installation/uninstallation
ACPICA commit ed6a5fbc694f3a27d93014391aa9a6f6fe490461
This patch adds 2 new table events to indicate table
installation/uninstallation.
Currently, as ACPICA never uninstalls tables, this patch thus only adds
table handler invocation for the table installation event. Lv Zheng.
The 2 events are to be used to fix a sysfs table handling issue related to
LoadTable opcode (see Link # [1] below). The actual sysfs fixing code is
not included, the sysfs fixes will be sent as separate patches.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=150841 # [1]
Link: https://github.com/acpica/acpica/commit/ed6a5fbc
Reported-by: Jason Voelz <jason.voelz@intel.com>
Reported-by: Francisco Leoner <francisco.j.lenoer.soto@intel.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
ACPICA commit fcc129d04f865161f308d3b8743496cc3f4d233e
There are wrong table event macros, this patch cleans them up.
Link: https://bugs.acpica.org/show_bug.cgi?id=1321
Link: https://github.com/acpica/acpica/commit/fcc129d0
fxxx()/errno/perror() instead
ACPICA commit 189429fb7d06cdb89043ae32d615faf553467f1d
This patch follows new ACPICA design, eliminates old portable OSLs, and
implements fopen/fread/fwrite/fclose/fseek/ftell for GNU EFI
environment. This patch also eliminates acpi_log_error(), convering them
into fprintf(stderr)/perror(). Lv Zheng.
Link: https://github.com/acpica/acpica/commit/189429fb
Link: https://bugs.acpica.org/show_bug.cgi?id=1302
ACPICA commit 23a417ca406a527e7ae1710893e59a8b6db30e14
There is a facility in Linux, developers can control the enabling/disabling
of a GPE via /sys/firmware/acpi/interrupts/gpexx. This is mainly for
debugging purposes.
But many users expect to use this facility to implement quirks to mask a
specific GPE when there is a gap in Linux causing this GPE to flood. This
is not working correctly because currently this facility invokes
enabling/disabling counting based GPE driver APIs:
acpi_enable_gpe()/acpi_disable_gpe()
and the GPE drivers can still affect the count to mess up the GPE
masking purposes.
However, most of the IRQ chip designs allow masking/unmasking IRQs via a
masking bit which is different from the enabled bit to achieve the same
purpose. But the GPE hardware doesn't contain such a feature, this brings
the trouble.
In this patch, we introduce a software mechanism to implement the GPE
masking feature, and acpi_mask_gpe() are provided to the OSPMs to
mask/unmask GPEs in the above mentioned situation instead of
acpi_enable_gpe()/acpi_disable_gpe(). ACPICA BZ 1102. Lv Zheng.
Link: https://github.com/acpica/acpica/commit/23a417ca
Link: https://bugs.acpica.org/show_bug.cgi?id=1102
ACPICA commit b2294cae776f5a66a7697414b21949d307e6856f
This patch removes unwanted spaces for typedef. This solution doesn't cover
function types.
Note that the linuxize result of this commit is very giant and should have
many conflicts against the current Linux upstream. Thus it is required to
modify the linuxize result of this commit and the commits around it
manually in order to have them merged to the Linux upstream. Since this is
very costy, we should do this only once, and if we can't ensure to do this
only once, we need to revert the Linux code to the wrong indentation result
before merging the linuxize result of this commit. Lv Zheng.
Link: https://github.com/acpica/acpica/commit/b2294cae
ACPICA commit a240cbb93647bddf525b3daf6e9d31b8b9bca34e
Integrated most changes proposed by net_BSD.
>From joerg@net_BSD.org (Joerg Sonnenberger)
ACPICA BZ 732.
Link: https://github.com/acpica/acpica/commit/a240cbb9
Link: https://bugs.acpica.org/show_bug.cgi?id=732
ACPICA commit 5f21bddaa2cec035ca80608803ce2f0858d4f387
Small changes:
1) A couple new predefined names
2) New _HID values
3) New subtable for HEST
Link: https://github.com/acpica/acpica/commit/5f21bdda
All tool/utility signons.
Dual-license module header.
