path: root/include/acpi/actbl.h
2017-07-20ACPICA: Tables: Add deferred table verification supportLv Zheng
ACPICA commit 2dd6c151d5d5e76dacba8f7db9e259fc72982d17 ACPICA commit ffddee6638aced83be18b8bc88569586c1a43e03 This patch allows tables not verified in early stage verfied in acpi_reallocate_root_table(). This is useful for OSPMs like linux where tables cannot be verified in early stage due to early ioremp limitations on some architectures. Reported by Hans de Geode, fixed by Lv Zheng. Link: https://github.com/acpica/acpica/commit/2dd6c151 Link: https://github.com/acpica/acpica/commit/ffddee66 Reported-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2017-06-12ACPICA: Tables: Mechanism to handle late stage acpi_get_table() imbalanceLv Zheng
Considering this case: 1. A program opens a sysfs table file 65535 times, it can increase validation_count and first increment cause the table to be mapped: validation_count = 65535 2. AML execution causes "Load" to be executed on the same table, this time it cannot increase validation_count, so validation_count remains: validation_count = 65535 3. The program closes sysfs table file 65535 times, it can decrease validation_count and the last decrement cause the table to be unmapped: validation_count = 0 4. AML code still accessing the loaded table, kernel crash can be observed. To prevent that from happening, add a validation_count threashold. When it is reached, the validation_count can no longer be incremented/decremented to invalidate the table descriptor (means preventing table unmappings) Note that code added in acpi_tb_put_table() is actually a no-op but changes the warning message into a "warn once" one. Lv Zheng. Signed-off-by: Lv Zheng <lv.zheng@intel.com> [ rjw: Changelog, comments ] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2017-02-09ACPICA: Source tree: Update copyright notices to 2017Bob Moore
ACPICA commit 16577e5265923f4999b4d2c0addb2343b18135e1 Affects all files. Link: https://github.com/acpica/acpica/commit/16577e52 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-12-21ACPICA: Tables: Back port acpi_get_table_with_size() and ↵Lv Zheng
early_acpi_os_unmap_memory() from Linux kernel ACPICA commit cac6790954d4d752a083e6122220b8a22febcd07 This patch back ports Linux acpi_get_table_with_size() and early_acpi_os_unmap_memory() into ACPICA upstream to reduce divergences. The 2 APIs are used by Linux as table management APIs for long time, it contains a hidden logic that during the early stage, the mapped tables should be unmapped before the early stage ends. During the early stage, tables are handled by the following sequence: acpi_get_table_with_size(); parse the table early_acpi_os_unmap_memory(); During the late stage, tables are handled by the following sequence: acpi_get_table(); parse the table Linux uses acpi_gbl_permanent_mmap to distinguish the early stage and the late stage. The reasoning of introducing acpi_get_table_with_size() is: ACPICA will remember the early mapped pointer in acpi_get_table() and Linux isn't able to prevent ACPICA from using the wrong early mapped pointer during the late stage as there is no API provided from ACPICA to be an inverse of acpi_get_table() to forget the early mapped pointer. But how ACPICA can work with the early/late stage requirement? Inside of ACPICA, tables are ensured to be remained in "INSTALLED" state during the early stage, and they are carefully not transitioned to "VALIDATED" state until the late stage. So the same logic is in fact implemented inside of ACPICA in a different way. The gap is only that the feature is not provided to the OSPMs in an accessible external API style. It then is possible to fix the gap by providing an inverse of acpi_get_table() from ACPICA, so that the two Linux sequences can be combined: acpi_get_table(); parse the table acpi_put_table(); In order to work easier with the current Linux code, acpi_get_table() and acpi_put_table() is implemented in a usage counting based style: 1. When the usage count of the table is increased from 0 to 1, table is mapped and .Pointer is set with the mapping address (VALIDATED); 2. When the usage count of the table is decreased from 1 to 0, .Pointer is unset and the mapping address is unmapped (INVALIDATED). So that we can deploy the new APIs to Linux with minimal effort by just invoking acpi_get_table() in acpi_get_table_with_size() and invoking acpi_put_table() in early_acpi_os_unmap_memory(). Lv Zheng. Link: https://github.com/acpica/acpica/commit/cac67909 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-11-14Revert "ACPICA: FADT support cleanup"Rafael J. Wysocki
