path: root/fs
2015-10-31Merge branch 'overlayfs-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs Pull overlayfs bug fixes from Miklos Szeredi: "This contains fixes for bugs that appeared in earlier kernels (all are marked for -stable)" * 'overlayfs-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs: ovl: free lower_mnt array in ovl_put_super ovl: free stack of paths in ovl_fill_super ovl: fix open in stacked overlay ovl: fix dentry reference leak ovl: use O_LARGEFILE in ovl_copy_up()
2015-10-24Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "A final set of fixes for 4.3. It is (again) bigger than I would have liked, but it's all been through the testing mill and has been carefully reviewed by multiple parties. Each fix is either a regression fix for this cycle, or is marked stable. You can scold me at KS. The pull request contains: - Three simple fixes for NVMe, fixing regressions since 4.3. From Arnd, Christoph, and Keith. - A single xen-blkfront fix from Cathy, fixing a NULL dereference if an error is returned through the staste change callback. - Fixup for some bad/sloppy code in nbd that got introduced earlier in this cycle. From Markus Pargmann. - A blk-mq tagset use-after-free fix from Junichi. - A backing device lifetime fix from Tejun, fixing a crash. - And finally, a set of regression/stable fixes for cgroup writeback from Tejun" * 'for-linus' of git://git.kernel.dk/linux-block: writeback: remove broken rbtree_postorder_for_each_entry_safe() usage in cgwb_bdi_destroy() NVMe: Fix memory leak on retried commands block: don't release bdi while request_queue has live references nvme: use an integer value to Linux errno values blk-mq: fix use-after-free in blk_mq_free_tag_set() nvme: fix 32-bit build warning writeback: fix incorrect calculation of available memory for memcg domains writeback: memcg dirty_throttle_control should be initialized with wb->memcg_completions writeback: bdi_writeback iteration must not skip dying ones writeback: fix bdi_writeback iteration in wakeup_dirtytime_writeback() writeback: laptop_mode_timer_fn() needs rcu_read_lock() around bdi_writeback iteration nbd: Add locking for tasks xen-blkfront: check for null drvdata in blkback_changed (XenbusStateClosing)
2015-10-24Merge branch 'for-linus-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "I have two more small fixes this week: Qu's fix avoids unneeded COW during fallocate, and Christian found a memory leak in the error handling of an earlier fix" * 'for-linus-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: btrfs: fix possible leak in btrfs_ioctl_balance() btrfs: Avoid truncate tailing page if fallocate range doesn't exceed inode size
2015-10-23ocfs2/dlm: unlock lockres spinlock before dlm_lockres_putJoseph Qi
dlm_lockres_put will call dlm_lockres_release if it is the last reference, and then it may call dlm_print_one_lock_resource and take lockres spinlock. So unlock lockres spinlock before dlm_lockres_put to avoid deadlock. Signed-off-by: Joseph Qi <joseph.qi@huawei.com> Cc: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-21btrfs: fix possible leak in btrfs_ioctl_balance()Christian Engelmayer
Commit 8eb934591f8b ("btrfs: check unsupported filters in balance arguments") adds a jump to exit label out_bargs in case the argument check fails. At this point in addition to the bargs memory, the memory for struct btrfs_balance_control has already been allocated. Ownership of bctl is passed to btrfs_balance() in the good case, thus the memory is not freed due to the introduced jump. Make sure that the memory gets freed in any case as necessary. Detected by Coverity CID 1328378. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Reviewed-by: David Sterba <dsterba@suse.com> Signed-off-by: Chris Mason <clm@fb.com>
2015-10-20btrfs: Avoid truncate tailing page if fallocate range doesn't exceed inode sizeQu Wenruo
Current code will always truncate tailing page if its alloc_start is smaller than inode size. For example, the file extent layout is like: 0 4K 8K 16K 32K |<-----Extent A---------------->| |<--Inode size: 18K---------->| But if calling fallocate even for range [0,4K), it will cause btrfs to re-truncate the range [16,32K), causing COW and a new extent. 0 4K 8K 16K 32K |///////| <- Fallocate call range |<-----Extent A-------->|<--B-->| The cause is quite easy, just a careless btrfs_truncate_inode() in a else branch without extra judgment. Fix it by add judgment on whether the fallocate range is beyond isize. Signed-off-by: Qu Wenruo <quwenruo@cn.fujitsu.com> Signed-off-by: Chris Mason <clm@fb.com>
2015-10-16Merge branch 'for-linus-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "I have two more bug fixes for btrfs. My commit fixes a bug we hit last week at FB, a combination of lots of hard links and an admin command to resolve inode numbers. Dave is adding checks to make sure balance on current kernels ignores filters it doesn't understand. The penalty for being wrong is just doing more work (not crashing etc), but it's a good fix" * 'for-linus-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: btrfs: fix use after free iterating extrefs btrfs: check unsupported filters in balance arguments
2015-10-16Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "6 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: sh: add copy_user_page() alias for __copy_user() lib/Kconfig: ZLIB_DEFLATE must select BITREVERSE mm, dax: fix DAX deadlocks memcg: convert threshold to bytes builddeb: remove debian/files before build mm, fs: obey gfp_mapping for add_to_page_cache()
2015-10-16mm, dax: fix DAX deadlocksRoss Zwisler
The following two locking commits in the DAX code: commit 843172978bb9 ("dax: fix race between simultaneous faults") commit 46c043ede471 ("mm: take i_mmap_lock in unmap_mapping_range() for DAX") introduced a number of deadlocks and other issues which need to be fixed for the v4.3 kernel. The list of issues in DAX after these commits (some newly introduced by the commits, some preexisting) can be found here: https://lkml.org/lkml/2015/9/25/602 (Subject: "Re: [PATCH] dax: fix deadlock in __dax_fault"). This undoes most of the changes introduced by those two commits, essentially returning us to the DAX locking scheme that was used in v4.2. Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Dan Williams <dan.j.williams@intel.com> Tested-by: Dave Chinner <dchinner@redhat.com> Cc: Jan Kara <jack@suse.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-16mm, fs: obey gfp_mapping for add_to_page_cache()Michal Hocko