ACPICA commit e4743959b59ad93eab7310adf756adc930be0ddb
This reverts commit 8e7a8753827660c3dd1f571f3185610402b756f0.
The _SUB method was found to be problematic for this interface
because some implementations use control methods. Therefore,
it is being removed.
Operations cannot be used because this interface is called
during the device discovery scan and the region handlers are
not fully installed at that time.
Link: https://github.com/acpica/acpica/commit/e4743959
ACPICA commit bba222c15c2ce79076eb3a5e9d4d5f7120db8a00
If "Objects" command is invoked with no arguments, the counts
for each object type are displayed.
Linux kernel is not affected by this commit as currently debugger is
not enabled in the Linux kernel.
Link: https://github.com/acpica/acpica/commit/bba222c1
ACPICA commit e8e4a9b19d0b72a7b165398bdc961fc2f6f502ec
This patch adds OSL trace hook support.
OSPMs are encouraged to use acpi_os_trace_point() with
ACPI_USE_SYSTEM_TRACER defined to implement platform specific trace
facility. Lv Zheng.
Link: https://github.com/acpica/acpica/commit/e8e4a9b1
ACPICA commit 6e0229bb156d71675f2e07dc7960adb7ec0a60ea
This patch adds functions to return normalized full path instead of
"external path". The external path contains trailing "_" for each
name segment while the normalized full path doesn't contain the
trailing "_".
Currently this function is used by the method tracing users to specify a
none trailing "_" attached name path. Lv Zheng.
Note that we need to validate and switch all Linux kernel acpi_get_name()
users to use the new name type before removing the old name type from
ACPICA.
Link: https://github.com/acpica/acpica/commit/6e0229bb
Reviewed-by: Ruiyi Zhang <ruiyi_zhang@hotmail.com>
ACPICA commit 3b1026e0bdd3c32eb6d5d313f3ba0b1fee7597b4
ACPICA commit 00f0dc83f5cfca53b27a3213ae0d7719b88c2d6b
ACPICA commit 47d22a738d0e19fd241ffe4e3e9d4e198e4afc69
Across all of ACPICA. Replace C library macros such as ACPI_STRLEN with the
standard names such as strlen. The original purpose for these macros is
long since obsolete.
Also cast various invocations as necessary. Bob Moore, Jung-uk Kim, Lv Zheng.
Link: https://github.com/acpica/acpica/commit/3b1026e0
Link: https://github.com/acpica/acpica/commit/00f0dc83
Link: https://github.com/acpica/acpica/commit/47d22a73
Signed-off-by: Jung-uk Kim <jkim@FreeBSD.org>
ACPICA commit 9a2b638acb3a7215209432e070c6bd0312374229
ACPI Device object often contains a _CLS object to supply PCI-defined class
code for the device. This patch introduces logic to process the _CLS
object. Suravee Suthikulpanit, Lv Zheng.
Link: https://github.com/acpica/acpica/commit/9a2b638a
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com>
ACPICA commit 90f5332a15e9d9ba83831ca700b2b9f708274658
This patch adds a new FACS initialization flag for acpi_tb_initialize().
acpi_enable_subsystem() might be invoked several times in OS bootup process,
and we don't want FACS initialization to be invoked twice. Lv Zheng.
Link: https://github.com/acpica/acpica/commit/90f5332a
Cc: All applicable <stable@vger.kernel.org> # All applicable
ACPICA commit 5de82757aef5d6163e37064033aacbce193abbca
Using a minus number with ACPI_ADD_PTR() will cause compiler warnings, such
warnings cannot be eliminated by force casting an unsigned value to a
signed value. This patch thus introduces ACPI_SUB_PTR() to be used with
minus numbers. Lv Zheng.
Link: https://github.com/acpica/acpica/commit/5de82757
There are two same "define"s in the actypes.h for ACPI_USE_NATIVE_DIVIDE,
this patch removes one of them as it is useless and is not in the ACPICA
upstream. It is likely that the useless block is there because of the
issues in the old ACPICA release process.
