path: root/include/acpi/acpixf.h
2009-09-08ACPICA: Update version to 20090903.Bob Moore
Version 20090903. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-28ACPICA: Update version to 20090730Bob Moore
Version 20090730. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-27ACPICA: Update version to 20090625Bob Moore
Update version number. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-27ACPICA: Major update for acpi_get_object_info external interfaceBob Moore
Completed a major update for the acpi_get_object_info external interface. Changes include: - Support for variable, unlimited length HID, UID, and CID strings - Support Processor objects the same as Devices (HID,UID,CID,ADR,STA, etc.) - Call the _SxW power methods on behalf of a device object - Determine if a device is a PCI root bridge - Change the ACPI_BUFFER parameter to ACPI_DEVICE_INFO. These changes will require an update to all callers of this interface. See the ACPICA Programmer Reference for details. Also, update all invocations of acpi_get_object_info interface Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-27ACPICA: Add 64-bit support to acpi_read and acpi_writeBob Moore
Needed by drivers for new ACPi tables. Internal versions of these functions still use 32-bit max transfers, in order to minimize disruption and stack use for the standard ACPI registers (FADT-based). Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-27ACPICA: Remove duplicate extern declarations for public globalsBob Moore
Some were defined twice, causes a warning with gcc -Wredundant-decls. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-05-27ACPICA: Update version to 20090521.Bob Moore
2009-05-27ACPICA: New: AcpiInstallMethod - install a single control methodLin Ming
This interface enables the override or creation of a single control method. Useful to repair a bug or install a missing method. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-05-27ACPICA: Update version to 20090422.Bob Moore
Version 20090422. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-05-27ACPICA: Update error/warning interfacesBob Moore
Moved the module name and line number to the end of the message. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-07hwmon: Add Asus ATK0110 supportLuca Tettamanti
Asus boards have an ACPI interface for interacting with the hwmon (fan, temperatures, voltages) subsystem; this driver exposes the relevant information via the standard sysfs interface. There are two different ACPI interfaces: - an old one (based on RVLT/RFAN/RTMP) - a new one (GGRP/GITM) Both may be present but there a few cases (my board, sigh) where the new interface is just an empty stub; the driver defaults to the old one when both are present. The old interface has received a considerable testing, but I'm still awaiting confirmation from my tester that the new one is working as expected (hence the debug code is still enabled). Currently all the attributes are read-only, though a (partial) control should be possible with a bit more work. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-04-05Merge branch 'linus' into releaseLen Brown
Conflicts: arch/x86/kernel/cpu/cpufreq/longhaul.c Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-27ACPICA: Update version to 20090320Bob Moore
Version 20090320. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-26ACPICA: Update version to 20090220Bob Moore
Version 20090220. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-26ACPICA: Rename ACPI bit register access functionsBob Moore
Rename acpi_get_register and acpi_set_register to clarify the purpose of these functions. New names are acpi_read_bit_register and acpi_write_bit_register. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-26ACPICA: Optimize ACPI register lockingBob Moore
Removed locking for reads from the ACPI bit registers in PM1 Status, Enable, Control, and PM2 Control. The lock is not required when reading the single-bit registers. The acpi_get_register_unlocked function is no longer needed and has been removed. This will improve performance for reads on these registers. ACPICA BZ 760. http://www.acpica.org/bugzilla/show_bug.cgi?id=760 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-26ACPICA: Conditionally compile acpi_set_firmware_waking_vector64Bob Moore
This function is only needed on 64-bit host operating systems. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-26ACPICA: Update version to 20090123Bob Moore
Update version to 20090123. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-09acpi/x86: introduce __apci_map_table, v4Yinghai Lu
to prevent wrongly overwriting fixmap that still want to use. ACPI used to rely on low mappings being all linearly mapped and grew a habit: it never really unmapped certain kinds of tables after use. This can cause problems - for example the hypothetical case when some spurious access still references it. v2: remove prev_map and prev_size in __apci_map_table v3: let acpi_os_unmap_memory() call early_iounmap too, so remove extral calling to early_acpi_os_unmap_memory v4: fix typo in one acpi_get_table_with_size calling Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-09Merge branch 'misc' into releaseLen Brown
Conflicts: include/acpi/acpixf.h Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-09ACPI : Use RSDT instead of XSDT by adding boot option of "acpi=rsdt"Zhao Yakui