Commit 6afdb859b710 ("mm: do not ignore mapping_gfp_mask in page cache allocation paths") has caught some users of hardcoded GFP_KERNEL used in the page cache allocation paths. This, however, wasn't complete and there were others which went unnoticed. Dave Chinner has reported the following deadlock for xfs on loop device: : With the recent merge of the loop device changes, I'm now seeing : XFS deadlock on my single CPU, 1GB RAM VM running xfs/073. : : The deadlocked is as follows: : : kloopd1: loop_queue_read_work : xfs_file_iter_read : lock XFS inode XFS_IOLOCK_SHARED (on image file) : page cache read (GFP_KERNEL) : radix tree alloc : memory reclaim : reclaim XFS inodes : log force to unpin inodes : <wait for log IO completion> : : xfs-cil/loop1: <does log force IO work> : xlog_cil_push : xlog_write : <loop issuing log writes> : xlog_state_get_iclog_space() : <blocks due to all log buffers under write io> : <waits for IO completion> : : kloopd1: loop_queue_write_work : xfs_file_write_iter : lock XFS inode XFS_IOLOCK_EXCL (on image file) : <wait for inode to be unlocked> : : i.e. the kloopd, with it's split read and write work queues, has : introduced a dependency through memory reclaim. i.e. that writes : need to be able to progress for reads make progress. : : The problem, fundamentally, is that mpage_readpages() does a : GFP_KERNEL allocation, rather than paying attention to the inode's : mapping gfp mask, which is set to GFP_NOFS. : : The didn't used to happen, because the loop device used to issue : reads through the splice path and that does: : : error = add_to_page_cache_lru(page, mapping, index, : GFP_KERNEL & mapping_gfp_mask(mapping)); This has changed by commit aa4d86163e4 ("block: loop: switch to VFS ITER_BVEC"). This patch changes mpage_readpage{s} to follow gfp mask set for the mapping. There are, however, other places which are doing basically the same. lustre:ll_dir_filler is doing GFP_KERNEL from the function which apparently uses GFP_NOFS for other allocations so let's make this consistent. cifs:readpages_get_pages is called from cifs_readpages and __cifs_readpages_from_fscache called from the same path obeys mapping gfp. ramfs_nommu_expand_for_mapping is hardcoding GFP_KERNEL as well regardless it uses mapping_gfp_mask for the page allocation. ext4_mpage_readpages is the called from the page cache allocation path same as read_pages and read_cache_pages As I've noticed in my previous post I cannot say I would be happy about sprinkling mapping_gfp_mask all over the place and it sounds like we should drop gfp_mask argument altogether and use it internally in __add_to_page_cache_locked that would require all the filesystems to use mapping gfp consistently which I am not sure is the case here. From a quick glance it seems that some file system use it all the time while others are selective. Signed-off-by: Michal Hocko <mhocko@suse.com> Reported-by: Dave Chinner <david@fromorbit.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Ming Lei <ming.lei@canonical.com> Cc: Andreas Dilger <andreas.dilger@intel.com> Cc: Oleg Drokin <oleg.drokin@intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-15Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull ext4 Kconfig description fixup from Jan Kara: "A small fixup in description of EXT4_USE_FOR_EXT2 config option" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: ext4: Update EXT4_USE_FOR_EXT2 description
2015-10-13btrfs: fix use after free iterating extrefsChris Mason
The code for btrfs inode-resolve has never worked properly for files with enough hard links to trigger extrefs. It was trying to get the leaf out of a path after freeing the path: btrfs_release_path(path); leaf = path->nodes[0]; item_size = btrfs_item_size_nr(leaf, slot); The fix here is to use the extent buffer we cloned just a little higher up to avoid deadlocks caused by using the leaf in the path. Signed-off-by: Chris Mason <clm@fb.com> cc: stable@vger.kernel.org # v3.7+ cc: Mark Fasheh <mfasheh@suse.de> Reviewed-by: Filipe Manana <fdmanana@suse.com> Reviewed-by: Mark Fasheh <mfasheh@suse.de>
2015-10-13btrfs: check unsupported filters in balance argumentsDavid Sterba
We don't verify that all the balance filter arguments supplemented by the flags are actually known to the kernel. Thus we let it silently pass and do nothing. At the moment this means only the 'limit' filter, but we're going to add a few more soon so it's better to have that fixed. Also in older stable kernels so that it works with newer userspace tools. Cc: stable@vger.kernel.org # 3.16+ Signed-off-by: David Sterba <dsterba@suse.com> Signed-off-by: Chris Mason <clm@fb.com>
2015-10-13Merge tag 'nfsd-4.3-2' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd fixes from Bruce Fields: "Two nfsd fixes, one for an RDMA crash, one for a pnfs/block protocol bug" * tag 'nfsd-4.3-2' of git://linux-nfs.org/~bfields/linux: svcrdma: Fix NFS server crash triggered by 1MB NFS WRITE nfsd/blocklayout: accept any minlength
2015-10-12writeback: bdi_writeback iteration must not skip dying onesTejun Heo
bdi_for_each_wb() is used in several places to wake up or issue writeback work items to all wb's (bdi_writeback's) on a given bdi. The iteration is performed by walking bdi->cgwb_tree; however, the tree only indexes wb's which are currently active. For example, when a memcg gets associated with a different blkcg, the old wb is removed from the tree so that the new one can be indexed. The old wb starts dying from then on but will linger till all its inodes are drained. As these dying wb's may still host dirty inodes, writeback operations which affect all wb's must include them. bdi_for_each_wb() skipping dying wb's led to sync(2) missing and failing to sync the inodes belonging to those wb's. This patch adds a RCU protected @bdi->wb_list which lists all wb's beloinging to that bdi. wb's are added on creation and removed on release rather than on the start of destruction. bdi_for_each_wb() usages are replaced with list_for_each[_continue]_rcu() iterations over @bdi->wb_list and bdi_for_each_wb() and its helpers are removed. v2: Updated as per Jan. last_wb ref leak in bdi_split_work_to_wbs() fixed and unnecessary list head severing in cgwb_bdi_destroy() removed. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-tested-by: Artem Bityutskiy <dedekind1@gmail.com> Fixes: ebe41ab0c79d ("writeback: implement bdi_for_each_wb()") Link: http://lkml.kernel.org/g/1443012552.19983.209.camel@gmail.com Cc: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-10-12writeback: fix bdi_writeback iteration in wakeup_dirtytime_writeback()Tejun Heo