During commit e252652fb266 ("ACPICA: acpidump: Remove integer types
translation protection.") two 'unsigned char' types got converted to 'u8'.
The result does not compile with gcc-4.5, it can not cope with duplicate
typedefs.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
It is reported that ACPI interrupts do not work any more on
Dell Latitude D600 after commit c50f13c672df (ACPICA: Save
current masks of enabled GPEs after enable register writes).
The problem turns out to be related to the fact that the
enable_mask and enable_for_run GPE bit masks are not in
sync (in the absence of any system suspend/resume events)
for at least one GPE register on that machine.
Address this problem by writing the enable_for_run mask into
enable_mask as soon as enable_for_run is updated instead of
doing that only after the subsequent register write has
succeeded. For consistency, update acpi_hw_gpe_enable_write()
to store the bit mask to be written into the GPE register
in enable_mask unconditionally before the write.
Since the ACPI_GPE_SAVE_MASK flag is not necessary any more after
that, drop it along with the symbols depending on it.
Reported-and-tested-by: Jim Bos <jim876@xs4all.nl>
Fixes: c50f13c672df (ACPICA: Save current masks of enabled GPEs after enable register writes)
Cc: 3.19+ <stable@vger.kernel.org> # 3.19+
ACPICA commit b293f602a67da478ae0bec129e68bd99787d9908
This change adds this string for Windows 10.
Link: https://github.com/acpica/acpica/commit/b293f602
GPE and fixed event.
ACPICA commit e25d791e4b3d5b9f4ead298269610cb05f89749a
There is a facility in Linux, developers can obtain GPE and fixed event
status via /sys/firmware/interrupts/. This is implemented using
acpi_get_event_status() and acpi_get_gpe_status(). Recently while debugging some
GPE race issues, it is found that the facility is lacking in the ability to
obtain real hardware register values, the confusing information makes
debugging difficult.
This patch modifies acpi_get_gpe_status() to return EN register values to fix
this gap. Then flags returned from acpi_get_event_status() and
acpi_get_gpe_status() are also cleaned up to reflect this change.
The old ACPI_EVENT_FLAG_SET is carefully kept to avoid regressions. It can
be deleted after we can make sure all its references are removed from OSPM
code. Lv Zheng.
Link: https://github.com/acpica/acpica/commit/e25d791e
ACPICA commit aacf863cfffd46338e268b7415f7435cae93b451
It is reported that on a physically 64-bit addressed machine, 32-bit kernel
can trigger crashes in accessing the memory regions that are beyond the
32-bit boundary. The region field's start address should still be 32-bit
compliant, but after a calculation (adding some offsets), it may exceed the
32-bit boundary. This case is rare and buggy, but there are real BIOSes
leaked with such issues (see References below).
This patch fixes this gap by always defining IO addresses as 64-bit, and
allows OSPMs to optimize it for a real 32-bit machine to reduce the size of
the internal objects.
Internal acpi_physical_address usages in the structures that can be fixed
by this change include:
1. struct acpi_object_region:
acpi_physical_address address;
2. struct acpi_address_range:
acpi_physical_address start_address;
acpi_physical_address end_address;
3. struct acpi_mem_space_context;
4. struct acpi_table_desc
See known issues 1 for other usages.
Note that acpi_io_address which is used for ACPI_PROCESSOR may also suffer
from same problem, so this patch changes it accordingly.
For iasl, it will enforce acpi_physical_address as 32-bit to generate
32-bit OSPM compatible tables on 32-bit platforms, we need to define
ACPI_32BIT_PHYSICAL_ADDRESS for it in acenv.h.
Known issues:
1. Cleanup of mapped virtual address
In struct acpi_mem_space_context, acpi_physical_address is used as a virtual
address:
acpi_physical_address mapped_physical_address;
It is better to introduce acpi_virtual_address or use acpi_size instead.
This patch doesn't make such a change. Because this should be done along
with a change to acpi_os_map_memory()/acpi_os_unmap_memory().
There should be no functional problem to leave this unchanged except
that only this structure is enlarged unexpectedly.
