commit c2338f2dc7c1e9f6202f370c64ffd7f44f3d4b51 upstream.
Dentry that had been through (or into) __dentry_kill() might be seen
by shrink_dentry_list(); that's normal, it'll be taken off the shrink
list and freed if __dentry_kill() has already finished. The problem
is, its ->d_parent might be pointing to already freed dentry, so
lock_parent() needs to be careful.
We need to check that dentry hasn't already gone into __dentry_kill()
*and* grab rcu_read_lock() before dropping ->d_lock - the latter makes
sure that whatever we see in ->d_parent after dropping ->d_lock it
won't be freed until we drop rcu_read_lock().
commit 23adbe12ef7d3d4195e80800ab36b37bee28cd03 upstream.
The kernel has no concept of capabilities with respect to inodes; inodes
exist independently of namespaces. For example, inode_capable(inode,
CAP_LINUX_IMMUTABLE) would be nonsense.
This patch changes inode_capable to check for uid and gid mappings and
renames it to capable_wrt_inode_uidgid, which should make it more
obvious what it does.
Fixes CVE-2014-4014.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fix from Chris Mason:
"I had this in my 3.16 merge window queue, but it is small and obvious
enough for 3.15. I cherry-picked and retested against current rc8"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
Btrfs: send, fix corrupted path strings for long paths
The age table walker doesn't check non-present hugetlb entry in common
path, so hugetlb_entry() callbacks must check it. The reason for this
behavior is that some callers want to handle it in its own way.
[ I think that reason is bogus, btw - it should just do what the regular
code does, which is to call the "pte_hole()" function for such hugetlb
entries - Linus]
However, some callers don't check it now, which causes unpredictable
result, for example when we have a race between migrating hugepage and
reading /proc/pid/numa_maps. This patch fixes it by adding !pte_present
checks on buggy callbacks.
This bug exists for years and got visible by introducing hugepage
migration.
ChangeLog v2:
- fix if condition (check !pte_present() instead of pte_present())
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: <stable@vger.kernel.org> [3.12+]
[ Backported to 3.15. Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> ]
If a path has more than 230 characters, we allocate a new buffer to
use for the path, but we were forgotting to copy the contents of the
previous buffer into the new one, which has random content from the
kmalloc call.
Test:
mkfs.btrfs -f /dev/sdd
mount /dev/sdd /mnt
TEST_PATH="/mnt/fdmanana/.config/google-chrome-mysetup/Default/Pepper_Data/Shockwave_Flash/WritableRoot/#SharedObjects/JSHJ4ZKN/s.wsj.net/[[IMPORT]]/players.edgesuite.net/flash/plugins/osmf/advanced-streaming-plugin/v2.7/osmf1.6/Ak#"
mkdir -p $TEST_PATH
echo "hello world" > $TEST_PATH/amaiAdvancedStreamingPlugin.txt
btrfs subvolume snapshot -r /mnt /mnt/mysnap1
btrfs send /mnt/mysnap1 -f /tmp/1.snap
A test for xfstests follows.
Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com>
Cc: Marc Merlin <marc@merlins.org>
Tested-by: Marc MERLIN <marc@merlins.org>
Signed-off-by: Chris Mason <clm@fb.com>
There is still one residue of sysfs remaining: the sb_magic
SYSFS_MAGIC. However this should be kernfs user specific,
so this patch moves it out. Kerrnfs user should specify their
magic number while mouting.
Signed-off-by: Jianyu Zhan <nasa4836@gmail.com>
Acked-by: Tejun Heo <tj@kernel.org>
lock_parent() very much on purpose does nested locking of dentries, and
is careful to maintain the right order (lock parent first). But because
it didn't annotate the nested locking order, lockdep thought it might be
a deadlock on d_lock, and complained.
Add the proper annotation for the inner locking of the child dentry to
make lockdep happy.
Introduced by commit 046b961b45f9 ("shrink_dentry_list(): take parent's
->d_lock earlier").
