but there will be some cases, where a file
system operation was aborted due to an ext4_error(), where there may
still be some dirty buffers in the buffer cache for the device. So
try to force them out to memory before calling invalidate_bdev().
This fixes a warning triggered by generic/081:
WARNING: CPU: 1 PID: 3473 at /usr/projects/linux/ext4/fs/block_dev.c:56 __blkdev_put+0xb5/0x16f()
commit 6f6a6fda294506dfe0e3e0a253bb2d2923f28f0a upstream.
If updating journal superblock fails after journal data has been
flushed, the error is omitted and this will mislead the caller as a
normal case. In ocfs2, the checkpoint will be treated successfully
and the other node can get the lock to update. Since the sb_start is
still pointing to the old log block, it will rewrite the journal data
during journal recovery by the other node. Thus the new updates will
be overwritten and ocfs2 corrupts. So in above case we have to return
the error, and ocfs2_commit_cache will take care of the error and
prevent the other node to do update first. And only after recovering
journal it can do the new updates.
The issue discussion mail can be found at:
https://oss.oracle.com/pipermail/ocfs2-devel/2015-June/010856.html
http://comments.gmane.org/gmane.comp.file-systems.ext4/48841
[ Fixed bug in patch which allowed a non-negative error return from
jbd2_cleanup_journal_tail() to leak out of jbd2_fjournal_flush(); this
was causing xfstests ext4/306 to fail. -- Ted ]
Reported-by: Yiwen Jiang <jiangyiwen@huawei.com>
Tested-by: Yiwen Jiang <jiangyiwen@huawei.com>
Cc: Junxiao Bi <junxiao.bi@oracle.com>
- Adjust context
- Don't drop j_checkpoint_mutex where we don't hold it]
commit b4f1afcd068f6e533230dfed00782cd8a907f96b upstream.
jbd2_cleanup_journal_tail() can be invoked by jbd2__journal_start()
So allocations should be done with GFP_NOFS
[Full stack trace snipped from 3.10-rh7]
[<ffffffff815c4bd4>] dump_stack+0x19/0x1b
[<ffffffff8105dba1>] warn_slowpath_common+0x61/0x80
[<ffffffff8105dcca>] warn_slowpath_null+0x1a/0x20
[<ffffffff815c2142>] slab_pre_alloc_hook.isra.31.part.32+0x15/0x17
[<ffffffff8119c045>] kmem_cache_alloc+0x55/0x210
[<ffffffff811477f5>] ? mempool_alloc_slab+0x15/0x20
[<ffffffff811477f5>] mempool_alloc_slab+0x15/0x20
[<ffffffff81147939>] mempool_alloc+0x69/0x170
[<ffffffff815cb69e>] ? _raw_spin_unlock_irq+0xe/0x20
[<ffffffff8109160d>] ? finish_task_switch+0x5d/0x150
[<ffffffff811f1a8e>] bio_alloc_bioset+0x1be/0x2e0
[<ffffffff8127ee49>] blkdev_issue_flush+0x99/0x120
[<ffffffffa019a733>] jbd2_cleanup_journal_tail+0x93/0xa0 [jbd2] -->GFP_KERNEL
[<ffffffffa019aca1>] jbd2_log_do_checkpoint+0x221/0x4a0 [jbd2]
[<ffffffffa019afc7>] __jbd2_log_wait_for_space+0xa7/0x1e0 [jbd2]
[<ffffffffa01952d8>] start_this_handle+0x2d8/0x550 [jbd2]
[<ffffffff811b02a9>] ? __memcg_kmem_put_cache+0x29/0x30
[<ffffffff8119c120>] ? kmem_cache_alloc+0x130/0x210
[<ffffffffa019573a>] jbd2__journal_start+0xba/0x190 [jbd2]
[<ffffffff811532ce>] ? lru_cache_add+0xe/0x10
[<ffffffffa01c9549>] ? ext4_da_write_begin+0xf9/0x330 [ext4]
[<ffffffffa01f2c77>] __ext4_journal_start_sb+0x77/0x160 [ext4]
[<ffffffffa01c9549>] ext4_da_write_begin+0xf9/0x330 [ext4]
[<ffffffff811446ec>] generic_file_buffered_write_iter+0x10c/0x270
[<ffffffff81146918>] __generic_file_write_iter+0x178/0x390
[<ffffffff81146c6b>] __generic_file_aio_write+0x8b/0xb0
[<ffffffff81146ced>] generic_file_aio_write+0x5d/0xc0
[<ffffffffa01bf289>] ext4_file_write+0xa9/0x450 [ext4]
[<ffffffff811c31d9>] ? pipe_read+0x379/0x4f0
[<ffffffff811b93f0>] do_sync_write+0x90/0xe0
[<ffffffff811b9b6d>] vfs_write+0xbd/0x1e0
[<ffffffff811ba5b8>] SyS_write+0x58/0xb0
[<ffffffff815d4799>] system_call_fastpath+0x16/0x1b
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
commit 79feb521a44705262d15cc819a4117a447b11ea7 upstream.
