commit 8bb2ee192e482c5d500df9f2b1b26a560bd3026f upstream.
do_task_stat() accesses IP and SP of a task without bumping reference
count of a stack (which became an entity with independent lifetime at
some point).
Steps to reproduce:
#include <stdio.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <sys/time.h>
#include <sys/resource.h>
#include <unistd.h>
#include <sys/wait.h>
int main(void)
setrlimit(RLIMIT_CORE, &(struct rlimit){});
while (1) {
char buf[64];
char buf2[4096];
pid_t pid;
int fd;
pid = fork();
if (pid == 0) {
*(volatile int *)0 = 0;
snprintf(buf, sizeof(buf), "/proc/%u/stat", pid);
fd = open(buf, O_RDONLY);
read(fd, buf2, sizeof(buf2));
close(fd);
waitpid(pid, NULL, 0);
return 0;
BUG: unable to handle kernel paging request at 0000000000003fd8
IP: do_task_stat+0x8b4/0xaf0
PGD 800000003d73e067 P4D 800000003d73e067 PUD 3d558067 PMD 0
Oops: 0000 [#1] PREEMPT SMP PTI
CPU: 0 PID: 1417 Comm: a.out Not tainted 4.15.0-rc8-dirty #2
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1.fc27 04/01/2014
RIP: 0010:do_task_stat+0x8b4/0xaf0
Call Trace:
proc_single_show+0x43/0x70
seq_read+0xe6/0x3b0
__vfs_read+0x1e/0x120
vfs_read+0x84/0x110
SyS_read+0x3d/0xa0
entry_SYSCALL_64_fastpath+0x13/0x6c
RIP: 0033:0x7f4d7928cba0
RSP: 002b:00007ffddb245158 EFLAGS: 00000246
Code: 03 b7 a0 01 00 00 4c 8b 4c 24 70 4c 8b 44 24 78 4c 89 74 24 18 e9 91 f9 ff ff f6 45 4d 02 0f 84 fd f7 ff ff 48 8b 45 40 48 89 ef <48> 8b 80 d8 3f 00 00 48 89 44 24 20 e8 9b 97 eb ff 48 89 44 24
RIP: do_task_stat+0x8b4/0xaf0 RSP: ffffc90000607cc8
CR2: 0000000000003fd8
John Ogness said: for my tests I added an else case to verify that the
race is hit and correctly mitigated.
Link: http://lkml.kernel.org/r/20180116175054.GA11513@avx2
Reported-by: "Kohli, Gaurav" <gkohli@codeaurora.org>
Tested-by: John Ogness <john.ogness@linutronix.de>
commit d3f14c485867cfb2e0c48aa88c41d0ef4bf5209c upstream.
round_pipe_size() contains a right-bit-shift expression which may
overflow, which would cause undefined results in a subsequent
roundup_pow_of_two() call.
static inline unsigned int round_pipe_size(unsigned int size)
unsigned long nr_pages;
nr_pages = (size + PAGE_SIZE - 1) >> PAGE_SHIFT;
return roundup_pow_of_two(nr_pages) << PAGE_SHIFT;
PAGE_SIZE is defined as (1UL << PAGE_SHIFT), so:
- 4 bytes wide on 32-bit (0 to 0xffffffff)
- 8 bytes wide on 64-bit (0 to 0xffffffffffffffff)
That means that 32-bit round_pipe_size(), nr_pages may overflow to 0:
size=0x00000000 nr_pages=0x0
size=0x00000001 nr_pages=0x1
size=0xfffff000 nr_pages=0xfffff
size=0xfffff001 nr_pages=0x0 << !
size=0xffffffff nr_pages=0x0 << !
This is bad because roundup_pow_of_two(n) is undefined when n == 0!
64-bit is not a problem as the unsigned int size is 4 bytes wide
(similar to 32-bit) and the larger, 8 byte wide unsigned long, is
sufficient to handle the largest value of the bit shift expression:
size=0xffffffff nr_pages=100000
Modify round_pipe_size() to return 0 if n == 0 and updates its callers to
handle accordingly.
Link: http://lkml.kernel.org/r/1507658689-11669-3-git-send-email-joe.lawrence@redhat.com
Signed-off-by: Joe Lawrence <joe.lawrence@redhat.com>
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Reviewed-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Signed-off-by: Dong Jinguang <dongjinguang@huawei.com>
commit bdcf0a423ea1c40bbb40e7ee483b50fc8aa3d758 upstream.
In testing, we found that nfsd threads may call set_groups in parallel
for the same entry cached in auth.unix.gid, racing in the call of
groups_sort, corrupting the groups for that entry and leading to
permission denials for the client.
This patch:
- Make groups_sort globally visible.
- Move the call to groups_sort to the modifiers of group_info
- Remove the call to groups_sort from set_groups
Link: http://lkml.kernel.org/r/20171211151420.18655-1-thiago.becker@gmail.com
Signed-off-by: Thiago Rafael Becker <thiago.becker@gmail.com>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
Reviewed-by: NeilBrown <neilb@suse.com>
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
[ Upstream commit 457ae7268b29c33dee1c0feb143a15f6029d177b ]
This isn't super serious because you need CAP_ADMIN to run this code.
I added this integer overflow check last year but apparently I am
rubbish at writing integer overflow checks... There are two issues.