Reported-and-tested-by: Josh Boyer <jwboyer@fedoraproject.org>
it's 1 in the only remaining caller.
We have the same problem with ->d_lock order in the inner loop, where
we are dropping references to ancestors. Same solution, basically -
instead of using dentry_kill() we use lock_parent() (introduced in the
previous commit) to get that lock in a safe way, recheck ->d_count
(in case if lock_parent() has ended up dropping and retaking ->d_lock
and somebody managed to grab a reference during that window), trylock
the inode->i_lock and use __dentry_kill() to do the rest.
The cause of livelocks there is that we are taking ->d_lock on
dentry and its parent in the wrong order, forcing us to use
trylock on the parent's one. d_walk() takes them in the right
order, and unfortunately it's not hard to create a situation
when shrink_dentry_list() can't make progress since trylock
keeps failing, and shrink_dcache_parent() or check_submounts_and_drop()
keeps calling d_walk() disrupting the very shrink_dentry_list() it's
waiting for.
Solution is straightforward - if that trylock fails, let's unlock
the dentry itself and take locks in the right order. We need to
stabilize ->d_parent without holding ->d_lock, but that's doable
using RCU. And we'd better do that in the very beginning of the
loop in shrink_dentry_list(), since the checks on refcount, etc.
would need to be redone anyway.
That deals with a half of the problem - killing dentries on the
shrink list itself. Another one (dropping their parents) is
in the next commit.
locking parent is interesting - it would be easy to do rcu_read_lock(),
lock whatever we think is a parent, lock dentry itself and check
if the parent is still the right one. Except that we need to check
that *before* locking the dentry, or we are risking taking ->d_lock
out of order. Fortunately, once the D1 is locked, we can check if
D2->d_parent is equal to D1 without the need to lock D2; D2->d_parent
can start or stop pointing to D1 only under D1->d_lock, so taking
D1->d_lock is enough. In other words, the right solution is
rcu_read_lock/lock what looks like parent right now/check if it's
still our parent/rcu_read_unlock/lock the child.
Result will be massaged to saner shape in the next commits. It is
ugly, no questions - the point of that one is to be a provably
equivalent transformation (and it might be worth splitting a bit
more).
... into trylocks and everything else. The latter (actual killing)
is __dentry_kill().
It can happen only when dentry_kill() is called with unlock_on_failure
equal to 0 - other callers had dentry pinned until the moment they've
got ->d_lock and DCACHE_DENTRY_KILLED is set only after lockref_mark_dead().
IOW, only one of three call sites of dentry_kill() might end up reaching
that code. Just move it there.
Commit 6130f5315ee8 "switch vmsplice_to_user() to copy_page_to_iter()" in
v3.15-rc1 broke vmsplice(2).
This patch fixes two bugs:
- count is not initialized to a proper value, which resulted in no data
being copied
- if rw_copy_check_uvector() returns negative then the iov might be leaked.
Tested OK.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs
Pull AFS fixes and cleanups from David Howells:
"Here are some patches to the AFS filesystem:
1) Fix problems in the clean-up parts of the cache manager service
handler.
2) Split afs_end_call() introduced in (1) and replace some identical
code elsewhere with a call to the first half of the split function.
3) Fix an error introduced in the workqueue PREPARE_WORK() elimination
commits.
4) Clean up argument passing to functions called from the workqueue as
there's now an insulating layer between them and the workqueue.
This is possible from (3)"
* 'afs' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs:
AFS: Pass an afs_call* to call->async_workfn() instead of a work_struct*
AFS: Fix kafs module unloading
AFS: Part of afs_end_call() is identical to code elsewhere, so split it
AFS: Fix cache manager service handlers
Pull two nfsd bugfixes from Bruce Fields:
"Just two bugfixes, one for a merge-window-introduced ACL regression,
the other for a longer-standing v4 state bug"
* 'for-3.15' of git://linux-nfs.org/~bfields/linux:
nfsd4: warn on finding lockowner without stateid's
nfsd4: remove lockowner when removing lock stateid
nfsd4: fix corruption on setting an ACL.