On some boxes there exist both RSDT and XSDT table. But unfortunately sometimes there exists the following error when XSDT table is used: a. 32/64X address mismatch b. The 32/64X FACS address mismatch In such case the boot option of "acpi=rsdt" is provided so that RSDT is tried instead of XSDT table when the system can't work well. http://bugzilla.kernel.org/show_bug.cgi?id=8246 Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> cc:Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-31ACPICA: Update version to 20081204.robert.moore@intel.com
2008-12-31ACPICA: Restructure includes into public/privateBob Moore
acpi.h now includes only the "public" acpica headers. All other acpica headers are "private" and should not be included by acpica users. One new file, accommon.h is used to include the commonly used private headers for acpica code generation. Future plans are to move all private headers to a new subdirectory. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-31ACPICA: New: acpi_reset interface - write to reset registerBob Moore
Uses the FADT-defined reset register and reset value. Checks the FADT flags for the reset register supported bit. Supports reset register in memory or I/O space, but not in PCI config space since the host has the information to do it. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-31ACPICA: New: acpi_read and acpi_write public interfacesBob Moore
Changed the acpi_hw_low_level_read and acpi_hw_low_level_write functions to the public acpi_read and acpi_write to allow direct access to ACPI registers. Removed the "width" parameter since the width can be obtained from the input GAS structure. Updated the FADT initialization to setup the GAS structures with the proper widths. Some widths are still hardcoded because many FADTs have incorrect register lengths. Signed-off-by: Bob Moore <robert.moore@intel.com Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-31ACPICA: New: Public GPE group enable/disable interfacesBob Moore
Added acpi_disable_all_gpes and acpi_enable_all_runtime_gpes for public use. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-31ACPICA: New: acpi_get_gpe_device interfaceBob Moore
This function maps an input GPE index to a GPE block device. Also Added acpi_current_gpe_count to track the current number of GPEs that are being managed by the ACPICA core (both FADT-based GPEs and the GPEs contained in GPE block devices.) Modify drivers/acpi/system.c to use these 2 new interfaces Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-31ACPI: osl.c: replace return_ACPI_STATUS with returnLin Ming
return_ACPI_STATUS is an internal acpica function, replace it with return. acpi_gbl_permanent_mmap moved from acglobal.h to acpixf.h for external use Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-29ACPICA: Update FACS waking vector interfacesBob Moore
Split AcpiSetFirmwareWakingVector into two: one for the 32-bit vector, another for the 64-bit vector. This is required because the host OS must setup the wake much differently for each vector (real vs. protected mode, etc.) and the interface should not be deciding which vector to use. Also eliminate the GetFirmwareWakingVector interface, as it served no purpose (only the firmware reads the vector, OS only writes the vector.) ACPICA BZ 731. http://www.acpica.org/bugzilla/show_bug.cgi?id=731 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-11-11ACPICA: Use spinlock for acpi_{en|dis}able_gpeAlexey Starikovskiy
Disabling gpe might interfere with gpe detection/handling, thus producing "interrupt not handled" errors. Ironically, disabling of GPE from interrupt context is already under spinlock, so only userspace needs to start using it. Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16ACPI: Enhance /sys/firmware/interrupts to allow enable/disable/clear from ↵Zhang Rui
user-space Allow users to enable/disable/clear a specific & valid GPE/Fixed Event in user space. This is useful for debugging, especially for some interrupt storm issues. All wakeup GPEs are disabled and they can not be enabled at runtime, and we mark them as invalid. All GPEs that don't have a _Lxx/_Exx method are marked as invalid. All Fixed Events that don't have an event handler are marked as invalid and they can't be enabled until an event handler is registered. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Ling Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPICA: Eliminate acpi_native_uint type v2Bob Moore
No longer needed; replaced mostly with u32, but also acpi_size where a type that changes 32/64 bit on 32/64-bit platforms is required. v2: Fix a cast of a 32-bit int to a pointer in ACPI to avoid a compiler warning. from David Howells Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-04-23ACPICA: update Intel copyrightLen Brown
2008-04-22ACPICA: New interfaces for table event handlersLin Ming
Designed and implemented new external interfaces to install and remove handlers for ACPI table-related events. Current events that are defined are LOAD and UNLOAD. These interfaces allow the host to track ACPI tables as they are dynamically loaded and unloaded. See AcpiInstallTableHandler and AcpiRemoveTableHandler. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-03include/acpi/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-01ACPI: Separate invocations of _GTS and _BFS from _PTS and _WAKRafael J. Wysocki
