This reverts commit aae576e5faefa8ba70647efa320d4747b6375f1e.
Push and Pop are not portable "enough", and caused problems for
some ACPICA customers.
Signed-off-by: Robert Moore <Robert.Moore@intel.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Use push and pop to both guarantee that the correct alignment is used,
and to restore the alignment to whatever it was before the header
was included.
It is reported that the #pragma pack(push/pop) directives are not supported
by the specific GCCs, but this patch still doesn't affect kernel build
as there are already #pragma pack([1]) directives used in the old ACPICA
headers, which means there shouldn't be GCCs that are currently used to
compile the ACPI kernels do not support #pragma pack() directives.
References: https://bugs.acpica.org/show_bug.cgi?id=1058
Signed-off-by: Bob Moore <robert.moore@intel.com>
Update ACPICA copyrights to 2014. Includes all source headers and
signons for the various tools.
This patch adds protection around ACPI_CHECKSUM_ABORT so that ACPI
user space test utilities can re-define it for their own purposes
(currently used by ASLTS build environment).
This patch doesn't affect Linux kernel behavior. Lv Zheng.
Surround definition of this with a #ifndef so that the kernel
can define it elsewhere if desired.
Fully implements typechecking on all incoming arguments for all
predefined names. This ensures that ACPI-related drivers are
passing the correct number of arguments, each of the correct
object type.
Acked-by: Len Brown <len.brown@intel.com>
Includes all source headers and signons for the various tools.
Created logical splits for eight new files. Improves modularity
and configurability.
This is a cosmetic patch only. Comparison of the resulting binary showed
only line number differences.
This patch does not affect the generation of the Linux binary.
This patch decreases 389 lines of 20121018 divergence.diff.
This patch reduces source code diff caused by the simple code maintenance
work:
1. Deletion of the unused include files.
2. Deletion of the deprecated codes blocks.
3. Repositioning of the code blocks.
4. Replacing the values with the well defined macros.
5. Replacing the types with the equivalent types.
This patch decreases 558 lines of 20121018 divergence.diff.
This patch reduces the source code diff between Linux and ACPICA by
cleaning the comments that already have been updated in ACPICA.
There is no extra indentation done in this patch. Even the empty line
deletions and insertions are also splitted into another cleanup patch so
that this patch can be easily reviewed, and the binary differences can be
held to a lowest level.
Debugger improvements in ACPICA are always ignored by ACPICA Linux
release. This will lead to divergences between Linux and ACPICA.
This patch fixes such unmerged debugger updates.
Following patches are included:
1. Fixed a couple compiler warnings for extra extern
Wed, 14 Mar 2007 21:12:19 +0000
2. Cleanup for internal Reference Object.
Wed, 27 Aug 2008 10:11:30 -0700
3. Debugger: Lock method args for multithread command.
Fri, 24 Apr 2009 12:28:49 -0700
4. Debugger: Add max count argument for Batch command.
Tue, 29 Sep 2009 12:31:58 -0700
5. Add new host interfaces for _OSI support.
Thu, 5 Aug 2010 14:18:28 -0700
6. Increase debugger buffer size for method return objects.
Wed, 17 Nov 2010 13:48:30 -0800
7. Debugger: Add command to display status of global handlers.
Tue, 25 Jan 2011 13:47:58 -0800
8. Debugger: Split large dbcmds.c file.
Wed, 26 Jan 2011 13:03:41 -0800
9. Debugger/AcpiExec: Add support to pass complex args to methods.
Tue, 17 May 2011 13:33:39 -0700
10.Debugger: Add Template command to dump resource templates.
Fri, 28 Oct 2011 14:18:51 -0700
11.Support for custom ACPICA build for ACPI 5.0 reduced hardware.
Wed, 1 Feb 2012 13:18:17 -0800
12.Debugger: Improve command help support.
Wed, 15 Feb 2012 07:59:26 -0800
13.Update ACPI_HW_DEPENDENT* macro invocations.
Wed, 15 Feb 2012 08:14:08 -0800
14.Debugger: Rename function to simplify source code conversion.
Wed, 13 Jun 2012 14:23:06 -0700
15.Debugger: Enhance "Tables" and "Unload" commands.
Fri, 29 Jun 2012 13:10:58 -0700
16.Debugger: update prototype for AcpiDbSleep function.
Fri, 17 Aug 2012 13:43:02 -0700
This patch will not affect the generated vmlinx binary.
This will decrease 264 lines of 20120913 divergence.diff.
Signed-off-by: Robert Moore <robert.moore@intel.com>
Add ACPI_REDUCED_HARDWARE flag that removes all hardware-related
code (about 10% code, 5% static data).
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
acpi.h now includes only the "public" acpica headers. All other
acpica headers are "private" and should not be included by acpica
users. One new file, accommon.h is used to include the commonly
used private headers for acpica code generation. Future plans
are to move all private headers to a new subdirectory.