In dlm_init, if create dlm_lockname_cache failed in
dlm_init_master_caches, it will destroy dlm_lockres_cache which created
before twice. And this will cause system die when loading modules.
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Cc: Mark Fasheh <mfasheh@suse.com>
call->async_workfn() can take an afs_call* arg rather than a work_struct* as
the functions assigned there are now called from afs_async_workfn() which has
to call container_of() anyway.
Reviewed-by: Nathaniel Wesley Filardo <nwf@cs.jhu.edu>
Reviewed-by: Tejun Heo <tj@kernel.org>
At present, it is not possible to successfully unload the kafs module if there
are outstanding async outgoing calls (those made with afs_make_call()). This
appears to be due to the changes introduced by:
commit 059499453a9abd1857d442b44da8b4c126dc72a8
Author: Tejun Heo <tj@kernel.org>
Date: Fri Mar 7 10:24:50 2014 -0500
Subject: afs: don't use PREPARE_WORK
which didn't go far enough. The problem is due to:
(1) The aforementioned commit introduced a separate handler function pointer
in the call, call->async_workfn, in addition to the original workqueue
item, call->async_work, for asynchronous operations because workqueues
subsystem cannot handle the workqueue item pointer being changed whilst
the item is queued or being processed.
(2) afs_async_workfn() was introduced in that commit to be the callback for
call->async_work. Its sole purpose is to run whatever call->async_workfn
points to.
(3) call->async_workfn is only used from afs_async_workfn(), which is only
set on async_work by afs_collect_incoming_call() - ie. for incoming
calls.
(4) call->async_workfn is *not* set by afs_make_call() when outgoing calls are
made, and call->async_work is set afs_process_async_call() - and not
afs_async_workfn().
(5) afs_process_async_call() now changes call->async_workfn rather than
call->async_work to point to afs_delete_async_call() to clean up, but this
is only effective for incoming calls because call->async_work does not
point to afs_async_workfn() for outgoing calls.
(6) Because, for incoming calls, call->async_work remains pointing to
afs_process_async_call() this results in an infinite loop.
Instead, make the workqueue uniformly vector through call->async_workfn, via
afs_async_workfn() and simply initialise call->async_workfn to point to
afs_process_async_call() in afs_make_call().
Signed-off-by: Nathaniel Wesley Filardo <nwf@cs.jhu.edu>
Split afs_end_call() into two pieces, one of which is identical to code in
afs_process_async_call(). Replace the latter with a call to the first part of
afs_end_call().
Pull two btrfs fixes from Chris Mason:
"This has two fixes that we've been testing for 3.16, but since both
are safe and fix real bugs, it makes sense to send for 3.15 instead"
Btrfs: send, fix incorrect ref access when using extrefs
Btrfs: fix EIO on reading file after ioctl clone works on it
Pull xfs fixes from Dave Chinner:
"Code inspection of the XFS error number sign translations found a
bunch of issues, including returning incorrectly signed errors for
some data integrity operations.
These leak to userspace and result in applications not getting the
errors correctly reported. Hence they need fixing sooner rather than
later.
A couple of the bugs are in data integrity operations, a couple more
are in the new COLLAPSE_RANGE code. One of these came in through a
recent ext4 merge and so I had to update the base tree to 3.15-rc5
before fixing the issues"
* tag 'xfs-for-linus-3.15-rc6' of git://oss.sgi.com/xfs/xfs:
xfs: list_lru_init returns a negative error
xfs: negate xfs_icsb_init_counters error value
xfs: negate mount workqueue init error value
xfs: fix wrong err sign on xfs_set_acl()
xfs: fix wrong errno from xfs_initxattrs
xfs: correct error sign on COLLAPSE_RANGE errors
xfs: xfs_commit_metadata returns wrong errno
xfs: fix incorrect error sign in xfs_file_aio_read
xfs: xfs_dir_fsync() returns positive errno
The current code assumes a one-to-one lockowner<->lock stateid
correspondance.
