path: root/include/acpi/acpiosxf.h
2011-07-13ACPI: Fix lockdep false positives in acpi_power_off()Rafael J. Wysocki
All ACPICA locks are allocated by the same function, acpi_os_create_lock(), with the help of a local variable called "lock". Thus, when lockdep is enabled, it uses "lock" as the name of all those locks and regards them as instances of the same lock, which causes it to report possible locking problems with them when there aren't any. To work around this problem, define acpi_os_create_lock() as a macro and make it pass its argument to spin_lock_init(), so that lockdep uses it as the name of the new lock. Define this macron in a Linux-specific file, to minimize the resulting modifications of the OS-independent ACPICA parts. This change is based on an earlier patch from Andrea Righi and it addresses a regression from 2.6.39 tracked as https://bugzilla.kernel.org/show_bug.cgi?id=38152 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Borislav Petkov <bp@alien8.de> Tested-by: Andrea Righi <andrea@betterlinux.com> Reviewed-by: Florian Mickler <florian@mickler.org> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-25ACPI: osl, add acpi_os_create_lock interfaceLin Ming
Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-18ACPICA: Update all ACPICA copyrights and signons to 2011Bob Moore
Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-26Merge branch 'misc' into releaseLen Brown
2010-10-19ACPI: remove dead codeStephen Hemminger
Found by running make namespacecheck on linux-next Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-01ACPICA: Obsolete the acpi_os_derive_pci_id OSL interfaceBob Moore
This function is not OS-dependent and has been replaced by acpi_hw_derive_pci_id, which is now in the ACPICA core code. Local implementations of acpi_os_derive_pci_id are no longer necessary and are removed. ACPICA BZ 857. http://www.acpica.org/bugzilla/show_bug.cgi?id=857 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-01ACPICA/ACPI: Add new host interfaces for _OSI supportLin Ming
Adds install/remove interfaces so that the host can dynamically alter the global _OSI table. Also adds support for _OSI handlers. Additional support: new debugger command (osi), and test support in the acpiexec utility. Adds new file, utilities/utosi.c. ACPICA bugzilla 836. The Linux OSL _OSI code is also changed. acpi_osi_setup can't call acpi_install/remove_interface because ACPICA is not initialized yet at this early time. So we just save the osi string in acpi_osi_setup and will handle it later in a new function acpi_osi_setup_late. http://www.acpica.org/bugzilla/show_bug.cgi?id=836 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-01ACPICA: Fix acpi_os_read_pci_configuration prototypeBob Moore
Prototype in acpiosxf.h had the output value pointer as a (u32 *). Should be a (u64 *). Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-06ACPICA: Update/clarify some parameter names associated with acpi_handleBob Moore
Simple rename of some parameters to standardize them. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-22ACPICA: Remove obsolete ACPI_INTEGER (acpi_integer) typeBob Moore
This type was introduced as the code was migrated from ACPI 1.0 (with 32-bit AML integers) to ACPI 2.0 (with 64-bit integers). It is now obsolete and this change removes it from the ACPICA code base, replaced by u64. The original typedef has been retained for now for compatibility with existing device driver code. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-22ACPICA: Update all ACPICA copyrights and signons to 2010Bob Moore
Add 2010 copyright to all module headers and signons, including the Linux header. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and all utilities. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-27ACPICA: fix leak of acpi_os_validate_addressLin Ming
http://bugzilla.kernel.org/show_bug.cgi?id=13620 If the dynamic region is created and added to resource list over and over again, it has the potential to be a memory leak by growing the list every time. This patch fixes the memory leak, as below 1) add a new field "count" to struct acpi_res_list. When inserting, if the region(addr, len) is already in the resource list, we just increase "count", otherwise, the region is inserted with count=1. When deleting, the "count" is decreased, if it's decreased to 0, the region is deleted from the resource list. With "count", the region with same address and length can only be inserted to the resource list once, so prevent potential memory leak. 2) add a new function acpi_os_invalidate_address, which is called when region is deleted. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-07-27Revert "ACPICA: Remove obsolete acpi_os_validate_address interface"Len Brown
This reverts commit f9ca058430333c9a24c5ca926aa445125f88df18. which caused a regression: http://bugzilla.kernel.org/show_bug.cgi?id=13620 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-05Merge branch 'linus' into releaseLen Brown
Conflicts: arch/x86/kernel/cpu/cpufreq/longhaul.c Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-27ACPICA: Remove obsolete acpi_os_validate_address interfaceBob Moore