When we reach jbd2_cleanup_journal_tail(), there is no guarantee that
checkpointed buffers are on a stable storage - especially if buffers were
written out by jbd2_log_do_checkpoint(), they are likely to be only in disk's
caches. Thus when we update journal superblock effectively removing old
transaction from journal, this write of superblock can get to stable storage
before those checkpointed buffers which can result in filesystem corruption
after a crash. Thus we must unconditionally issue a cache flush before we
update journal superblock in these cases.
A similar problem can also occur if journal superblock is written only in
disk's caches, other transaction starts reusing space of the transaction
cleaned from the log and power failure happens. Subsequent journal replay would
still try to replay the old transaction but some of it's blocks may be already
overwritten by the new transaction. For this reason we must use WRITE_FUA when
updating log tail and we must first write new log tail to disk and update
in-memory information only after that.
[bwh: Prerequisite for "jbd2: fix ocfs2 corrupt when updating journal
superblock fails".
Backported to 3.2:
- Adjust context
- Drop changes to jbd2_journal_update_sb_log_tail trace event]
commit 24bcc89c7e7c64982e6192b4952a0a92379fc341 upstream.
There are three case of updating journal superblock. In the first case, we want
to mark journal as empty (setting s_sequence to 0), in the second case we want
to update log tail, in the third case we want to update s_errno. Split these
cases into separate functions. It makes the code slightly more straightforward
and later patches will make the distinction even more important.
superblock fails".
Backported to 3.2: drop changes to trace events.]
commit bdf96838aea6a265f2ae6cbcfb12a778c84a0b8e upstream.
The commit cf108bca465d: "ext4: Invert the locking order of page_lock
and transaction start" caused __ext4_journalled_writepage() to drop
the page lock before the page was written back, as part of changing
the locking order to jbd2_journal_start -> page_lock. However, this
introduced a potential race if there was a truncate racing with the
data=journalled writeback mode.
Fix this by grabbing the page lock after starting the journal handle,
and then checking to see if page had gotten truncated out from under
us.
This fixes a number of different warnings or BUG_ON's when running
xfstests generic/086 in data=journalled mode, including:
jbd2_journal_dirty_metadata: vdc-8: bad jh for block 115643: transaction (ee3fe7
c0, 164), jh->b_transaction ( (null), 0), jh->b_next_transaction ( (null), 0), jlist 0
- and -
kernel BUG at /usr/projects/linux/ext4/fs/jbd2/transaction.c:2200!