First, access_ok() works on unsigned long type and not u64 so on 32 bit
systems the access_ok() could be checking a truncated size. The other
issue is that we should be using a stricter limit so we don't overflow
the kzalloc() setting ctx->clone_roots later in the function after the
access_ok():
alloc_size = sizeof(struct clone_root) * (arg->clone_sources_count + 1);
sctx->clone_roots = kzalloc(alloc_size, GFP_KERNEL | __GFP_NOWARN);
Fixes: f5ecec3ce21f ("btrfs: send: silence an integer overflow warning")
Reviewed-by: David Sterba <dsterba@suse.com>
[ added comment ]
Signed-off-by: David Sterba <dsterba@suse.com>
[ Upstream commit abdc0eb06964fe1d2fea6dd1391b734d0590365d ]
When session starts beyond offset 2^31 the arithmetics in
udf_check_vsd() would overflow. Make sure the computation is done in
large enough type.
Reported-by: Cezary Sliwa <sliwa@ifpan.edu.pl>
[ Upstream commit c79dde629d2027ca80329c62854a7635e623d527 ]
After rmmod 8250.ko
tty_kref_put starts kwork (release_one_tty) to release proc interface
oops when accessing driver->driver_name in proc_tty_unregister_driver
Use jprobe, found driver->driver_name point to 8250.ko
static static struct uart_driver serial8250_reg
.driver_name= serial,
Use name in proc_dir_entry instead of driver->driver_name to fix oops
test on linux 4.1.12:
BUG: unable to handle kernel paging request at ffffffffa01979de
IP: [<ffffffff81310f40>] strchr+0x0/0x30
PGD 1a0d067 PUD 1a0e063 PMD 851c1f067 PTE 0
Modules linked in: ... ... [last unloaded: 8250]
CPU: 7 PID: 116 Comm: kworker/7:1 Tainted: G O 4.1.12 #1
Hardware name: Insyde RiverForest/Type2 - Board Product Name1, BIOS NE5KV904 12/21/2015
Workqueue: events release_one_tty
task: ffff88085b684960 ti: ffff880852884000 task.ti: ffff880852884000
RIP: 0010:[<ffffffff81310f40>] [<ffffffff81310f40>] strchr+0x0/0x30
RSP: 0018:ffff880852887c90 EFLAGS: 00010282
RAX: ffffffff81a5eca0 RBX: ffffffffa01979de RCX: 0000000000000004
RDX: ffff880852887d10 RSI: 000000000000002f RDI: ffffffffa01979de
RBP: ffff880852887cd8 R08: 0000000000000000 R09: ffff88085f5d94d0
R10: 0000000000000195 R11: 0000000000000000 R12: ffffffffa01979de
R13: ffff880852887d00 R14: ffffffffa01979de R15: ffff88085f02e840
FS: 0000000000000000(0000) GS:ffff88085f5c0000(0000) knlGS:0000000000000000
CR2: ffffffffa01979de CR3: 0000000001a0c000 CR4: 00000000001406e0
Stack:
ffffffff812349b1 ffff880852887cb8 ffff880852887d10 ffff88085f5cd6c2
ffff880852800a80 ffffffffa01979de ffff880852800a84 0000000000000010
ffff88085bb28bd8 ffff880852887d38 ffffffff812354f0 ffff880852887d08
Call Trace:
[<ffffffff812349b1>] ? __xlate_proc_name+0x71/0xd0
[<ffffffff812354f0>] remove_proc_entry+0x40/0x180
[<ffffffff815f6811>] ? _raw_spin_lock_irqsave+0x41/0x60
[<ffffffff813be520>] ? destruct_tty_driver+0x60/0xe0
[<ffffffff81237c68>] proc_tty_unregister_driver+0x28/0x40
[<ffffffff813be548>] destruct_tty_driver+0x88/0xe0
[<ffffffff813be5bd>] tty_driver_kref_put+0x1d/0x20
[<ffffffff813becca>] release_one_tty+0x5a/0xd0
[<ffffffff81074159>] process_one_work+0x139/0x420
[<ffffffff810745a1>] worker_thread+0x121/0x450
[<ffffffff81074480>] ? process_scheduled_works+0x40/0x40
[<ffffffff8107a16c>] kthread+0xec/0x110
[<ffffffff81080000>] ? tg_rt_schedulable+0x210/0x220
[<ffffffff8107a080>] ? kthread_freezable_should_stop+0x80/0x80
[<ffffffff815f7292>] ret_from_fork+0x42/0x70
Signed-off-by: nixiaoming <nixiaoming@huawei.com>
[ Upstream commit 5e422f5e4fd71d18bc6b851eeb3864477b3d842e ]
There was one spot in xfs_bmap_add_extent_unwritten_real that didn't use the
passed in new extent state but always converted to normal, leading to wrong
behavior when converting from normal to unwritten.
Only found by code inspection, it seems like this code path to move partial
extent from written to unwritten while merging it with the next extent is
rarely exercised.
Reviewed-by: Brian Foster <bfoster@redhat.com>
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
[ Upstream commit 9f2a4505800607e537e9dd9dea4f55c4b0c30c7a ]
It is possible for mkfs to format very small filesystems with too
small of an internal log with respect to the various minimum size
and block count requirements. If this occurs when the log happens to
be smaller than the scan window used for cycle verification and the
scan wraps the end of the log, the start_blk calculation in
xlog_find_head() underflows and leads to an attempt to scan an
invalid range of log blocks. This results in log recovery failure
and a failed mount.
Since there may be filesystems out in the wild with this kind of
geometry, we cannot simply refuse to mount. Instead, cap the scan
window for cycle verification to the size of the physical log. This
ensures that the cycle verification proceeds as expected when the
scan wraps the end of the log.
