path: root/include/acpi/acnames.h
2016-01-15ACPICA: Additional 2016 copyright changesBob Moore
All tool/utility signons. Dual-license module header. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-01ACPICA: Utilities: Add _CLS processingSuravee Suthikulpanit
ACPICA commit 9a2b638acb3a7215209432e070c6bd0312374229 ACPI Device object often contains a _CLS object to supply PCI-defined class code for the device. This patch introduces logic to process the _CLS object. Suravee Suthikulpanit, Lv Zheng. Link: https://github.com/acpica/acpica/commit/9a2b638a Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org> Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-05ACPICA: Update Copyright headers to 2015David E. Box
ACPICA commit 8990e73ab2aa15d6a0068b860ab54feff25bee36 Link: https://github.com/acpica/acpica/commit/8990e73a Signed-off-by: David E. Box <david.e.box@linux.intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-10-21ACPICA: Add string for _DDN method name.Bob Moore
The _DDN method will be used internally. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-09-03ACPICA: Add _PSx names to the METHOD_NAME list.Bob Moore
Will be used by iASL. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-31ACPICA: ACPI 5.1: Support for the _DSD predefined name.David E. Box
Adds full support for _DSD. David Box. Signed-off-by: David E. Box <david.e.box@linux.intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-11ACPICA: Update ACPICA copyrights to 2014.Bob Moore
Update ACPICA copyrights to 2014. Includes all source headers and signons for the various tools. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-30ACPICA: Predefine name macros: Sort list.Bob Moore
Sort the method names in acnames.h. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25ACPICA: Update ACPICA copyrights to 2013Bob Moore
2012-11-15ACPICA: AcpiGetObjectInfo: Add support for ACPI 5 _SUB methodBob Moore
Now calls _SUB in addition to the other ID methods: _HID, _CID, and _UID. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-09-21ACPICA: Add support for complex _PLD buffers.Bob Moore
_PLD (Physical Location of Device) returns a bit-packed buffer that is difficult to parse. This change adds a new interface, AcpiDecodePldBuffer that parses the buffer into a more usable local struct. Also adds macros to both get and set individual fields within the packed _PLD buffer. Adds a new include file, acbuffer.h - which will be expanded to add structs for other ACPI names that return buffers. ACPICA BZ 954. Emit (in comments) the decoded contents of a static _PLD buffer in order to improve comprehension of this bit-packed buffer. Add multi-endian support to the _PLD decode routine. Deploy the multi-endian macros to extract data from the _PLD buffer. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-09-21ACPI: delelte more BFS/GTS related definition and codeFeng Tang
This is a follow on for commmit 3f6f49c7 "ACPI: delete _GTS/_BFS support" to do more cleanup. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-07-26Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull ACPI & power management update from Len Brown: "Re-write of the turbostat tool. lower overhead was necessary for measuring very large system when they are very idle. IVB support in intel_idle It's what I run on my IVB, others should be able to also:-) ACPICA core update We have found some bugs due to divergence between Linux and the upstream ACPICA base. Most of these patches are to reduce that divergence to reduce the risk of future bugs. Some cpuidle updates, mostly for non-Intel More will be coming, as they depend on this part. Some thermal management changes needed by non-ACPI systems. Some _OST (OS Status Indication) updates for hot ACPI hot-plug." * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (51 commits) Thermal: Documentation update Thermal: Add Hysteresis attributes Thermal: Make Thermal trip points writeable ACPI/AC: prevent OOPS on some boxes due to missing check power_supply_register() return value check tools/power: turbostat: fix large c1% issue tools/power: turbostat v2 - re-write for efficiency ACPICA: Update to version 20120711 ACPICA: AcpiSrc: Fix some translation issues for Linux conversion ACPICA: Update header files copyrights to 2012 ACPICA: Add new ACPI table load/unload external interfaces ACPICA: Split file: tbxface.c -> tbxfload.c ACPICA: Add PCC address space to space ID decode function ACPICA: Fix some comment fields ACPICA: Table manager: deploy new firmware error/warning interfaces ACPICA: Add new interfaces for BIOS(firmware) errors and warnings ACPICA: Split exception code utilities to a new file, utexcep.c ACPI: acpi_pad: tune round_robin_time ACPICA: Update to version 20120620 ACPICA: Add support for implicit notify on multiple devices ACPICA: Update comments; no functional change ...