Cc: stable@vger.kernel.org
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
The nfsv4 state code has always assumed a one-to-one correspondance
between lock stateid's and lockowners even if it appears not to in some
places.
We may actually change that, but for now when FREE_STATEID releases a
lock stateid it also needs to release the parent lockowner.
Symptoms were a subsequent LOCK crashing in find_lockowner_str when it
calls same_lockowner_ino on a lockowner that unexpectedly has an empty
so_stateids list.
Fix the cache manager RPC service handlers. The afs_send_empty_reply() and
afs_send_simple_reply() functions:
(a) Kill the call and free up the buffers associated with it if they fail.
(b) Return with call intact if it they succeed.
However, none of the callers actually check the result or clean up if
successful - and may use the now non-existent data if it fails.
This was detected by Dan Carpenter using a static checker:
The patch 08e0e7c82eea: "[AF_RXRPC]: Make the in-kernel AFS
filesystem use AF_RXRPC." from Apr 26, 2007, leads to the following
static checker warning:
"fs/afs/cmservice.c:155 SRXAFSCB_CallBack()
warn: 'call' was already freed."
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core fixes from Greg KH:
"Here are two driver core (well, sysfs) fixes for 3.15-rc6 that resolve
some reported issues and a regression from 3.13"
* tag 'driver-core-3.15-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
sysfs: make sure read buffer is zeroed
kernfs, sysfs, cgroup: restrict extra perm check on open to sysfs
When running send, if an inode only has extended reference items
associated to it and no regular references, send.c:get_first_ref()
was incorrectly assuming the reference it found was of type
BTRFS_INODE_REF_KEY due to use of the wrong key variable.
This caused weird behaviour when using the found item has a regular
reference, such as weird path string, and occasionally (when lucky)
a crash:
[ 190.600652] general protection fault: 0000 [#1] SMP DEBUG_PAGEALLOC
[ 190.600994] Modules linked in: btrfs xor raid6_pq binfmt_misc nfsd auth_rpcgss oid_registry nfs_acl nfs lockd fscache sunrpc psmouse serio_raw evbug pcspkr i2c_piix4 e1000 floppy
[ 190.602565] CPU: 2 PID: 14520 Comm: btrfs Not tainted 3.13.0-fdm-btrfs-next-26+ #1
[ 190.602728] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 190.602868] task: ffff8800d447c920 ti: ffff8801fa79e000 task.ti: ffff8801fa79e000
[ 190.603030] RIP: 0010:[<ffffffff813266b4>] [<ffffffff813266b4>] memcpy+0x54/0x110
[ 190.603262] RSP: 0018:ffff8801fa79f880 EFLAGS: 00010202
[ 190.603395] RAX: ffff8800d4326e3f RBX: 000000000000036a RCX: ffff880000000000
[ 190.603553] RDX: 000000000000032a RSI: ffe708844042936a RDI: ffff8800d43271a9
[ 190.603710] RBP: ffff8801fa79f8c8 R08: 00000000003a4ef0 R09: 0000000000000000
[ 190.603867] R10: 793a4ef09f000000 R11: 9f0000000053726f R12: ffff8800d43271a9
[ 190.604020] R13: 0000160000000000 R14: ffff8802110134f0 R15: 000000000000036a
[ 190.604020] FS: 00007fb423d09b80(0000) GS:ffff880216200000(0000) knlGS:0000000000000000
[ 190.604020] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 190.604020] CR2: 00007fb4229d4b78 CR3: 00000001f5d76000 CR4: 00000000000006e0
[ 190.604020] Stack:
[ 190.604020] ffffffffa01f4d49 ffff8801fa79f8f0 00000000000009f9 ffff8801fa79f8c8
[ 190.604020] 00000000000009f9 ffff880211013260 000000000000f971 ffff88021147dba8
[ 190.604020] 00000000000009f9 ffff8801fa79f918 ffffffffa02367f5 ffff8801fa79f928