Reported-by: Zorro Lang <zlang@redhat.com>
Signed-off-by: Brian Foster <bfoster@redhat.com>
[ Upstream commit 9ca2e97fa3c3216200afe35a3b111ec51cc796d2 ]
If 'btrfs_alloc_path()' fails, we must free the resources already
allocated, as done in the other error handling paths in this function.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Reviewed-by: Qu Wenruo <quwenruo.btrfs@gmx.com>
[ Upstream commit cc555b09d8c3817aeebda43a14ab67049a5653f7 ]
This patch fixes a deadlock caused when the jdata flag is set for
inodes that are already on the ordered write list. Since it is
on the ordered write list, log_flush calls gfs2_ordered_write which
calls filemap_fdatawrite. But since the inode had the jdata flag
set, that calls gfs2_jdata_writepages, which tries to start a new
transaction. A new transaction cannot be started because it tries
to acquire the log_flush rwsem which is already locked by the log
flush operation.
The bottom line is: We cannot switch an inode from ordered to jdata
until we eliminate any ordered data pages (via log flush) or any
log_flush operation afterward will create the circular dependency
above. So we need to flush the log before setting the diskflags to
switch the file mode, then we need to remove the inode from the
ordered writes list.
Before this patch, the log flush was done for jdata->ordered, but
that's wrong. If we're going from jdata to ordered, we don't need
to call gfs2_log_flush because the call to filemap_fdatawrite will
do it for us:
filemap_fdatawrite() -> __filemap_fdatawrite_range()
__filemap_fdatawrite_range() -> do_writepages()
do_writepages() -> gfs2_jdata_writepages()
gfs2_jdata_writepages() -> gfs2_log_flush()
This patch modifies function do_gfs2_set_flags so that if a file
has its jdata flag set, and it's already on the ordered write list,
the log will be flushed and it will be removed from the list
before setting the flag.
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Acked-by: Abhijith Das <adas@redhat.com>
[ Upstream commit 350976ae21873b0d36584ea005076356431b8f79 ]
On truncate down, if new size is not block size aligned, we zero the
rest of block to avoid exposing stale data to user, and
iomap_truncate_page() skips zeroing if the range is already in
unwritten state or a hole. Then we writeback from on-disk i_size to
the new size if this range hasn't been written to disk yet, and
truncate page cache beyond new EOF and set in-core i_size.
The problem is that we could write data between di_size and newsize
before removing the page cache beyond newsize, as the extents may
still be in unwritten state right after a buffer write. As such, the
page of data that newsize lies in has not been zeroed by page cache
invalidation before it is written, and xfs_do_writepage() hasn't
triggered it's "zero data beyond EOF" case because we haven't
updated in-core i_size yet. Then a subsequent mmap read could see
non-zeros past EOF.
I occasionally see this in fsx runs in fstests generic/112, a
simplified fsx operation sequence is like (assuming 4k block size
xfs):
fallocate 0x0 0x1000 0x0 keep_size
write 0x0 0x1000 0x0
truncate 0x0 0x800 0x1000
punch_hole 0x0 0x800 0x800
mapread 0x0 0x800 0x800
where fallocate allocates unwritten extent but doesn't update
i_size, buffer write populates the page cache and extent is still
unwritten, truncate skips zeroing page past new EOF and writes the
page to disk, punch_hole invalidates the page cache, at last mapread
reads the block back and sees non-zero beyond EOF.
Fix it by moving truncate_setsize() to before writeback so the page
cache invalidation zeros the partial page at the new EOF. This also
triggers "zero data beyond EOF" in xfs_do_writepage() at writeback
time, because newsize has been set and page straddles the newsize.
Also fixed the wrong 'end' param of filemap_write_and_wait_range()
call while we're at it, the 'end' is inclusive and should be
'newsize - 1'.
Suggested-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Eryu Guan <eguan@redhat.com>
Acked-by: Dave Chinner <dchinner@redhat.com>
[ Upstream commit e1699d2d7bf6e6cce3e1baff19f9dd4595a58664 ]
This is a story about 4 distinct (and very old) btrfs bugs.
Commit c8b978188c ("Btrfs: Add zlib compression support") added
three data corruption bugs for inline extents (bugs #1-3).
Commit 93c82d5750 ("Btrfs: zero page past end of inline file items")
fixed bug #1: uncompressed inline extents followed by a hole and more
extents could get non-zero data in the hole as they were read. The fix
was to add a memset in btrfs_get_extent to zero out the hole.
Commit 166ae5a418 ("btrfs: fix inline compressed read err corruption")
fixed bug #2: compressed inline extents which contained non-zero bytes
might be replaced with zero bytes in some cases. This patch removed an
unhelpful memset from uncompress_inline, but the case where memset is
required was missed.
There is also a memset in the decompression code, but this only covers
decompressed data that is shorter than the ram_bytes from the extent
ref record. This memset doesn't cover the region between the end of the
decompressed data and the end of the page. It has also moved around a
few times over the years, so there's no single patch to refer to.
This patch fixes bug #3: compressed inline extents followed by a hole
and more extents could get non-zero data in the hole as they were read
(i.e. bug #3 is the same as bug #1, but s/uncompressed/compressed/).
The fix is the same: zero out the hole in the compressed case too,
by putting a memset back in uncompress_inline, but this time with
correct parameters.
The last and oldest bug, bug #0, is the cause of the offending inline
extent/hole/extent pattern. Bug #0 is a subtle and mostly-harmless quirk
of behavior somewhere in the btrfs write code. In a few special cases,
an inline extent and hole are allowed to persist where they normally
would be combined with later extents in the file.
A fast reproducer for bug #0 is presented below. A few offending extents
are also created in the wild during large rsync transfers with the -S
flag. A Linux kernel build (git checkout; make allyesconfig; make -j8)
will produce a handful of offending files as well. Once an offending
file is created, it can present different content to userspace each
time it is read.
