path: root/fs
2015-12-22Merge tag 'nfsd-4.4-1' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd fix from Bruce Fields: "Just one fix for a NFSv4 callback bug introduced in 4.4" * tag 'nfsd-4.4-1' of git://linux-nfs.org/~bfields/linux: nfsd: don't hold ls_mutex across a layout recall
2015-12-18Merge branch 'for-linus-4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "A couple of small fixes" * 'for-linus-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: check prepare_uptodate_page() error code earlier Btrfs: check for empty bitmap list in setup_cluster_bitmaps btrfs: fix misleading warning when space cache failed to load Btrfs: fix transaction handle leak in balance Btrfs: fix unprotected list move from unused_bgs to deleted_bgs list
2015-12-18proc: fix -ESRCH error when writing to /proc/$pid/coredump_filterColin Ian King
Writing to /proc/$pid/coredump_filter always returns -ESRCH because commit 774636e19ed51 ("proc: convert to kstrto*()/kstrto*_from_user()") removed the setting of ret after the get_proc_task call and incorrectly left it as -ESRCH. Instead, return 0 when successful. Example breakage: echo 0 > /proc/self/coredump_filter bash: echo: write error: No such process Fixes: 774636e19ed51 ("proc: convert to kstrto*()/kstrto*_from_user()") Signed-off-by: Colin Ian King <colin.king@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Cc: <stable@vger.kernel.org> [4.3+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-12-16nfsd: don't hold ls_mutex across a layout recallJeff Layton
We do need to serialize layout stateid morphing operations, but we currently hold the ls_mutex across a layout recall which is pretty ugly. It's also unnecessary -- once we've bumped the seqid and copied it, we don't need to serialize the rest of the CB_LAYOUTRECALL vs. anything else. Just drop the mutex once the copy is done. This was causing a "workqueue leaked lock or atomic" warning and an occasional deadlock. There's more work to be done here but this fixes the immediate regression. Fixes: cc8a55320b5f "nfsd: serialize layout stateid morphing operations" Cc: stable@vger.kernel.org Reported-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2015-12-15Merge branch 'for-chris-4.4' of ↵Chris Mason
git://git.kernel.org/pub/scm/linux/kernel/git/fdmanana/linux into for-linus-4.4
2015-12-15Btrfs: check prepare_uptodate_page() error code earlierChris Mason
prepare_pages() may end up calling prepare_uptodate_page() twice if our write only spans a single page. But if the first call returns an error, our page will be unlocked and its not safe to call it again. This bug goes all the way back to 2011, and it's not something commonly hit. While we're here, add a more explicit check for the page being truncated away. The bare lock_page() alone is protected only by good thoughts and i_mutex, which we're sure to regret eventually. Reported-by: Dave Jones <dsj@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2015-12-15Btrfs: check for empty bitmap list in setup_cluster_bitmapsChris Mason
Dave Jones found a warning from kasan in setup_cluster_bitmaps() ================================================================== BUG: KASAN: stack-out-of-bounds in setup_cluster_bitmap+0xc4/0x5a0 at addr ffff88039bef6828 Read of size 8 by task nfsd/1009 page:ffffea000e6fbd80 count:0 mapcount:0 mapping: (null) index:0x0 flags: 0x8000000000000000() page dumped because: kasan: bad access detected CPU: 1 PID: 1009 Comm: nfsd Tainted: G W 4.4.0-rc3-backup-debug+ #1 ffff880065647b50 000000006bb712c2 ffff88039bef6640 ffffffffa680a43e 0000004559c00000 ffff88039bef66c8 ffffffffa62638d1 ffffffffa61121c0 ffff8803a5769de8 0000000000000296 ffff8803a5769df0 0000000000046280 Call Trace: [<ffffffffa680a43e>] dump_stack+0x4b/0x6d [<ffffffffa62638d1>] kasan_report_error+0x501/0x520 [<ffffffffa61121c0>] ? debug_show_all_locks+0x1e0/0x1e0 [<ffffffffa6263948>] kasan_report+0x58/0x60 [<ffffffffa6814b00>] ? rb_last+0x10/0x40 [<ffffffffa66f8af4>] ? setup_cluster_bitmap+0xc4/0x5a0 [<ffffffffa6262ead>] __asan_load8+0x5d/0x70 [<ffffffffa66f8af4>] setup_cluster_bitmap+0xc4/0x5a0 [<ffffffffa66f675a>] ? setup_cluster_no_bitmap+0x6a/0x400 [<ffffffffa66fcd16>] btrfs_find_space_cluster+0x4b6/0x640 [<ffffffffa66fc860>] ? btrfs_alloc_from_cluster+0x4e0/0x4e0 [<ffffffffa66fc36e>] ? btrfs_return_cluster_to_free_space+0x9e/0xb0 [<ffffffffa702dc37>] ? _raw_spin_unlock+0x27/0x40 [<ffffffffa666a1a1>] find_free_extent+0xba1/0x1520 Andrey noticed this was because we were doing list_first_entry on a list that might be empty. Rework the tests a bit so we don't do that. Signed-off-by: Chris Mason <clm@fb.com> Reprorted-by: Andrey Ryabinin <ryabinin.a.a@gmail.com> Reported-by: Dave Jones <dsj@fb.com>
2015-12-13sched/wait: Fix the signal handling fixPeter Zijlstra
Jan Stancek reported that I wrecked things for him by fixing things for Vladimir :/ His report was due to an UNINTERRUPTIBLE wait getting -EINTR, which should not be possible, however my previous patch made this possible by unconditionally checking signal_pending(). We cannot use current->state as was done previously, because the instruction after the store to that variable it can be changed. We must instead pass the initial state along and use that. Fixes: 68985633bccb ("sched/wait: Fix signal handling in bit wait helpers") Reported-by: Jan Stancek <jstancek@redhat.com> Reported-by: Chris Mason <clm@fb.com> Tested-by: Jan Stancek <jstancek@redhat.com> Tested-by: Vladimir Murzin <vladimir.murzin@arm.com> Tested-by: Chris Mason <clm@fb.com> Reviewed-by: Paul Turner <pjt@google.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: tglx@linutronix.de Cc: Oleg Nesterov <oleg@redhat.com> Cc: hpa@zytor.com Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-12-13Merge tag 'nfs-for-4.4-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfix from Trond Myklebust: "SUNRPC: Fix a NFSv4.1 callback channel regression" * tag 'nfs-for-4.4-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: SUNRPC: Fix callback channel
2015-12-12Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "17 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: MIPS: fix DMA contiguous allocation sh64: fix __NR_fgetxattr ocfs2: fix SGID not inherited issue mm/oom_kill.c: avoid attempting to kill init sharing same memory drivers/base/memory.c: prohibit offlining of memory blocks with missing sections tmpfs: fix shmem_evict_inode() warnings on i_blocks mm/hugetlb.c: fix resv map memory leak for placeholder entries mm: hugetlb: call huge_pte_alloc() only if ptep is null kernel: remove stop_machine() Kconfig dependency mm: kmemleak: mark kmemleak_init prototype as __init mm: fix kerneldoc on mem_cgroup_replace_page osd fs: __r4w_get_page rely on PageUptodate for uptodate MAINTAINERS: make Vladimir co-maintainer of the memory controller mm, vmstat: allow WQ concurrency to discover memory reclaim doesn't make any progress mm: fix swapped Movable and Reclaimable in /proc/pagetypeinfo memcg: fix memory.high target mm: hugetlb: fix hugepage memory leak caused by wrong reserve count