2012-07-17ACPICA: Update header files copyrights to 2012Bob Moore
Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-06-22PCI/ACPI: provide MMCONFIG address for PCI host bridgesJiang Liu
This patch provide MMCONFIG address for PCI host bridges, which will be used to support host bridge hotplug. It gets MMCONFIG address by evaluating _CBA method if available. Reviewed-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jiang Liu <liuj97@gmail.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-03-22ACPICA: Clarify METHOD_NAME* defines for full-pathname casesBob Moore
Changed the METHOD_NAME* defines that define a full pathname to the method to METHOD_PATHNAME* in order to make it clear that it is not a simple 4-character ACPI name. Used for the various sleep/wake methods. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI 5.0: Allow _AEI method in walk resourcesZhang Rui
_AEI contains a resource template, this change adds support for the walk resources function. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-18ACPICA: Update all ACPICA copyrights and signons to 2011Bob Moore
2010-01-22ACPICA: Update all ACPICA copyrights and signons to 2010Bob Moore
Add 2010 copyright to all module headers and signons, including the Linux header. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and all utilities. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-23ACPICA: update Intel copyrightLen Brown
2007-02-02ACPICA: Update copyright to 2007.Bob Moore
Added 2007 copyright to all module headers and signons. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and the utilities. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-20[ACPI] ACPICA 20060113Bob Moore
Added 2006 copyright. At SuSE's suggestion, enabled all error messages without enabling function tracing, ie with CONFIG_ACPI_DEBUG=n Replaced all instances of the ACPI_DEBUG_PRINT macro invoked at the ACPI_DB_ERROR and ACPI_DB_WARN debug levels with the ACPI_REPORT_ERROR and ACPI_REPORT_WARNING macros, respectively. This preserves all error and warning messages in the non-debug version of the ACPICA code (this has been referred to as the "debug lite" option.) Over 200 cases were converted to create a total of over 380 error/warning messages across the ACPICA code. This increases the code and data size of the default non-debug version by about 13K. Added ACPI_NO_ERROR_MESSAGES flag to enable deleting all messages. The size of the debug version remains about the same. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-29[ACPI] ACPICA 20050815Bob Moore
Implemented a full bytewise compare to determine if a table load request is attempting to load a duplicate table. The compare is performed if the table signatures and table lengths match. This will allow different tables with the same OEM Table ID and revision to be loaded. Although the BIOS is technically violating the ACPI spec when this happens -- it does happen -- so Linux must handle it. Signed-off-by: Robert Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
2005-07-30[ACPI] ACPICA 20050729 from Bob MooreRobert Moore
Implemented support to ignore an attempt to install/load a particular ACPI table more than once. Apparently there exists BIOS code that repeatedly attempts to load the same SSDT upon certain events. Thanks to Venkatesh Pallipadi. Restructured the main interface to the AML parser in order to correctly handle all exceptional conditions. This will prevent leakage of the OwnerId resource and should eliminate the AE_OWNER_ID_LIMIT exceptions seen on some machines. Thanks to Alexey Starikovskiy. Support for "module level code" has been disabled in this version due to a number of issues that have appeared on various machines. The support can be enabled by defining ACPI_ENABLE_MODULE_LEVEL_CODE during subsystem compilation. When the issues are fully resolved, the code will be enabled by default again. Modified the internal functions for debug print support to define the FunctionName parameter as a (const char *) for compatibility with compiler built-in macros such as __FUNCTION__, etc. Linted the entire ACPICA source tree for both 32-bit and 64-bit. Signed-off-by: Robert Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12ACPICA 20050408 from Bob MooreRobert Moore
Fixed three cases in the interpreter where an "index" argument to an ASL function was still (internally) 32 bits instead of the required 64 bits. This was the Index argument to the Index, Mid, and Match operators. The "strupr" function is now permanently local (acpi_ut_strupr), since this is not a POSIX-defined function and not present in most kernel-level C libraries. References to the C library strupr function have been removed from the headers. Completed the deployment of static functions/prototypes. All prototypes with the static attribute have been moved from the headers to the owning C file. ACPICA 20050329 from Bob Moore An error is now generated if an attempt is made to create a Buffer Field of length zero (A CreateField with a length operand of zero.) The interpreter now issues a warning whenever executable code at the module level is detected during ACPI table load. This will give some idea of the prevalence of this type of code. Implemented support for references to named objects (other than control methods) within package objects. Enhanced package object output for the debug object. Package objects are now completely dumped, showing all elements. Enhanced miscellaneous object output for the debug object. Any object can now be written to the debug object (for example, a device object can be written, and the type of the object will be displayed.) The "static" qualifier has been added to all local functions across the core subsystem. The number of "long" lines (> 80 chars) within the source has been significantly reduced, by about 1/3. Cleaned up all header files to ensure that all CA/iASL functions are prototyped (even static functions) and the formatting is consistent. Two new header files have been added, acopcode.h and acnames.h. Removed several obsolete functions that were no longer used. Signed-off-by: Len Brown <len.brown@intel.com>
