path: root/include/acpi
2008-01-23Revert "ACPI: Fan: Drop force_power_state acpi_device option"Len Brown
This reverts commit 93ad7c07ad487b036add8760dabcc35666a550ef. http://bugzilla.kernel.org/show_bug.cgi?id=9798 Signed-off-by: Len Brown <len.brown@intel.com>
2007-11-20Pull cpuidle into release branchLen Brown
2007-11-19cpuidle: fix HP nx6125 regressionVenkatesh Pallipadi
Fix for http://bugzilla.kernel.org/show_bug.cgi?id=9355 cpuidle always used to fallback to C2 if there is some bm activity while entering C3. But, presence of C2 is not always guaranteed. Change cpuidle algorithm to detect a safe_state to fallback in case of bm_activity and use that state instead of C2. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-25ACPI: Fan: Drop force_power_state acpi_device optionAlexey Starikovskiy
force_power_state was used as a workaround for invalid cached power state of the device. We do not cache power state, so no need for workaround. Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-22Intel IOMMU: DMAR detection and parsing logicKeshavamurthy, Anil S
This patch supports the upcomming Intel IOMMU hardware a.k.a. Intel(R) Virtualization Technology for Directed I/O Architecture and the hardware spec for the same can be found here http://www.intel.com/technology/virtualization/index.htm FAQ! (questions from akpm, answers from ak) > So... what's all this code for? > > I assume that the intent here is to speed things up under Xen, etc? Yes in some cases, but not this code. That would be the Xen version of this code that could potentially assign whole devices to guests. I expect this to be only useful in some special cases though because most hardware is not virtualizable and you typically want an own instance for each guest. Ok at some point KVM might implement this too; i likely would use this code for this. > Do we > have any benchmark results to help us to decide whether a merge would be > justified? The main advantage for doing it in the normal kernel is not performance, but more safety. Broken devices won't be able to corrupt memory by doing random DMA. Unfortunately that doesn't work for graphics yet, for that need user space interfaces for the X server are needed. There are some potential performance benefits too: - When you have a device that cannot address the complete address range an IOMMU can remap its memory instead of bounce buffering. Remapping is likely cheaper than copying. - The IOMMU can merge sg lists into a single virtual block. This could potentially speed up SG IO when the device is slow walking SG lists. [I long ago benchmarked 5% on some block benchmark with an old MPT Fusion; but it probably depends a lot on the HBA] And you get better driver debugging because unexpected memory accesses from the devices will cause a trappable event. > > Does it slow anything down? It adds more overhead to each IO so yes. This patch: Add support for early detection and parsing of DMAR's (DMA Remapping) reported to OS via ACPI tables. DMA remapping(DMAR) devices support enables independent address translations for Direct Memory Access(DMA) from Devices. These DMA remapping devices are reported via ACPI tables and includes pci device scope covered by these DMA remapping device. For detailed info on the specification of "Intel(R) Virtualization Technology for Directed I/O Architecture" please see http://www.intel.com/technology/virtualization/index.htm Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Andi Kleen <ak@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Ashok Raj <ashok.raj@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Christoph Lameter <clameter@sgi.com> Cc: Greg KH <greg@kroah.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10Pull acpica into test branchLen Brown
2007-10-10ACPICA: hw: Don't carry spinlock over suspendAlexey Starikovskiy
ACPI uses acpi_get_register() in order to get into suspend. This function is guarded by acpi_gbl_hardware_lock, which will be carried into resume phase. At resume interrupts are enabled and first ACPI interrupt deadlocks on this lock. Solution seems to be to not lock register read, as there are no concurrent activity at this point. Reference: http://bugzilla.kernel.org/show_bug.cgi?id=7499 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-10ACPICA: hw: remove use_lock flag from acpi_hw_register_{read, write}Alexey Starikovskiy
use_lock flag is used once for acpi_hw_register_read, and never for acpi_hw_register_write. It will greatly simplify understanding of locking if we just drop this use_lock altogether, and wrap the only call to ..._read in lock/unlock. Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-10Pull cpuidle into test branchLen Brown
2007-10-10Pull bugzilla-292300 into release branchLen Brown
2007-10-10cpuidle: consolidate 2.6.22 cpuidle branch into one patchLen Brown