The execution of ACPI global control methods _GTS and _BFS is currently tied to the preparation to enter a sleep state and to the leaving of the sleep state, respectively. However, these functions are called before disabling the nonboot CPUs and after enabling them, respectively (in fact, on ACPI 1.0x systems the first of them ought to be called before suspending devices), while according to the ACPI specification, _GTS is to be executed right prior to entering the system sleep state and _BFS is to be executed right after the platfor firmware has returned control to the OS on wake up. Move the execution of _GTS and _BFS to the right places. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-10ACPICA: hw: Don't carry spinlock over suspendAlexey Starikovskiy
ACPI uses acpi_get_register() in order to get into suspend. This function is guarded by acpi_gbl_hardware_lock, which will be carried into resume phase. At resume interrupts are enabled and first ACPI interrupt deadlocks on this lock. Solution seems to be to not lock register read, as there are no concurrent activity at this point. Reference: http://bugzilla.kernel.org/show_bug.cgi?id=7499 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-08-25ACPI: Fix a warning of discarding qualifiers from pointer target typeAl Viro
drivers/acpi/ec.c: In function `acpi_ec_ecdt_probe': drivers/acpi/ec.c:873: warning: passing arg 1 of `acpi_get_devices' discards qualifiers from pointer target type Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-30ACPI: add __init to acpi_initialize_subsystem()Len Brown
Add __init to: acpi_initialize_subsystem() (and un-export it) acpi_os_initialize() Add __initdata to: acpi_osl_dmi_table[] Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Update copyright to 2007.Bob Moore
Added 2007 copyright to all module headers and signons. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and the utilities. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Miscellaneous table manager updates and optimizationsAlexey Starikovskiy
2007-02-02ACPICA: Remove obsolete Flags parameter.Bob Moore
Remove flags parameter for acpi_{get,set}_register(). It is no longer necessary now that these functions use a spinlock for mutual exclusion. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Implement simplified Table ManagerBob Moore
The Table Manager component has been completely redesigned and reimplemented. The new design is much simpler, and reduces the overall code and data size of the kernel-resident ACPICA by approximately 5%. Also, it is now possible to obtain the ACPI tables very early during kernel initialization, even before dynamic memory management is initialized. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-12-20ACPI: Add support for acpi_load_table/acpi_unload_table_idJohn Keller
Make acpi_load_table() available for use by removing it from the #ifdef ACPI_FUTURE_USAGE. Also add a new routine used to unload an ACPI table of a given type and "id" - acpi_unload_table_id(). The implementation of this new routine was almost a direct copy of existing routine acpi_unload_table() - only difference being that it only removes a specific table id instead of ALL tables of a given type. The SN hotplug driver (sgi_hotplug.c) now uses both of these interfaces to dynamically load and unload SSDT ACPI tables. Also, a few other ACPI routines now used by the SN hotplug driver are exported (since the driver can be a loadable module): acpi_ns_map_handle_to_node acpi_ns_convert_entry_to_handle acpi_ns_get_next_node Signed-off-by: Aaron Young <ayoung@sgi.com> Cc: Greg KH <greg@kroah.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14[ACPI] ACPICA 20060317Bob Moore
Implemented the use of a cache object for all internal namespace nodes. Since there are about 1000 static nodes in a typical system, this will decrease memory use for cache implementations that minimize per-allocation overhead (such as a slab allocator.) Removed the reference count mechanism for internal namespace nodes, since it was deemed unnecessary. This reduces the size of each namespace node by about 5%-10% on all platforms. Nodes are now 20 bytes for the 32-bit case, and 32 bytes for the 64-bit case. Optimized several internal data structures to reduce object size on 64-bit platforms by packing data within the 64-bit alignment. This includes the frequently used ACPI_OPERAND_OBJECT, of which there can be ~1000 static instances corresponding to the namespace objects. Added two new strings for the predefined _OSI method: "Windows 2001.1 SP1" and "Windows 2006". Split the allocation tracking mechanism out to a separate file, from utalloc.c to uttrack.c. This mechanism appears to be only useful for application-level code. Kernels may wish to not include uttrack.c in distributions. Removed all remnants of the obsolete ACPI_REPORT_* macros and the associated code. (These macros have been replaced by the ACPI_ERROR and ACPI_WARNING macros.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-20[ACPI] ACPICA 20060113Bob Moore