Bug #0 is at least 4 and possibly 8 years old. I verified every vX.Y
kernel back to v3.5 has this behavior. There are fossil records of this
bug's effects in commits all the way back to v2.6.32. I have no reason
to believe bug #0 wasn't present at the beginning of btrfs compression
support in v2.6.29, but I can't easily test kernels that old to be sure.
It is not clear whether bug #0 is worth fixing. A fix would likely
require injecting extra reads into currently write-only paths, and most
of the exceptional cases caused by bug #0 are already handled now.
Whether we like them or not, bug #0's inline extents followed by holes
are part of the btrfs de-facto disk format now, and we need to be able
to read them without data corruption or an infoleak. So enough about
bug #0, let's get back to bug #3 (this patch).
An example of on-disk structure leading to data corruption found in
the wild:
item 61 key (606890 INODE_ITEM 0) itemoff 9662 itemsize 160
inode generation 50 transid 50 size 47424 nbytes 49141
block group 0 mode 100644 links 1 uid 0 gid 0
rdev 0 flags 0x0(none)
item 62 key (606890 INODE_REF 603050) itemoff 9642 itemsize 20
inode ref index 3 namelen 10 name: DB_File.so
item 63 key (606890 EXTENT_DATA 0) itemoff 8280 itemsize 1362
inline extent data size 1341 ram 4085 compress(zlib)
item 64 key (606890 EXTENT_DATA 4096) itemoff 8227 itemsize 53
extent data disk byte 5367308288 nr 20480
extent data offset 0 nr 45056 ram 45056
extent compression(zlib)
Different data appears in userspace during each read of the 11 bytes
between 4085 and 4096. The extent in item 63 is not long enough to
fill the first page of the file, so a memset is required to fill the
space between item 63 (ending at 4085) and item 64 (beginning at 4096)
with zero.
Here is a reproducer from Liu Bo, which demonstrates another method
of creating the same inline extent and hole pattern:
Using 'page_poison=on' kernel command line (or enable
CONFIG_PAGE_POISONING) run the following:
# touch foo
# chattr +c foo
# xfs_io -f -c "pwrite -W 0 1000" foo
# xfs_io -f -c "falloc 4 8188" foo
# od -x foo
# echo 3 >/proc/sys/vm/drop_caches
# od -x foo
This produce the following on my box:
Correct output: file contains 1000 data bytes followed
by zeros:
0000000 cdcd cdcd cdcd cdcd cdcd cdcd cdcd cdcd
0001740 cdcd cdcd cdcd cdcd 0000 0000 0000 0000
0001760 0000 0000 0000 0000 0000 0000 0000 0000
0020000
Actual output: the data after the first 1000 bytes
will be different each run:
0001740 cdcd cdcd cdcd cdcd 6c63 7400 635f 006d
0001760 5f74 6f43 7400 435f 0053 5f74 7363 7400
0002000 435f 0056 5f74 6164 7400 645f 0062 5f74
Signed-off-by: Zygo Blaxell <ce3g8jdj@umail.furryterror.org>
Reviewed-by: Liu Bo <bo.li.liu@oracle.com>
Reviewed-by: Chris Mason <clm@fb.com>
Signed-off-by: Chris Mason <clm@fb.com>
[ Upstream commit 033853325fe3bdc70819a8b97915bd3bca41d3af ]
Currently client doesn't respect max sizes server returns in CREATE_SESSION.
nfs4_session_set_rwsize() gets called and server->rsize, server->wsize are 0
so they never get set to the sizes returned by the server.
Signed-off-by: Olga Kornievskaia <kolga@netapp.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
[ Upstream commit 954cd6dc02a65065aecb7150962c0870c5b0e322 ]
Fix the way in which a call that's in progress and being waited for is
aborted in the case that EINTR is detected. We should be sending
RX_USER_ABORT rather than RX_CALL_DEAD as the abort code.
Note that since the only two ways out of the loop are if the call completes
or if a signal happens, the kill-the-call clause after the loop has
finished can only happen in the case of EINTR. This means that we only
have one abort case to deal with, not two, and the "KWC" case can never
happen and so can be deleted.
Note further that simply aborting the call isn't necessarily the best thing
here since at this point: the request has been entirely sent and it's
likely the server will do the operation anyway - whether we abort it or
not. In future, we should punt the handling of the remainder of the call
off to a background thread.
Reported-by: Marc Dionne <marc.c.dionne@auristor.com>
[ Upstream commit 7286a35e893176169b09715096a4aca557e2ccd2 ]
Fix afs_kill_pages() in two ways:
(1) If a writeback has been partially flushed, then if we try and kill the
pages it contains, some of them may no longer be undergoing writeback
and end_page_writeback() will assert.
Fix this by checking to see whether the page in question is actually
undergoing writeback before ending that writeback.
(2) The loop that scans for pages to kill doesn't increase the first page
index, and so the loop may not terminate, but it will try to process
the same pages over and over again.
Fix this by increasing the first page index to one after the last page
we processed.
[ Upstream commit 6d06b0d25209c80e99c1e89700f1e09694a3766b ]
afs_write_begin() leaks a ref and a lock on a page if afs_fill_page()
fails. Fix the leak by unlocking and releasing the page in the error path.
[ Upstream commit ab94f5d0dd6fd82e7eeca5e7c8096eaea0a0261f ]
The inode timestamps should be set from the client time
in the status received from the server, rather than the
server time which is meant for internal server use.
Set AFS_SET_MTIME and populate the mtime for operations
that take an input status, such as file/dir creation
and StoreData. If an input time is not provided the
server will set the vnode times based on the current server
time.
In a situation where the server has some skew with the
client, this could lead to the client seeing a timestamp
in the future for a file that it just created or wrote.