Pavel Machek reports that commit 6ea8c546f365 (ACPICA: FADT support cleanup) breaks thermal management on his Thinkpad X60 and T40p, so revert it. Link: https://bugzilla.kernel.org/show_bug.cgi?id=187311 Fixes: 6ea8c546f365 (ACPICA: FADT support cleanup) Reported-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-08-13ACPICA: FADT support cleanupBob Moore
ACPICA commit 34ccd43af3fd1870fddfac0617dd0ba706963558 Remove all vestiges of the version 2 FADT which never was included in the ACPI specification. This enabled significant cleanup of both the data table compiler and the disassembler. Added many clarification comments to associate each FADT version with the version of the ACPI spec where it was originally defined. Link: https://github.com/acpica/acpica/commit/34ccd43a Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-05ACPICA: Tables: Update FADT handlingBob Moore
ACPICA commit bca0c4cb063ee488c543e6f160fe89679a2338d6 Update a warning message simplify versioning for "table too big" case. Link: https://github.com/acpica/acpica/commit/bca0c4cb Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-01-15ACPICA: Additional 2016 copyright changesBob Moore
All tool/utility signons. Dual-license module header. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-01ACPICA: Namespace: Add support of OSDT tableBob Moore
ACPICA commit 27415c82fcecf467446f66d1007a0691cc5f3709 This patch adds OSDT (Override System Definition Table) support. When OSDT is loaded, conflict namespace objects will be overridden by the AML interpreter. Bob Moore, Lv Zheng. Link: https://github.com/acpica/acpica/commit/27415c82 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-05-22ACPICA: ACPI 6.0: Add changes for FADT table.Bob Moore
ACPICA commit 72b0b6741990f619f6aaa915302836b7cbb41ac4 One new 64-bit field at the end of the table. FADT version is now 6. Link: https://github.com/acpica/acpica/commit/72b0b674 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-05ACPICA: Update Copyright headers to 2015David E. Box
ACPICA commit 8990e73ab2aa15d6a0068b860ab54feff25bee36 Link: https://github.com/acpica/acpica/commit/8990e73a Signed-off-by: David E. Box <david.e.box@linux.intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-31ACPICA/ARM: ACPI 5.1: Update for FADT changes.Graeme Gregory
Adds ARM flags and FADT minor revision. Graeme Gregory. Signed-off-by: Graeme Gregory <graeme.gregory@linaro.org> Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-20ACPICA: Table Manager: Misc cleanup and renames, no functional change.Bob Moore
Some various cleanups and renames. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-20ACPICA: Tables: Cleanup ACPI_TABLE_ORIGIN_xxx flags.Lv Zheng
This patch refines ACPI_TABLE_ORIGIN_xxx flags. No functional changes. The previous commits have introduced the following internal APIs: 1. acpi_tb_acquire_table: Acquire struct acpi_table_header according to ACPI_TABLE_ORIGIN_xxx flags. 2. acpi_tb_release_table: Release struct acpi_table_header according to ACPI_TABLE_ORIGIN_xxx flags. 3. acpi_tb_install_table: Make struct acpi_table_desc.Address not NULL according to ACPI_TABLE_ORIGIN_xxx flags. 4. acpi_tb_uninstall_table: Make struct acpi_table_desc.Address NULL according to ACPI_TABLE_ORIGIN_xxx flags. 5. acpi_tb_validate_table: Make struct acpi_table_desc.Pointer not NULL according to ACPI_TABLE_ORIGIN_xxx flags. 6. acpi_tb_invalidate_table: Make struct acpi_table_desc.Pointer NULL according to ACPI_TABLE_ORIGIN_xxx flags. It thus detects that the ACPI_TABLE_ORIGIN_UNKNOWN is redundant to ACPI_TABLE_ORIGIN_OVERRIDE. The ACPI_TABLE_ORIGIN_xxTERN_VIRTUAL flags are named as VIRTUAL in order not to confuse with x86 logical address, this patch also renames all "logical override" into "virtual override". Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-03-18ACPICA: Revert "Headers: Deploy #pragma pack (push) and (pop)."Robert Moore
This reverts commit aae576e5faefa8ba70647efa320d4747b6375f1e. Push and Pop are not portable "enough", and caused problems for some ACPICA customers. Signed-off-by: Robert Moore <Robert.Moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-27ACPICA: Headers: Deploy #pragma pack (push) and (pop).Bob Moore
Use push and pop to both guarantee that the correct alignment is used, and to restore the alignment to whatever it was before the header was included. It is reported that the #pragma pack(push/pop) directives are not supported by the specific GCCs, but this patch still doesn't affect kernel build as there are already #pragma pack([1]) directives used in the old ACPICA headers, which means there shouldn't be GCCs that are currently used to compile the ACPI kernels do not support #pragma pack() directives. References: https://bugs.acpica.org/show_bug.cgi?id=1058 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-11ACPICA: Update ACPICA copyrights to 2014.Bob Moore