wakeup_dirtytime_writeback() walks and wakes up all wb's of all bdi's; unfortunately, it was always waking up bdi->wb instead of the wb being walked. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Fixes: 001fe6f617b1 ("writeback: make wakeup_dirtytime_writeback() handle multiple bdi_writeback's") Reviewed-by: Jan Kara <jack@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-10-12ovl: free lower_mnt array in ovl_put_superKonstantin Khlebnikov
This fixes memory leak after umount. Kmemleak report: unreferenced object 0xffff8800ba791010 (size 8): comm "mount", pid 2394, jiffies 4294996294 (age 53.920s) hex dump (first 8 bytes): 20 1c 13 02 00 88 ff ff ....... backtrace: [<ffffffff811f8cd4>] create_object+0x124/0x2c0 [<ffffffff817a059b>] kmemleak_alloc+0x7b/0xc0 [<ffffffff811dffe6>] __kmalloc+0x106/0x340 [<ffffffffa0152bfc>] ovl_fill_super+0x55c/0x9b0 [overlay] [<ffffffff81200ac4>] mount_nodev+0x54/0xa0 [<ffffffffa0152118>] ovl_mount+0x18/0x20 [overlay] [<ffffffff81201ab3>] mount_fs+0x43/0x170 [<ffffffff81220d34>] vfs_kern_mount+0x74/0x170 [<ffffffff812233ad>] do_mount+0x22d/0xdf0 [<ffffffff812242cb>] SyS_mount+0x7b/0xc0 [<ffffffff817b6bee>] entry_SYSCALL_64_fastpath+0x12/0x76 [<ffffffffffffffff>] 0xffffffffffffffff Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Fixes: dd662667e6d3 ("ovl: add mutli-layer infrastructure") Cc: <stable@vger.kernel.org> # v4.0+
2015-10-12ovl: free stack of paths in ovl_fill_superKonstantin Khlebnikov
This fixes small memory leak after mount. Kmemleak report: unreferenced object 0xffff88003683fe00 (size 16): comm "mount", pid 2029, jiffies 4294909563 (age 33.380s) hex dump (first 16 bytes): 20 27 1f bb 00 88 ff ff 40 4b 0f 36 02 88 ff ff '......@K.6.... backtrace: [<ffffffff811f8cd4>] create_object+0x124/0x2c0 [<ffffffff817a059b>] kmemleak_alloc+0x7b/0xc0 [<ffffffff811dffe6>] __kmalloc+0x106/0x340 [<ffffffffa01b7a29>] ovl_fill_super+0x389/0x9a0 [overlay] [<ffffffff81200ac4>] mount_nodev+0x54/0xa0 [<ffffffffa01b7118>] ovl_mount+0x18/0x20 [overlay] [<ffffffff81201ab3>] mount_fs+0x43/0x170 [<ffffffff81220d34>] vfs_kern_mount+0x74/0x170 [<ffffffff812233ad>] do_mount+0x22d/0xdf0 [<ffffffff812242cb>] SyS_mount+0x7b/0xc0 [<ffffffff817b6bee>] entry_SYSCALL_64_fastpath+0x12/0x76 [<ffffffffffffffff>] 0xffffffffffffffff Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Fixes: a78d9f0d5d5c ("ovl: support multiple lower layers") Cc: <stable@vger.kernel.org> # v4.0+
2015-10-12ovl: fix open in stacked overlayMiklos Szeredi
If two overlayfs filesystems are stacked on top of each other, then we need recursion in ovl_d_select_inode(). I guess d_backing_inode() is supposed to do that. But currently it doesn't and that functionality is open coded in vfs_open(). This is now copied into ovl_d_select_inode() to fix this regression. Reported-by: Alban Crequy <alban.crequy@gmail.com> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Fixes: 4bacc9c9234c ("overlayfs: Make f_path always point to the overlay...") Cc: David Howells <dhowells@redhat.com> Cc: <stable@vger.kernel.org> # v4.2+
2015-10-12ovl: fix dentry reference leakDavid Howells
In ovl_copy_up_locked(), newdentry is leaked if the function exits through out_cleanup as this just to out after calling ovl_cleanup() - which doesn't actually release the ref on newdentry. The out_cleanup segment should instead exit through out2 as certainly newdentry leaks - and possibly upper does also, though this isn't caught given the catch of newdentry. Without this fix, something like the following is seen: BUG: Dentry ffff880023e9eb20{i=f861,n=#ffff880023e82d90} still in use (1) [unmount of tmpfs tmpfs] BUG: Dentry ffff880023ece640{i=0,n=bigfile} still in use (1) [unmount of tmpfs tmpfs] when unmounting the upper layer after an error occurred in copyup. An error can be induced by creating a big file in a lower layer with something like: dd if=/dev/zero of=/lower/a/bigfile bs=65536 count=1 seek=$((0xf000)) to create a large file (4.1G). Overlay an upper layer that is too small (on tmpfs might do) and then induce a copy up by opening it writably. Reported-by: Ulrich Obergfell <uobergfe@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: <stable@vger.kernel.org> # v3.18+
2015-10-12ovl: use O_LARGEFILE in ovl_copy_up()David Howells
Open the lower file with O_LARGEFILE in ovl_copy_up(). Pass O_LARGEFILE unconditionally in ovl_copy_up_data() as it's purely for catching 32-bit userspace dealing with a file large enough that it'll be mishandled if the application isn't aware that there might be an integer overflow. Inside the kernel, there shouldn't be any problems. Reported-by: Ulrich Obergfell <uobergfe@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: <stable@vger.kernel.org> # v3.18+
2015-10-10namei: results of d_is_negative() should be checked after dentry revalidationTrond Myklebust
Leandro Awa writes: "After switching to version 4.1.6, our parallelized and distributed workflows now fail consistently with errors of the form: T34: ./regex.c:39:22: error: config.h: No such file or directory From our 'git bisect' testing, the following commit appears to be the possible cause of the behavior we've been seeing: commit 766c4cbfacd8" Al Viro says: "What happens is that 766c4cbfacd8 got the things subtly wrong. We used to treat d_is_negative() after lookup_fast() as "fall with ENOENT". That was wrong - checking ->d_flags outside of ->d_seq protection is unreliable and failing with hard error on what should've fallen back to non-RCU pathname resolution is a bug. Unfortunately, we'd pulled the test too far up and ran afoul of another kind of staleness. The dentry might have been absolutely stable from the RCU point of view (and we might be on UP, etc), but stale from the remote fs point of view. If ->d_revalidate() returns "it's actually stale", dentry gets thrown away and the original code wouldn't even have looked at its ->d_flags. What we need is to check ->d_flags where 766c4cbfacd8 does (prior to ->d_seq validation) but only use the result in cases where we do not discard this dentry outright" Reported-by: Leandro Awa <lawa@nvidia.com> Link: https://bugzilla.kernel.org/show_bug.cgi?id=104911 Fixes: 766c4cbfacd8 ("namei: d_is_negative() should be checked...") Tested-by: Leandro Awa <lawa@nvidia.com> Cc: stable@vger.kernel.org # v4.1+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-09Merge branch 'for-linus-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "These are small and assorted. Neil's is the oldest, I dropped the ball thinking he was going to send it in" * 'for-linus-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: support NFSv2 export Btrfs: open_ctree: Fix possible memory leak Btrfs: fix deadlock when finalizing block group creation Btrfs: update fix for read corruption of compressed and shared extents Btrfs: send, fix corner case for reference overwrite detection