Signed-off-by: Marc Dionne <marc.dionne@auristor.com>
[ Upstream commit 70af0e3bd65142f9e674961c975451638a7ce1d5 ]
If we receive a network error, a remote abort or a protocol error whilst
we're still transmitting data, make sure we return an appropriate error to
the caller rather than ESHUTDOWN or ECONNABORTED.
[ Upstream commit 1157f153f37a8586765034470e4f00a4a6c4ce6f ]
When we are given an invalid operation ID, we should abort that with
RXGEN_OPCODE rather than RX_INVALID_OPERATION.
Also map RXGEN_OPCODE to -ENOTSUPP.
[ Upstream commit 146a1192783697810b63a1e41c4d59fc93387340 ]
afs_fs_store_data() works out of the size of the write it's going to make,
but it uses 32-bit unsigned subtraction in one place that gets
automatically cast to loff_t.
However, if to < offset, then the number goes negative, but as the result
isn't signed, this doesn't get sign-extended to 64-bits when placed in a
loff_t.
Fix by casting the operands to loff_t.
[ Upstream commit 56e714312e7dbd6bb83b2f78d3ec19a404c7649f ]
get_seconds() returns real wall-clock seconds. On 32-bit systems
this value will overflow in year 2038 and beyond. This patch changes
afs_vnode record to use ktime_get_real_seconds() instead, for the
fields cb_expires and cb_expires_at.
Signed-off-by: Tina Ruchandani <ruchandani.tina@gmail.com>
[ Upstream commit 8a79790bf0b7da216627ffb85f52cfb4adbf1e4e ]
afs's vlocation record to use ktime_get_real_seconds() instead, for the
fields time_of_death and update_at.
[ Upstream commit 58fed94dfb17e89556b5705f20f90e5b2971b6a1 ]
Flush outstanding writes in afs when an fd is closed. This is what NFS and
CIFS do.
Reported-by: Marc Dionne <marc.c.dionne@gmail.com>
[ Upstream commit bcd89270d93b7edebb5de5e5e7dca1a77a33496e ]
Servers may send a callback array that is the same size as
the FID array, or an empty array. If the callback count is
0, the code would attempt to read (fid_count * 12) bytes of
data, which would fail and result in an unmarshalling error.
This would lead to stale data for remotely modified files
or directories.
Store the callback array size in the internal afs_call
structure and use that to determine the amount of data to
read.
[ Upstream commit 627f46943ff90bcc32ddeb675d881c043c6fa2ae ]
Mode bits for an afs file should not be enforced in the usual
way.
For files, the absence of user bits can restrict file access
with respect to what is granted by the server.
These bits apply regardless of the owner or the current uid; the
rest of the mode bits (group, other) are ignored.
[ Upstream commit 6186f0788b31f44affceeedc7b48eb10faea120d ]
The group was hard coded to GLOBAL_ROOT_GID; use the group
ID that was received from the server.
[ Upstream commit 29c8bbbd6e21daa0997d1c3ee886b897ee7ad652 ]
In afs_writepages_region(), inside the loop where we find dirty pages to
deal with, one of the if-statements is missing a put_page().
[ Upstream commit 4a3a485b1ed0e109718cc8c9d094fa0f552de9b2 ]
When WB_registered flag is not set, wb_queue_work() skips queuing the
work, but does not perform the necessary clean up. In particular, if
work->auto_free is true, it should free the memory.
The leak condition can be reprouced by following these steps:
mount /dev/sdb /mnt/sdb
/* In qemu console: device_del sdb */
umount /dev/sdb
Above will result in a wb_queue_work() call on an unregistered wb and
thus leak memory.
Reported-by: John Sperbeck <jsperbeck@google.com>
Signed-off-by: Tahsin Erdogan <tahsin@google.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
[ Upstream commit 800a938f0bf9130c8256116649c0cc5806bfb2fd ]
If you write "-2 -3 -4" to the "versions" file, it will
notice that no versions are enabled, and nfsd_reset_versions()
is called.
This enables all major versions, not no minor versions.
So we lose the invariant that NFSv4 is only advertised when
at least one minor is enabled.
Fix the code to explicitly enable minor versions for v4,
change it to use nfsd_vers() to test and set, and simplify
the code.
Signed-off-by: NeilBrown <neilb@suse.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
[ Upstream commit 928c6fb3a9bfd6c5b287aa3465226add551c13c0 ]
Current code will return 1 if the version is supported,
and -1 if it isn't.
This is confusing and inconsistent with the one place where this
is used.
So change to return 1 if it is supported, and zero if not.
i.e. an error is never returned.
[ Upstream commit 6bbc4a4144b1a69743022ac68dfaf6e7d993abb9 ]
__do_fault assumes vmf->page has been initialized and is valid if
VM_FAULT_NOPAGE is not returned by vma->vm_ops->fault(vma, vmf).
handle_userfault() in turn should return VM_FAULT_NOPAGE if it doesn't
return VM_FAULT_SIGBUS or VM_FAULT_RETRY (the other two possibilities).
This VM_FAULT_NOPAGE case is only invoked when signal are pending and it
didn't matter for anonymous memory before. It only started to matter
since shmem was introduced. hugetlbfs also takes a different path and
doesn't exercise __do_fault.
Link: http://lkml.kernel.org/r/20170228154201.GH5816@redhat.com
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
commit 9d5afec6b8bd46d6ed821aa1579634437f58ef1f upstream.