Added 2006 copyright. At SuSE's suggestion, enabled all error messages without enabling function tracing, ie with CONFIG_ACPI_DEBUG=n Replaced all instances of the ACPI_DEBUG_PRINT macro invoked at the ACPI_DB_ERROR and ACPI_DB_WARN debug levels with the ACPI_REPORT_ERROR and ACPI_REPORT_WARNING macros, respectively. This preserves all error and warning messages in the non-debug version of the ACPICA code (this has been referred to as the "debug lite" option.) Over 200 cases were converted to create a total of over 380 error/warning messages across the ACPICA code. This increases the code and data size of the default non-debug version by about 13K. Added ACPI_NO_ERROR_MESSAGES flag to enable deleting all messages. The size of the debug version remains about the same. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-10[ACPI] ACPICA 20051117Bob Moore
Fixed a problem in the AML parser where the method thread count could be decremented below zero if any errors occurred during the method parse phase. This should eliminate AE_AML_METHOD_LIMIT exceptions seen on some machines. This also fixed a related regression with the mechanism that detects and corrects methods that cannot properly handle reentrancy (related to the deployment of the new OwnerId mechanism.) Eliminated the pre-parsing of control methods (to detect errors) during table load. Related to the problem above, this was causing unwind issues if any errors occurred during the parse, and it seemed to be overkill. A table load should not be aborted if there are problems with any single control method, thus rendering this feature rather pointless. Fixed a problem with the new table-driven resource manager where an internal buffer overflow could occur for small resource templates. Implemented a new external interface, acpi_get_vendor_resource() This interface will find and return a vendor-defined resource descriptor within a _CRS or _PRS method via an ACPI 3.0 UUID match. (from Bjorn Helgaas) Removed the length limit (200) on string objects as per the upcoming ACPI 3.0A specification. This affects the following areas of the interpreter: 1) any implicit conversion of a Buffer to a String, 2) a String object result of the ASL Concatentate operator, 3) the String object result of the ASL ToString operator. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-10[ACPI] ACPICA 20050930Bob Moore
Completed a major overhaul of the Resource Manager code - specifically, optimizations in the area of the AML/internal resource conversion code. The code has been optimized to simplify and eliminate duplicated code, CPU stack use has been decreased by optimizing function parameters and local variables, and naming conventions across the manager have been standardized for clarity and ease of maintenance (this includes function, parameter, variable, and struct/typedef names.) All Resource Manager dispatch and information tables have been moved to a single location for clarity and ease of maintenance. One new file was created, named "rsinfo.c". The ACPI return macros (return_ACPI_STATUS, etc.) have been modified to guarantee that the argument is not evaluated twice, making them less prone to macro side-effects. However, since there exists the possibility of additional stack use if a particular compiler cannot optimize them (such as in the debug generation case), the original macros are optionally available. Note that some invocations of the return_VALUE macro may now cause size mismatch warnings; the return_UINT8 and return_UINT32 macros are provided to eliminate these. (From Randy Dunlap) Implemented a new mechanism to enable debug tracing for individual control methods. A new external interface, acpi_debug_trace(), is provided to enable this mechanism. The intent is to allow the host OS to easily enable and disable tracing for problematic control methods. This interface can be easily exposed to a user or debugger interface if desired. See the file psxface.c for details. acpi_ut_callocate() will now return a valid pointer if a length of zero is specified - a length of one is used and a warning is issued. This matches the behavior of acpi_ut_allocate(). Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
2005-07-13ACPICA from Bob Moore <robert.moore@intel.com>Robert Moore
Implemented support for PCI Express root bridges -- added support for device PNP0A08 in the root bridge search within AcpiEvPciConfigRegionSetup. acpi_ev_pci_config_region_setup(). The interpreter now automatically truncates incoming 64-bit constants to 32 bits if currently executing out of a 32-bit ACPI table (Revision < 2). This also affects the iASL compiler constant folding. (Note: as per below, the iASL compiler no longer allows 64-bit constants within 32-bit tables.) Fixed a problem where string and buffer objects with "static" pointers (pointers to initialization data within an ACPI table) were not handled consistently. The internal object copy operation now always copies the data to a newly allocated buffer, regardless of whether the source object is static or not. Fixed a problem with the FromBCD operator where an implicit result conversion was improperly performed while storing the result to the target operand. Since this is an "explicit conversion" operator, the implicit conversion should never be performed on the output. Fixed a problem with the CopyObject operator where a copy to an existing named object did not always completely overwrite the existing object stored at name. Specifically, a buffer-to-buffer copy did not delete the existing buffer. Replaced "interrupt_level" with "interrupt_number" in all GPE interfaces and structs for consistency. Signed-off-by: Len Brown <len.brown@intel.com>