Link: https://github.com/acpica/acpica/commit/aacf863c
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=87971
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=79501
Reported-and-tested-by: Paul Menzel <paulepanter@users.sourceforge.net>
Reported-and-tested-by: Sial Nije <sialnije@gmail.com>
the current GPE APIs
ACPICA commit 199cad16530a45aea2bec98e528866e20c5927e1
Since whether the GPE should be disabled/enabled/cleared should only be
determined by the GPE driver's state machine:
1. GPE should be disabled if the driver wants to switch to the GPE polling
mode when a GPE storm condition is indicated and should be enabled if
the driver wants to switch back to the GPE interrupt mode when all of
the storm conditions are cleared. The conditions should be protected by
the driver's specific lock.
2. GPE should be enabled if the driver has accepted more than one request
and should be disabled if the driver has completed all of the requests.
The request count should be protected by the driver's specific lock.
3. GPE should be cleared either when the driver is about to handle an edge
triggered GPE or when the driver has completed to handle a level
triggered GPE. The handling code should be protected by the driver's
specific lock.
Thus the GPE enabling/disabling/clearing operations are likely to be
performed with the driver's specific lock held while we currently cannot do
this. This is because:
1. We have the acpi_gbl_gpe_lock held before invoking the GPE driver's
handler. Driver's specific lock is likely to be held inside of the
handler, thus we can see some dead lock issues due to the reversed
locking order or recursive locking. In order to solve such dead lock
issues, we need to unlock the acpi_gbl_gpe_lock before invoking the
handler. BZ 1100.
2. Since GPE disabling/enabling/clearing should be determined by the GPE
driver's state machine, we shouldn't perform such operations inside of
ACPICA for a GPE handler to mess up the driver's state machine. BZ 1101.
Originally this patch includes a logic to flush GPE handlers, it is dropped
due to the following reasons:
1. This is a different issue;
2. Linux OSL has fixed this by flushing SCI in acpi_os_wait_events_complete().
We will pick up this topic when the Linux OSL fix turns out to be not
sufficient.
Note that currently the internal operations and the acpi_gbl_gpe_lock are
also used by ACPI_GPE_DISPATCH_METHOD and ACPI_GPE_DISPATCH_NOTIFY. In
order not to introduce regressions, we add one
ACPI_GPE_DISPATCH_RAW_HANDLER type to be distiguished from
ACPI_GPE_DISPATCH_HANDLER. For which the acpi_gbl_gpe_lock is unlocked before
invoking the GPE handler and the internal enabling/disabling operations are
bypassed to allow drivers to perform them at a proper position using the
GPE APIs and ACPI_GPE_DISPATCH_RAW_HANDLER users should invoke acpi_set_gpe()
instead of acpi_enable_gpe()/acpi_disable_gpe() to bypass the internal GPE
clearing code in acpi_enable_gpe(). Lv Zheng.
Known issues:
1. Edge-triggered GPE lost for frequent enablings
On some buggy silicon platforms, GPE enable line may not be directly
wired to the GPE trigger line. In that case, when GPE enabling is
frequently performed for edge-triggered GPEs, GPE status may stay set
without being triggered.
This patch may maginify this problem as it allows GPE enabling to be
parallel performed during the process the GPEs are handled.
This is an existing issue, because:
1. For task context:
Current ACPI_GPE_DISPATCH_METHOD practices have proven that this
isn't a real issue - we can re-enable edge-triggered GPE in a work
queue where the GPE status bit might already be set.
2. For IRQ context:
This can even happen when the GPE enabling occurs before returning
from the GPE handler and after unlocking the GPE lock.
Thus currently no code is included to protect this.
Link: https://github.com/acpica/acpica/commit/199cad16
ACPICA commit 8990e73ab2aa15d6a0068b860ab54feff25bee36
Link: https://github.com/acpica/acpica/commit/8990e73a
Signed-off-by: David E. Box <david.e.box@linux.intel.com>
ACPICA commit 7926d5ca9452c87f866938dcea8f12e1efb58f89
There is an issue in acpi_install_gpe_handler() and acpi_remove_gpe_handler().