Update ACPICA copyrights to 2014. Includes all source headers and signons for the various tools. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-01-08ACPICA: Back port and refine validation of the XSDT root table.Lv Zheng
Some platforms contain an XSDT that is ill-formed or otherwise invalid (such as containing some or all entries that are NULL pointers). This change adds a new function to validate the XSDT before actually using it. If the XSDT is found to be invalid, ACPICA will now fall back to using the RSDT instead. This feature is already in the Linux kernel. When it is back ported to ACPICA, code is refined to follow ACPICA coding style and this patch is the generation of the integration. Original-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-31ACPICA: Update RSDP table definitions.Lv Zheng
This patch updates RSDP table header definitions as such enhancement has been made in ACPICA upstream already. It ports that change to the Linux source to reduce source code differences between Linux and ACPICA upstream. This patch does not affect the generation of the Linux kernel binary. [rjw: Changelog] Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25ACPICA: Update ACPICA copyrights to 2013Bob Moore
2013-01-10ACPICA: Cleanup indentation to reduce differences between Linux and ACPICA.Lv Zheng
This is a cosmetic patch only. Comparison of the resulting binary showed only line number differences. This patch does not affect the generation of the Linux binary. This patch decreases 210 lines of 20121018 divergence.diff. The ACPICA source codes uses a totally different indentation style from the Linux to be compatible with other users (operating systems or BIOS). Indentation differences are critical to the release automation. There are two causes related to the "indentation" that are affecting the release automation: 1. The ACPICA -> Linux release process is: ACPICA source -- acpisrc - hierarchy - indent -> linuxized ACPICA source -- diff -> linuxized ACPICA patch (x) -- human intervention -> linuxized ACPICA patch (o) Where 'x' means "cannot be directly applied to the Linux" 'o' means "can be directly applied to the Linux" Different "indent" version or "indent" options used in the "indent" step will lead to different divergences. The version of "indent" used for the current release process is: GNU indent 2.2.11 The options of "indent" used for the current release process is: -npro -kr -i8 -ts8 -sob -l80 -ss -ncs 2. Manual indentation prettifying work in the Linux side will also harm the automatically generated linuxized ACPICA patches, making them impossible to apply directly. This patch fixes source code differences caused by the two causes so that the "human intervention" can be reduced in the future. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-10ACPICA: Cleanup source to reduce differences between Linux and ACPICA.Lv Zheng
This is a cosmetic patch only. Comparison of the resulting binary showed only line number differences. This patch does not affect the generation of the Linux binary. This patch decreases 389 lines of 20121018 divergence.diff. This patch reduces source code diff caused by the simple code maintenance work: 1. Deletion of the unused include files. 2. Deletion of the deprecated codes blocks. 3. Repositioning of the code blocks. 4. Replacing the values with the well defined macros. 5. Replacing the types with the equivalent types. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-09-21ACPICA: Add support for complex _PLD buffers.Bob Moore
_PLD (Physical Location of Device) returns a bit-packed buffer that is difficult to parse. This change adds a new interface, AcpiDecodePldBuffer that parses the buffer into a more usable local struct. Also adds macros to both get and set individual fields within the packed _PLD buffer. Adds a new include file, acbuffer.h - which will be expanded to add structs for other ACPI names that return buffers. ACPICA BZ 954. Emit (in comments) the decoded contents of a static _PLD buffer in order to improve comprehension of this bit-packed buffer. Add multi-endian support to the _PLD decode routine. Deploy the multi-endian macros to extract data from the _PLD buffer. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-09-21ACPICA: Comment update: Fix some typos in actble.hBob Moore
No functional change. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-07-17ACPICA: AcpiSrc: Fix some translation issues for Linux conversionBob Moore
Fixes issues like this: i_aSL -> iASL 00-7_f -> 00-7F local_fADT -> local_FADT execute_oSI -> execute_OSI Also, in function headers, the parameters are now translated to lower case (with underscores if necessary.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-07-17ACPICA: Update header files copyrights to 2012Bob Moore