commit e5a16b1f9eec0af7cfa0830304b41c1c0833cf9f Author: Len Brown <len.brown@intel.com> Date: Tue Oct 2 23:44:44 2007 -0400 cpuidle: shrink diff processor_idle.c | 440 +++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 429 insertions(+), 11 deletions(-) Signed-off-by: Len Brown <len.brown@intel.com> commit dfbb9d5aedfb18848a3e0d6f6e3e4969febb209c Author: Len Brown <len.brown@intel.com> Date: Wed Sep 26 02:17:55 2007 -0400 cpuidle: reduce diff size Reduces the cpuidle processor_idle.c diff vs 2.6.22 from this processor_idle.c | 2006 ++++++++++++++++++++++++++----------------- 1 file changed, 1219 insertions(+), 787 deletions(-) to this: processor_idle.c | 502 +++++++++++++++++++++++++++++++++++++++---- 1 file changed, 458 insertions(+), 44 deletions(-) ...for the purpose of making the cpuilde patch less invasive and easier to review. no functional changes. build tested only. Signed-off-by: Len Brown <len.brown@intel.com> commit 889172fc915f5a7fe20f35b133cbd205ce69bf6c Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Thu Sep 13 13:40:05 2007 -0700 cpuidle: Retain old ACPI policy for !CONFIG_CPU_IDLE Retain the old policy in processor_idle, so that when CPU_IDLE is not configured, old C-state policy will still be used. This provides a clean gradual migration path from old ACPI policy to new cpuidle based policy. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 9544a8181edc7ecc33b3bfd69271571f98ed08bc Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Thu Sep 13 13:39:17 2007 -0700 cpuidle: Configure governors by default Quoting Len "Do not give an option to users to shoot themselves in the foot". Remove the configurability of ladder and menu governors as they are needed for default policy of cpuidle. That way users will not be able to have cpuidle without any policy loosing all C-state power savings. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 8975059a2c1e56cfe83d1bcf031bcf4cb39be743 Author: Adam Belay <abelay@novell.com> Date: Tue Aug 21 18:27:07 2007 -0400 CPUIDLE: load ACPI properly when CPUIDLE is disabled Change the registration return codes for when CPUIDLE support is not compiled into the kernel. As a result, the ACPI processor driver will load properly even if CPUIDLE is unavailable. However, it may be possible to cleanup the ACPI processor driver further and eliminate some dead code paths. Signed-off-by: Adam Belay <abelay@novell.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit e0322e2b58dd1b12ec669bf84693efe0dc2414a8 Author: Adam Belay <abelay@novell.com> Date: Tue Aug 21 18:26:06 2007 -0400 CPUIDLE: remove cpuidle_get_bm_activity() Remove cpuidle_get_bm_activity() and updates governors accordingly. Signed-off-by: Adam Belay <abelay@novell.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 18a6e770d5c82ba26653e53d240caa617e09e9ab Author: Adam Belay <abelay@novell.com> Date: Tue Aug 21 18:25:58 2007 -0400 CPUIDLE: max_cstate fix Currently max_cstate is limited to 0, resulting in no idle processor power management on ACPI platforms. This patch restores the value to the array size. Signed-off-by: Adam Belay <abelay@novell.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 1fdc0887286179b40ce24bcdbde663172e205ef0 Author: Adam Belay <abelay@novell.com> Date: Tue Aug 21 18:25:40 2007 -0400 CPUIDLE: handle BM detection inside the ACPI Processor driver Update the ACPI processor driver to detect BM activity and limit state entry depth internally, rather than exposing such requirements to CPUIDLE. As a result, CPUIDLE can drop this ACPI-specific interface and become more platform independent. BM activity is now handled much more aggressively than it was in the original implementation, so some testing coverage may be needed to verify that this doesn't introduce any DMA buffer under-run issues. Signed-off-by: Adam Belay <abelay@novell.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 0ef38840db666f48e3cdd2b769da676c57228dd9 Author: Adam Belay <abelay@novell.com> Date: Tue Aug 21 18:25:14 2007 -0400 CPUIDLE: menu governor updates Tweak the menu governor to more effectively handle non-timer break events. Non-timer break events are detected by comparing the actual sleep time to the expected sleep time. In future revisions, it may be more reliable to use the timer data structures directly. Signed-off-by: Adam Belay <abelay@novell.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit bb4d74fca63fa96cf3ace644b15ae0f12b7df5a1 Author: Adam Belay <abelay@novell.com> Date: Tue Aug 21 18:24:40 2007 -0400 CPUIDLE: fix 'current_governor' sysfs entry Allow the "current_governor" sysfs entry to properly handle input terminated with '\n'. Signed-off-by: Adam Belay <abelay@novell.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit df3c71559bb69b125f1a48971bf0d17f78bbdf47 Author: Len Brown <len.brown@intel.com> Date: Sun Aug 12 02:00:45 2007 -0400 cpuidle: fix IA64 build (again) Signed-off-by: Len Brown <len.brown@intel.com> commit a02064579e3f9530fd31baae16b1fc46b5a7bca8 Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Sun Aug 12 01:39:27 2007 -0400 cpuidle: Remove support for runtime changing of max_cstate Remove support for runtime changeability of max_cstate. Drivers can use use latency APIs. max_cstate can still be used as a boot time option and dmi override. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 0912a44b13adf22f5e3f607d263aed23b4910d7e Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Sun Aug 12 01:39:16 2007 -0400 cpuidle: Remove ACPI cstate_limit calls from ipw2100 ipw2100 already has code to use accetable_latency interfaces to limit the C-state. Remove the calls to acpi_set_cstate_limit and acpi_get_cstate_limit as they are redundant. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit c649a76e76be6bff1fd770d0a775798813a3f6e0 Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Sun Aug 12 01:35:39 2007 -0400 cpuidle: compile fix for pause and resume functions Fix the compilation failure when cpuidle is not compiled in. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Acked-by: Adam Belay <adam.belay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 2305a5920fb8ee6ccec1c62ade05aa8351091d71 Author: Adam Belay <abelay@novell.com> Date: Thu Jul 19 00:49:00 2007 -0400 cpuidle: re-write Some portions have been rewritten to make the code cleaner and lighter weight. The following is a list of changes: 1.) the state name is now included in the sysfs interface 2.) detection, hotplug, and available state modifications are handled by CPUIDLE drivers directly 3.) the CPUIDLE idle handler is only ever installed when at least one cpuidle_device is enabled and ready 4.) the menu governor BM code no longer overflows 5.) the sysfs attributes are now printed as unsigned integers, avoiding negative values 6.) a variety of other small cleanups Also, Idle drivers are no longer swappable during runtime through the CPUIDLE sysfs inteface. On i386 and x86_64 most idle handlers (e.g. poll, mwait, halt, etc.) don't benefit from an infrastructure that supports multiple states, so I think using a more general case idle handler selection mechanism would be cleaner. Signed-off-by: Adam Belay <abelay@novell.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Acked-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit df25b6b56955714e6e24b574d88d1fd11f0c3ee5 Author: Len Brown <len.brown@intel.com> Date: Tue Jul 24 17:08:21 2007 -0400 cpuidle: fix IA64 buid Signed-off-by: Len Brown <len.brown@intel.com> commit fd6ada4c14488755ff7068860078c437431fbccd Author: Adrian Bunk <bunk@stusta.de> Date: Mon Jul 9 11:33:13 2007 -0700 cpuidle: static make cpuidle_replace_governor() static Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit c1d4a2cebcadf2429c0c72e1d29aa2a9684c32e0 Author: Adrian Bunk <bunk@stusta.de> Date: Tue Jul 3 00:54:40 2007 -0400 cpuidle: static This patch makes the needlessly global struct menu_governor static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit dbf8780c6e8d572c2c273da97ed1cca7608fd999 Author: Andrew Morton <akpm@linux-foundation.org> Date: Tue Jul 3 00:49:14 2007 -0400 export symbol tick_nohz_get_sleep_length ERROR: "tick_nohz_get_sleep_length" [drivers/cpuidle/governors/menu.ko] undefined! ERROR: "tick_nohz_get_idle_jiffies" [drivers/cpuidle/governors/menu.ko] undefined! And please be sure to get your changes to core kernel suitably reviewed. Cc: Adam Belay <abelay@novell.com> Cc: Venki Pallipadi <venkatesh.pallipadi@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 29f0e248e7017be15f99febf9143a2cef00b2961 Author: Andrew Morton <akpm@linux-foundation.org> Date: Tue Jul 3 00:43:04 2007 -0400 tick.h needs hrtimer.h It uses hrtimers. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit e40cede7d63a029e92712a3fe02faee60cc38fb4 Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Jul 3 00:40:34 2007 -0400 cpuidle: first round of documentation updates Documentation changes based on Pavel's feedback. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 83b42be2efece386976507555c29e7773a0dfcd1 Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Jul 3 00:39:25 2007 -0400 cpuidle: add rating to the governors and pick the one with highest rating by default Introduce a governor rating scheme to pick the right governor by default. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit d2a74b8c5e8f22def4709330d4bfc4a29209b71c Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Jul 3 00:38:08 2007 -0400 cpuidle: make cpuidle sysfs driver governor switch off by default Make default cpuidle sysfs to show current_governor and current_driver in read-only mode. More elaborate available_governors and available_drivers with writeable current_governor and current_driver interface only appear with "cpuidle_sysfs_switch" boot parameter. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 1f60a0e80bf83cf6b55c8845bbe5596ed8f6307b Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Jul 3 00:37:00 2007 -0400 cpuidle: menu governor: change the early break condition Change the C-state early break out algorithm in menu governor. We only look at early breakouts that result in wakeups shorter than idle state's target_residency. If such a breakout is frequent enough, eliminate the particular idle state upto a timeout period. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 45a42095cf64b003b4a69be3ce7f434f97d7af51 Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Jul 3 00:35:38 2007 -0400 cpuidle: fix uninitialized variable in sysfs routine Fix the uninitialized usage of ret. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 80dca7cdba3e6ee13eae277660873ab9584eb3be Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Jul 3 00:34:16 2007 -0400 cpuidle: reenable /proc/acpi//power interface for the time being Keep /proc/acpi/processor/CPU*/power around for a while as powertop depends on it. It will be marked deprecated and removed in future. powertop can use cpuidle interfaces instead. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 589c37c2646c5e3813a51255a5ee1159cb4c33fc Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Jul 3 00:32:37 2007 -0400 cpuidle: menu governor and hrtimer compile fix Compile fix for menu governor. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 0ba80bd9ab3ed304cb4f19b722e4cc6740588b5e Author: Len Brown <len.brown@intel.com> Date: Thu May 31 22:51:43 2007 -0400 cpuidle: build fix - cpuidle vs ipw2100 module ERROR: "acpi_set_cstate_limit" [drivers/net/wireless/ipw2100.ko] undefined! Signed-off-by: Len Brown <len.brown@intel.com> commit d7d8fa7f96a7f7682be7c6cc0cc53fa7a18c3b58 Author: Adam Belay <abelay@novell.com> Date: Sat Mar 24 03:47:07 2007 -0400 cpuidle: add the 'menu' governor Here is my first take at implementing an idle PM governor that takes full advantage of NO_HZ. I call it the 'menu' governor because it considers the full list of idle states before each entry. I've kept the implementation fairly simple. It attempts to guess the next residency time and then chooses a state that would meet at least the break-even point between power savings and entry cost. To this end, it selects the deepest idle state that satisfies the following constraints: 1. If the idle time elapsed since bus master activity was detected is below a threshold (currently 20 ms), then limit the selection to C2-type or above. 2. Do not choose a state with a break-even residency that exceeds the expected time remaining until the next timer interrupt. 3. Do not choose a state with a break-even residency that exceeds the elapsed time between the last pair of break events, excluding timer interrupts. This governor has an advantage over "ladder" governor because it proactively checks how much time remains until the next timer interrupt using the tick infrastructure. Also, it handles device interrupt activity more intelligently by not including timer interrupts in break event calculations. Finally, it doesn't make policy decisions using the number of state entries, which can have variable residency times (NO_HZ makes these potentially very large), and instead only considers sleep time deltas. The menu governor can be selected during runtime using the cpuidle sysfs interface like so: "echo "menu" > /sys/devices/system/cpu/cpuidle/current_governor" Signed-off-by: Adam Belay <abelay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com> commit a4bec7e65aa3b7488b879d971651cc99a6c410fe Author: Adam Belay <abelay@novell.com> Date: Sat Mar 24 03:47:03 2007 -0400 cpuidle: export time until next timer interrupt using NO_HZ Expose information about the time remaining until the next timer interrupt expires by utilizing the dynticks infrastructure. Also modify the main idle loop to allow dynticks to handle non-interrupt break events (e.g. DMA). Finally, expose sleep ticks information to external code. Thomas Gleixner is responsible for much of the code in this patch. However, I've made some additional changes, so I'm probably responsible if there are any bugs or oversights :) Signed-off-by: Adam Belay <abelay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 2929d8996fbc77f41a5ff86bb67cdde3ca7d2d72 Author: Adam Belay <abelay@novell.com> Date: Sat Mar 24 03:46:58 2007 -0400 cpuidle: governor API changes This patch prepares cpuidle for the menu governor. It adds an optional stage after idle state entry to give the governor an opportunity to check why the state was exited. Also it makes sure the idle loop returns after each state entry, allowing the appropriate dynticks code to run. Signed-off-by: Adam Belay <abelay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 3a7fd42f9825c3b03e364ca59baa751bb350775f Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Thu Apr 26 00:03:59 2007 -0700 cpuidle: hang fix Prevent hang on x86-64, when ACPI processor driver is added as a module on a system that does not support C-states. x86-64 expects all idle handlers to enable interrupts before returning from idle handler. This is due to enter_idle(), exit_idle() races. Make cpuidle_idle_call() confirm to this when there is no pm_idle_old. Also, cpuidle look at the return values of attch_driver() and set current_driver to NULL if attach fails on all CPUs. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 4893339a142afbd5b7c01ffadfd53d14746e858e Author: Shaohua Li <shaohua.li@intel.com> Date: Thu Apr 26 10:40:09 2007 +0800 cpuidle: add support for max_cstate limit With CPUIDLE framework, the max_cstate (to limit max cpu c-state) parameter is ingored. Some systems require it to ignore C2/C3 and some drivers like ipw require it too. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 43bbbbe1cb998cbd2df656f55bb3bfe30f30e7d1 Author: Shaohua Li <shaohua.li@intel.com> Date: Thu Apr 26 10:40:13 2007 +0800 cpuidle: add cpuidle_fore_redetect_devices API add cpuidle_force_redetect_devices API, which forces all CPU redetect idle states. Next patch will use it. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit d1edadd608f24836def5ec483d2edccfb37b1d19 Author: Shaohua Li <shaohua.li@intel.com> Date: Thu Apr 26 10:40:01 2007 +0800 cpuidle: fix sysfs related issue Fix the cpuidle sysfs issue. a. make kobject dynamicaly allocated b. fixed sysfs init issue to avoid suspend/resume issue Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 7169a5cc0d67b263978859672e86c13c23a5570d Author: Randy Dunlap <randy.dunlap@oracle.com> Date: Wed Mar 28 22:52:53 2007 -0400 cpuidle: 1-bit field must be unsigned A 1-bit bitfield has no room for a sign bit. drivers/cpuidle/governors/ladder.c:54:16: error: dubious bitfield without explicit `signed' or `unsigned' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 4658620158dc2fbd9e4bcb213c5b6fb5d05ba7d4 Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Wed Mar 28 22:52:41 2007 -0400 cpuidle: fix boot hang Patch for cpuidle boot hang reported by Larry Finger here. http://www.ussg.iu.edu/hypermail/linux/kernel/0703.2/2025.html Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Larry Finger <larry.finger@lwfinger.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit c17e168aa6e5fe3851baaae8df2fbc1cf11443a9 Author: Len Brown <len.brown@intel.com> Date: Wed Mar 7 04:37:53 2007 -0500 cpuidle: ladder does not depend on ACPI build fix for CONFIG_ACPI=n In file included from drivers/cpuidle/governors/ladder.c:21: include/acpi/processor.h:88: error: expected specifier-qualifier-list before ‘acpi_integer’ include/acpi/processor.h:106: error: expected specifier-qualifier-list before ‘acpi_integer’ include/acpi/processor.h:168: error: expected specifier-qualifier-list before ‘acpi_handle’ Signed-off-by: Len Brown <len.brown@intel.com> commit 8c91d958246bde68db0c3f0c57b535962ce861cb Author: Adrian Bunk <bunk@stusta.de> Date: Tue Mar 6 02:29:40 2007 -0800 cpuidle: make code static This patch makes the following needlessly global code static: - driver.c: __cpuidle_find_driver() - governor.c: __cpuidle_find_governor() - ladder.c: struct ladder_governor Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Adam Belay <abelay@novell.com> Cc: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 0c39dc3187094c72c33ab65a64d2017b21f372d2 Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Wed Mar 7 02:38:22 2007 -0500 cpu_idle: fix build break This patch fixes a build breakage with !CONFIG_HOTPLUG_CPU and CONFIG_CPU_IDLE. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 8112e3b115659b07df340ef170515799c0105f82 Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Mar 6 02:29:39 2007 -0800 cpuidle: build fix for !CPU_IDLE Fix the compile issues when CPU_IDLE is not configured. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Adam Belay <abelay@novell.com> Cc: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 1eb4431e9599cd25e0d9872f3c2c8986821839dd Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Thu Feb 22 13:54:57 2007 -0800 cpuidle take2: Basic documentation for cpuidle Documentation for cpuidle infrastructure Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Adam Belay <abelay@novell.com> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit ef5f15a8b79123a047285ec2e3899108661df779 Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Thu Feb 22 13:54:03 2007 -0800 cpuidle take2: Hookup ACPI C-states driver with cpuidle Hookup ACPI C-states onto generic cpuidle infrastructure. drivers/acpi/procesor_idle.c is now a ACPI C-states driver that registers as a driver in cpuidle infrastructure and the policy part is removed from drivers/acpi/processor_idle.c. We use governor in cpuidle instead. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Adam Belay <abelay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 987196fa82d4db52c407e8c9d5dec884ba602183 Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Thu Feb 22 13:52:57 2007 -0800 cpuidle take2: Core cpuidle infrastructure Announcing 'cpuidle', a new CPU power management infrastructure to manage idle CPUs in a clean and efficient manner. cpuidle separates out the drivers that can provide support for multiple types of idle states and policy governors that decide on what idle state to use at run time. A cpuidle driver can support multiple idle states based on parameters like varying power consumption, wakeup latency, etc (ACPI C-states for example). A cpuidle governor can be usage model specific (laptop, server, laptop on battery etc). Main advantage of the infrastructure being, it allows independent development of drivers and governors and allows for better CPU power management. A huge thanks to Adam Belay and Shaohua Li who were part of this mini-project since its beginning and are greatly responsible for this patchset. This patch: Core cpuidle infrastructure. Introduces a new abstraction layer for cpuidle: * which manages drivers that can support multiple idles states. Drivers can be generic or particular to specific hardware/platform * allows pluging in multiple policy governors that can take idle state policy decision * The core also has a set of sysfs interfaces with which administrato can know about supported drivers and governors and switch them at run time. Signed-off-by: Adam Belay <abelay@novell.com> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-09-27ACPI: Add acpi_bus_generate_event4() functionAlexey Starikovskiy
acpi_bus_generate_event() takes two strings out of passed device object. SBS needs to supply these strings directly. Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-09-27ACPI: Hibernate erroneously disabled Suspend wakeup devicesAlexey Starikovskiy
S4 suspend to disk will disable GPE's permanently because acpi_gpe_sleep_prepare() does not have a counterpart at resume time. Thus, those devices became unavailable for wakeup from subsequent S3 suspend-to-ram. Here acpi_gpe_sleep_prepare() is removed, and upon suspend acpi_enable_wakeup_device() gets its functionality. Upon resume, acpi_disable_wakeup_device() restores the state. https://bugzilla.novell.com/show_bug.cgi?id=292300 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2007-09-25ACPI: CONFIG_ACPI_SLEEP=n power off regression in 2.6.23-rc8 (NOT in rc7)Alexey Starikovskiy
2007-09-22ACPI: disable lower idle C-states across suspend/resumeThomas Gleixner
device_suspend() calls ACPI suspend functions, which seems to have undesired side effects on lower idle C-states. It took me some time to realize that especially the VAIO BIOSes (both Andrews jinxed UP and my elfstruck SMP one) show this effect. I'm quite sure that other bug reports against suspend/resume about turning the system into a brick have the same root cause. After fishing in the dark for quite some time, I realized that removing the ACPI processor module before suspend (this removes the lower C-state functionality) made the problem disappear. Interestingly enough the propability of having a bricked box is influenced by various factors (interrupts, size of the ram image, ...). Even adding a bunch of printks in the wrong places made the problem go away. The previous periodic tick implementation simply pampered over the problem, which explains why the dyntick / clockevents changes made this more prominent. We avoid complex functionality during the boot process and we have to do the same during suspend/resume. It is a similar scenario and equaly fragile. Add suspend / resume functions to the ACPI processor code and disable the lower idle C-states across suspend/resume. Fall back to the default idle implementation (halt) instead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Andrew Morton <akpm@linux-foundation.org> Cc: Len Brown <lenb@kernel.org> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-25Pull events into release branchLen Brown
Conflicts: drivers/acpi/video.c Signed-off-by: Len Brown <len.brown@intel.com>
2007-08-25ACPI: Fix a warning of discarding qualifiers from pointer target typeAl Viro
drivers/acpi/ec.c: In function `acpi_ec_ecdt_probe': drivers/acpi/ec.c:873: warning: passing arg 1 of `acpi_get_devices' discards qualifiers from pointer target type Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Len Brown <len.brown@intel.com>
2007-08-23ACPI: Schedule /proc/acpi/event for removalLen Brown
Schedule /proc/acpi/event for removal in 6 months. Re-name acpi_bus_generate_event() to acpi_bus_generate_proc_event() to make sure there is no confusion that it is for /proc/acpi/event only. Add CONFIG_ACPI_PROC_EVENT to allow removal of /proc/acpi/event. There is no functional change if CONFIG_ACPI_PROC_EVENT=y Signed-off-by: Len Brown <len.brown@intel.com>
2007-08-23ACPI: don't duplicate input events on netlinkZhang Rui
The previous events patch added a netlink event for every user of the legacy /proc/acpi/event interface. However, some users of /proc/acpi/event are really input events, and they already report their events via the input layer. Introduce a new interface, acpi_bus_generate_netlink_event(), which is explicitly called by devices that want to repoprt events via netlink. This allows the input-like events to opt-out of generating netlink events. In summary: events that are sent via netlink: ac/battery/sbs thermal processor thinkpad_acpi dock/bay events that are sent via input layer: button video hotkey thinkpad_acpi hotkey asus_acpi/asus-laptop hotkey sonypi/sonylaptop Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-08-07acpi-cpufreq: Fix some x86/x86-64 acpi-cpufreq driver issuesFenghua Yu