On a ppc64 machine, when mounting a fuzzed ext2 image (generated by
fsfuzzer) the following call trace is seen,
VFS: brelse: Trying to free free buffer
WARNING: CPU: 1 PID: 6913 at /root/repos/linux/fs/buffer.c:1165 .__brelse.part.6+0x24/0x40
.__brelse.part.6+0x20/0x40 (unreliable)
.ext4_find_entry+0x384/0x4f0
.ext4_lookup+0x84/0x250
.lookup_slow+0xdc/0x230
.walk_component+0x268/0x400
.path_lookupat+0xec/0x2d0
.filename_lookup+0x9c/0x1d0
.vfs_statx+0x98/0x140
.SyS_newfstatat+0x48/0x80
system_call+0x58/0x6c
This happens because the directory that ext4_find_entry() looks up has
inode->i_size that is less than the block size of the filesystem. This
causes 'nblocks' to have a value of zero. ext4_bread_batch() ends up not
reading any of the directory file's blocks. This renders the entries in
bh_use[] array to continue to have garbage data. buffer_uptodate() on
bh_use[0] can then return a zero value upon which brelse() function is
invoked.
This commit fixes the bug by returning -ENOENT when the directory file
has no associated blocks.
Reported-by: Abdul Haleem <abdhalee@linux.vnet.ibm.com>
Signed-off-by: Chandan Rajendra <chandan@linux.vnet.ibm.com>
commit c894aa97577e47d3066b27b32499ecf899bfa8b0 upstream.
Currently, fallocate(2) with KEEP_SIZE followed by a fdatasync(2)
then crash, we'll see wrong allocated block number (stat -c %b), the
blocks allocated beyond EOF are all lost. fstests generic/468
exposes this bug.
Commit 67a7d5f561f4 ("ext4: fix fdatasync(2) after extent
manipulation operations") fixed all the other extent manipulation
operation paths such as hole punch, zero range, collapse range etc.,
but forgot the fallocate case.
So similarly, fix it by recording the correct journal tid in ext4
inode in fallocate(2) path, so that ext4_sync_file() will wait for
the right tid to be committed on fdatasync(2).
This addresses the test failure in xfstests test generic/468.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit dc4fd9ab01ab379ae5af522b3efd4187a7c30a31 upstream.
If there were no commit requests, then nfs_commit_inode() should not
wait on the commit or mark the inode dirty, otherwise the following
BUG_ON can be triggered:
[ 1917.130762] kernel BUG at fs/inode.c:578!
[ 1917.130766] Oops: Exception in kernel mode, sig: 5 [#1]
[ 1917.130768] SMP NR_CPUS=2048 NUMA pSeries
[ 1917.130772] Modules linked in: iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi blocklayoutdriver rpcsec_gss_krb5 auth_rpcgss nfsv4 dns_resolver nfs lockd grace fscache sunrpc sg nx_crypto pseries_rng ip_tables xfs libcrc32c sd_mod crc_t10dif crct10dif_generic crct10dif_common ibmvscsi scsi_transport_srp ibmveth scsi_tgt dm_mirror dm_region_hash dm_log dm_mod
[ 1917.130805] CPU: 2 PID: 14923 Comm: umount.nfs4 Tainted: G ------------ T 3.10.0-768.el7.ppc64 #1
[ 1917.130810] task: c0000005ecd88040 ti: c00000004cea0000 task.ti: c00000004cea0000
[ 1917.130813] NIP: c000000000354178 LR: c000000000354160 CTR: c00000000012db80
[ 1917.130816] REGS: c00000004cea3720 TRAP: 0700 Tainted: G ------------ T (3.10.0-768.el7.ppc64)
[ 1917.130820] MSR: 8000000100029032 <SF,EE,ME,IR,DR,RI> CR: 22002822 XER: 20000000
[ 1917.130828] CFAR: c00000000011f594 SOFTE: 1
GPR00: c000000000354160 c00000004cea39a0 c0000000014c4700 c0000000018cc750
GPR04: 000000000000c750 80c0000000000000 0600000000000000 04eeb76bea749a03
GPR08: 0000000000000034 c0000000018cc758 0000000000000001 d000000005e619e8
GPR12: c00000000012db80 c000000007b31200 0000000000000000 0000000000000000
GPR16: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
GPR20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
GPR24: 0000000000000000 c000000000dfc3ec 0000000000000000 c0000005eefc02c0
GPR28: d0000000079dbd50 c0000005b94a02c0 c0000005b94a0250 c0000005b94a01c8
[ 1917.130867] NIP [c000000000354178] .evict+0x1c8/0x350
[ 1917.130871] LR [c000000000354160] .evict+0x1b0/0x350
[ 1917.130873] Call Trace:
[ 1917.130876] [c00000004cea39a0] [c000000000354160] .evict+0x1b0/0x350 (unreliable)
[ 1917.130880] [c00000004cea3a30] [c0000000003558cc] .evict_inodes+0x13c/0x270
[ 1917.130884] [c00000004cea3af0] [c000000000327d20] .kill_anon_super+0x70/0x1e0
[ 1917.130896] [c00000004cea3b80] [d000000005e43e30] .nfs_kill_super+0x20/0x60 [nfs]
[ 1917.130900] [c00000004cea3c00] [c000000000328a20] .deactivate_locked_super+0xa0/0x1b0
[ 1917.130903] [c00000004cea3c80] [c00000000035ba54] .cleanup_mnt+0xd4/0x180
[ 1917.130907] [c00000004cea3d10] [c000000000119034] .task_work_run+0x114/0x150
[ 1917.130912] [c00000004cea3db0] [c00000000001ba6c] .do_notify_resume+0xcc/0x100
[ 1917.130916] [c00000004cea3e30] [c00000000000a7b0] .ret_from_except_lite+0x5c/0x60
[ 1917.130919] Instruction dump:
[ 1917.130921] 7fc3f378 486734b5 60000000 387f00a0 38800003 4bdcb365 60000000 e95f00a0
[ 1917.130927] 694a0060 7d4a0074 794ad182 694a0001 <0b0a0000> 892d02a4 2f890000 40de0134
Signed-off-by: Scott Mayhew <smayhew@redhat.com>
commit 040d786032bf59002d374b86d75b04d97624005c upstream.