[ 190.604020] Call Trace:
[ 190.604020] [<ffffffffa01f4d49>] ? read_extent_buffer+0xb9/0x120 [btrfs]
[ 190.604020] [<ffffffffa02367f5>] fs_path_add_from_extent_buffer+0x45/0x60 [btrfs]
[ 190.604020] [<ffffffffa0238806>] get_first_ref+0x1f6/0x210 [btrfs]
[ 190.604020] [<ffffffffa0238994>] __get_cur_name_and_parent+0x174/0x3a0 [btrfs]
[ 190.604020] [<ffffffff8118df3d>] ? kmem_cache_alloc_trace+0x11d/0x1e0
[ 190.604020] [<ffffffffa0236674>] ? fs_path_alloc+0x24/0x60 [btrfs]
[ 190.604020] [<ffffffffa0238c91>] get_cur_path+0xd1/0x240 [btrfs]
Steps to reproduce (either crash or some weirdness like an odd path string):
mkfs.btrfs -f -O extref /dev/sdd
mount /dev/sdd /mnt
mkdir /mnt/testdir
touch /mnt/testdir/foobar
for i in `seq 1 2550`; do
ln /mnt/testdir/foobar /mnt/testdir/foobar_link_`printf "%04d" $i`
done
ln /mnt/testdir/foobar /mnt/testdir/final_foobar_name
rm -f /mnt/testdir/foobar
rm -f /mnt/testdir/foobar_link_`printf "%04d" $i`
done
btrfs send /mnt/mysnap -f /tmp/mysnap.send
Reviewed-by: Liu Bo <bo.li.liu@oracle.com>
For inline data extent, we need to make its length aligned, otherwise,
we can get a phantom extent map which confuses readpages() to return -EIO.
This can be detected by xfstests/btrfs/035.
Reported-by: David Disseldorp <ddiss@suse.de>
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag
Pull Metag architecture and related fixes from James Hogan:
"Mostly fixes for metag and parisc relating to upgrowing stacks.
- Fix missing compiler barriers in metag memory barriers.
- Fix BUG_ON on metag when RLIMIT_STACK hard limit is increased
beyond safe value.
- Make maximum stack size configurable. This reduces the default
user stack size back to 80MB (especially on parisc after their
removal of _STK_LIM_MAX override). This only affects metag and
parisc.
- Remove metag _STK_LIM_MAX override to match other arches and follow
parisc, now that it is safe to do so (due to the BUG_ON fix
mentioned above).
- Finally now that both metag and parisc _STK_LIM_MAX overrides have
been removed, it makes sense to remove _STK_LIM_MAX altogether"
* tag 'metag-for-v3.15-2' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag:
asm-generic: remove _STK_LIM_MAX
metag: Remove _STK_LIM_MAX override
parisc,metag: Do not hardcode maximum userspace stack size
metag: Reduce maximum stack size to 256MB
metag: fix memory barriers
13c589d5b0ac ("sysfs: use seq_file when reading regular files")
switched sysfs from custom read implementation to seq_file to enable
later transition to kernfs. After the change, the buffer passed to
->show() is acquired through seq_get_buf(); unfortunately, this
introduces a subtle behavior change. Before the commit, the buffer
passed to ->show() was always zero as it was allocated using
get_zeroed_page(). Because seq_file doesn't clear buffers on
allocation and neither does seq_get_buf(), after the commit, depending
on the behavior of ->show(), we may end up exposing uninitialized data
to userland thus possibly altering userland visible behavior and
leaking information.
Fix it by explicitly clearing the buffer.
Reported-by: Ron <ron@debian.org>
Fixes: 13c589d5b0ac ("sysfs: use seq_file when reading regular files")
Cc: stable <stable@vger.kernel.org> # 3.13+
As of 06f9cc12caa862f5bc86ebdb4f77568a4bef0167 "nfsd4: don't create
unnecessary mask acl", any non-trivial ACL will be left with an
unitialized entry, and a trivial ACL may write one entry beyond what's
allocated.