2015-10-09nfsd/blocklayout: accept any minlengthChristoph Hellwig
Recent Linux clients have started to send GETLAYOUT requests with minlength less than blocksize. Servers aren't really allowed to impose this kind of restriction on layouts; see RFC 5661 section 18.43.3 for details. This has been observed to cause indefinite hangs on fsx runs on some clients. Cc: stable@vger.kernel.org Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2015-10-07Merge tag 'nfs-for-4.3-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "Highlights include: Bugfixes: - Fix a use-after-free bug in the RPC/RDMA client - Fix a write performance regression - Fix up page writeback accounting - Don't try to reclaim unused state owners - Fix a NFSv4 nograce recovery hang - reset states to use open_stateid when returning delegation voluntarily - Fix a tracepoint NULL-pointer dereference" * tag 'nfs-for-4.3-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFS: Fix a tracepoint NULL-pointer dereference nfs4: reset states to use open_stateid when returning delegation voluntarily NFSv4: Fix a nograce recovery hang NFSv4.1: nfs4_opendata_check_deleg needs to handle NFS4_OPEN_CLAIM_DELEG_CUR_FH NFSv4: Don't try to reclaim unused state owners NFS: Fix a write performance regression NFS: Fix up page writeback accounting xprtrdma: disconnect and flush cqs before freeing buffers
2015-10-06NFS: Fix a tracepoint NULL-pointer dereferenceAnna Schumaker
Running xfstest generic/013 with the tracepoint nfs:nfs4_open_file enabled produces a NULL-pointer dereference when calculating fileid and filehandle of the opened file. Fix this by checking if state is NULL before trying to use the inode pointer. Reported-by: Olga Kornievskaia <aglo@umich.edu> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-10-06BTRFS: support NFSv2 exportNeilBrown
The "fh_len" passed to ->fh_to_* is not guaranteed to be that same as that returned by encode_fh - it may be larger. With NFSv2, the filehandle is fixed length, so it may appear longer than expected and be zero-padded. So we must test that fh_len is at least some value, not exactly equal to it. Signed-off-by: NeilBrown <neilb@suse.de> Acked-by: David Sterba <dsterba@suse.cz>
2015-10-06Btrfs: open_ctree: Fix possible memory leakchandan
After reading one of chunk or tree root tree's root node from disk, if the root node does not have EXTENT_BUFFER_UPTODATE flag set, we fail to release the memory used by the root node. Fix this. Signed-off-by: Chandan Rajendra <chandan@linux.vnet.ibm.com>
2015-10-06Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "Two fixes for problems pointed out by automated tools. Thanks PaX/grsecurity team and Dan Carpenter (and the Smatch tool)" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: [CIFS] Update cifs version number [SMB3] Do not fall back to SMBWriteX in set_file_size error cases [SMB3] Missing null tcon check
2015-10-05Btrfs: fix deadlock when finalizing block group creationFilipe Manana
Josef ran into a deadlock while a transaction handle was finalizing the creation of its block groups, which produced the following trace: [260445.593112] fio D ffff88022a9df468 0 8924 4518 0x00000084 [260445.593119] ffff88022a9df468 ffffffff81c134c0 ffff880429693c00 ffff88022a9df488 [260445.593126] ffff88022a9e0000 ffff8803490d7b00 ffff8803490d7b18 ffff88022a9df4b0 [260445.593132] ffff8803490d7af8 ffff88022a9df488 ffffffff8175a437 ffff8803490d7b00 [260445.593137] Call Trace: [260445.593145] [<ffffffff8175a437>] schedule+0x37/0x80 [260445.593189] [<ffffffffa0850f37>] btrfs_tree_lock+0xa7/0x1f0 [btrfs] [260445.593197] [<ffffffff810db7c0>] ? prepare_to_wait_event+0xf0/0xf0 [260445.593225] [<ffffffffa07eac44>] btrfs_lock_root_node+0x34/0x50 [btrfs] [260445.593253] [<ffffffffa07eff6b>] btrfs_search_slot+0x88b/0xa00 [btrfs] [260445.593295] [<ffffffffa08389df>] ? free_extent_buffer+0x4f/0x90 [btrfs] [260445.593324] [<ffffffffa07f1a06>] btrfs_insert_empty_items+0x66/0xc0 [btrfs] [260445.593351] [<ffffffffa07ea94a>] ? btrfs_alloc_path+0x1a/0x20 [btrfs] [260445.593394] [<ffffffffa08403b9>] btrfs_finish_chunk_alloc+0x1c9/0x570 [btrfs] [260445.593427] [<ffffffffa08002ab>] btrfs_create_pending_block_groups+0x11b/0x200 [btrfs] [260445.593459] [<ffffffffa0800964>] do_chunk_alloc+0x2a4/0x2e0 [btrfs] [260445.593491] [<ffffffffa0803815>] find_free_extent+0xa55/0xd90 [btrfs] [260445.593524] [<ffffffffa0803c22>] btrfs_reserve_extent+0xd2/0x220 [btrfs] [260445.593532] [<ffffffff8119fe5d>] ? account_page_dirtied+0xdd/0x170 [260445.593564] [<ffffffffa0803e78>] btrfs_alloc_tree_block+0x108/0x4a0 [btrfs] [260445.593597] [<ffffffffa080c9de>] ? btree_set_page_dirty+0xe/0x10 [btrfs] [260445.593626] [<ffffffffa07eb5cd>] __btrfs_cow_block+0x12d/0x5b0 [btrfs] [260445.593654] [<ffffffffa07ebbff>] btrfs_cow_block+0x11f/0x1c0 [btrfs] [260445.593682] [<ffffffffa07ef8c7>] btrfs_search_slot+0x1e7/0xa00 [btrfs] [260445.593724] [<ffffffffa08389df>] ? free_extent_buffer+0x4f/0x90 [btrfs] [260445.593752] [<ffffffffa07f1a06>] btrfs_insert_empty_items+0x66/0xc0 [btrfs] [260445.593830] [<ffffffffa07ea94a>] ? btrfs_alloc_path+0x1a/0x20 [btrfs] [260445.593905] [<ffffffffa08403b9>] btrfs_finish_chunk_alloc+0x1c9/0x570 [btrfs] [260445.593946] [<ffffffffa08002ab>] btrfs_create_pending_block_groups+0x11b/0x200 [btrfs] [260445.593990] [<ffffffffa0815798>] btrfs_commit_transaction+0xa8/0xb40 [btrfs] [260445.594042] [<ffffffffa085abcd>] ? btrfs_log_dentry_safe+0x6d/0x80 [btrfs] [260445.594089] [<ffffffffa082bc84>] btrfs_sync_file+0x294/0x350 [btrfs] [260445.594115] [<ffffffff8123e29b>] vfs_fsync_range+0x3b/0xa0 [260445.594133] [<ffffffff81023891>] ? syscall_trace_enter_phase1+0x131/0x180 [260445.594149] [<ffffffff8123e35d>] do_fsync+0x3d/0x70 [260445.594169] [<ffffffff81023bb8>] ? syscall_trace_leave+0xb8/0x110 [260445.594187] [<ffffffff8123e600>] SyS_fsync+0x10/0x20 [260445.594204] [<ffffffff8175de6e>] entry_SYSCALL_64_fastpath+0x12/0x71 This happened because the same transaction handle created a large number of block groups and while finalizing their creation (inserting new items and updating existing items in the chunk and device trees) a new metadata extent had to be allocated and no free space was found in the current metadata block groups, which made find_free_extent() attempt to allocate a new block group via do_chunk_alloc(). However at do_chunk_alloc() we ended up allocating a new system chunk too and exceeded the threshold of 2Mb of reserved chunk bytes, which makes do_chunk_alloc() enter the final part of block group creation again (at btrfs_create_pending_block_groups()) and attempt to lock again the root of the chunk tree when it's already write locked by the same task. Similarly we can deadlock on extent tree nodes/leafs if while we are running delayed references we end up creating a new metadata block group in order to allocate a new node/leaf for the extent tree (as part of a CoW operation or growing the tree), as btrfs_create_pending_block_groups inserts items into the extent tree as well. In this case we get the following trace: [14242.773581] fio D ffff880428ca3418 0 3615 3100 0x00000084 [14242.773588] ffff880428ca3418 ffff88042d66b000 ffff88042a03c800 ffff880428ca3438 [14242.773594] ffff880428ca4000 ffff8803e4b20190 ffff8803e4b201a8 ffff880428ca3460 [14242.773600] ffff8803e4b20188 ffff880428ca3438 ffffffff8175a437 ffff8803e4b20190 [14242.773606] Call Trace: [14242.773613] [<ffffffff8175a437>] schedule+0x37/0x80 [14242.773656] [<ffffffffa057ff07>] btrfs_tree_lock+0xa7/0x1f0 [btrfs] [14242.773664] [<ffffffff810db7c0>] ? prepare_to_wait_event+0xf0/0xf0 [14242.773692] [<ffffffffa0519c44>] btrfs_lock_root_node+0x34/0x50 [btrfs] [14242.773720] [<ffffffffa051ef6b>] btrfs_search_slot+0x88b/0xa00 [btrfs] [14242.773750] [<ffffffffa0520a06>] btrfs_insert_empty_items+0x66/0xc0 [btrfs] [14242.773758] [<ffffffff811ef4a2>] ? kmem_cache_alloc+0x1d2/0x200 [14242.773786] [<ffffffffa0520ad1>] btrfs_insert_item+0x71/0xf0 [btrfs] [14242.773818] [<ffffffffa052f292>] btrfs_create_pending_block_groups+0x102/0x200 [btrfs] [14242.773850] [<ffffffffa052f96e>] do_chunk_alloc+0x2ae/0x2f0 [btrfs] [14242.773934] [<ffffffffa0532825>] find_free_extent+0xa55/0xd90 [btrfs] [14242.773998] [<ffffffffa0532c22>] btrfs_reserve_extent+0xc2/0x1d0 [btrfs] [14242.774041] [<ffffffffa0532e38>] btrfs_alloc_tree_block+0x108/0x4a0 [btrfs] [14242.774078] [<ffffffffa051a5cd>] __btrfs_cow_block+0x12d/0x5b0 [btrfs] [14242.774118] [<ffffffffa051abff>] btrfs_cow_block+0x11f/0x1c0 [btrfs] [14242.774155] [<ffffffffa051e8c7>] btrfs_search_slot+0x1e7/0xa00 [btrfs] [14242.774194] [<ffffffffa0528021>] ? __btrfs_free_extent.isra.70+0x2e1/0xcb0 [btrfs] [14242.774235] [<ffffffffa0520a06>] btrfs_insert_empty_items+0x66/0xc0 [btrfs] [14242.774274] [<ffffffffa051994a>] ? btrfs_alloc_path+0x1a/0x20 [btrfs] [14242.774318] [<ffffffffa052c433>] __btrfs_run_delayed_refs+0xbb3/0x1020 [btrfs] [14242.774358] [<ffffffffa052f404>] btrfs_run_delayed_refs.part.78+0x74/0x280 [btrfs] [14242.774391] [<ffffffffa052f627>] btrfs_run_delayed_refs+0x17/0x20 [btrfs] [14242.774432] [<ffffffffa05be236>] commit_cowonly_roots+0x8d/0x2bd [btrfs] [14242.774474] [<ffffffffa059d07f>] ? __btrfs_run_delayed_items+0x1cf/0x210 [btrfs] [14242.774516] [<ffffffffa05adac3>] ? btrfs_qgroup_account_extents+0x83/0x130 [btrfs] [14242.774558] [<ffffffffa0544c40>] btrfs_commit_transaction+0x590/0xb40 [btrfs] [14242.774599] [<ffffffffa0589b9d>] ? btrfs_log_dentry_safe+0x6d/0x80 [btrfs] [14242.774642] [<ffffffffa055ac54>] btrfs_sync_file+0x294/0x350 [btrfs] [14242.774650] [<ffffffff8123e29b>] vfs_fsync_range+0x3b/0xa0 [14242.774657] [<ffffffff81023891>] ? syscall_trace_enter_phase1+0x131/0x180 [14242.774663] [<ffffffff8123e35d>] do_fsync+0x3d/0x70 [14242.774669] [<ffffffff81023bb8>] ? syscall_trace_leave+0xb8/0x110 [14242.774675] [<ffffffff8123e600>] SyS_fsync+0x10/0x20 [14242.774681] [<ffffffff8175de6e>] entry_SYSCALL_64_fastpath+0x12/0x71 Fix this by never recursing into the finalization phase of block group creation and making sure we never trigger the finalization of block group creation while running delayed references. Reported-by: Josef Bacik <jbacik@fb.com> Fixes: 00d80e342c0f ("Btrfs: fix quick exhaustion of the system array in the superblock") Signed-off-by: Filipe Manana <fdmanana@suse.com>
2015-10-05Btrfs: update fix for read corruption of compressed and shared extentsFilipe Manana
My previous fix in commit 005efedf2c7d ("Btrfs: fix read corruption of compressed and shared extents") was effective only if the compressed extents cover a file range with a length that is not a multiple of 16 pages. That's because the detection of when we reached a different range of the file that shares the same compressed extent as the previously processed range was done at extent_io.c:__do_contiguous_readpages(), which covers subranges with a length up to 16 pages, because extent_readpages() groups the pages in clusters no larger than 16 pages. So fix this by tracking the start of the previously processed file range's extent map at extent_readpages(). The following test case for fstests reproduces the issue: seq=`basename $0` seqres=$RESULT_DIR/$seq echo "QA output created by $seq" tmp=/tmp/$$ status=1 # failure is the default! trap "_cleanup; exit \$status" 0 1 2 3 15 _cleanup() { rm -f $tmp.