Add a loop counter to force exit from AML While loops if the
count becomes too large. This can occur in poorly written AML
when the hardware does not respond within a while loop and the
loop does not implement a timeout. The maximum loop count is
configurable. A new exception code is returned when a loop is
broken, AE_AML_INFINITE_LOOP. Bob Moore, Alexey Starikovskiy.
Update version to 20080926.
Update version to 20080829.
Update version to 20080701.
Update version to 20080609.
Update version to 20080514
Update version to 20080321.
Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de>
Update ACPICA version to 20080213.
Update version to 20080123.
Update version to 20071219.
Update version to 20071114.
Update version to 20071019.
Update version to 20070508.
pdate version to 20070320
fixes STACK_OVERFLOW exception on nested method calls. internal
bugzilla 262 and 275.
Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com>
Added 2007 copyright to all module headers and signons. This affects
virtually every file in the ACPICA core subsystem, iASL compiler,
and the utilities.
The Table Manager component has been completely
redesigned and reimplemented. The new design is much
simpler, and reduces the overall code and data size of
the kernel-resident ACPICA by approximately 5%. Also,
it is now possible to obtain the ACPI tables very early
during kernel initialization, even before dynamic memory
management is initialized.
We have some new larger ia64 systems in HP that trip over the
ACPI_MAX_REFERENCE_COUNT limit which triggers a large number of these
debug messages:
ACPI Warning (utdelete-0397): Large Reference Count (XXX) in object e0000a0ff6797ab0 [20060707]
This was increased once in the past as described in this very brief thread:
http://www.mail-archive.com/linux-acpi@vger.kernel.org/msg00890.html
Signed-off-by: Doug Chapman <doug.chapman@hp.com>
Added the ACPI_PACKED_POINTERS_NOT_SUPPORTED macro to
support C compilers that do not allow the initialization
of address pointers within packed structures - even though
the hardware itself may support misaligned transfers. Some
of the debug data structures are packed by default to
minimize size.
Added an error message for the case where
acpi_os_get_thread_id() returns zero. A non-zero value is
required by the core ACPICA code to ensure the proper
operation of AML mutexes and recursive control methods.
The DSDT is now the only ACPI table that determines whether
the AML interpreter is in 32-bit or 64-bit mode. Not really
a functional change, but the hooks for per-table 32/64
switching have been removed from the code. A clarification
to the ACPI specification is forthcoming in ACPI 3.0B.
Fixed a possible leak of an Owner ID in the error
path of tbinstal.c acpi_tb_init_table_descriptor() and
migrated all table OwnerID deletion to a single place in
acpi_tb_uninstall_table() to correct possible leaks when using
the acpi_tb_delete_tables_by_type() interface (with assistance
from Lance Ortiz.)
Fixed a problem with Serialized control methods where the
semaphore associated with the method could be over-signaled
after multiple method invocations.
Fixed two issues with the locking of the internal
namespace data structure. Both the Unload() operator and
acpi_unload_table() interface now lock the namespace during
the namespace deletion associated with the table unload
(with assistance from Linn Crosetto.)
Fixed problem reports (Valery Podrezov) integrated: -
Eliminate unnecessary memory allocation for CreateXxxxField
http://bugzilla.kernel.org/show_bug.cgi?id=5426
Fixed problem reports (Fiodor Suietov) integrated: -
Incomplete cleanup branches in AcpiTbGetTableRsdt (BZ 369)
- On Address Space handler deletion, needless deactivation
call (BZ 374) - AcpiRemoveAddressSpaceHandler: validate
Device handle parameter (BZ 375) - Possible memory leak,
Notify sub-objects of Processor, Power, ThermalZone (BZ
376) - AcpiRemoveAddressSpaceHandler: validate Handler
parameter (BZ 378) - Minimum Length of RSDT should be
validated (BZ 379) - AcpiRemoveNotifyHandler: return
AE_NOT_EXIST if Processor Obj has no Handler (BZ (380)
- AcpiUnloadTable: return AE_NOT_EXIST if no table of
specified type loaded (BZ 381)
Implemented a new acpi_spinlock type for the OSL lock
interfaces. This allows the type to be customized to
the host OS for improved efficiency (since a spinlock is
usually a very small object.)
Implemented support for "ignored" bits in the ACPI
registers. According to the ACPI specification, these
bits should be preserved when writing the registers via
a read/modify/write cycle. There are 3 bits preserved
in this manner: PM1_CONTROL[0] (SCI_EN), PM1_CONTROL[9],
and PM1_STATUS[11].
http://bugzilla.kernel.org/show_bug.cgi?id=3691
Implemented the initial deployment of new OSL mutex
interfaces. Since some host operating systems have
separate mutex and semaphore objects, this feature was
requested. The base code now uses mutexes (and the new
mutex interfaces) wherever a binary semaphore was used
previously. However, for the current release, the mutex
interfaces are defined as macros to map them to the
existing semaphore interfaces.