Negative child dentry holds reference on inode's alias, it makes
d_prune_aliases() do nothing.
Signed-off-by: "Yan, Zheng" <zyan@redhat.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
commit 302ec300ef8a545a7fc7f667e5fd743b091c2eeb upstream.
Commit ecc0c469f277 ("autofs: don't fail mount for transient error") was
meant to replace an 'if' with a 'switch', but instead added the 'switch'
leaving the case in place.
Link: http://lkml.kernel.org/r/87zi6wstmw.fsf@notabene.neil.brown.name
Fixes: ecc0c469f277 ("autofs: don't fail mount for transient error")
Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Cc: Ian Kent <raven@themaw.net>
[ Upstream commit f4b3526d83c40dd8bf5948b9d7a1b2c340f0dcc8 ]
The handler for the CB.ProbeUuid operation in the cache manager is
implemented, but isn't listed in the switch-statement of operation
selection, so won't be used. Fix this by adding it.
[ Upstream commit 962cc1ad6caddb5abbb9f0a43e5abe7131a71f18 ]
In commit f2e9ad21 ("xfs: check for race with xfs_reclaim_inode"), we
skip an inode if we're racing with freeing the inode via
xfs_reclaim_inode, but we forgot to release the rcu read lock when
dumping the inode, with the result that we exit to userspace with a lock
held. Don't do that; generic/320 with a 1k block size fails this
very occasionally.
WARNING: lock held when returning to user space!
4.14.0-rc6-djwong #4 Tainted: G W
rm/30466 is leaving the kernel with locks still held!
1 lock held by rm/30466:
#0: (rcu_read_lock){....}, at: [<ffffffffa01364d3>] xfs_ifree_cluster.isra.17+0x2c3/0x6f0 [xfs]
WARNING: CPU: 1 PID: 30466 at kernel/rcu/tree_plugin.h:329 rcu_note_context_switch+0x71/0x700
Modules linked in: deadline_iosched dm_snapshot dm_bufio ext4 mbcache jbd2 dm_flakey xfs libcrc32c dax_pmem device_dax nd_pmem sch_fq_codel af_packet [last unloaded: scsi_debug]
CPU: 1 PID: 30466 Comm: rm Tainted: G W 4.14.0-rc6-djwong #4
Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS 1.10.2-1ubuntu1djwong0 04/01/2014
task: ffff880037680000 task.stack: ffffc90001064000
RIP: 0010:rcu_note_context_switch+0x71/0x700
RSP: 0000:ffffc90001067e50 EFLAGS: 00010002
RAX: 0000000000000001 RBX: ffff880037680000 RCX: ffff88003e73d200
RDX: 0000000000000002 RSI: ffffffff819e53e9 RDI: ffffffff819f4375
RBP: 0000000000000000 R08: 0000000000000000 R09: ffff880062c900d0
R10: 0000000000000000 R11: 0000000000000000 R12: ffff880037680000
R13: 0000000000000000 R14: ffffc90001067eb8 R15: ffff880037680690
FS: 00007fa3b8ce8700(0000) GS:ffff88003ec00000(0000) knlGS:0000000000000000
CR2: 00007f69bf77c000 CR3: 000000002450a000 CR4: 00000000000006e0
Call Trace:
__schedule+0xb8/0xb10
schedule+0x40/0x90
exit_to_usermode_loop+0x6b/0xa0
prepare_exit_to_usermode+0x7a/0x90
retint_user+0x8/0x20
RIP: 0033:0x7fa3b87fda87
RSP: 002b:00007ffe41206568 EFLAGS: 00000246 ORIG_RAX: ffffffffffffff02
RAX: 0000000000000000 RBX: 00000000010e88c0 RCX: 00007fa3b87fda87
RDX: 0000000000000000 RSI: 00000000010e89c8 RDI: 0000000000000005
RBP: 0000000000000000 R08: 0000000000000003 R09: 0000000000000000
R10: 000000000000015e R11: 0000000000000246 R12: 00000000010c8060
R13: 00007ffe41206690 R14: 0000000000000000 R15: 0000000000000000
---[ end trace e88f83bf0cfbd07d ]---
Fixes: f2e9ad212def50bcf4c098c6288779dd97fff0f0
Cc: Omar Sandoval <osandov@fb.com>
Reviewed-by: Omar Sandoval <osandov@fb.com>
[ Upstream commit d803224c84be067754db7fa58a93f36f61566493 ]
On successful rename, the "old_dentry" is retained and is attached to
the "new_dir", so we need to call nfs_set_verifier() accordingly.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit e19182c0fff451e3744c1107d98f072e7ca377a0 upstream.
If btrfs_del_root fails in btrfs_drop_snapshot, we'll pick up the
error but then return 0 anyway due to mixing err and ret.
Fixes: 79787eaab4612 ("btrfs: replace many BUG_ONs with proper error handling")
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
[ Upstream commit c6180a6237174f481dc856ed6e890d8196b6f0fb ]
If the server reboots multiple times, the client should rely on the
server to tell it that it cannot reclaim state as per section 9.6.3.4
in RFC7530 and section 8.4.2.1 in RFC5661.
Currently, the client is being to conservative, and is assuming that
if the server reboots while state recovery is in progress, then it must
ignore state that was not recovered before the reboot.
[ Upstream commit 4b09ec4b14a168bf2c687e1f598140c3c11e9222 ]
I have reports of a crash that look like __fput() was called twice for
a NFSv4.0 file. It seems possible that the state manager could try to
reclaim a lock and take a reference on the fl->fl_file at the same time the
file is being released if, during the close(), a signal interrupts the wait
for outstanding IO while removing locks which then skips the removal
of that lock.
