path: root/include/acpi
2007-03-20Pull bugzilla-8171 into release branchLen Brown
2007-03-19ACPI: IA64: fix %ll build warningsLen Brown
acpi_integer is 64-bits on all platforms, and so was defined as a u64. i386 and x86_64 define u64 as unsigned long long. ia64 defines u64 as long. While these are all 64-bits, the kernel build warns about formating a "long" with %ll: drivers/ata/libata-acpi.c:176: warning: long long unsigned int format, acpi_integer arg (arg 5) So skip using "u64" and define acpi_integer as "unsigned long long" to make gcc happy with %ll. Signed-off-by: Len Brown <len.brown@intel.com>
2007-03-15ACPICA: revert "acpi_serialize" changesLen Brown
This reverts 977a6226feae3e2c10a4d8227625ff0f04b49239 and reverts 1ba753acb372c2955a4843302e92e49ce82e2fea and updates acpi_ev_queue_notify_request() to restore the previous implementation of the "acpi_serialize" workaround. http://bugzilla.kernel.org/show_bug.cgi?id=8171 Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-16Pull bugzilla-7887 into release branchLen Brown
2007-02-16Pull bugzilla-5534 into release branchLen Brown
2007-02-16Pull remove-hotkey into release branchLen Brown
2007-02-16ACPI: hotkey: remove driver, per feature-removal-schedule.txtLen Brown
2007-02-16Pull misc-for-upstream into release branchLen Brown
Conflicts: drivers/usb/misc/appledisplay.c Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-16[PATCH] ACPI keep track of timer broadcastingThomas Gleixner
This is a preperatory patch for highres/dyntick: - replace the big #ifdef ARCH_APICTIMER_STOPS_ON_C3 hackery by functions - remove the double switch in the power verify function (in the worst case we switched ipi to apic and 20usec later apic to ipi) - keep track of the the state which stops local APIC timer Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Len Brown <len.brown@intel.com> Cc: <linux-acpi@vger.kernel.org> Cc: Andi Kleen <ak@suse.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-15ACPI: remove acpi_os_readable(), acpi_os_writable()Len Brown
...which are now unused Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-15ACPICA: fix AML mutex re-entrancyAlexey Starikovskiy
ACPI AML supports "serialized" methods which are protected by an implicit mutex. The mutex is re-entrant for that AML thread to allow recursion. However, Linux implements notify() by creating a new AML thread. So for systems where notify() re-enters a serialized method, deadlock results. The fix is to use the Linux thread_id as the key to allowing re-entrancy, not the AML thread pointer. http://bugzilla.kernel.org/show_bug.cgi?id=5534 Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-10ACPI: invoke acpi_sleep_init() earlierAlexey Starikovskiy
late_initcall() is too late for acpi_sleep_init(). Call it directly from acpi_init code. http://bugzilla.kernel.org/show_bug.cgi?id=7887 Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@linux.intel.com> Signed-off-by: Vladimir Lebedev <vladimir.p.lebedev@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-09ACPI: bay: fix build warningAndrew Morton
drivers/acpi/bay.c: In function 'bay_add': drivers/acpi/bay.c:310: warning: statement with no effect Fix it by rewriting those macros in C. Much nicer. Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-03Pull sysfs into test branchLen Brown
Conflicts: Documentation/feature-removal-schedule.txt include/acpi/acpi_drivers.h Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Update version to 20070126Bob Moore
Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Update copyright to 2007.Bob Moore
Added 2007 copyright to all module headers and signons. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and the utilities. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Allow processor to be declared with the Device() instead of Processor()Alexey Starikovskiy
Allow processor to be declered with the Device(), such as: Device(CPU1234) { Name(_HID, "ACPI007") Name(_UID, 1234) } Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Update version to 20061215Bob Moore
2007-02-02ACPICA: Added option to display memory statistics upon termination.Bob Moore
2007-02-02ACPICA: Enhance debugger statistics/memory command.Valery A. Podrezov
Debugger: Enhanced the Statistics/Memory command to emit the total (maximum) memory used during execution, as well as the maximum memory consumed by each of the various object types. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Update a comment.Bob Moore
2007-02-02ACPICA: Debugger multithreading enhancements.Bob Moore