2015-12-12Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "A set of fixes for the current series. This contains: - A bunch of fixes for lightnvm, should be the last round for this series. From Matias and Wenwei. - A writeback detach inode fix from Ilya, also marked for stable. - A block (though it says SCSI) fix for an OOPS in SCSI runtime power management. - Module init error path fixes for null_blk from Minfei" * 'for-linus' of git://git.kernel.dk/linux-block: null_blk: Fix error path in module initialization lightnvm: do not compile in debugging by default lightnvm: prevent gennvm module unload on use lightnvm: fix media mgr registration lightnvm: replace req queue with nvmdev for lld lightnvm: comments on constants lightnvm: check mm before use lightnvm: refactor spin_unlock in gennvm_get_blk lightnvm: put blks when luns configure failed lightnvm: use flags in rrpc_get_blk block: detach bdev inode from its wb in __blkdev_put() SCSI: Fix NULL pointer dereference in runtime PM
2015-12-12ocfs2: fix SGID not inherited issueJunxiao Bi
Commit 8f1eb48758aa ("ocfs2: fix umask ignored issue") introduced an issue, SGID of sub dir was not inherited from its parents dir. It is because SGID is set into "inode->i_mode" in ocfs2_get_init_inode(), but is overwritten by "mode" which don't have SGID set later. Fixes: 8f1eb48758aa ("ocfs2: fix umask ignored issue") Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Cc: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Acked-by: Srinivas Eeda <srinivas.eeda@oracle.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-12-12osd fs: __r4w_get_page rely on PageUptodate for uptodateHugh Dickins
Commit 42cb14b110a5 ("mm: migrate dirty page without clear_page_dirty_for_io etc") simplified the migration of a PageDirty pagecache page: one stat needs moving from zone to zone and that's about all. It's convenient and safest for it to shift the PageDirty bit from old page to new, just before updating the zone stats: before copying data and marking the new PageUptodate. This is all done while both pages are isolated and locked, just as before; and just as before, there's a moment when the new page is visible in the radix_tree, but not yet PageUptodate. What's new is that it may now be briefly visible as PageDirty before it is PageUptodate. When I scoured the tree to see if this could cause a problem anywhere, the only places I found were in two similar functions __r4w_get_page(): which look up a page with find_get_page() (not using page lock), then claim it's uptodate if it's PageDirty or PageWriteback or PageUptodate. I'm not sure whether that was right before, but now it might be wrong (on rare occasions): only claim the page is uptodate if PageUptodate. Or perhaps the page in question could never be migratable anyway? Signed-off-by: Hugh Dickins <hughd@google.com> Tested-by: Boaz Harrosh <ooo@electrozaur.com> Cc: Benny Halevy <bhalevy@panasas.com> Cc: Trond Myklebust <trond.myklebust@primarydata.com> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-12-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse Pull fuse fixes from Miklos Szeredi: "Two bugfixes, both bound for -stable" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: break infinite loop in fuse_fill_write_pages() cuse: fix memory leak
2015-12-10btrfs: fix misleading warning when space cache failed to loadHolger Hoffstätte
When an inconsistent space cache is detected during loading we log a warning that users frequently mistake as instruction to invalidate the cache manually, even though this is not required. Fix the message to indicate that the cache will be rebuilt automatically. Signed-off-by: Holger Hoffstätte <holger.hoffstaette@googlemail.com> Acked-by: Filipe Manana <fdmanana@suse.com>
2015-12-10Btrfs: fix transaction handle leak in balanceFilipe Manana
If we fail to allocate a new data chunk, we were jumping to the error path without release the transaction handle we got before. Fix this by always releasing it before doing the jump. Fixes: 2c9fe8355258 ("btrfs: Fix lost-data-profile caused by balance bg") Signed-off-by: Filipe Manana <fdmanana@suse.com>
2015-12-10Btrfs: fix unprotected list move from unused_bgs to deleted_bgs listFilipe Manana
As of my previous change titled "Btrfs: fix scrub preventing unused block groups from being deleted", the following warning at extent-tree.c:btrfs_delete_unused_bgs() can be hit when we mount the a filesysten with "-o discard": 10263 void btrfs_delete_unused_bgs(struct btrfs_fs_info *fs_info) 10264 { (...) 10405 if (trimming) { 10406 WARN_ON(!list_empty(&block_group->bg_list)); 10407 spin_lock(&trans->transaction->deleted_bgs_lock); 10408 list_move(&block_group->bg_list, 10409 &trans->transaction->deleted_bgs); 10410 spin_unlock(&trans->transaction->deleted_bgs_lock); 10411 btrfs_get_block_group(block_group); 10412 } (...) This happens because scrub can now add back the block group to the list of unused block groups (fs_info->unused_bgs). This is dangerous because we are moving the block group from the unused block groups list to the list of deleted block groups without holding the lock that protects the source list (fs_info->unused_bgs_lock). The following diagram illustrates how this happens: CPU 1 CPU 2 cleaner_kthread() btrfs_delete_unused_bgs() sees bg X in list fs_info->unused_bgs deletes bg X from list fs_info->unused_bgs scrub_enumerate_chunks() searches device tree using its commit root finds device extent for block group X gets block group X from the tree fs_info->block_group_cache_tree (via btrfs_lookup_block_group()) sets bg X to RO (again) scrub_chunk(bg X) sets bg X back to RW mode adds bg X to the list fs_info->unused_bgs again, since it's still unused and currently not in that list sets bg X to RO mode btrfs_remove_chunk(bg X) --> discard is enabled and bg X is in the fs_info->unused_bgs list again so the warning is triggered --> we move it from that list into the transaction's delete_bgs list, but we can have another task currently manipulating the first list (fs_info->unused_bgs) Fix this by using the same lock (fs_info->unused_bgs_lock) to protect both the list of unused block groups and the list of deleted block groups. This makes it safe and there's not much worry for more lock contention, as this lock is seldom used and only the cleaner kthread adds elements to the list of deleted block groups. The warning goes away too, as this was previously an impossible case (and would have been better a BUG_ON/ASSERT) but it's not impossible anymore. Reproduced with fstest btrfs/073 (using MOUNT_OPTIONS="-o discard"). Signed-off-by: Filipe Manana <fdmanana@suse.com>