This interface is no longer necessary. Requests should be validated on a per-field basis, not on the entire operation region. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-09acpi/x86: introduce __apci_map_table, v4Yinghai Lu
to prevent wrongly overwriting fixmap that still want to use. ACPI used to rely on low mappings being all linearly mapped and grew a habit: it never really unmapped certain kinds of tables after use. This can cause problems - for example the hypothetical case when some spurious access still references it. v2: remove prev_map and prev_size in __apci_map_table v3: let acpi_os_unmap_memory() call early_iounmap too, so remove extral calling to early_acpi_os_unmap_memory v4: fix typo in one acpi_get_table_with_size calling Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-31ACPICA: Add ACPI_MUTEX_TYPE configuration optionBob Moore
Used to specify whether the OSL mutex interfaces should be used, or binary semaphores instead. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-09-23ACPI: fix hotplug raceZhang Rui
The hotplug notification handler and drivers' notification handler all run in one workqueue. Before hotplug removes an acpi device, the device driver's notification handler is already be recorded to run just after global notification handler. After hotplug notification handler runs, acpica will notice a NULL notification handler and crash. So now we run run hotplug in another workqueue and wait for all acpi notication handlers finish. This was found in battery hotplug, but actually all hotplug can be affected. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16ACPICA: Eliminate acpi_native_uint type v2Bob Moore
No longer needed; replaced mostly with u32, but also acpi_size where a type that changes 32/64 bit on 32/64-bit platforms is required. v2: Fix a cast of a 32-bit int to a pointer in ACPI to avoid a compiler warning. from David Howells Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-04-23ACPICA: update Intel copyrightLen Brown
2008-02-13acpi: fix acpi_os_read_pci_configuration() misuse of raw_pci_read()Linus Torvalds
The raw_pci_read() interface (as the raw_pci_ops->read() before it) unconditionally fills in a 32-bit integer return value regardless of the size of the operation requested. So claiming to take a "void *" is wrong, as is passing in a pointer to just a byte variable. Noticed by pageexec when enabling -fstack-protector (which needs other patches too to actually work, but that's a separate issue). Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Merge branches 'release' and 'hwmon-conflicts' into releaseLen Brown
2008-02-07ACPI: track opregion names to avoid driver resource conflicts.Thomas Renninger
Small ACPICA extension to be able to store the name of operation regions in osl.c later In ACPI, AML can define accesses to IO ports and System Memory by Operation Regions. Those are not registered as done by PNPACPI using resource templates (and _CRS/_SRS methods). The IO ports and System Memory regions may get accessed by arbitrary AML code. When native drivers are accessing the same resources bad things can happen (e.g. a critical shutdown temperature of 3000 C every 2 months or so). It is not really possible to register the operation regions via request_resource, as they often overlap with pnp or other resources (e.g. statically setup IO resources below 0x100). This approach stores all Operation Region declarations (IO and System Memory only) at ACPI table parse time. It offers a similar functionality like request_region and let drivers which are known to possibly use the same IO ports and Memory which are also often used by ACPI (hwmon and i2c) check for ACPI interference. A boot parameter acpi_enforce_resources=strict/lax/no is provided, which is default set to lax: - strict: let conflicting drivers fail to load with an error message - lax: let conflicting driver work normal with a warning message - no: no functional change at all Depending on the feedback and the kind of interferences we see, this should be set to strict at later time. Goal of this patch set is: - Identify ACPI interferences in bug reports (very hard to reproduce and to identify) - Find BIOSes for that an ACPI driver should exist for specific HW instead of a native one. - stability in general Provide acpi_check_{mem_}region. Drivers can additionally check against possible ACPI interference by also invoking this shortly before they call request_region. If -EBUSY is returned, the driver must not load. Use acpi_enforce_resources=strict/lax/no options to: - strict: let conflicting drivers fail to load with an error message - lax: let conflicting driver work normal with a warning message - no: no functional change at all Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Len Brown <lenb@kernel.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-06ACPI: create /sys/firmware/acpi/interruptsLen Brown
See Documentation/ABI/testing/sysfs-firmware-acpi Based-on-original-patch-by: Luming Yu <luming.yu@intel.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-30ACPI: add __init to acpi_initialize_subsystem()Len Brown
Add __init to: acpi_initialize_subsystem() (and un-export it) acpi_os_initialize() Add __initdata to: acpi_osl_dmi_table[] Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-29ACPI: extend "acpi_osi=" boot optionLen Brown