* } # get standard environment, filters and checks . ./common/rc . ./common/filter # real QA test starts here _need_to_be_root _supported_fs btrfs _supported_os Linux _require_scratch _require_cloner rm -f $seqres.full test_clone_and_read_compressed_extent() { local mount_opts=$1 _scratch_mkfs >>$seqres.full 2>&1 _scratch_mount $mount_opts # Create our test file with a single extent of 64Kb that is going to # be compressed no matter which compression algo is used (zlib/lzo). $XFS_IO_PROG -f -c "pwrite -S 0xaa 0K 64K" \ $SCRATCH_MNT/foo | _filter_xfs_io # Now clone the compressed extent into an adjacent file offset. $CLONER_PROG -s 0 -d $((64 * 1024)) -l $((64 * 1024)) \ $SCRATCH_MNT/foo $SCRATCH_MNT/foo echo "File digest before unmount:" md5sum $SCRATCH_MNT/foo | _filter_scratch # Remount the fs or clear the page cache to trigger the bug in # btrfs. Because the extent has an uncompressed length that is a # multiple of 16 pages, all the pages belonging to the second range # of the file (64K to 128K), which points to the same extent as the # first range (0K to 64K), had their contents full of zeroes instead # of the byte 0xaa. This was a bug exclusively in the read path of # compressed extents, the correct data was stored on disk, btrfs # just failed to fill in the pages correctly. _scratch_remount echo "File digest after remount:" # Must match the digest we got before. md5sum $SCRATCH_MNT/foo | _filter_scratch } echo -e "\nTesting with zlib compression..." test_clone_and_read_compressed_extent "-o compress=zlib" _scratch_unmount echo -e "\nTesting with lzo compression..." test_clone_and_read_compressed_extent "-o compress=lzo" status=0 exit Cc: stable@vger.kernel.org Signed-off-by: Filipe Manana <fdmanana@suse.com> Tested-by: Timofey Titovets <nefelim4ag@gmail.com>
2015-10-05Btrfs: send, fix corner case for reference overwrite detectionFilipe Manana
When the inode given to did_overwrite_ref() matches the current progress and has a reference that collides with the reference of other inode that has the same number as the current progress, we were always telling our caller that the inode's reference was overwritten, which is incorrect because the other inode might be a new inode (different generation number) in which case we must return false from did_overwrite_ref() so that its callers don't use an orphanized path for the inode (as it will never be orphanized, instead it will be unlinked and the new inode created later). The following test case for fstests reproduces the issue: seq=`basename $0` seqres=$RESULT_DIR/$seq echo "QA output created by $seq" tmp=/tmp/$$ status=1 # failure is the default! trap "_cleanup; exit \$status" 0 1 2 3 15 _cleanup() { rm -fr $send_files_dir rm -f $tmp.* } # get standard environment, filters and checks . ./common/rc . ./common/filter # real QA test starts here _supported_fs btrfs _supported_os Linux _require_scratch _need_to_be_root send_files_dir=$TEST_DIR/btrfs-test-$seq rm -f $seqres.full rm -fr $send_files_dir mkdir $send_files_dir _scratch_mkfs >>$seqres.full 2>&1 _scratch_mount # Create our test file with a single extent of 64K. mkdir -p $SCRATCH_MNT/foo $XFS_IO_PROG -f -c "pwrite -S 0xaa 0 64K" $SCRATCH_MNT/foo/bar \ | _filter_xfs_io _run_btrfs_util_prog subvolume snapshot -r $SCRATCH_MNT \ $SCRATCH_MNT/mysnap1 _run_btrfs_util_prog subvolume snapshot $SCRATCH_MNT \ $SCRATCH_MNT/mysnap2 echo "File digest before being replaced:" md5sum $SCRATCH_MNT/mysnap1/foo/bar | _filter_scratch # Remove the file and then create a new one in the same location with # the same name but with different content. This new file ends up # getting the same inode number as the previous one, because that inode # number was the highest inode number used by the snapshot's root and # therefore when attempting to find the a new inode number for the new # file, we end up reusing the same inode number. This happens because # currently btrfs uses the highest inode number summed by 1 for the # first inode created once a snapshot's root is loaded (done at # fs/btrfs/inode-map.c:btrfs_find_free_objectid in the linux kernel # tree). # Having these two different files in the snapshots with the same inode # number (but different generation numbers) caused the btrfs send code # to emit an incorrect path for the file when issuing an unlink # operation because it failed to realize they were different files. rm -f $SCRATCH_MNT/mysnap2/foo/bar $XFS_IO_PROG -f -c "pwrite -S 0xbb 0 96K" \ $SCRATCH_MNT/mysnap2/foo/bar | _filter_xfs_io _run_btrfs_util_prog subvolume snapshot -r $SCRATCH_MNT/mysnap2 \ $SCRATCH_MNT/mysnap2_ro _run_btrfs_util_prog send $SCRATCH_MNT/mysnap1 -f $send_files_dir/1.snap _run_btrfs_util_prog send -p $SCRATCH_MNT/mysnap1 \ $SCRATCH_MNT/mysnap2_ro -f $send_files_dir/2.snap echo "File digest in the original filesystem after being replaced:" md5sum $SCRATCH_MNT/mysnap2_ro/foo/bar | _filter_scratch # Now recreate the filesystem by receiving both send streams and verify # we get the same file contents that the original filesystem had. _scratch_unmount _scratch_mkfs >>$seqres.full 2>&1 _scratch_mount _run_btrfs_util_prog receive -vv $SCRATCH_MNT -f $send_files_dir/1.snap _run_btrfs_util_prog receive -vv $SCRATCH_MNT -f $send_files_dir/2.snap echo "File digest in the new filesystem:" # Must match the digest from the new file. md5sum $SCRATCH_MNT/mysnap2_ro/foo/bar | _filter_scratch status=0 exit Reported-by: Martin Raiber <martin@urbackup.org> Fixes: 8b191a684968 ("Btrfs: incremental send, check if orphanized dir inode needs delayed rename") Signed-off-by: Filipe Manana <fdmanana@suse.com>
2015-10-03[CIFS] Update cifs version numberSteve French
Update modinfo cifs.ko version number to 2.08 Signed-off-by: Steve French <steve.french@primarydata.com>
2015-10-02nfs4: reset states to use open_stateid when returning delegation voluntarilyJeff Layton
When the client goes to return a delegation, it should always update any nfs4_state currently set up to use that delegation stateid to instead use the open stateid. It already does do this in some cases, particularly in the state recovery code, but not currently when the delegation is voluntarily returned (e.g. in advance of a RENAME). This causes the client to try to continue using the delegation stateid after the DELEGRETURN, e.g. in LAYOUTGET. Set the nfs4_state back to using the open stateid in nfs4_open_delegation_recall, just before clearing the NFS_DELEGATED_STATE bit. Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-10-02NFSv4: Fix a nograce recovery hangBenjamin Coddington
Since commit 5cae02f42793130e1387f4ec09c4d07056ce9fa5 an OPEN_CONFIRM should have a privileged sequence in the recovery case to allow nograce recovery to proceed for NFSv4.0. Signed-off-by: Benjamin Coddington <bcodding@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-10-02NFSv4.1: nfs4_opendata_check_deleg needs to handle NFS4_OPEN_CLAIM_DELEG_CUR_FHTrond Myklebust