2015-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "A couple of fixes, both -stable fodder (9p one all way back to 2.6.32, dio - to all branches where "Fix negative return from dio read beyond eof" will end up it; it's a fixup to commit marked for -stable)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fix the regression from "direct-io: Fix negative return from dio read beyond eof" 9p: ->evict_inode() should kick out ->i_data, not ->i_mapping
2015-12-08fix the regression from "direct-io: Fix negative return from dio read beyond ↵Al Viro
eof" Sure, it's better to bail out of past-the-eof read and return 0 than return a bogus negative value on such. Only we'd better make sure we are bailing out with 0 and not -ENOMEM... Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-089p: ->evict_inode() should kick out ->i_data, not ->i_mappingAl Viro
For block devices the pagecache is associated with the inode on bdevfs, not with the aliasing ones on the mountable filesystems. The latter have its own ->i_data empty and ->i_mapping pointing to the (unique per major/minor) bdevfs inode. That guarantees cache coherence between all block device inodes with the same device number. Eviction of an alias inode has no business trying to evict the pages belonging to bdevfs one; moreover, ->i_mapping is only safe to access when the thing is opened. At the time of ->evict_inode() the victim is definitely *not* opened. We are about to kill the address space embedded into struct inode (inode->i_data) and that's what we need to empty of any pages. 9p instance tries to empty inode->i_mapping instead, which is both unsafe and bogus - if we have several device nodes with the same device number in different places, closing one of them should not try to empty the (shared) page cache. Fortunately, other instances in the tree are OK; they are evicting from &inode->i_data instead, as 9p one should. Cc: stable@vger.kernel.org # v2.6.32+, ones prior to 2.6.36 need only half of that Reported-by: "Suzuki K. Poulose" <Suzuki.Poulose@arm.com> Tested-by: "Suzuki K. Poulose" <Suzuki.Poulose@arm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-07SUNRPC: Fix callback channelTrond Myklebust
The NFSv4.1 callback channel is currently broken because the receive message will keep shrinking because the backchannel receive buffer size never gets reset. The easiest solution to this problem is instead of changing the receive buffer, to rather adjust the copied request. Fixes: 38b7631fbe42 ("nfs4: limit callback decoding to received bytes") Cc: Benjamin Coddington <bcodding@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-12-07Merge tag 'ext4_for_linus_stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 fixes from Ted Ts'o: "Ext4 bug fixes for v4.4, including fixes for post-2038 time encodings, some endian conversion problems with ext4 encryption, potential memory leaks after truncate in data=journal mode, and an ocfs2 regression caused by a jbd2 performance improvement" * tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: jbd2: fix null committed data return in undo_access ext4: add "static" to ext4_seq_##name##_fops struct ext4: fix an endianness bug in ext4_encrypted_follow_link() ext4: fix an endianness bug in ext4_encrypted_zeroout() jbd2: Fix unreclaimed pages after truncate in data=journal mode ext4: Fix handling of extended tv_sec
2015-12-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "A couple of fixes (-stable fodder) + dead code removal after the overlayfs fix. I agree that it's better to separate from the fix part to make backporting easier, but IMO it's not worth delaying said dead code removal until the next window" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: Don't reset ->total_link_count on nested calls of vfs_path_lookup() ovl: get rid of the dead code left from broken (and disabled) optimizations ovl: fix permission checking for setattr
2015-12-06Don't reset ->total_link_count on nested calls of vfs_path_lookup()Al Viro
we already zero it on outermost set_nameidata(), so initialization in path_init() is pointless and wrong. The same DoS exists on pre-4.2 kernels, but there a slightly different fix will be needed. Cc: stable@vger.kernel.org # v4.2 Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-06ovl: get rid of the dead code left from broken (and disabled) optimizationsAl Viro
2015-12-06ovl: fix permission checking for setattrMiklos Szeredi
[Al Viro] The bug is in being too enthusiastic about optimizing ->setattr() away - instead of "copy verbatim with metadata" + "chmod/chown/utimes" (with the former being always safe and the latter failing in case of insufficient permissions) it tries to combine these two. Note that copyup itself will have to do ->setattr() anyway; _that_ is where the elevated capabilities are right. Having these two ->setattr() (one to set verbatim copy of metadata, another to do what overlayfs ->setattr() had been asked to do in the first place) combined is where it breaks. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: <stable@vger.kernel.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-04block: detach bdev inode from its wb in __blkdev_put()Ilya Dryomov
Since 52ebea749aae ("writeback: make backing_dev_info host cgroup-specific bdi_writebacks") inode, at some point in its lifetime, gets attached to a wb (struct bdi_writeback). Detaching happens on evict, in inode_detach_wb() called from __destroy_inode(), and involves updating wb. However, detaching an internal bdev inode from its wb in __destroy_inode() is too late. Its bdi and by extension root wb are embedded into struct request_queue, which has different lifetime rules and can be freed long before the final bdput() is called (can be from __fput() of a corresponding /dev inode, through dput() - evict() - bd_forget(). bdevs hold onto the underlying disk/queue pair only while opened; as soon as bdev is closed all bets are off. In fact, disk/queue can be gone before __blkdev_put() even returns: 1499 static void __blkdev_put(struct block_device *bdev, fmode_t mode, int for_part) 1500 { ... 1518 if (bdev->bd_contains == bdev) { 1519 if (disk->fops->release) 1520 disk->fops->release(disk, mode); [ Driver puts its references to disk/queue ] 1521 } 1522 if (!bdev->bd_openers) { 1523 struct module *owner = disk->fops->owner; 1524 1525 disk_put_part(bdev->bd_part); 1526 bdev->bd_part = NULL; 1527 bdev->bd_disk = NULL; 1528 if (bdev != bdev->bd_contains) 1529 victim = bdev->bd_contains; 1530 bdev->bd_contains = NULL; 1531 1532 put_disk(disk); [ We put ours, the queue is gone The last bdput() would result in a write to invalid memory ] 1533 module_put(owner); ... 1539 } Since bdev inodes are special anyway, detach them in __blkdev_put() after clearing inode's dirty bits, turning the problematic inode_detach_wb() in __destroy_inode() into a noop. add_disk() grabs its disk->queue since 523e1d399ce0 ("block: make gendisk hold a reference to its queue"), so the old ->release comment is removed in favor of the new inode_detach_wb() comment. Cc: stable@vger.kernel.org # 4.2+, needs backporting Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Tested-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-12-04jbd2: fix null committed data return in undo_accessJunxiao Bi