Call Trace:
[<c02b2ded>] ? __ext4_journalled_invalidatepage+0x117/0x117
[<c02b2de5>] __ext4_journalled_invalidatepage+0x10f/0x117
[<c027d883>] ? lock_buffer+0x36/0x36
[<c02b2dfa>] ext4_journalled_invalidatepage+0xd/0x22
[<c0229139>] do_invalidatepage+0x22/0x26
[<c0229198>] truncate_inode_page+0x5b/0x85
[<c022934b>] truncate_inode_pages_range+0x156/0x38c
[<c0229592>] truncate_inode_pages+0x11/0x15
[<c022962d>] truncate_pagecache+0x55/0x71
[<c02b913b>] ext4_setattr+0x4a9/0x560
[<c01ca542>] ? current_kernel_time+0x10/0x44
[<c026c4d8>] notify_change+0x1c7/0x2be
[<c0256a00>] do_truncate+0x65/0x85
[<c0226f31>] ? file_ra_state_init+0x12/0x29
- and -
WARNING: CPU: 1 PID: 1331 at /usr/projects/linux/ext4/fs/jbd2/transaction.c:1396
irty_metadata+0x14a/0x1ae()
Call Trace:
[<c01b879f>] ? console_unlock+0x3a1/0x3ce
[<c082cbb4>] dump_stack+0x48/0x60
[<c0178b65>] warn_slowpath_common+0x89/0xa0
[<c02ef2cf>] ? jbd2_journal_dirty_metadata+0x14a/0x1ae
[<c0178bef>] warn_slowpath_null+0x14/0x18
[<c02ef2cf>] jbd2_journal_dirty_metadata+0x14a/0x1ae
[<c02d8615>] __ext4_handle_dirty_metadata+0xd4/0x19d
[<c02b2f44>] write_end_fn+0x40/0x53
[<c02b4a16>] ext4_walk_page_buffers+0x4e/0x6a
[<c02b59e7>] ext4_writepage+0x354/0x3b8
[<c02b2f04>] ? mpage_release_unused_pages+0xd4/0xd4
[<c02b1b21>] ? wait_on_buffer+0x2c/0x2c
[<c02b5a4b>] ? ext4_writepage+0x3b8/0x3b8
[<c02b5a5b>] __writepage+0x10/0x2e
[<c0225956>] write_cache_pages+0x22d/0x32c
[<c02b6ee8>] ext4_writepages+0x102/0x607
[<c019adfe>] ? sched_clock_local+0x10/0x10e
[<c01a8a7c>] ? __lock_is_held+0x2e/0x44
[<c01a8ad5>] ? lock_is_held+0x43/0x51
[<c0226dff>] do_writepages+0x1c/0x29
[<c0276bed>] __writeback_single_inode+0xc3/0x545
[<c0277c07>] writeback_sb_inodes+0x21f/0x36d
commit d683cc49daf7c5afca8cd9654aaa1bf63cdf2ad9 upstream.
When encoding the NFSACL SETACL operation, reserve just the estimated
size of the ACL rather than a fixed maximum. This eliminates needless
zero padding on the wire that the server ignores.
Fixes: ee5dc7732bd5 ('NFS: Fix "kernel BUG at fs/nfs/nfs3xdr.c:1338!"')
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
commit e8d975e73e5fa05f983fbf2723120edcf68e0b38 upstream.
Problem: When an operation like WRITE receives a BAD_STATEID, even though
recovery code clears the RECLAIM_NOGRACE recovery flag before recovering
the open state, because of clearing delegation state for the associated
inode, nfs_inode_find_state_and_recover() gets called and it makes the
same state with RECLAIM_NOGRACE flag again. As a results, when we restart
looking over the open states, we end up in the infinite loop instead of
breaking out in the next test of state flags.
Solution: unset the RECLAIM_NOGRACE set because of
calling of nfs_inode_find_state_and_recover() after returning from calling
recover_open() function.
Signed-off-by: Olga Kornievskaia <kolga@netapp.com>
Commit 915f4f86ddc4 ("debugfs: leave freeing a symlink body until inode
eviction", commit 0db59e59299f upstream) changed debugfs to define its
own super_operations and implement the evict_inode operation.
Luis Henriques pointed out that it needs to define the statfs
operation, as in simple_super_operations which it was using before.