The code to obtain the GPE dispatcher type from the Handler->original_flags
is wrong:
if (((Handler->original_flags & ACPI_GPE_DISPATCH_METHOD) ||
(Handler->original_flags & ACPI_GPE_DISPATCH_NOTIFY)) &&
ACPI_GPE_DISPATCH_NOTIFY is 0x03 and ACPI_GPE_DISPATCH_METHOD is 0x02, thus
this statement is TRUE for the following dispatcher types:
0x01 (ACPI_GPE_DISPATCH_HANDLER): not expected
0x02 (ACPI_GPE_DISPATCH_METHOD): expected
0x03 (ACPI_GPE_DISPATCH_NOTIFY): expected
There is no functional issue due to this because Handler->original_flags is
only set in acpi_install_gpe_handler(), and an earlier checker has excluded
the ACPI_GPE_DISPATCH_HANDLER:
if ((gpe_event_info->Flags & ACPI_GPE_DISPATCH_MASK) ==
Status = AE_ALREADY_EXISTS;
goto free_and_exit;
Handler->original_flags = (u8) (gpe_event_info->Flags &
(ACPI_GPE_XRUPT_TYPE_MASK | ACPI_GPE_DISPATCH_MASK));
We need to clean this up before modifying the GPE dispatcher type values.
In order to prevent such issue from happening in the future, this patch
introduces ACPI_GPE_DISPATCH_TYPE() macro to be used to obtain the GPE
dispatcher types. Lv Zheng.
Link: https://github.com/acpica/acpica/commit/7926d5ca
There is a race condition between acpi_hw_disable_all_gpes() or
acpi_enable_all_wakeup_gpes() and acpi_ev_asynch_enable_gpe() such
that if the latter wins the race, it may mistakenly enable a GPE
disabled by the former. This may lead to premature system wakeups
during system suspend and potentially to more serious consequences.
The source of the problem is how acpi_hw_low_set_gpe() works when
passed ACPI_GPE_CONDITIONAL_ENABLE as the second argument. In that
case, the GPE will be enabled if the corresponding bit is set in the
enable_for_run mask of the GPE enable register containing that bit.
However, acpi_hw_disable_all_gpes() and acpi_enable_all_wakeup_gpes()
don't modify the enable_for_run masks of GPE registers when writing
to them. In consequence, if acpi_ev_asynch_enable_gpe(), which
eventually calls acpi_hw_low_set_gpe() with the second argument
equal to ACPI_GPE_CONDITIONAL_ENABLE, is executed in parallel with
one of these functions, it may reverse changes made by them.
To fix the problem, introduce a new enable_mask field in struct
acpi_gpe_register_info in which to store the current mask of
enabled GPEs and modify acpi_hw_low_set_gpe() to take this
mask into account instead of enable_for_run when its second
argument is equal to ACPI_GPE_CONDITIONAL_ENABLE. Also modify
the low-level routines called by acpi_hw_disable_all_gpes(),
acpi_enable_all_wakeup_gpes() and acpi_enable_all_runtime_gpes()
to update the enable_mask masks of GPE registers after all
(successful) writes to those registers.
Acked-by: Lv Zheng <lv.zheng@intel.com>
renaming.
This patch is partial linuxized result of the following ACPICA commit:
ACPICA commit: a73b66c6aa1846d055bb6390d9c9b9902f7d804d
Subject: Add "has handler" flag to event/gpe status interfaces.
This change adds a new flag, ACPI_EVENT_FLAGS_HAS_HANDLER to the
acpi_get_event_status and acpi_get_gpe_status external interfaces. It
is set if the event/gpe currently has a handler associated with it.
This patch contains the code to rename ACPI_EVENT_FLAG_HANDLE to
ACPI_EVENT_FLAG_HAS_HANDLER, and the corresponding updates of its usages.
Link: https://github.com/acpica/acpica/commit/a73b66c6
support.
This patch is a partial linuxized result of the following ACPICA commit:
This commit back ports ACPI_EVENT_FLAG_HANDLE from Linux upstream to
ACPICA, the flag along with its support code currently can only be found
in the Linux upstream and is used by the ACPI sysfs GPE interfaces and
the ACPI bus scanning support.