The boot option "acpi_osi=" has always disabled Linux _OSI support, thus disabling all OS Interface strings which are advertised by Linux to the BIOS. Now... acpi_osi="string" adds the interface string, and acpi_osi="!string" invalidates the pre-defined interface string eg. acpi_osi="!Windows 2006" would disable Linux's claim of Vista compatibility. Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-09ACPICA: LindentLen Brown
2007-02-15ACPI: remove acpi_os_readable(), acpi_os_writable()Len Brown
...which are now unused Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Update copyright to 2007.Bob Moore
Added 2007 copyright to all module headers and signons. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and the utilities. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Implement simplified Table ManagerBob Moore
The Table Manager component has been completely redesigned and reimplemented. The new design is much simpler, and reduces the overall code and data size of the kernel-resident ACPICA by approximately 5%. Also, it is now possible to obtain the ACPI tables very early during kernel initialization, even before dynamic memory management is initialized. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-30ACPI: delete acpi_os_free(), use kfree() directlyLen Brown
2006-06-28ACPI: ACPICA 20060623Bob Moore
Implemented a new acpi_spinlock type for the OSL lock interfaces. This allows the type to be customized to the host OS for improved efficiency (since a spinlock is usually a very small object.) Implemented support for "ignored" bits in the ACPI registers. According to the ACPI specification, these bits should be preserved when writing the registers via a read/modify/write cycle. There are 3 bits preserved in this manner: PM1_CONTROL[0] (SCI_EN), PM1_CONTROL[9], and PM1_STATUS[11]. http://bugzilla.kernel.org/show_bug.cgi?id=3691 Implemented the initial deployment of new OSL mutex interfaces. Since some host operating systems have separate mutex and semaphore objects, this feature was requested. The base code now uses mutexes (and the new mutex interfaces) wherever a binary semaphore was used previously. However, for the current release, the mutex interfaces are defined as macros to map them to the existing semaphore interfaces. Fixed several problems with the support for the control method SyncLevel parameter. The SyncLevel now works according to the ACPI specification and in concert with the Mutex SyncLevel parameter, since the current SyncLevel is a property of the executing thread. Mutual exclusion for control methods is now implemented with a mutex instead of a semaphore. Fixed three instances of the use of the C shift operator in the bitfield support code (exfldio.c) to avoid the use of a shift value larger than the target data width. The behavior of C compilers is undefined in this case and can cause unpredictable results, and therefore the case must be detected and avoided. (Fiodor Suietov) Added an info message whenever an SSDT or OEM table is loaded dynamically via the Load() or LoadTable() ASL operators. This should improve debugging capability since it will show exactly what tables have been loaded (beyond the tables present in the RSDT/XSDT.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060526Bob Moore
Restructured, flattened, and simplified the internal interfaces for namespace object evaluation - resulting in smaller code, less CPU stack use, and fewer interfaces. (With assistance from Mikhail Kouzmich) Fixed a problem with the CopyObject operator where the first parameter was not typed correctly for the parser, interpreter, compiler, and disassembler. Caused various errors and unexpected behavior. Fixed a problem where a ShiftLeft or ShiftRight of more than 64 bits produced incorrect results with some C compilers. Since the behavior of C compilers when the shift value is larger than the datatype width is apparently not well defined, the interpreter now detects this condition and simply returns zero as expected in all such cases. (BZ 395) Fixed problem reports (Valery Podrezov) integrated: - Update String-to-Integer conversion to match ACPI 3.0A spec http://bugzilla.kernel.org/show_bug.cgi?id=5329 Allow interpreter to handle nested method declarations http://bugzilla.kernel.org/show_bug.cgi?id=5361 Fixed problem reports (Fiodor Suietov) integrated: - acpi_terminate() doesn't free debug memory allocation list objects (BZ 355) - After Core Subsystem shutdown, acpi_subsystem_status() returns AE_OK (BZ 356) - acpi_os_unmap_memory() for RSDP can be invoked inconsistently (BZ 357) - Resource Manager should return AE_TYPE for non-device objects (BZ 358) - Incomplete cleanup branch in AcpiNsEvaluateRelative (BZ 359) - Use acpi_os_free() instead of ACPI_FREE in acpi_rs_set_srs_method_data (BZ 360) - Incomplete cleanup branch in acpi_ps_parse_aml (BZ 361) - Incomplete cleanup branch in acpi_ds_delete_walk_state (BZ 362) - acpi_get_table_header returns AE_NO_ACPI_TABLES until DSDT is loaded (BZ 365) - Status of the Global Initialization Handler call not used (BZ 366) - Incorrect object parameter to Global Initialization Handler (BZ 367) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060512Bob Moore