Reported-by: Luis Henriques <luis.henriques@canonical.com>
pipe_iov_copy_{from,to}_user() may be tried twice with the same iovec,
the first time atomically and the second time not. The second attempt
needs to continue from the iovec position, pipe buffer offset and
remaining length where the first attempt failed, but currently the
pipe buffer offset and remaining length are reset. This will corrupt
the piped data (possibly also leading to an information leak between
processes) and may also corrupt kernel memory.
This was fixed upstream by commits f0d1bec9d58d ("new helper:
copy_page_from_iter()") and 637b58c2887e ("switch pipe_read() to
copy_page_to_iter()"), but those aren't suitable for stable. This fix
for older kernel versions was made by Seth Jennings for RHEL and I
have extracted it from their update.
CVE-2015-1805
References: https://bugzilla.redhat.com/show_bug.cgi?id=1202855
commit 161f873b89136eb1e69477c847d5a5033239d9ba upstream.
We used to read file_handle twice. Once to get the amount of extra
bytes, and once to fetch the entire structure.
This may be problematic since we do size verifications only after the
first read, so if the number of extra bytes changes in userspace between
the first and second calls, we'll have an incoherent view of
file_handle.
Instead, read the constant size once, and copy that over to the final
structure without having to re-read it again.
commit 2159184ea01e4ae7d15f2017e296d4bc82d5aeb0 upstream.
when we find that a child has died while we'd been trying to ascend,
we should go into the first live sibling itself, rather than its sibling.
Off-by-one in question had been introduced in "deal with deadlock in
d_walk()" and the fix needs to be backported to all branches this one
has been backported to.
[bwh: Backported to 3.2: apply to the 3 copies of this logic we
ended up with]
commit dcbff39da3d815f08750552fdd04f96b51751129 upstream.
match_token() expects a NULL terminator at the end of the token list so
that it would know where to stop. Not having one causes it to overrun
to invalid memory.
In practice, passing a mount option that omfs didn't recognize would
sometimes panic the system.
Signed-off-by: Bob Copeland <me@bobcopeland.com>
commit 2b1d3ae940acd11be44c6eced5873d47c2e00ffa upstream.
load_elf_binary() returns `retval', not `error'.
Fixes: a87938b2e246b81b4fb ("fs/binfmt_elf.c: fix bug in loading of PIE binaries")
Reported-by: James Hogan <james.hogan@imgtec.com>
Cc: Michael Davidson <md@google.com>
commit e531d0bceb402e643a4499de40dd3fa39d8d2e43 upstream.
The journal revoke block recovery code does not check r_count for
sanity, which means that an evil value of r_count could result in
the kernel reading off the end of the revoke table and into whatever
garbage lies beyond. This could crash the kernel, so fix that.
However, in testing this fix, I discovered that the code to write
out the revoke tables also was not correctly checking to see if the
block was full -- the current offset check is fine so long as the
revoke table space size is a multiple of the record size, but this
is not true when either journal_csum_v[23] are set.
[bwh: Backported to 3.2: journal checksumming is not supported, so only
the first fix is needed]
commit 2f974865ffdfe7b9f46a9940836c8b167342563d upstream.
The following commit introduced a bug when checking for zero length extent
5946d08 ext4: check for overlapping extents in ext4_valid_extent_entries()
Zero length extent could pass the check if lblock is zero.
Adding the explicit check for zero length back.
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
commit b1432a2a35565f538586774a03bf277c27fc267d upstream.
There is a race window in dlm_get_lock_resource(), which may return a
lock resource which has been purged. This will cause the process to
hang forever in dlmlock() as the ast msg can't be handled due to its
lock resource not existing.
dlm_get_lock_resource {
spin_lock(&dlm->spinlock);
tmpres = __dlm_lookup_lockres_full(dlm, lockid, namelen, hash);
if (tmpres) {
spin_unlock(&dlm->spinlock);
>>>>>>>> race window, dlm_run_purge_list() may run and purge
the lock resource
spin_lock(&tmpres->spinlock);
spin_unlock(&tmpres->spinlock);
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Cc: Joseph Qi <joseph.qi@huawei.com>
commit d8fd150fe3935e1692bf57c66691e17409ebb9c1 upstream.