New value for the Notify() operator.
It is already casted to acpi_size by ACPI_PTR_DIFF() macro.
This patch enhances acpi_getopt() by converting the standard C library
invocations into portable ACPI string APIs and acpi_log_error() to improve
portability. Lv Zheng.
This patch introduces formatted printing APIs to handle ACPICA specific
formatted print requirements. Currently only specific OSPMs will use this
customized printing support, Linux kernel doesn't use these APIs at this
time. It will be enabled for Linux kernel resident ACPICA after being well
tested. So currently this patch is a no-op.
The specific formatted printing APIs are useful to ACPICA as:
1. Some portable applications do not link standard C library, so they
cannot use standard formatted print APIs directly.
2. Platform specific printing format may differ and thus not portable, for
example, u64 is %ull for Linux kernel and is %uI64 for some MSVC
versions.
3. Platform specific printing format may conflict with ACPICA's usages
while it is not possible for ACPICA developers to test their code for
all platforms. For example, developers may generate %pRxxx while Linux
kernel treats %pR as structured resource printing and decodes variable
argument as a "struct resource" pointer.
This patch solves above issues by introducing the new APIs.
Note that users of such APIs are not introduced in this patch. Users of
acpi_os_file_vprintf()/acpi_ut_file_printf() need to invoke acpi_os_initialize(),
this should be taken care by the further patches where such users are
introduced. Lv Zheng.
This patch adds portable file IO to generic OSL to improve the portability
of the applications.
A portable application may use different file IO interfaces than the
standard C library ones. This patch thus introduces an abstract file IO
layer into the generic OSL.
Note that this patch does not introduce users of such interfaces, further
patches should introduce users one by one carefully with build tests
performed. Lv Zheng.
OSPMs like Linux trend to include all header files but leave empty stub
macros for a feature that is not configured during build.
For macros defined without other symbols referencesd it is safe to leave
them without protections.
By investigation, there are only the following internal/external
symbols referenced by the ACPICA macros:
1. C library symbols, including string, ctype, stdarg APIs. Since such
symbols are always accessbile in the kernel source tree, it is safe to
leave macros referencing them without protected for Linux.
2. ACPICA OSL symbols, such symbols are designed to be used only by ACPICA
internal APIs. And there are macros directly referencing mutex and
memory allocation OSL symbols. We need to examine the external usages
of such macros.
For macros referencing the mutex OSL symbols, fortunately, there is no
external user directly invoking such macros.
!! IMPORTANT !!
For macros referencing memory allocation OSL symbols -
1. 'free' - ACPI_FREE
2. 'alloc' - ACPI_ALLOCATE, ACPI_ALLOCATE_ZEROED, ACPI_ALLOCATE_BUFFER,
ACPI_ALLOCATE_LOCAL_BUFFER
there are external users directly invoking 'alloc' macros. And the more
complicated situation is the reversals of such macros are not ACPI_FREE
but acpi_os_free (or kfree) in Linux. Though we can define such macros
into no-op, we in fact cannot define their reversals into no-op.
This patch adds mechanism to protect ACPICA memory allocation APIs for
Linux so that acpi_os_free (or kfree) invoked in Linux can have a zero
address returned by 'alloc' macros to free. In this
way, acpi_os_free (or kfree) can be converted into no-op.
3. ACPI_OFFSET and other macros that would access structure members, we
need to check if such structure members are not accessible under a
specific configuration. Fortunately, currently Linux doesn't use such
structure members when CONFIG_ACPI is disabled.
This patch thus only adds mechanism useful for implementing stubs for
ACPICA provided macros - the configurability of memory allocation APIs.
This patch doesn't include code for Linux to use this new mechanism, thus
no functional changes. Lv Zheng.
This reverts commit aae576e5faefa8ba70647efa320d4747b6375f1e.
Push and Pop are not portable "enough", and caused problems for
some ACPICA customers.
Signed-off-by: Robert Moore <Robert.Moore@intel.com>
Use push and pop to both guarantee that the correct alignment is used,
and to restore the alignment to whatever it was before the header
was included.