We need to warn against broken NFSv4.1 servers that try to hand out delegations in response to NFS4_OPEN_CLAIM_DELEG_CUR_FH. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-10-02NFSv4: Don't try to reclaim unused state ownersTrond Myklebust
Currently, we don't test if the state owner is in use before we try to recover it. The problem is that if the refcount is zero, then the state owner will be waiting on the lru list for garbage collection. The expectation in that case is that if you bump the refcount, then you must also remove the state owner from the lru list. Otherwise the call to nfs4_put_state_owner will corrupt that list by trying to add our state owner a second time. Avoid the whole problem by just skipping state owners that hold no state. Reported-by: Andrew W Elble <aweits@rit.edu> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-10-02NFS: Fix a write performance regressionTrond Myklebust
If all other conditions in nfs_can_extend_write() are met, and there are no locks, then we should be able to assume close-to-open semantics and the ability to extend our write to cover the whole page. With this patch, the xfstests generic/074 test completes in 242s instead of >1400s on my test rig. Fixes: bd61e0a9c852 ("locks: convert posix locks to file_lock_context") Cc: Jeff Layton <jlayton@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-10-02NFS: Fix up page writeback accountingTrond Myklebust
Currently, we are crediting all the calls to nfs_writepages_callback() (i.e. the nfs_writepages() callback) to nfs_writepage(). Aside from being inconsistent with the behaviour of the equivalent readpage/readpages accounting, this also means that we cannot distinguish between bulk writes and single page writebacks (which confuses the 'nfsiostat -p' tool). Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-10-01[SMB3] Do not fall back to SMBWriteX in set_file_size error casesSteve French
The error paths in set_file_size for cifs and smb3 are incorrect. In the unlikely event that a server did not support set file info of the file size, the code incorrectly falls back to trying SMBWriteX (note that only the original core SMB Write, used for example by DOS, can set the file size this way - this actually does not work for the more recent SMBWriteX). The idea was since the old DOS SMB Write could set the file size if you write zero bytes at that offset then use that if server rejects the normal set file info call. Fortunately the SMBWriteX will never be sent on the wire (except when file size is zero) since the length and offset fields were reversed in the two places in this function that call SMBWriteX causing the fall back path to return an error. It is also important to never call an SMB request from an SMB2/sMB3 session (which theoretically would be possible, and can cause a brief session drop, although the client recovers) so this should be fixed. In practice this path does not happen with modern servers but the error fall back to SMBWriteX is clearly wrong. Removing the calls to SMBWriteX in the error paths in cifs_set_file_size Pointed out by PaX/grsecurity team Signed-off-by: Steve French <steve.french@primarydata.com> Reported-by: PaX Team <pageexec@freemail.hu> CC: Emese Revfy <re.emese@gmail.com> CC: Brad Spengler <spender@grsecurity.net> CC: Stable <stable@vger.kernel.org>
2015-10-01dax: fix NULL pointer in __dax_pmd_fault()Ross Zwisler
Commit 46c043ede471 ("mm: take i_mmap_lock in unmap_mapping_range() for DAX") moved some code in __dax_pmd_fault() that was responsible for zeroing newly allocated PMD pages. The new location didn't properly set up 'kaddr', so when run this code resulted in a NULL pointer BUG. Fix this by getting the correct 'kaddr' via bdev_direct_access(). Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com> Reported-by: Dan Williams <dan.j.williams@intel.com> Reviewed-by: Dan Williams <dan.j.williams@intel.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-01Merge tag 'upstream-4.3-rc4' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull UBI/UBIFS fixes from Richard Weinberger: "This contains three bug fixes for both UBI and UBIFS" * tag 'upstream-4.3-rc4' of git://git.infradead.org/linux-ubifs: UBI: return ENOSPC if no enough space available UBI: Validate data_size UBIFS: Kill unneeded locking in ubifs_init_security
2015-09-29UBIFS: Kill unneeded locking in ubifs_init_securityRichard Weinberger
Fixes the following lockdep splat: [ 1.244527] ============================================= [ 1.245193] [ INFO: possible recursive locking detected ] [ 1.245193] 4.2.0-rc1+ #37 Not tainted [ 1.245193] --------------------------------------------- [ 1.245193] cp/742 is trying to acquire lock: [ 1.245193] (&sb->s_type->i_mutex_key#9){+.+.+.}, at: [<ffffffff812b3f69>] ubifs_init_security+0x29/0xb0 [ 1.245193] [ 1.245193] but task is already holding lock: [ 1.245193] (&sb->s_type->i_mutex_key#9){+.+.+.}, at: [<ffffffff81198e7f>] path_openat+0x3af/0x1280 [ 1.245193] [ 1.245193] other info that might help us debug this: [ 1.245193] Possible unsafe locking scenario: [ 1.245193] [ 1.245193] CPU0 [ 1.245193] ---- [ 1.245193] lock(&sb->s_type->i_mutex_key#9); [ 1.245193] lock(&sb->s_type->i_mutex_key#9); [ 1.245193] [ 1.245193] *** DEADLOCK *** [ 1.245193] [ 1.245193] May be due to missing lock nesting notation [ 1.245193] [ 1.245193] 2 locks held by cp/742: [ 1.245193] #0: (sb_writers#5){.+.+.+}, at: [<ffffffff811ad37f>] mnt_want_write+0x1f/0x50 [ 1.245193] #1: (&sb->s_type->i_mutex_key#9){+.+.+.