The range check for b-tree level parameter in nilfs_btree_root_broken()
is wrong; it accepts the case of "level == NILFS_BTREE_LEVEL_MAX" even
though the level is limited to values in the range of 0 to
(NILFS_BTREE_LEVEL_MAX - 1).
Since the level parameter is read from storage device and used to index
nilfs_btree_path array whose element count is NILFS_BTREE_LEVEL_MAX, it
can cause memory overrun during btree operations if the boundary value
is set to the level parameter on device.
This fixes the broken sanity check and adds a comment to clarify that
the upper bound NILFS_BTREE_LEVEL_MAX is exclusive.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit ebe9cb3bb13e7b9b281969cd279ce70834f7500f upstream.
If we find a non-confirmed openowner we jump to exit the function, but do
not set an error value. Fix this by factoring out a helper to do the
check and properly set the error from nfsd4_validate_stateid.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 280227a75b56ab5d35854f3a77ef74a7ad56a203 upstream.
fallocate() checks that the file is extent-based and returns
EOPNOTSUPP in case is not. Other tasks can convert from and to
indirect and extent so it's safe to check only after grabbing
the inode mutex.
Signed-off-by: Davide Italiano <dccitaliano@gmail.com>
- Adjust context
- Add the 'out' label]
commit a87938b2e246b81b4fb713edb371a9fa3c5c3c86 upstream.
With CONFIG_ARCH_BINFMT_ELF_RANDOMIZE_PIE enabled, and a normal top-down
address allocation strategy, load_elf_binary() will attempt to map a PIE
binary into an address range immediately below mm->mmap_base.
Unfortunately, load_elf_ binary() does not take account of the need to
allocate sufficient space for the entire binary which means that, while
the first PT_LOAD segment is mapped below mm->mmap_base, the subsequent
PT_LOAD segment(s) end up being mapped above mm->mmap_base into the are
that is supposed to be the "gap" between the stack and the binary.
Since the size of the "gap" on x86_64 is only guaranteed to be 128MB this
means that binaries with large data segments > 128MB can end up mapping
part of their data segment over their stack resulting in corruption of the
stack (and the data segment once the binary starts to run).
Any PIE binary with a data segment > 128MB is vulnerable to this although
address randomization means that the actual gap between the stack and the
end of the binary is normally greater than 128MB. The larger the data
segment of the binary the higher the probability of failure.
Fix this by calculating the total size of the binary in the same way as
load_elf_interp().
Signed-off-by: Michael Davidson <md@google.com>
Cc: Jiri Kosina <jkosina@suse.cz>
commit ccccf3d67294714af2d72a6fd6fd7d73b01c9329 upstream.