It is reported that the #pragma pack(push/pop) directives are not supported
by the specific GCCs, but this patch still doesn't affect kernel build
as there are already #pragma pack([1]) directives used in the old ACPICA
headers, which means there shouldn't be GCCs that are currently used to
compile the ACPI kernels do not support #pragma pack() directives.
References: https://bugs.acpica.org/show_bug.cgi?id=1058
Remove translation protection for applications as Linux tools folder will
start to use such types.
In Linux kernel source tree, after removing this translation protection,
the u8/u16/u32/u64/s32/s64 typedefs are exposed for both __KERNEL__ builds
and !__KERNEL__ builds (tools/power/acpi) and the original definitions of
ACPI_UINT8/16/32/64_MAX are changed.
For !__KERNEL__ builds, this kind of defintions should already been tested
by the distribution vendors that are distributing binary ACPICA package and
we've achieved the successful built/run test result in the kernel source
tree.
For __KERNEL__ builds, there are 2 things affected:
1. u8/u16/u32/u64/s32/s64 type definitions:
Since Linux has already type defined u8/u16/u32/u64/s32/s64 in
include/uapi/asm-generic/int-ll64.h for __KERNEL__. In order not to
introduce build regressions where the 2 typedefs are differed,
ACPI_USE_SYSTEM_INTTYPES is introduced to mask out ACPICA's typedefs.
It must be defined for Linux __KERNEL__ builds.
2. ACPI_UINT8/16/32/64_MAX definitions:
Before applying this change:
ACPI_UINT8_MAX: sizeof (UINT8)
UINT8: unsigned char
ACPI_UINT16_MAX: sizeof (UINT16)
UINT16: unsigned short
ACPI_UINT32_MAX: sizeof (UINT32)
INT32: int
UINT32: unsigned int
ACPI_UINT64_MAX: sizeof (UINT64)
INT64: COMPILER_DEPENDENT_INT64
COMPILER_DEPENDENT_INT64: signed long (IA64) or
signed long long (IA32)
UINT64: COMPILER_DEPENDENT_UINT64
COMPILER_DEPENDENT_UINT64: unsigned long (IA64) or
unsigned long long (IA32)
After applying this change:
ACPI_UINT8_MAX: sizeof (u8)
u8: unsigned char
UINT8: (removed from actypes.h)
ACPI_UINT16_MAX: sizeof (u16)
u16: unsigned short
UINT16: (removed from actypes.h)
ACPI_UINT32_MAX: sizeof (u32)
INT32/UINT32: (removed from actypes.h)
s32: signed int
u32: unsigned int
ACPI_UINT64_MAX: sizeof (u64)
INT64/UINT64: (removed from actypes.h)
u64: unsigned long long
s64: signed long long
COMPILER_DEPENDENT_INT64: signed long (IA64) (not used any more)
signed long long (IA32) (not used any more)
COMPILER_DEPENDENT_UINT64: unsigned long (IA64) (not used any more)
unsigned long long (IA32) (not used any more)
All definitions are equal except ACPI_UINT64_MAX for CONFIG_IA64. It
is changed from sizeof(unsigned long) to sizeof(unsigned long long).
By investigation, 64bit Linux kernel build is LP64 compliant, i.e.,
sizeof(long) and (pointer) are 64. As sizeof(unsigned long) equals to
sizeof(unsigned long long) on IA64 platform where CONFIG_64BIT cannot be
disabled, this change actually will not affect the value of
ACPI_UINT64_MAX on IA64 platforms.
This patch is necessary for the ACPICA's acpidump tool to build
correctly. Lv Zheng.
Update ACPICA copyrights to 2014. Includes all source headers and
signons for the various tools.
This macro is no longer used by ACPICA and it is not public.
Also update comments related to the use of ACPI_ALLOCATE_BUFFER and
the use of acpi_os_free (kfree is equivalent and prefered in the
kernel) to free the buffer.
This patch updates header files used by acpidump to reduce the
source code differences between Linux and ACPICA upstream.
This patch does not affect the generation of the Linux kernel binary.