}, at: [<ffffffff81198e7f>] path_openat+0x3af/0x1280 [ 1.245193] [ 1.245193] stack backtrace: [ 1.245193] CPU: 2 PID: 742 Comm: cp Not tainted 4.2.0-rc1+ #37 [ 1.245193] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.7.5-0-ge51488c-20140816_022509-build35 04/01/2014 [ 1.245193] ffffffff8252d530 ffff88007b023a38 ffffffff814f6f49 ffffffff810b56c5 [ 1.245193] ffff88007c30cc80 ffff88007b023af8 ffffffff810a150d ffff88007b023a68 [ 1.245193] 000000008101302a ffff880000000000 00000008f447e23f ffffffff8252d500 [ 1.245193] Call Trace: [ 1.245193] [<ffffffff814f6f49>] dump_stack+0x4c/0x65 [ 1.245193] [<ffffffff810b56c5>] ? console_unlock+0x1c5/0x510 [ 1.245193] [<ffffffff810a150d>] __lock_acquire+0x1a6d/0x1ea0 [ 1.245193] [<ffffffff8109fa78>] ? __lock_is_held+0x58/0x80 [ 1.245193] [<ffffffff810a1a93>] lock_acquire+0xd3/0x270 [ 1.245193] [<ffffffff812b3f69>] ? ubifs_init_security+0x29/0xb0 [ 1.245193] [<ffffffff814fc83b>] mutex_lock_nested+0x6b/0x3a0 [ 1.245193] [<ffffffff812b3f69>] ? ubifs_init_security+0x29/0xb0 [ 1.245193] [<ffffffff812b3f69>] ? ubifs_init_security+0x29/0xb0 [ 1.245193] [<ffffffff812b3f69>] ubifs_init_security+0x29/0xb0 [ 1.245193] [<ffffffff8128e286>] ubifs_create+0xa6/0x1f0 [ 1.245193] [<ffffffff81198e7f>] ? path_openat+0x3af/0x1280 [ 1.245193] [<ffffffff81195d15>] vfs_create+0x95/0xc0 [ 1.245193] [<ffffffff8119929c>] path_openat+0x7cc/0x1280 [ 1.245193] [<ffffffff8109ffe3>] ? __lock_acquire+0x543/0x1ea0 [ 1.245193] [<ffffffff81088f20>] ? sched_clock_cpu+0x90/0xc0 [ 1.245193] [<ffffffff81088c00>] ? calc_global_load_tick+0x60/0x90 [ 1.245193] [<ffffffff81088f20>] ? sched_clock_cpu+0x90/0xc0 [ 1.245193] [<ffffffff811a9cef>] ? __alloc_fd+0xaf/0x180 [ 1.245193] [<ffffffff8119ac55>] do_filp_open+0x75/0xd0 [ 1.245193] [<ffffffff814ffd86>] ? _raw_spin_unlock+0x26/0x40 [ 1.245193] [<ffffffff811a9cef>] ? __alloc_fd+0xaf/0x180 [ 1.245193] [<ffffffff81189bd9>] do_sys_open+0x129/0x200 [ 1.245193] [<ffffffff81189cc9>] SyS_open+0x19/0x20 [ 1.245193] [<ffffffff81500717>] entry_SYSCALL_64_fastpath+0x12/0x6f While the lockdep splat is a false positive, becuase path_openat holds i_mutex of the parent directory and ubifs_init_security() tries to acquire i_mutex of a new inode, it reveals that taking i_mutex in ubifs_init_security() is in vain because it is only being called in the inode allocation path and therefore nobody else can see the inode yet. Cc: stable@vger.kernel.org # 3.20- Reported-and-tested-by: Boris Brezillon <boris.brezillon@free-electrons.com> Reviewed-and-tested-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: dedekind1@gmail.com
2015-09-27Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "Four fixes from testing at the recent SMB3 Plugfest including two important authentication ones (one fixes authentication problems to some popular servers when clock times differ more than two hours between systems, the other fixes Kerberos authentication for SMB3)" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: fix encryption error checks on mount [SMB3] Fix sec=krb5 on smb3 mounts cifs: use server timestamp for ntlmv2 authentication disabling oplocks/leases via module parm enable_oplocks broken for SMB3
2015-09-26[SMB3] Missing null tcon checkSteve French
Pointed out by Dan Carpenter via smatch code analysis tool CC: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Steve French <steve.french@primarydata.com>
2015-09-25Merge branch 'for-linus-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "This is an assorted set I've been queuing up: Jeff Mahoney tracked down a tricky one where we ended up starting IO on the wrong mapping for special files in btrfs_evict_inode. A few people reported this one on the list. Filipe found (and provided a test for) a difficult bug in reading compressed extents, and Josef fixed up some quota record keeping with snapshot deletion. Chandan killed off an accounting bug during DIO that lead to WARN_ONs as we freed inodes" * 'for-linus-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: keep dropped roots in cache until transaction commit Btrfs: Direct I/O: Fix space accounting btrfs: skip waiting on ordered range for special files Btrfs: fix read corruption of compressed and shared extents Btrfs: remove unnecessary locking of cleaner_mutex to avoid deadlock Btrfs: don't initialize a space info as full to prevent ENOSPC
2015-09-25Merge tag 'nfs-for-4.3-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "Highlights include: Stable patches: - fix v4.2 SEEK on files over 2 gigs - Fix a layout segment reference leak when pNFS I/O falls back to inband I/O. - Fix recovery of recalled read delegations Bugfixes: - Fix a case where NFSv4 fails to send CLOSE after a server reboot - Fix sunrpc to wait for connections to complete before retrying - Fix sunrpc races between transport connect/disconnect and shutdown - Fix an infinite loop when layoutget fail with BAD_STATEID - nfs/filelayout: Fix NULL reference caused by double freeing of fh_array - Fix a bogus WARN_ON_ONCE() in O_DIRECT when layout commit_through_mds is set - Fix layoutreturn/close ordering issues" * tag 'nfs-for-4.3-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFS41: make close wait for layoutreturn NFS: Skip checking ds_cinfo.buckets when lseg's commit_through_mds is set NFSv4.x/pnfs: Don't try to recover stateids twice in layoutget NFSv4: Recovery of recalled read delegations is broken NFS: Fix an infinite loop when layoutget fail with BAD_STATEID NFS: Do cleanup before resetting pageio read/write to mds SUNRPC: xs_sock_mark_closed() does not need to trigger socket autoclose SUNRPC: Lock the transport layer on shutdown nfs/filelayout: Fix NULL reference caused by double freeing of fh_array SUNRPC: Ensure that we wait for connections to complete before retrying SUNRPC: drop null test before destroy functions nfs: fix v4.2 SEEK on files over 2 gigs SUNRPC: Fix races between socket connection and destroy code nfs: fix pg_test page count calculation Failing to send a CLOSE if file is opened WRONLY and server reboots on a 4.x mount
2015-09-24ext4: Update EXT4_USE_FOR_EXT2 descriptionJean Delvare
Configuration option EXT4_USE_FOR_EXT2 has no effect on ext3 support. Support for ext3 is always included now. Signed-off-by: Jean Delvare <jdelvare@suse.de> Fixes: c290ea01ab ("fs: Remove ext3 filesystem driver") Cc: Jan Kara <jack@suse.cz> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Signed-off-by: Jan Kara <jack@suse.com>
2015-09-24fix encryption error checks on mountSteve French
2015-09-24[SMB3] Fix sec=krb5 on smb3 mountsSteve French
Kerberos, which is very important for security, was only enabled for CIFS not SMB2/SMB3 mounts (e.g. vers=3.0) Patch based on the information detailed in http://thread.gmane.org/gmane.linux.kernel.cifs/10081/focus=10307 to enable Kerberized SMB2/SMB3 a) SMB2_negotiate: enable/use decode_negTokenInit in SMB2_negotiate b) SMB2_sess_setup: handle Kerberos sectype and replicate Kerberos SMB1 processing done in sess_auth_kerberos Signed-off-by: Noel Power <noel.power@suse.com> Signed-off-by: Jim McDonough <jmcd@samba.org> CC: Stable <stable@vger.kernel.org> Signed-off-by: Steve French <steve.french@primarydata.com>