This patch addresses some issues in x86/x86-64 acpi-cpufreq driver: 1. Current memory allocation for acpi_perf_data is actually open-coded alloc_percpu(). The patch defines and handles acpi_perf_data as percpu data. The code will be cleaner and easier to be maintained with this change. 2. Won't load driver in acpi_cpufreq_early_init() failure case. 3. Add __init for acpi_cpufreq_early_init(). Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-29ACPI: restore CONFIG_ACPI_SLEEPLen Brown
Restore the 2.6.22 CONFIG_ACPI_SLEEP build option, but now shadowing the new CONFIG_PM_SLEEP option. Signed-off-by: Len Brown <len.brown@intel.com> [ Modified to work with the PM config setup changes. ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-29Introduce CONFIG_SUSPEND for suspend-to-Ram and standbyRafael J. Wysocki
Introduce CONFIG_SUSPEND representing the ability to enter system sleep states, such as the ACPI S3 state, and allow the user to choose SUSPEND and HIBERNATION independently of each other. Make HOTPLUG_CPU be selected automatically if SUSPEND or HIBERNATION has been chosen and the kernel is intended for SMP systems. Also, introduce CONFIG_PM_SLEEP which is automatically selected if CONFIG_SUSPEND or CONFIG_HIBERNATION is set and use it to select the code needed for both suspend and hibernation. The top-level power management headers and the ACPI code related to suspend and hibernation are modified to use the new definitions (the changes in drivers/acpi/sleep/main.c are, mostly, moving code to reduce the number of ifdefs). There are many other files in which CONFIG_PM can be replaced with CONFIG_PM_SLEEP or even with CONFIG_SUSPEND, but they can be updated in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-25Pull auto-load-modules into release branchLen Brown
2007-07-25Pull d-states into release branchLen Brown
Conflicts: drivers/acpi/sleep/main.c Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-25ACPI: Kconfig: remove CONFIG_ACPI_SLEEP from sourceLen Brown
As it was a synonym for (CONFIG_ACPI && CONFIG_X86), the ifdefs for it were more clutter than they were worth. For ia64, just add a few stubs in anticipation of future S3 or S4 support. Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-23ACPI: autoload modules - ACPICA modificationsThomas Renninger
Define standardized HIDs - Rename current acpi_device_id to acpica_device_id Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22ACPI: Add acpi_pm_device_sleep_state helper routineShaohua Li
Based on the David Brownell's patch at http://marc.info/?l=linux-acpi&m=117873972806360&w=2 updated by: Rafael J. Wysocki <rjw@sisk.pl> Add a helper routine returning the lowest power (highest number) ACPI device power state that given device can be in while the system is in the sleep state indicated by acpi_target_sleep_state . Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22Pull netlink into release branchLen Brown
2007-07-22Pull throttle into release branchLen Brown
2007-07-22Pull misc into release branchLen Brown
Conflicts: Documentation/feature-removal-schedule.txt
2007-07-22Pull acpi-debug into release branchLen Brown
2007-07-22Pull acpica into release branchLen Brown
2007-07-22ACPI: create CONFIG_ACPI_DEBUG_FUNC_TRACEThomas Renninger
Split ACPI_DEBUG into function trace enabled and not enabled. Function trace is most of the ACPI_DEBUG costs, but is not much of use for kernel ACPI debugging. Size of kernel image increased on test compile: + 48k (Full ACPI_DEBUG) + 35k (ACPI_DEBUG with function trace compiled out) Performance without function trace is also much better. Also remove ACPI_LV_DEBUG_OBJECT from default debug level as a lot vendors let Store (value, debug) in their code and this might confuse users when it pops up in syslog. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22ACPI: fix empty macros found by -WextraDave Jones
ACPI has a ton of macros which make a bunch of empty if's when configured in non-debug mode. [lenb: The code it complaines about is functionally correct, so this patch is just to make -Wextra happier] #define DBG() if(...) DBG(); next_c_statement which turns into if(...) ; next_c_statement Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-21x86_64: fake pxm-to-node mapping for fake numaDavid Rientjes