And we don't invert it properly when initialising the dquot lru
list.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Jie Liu <jeff.liu@oracle.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
Invert it.
And it should be negative.
Specify the maximum stack size for arches where the stack grows upward
(parisc and metag) in asm/processor.h rather than hard coding in
fs/exec.c so that metag can specify a smaller value of 256MB rather than
1GB.
This fixes a BUG on metag if the RLIMIT_STACK hard limit is increased
beyond a safe value by root. E.g. when starting a process after running
"ulimit -H -s unlimited" it will then attempt to use a stack size of the
maximum 1GB which is far too big for metag's limited user virtual
address space (stack_top is usually 0x3ffff000):
BUG: failure at fs/exec.c:589/shift_arg_pages()!
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: linux-parisc@vger.kernel.org
Cc: linux-metag@vger.kernel.org
Cc: John David Anglin <dave.anglin@bell.net>
Cc: stable@vger.kernel.org # only needed for >= v3.9 (arch/metag)
The kernfs open method - kernfs_fop_open() - inherited extra
permission checks from sysfs. While the vfs layer allows ignoring the
read/write permissions checks if the issuer has CAP_DAC_OVERRIDE,
sysfs explicitly denied open regardless of the cap if the file doesn't
have any of the UGO perms of the requested access or doesn't implement
the requested operation. It can be debated whether this was a good
idea or not but the behavior is too subtle and dangerous to change at
this point.
After cgroup got converted to kernfs, this extra perm check also got
applied to cgroup breaking libcgroup which opens write-only files with
O_RDWR as root. This patch gates the extra open permission check with
a new flag KERNFS_ROOT_EXTRA_OPEN_PERM_CHECK and enables it for sysfs.
For sysfs, nothing changes. For cgroup, root now can perform any
operation regardless of the permissions as it was before kernfs
conversion. Note that kernfs still fails unimplemented operations
with -EINVAL.
While at it, add comments explaining KERNFS_ROOT flags.
Reported-by: Andrey Wagin <avagin@gmail.com>
Tested-by: Andrey Wagin <avagin@gmail.com>
Cc: Li Zefan <lizefan@huawei.com>
References: http://lkml.kernel.org/g/CANaxB-xUm3rJ-Cbp72q-rQJO5mZe1qK6qXsQM=vh0U8upJ44+A@mail.gmail.com
Fixes: 2bd59d48ebfb ("cgroup: convert to kernfs")
Pull file locking fix from Jeff Layton:
"Fix for regression in handling of F_GETLK commands"
* tag 'locks-v3.15-4' of git://git.samba.org/jlayton/linux:
locks: only validate the lock vs. f_mode in F_SETLK codepaths
Pull cifs fix from Steve French:
"Small cifs fix for metadata caching"
* 'for-linus' of git://git.samba.org/sfrench/cifs-2.6:
cifs: fix actimeo=0 corner case when cifs_i->time == jiffies
Pull nfsd fixes from Bruce Fields.
NFSD: Call ->set_acl with a NULL ACL structure if no entries
NFSd: call rpc_destroy_wait_queue() from free_client()
NFSd: Move default initialisers from create_client() to alloc_client()
v2: replace missing break in switch statement (as pointed out by Dave
Jones)
commit bce7560d4946 (locks: consolidate checks for compatible
filp->f_mode values in setlk handlers) introduced a regression in the
F_GETLK handler.
flock64_to_posix_lock is a shared codepath between F_GETLK and F_SETLK,
but the f_mode checks should only be applicable to the F_SETLK codepaths
according to POSIX.
Instead of just reverting the patch, add a new function to do this
checking and have the F_SETLK handlers call it.
Cc: Dave Jones <davej@redhat.com>
Reported-and-Tested-by: Reuben Farrelly <reuben@reub.net>
Signed-off-by: Jeff Layton <jlayton@poochiereds.net>
"The main fix is adding support for default ACLs on O_TMPFILE opened
inodes to bring XFS into line with other filesystems. Metadata CRCs
are now also considered well enough tested to be fully supported, so
we're removing the shouty warnings issued at mount time for
filesystems with that format. And there's transaction block
reservation overrun fix.