Replaced the acpi_os_queue_for_execution() with a new interface named acpi_os_execute(). The major difference is that the new interface does not have a Priority parameter, this appeared to be useless and has been replaced by a Type parameter. The Type tells the OS what type of execution is being requested, such as global lock handler, notify handler, GPE handler, etc. This allows the host to queue and execute the request as appropriate for the request type, possibly using different work queues and different priorities for the various request types. This enables fixes for multithreading deadlock problems such as http://bugzilla.kernel.org/show_bug.cgi?id=5534 (Alexey Starikovskiy and Bob Moore) Fixed a possible memory leak associated with the support for the so-called "implicit return" ACPI extension. Reported by FreeBSD (Fiodor Suietov) http://bugzilla.kernel.org/show_bug.cgi?id=6514 Fixed a problem with the Load() operator where a table load from an operation region could overwrite an internal table buffer by up to 7 bytes and cause alignment faults on IPF systems. (With assistance from Luming Yu) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060421Bob Moore
Removed a device initialization optimization introduced in 20051216 where the _STA method was not run unless an _INI was also present for the same device. This optimization could cause problems because it could allow _INI methods to be run within a not-present device subtree (If a not-present device had no _INI, _STA would not be run, the not-present status would not be discovered, and the children of the device would be incorrectly traversed.) Implemented a new _STA optimization where namespace subtrees that do not contain _INI are identified and ignored during device initialization. Selectively running _STA can significantly improve boot time on large machines (with assistance from Len Brown.) Implemented support for the device initialization case where the returned _STA flags indicate a device not-present but functioning. In this case, _INI is not run, but the device children are examined for presence, as per the ACPI specification. Implemented an additional change to the IndexField support in order to conform to MS behavior. The value written to the Index Register is not simply a byte offset, it is a byte offset in units of the access width of the parent Index Field. (Fiodor Suietov) Defined and deployed a new OSL interface, acpi_os_validate_address(). This interface is called during the creation of all AML operation regions, and allows the host OS to exert control over what addresses it will allow the AML code to access. Operation Regions whose addresses are disallowed will cause a runtime exception when they are actually accessed (will not affect or abort table loading.) Defined and deployed a new OSL interface, acpi_os_validate_interface(). This interface allows the host OS to match the various "optional" interface/behavior strings for the _OSI predefined control method as appropriate (with assistance from Bjorn Helgaas.) Restructured and corrected various problems in the exception handling code paths within DsCallControlMethod and DsTerminateControlMethod in dsmethod (with assistance from Takayoshi Kochi.) Modified the Linux source converter to ignore quoted string literals while converting identifiers from mixed to lower case. This will correct problems with the disassembler and other areas where such strings must not be modified. The ACPI_FUNCTION_* macros no longer require quotes around the function name. This allows the Linux source converter to convert the names, now that the converter ignores quoted strings. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060331Bob Moore
Implemented header file support for the following additional ACPI tables: ASF!, BOOT, CPEP, DBGP, MCFG, SPCR, SPMI, TCPA, and WDRT. With this support, all current and known ACPI tables are now defined in the ACPICA headers and are available for use by device drivers and other software. Implemented support to allow tables that contain ACPI names with invalid characters to be loaded. Previously, this would cause the table load to fail, but since there are several known cases of such tables on existing machines, this change was made to enable ACPI support for them. Also, this matches the behavior of the Microsoft ACPI implementation. https://bugzilla.novell.com/show_bug.cgi?id=147621 Fixed a couple regressions introduced during the memory optimization in the 20060317 release. The namespace node definition required additional reorganization and an internal datatype that had been changed to 8-bit was restored to 32-bit. (Valery Podrezov) Fixed a problem where a null pointer passed to acpi_ut_delete_generic_state() could be passed through to acpi_os_release_object which is unexpected. Such null pointers are now trapped and ignored, matching the behavior of the previous implementation before the deployment of acpi_os_release_object(). (Valery Podrezov, Fiodor Suietov) Fixed a memory mapping leak during the deletion of a SystemMemory operation region where a cached memory mapping was not deleted. This became a noticeable problem for operation regions that are defined within frequently used control methods. (Dana Meyers) Reorganized the ACPI table header files into two main files: one for the ACPI tables consumed by the ACPICA core, and another for the miscellaneous ACPI tables that are consumed by the drivers and other software. The various FADT definitions were merged into one common section and three different tables (ACPI 1.0, 1.0+, and 2.0) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-04-01ACPI: ACPICA 20060310Bob Moore