introduced jbd2_write_access_granted() to improve write|undo_access speed, but missed to check the status of b_committed_data which caused a kernel panic on ocfs2. [ 6538.405938] ------------[ cut here ]------------ [ 6538.406686] kernel BUG at fs/ocfs2/suballoc.c:2400! [ 6538.406686] invalid opcode: 0000 [#1] SMP [ 6538.406686] Modules linked in: ocfs2 nfsd lockd grace nfs_acl auth_rpcgss sunrpc autofs4 ocfs2_dlmfs ocfs2_stack_o2cb ocfs2_dlm ocfs2_nodemanager ocfs2_stackglue configfs sd_mod sg ip6t_REJECT nf_reject_ipv6 nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables be2iscsi iscsi_boot_sysfs bnx2i cnic uio cxgb4i cxgb4 cxgb3i libcxgbi cxgb3 mdio ib_iser rdma_cm ib_cm iw_cm ib_sa ib_mad ib_core ib_addr ipv6 iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi ppdev xen_kbdfront xen_netfront xen_fbfront parport_pc parport pcspkr i2c_piix4 acpi_cpufreq ext4 jbd2 mbcache xen_blkfront floppy pata_acpi ata_generic ata_piix cirrus ttm drm_kms_helper drm fb_sys_fops sysimgblt sysfillrect i2c_core syscopyarea dm_mirror dm_region_hash dm_log dm_mod [ 6538.406686] CPU: 1 PID: 16265 Comm: mmap_truncate Not tainted 4.3.0 #1 [ 6538.406686] Hardware name: Xen HVM domU, BIOS 4.3.1OVM 05/14/2014 [ 6538.406686] task: ffff88007c2bab00 ti: ffff880075b78000 task.ti: ffff880075b78000 [ 6538.406686] RIP: 0010:[<ffffffffa06a286b>] [<ffffffffa06a286b>] ocfs2_block_group_clear_bits+0x23b/0x250 [ocfs2] [ 6538.406686] RSP: 0018:ffff880075b7b7f8 EFLAGS: 00010246 [ 6538.406686] RAX: ffff8800760c5b40 RBX: ffff88006c06a000 RCX: ffffffffa06e6df0 [ 6538.406686] RDX: 0000000000000000 RSI: ffff88007a6f6ea0 RDI: ffff88007a760430 [ 6538.406686] RBP: ffff880075b7b878 R08: 0000000000000002 R09: 0000000000000001 [ 6538.406686] R10: ffffffffa06769be R11: 0000000000000000 R12: 0000000000000001 [ 6538.406686] R13: ffffffffa06a1750 R14: 0000000000000001 R15: ffff88007a6f6ea0 [ 6538.406686] FS: 00007f17fde30720(0000) GS:ffff88007f040000(0000) knlGS:0000000000000000 [ 6538.406686] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 6538.406686] CR2: 0000000000601730 CR3: 000000007aea0000 CR4: 00000000000406e0 [ 6538.406686] Stack: [ 6538.406686] ffff88007c2bb5b0 ffff880075b7b8e0 ffff88007a7604b0 ffff88006c640800 [ 6538.406686] ffff88007a7604b0 ffff880075d77390 0000000075b7b878 ffffffffa06a309d [ 6538.406686] ffff880075d752d8 ffff880075b7b990 ffff880075b7b898 0000000000000000 [ 6538.406686] Call Trace: [ 6538.406686] [<ffffffffa06a309d>] ? ocfs2_read_group_descriptor+0x6d/0xa0 [ocfs2] [ 6538.406686] [<ffffffffa06a3654>] _ocfs2_free_suballoc_bits+0xe4/0x320 [ocfs2] [ 6538.406686] [<ffffffffa06a1750>] ? ocfs2_put_slot+0xf0/0xf0 [ocfs2] [ 6538.406686] [<ffffffffa06a397e>] _ocfs2_free_clusters+0xee/0x210 [ocfs2] [ 6538.406686] [<ffffffffa06a1750>] ? ocfs2_put_slot+0xf0/0xf0 [ocfs2] [ 6538.406686] [<ffffffffa06a1750>] ? ocfs2_put_slot+0xf0/0xf0 [ocfs2] [ 6538.406686] [<ffffffffa0682d50>] ? ocfs2_extend_trans+0x50/0x1a0 [ocfs2] [ 6538.406686] [<ffffffffa06a3ad5>] ocfs2_free_clusters+0x15/0x20 [ocfs2] [ 6538.406686] [<ffffffffa065072c>] ocfs2_replay_truncate_records+0xfc/0x290 [ocfs2] [ 6538.406686] [<ffffffffa06843ac>] ? ocfs2_start_trans+0xec/0x1d0 [ocfs2] [ 6538.406686] [<ffffffffa0654600>] __ocfs2_flush_truncate_log+0x140/0x2d0 [ocfs2] [ 6538.406686] [<ffffffffa0654394>] ? ocfs2_reserve_blocks_for_rec_trunc.clone.0+0x44/0x170 [ocfs2] [ 6538.406686] [<ffffffffa065acd4>] ocfs2_remove_btree_range+0x374/0x630 [ocfs2] [ 6538.406686] [<ffffffffa017486b>] ? jbd2_journal_stop+0x25b/0x470 [jbd2] [ 6538.406686] [<ffffffffa065d5b5>] ocfs2_commit_truncate+0x305/0x670 [ocfs2] [ 6538.406686] [<ffffffffa0683430>] ? ocfs2_journal_access_eb+0x20/0x20 [ocfs2] [ 6538.406686] [<ffffffffa067adb7>] ocfs2_truncate_file+0x297/0x380 [ocfs2] [ 6538.406686] [<ffffffffa01759e4>] ? jbd2_journal_begin_ordered_truncate+0x64/0xc0 [jbd2] [ 6538.406686] [<ffffffffa067c7a2>] ocfs2_setattr+0x572/0x860 [ocfs2] [ 6538.406686] [<ffffffff810e4a3f>] ? current_fs_time+0x3f/0x50 [ 6538.406686] [<ffffffff812124b7>] notify_change+0x1d7/0x340 [ 6538.406686] [<ffffffff8121abf9>] ? generic_getxattr+0x79/0x80 [ 6538.406686] [<ffffffff811f5876>] do_truncate+0x66/0x90 [ 6538.406686] [<ffffffff81120e30>] ? __audit_syscall_entry+0xb0/0x110 [ 6538.406686] [<ffffffff811f5bb3>] do_sys_ftruncate.clone.0+0xf3/0x120 [ 6538.406686] [<ffffffff811f5bee>] SyS_ftruncate+0xe/0x10 [ 6538.406686] [<ffffffff816aa2ae>] entry_SYSCALL_64_fastpath+0x12/0x71 [ 6538.406686] Code: 28 48 81 ee b0 04 00 00 48 8b 92 50 fb ff ff 48 8b 80 b0 03 00 00 48 39 90 88 00 00 00 0f 84 30 fe ff ff 0f 0b eb fe 0f 0b eb fe <0f> 0b 0f 1f 00 eb fb 66 66 66 66 66 2e 0f 1f 84 00 00 00 00 00 [ 6538.406686] RIP [<ffffffffa06a286b>] ocfs2_block_group_clear_bits+0x23b/0x250 [ocfs2] [ 6538.406686] RSP <ffff880075b7b7f8> [ 6538.691128] ---[ end trace 31cd7011d6770d7e ]--- [ 6538.694492] Kernel panic - not syncing: Fatal exception [ 6538.695484] Kernel Offset: disabled Fixes: de92c8caf16c("jbd2: speedup jbd2_journal_get_[write|undo]_access()") Cc: <stable@vger.kernel.org> Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2015-12-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "A lot of Thanksgiving turkey leftovers accumulated, here goes: 1) Fix bluetooth l2cap_chan object leak, from Johan Hedberg. 2) IDs for some new iwlwifi chips, from Oren Givon. 3) Fix rtlwifi lockups on boot, from Larry Finger. 4) Fix memory leak in fm10k, from Stephen Hemminger. 5) We have a route leak in the ipv6 tunnel infrastructure, fix from Paolo Abeni. 6) Fix buffer pointer handling in arm64 bpf JIT,f rom Zi Shen Lim. 7) Wrong lockdep annotations in tcp md5 support, fix from Eric Dumazet. 8) Work around some middle boxes which prevent proper handling of TCP Fast Open, from Yuchung Cheng. 9) TCP repair can do huge kmalloc() requests, build paged SKBs instead. From Eric Dumazet. 