For NUMA emulation, our SLIT should represent the true NUMA topology of the system but our proximity domain to node ID mapping needs to reflect the emulated state. When NUMA emulation has successfully setup fake nodes on the system, a new function, acpi_fake_nodes() is called. This function determines the proximity domain (_PXM) for each true node found on the system. It then finds which emulated nodes have been allocated on this true node as determined by its starting address. The node ID to PXM mapping is changed so that each fake node ID points to the PXM of the true node that it is located on. If the machine failed to register a SLIT, then we assume there is no special requirement for emulated node affinity so we use the default LOCAL_DISTANCE, which is newly exported to this code, as our measurement if the emulated nodes appear in the same PXM. Otherwise, we use REMOTE_DISTANCE. PXM_INVAL and NID_INVAL are also exported to the ACPI header file so that we can compare node_to_pxm() results in generic code (in this case, the SRAT code). Cc: Len Brown <lenb@kernel.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-03ACPI: Export events via generic netlinkZhang Rui
Upon ACPI events, send an "acpi_event" via Generic Netlink. This is in addition to /proc/acpi/event, which remains intact for now. Thanks to Jamal for his great help. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-03ACPICA: Changes for Cygwin compatibilityBob Moore
Allow generation of ACPICA apps on Cygwin. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-06-02Pull osi-now into release branchLen Brown
2007-06-02ACPICA: Support for external package objects as method argumentsBob Moore
Implemented support to allow Package objects to be passed as method arguments to the acpi_evaluate_object interface. Previously, this would return an AE_NOT_IMPLEMENTED exception. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-06-02ACPI: Section mismatch ... acpi_map_pxm_to_nodeLuck, Tony
Last of the "Section mismatch" errors from ia64 builds! acpi_map_pxm_to_node() is defined with attribute __cpuinit, but is called by "normal" kernel functions acpi_getnode() and acpi_map_cpu2node(). Commit f363d16fbb9374c0bd7f2757d412c287169094c9 moved the data structures on which this routine operates from __cpuinitdata to regular memory, so this routine can also move out of init space. Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-06-02ACPI: Lindent processor throttling codeLen Brown
2007-06-02ACPI: add ACPI 3.0 _TPC _TSS _PTC throttling supportLuming Yu
adds _TPC _TSS _PTC -- Throttling Present Capabilities Signed-off-by: Luming Yu <luming.yu@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-30ACPI: add __init to acpi_initialize_subsystem()Len Brown
Add __init to: acpi_initialize_subsystem() (and un-export it) acpi_os_initialize() Add __initdata to: acpi_osl_dmi_table[] Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-29ACPI: extend "acpi_osi=" boot optionLen Brown
The boot option "acpi_osi=" has always disabled Linux _OSI support, thus disabling all OS Interface strings which are advertised by Linux to the BIOS. Now... acpi_osi="string" adds the interface string, and acpi_osi="!string" invalidates the pre-defined interface string eg. acpi_osi="!Windows 2006" would disable Linux's claim of Vista compatibility. Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-17acpi: fix potential call to a freed memory section.Aaron Durbin
Strip __cpuinit[data] from Node <-> PXM routines and supporting data structures. Also make pxm_to_node_map and node_to_pxm_map local to the numa acpi module. This fixes a bug triggered by the following conditions: - boot on a machine with a SLIT table defined - kernel is configured w/ CONFIG_HOTPLUG_CPU=n - cat /sys/devices/system/node/node*/distance This will cause an oops by calling into a freed memory section. In particular, on x86_64, __node_distance calls node_to_pxm(). Signed-off-by: Aaron Durbin <adurbin@google.com> Cc: Len Brown <lenb@kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09ACPICA: LindentLen Brown
2007-05-09Revert "ACPICA: fix AML mutex re-entrancy"Len Brown
This reverts commit c0d127b56937c3e72c2b1819161d2f6718eee877. These changes to AML locking were made to allow Notify handlers to be called on the stack and not deadlock. However, that scheme turns out to be flawed and was reverted by the previous commit, so this commit restores the locking to it previous design. Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-09Revert "ACPICA: revert "acpi_serialize" changes"Len Brown
This reverts commit a8f4af6dc6600980885c594f52eecd60edd62013. Thus restoring ACPICA's new acpi_serialize code. This commit by itself may cause a regression, but it is reverted in this order so that subsequent reverts reverts under this one can be made without conflict. Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-08PNPACPI sets pnpdev->dev.archdataDavid Brownell
Teach PNPACPI how to hook up its devices to their ACPI nodes, so that pnpdev->dev.archdata points to the parallel acpi device node. Previously this only worked for PCI, leaving a notable hole. Export "acpi_bus_type" so this can work. Remove some extraneous whitespace. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