Summary:
- fix a remote attribute size calculation bug that leads to a
transaction overrun
- add default ACLs to O_TMPFILE files
- Remove the EXPERIMENTAL tag from filesystems with metadata CRC
support"
* tag 'xfs-for-linus-3.15-rc5' of git://oss.sgi.com/xfs/xfs:
xfs: remote attribute overwrite causes transaction overrun
xfs: initialize default acls for ->tmpfile()
xfs: fully support v5 format filesystems
After setting ACL for directory, I got two problems that caused
by the cached zero-length default posix acl.
This patch make sure nfsd4_set_nfs4_acl calls ->set_acl
with a NULL ACL structure if there are no entries.
Thanks for Christoph Hellwig's advice.
First problem:
............ hang ...........
Second problem:
[ 1610.167668] ------------[ cut here ]------------
[ 1610.168320] kernel BUG at /root/nfs/linux/fs/nfsd/nfs4acl.c:239!
[ 1610.168320] invalid opcode: 0000 [#1] SMP DEBUG_PAGEALLOC
[ 1610.168320] Modules linked in: nfsv4(OE) nfs(OE) nfsd(OE)
rpcsec_gss_krb5 fscache ip6t_rpfilter ip6t_REJECT cfg80211 xt_conntrack
rfkill ebtable_nat ebtable_broute bridge stp llc ebtable_filter ebtables
ip6table_nat nf_conntrack_ipv6 nf_defrag_ipv6 nf_nat_ipv6
ip6table_mangle ip6table_security ip6table_raw ip6table_filter
ip6_tables iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4
nf_nat nf_conntrack iptable_mangle iptable_security iptable_raw
auth_rpcgss nfs_acl snd_intel8x0 ppdev lockd snd_ac97_codec ac97_bus
snd_pcm snd_timer e1000 pcspkr parport_pc snd parport serio_raw joydev
i2c_piix4 sunrpc(OE) microcode soundcore i2c_core ata_generic pata_acpi
[last unloaded: nfsd]
[ 1610.168320] CPU: 0 PID: 27397 Comm: nfsd Tainted: G OE
3.15.0-rc1+ #15
[ 1610.168320] Hardware name: innotek GmbH VirtualBox/VirtualBox, BIOS
VirtualBox 12/01/2006
[ 1610.168320] task: ffff88005ab653d0 ti: ffff88005a944000 task.ti:
ffff88005a944000
[ 1610.168320] RIP: 0010:[<ffffffffa034d5ed>] [<ffffffffa034d5ed>]
_posix_to_nfsv4_one+0x3cd/0x3d0 [nfsd]
[ 1610.168320] RSP: 0018:ffff88005a945b00 EFLAGS: 00010293
[ 1610.168320] RAX: 0000000000000001 RBX: ffff88006700bac0 RCX:
0000000000000000
[ 1610.168320] RDX: 0000000000000000 RSI: ffff880067c83f00 RDI:
ffff880068233300
[ 1610.168320] RBP: ffff88005a945b48 R08: ffffffff81c64830 R09:
0000000000000000
[ 1610.168320] R10: ffff88004ea85be0 R11: 000000000000f475 R12:
ffff880068233300
[ 1610.168320] R13: 0000000000000003 R14: 0000000000000002 R15:
ffff880068233300
[ 1610.168320] FS: 0000000000000000(0000) GS:ffff880077800000(0000)
[ 1610.168320] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 1610.168320] CR2: 00007f5bcbd3b0b9 CR3: 0000000001c0f000 CR4:
00000000000006f0
[ 1610.168320] DR0: 0000000000000000 DR1: 0000000000000000 DR2:
0000000000000000
[ 1610.168320] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7:
0000000000000400
[ 1610.168320] Stack:
[ 1610.168320] ffffffff00000000 0000000b67c83500 000000076700bac0
0000000000000000
[ 1610.168320] ffff88006700bac0 ffff880068233300 ffff88005a945c08
0000000000000002
[ 1610.168320] 0000000000000000 ffff88005a945b88 ffffffffa034e2d5
000000065a945b68
[ 1610.168320] Call Trace:
[ 1610.168320] [<ffffffffa034e2d5>] nfsd4_get_nfs4_acl+0x95/0x150 [nfsd]
[ 1610.168320] [<ffffffffa03400d6>] nfsd4_encode_fattr+0x646/0x1e70 [nfsd]
[ 1610.168320] [<ffffffff816a6e6e>] ? kmemleak_alloc+0x4e/0xb0
[ 1610.168320] [<ffffffffa0327962>] ?