10) Fix msg_controllen overflow in scm_detach_fds, from Daniel Borkmann. 11) Fix device leaks on ipmr table destruction in ipv4 and ipv6, from Nikolay Aleksandrov. 12) Fix use after free in epoll with AF_UNIX sockets, from Rainer Weikusat. 13) Fix double free in VRF code, from Nikolay Aleksandrov. 14) Fix skb leaks on socket receive queue in tipc, from Ying Xue. 15) Fix ifup/ifdown crach in xgene driver, from Iyappan Subramanian. 16) Fix clearing of persistent array maps in bpf, from Daniel Borkmann. 17) In TCP, for the cross-SYN case, we don't initialize tp->copied_seq early enough. From Eric Dumazet. 18) Fix out of bounds accesses in bpf array implementation when updating elements, from Daniel Borkmann. 19) Fill gaps in RCU protection of np->opt in ipv6 stack, from Eric Dumazet. 20) When dumping proxy neigh entries, we have to accomodate NULL device pointers properly, from Konstantin Khlebnikov. 21) SCTP doesn't release all ipv6 socket resources properly, fix from Eric Dumazet. 22) Prevent underflows of sch->q.qlen for multiqueue packet schedulers, also from Eric Dumazet. 23) Fix MAC and unicast list handling in bnxt_en driver, from Jeffrey Huang and Michael Chan. 24) Don't actively scan radar channels, from Antonio Quartulli" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (110 commits) net: phy: reset only targeted phy bnxt_en: Setup uc_list mac filters after resetting the chip. bnxt_en: enforce proper storing of MAC address bnxt_en: Fixed incorrect implementation of ndo_set_mac_address net: lpc_eth: remove irq > NR_IRQS check from probe() net_sched: fix qdisc_tree_decrease_qlen() races openvswitch: fix hangup on vxlan/gre/geneve device deletion ipv4: igmp: Allow removing groups from a removed interface ipv6: sctp: implement sctp_v6_destroy_sock() arm64: bpf: add 'store immediate' instruction ipv6: kill sk_dst_lock ipv6: sctp: add rcu protection around np->opt net/neighbour: fix crash at dumping device-agnostic proxy entries sctp: use GFP_USER for user-controlled kmalloc sctp: convert sack_needed and sack_generation to bits ipv6: add complete rcu protection around np->opt bpf: fix allocation warnings in bpf maps and integer overflow mvebu: dts: enable IP checksum with jumbo frames for Armada 38x on Port0 net: mvneta: enable setting custom TX IP checksum limit net: mvneta: fix error path for building skb ...
2015-12-03Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block fixes from Jens Axboe: "A collection of fixes from this series. The most important here is a regression fix for an issue that some folks would hit in blk-merge.c, and the NVMe queue depth limit for the screwed up Apple "nvme" controller. In more detail, this pull request contains: - a set of fixes for null_blk, including a fix for a few corner cases where we could hang the device. From Arianna and Paolo. - lightnvm: - A build improvement from Keith. - Update the qemu pci id detection from Matias. - Error handling fixes for leaks and other little fixes from Sudip and Wenwei. - fix from Eric where BLKRRPART would not return EBUSY for whole device mounts, only when partitions were mounted. - fix from Jan Kara, where EOF O_DIRECT reads would return negatively. - remove check for rq_mergeable() when checking limits for cloned requests. The check doesn't make any sense. It's assuming that since NOMERGE is set on the request that we don't have to recalculate limits since the request didn't change, but that's not true if the request has been redirected. From Hannes. - correctly get the bio front segment value set for single segment bio's, fixing a BUG() in blk-merge. From Ming" * 'for-linus' of git://git.kernel.dk/linux-block: nvme: temporary fix for Apple controller reset null_blk: change type of completion_nsec to unsigned long null_blk: guarantee device restart in all irq modes null_blk: set a separate timer for each command blk-merge: fix computing bio->bi_seg_front_size in case of single segment direct-io: Fix negative return from dio read beyond eof block: Always check queue limits for cloned requests lightnvm: missing nvm_lock acquire lightnvm: unconverted ppa returned in get_bb_tbl lightnvm: refactor and change vendor id for qemu lightnvm: do device max sectors boundary check first lightnvm: fix ioctl memory leaks lightnvm: free memory when gennvm register fails lightnvm: Simplify config when disabled Return EBUSY from BLKRRPART for mounted whole-dev fs
2015-12-01net: rename SOCK_ASYNC_NOSPACE and SOCK_ASYNC_WAITDATAEric Dumazet
This patch is a cleanup to make following patch easier to review. Goal is to move SOCK_ASYNC_NOSPACE and SOCK_ASYNC_WAITDATA from (struct socket)->flags to a (struct socket_wq)->flags to benefit from RCU protection in sock_wake_async() To ease backports, we rename both constants. Two new helpers, sk_set_bit(int nr, struct sock *sk) and sk_clear_bit(int net, struct sock *sk) are added so that following patch can change their implementation. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-30direct-io: Fix negative return from dio read beyond eofJan Kara
Assume a filesystem with 4KB blocks. When a file has size 1000 bytes and we issue direct IO read at offset 1024, blockdev_direct_IO() reads the tail of the last block and the logic for handling short DIO reads in dio_complete() results in a return value -24 (1000 - 1024) which obviously confuses userspace. Fix the problem by bailing out early once we sample i_size and can reliably check that direct IO read starts beyond i_size. Reported-by: Avi Kivity <avi@scylladb.com> Fixes: 9fe55eea7e4b444bafc42fa0000cc2d1d2847275 CC: stable@vger.kernel.org CC: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-11-27Merge tag 'nfs-for-4.4-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "Highlights include: Stable patches: - Fix a NFSv4 callback identifier leak that was also causing client crashes - Fix NFSv4 callback decoding issues when incoming requests are truncated - Don't declare the attribute cache valid when we call nfs_update_inode with an empty attribute structure. - Resend LAYOUTGET when there is a race that changes the seqid Bugfixes: - Fix a number of issues with the NFSv4.2 CLONE ioctl() - Properly set NFS v4.2 NFSDBG_FACILITY - NFSv4 referrals are broken; Cleanup FATTR4_WORD0_FS_LOCATIONS after decoding success - Use sliding delay when LAYOUTGET gets NFS4ERR_DELAY - Ensure that attrcache is revalidated after a SETATTR" * tag 'nfs-for-4.4-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: nfs4: resend LAYOUTGET when there is a race that changes the seqid nfs: if we have no valid attrs, then don't declare the attribute cache valid nfs: ensure that attrcache is revalidated after a SETATTR nfs4: limit callback decoding to received bytes nfs4: start callback_ident at idr 1 nfs: use sliding delay when LAYOUTGET gets NFS4ERR_DELAY NFS4: Cleanup FATTR4_WORD0_FS_LOCATIONS after decoding success NFS: Properly set NFS v4.2 NFSDBG_FACILITY nfs: reduce the amount of ifdefs for v4.2 in nfs4file.c nfs: use btrfs ioctl defintions for clone nfs: allow intra-file CLONE nfs: offer native ioctls even if CONFIG_COMPAT is set nfs: pass on count for CLONE operations