Fixed several problems with the support for the control
method SyncLevel parameter. The SyncLevel now works
according to the ACPI specification and in concert with the
Mutex SyncLevel parameter, since the current SyncLevel is
a property of the executing thread. Mutual exclusion for
control methods is now implemented with a mutex instead
of a semaphore.
Fixed three instances of the use of the C shift operator
in the bitfield support code (exfldio.c) to avoid the use
of a shift value larger than the target data width. The
behavior of C compilers is undefined in this case and can
cause unpredictable results, and therefore the case must
be detected and avoided. (Fiodor Suietov)
Added an info message whenever an SSDT or OEM table
is loaded dynamically via the Load() or LoadTable()
ASL operators. This should improve debugging capability
since it will show exactly what tables have been loaded
(beyond the tables present in the RSDT/XSDT.)
Converted the locking mutex used for the ACPI hardware
to a spinlock. This change should eliminate all problems
caused by attempting to acquire a semaphore at interrupt
level, and it means that all ACPICA external interfaces
that directly access the ACPI hardware can be safely
called from interrupt level.
Fixed a regression introduced in 20060526 where the ACPI
device initialization could be prematurely aborted with
an AE_NOT_FOUND if a device did not have an optional
_INI method.
Fixed an IndexField issue where a write to the Data
Register should be limited in size to the AccessSize
(width) of the IndexField itself. (BZ 433, Fiodor Suietov)
Fixed problem reports (Valery Podrezov) integrated: - Allow
store of ThermalZone objects to Debug object.
http://bugzilla.kernel.org/show_bug.cgi?id=5369
http://bugzilla.kernel.org/show_bug.cgi?id=5370
acpi_get_table_header() doesn't handle multiple instances
correctly (BZ 364)
Removed four global mutexes that were obsolete and were
no longer being used.
Restructured, flattened, and simplified the internal
interfaces for namespace object evaluation - resulting
in smaller code, less CPU stack use, and fewer
interfaces. (With assistance from Mikhail Kouzmich)
Fixed a problem with the CopyObject operator where the
first parameter was not typed correctly for the parser,
interpreter, compiler, and disassembler. Caused various
errors and unexpected behavior.
Fixed a problem where a ShiftLeft or ShiftRight of
more than 64 bits produced incorrect results with some
C compilers. Since the behavior of C compilers when
the shift value is larger than the datatype width is
apparently not well defined, the interpreter now detects
this condition and simply returns zero as expected in all
such cases. (BZ 395)
Update String-to-Integer conversion to match ACPI 3.0A spec
http://bugzilla.kernel.org/show_bug.cgi?id=5329
Allow interpreter to handle nested method declarations
http://bugzilla.kernel.org/show_bug.cgi?id=5361
acpi_terminate() doesn't free debug memory allocation
list objects (BZ 355) - After Core Subsystem
shutdown, acpi_subsystem_status() returns AE_OK (BZ 356) -
acpi_os_unmap_memory() for RSDP can be invoked inconsistently
(BZ 357) - Resource Manager should return AE_TYPE for
non-device objects (BZ 358) - Incomplete cleanup branch
in AcpiNsEvaluateRelative (BZ 359) - Use acpi_os_free()
instead of ACPI_FREE in acpi_rs_set_srs_method_data (BZ 360)
- Incomplete cleanup branch in acpi_ps_parse_aml (BZ 361) -
Incomplete cleanup branch in acpi_ds_delete_walk_state (BZ 362)
- acpi_get_table_header returns AE_NO_ACPI_TABLES until DSDT
is loaded (BZ 365) - Status of the Global Initialization
Handler call not used (BZ 366) - Incorrect object parameter
to Global Initialization Handler (BZ 367)
Replaced the acpi_os_queue_for_execution() with a new
interface named acpi_os_execute(). The major difference is
that the new interface does not have a Priority parameter,
this appeared to be useless and has been replaced by
a Type parameter. The Type tells the OS what type of
execution is being requested, such as global lock handler,
notify handler, GPE handler, etc. This allows the host
to queue and execute the request as appropriate for the
request type, possibly using different work queues and
different priorities for the various request types. This
enables fixes for multithreading deadlock problems such as
http://bugzilla.kernel.org/show_bug.cgi?id=5534
(Alexey Starikovskiy and Bob Moore)
Fixed a possible memory leak associated with the
support for the so-called "implicit return" ACPI
extension. Reported by FreeBSD (Fiodor Suietov)
http://bugzilla.kernel.org/show_bug.cgi?id=6514
Fixed a problem with the Load() operator where a table
load from an operation region could overwrite an internal
table buffer by up to 7 bytes and cause alignment faults
on IPF systems. (With assistance from Luming Yu)