nfsd_setuser_and_check_port+0x52/0x80 [nfsd]
[ 1610.168320] [<ffffffff812cd4bb>] ? selinux_cred_prepare+0x1b/0x30
[ 1610.168320] [<ffffffffa0341caa>] nfsd4_encode_getattr+0x5a/0x60 [nfsd]
[ 1610.168320] [<ffffffffa0341e07>] nfsd4_encode_operation+0x67/0x110
[nfsd]
[ 1610.168320] [<ffffffffa033844d>] nfsd4_proc_compound+0x21d/0x810 [nfsd]
[ 1610.168320] [<ffffffffa0324d9b>] nfsd_dispatch+0xbb/0x200 [nfsd]
[ 1610.168320] [<ffffffffa00850cd>] svc_process_common+0x46d/0x6d0 [sunrpc]
[ 1610.168320] [<ffffffffa0085433>] svc_process+0x103/0x170 [sunrpc]
[ 1610.168320] [<ffffffffa032472f>] nfsd+0xbf/0x130 [nfsd]
[ 1610.168320] [<ffffffffa0324670>] ? nfsd_destroy+0x80/0x80 [nfsd]
[ 1610.168320] [<ffffffff810a5202>] kthread+0xd2/0xf0
[ 1610.168320] [<ffffffff810a5130>] ? insert_kthread_work+0x40/0x40
[ 1610.168320] [<ffffffff816c1ebc>] ret_from_fork+0x7c/0xb0
[ 1610.168320] Code: 78 02 e9 e7 fc ff ff 31 c0 31 d2 31 c9 66 89 45 ce
41 8b 04 24 66 89 55 d0 66 89 4d d2 48 8d 04 80 49 8d 5c 84 04 e9 37 fd
ff ff <0f> 0b 90 0f 1f 44 00 00 55 8b 56 08 c7 07 00 00 00 00 8b 46 0c
[ 1610.168320] RIP [<ffffffffa034d5ed>] _posix_to_nfsv4_one+0x3cd/0x3d0
[nfsd]
[ 1610.168320] RSP <ffff88005a945b00>
[ 1610.257313] ---[ end trace 838254e3e352285b ]---
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
Merge misc fixes from Andrew Morton:
"13 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
agp: info leak in agpioc_info_wrap()
fs/affs/super.c: bugfix / double free
fanotify: fix -EOVERFLOW with large files on 64-bit
slub: use sysfs'es release mechanism for kmem_cache
revert "mm: vmscan: do not swap anon pages just because free+file is low"
autofs: fix lockref lookup
mm: filemap: update find_get_pages_tag() to deal with shadow entries
mm/compaction: make isolate_freepages start at pageblock boundary
MAINTAINERS: zswap/zbud: change maintainer email address
mm/page-writeback.c: fix divide by zero in pos_ratio_polynom
hugetlb: ensure hugepage access is denied if hugepages are not supported
slub: fix memcg_propagate_slab_attrs
drivers/rtc/rtc-pcf8523.c: fix month definition
Commit 842a859db26b ("affs: use ->kill_sb() to simplify ->put_super()
and failure exits of ->mount()") adds .kill_sb which frees sbi but
doesn't remove sbi free in case of parse_options error causing double
free+random crash.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: <stable@vger.kernel.org> [3.14.x]