Tagged all external interfaces to the subsystem with the new ACPI_EXPORT_SYMBOL macro. This macro can be defined as necessary to assist kernel integration. For Linux, the macro resolves to the EXPORT_SYMBOL macro. The default definition is NULL. Added the ACPI_THREAD_ID type for the return value from acpi_os_get_thread_id(). This allows the host to define this as necessary to simplify kernel integration. The default definition is ACPI_NATIVE_UINT. Valery Podrezov fixed two interpreter problems related to error processing, the deletion of objects, and placing invalid pointers onto the internal operator result stack. http://bugzilla.kernel.org/show_bug.cgi?id=6028 http://bugzilla.kernel.org/show_bug.cgi?id=6151 Increased the reference count threshold where a warning is emitted for large reference counts in order to eliminate unnecessary warnings on systems with large namespaces (especially 64-bit.) Increased the value from 0x400 to 0x800. Due to universal disagreement as to the meaning of the 'c' in the calloc() function, the ACPI_MEM_CALLOCATE macro has been renamed to ACPI_ALLOCATE_ZEROED so that the purpose of the interface is 'clear'. ACPI_MEM_ALLOCATE and ACPI_MEM_FREE are renamed to ACPI_ALLOCATE and ACPI_FREE. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-31[ACPI] ACPICA 20060127Bob Moore
Implemented support in the Resource Manager to allow unresolved namestring references within resource package objects for the _PRT method. This support is in addition to the previously implemented unresolved reference support within the AML parser. If the interpreter slack mode is enabled (true on Linux unless acpi=strict), these unresolved references will be passed through to the caller as a NULL package entry. http://bugzilla.kernel.org/show_bug.cgi?id=5741 Implemented and deployed new macros and functions for error and warning messages across the subsystem. These macros are simpler and generate less code than their predecessors. The new macros ACPI_ERROR, ACPI_EXCEPTION, ACPI_WARNING, and ACPI_INFO replace the ACPI_REPORT_* macros. Implemented the acpi_cpu_flags type to simplify host OS integration of the Acquire/Release Lock OSL interfaces. Suggested by Steven Rostedt and Andrew Morton. Fixed a problem where Alias ASL operators are sometimes not correctly resolved. causing AE_AML_INTERNAL http://bugzilla.kernel.org/show_bug.cgi?id=5189 http://bugzilla.kernel.org/show_bug.cgi?id=5674 Fixed several problems with the implementation of the ConcatenateResTemplate ASL operator. As per the ACPI specification, zero length buffers are now treated as a single EndTag. One-length buffers always cause a fatal exception. Non-zero length buffers that do not end with a full 2-byte EndTag cause a fatal exception. Fixed a possible structure overwrite in the AcpiGetObjectInfo external interface. (With assistance from Thomas Renninger) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-20[ACPI] ACPICA 20060113Bob Moore
Added 2006 copyright. At SuSE's suggestion, enabled all error messages without enabling function tracing, ie with CONFIG_ACPI_DEBUG=n Replaced all instances of the ACPI_DEBUG_PRINT macro invoked at the ACPI_DB_ERROR and ACPI_DB_WARN debug levels with the ACPI_REPORT_ERROR and ACPI_REPORT_WARNING macros, respectively. This preserves all error and warning messages in the non-debug version of the ACPICA code (this has been referred to as the "debug lite" option.) Over 200 cases were converted to create a total of over 380 error/warning messages across the ACPICA code. This increases the code and data size of the default non-debug version by about 13K. Added ACPI_NO_ERROR_MESSAGES flag to enable deleting all messages. The size of the debug version remains about the same. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-10[ACPI] ACPICA 20051021Bob Moore
Implemented support for the EM64T and other x86_64 processors. This essentially entails recognizing that these processors support non-aligned memory transfers. Previously, all 64-bit processors were assumed to lack hardware support for non-aligned transfers. Completed conversion of the Resource Manager to nearly full table-driven operation. Specifically, the resource conversion code (convert AML to internal format and the reverse) and the debug code to dump internal resource descriptors are fully table-driven, reducing code and data size and improving maintainability. The OSL interfaces for Acquire and Release Lock now use a 64-bit flag word on 64-bit processors instead of a fixed 32-bit word. (Alexey Starikovskiy) Implemented support within the resource conversion code for the Type-Specific byte within the various ACPI 3.0 *WordSpace macros. Fixed some issues within the resource conversion code for the type-specific flags for both Memory and I/O address resource descriptors. For Memory, implemented support for the MTP and TTP flags. For I/O, split the TRS and TTP flags into two separate fields. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