Implemented enhancements to the multithreading support within the debugger to enable better multithreading evaluation of the subsystem. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Removed all 16-bit support.Bob Moore
Support for 16-bit ACPICA has been completely removed since it is no longer necessary and it clutters the code. All 16-bit macros, types, and conditional compiles have been removed, cleaning up and simplifying the code across the entire subsystem. DOS support is no longer needed since the Linux firmware kit is now available. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Update version to 20061109Bob Moore
2007-02-02ACPICA: Fail AcpiEnable if ACPI tables not loaded.Bob Moore
AcpiEnable will now fail if all of the required ACPI tables are not loaded (FADT, FACS, DSDT). BZ 477 Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Add ACPI_MAX macroBob Moore
2007-02-02ACPICA: Ensure that all structures in acobject.h are aligned, via #pragma.Bob Moore
Thus, even if the default compiler setting is non-aligned, the header is compiled correctly. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Fixes for load() operator.Alexey Starikovskiy
Optimized the Load operator in the case where the source operand is an operation region. Simply map the operation region memory, instead of performing a bytewise read. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Miscellaneous table manager updates and optimizationsAlexey Starikovskiy
2007-02-02ACPICA: Remove duplicate table definitions.Alexey Starikovskiy
2007-02-02ACPICA: use new ACPI headers.Alexey Starikovskiy
2007-02-02ACPICA: Update version to 20061011Bob Moore
2007-02-02ACPICA: Use manifest constants for parse pass numberBob Moore
2007-02-02ACPICA: Fix race condition with AcpiWalkNamespace.Bob Moore
Fixed a problem with a possible race condition between threads executing AcpiWalkNamespace and the AML interpreter. This condition was removed by modifying AcpiWalkNamespace to (by default) ignore all temporary namespace entries created during any concurrent control method execution Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Restructured module into multiple functions.Mikhail Kouzmich
Restructured the AML ParseLoop function, breaking it into several subfunctions in order to reduce CPU stack use and improve maintainability Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Update version to 20060927Bob Moore
2007-02-02ACPICA: Add new subsystem state bit that is set after SubsystemInitialize is ↵Bob Moore
called Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Remove obsolete Flags parameter.Bob Moore
Remove flags parameter for acpi_{get,set}_register(). It is no longer necessary now that these functions use a spinlock for mutual exclusion. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Add full table name to disassembler outputBob Moore
2007-02-02ACPICA: Update version to 20060912Bob Moore
2007-02-02ACPICA: New common routine for creating and verifying a local FADT.Bob Moore
2007-02-02ACPICA: FADT verification is now table driven.Bob Moore
Disassembler now verifies an input Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Add declarations for ASF! sub-tablesBob Moore
2007-02-02ACPICA: IsResourceTemplate now returns ACPI_STATUSBob Moore
to differentiate the failure modes. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: re-factor table init routines for benefit of iASLBob Moore
Required new table init interface since iASL does not use RSDP/XSDT. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: add ASF commentBob Moore
2007-02-02ACPICA: Delete stale FADT functions outside tbfadt.c.Bob Moore
Moved all FADT-related functions to a new file, tbfadt.c. Eliminated the acpi_hw_initialize function - the FADT registers are now validated when the table is loaded. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Re-implement interpreters' "serialized mode"Bob Moore
Enhanced the implementation of the interpreters' serialized mode (boot with "acpi_serialize" to set acpi_glb_all_methods_serialized flag.) When this mode is specified, instead of creating a serialization semaphore per control method, the interpreter lock is simply no longer released before a blocking operation during control method execution. This effectively makes the AML Interpreter single-threaded. The overhead of a semaphore per-method is eliminated. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Update version to 20060831Bob Moore
2007-02-02ACPICA: Split acpi_format_exception into two partsBob Moore
Split acpi_format_exception into two parts. New function is acpi_ut_verify_exception and will be used to verify exception codes returned by user. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