This patch ports new counters and statistics interface, already
implemented in ACPICA upstream, to Linux. That helps to reduce
[rjw: Changelog]
interfaces.
This changes can reduce source code differences between Linux and ACPICA
upstream to help improving the release automation.
The side effect of applying this patch in Linux is:
1. Some ACPICA initialization/termination APIs are no longer exported in
Linux, these include:
acpi_load_tables
acpi_initialize_subsystem
acpi_initialize_objects
acpi_terminate
2. This patch does not affect the following APIs as they are currently not
marked with ACPI_EXPORT_SYMBOL in Linux:
acpi_reallocate_root_table
acpi_initialize_tables
Such functions should not be exported as they are internal to ACPI
subsystem in Linux, and will only be invoked inside of ACPI subsystem's
initialization routines marked with __init and termination routines marked
with __exit. While on other OSPMs, such functions may still need to be
exported.
Thus this patch adds the configurability for ACPICA, so that it leaves
OSPMs to determine if the __init/__exit marked functions should be exported
or not. Lv Zheng.
Add a comment to clarify reason for using ACPI_FREE_BUFFER directly
instead of ACPI_FREE.
In addition to that, change one instance in which ACPI_FREE_BUFFER()
should be used instead of ACPI_FREE().
[rjw: Subject and changelog]
The ACPI spec requires the reset register width to be 8, so we
now hardcode it and ignore the FADT value. This provides/maintains
compatibility with other ACPI implementations that have allowed
BIOS code with bad register width values to go unnoticed.
Matthew Garett, Bob Moore, Lv Zheng.
In the common case, the ACPI_ALLOCATE and related macros now resolve
directly to their respective acpi_os* OSL interfaces. Two options:
1) The ACPI_ALLOCATE_ZEROED macro defaults to a simple local implementation
by default, unless overridden by the USE_NATIVE_ALLOCATE_ZEROED define.
2) For ACPI execution simulation environment (AcpiExec) which is not
shipped with the Linux kernel, the macros can optionally be resolved to
the local interfaces that track each allocation (used to immediately
detect memory leaks).
The SCI interrupt number is not needed for the SCI handlers, and was
just unnecessary overhead.
Reviewed-by: Len Brown <len.brown@intel.com>
This patch introduces new macors to handle RSDP signature and cleans up the
affected codes. Lv Zheng.
Some updates are only used for ACPICA utilities which are not shipped in
the kernel yet.
This change adds support to allow hosts to install System Control
Interrupt handlers. Certain ACPI functionality requires the host
to handle raw SCIs. For example, the "SCI Doorbell" that is defined
for memory power state support requires the host device driver to
handle SCIs to examine if the doorbell has been activated. Multiple
SCI handlers can be installed to allow for future expansion.
Debugger support is included.
Lv Zheng, Bob Moore. ACPICA BZ 1032.
Bug summary:
It is reported when the PCC (Platform Communication Channel, via
MPST table, defined in ACPI specification 5.0) subchannel responds
to the host, it issues an SCI and the host must probe the subchannel
for channel status.
Buglink: http://bugs.acpica.org/show_bug.cgi?id=1032
The original commit 242b2287cd7f27521c8b54a4101d569e53e7a0ca "ACPICA:
expose OSI version" triggers build errors in ACPICA when it is back
ported. The patch removes the divergences between Linux and upstream
ACPICA resulting from that.
Add new API to allow OSPM to disable/enable specific types of _OSI
interface strings.
ACPICA does not have the knowledge about whether an _OSI interface
string is an OS vendor string or a feature group string and there
isn't any API interface to allow OSPM to install a new interface
string as a feature group string.
This patch simply adds all feature group strings defined by ACPI
specification into the acpi_default_supported_interfaces with
ACPI_OSI_FEATURE flag set to fix this gap. This patch also adds
codes to keep their default states as ACPI_OSI_INVALID before the
initialization and after the termination.
Reviewed-by: Zhang Rui <rui.zhang@intel.com>
Acked-by: Len Brown <len.brown@intel.com>
include/acpi/actypes.h (with commit 242b228)