2015-11-27Merge branch 'for-linus-4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "This has Mark Fasheh's patches to fix quota accounting during subvol deletion, which we've been working on for a while now. The patch is pretty small but it's a key fix. Otherwise it's a random assortment" * 'for-linus-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: btrfs: fix balance range usage filters in 4.4-rc btrfs: qgroup: account shared subtree during snapshot delete Btrfs: use btrfs_get_fs_root in resolve_indirect_ref btrfs: qgroup: fix quota disable during rescan Btrfs: fix race between cleaner kthread and space cache writeout Btrfs: fix scrub preventing unused block groups from being deleted Btrfs: fix race between scrub and block group deletion btrfs: fix rcu warning during device replace btrfs: Continue replace when set_block_ro failed btrfs: fix clashing number of the enhanced balance usage filter Btrfs: fix the number of transaction units needed to remove a block group Btrfs: use global reserve when deleting unused block group after ENOSPC Btrfs: tests: checking for NULL instead of IS_ERR() btrfs: fix signed overflows in btrfs_sync_file
2015-11-26ext4: add "static" to ext4_seq_##name##_fops structXu Cang
to fix sparse warning, add static to ext4_seq_##name##_fops struct. Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2015-11-26ext4: fix an endianness bug in ext4_encrypted_follow_link()Al Viro
applying le32_to_cpu() to 16bit value is a bad idea... Cc: stable@vger.kernel.org # v4.1+ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2015-11-26ext4: fix an endianness bug in ext4_encrypted_zeroout()Al Viro
ex->ee_block is not host-endian (note that accesses of other fields of *ex right next to that line go through the helpers that do proper conversion from little-endian to host-endian; it might make sense to add similar for ->ee_block to avoid reintroducing that kind of bugs...) Cc: stable@vger.kernel.org # v4.1+ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2015-11-25nfs4: resend LAYOUTGET when there is a race that changes the seqidJeff Layton
pnfs_layout_process will check the returned layout stateid against what the kernel has in-core. If it turns out that the stateid we received is older, then we should resend the LAYOUTGET instead of falling back to MDS I/O. Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Cc: stable@vger.kernel.org # 3.18+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-11-25nfs: if we have no valid attrs, then don't declare the attribute cache validJeff Layton
If we pass in an empty nfs_fattr struct to nfs_update_inode, it will (correctly) not update any of the attributes, but it then clears the NFS_INO_INVALID_ATTR flag, which indicates that the attributes are up to date. Don't clear the flag if the fattr struct has no valid attrs to apply. Reviewed-by: Steve French <steve.french@primarydata.com> Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Cc: stable@vger.kernel.org Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-11-25nfs: ensure that attrcache is revalidated after a SETATTRJeff Layton
If we get no post-op attributes back from a SETATTR operation, then no attributes will of course be updated during the call to nfs_update_inode. We know however that the attributes are invalid at that point, since we just changed some of them. At the very least, the ctime will be bogus. If we get no post-op attributes back on the call, mark the attrcache invalid to reflect that fact. Reviewed-by: Steve French <steve.french@primarydata.com> Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-11-25btrfs: fix balance range usage filters in 4.4-rcHolger Hoffstätte
There's a regression in 4.4-rc since commit bc3094673f22 (btrfs: extend balance filter usage to take minimum and maximum) in that existing (non-ranged) balance with -dusage=x no longer works; all chunks are skipped. After staring at the code for a while and wondering why a non-ranged balance would even need min and max thresholds (..which then were not set correctly, leading to the bug) I realized that the only problem was the fact that the filter functions were named wrong, thanks to patching copypasta. Simply renaming both functions lets the existing btrfs-progs call balance with -dusage=x and now the non-ranged filter function is invoked, properly using only a single chunk limit. Signed-off-by: Holger Hoffstätte <holger.hoffstaette@googlemail.com> Fixes: bc3094673f22 ("btrfs: extend balance filter usage to take minimum and maximum") Reviewed-by: Filipe Manana <fdmanana@suse.com> Signed-off-by: Chris Mason <clm@fb.com>
2015-11-25btrfs: qgroup: account shared subtree during snapshot deleteMark Fasheh
Commit 0ed4792 ('btrfs: qgroup: Switch to new extent-oriented qgroup mechanism.') removed our qgroup accounting during btrfs_drop_snapshot(). Predictably, this results in qgroup numbers going bad shortly after a snapshot is removed. Fix this by adding a dirty extent record when we encounter extents during our shared subtree walk. This effectively restores the functionality we had with the original shared subtree walking code in 1152651 (btrfs: qgroup: account shared subtrees during snapshot delete). The idea with the original patch (and this one) is that shared subtrees can get skipped during drop_snapshot. The shared subtree walk then allows us a chance to visit those extents and add them to the qgroup work for later processing. This ultimately makes the accounting for drop snapshot work. The new qgroup code nicely handles all the other extents during the tree walk via the ref dec/inc functions so we don't have to add actions beyond what we had originally. Signed-off-by: Mark Fasheh <mfasheh@suse.de> Signed-off-by: Chris Mason <clm@fb.com>
2015-11-25Btrfs: use btrfs_get_fs_root in resolve_indirect_refJosef Bacik
The backref code will look up the fs_root we're trying to resolve our indirect refs for, unfortunately we use btrfs_read_fs_root_no_name, which returns -ENOENT if the ref is 0. This isn't helpful for the qgroup stuff with snapshot delete as it won't be able to search down the snapshot we are deleting, which will cause us to miss roots. So use btrfs_get_fs_root and send false for check_ref so we can always get the root we're looking for. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Mark Fasheh <mfasheh@suse.de> Signed-off-by: Chris Mason <clm@fb.com>