If we attempt to clone a 0 length region into a file we can end up
inserting a range in the inode's extent_io tree with a start offset
that is greater then the end offset, which triggers immediately the
following warning:
[ 3914.619057] WARNING: CPU: 17 PID: 4199 at fs/btrfs/extent_io.c:435 insert_state+0x4b/0x10b [btrfs]()
[ 3914.620886] BTRFS: end < start 4095 4096
[ 3914.638093] Call Trace:
[ 3914.638636] [<ffffffff81425fd9>] dump_stack+0x4c/0x65
[ 3914.639620] [<ffffffff81045390>] warn_slowpath_common+0xa1/0xbb
[ 3914.640789] [<ffffffffa03ca44f>] ? insert_state+0x4b/0x10b [btrfs]
[ 3914.642041] [<ffffffff810453f0>] warn_slowpath_fmt+0x46/0x48
[ 3914.643236] [<ffffffffa03ca44f>] insert_state+0x4b/0x10b [btrfs]
[ 3914.644441] [<ffffffffa03ca729>] __set_extent_bit+0x107/0x3f4 [btrfs]
[ 3914.645711] [<ffffffffa03cb256>] lock_extent_bits+0x65/0x1bf [btrfs]
[ 3914.646914] [<ffffffff8142b2fb>] ? _raw_spin_unlock+0x28/0x33
[ 3914.648058] [<ffffffffa03cbac4>] ? test_range_bit+0xcc/0xde [btrfs]
[ 3914.650105] [<ffffffffa03cb3c3>] lock_extent+0x13/0x15 [btrfs]
[ 3914.651361] [<ffffffffa03db39e>] lock_extent_range+0x3d/0xcd [btrfs]
[ 3914.652761] [<ffffffffa03de1fe>] btrfs_ioctl_clone+0x278/0x388 [btrfs]
[ 3914.654128] [<ffffffff811226dd>] ? might_fault+0x58/0xb5
[ 3914.655320] [<ffffffffa03e0909>] btrfs_ioctl+0xb51/0x2195 [btrfs]
[ 3914.669271] ---[ end trace 14843d3e2e622fc1 ]---
This later makes the inode eviction handler enter an infinite loop that
keeps dumping the following warning over and over:
[ 3915.117629] WARNING: CPU: 22 PID: 4228 at fs/btrfs/extent_io.c:435 insert_state+0x4b/0x10b [btrfs]()
[ 3915.119913] BTRFS: end < start 4095 4096
[ 3915.137394] Call Trace:
[ 3915.137913] [<ffffffff81425fd9>] dump_stack+0x4c/0x65
[ 3915.139154] [<ffffffff81045390>] warn_slowpath_common+0xa1/0xbb
[ 3915.140316] [<ffffffffa03ca44f>] ? insert_state+0x4b/0x10b [btrfs]
[ 3915.141505] [<ffffffff810453f0>] warn_slowpath_fmt+0x46/0x48
[ 3915.142709] [<ffffffffa03ca44f>] insert_state+0x4b/0x10b [btrfs]
[ 3915.143849] [<ffffffffa03ca729>] __set_extent_bit+0x107/0x3f4 [btrfs]
[ 3915.145120] [<ffffffffa038c1e3>] ? btrfs_kill_super+0x17/0x23 [btrfs]
[ 3915.146352] [<ffffffff811548f6>] ? deactivate_locked_super+0x3b/0x50
[ 3915.147565] [<ffffffffa03cb256>] lock_extent_bits+0x65/0x1bf [btrfs]
[ 3915.148785] [<ffffffff8142b7e2>] ? _raw_write_unlock+0x28/0x33
[ 3915.149931] [<ffffffffa03bc325>] btrfs_evict_inode+0x196/0x482 [btrfs]
[ 3915.151154] [<ffffffff81168904>] evict+0xa0/0x148
[ 3915.152094] [<ffffffff811689e5>] dispose_list+0x39/0x43
[ 3915.153081] [<ffffffff81169564>] evict_inodes+0xdc/0xeb
[ 3915.154062] [<ffffffff81154418>] generic_shutdown_super+0x49/0xef
[ 3915.155193] [<ffffffff811546d1>] kill_anon_super+0x13/0x1e
[ 3915.156274] [<ffffffffa038c1e3>] btrfs_kill_super+0x17/0x23 [btrfs]
[ 3915.167404] ---[ end trace 14843d3e2e622fc2 ]---
So just bail out of the clone ioctl if the length of the region to clone
is zero, without locking any extent range, in order to prevent this issue
(same behaviour as a pwrite with a 0 length for example).
This is trivial to reproduce. For example, the steps for the test I just
made for fstests:
mkfs.btrfs -f SCRATCH_DEV
mount SCRATCH_DEV $SCRATCH_MNT
touch $SCRATCH_MNT/foo
touch $SCRATCH_MNT/bar
$CLONER_PROG -s 0 -d 4096 -l 0 $SCRATCH_MNT/foo $SCRATCH_MNT/bar
umount $SCRATCH_MNT
A test case for fstests follows soon.
Reviewed-by: Omar Sandoval <osandov@osandov.com>