Since 83bfff23e9ed ("nfs4: have do_vfs_lock take an inode pointer") has
removed the need to traverse fl->fl_file->f_inode in nfs4_lock_done(),
taking that reference is no longer necessary.
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
[ Upstream commit 75422726b0f717d67db3283c2eb5bc14fa2619c5 ]
Add MS_KERNMOUNT to the flags that are passed.
Use sget_userns and force &init_user_ns instead of calling sget so that
even if called from a weird context the internal filesystem will be
considered to be in the intial user namespace.
Luis Ressel reported that the the failure to pass MS_KERNMOUNT into
mount_pseudo broke his in development graphics driver that uses the
generic drm infrastructure. I am not certain the deriver was bug
free in it's usage of that infrastructure but since
mount_pseudo_xattr can never be triggered by userspace it is clearer
and less error prone, and less problematic for the code to be explicit.
Reported-by: Luis Ressel <aranea@aixah.de>
Tested-by: Luis Ressel <aranea@aixah.de>
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
[ Upstream commit e3fce68cdbed297d927e993b3ea7b8b1cee545da ]
Currently dax_iomap_rw() takes care of invalidating page tables and
evicting hole pages from the radix tree when write(2) to the file
happens. This invalidation is only necessary when there is some block
allocation resulting from write(2). Furthermore in current place the
invalidation is racy wrt page fault instantiating a hole page just after
we have invalidated it.
So perform the page invalidation inside dax_iomap_actor() where we can
do it only when really necessary and after blocks have been allocated so
nobody will be instantiating new hole pages anymore.
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
commit b688741cb06695312f18b730653d6611e1bad28d upstream.
For correct close-to-open semantics, NFS must validate
the change attribute of a directory (or file) on open.
Since commit ecf3d1f1aa74 ("vfs: kill FS_REVAL_DOT by adding a
d_weak_revalidate dentry op"), open() of "." or a path ending ".." is
not revalidated reliably (except when that direct is a mount point).
Prior to that commit, "." was revalidated using nfs_lookup_revalidate()
which checks the LOOKUP_OPEN flag and forces revalidation if the flag is
set.
Since that commit, nfs_weak_revalidate() is used for NFSv3 (which
ignores the flags) and nothing is used for NFSv4.
This is fixed by using nfs_lookup_verify_inode() in
nfs_weak_revalidate(). This does the revalidation exactly when needed.
Also, add a definition of .d_weak_revalidate for NFSv4.
The incorrect behavior is easily demonstrated by running "echo *" in
some non-mountpoint NFS directory while watching network traffic.
Without this patch, "echo *" sometimes doesn't produce any traffic.
With the patch it always does.
Fixes: ecf3d1f1aa74 ("vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op")
cc: stable@vger.kernel.org (3.9+)
commit 64ebe12494fd5d193f014ce38e1fd83cc57883c8 upstream.
From kernel 4.9, my two nfsv4 servers sometimes suffer from
"panic: unable to handle kernel page request"
in posix_unblock_lock() called from nfs4_laundromat().
These panics diseappear if we revert the commit "nfsd: add a LRU list
for blocked locks".
The cause appears to be a typo in nfs4_laundromat(), which is also
present in nfs4_state_shutdown_net().
Fixes: 7919d0a27f1e "nfsd: add a LRU list for blocked locks"
Cc: jlayton@redhat.com
Reveiwed-by: Jeff Layton <jlayton@redhat.com>
commit d8a1a000555ecd1b824ac1ed6df8fe364dfbbbb0 upstream.
If nfsd4_process_open2() is initialising a new stateid, and yet the
call to nfs4_get_vfs_file() fails for some reason, then we must
declare the stateid closed, and unhash it before dropping the mutex.
Right now, we unhash the stateid after dropping the mutex, and without
changing the stateid type, meaning that another OPEN could theoretically
look it up and attempt to use it.
Reported-by: Andrew W Elble <aweits@rit.edu>
commit 15ca08d3299682dc49bad73251677b2c5017ef08 upstream.
Open file stateids can linger on the nfs4_file list of stateids even
after they have been closed. In order to avoid reusing such a
stateid, and confusing the client, we need to recheck the
nfs4_stid's type after taking the mutex.
Otherwise, we risk reusing an old stateid that was already closed,
which will confuse clients that expect new stateids to conform to
RFC7530 Sections 9.1.4.2 and 16.2.5 or RFC5661 Sections 8.2.2 and 18.2.4.
commit 8e138e0d92c6c9d3d481674fb14e3439b495be37 upstream.
We discovered a box that had double allocations, and suspected the space
cache may be to blame. While auditing the write out path I noticed that
if we've already setup the space cache we will just carry on. This
means that any error we hit after cache_save_setup before we go to
actually write the cache out we won't reset the inode generation, so
whatever was already written will be considered correct, except it'll be
stale. Fix this by _always_ resetting the generation on the block group
inode, this way we only ever have valid or invalid cache.
With this patch I was no longer able to reproduce cache corruption with
dm-log-writes and my bpf error injection tool.
Signed-off-by: Josef Bacik <jbacik@fb.com>
[ Upstream commit 73ba39ab9307340dc98ec3622891314bbc09cc2e ]
In function btrfs_uuid_tree_iterate(), errno is assigned to variable ret
on errors. However, it directly returns 0. It may be better to return
ret. This patch also removes the warning, because the caller already
prints a warning.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=188731
Signed-off-by: Pan Bian <bianpan2016@163.com>
[ edited subject ]