2005-07-13ACPICA 20050617-0624 from Bob Moore <robert.moore@intel.com>Robert Moore
ACPICA 20050617: Moved the object cache operations into the OS interface layer (OSL) to allow the host OS to handle these operations if desired (for example, the Linux OSL will invoke the slab allocator). This support is optional; the compile time define ACPI_USE_LOCAL_CACHE may be used to utilize the original cache code in the ACPI CA core. The new OSL interfaces are shown below. See utalloc.c for an example implementation, and acpiosxf.h for the exact interface definitions. Thanks to Alexey Starikovskiy. acpi_os_create_cache acpi_os_delete_cache acpi_os_purge_cache acpi_os_acquire_object acpi_os_release_object Modified the interfaces to acpi_os_acquire_lock and acpi_os_release_lock to return and restore a flags parameter. This fits better with many OS lock models. Note: the current execution state (interrupt handler or not) is no longer passed to these interfaces. If necessary, the OSL must determine this state by itself, a simple and fast operation. Thanks to Alexey Starikovskiy. Fixed a problem in the ACPI table handling where a valid XSDT was assumed present if the revision of the RSDP was 2 or greater. According to the ACPI specification, the XSDT is optional in all cases, and the table manager therefore now checks for both an RSDP >=2 and a valid XSDT pointer. Otherwise, the RSDT pointer is used. Some ACPI 2.0 compliant BIOSs contain only the RSDT. Fixed an interpreter problem with the Mid() operator in the case of an input string where the resulting output string is of zero length. It now correctly returns a valid, null terminated string object instead of a string object with a null pointer. Fixed a problem with the control method argument handling to allow a store to an Arg object that already contains an object of type Device. The Device object is now correctly overwritten. Previously, an error was returned. ACPICA 20050624: Modified the new OSL cache interfaces to use ACPI_CACHE_T as the type for the host-defined cache object. This allows the OSL implementation to define and type this object in any manner desired, simplifying the OSL implementation. For example, ACPI_CACHE_T is defined as kmem_cache_t for Linux, and should be defined in the OS-specific header file for other operating systems as required. Changed the interface to AcpiOsAcquireObject to directly return the requested object as the function return (instead of ACPI_STATUS.) This change was made for performance reasons, since this is the purpose of the interface in the first place. acpi_os_acquire_object is now similar to the acpi_os_allocate interface. Thanks to Alexey Starikovskiy. Modified the initialization sequence in acpi_initialize_subsystem to call the OSL interface acpi_osl_initialize first, before any local initialization. This change was required because the global initialization now calls OSL interfaces. Restructured the code base to split some files because of size and/or because the code logically belonged in a separate file. New files are listed below. utilities/utcache.c /* Local cache interfaces */ utilities/utmutex.c /* Local mutex support */ utilities/utstate.c /* State object support */ parser/psloop.c /* Main AML parse loop */ Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12ACPICA 20050408 from Bob MooreRobert Moore
Fixed three cases in the interpreter where an "index" argument to an ASL function was still (internally) 32 bits instead of the required 64 bits. This was the Index argument to the Index, Mid, and Match operators. The "strupr" function is now permanently local (acpi_ut_strupr), since this is not a POSIX-defined function and not present in most kernel-level C libraries. References to the C library strupr function have been removed from the headers. Completed the deployment of static functions/prototypes. All prototypes with the static attribute have been moved from the headers to the owning C file. ACPICA 20050329 from Bob Moore An error is now generated if an attempt is made to create a Buffer Field of length zero (A CreateField with a length operand of zero.) The interpreter now issues a warning whenever executable code at the module level is detected during ACPI table load. This will give some idea of the prevalence of this type of code. Implemented support for references to named objects (other than control methods) within package objects. Enhanced package object output for the debug object. Package objects are now completely dumped, showing all elements. Enhanced miscellaneous object output for the debug object. Any object can now be written to the debug object (for example, a device object can be written, and the type of the object will be displayed.) The "static" qualifier has been added to all local functions across the core subsystem. The number of "long" lines (> 80 chars) within the source has been significantly reduced, by about 1/3. Cleaned up all header files to ensure that all CA/iASL functions are prototyped (even static functions) and the formatting is consistent. Two new header files have been added, acopcode.h and acnames.h. Removed several obsolete functions that were no longer used. Signed-off-by: Len Brown <len.brown@intel.com>