2015-11-25btrfs: qgroup: fix quota disable during rescanJustin Maggard
There's a race condition that leads to a NULL pointer dereference if you disable quotas while a quota rescan is running. To fix this, we just need to wait for the quota rescan worker to actually exit before tearing down the quota structures. Signed-off-by: Justin Maggard <jmaggard@netgear.com> Signed-off-by: Chris Mason <clm@fb.com>
2015-11-25Btrfs: fix race between cleaner kthread and space cache writeoutFilipe Manana
When a block group becomes unused and the cleaner kthread is currently running, we can end up getting the current transaction aborted with error -ENOENT when we try to commit the transaction, leading to the following trace: [59779.258768] WARNING: CPU: 3 PID: 5990 at fs/btrfs/extent-tree.c:3740 btrfs_write_dirty_block_groups+0x17c/0x214 [btrfs]() [59779.272594] BTRFS: Transaction aborted (error -2) (...) [59779.291137] Call Trace: [59779.291621] [<ffffffff812566f4>] dump_stack+0x4e/0x79 [59779.292543] [<ffffffff8104d0a6>] warn_slowpath_common+0x9f/0xb8 [59779.293435] [<ffffffffa04cb81f>] ? btrfs_write_dirty_block_groups+0x17c/0x214 [btrfs] [59779.295000] [<ffffffff8104d107>] warn_slowpath_fmt+0x48/0x50 [59779.296138] [<ffffffffa04c2721>] ? write_one_cache_group.isra.32+0x77/0x82 [btrfs] [59779.297663] [<ffffffffa04cb81f>] btrfs_write_dirty_block_groups+0x17c/0x214 [btrfs] [59779.299141] [<ffffffffa0549b0d>] commit_cowonly_roots+0x1de/0x261 [btrfs] [59779.300359] [<ffffffffa04dd5b6>] btrfs_commit_transaction+0x4c4/0x99c [btrfs] [59779.301805] [<ffffffffa04b5df4>] btrfs_sync_fs+0x145/0x1ad [btrfs] [59779.302893] [<ffffffff81196634>] sync_filesystem+0x7f/0x93 (...) [59779.318186] ---[ end trace 577e2daff90da33a ]--- The following diagram illustrates a sequence of steps leading to this problem: CPU 1 CPU 2 <at transaction N> adds bg A to list fs_info->unused_bgs adds bg B to list fs_info->unused_bgs <transaction kthread commits transaction N and wakes up the cleaner kthread> cleaner kthread delete_unused_bgs() sees bg A in list fs_info->unused_bgs btrfs_start_transaction() <transaction N + 1 starts> deletes bg A update_block_group(bg C) --> adds bg C to list fs_info->unused_bgs deletes bg B sees bg C in the list fs_info->unused_bgs btrfs_remove_chunk(bg C) btrfs_remove_block_group(bg C) --> checks if the block group is in a dirty list, and because it isn't now, it does nothing --> the block group item is deleted from the extent tree --> adds bg C to list transaction->dirty_bgs some task calls btrfs_commit_transaction(t N + 1) commit_cowonly_roots() btrfs_write_dirty_block_groups() --> sees bg C in cur_trans->dirty_bgs --> calls write_one_cache_group() which returns -ENOENT because it did not find the block group item in the extent tree --> transaction aborte with -ENOENT because write_one_cache_group() returned that error So fix this by adding a block group to the list of dirty block groups before adding it to the list of unused block groups. This happened on a stress test using fsstress plus concurrent calls to fallocate 20G and truncate (releasing part of the space allocated with fallocate). Signed-off-by: Filipe Manana <fdmanana@suse.com> Signed-off-by: Chris Mason <clm@fb.com>
2015-11-25Btrfs: fix scrub preventing unused block groups from being deletedFilipe Manana
Currently scrub can race with the cleaner kthread when the later attempts to delete an unused block group, and the result is preventing the cleaner kthread from ever deleting later the block group - unless the block group becomes used and unused again. The following diagram illustrates that race: CPU 1 CPU 2 cleaner kthread btrfs_delete_unused_bgs() gets block group X from fs_info->unused_bgs and removes it from that list scrub_enumerate_chunks() searches device tree using its commit root finds device extent for block group X gets block group X from the tree fs_info->block_group_cache_tree (via btrfs_lookup_block_group()) sets bg X to RO sees the block group is already RO and therefore doesn't delete it nor adds it back to unused list So fix this by making scrub add the block group again to the list of unused block groups if the block group is still unused when it finished scrubbing it and it hasn't been removed already. Signed-off-by: Filipe Manana <fdmanana@suse.com> Signed-off-by: Chris Mason <clm@fb.com>
2015-11-25Btrfs: fix race between scrub and block group deletionFilipe Manana
Scrub can race with the cleaner kthread deleting block groups that are unused (and with relocation too) leading to a failure with error -EINVAL that gets returned to user space. The following diagram illustrates how it happens: CPU 1 CPU 2 cleaner kthread btrfs_delete_unused_bgs() gets block group X from fs_info->unused_bgs sets block group to RO btrfs_remove_chunk(bg X) deletes device extents scrub_enumerate_chunks() searches device tree using its commit root finds device extent for block group X gets block group X from the tree fs_info->block_group_cache_tree (via btrfs_lookup_block_group()) sets bg X to RO (again) btrfs_remove_block_group(bg X) deletes block group from fs_info->block_group_cache_tree removes extent map from fs_info->mapping_tree scrub_chunk(offset X) searches fs_info->mapping_tree for extent map starting at offset X --> doesn't find any such extent map --> returns -EINVAL and scrub errors out to userspace with -EINVAL Fix this by dealing with an extent map lookup failure as an indicator of block group deletion. Issue reproduced with fstest btrfs/071. Signed-off-by: Filipe Manana <fdmanana@suse.com> Signed-off-by: Chris Mason <clm@fb.com>
2015-11-25btrfs: fix rcu warning during device replaceDavid Sterba