2012-03-22ACPICA: ACPI 5: Support for new FADT SleepStatus, SleepControl registersBob Moore
Adds sleep and wake support for systems with these registers. One new file, hwxfsleep.c Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI 5.0: Add new/changed tables to headersBob Moore
Adds new file, actbl3.h Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI 5.0: Basic support for FADT version 5Bob Moore
2011-03-02ACPICA: Remove use of unreliable FADT revision fieldBob Moore
The revision number in the FADT has been found to be completely unreliable and cannot be trusted. Only the table length can be used to infer the actual version. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-18ACPICA: Update all ACPICA copyrights and signons to 2011Bob Moore
2010-01-22ACPICA: Update all ACPICA copyrights and signons to 2010Bob Moore
Add 2010 copyright to all module headers and signons, including the Linux header. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and all utilities. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-28ACPICA: ACPI 4: Update headers for new and changed ACPI tables.Bob Moore
Add IVRS,MSCT,UEFI,WAET,WDAT. Updated several existing tables for ACPI 4.0-related changes. Added document references for all tables not defined in ACPI spec. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-28ACPICA: Split large ACPI table headerBob Moore
Split out the non-acpi-defined ACPI tables into the existing (but empty) actbl2.h file. Preparation for new ACPI 4.0 tables. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-27ACPICA: ACPI 4.0: Changes for existing ACPI tables.Bob Moore
FACS: new flag and new OspmFlags field. SRAT: x2APIC - add ClockDomain field to descriptor #2 Includes header and disassembler support. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-26ACPICA: Update FADT flag definitionsBob Moore
Add new flags in the Boot Architecture flags field. Update comments for all FADT flags. Add FADT version when each flag was defined. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-26ACPICA: Allow OS override of all ACPI tablesBob Moore
Previously, the table override mechanism was implemented for the DSDT only. Now, any table in the RSDT/XSDT can be replaced by the host OS. (including the DSDT). Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16ACPI: fix ACPI_FADT_S4_RTC_WAKE commentDavid Brownell
Make the comment for ACPI_FADT_S4_RTC_WAKE match the ACPI spec; that bit has nothing to do with status bits. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-31ACPICA: Restructure includes into public/privateBob Moore
acpi.h now includes only the "public" acpica headers. All other acpica headers are "private" and should not be included by acpica users. One new file, accommon.h is used to include the commonly used private headers for acpica code generation. Future plans are to move all private headers to a new subdirectory. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-28PCI: disable ASPM per ACPI FADT settingShaohua Li
The ACPI FADT table includes an ASPM control bit. If the bit is set, do not enable ASPM since it may indicate that the platform doesn't actually support the feature. Tested-by: Jack Howarth <howarth@bromo.msbb.uc.edu> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-23ACPICA: update Intel copyrightLen Brown
2007-04-25ACPI: Disable MSI on request of FADTShaohua Li
The ACPI spec defines the bit and Microsoft uses it, so Linux must use it too. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Update copyright to 2007.Bob Moore
Added 2007 copyright to all module headers and signons. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and the utilities. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Remove duplicate table definitions.Alexey Starikovskiy
2007-02-02ACPICA: use new ACPI headers.Alexey Starikovskiy
2007-02-02ACPICA: minimal patch to integrate new tables into LinuxAlexey Starikovskiy
2007-02-02ACPICA: Update comments for individual table fieldsBob Moore
comments only Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: misc fixes for new Table Manager:Bob Moore
2007-02-02ACPICA: Implement simplified Table ManagerBob Moore
The Table Manager component has been completely redesigned and reimplemented. The new design is much simpler, and reduces the overall code and data size of the kernel-resident ACPICA by approximately 5%. Also, it is now possible to obtain the ACPI tables very early during kernel initialization, even before dynamic memory management is initialized. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