The test btrfs/011 triggers a rcu warning Reviewed-by: Anand Jain <anand.jain@oracle.com> =============================== [ INFO: suspicious RCU usage. ] 4.4.0-rc1-default+ #286 Tainted: G W ------------------------------- fs/btrfs/volumes.c:1977 suspicious rcu_dereference_check() usage! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 4 locks held by btrfs/28786: 0: (&fs_info->dev_replace.lock_finishing_cancel_unmount){+.+...}, at: [<ffffffffa00bc785>] btrfs_dev_replace_finishing+0x45/0xa00 [btrfs] 1: (uuid_mutex){+.+.+.}, at: [<ffffffffa00bc84f>] btrfs_dev_replace_finishing+0x10f/0xa00 [btrfs] 2: (&fs_devs->device_list_mutex){+.+.+.}, at: [<ffffffffa00bc868>] btrfs_dev_replace_finishing+0x128/0xa00 [btrfs] 3: (&fs_info->chunk_mutex){+.+...}, at: [<ffffffffa00bc87d>] btrfs_dev_replace_finishing+0x13d/0xa00 [btrfs] stack backtrace: CPU: 0 PID: 28786 Comm: btrfs Tainted: G W 4.4.0-rc1-default+ #286 Hardware name: Intel Corporation SandyBridge Platform/To be filled by O.E.M., BIOS ASNBCPT1.86C.0031.B00.1006301607 06/30/2010 0000000000000001 ffff8800a07dfb48 ffffffff8141d47b 0000000000000001 0000000000000001 0000000000000000 ffff8801464a4f00 ffff8800a07dfb78 ffffffff810cd883 ffff880146eb9400 ffff8800a3698600 ffff8800a33fe220 Call Trace: [<ffffffff8141d47b>] dump_stack+0x4f/0x74 [<ffffffff810cd883>] lockdep_rcu_suspicious+0x103/0x140 [<ffffffffa0071261>] btrfs_rm_dev_replace_remove_srcdev+0x111/0x130 [btrfs] [<ffffffff810d354d>] ? trace_hardirqs_on+0xd/0x10 [<ffffffff81449536>] ? __percpu_counter_sum+0x66/0x80 [<ffffffffa00bcc15>] btrfs_dev_replace_finishing+0x4d5/0xa00 [btrfs] [<ffffffffa00bc96e>] ? btrfs_dev_replace_finishing+0x22e/0xa00 [btrfs] [<ffffffffa00a8795>] ? btrfs_scrub_dev+0x415/0x6d0 [btrfs] [<ffffffffa003ea69>] ? btrfs_start_transaction+0x9/0x20 [btrfs] [<ffffffffa00bda79>] btrfs_dev_replace_start+0x339/0x590 [btrfs] [<ffffffff81196aa5>] ? __might_fault+0x95/0xa0 [<ffffffffa0078638>] btrfs_ioctl_dev_replace+0x118/0x160 [btrfs] [<ffffffff811409c6>] ? stack_trace_call+0x46/0x70 [<ffffffffa007c914>] ? btrfs_ioctl+0x24/0x1770 [btrfs] [<ffffffffa007ce43>] btrfs_ioctl+0x553/0x1770 [btrfs] [<ffffffff811409c6>] ? stack_trace_call+0x46/0x70 [<ffffffff811d6eb1>] ? do_vfs_ioctl+0x21/0x5a0 [<ffffffff811d6f1c>] do_vfs_ioctl+0x8c/0x5a0 [<ffffffff811e3336>] ? __fget_light+0x86/0xb0 [<ffffffff811e3369>] ? __fdget+0x9/0x20 [<ffffffff811d7451>] ? SyS_ioctl+0x21/0x80 [<ffffffff811d7483>] SyS_ioctl+0x53/0x80 [<ffffffff81b1efd7>] entry_SYSCALL_64_fastpath+0x12/0x6f This is because of unprotected use of rcu_dereference in btrfs_scratch_superblocks. We can't add rcu locks around the whole function because we read the superblock. The fix will use the rcu string buffer directly without the rcu locking. Thi is safe as the device will not go away in the meantime. We're holding the device list mutexes. Restructuring the code to narrow down the rcu section turned out to be impossible, we need to call filp_open (through update_dev_time) on the buffer and this could call kmalloc/__might_sleep. We could call kstrdup with GFP_ATOMIC but it's not absolutely necessary. Fixes: 12b1c2637b6e (Btrfs: enhance btrfs_scratch_superblock to scratch all superblocks) Signed-off-by: David Sterba <dsterba@suse.com> Signed-off-by: Chris Mason <clm@fb.com>
2015-11-25btrfs: Continue replace when set_block_ro failedZhaolei
xfstests/011 failed in node with small_size filesystem. Can be reproduced by following script: DEV_LIST="/dev/vdd /dev/vde" DEV_REPLACE="/dev/vdf" do_test() { local mkfs_opt="$1" local size="$2" dmesg -c >/dev/null umount $SCRATCH_MNT &>/dev/null echo mkfs.btrfs -f $mkfs_opt "${DEV_LIST[*]}" mkfs.btrfs -f $mkfs_opt "${DEV_LIST[@]}" || return 1 mount "${DEV_LIST[0]}" $SCRATCH_MNT echo -n "Writing big files" dd if=/dev/urandom of=$SCRATCH_MNT/t0 bs=1M count=1 >/dev/null 2>&1 for ((i = 1; i <= size; i++)); do echo -n . /bin/cp $SCRATCH_MNT/t0 $SCRATCH_MNT/t$i || return 1 done echo echo Start replace btrfs replace start -Bf "${DEV_LIST[0]}" "$DEV_REPLACE" $SCRATCH_MNT || { dmesg return 1 } return 0 } # Set size to value near fs size # for example, 1897 can trigger this bug in 2.6G device. # ./do_test "-d raid1 -m raid1" 1897 System will report replace fail with following warning in dmesg: [ 134.710853] BTRFS: dev_replace from /dev/vdd (devid 1) to /dev/vdf started [ 135.542390] BTRFS: btrfs_scrub_dev(/dev/vdd, 1, /dev/vdf) failed -28 [ 135.543505] ------------[ cut here ]------------ [ 135.544127] WARNING: CPU: 0 PID: 4080 at fs/btrfs/dev-replace.c:428 btrfs_dev_replace_start+0x398/0x440() [ 135.545276] Modules linked in: [ 135.545681] CPU: 0 PID: 4080 Comm: btrfs Not tainted 4.3.0 #256 [ 135.546439] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.8.2-0-g33fbe13 by qemu-project.org 04/01/2014 [ 135.547798] ffffffff81c5bfcf ffff88003cbb3d28 ffffffff817fe7b5 0000000000000000 [ 135.548774] ffff88003cbb3d60 ffffffff810a88f1 ffff88002b030000 00000000ffffffe4 [ 135.549774] ffff88003c080000 ffff88003c082588 ffff88003c28ab60 ffff88003cbb3d70 [ 135.550758] Call Trace: [ 135.551086] [<ffffffff817fe7b5>] dump_stack+0x44/0x55 [ 135.551737] [<ffffffff810a88f1>] warn_slowpath_common+0x81/0xc0 [ 135.552487] [<ffffffff810a89e5>] warn_slowpath_null+0x15/0x20 [ 135.553211] [<ffffffff81448c88>] btrfs_dev_replace_start+0x398/0x440 [ 135.554051] [<ffffffff81412c3e>] btrfs_ioctl+0x1d2e/0x25c0 [ 135.554722] [<ffffffff8114c7ba>] ? __audit_syscall_entry+0xaa/0xf0 [ 135.555506] [<ffffffff8111ab36>] ? current_kernel_time64+0x56/0xa0 [ 135.556304] [<ffffffff81201e3d>] do_vfs_ioctl+0x30d/0x580 [ 135.557009] [<ffffffff8114c7ba>] ? __audit_syscall_entry+0xaa/0xf0 [ 135.557855] [<ffffffff810011d1>] ? do_audit_syscall_entry+0x61/0x70 [ 135.558669] [<ffffffff8120d1c1>] ? __fget_light+0x61/0x90 [ 135.559374] [<ffffffff81202124>] SyS_ioctl+0x74/0x80 [ 135.559987] [<ffffffff81809857>] entry_SYSCALL_64_fastpath+0x12/0x6f [ 135.560842] ---[ end trace 2a5c1fc3205abbdd ]--- Reason: When big data writen to fs, the whole free space will be allocated for data chunk. And operation as scrub need to set_block_ro(), and when there is only one metadata chunk in system(or other metadata chunks are all full), the function will try to allocate a new chunk, and failed because no space in device. Fix: When set_block_ro failed for metadata chunk, it is not a problem because scrub_lock paused commit_trancaction in same time, and metadata are always cowed, so the on-the-fly writepages will not write data into same place with scrub/replace. Let replace continue in this case is no problem. Tested by above script, and xfstests/011, plus 100 times xfstests/070. Changelog v1->v2: 1: Add detail comments in source and commit-message. 2: Add dmesg detail into commit-message. 3: Limit return value of -ENOSPC to be passed. All suggested by: Filipe Manana <fdmanana@gmail.com> Suggested-by: Filipe Manana <fdmanana@gmail.com> Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com> Signed-off-by: Chris Mason <clm@fb.com>
2015-11-25btrfs: fix clashing number of the enhanced balance usage filterDavid Sterba
I've accidentally picked an already used number for the enhanced usage filter represented by BTRFS_BALANCE_ARGS_USAGE_RANGE, clashing with BTRFS_BALANCE_ARGS_CONVERT. Introduced during the development phase, no backward compatibility issues. Reported-by: Holger Hoffstätte <holger.hoffstaette@googlemail.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Fixes: bc3094673f22 ("btrfs: extend balance filter usage to take minimum and maximum") Signed-off-by: David Sterba <dsterba@suse.com> Signed-off-by: Chris Mason <clm@fb.com>
