path: root/include/acpi
2015-11-07Merge branch 'acpi-pci'Rafael J. Wysocki
* acpi-pci: PCI: ACPI: Add support for PCI device DMA coherency PCI: OF: Move of_pci_dma_configure() to pci_dma_configure() of/pci: Fix pci_get_host_bridge_device leak device property: ACPI: Remove unused DMA APIs device property: ACPI: Make use of the new DMA Attribute APIs device property: Adding DMA Attribute APIs for Generic Devices ACPI: Adding DMA Attribute APIs for ACPI Device device property: Introducing enum dev_dma_attr ACPI: Honor ACPI _CCA attribute setting Conflicts: drivers/crypto/ccp/ccp-platform.c
2015-11-07device property: ACPI: Remove unused DMA APIsSuthikulpanit, Suravee
These DMA APIs are replaced with the newer versions, which return the enum dev_dma_attr. So, we can safely remove them. Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-11-07ACPI: Adding DMA Attribute APIs for ACPI DeviceSuthikulpanit, Suravee
Adding acpi_get_dma_attr() to query DMA attributes of ACPI devices. It returns the enum dev_dma_attr, which communicates DMA information more clearly. This API replaces the acpi_check_dma(), which will be removed in subsequent patch. This patch also provides a convenient function, acpi_dma_supported(), to check DMA support of the specified ACPI device. Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-11-07ACPI: Honor ACPI _CCA attribute settingJeremy Linton
ACPI configurations can now mark devices as noncoherent, support that choice. NOTE: This is required to support USB on ARM Juno Development Board. Signed-off-by: Jeremy Linton <jeremy.linton@arm.com> Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-11-02Merge branch 'device-properties' into acpi-pciRafael J. Wysocki
2015-11-02Merge branch 'acpi-processor'Rafael J. Wysocki
* acpi-processor: ACPI / CPPC: Fix potential memory leak ACPI / CPPC: signedness bug in register_pcc_channel() ACPI: Allow selection of the ACPI processor driver for ARM64 CPPC: Probe for CPPC tables for each ACPI Processor object ACPI: Add weak routines for ACPI CPU Hotplug ACPI / CPPC: Add a CPUFreq driver for use with CPPC ACPI: Introduce CPU performance controls using CPPC
2015-11-02Merge branch 'acpica'Rafael J. Wysocki
* acpica: ACPICA: Update version to 20150930 ACPICA: Debugger: Fix dead lock issue ocurred in single stepping mode ACPI: Enable build of AML interpreter debugger ACPICA: Debugger: Add thread ID support so that single step mode can only apply to the debugger thread ACPICA: Debugger: Fix "terminate" command by cleaning up subsystem shutdown logic ACPICA: Debugger: Fix "quit/exit" command by cleaning up user commands termination logic ACPICA: Linuxize: Export debugger files to Linux ACPICA: iASL: General cleanup of the file suffix #defines ACPICA: Improve typechecking, both compile-time and runtime ACPICA: Update NFIT table to rename a flags field ACPICA: Debugger: Update mutexes used for multithreaded debugger ACPICA: Update exception code for "file not found" error ACPICA: iASL: Add symbolic operator support for Index() operator ACPICA: Remove unnecessary conditional compilation
2015-10-25Merge branches 'acpi-scan', 'acpi-tables', 'acpi-ec' and 'acpi-assorted'Rafael J. Wysocki
* acpi-scan: ACPI / scan: use kstrdup_const() in acpi_add_id() ACPI / scan: constify struct acpi_hardware_id::id ACPI / scan: constify first argument of struct acpi_scan_handler::match * acpi-tables: ACPI / tables: test the correct variable x86, ACPI: Handle apic/x2apic entries in MADT in correct order ACPI / tables: Add acpi_subtable_proc to ACPI table parsers * acpi-ec: ACPI / EC: Fix a race issue in acpi_ec_guard_event() ACPI / EC: Fix query handler related issues * acpi-assorted: ACPI: change acpi_sleep_proc_init() to return void ACPI: change init_acpi_device_notify() to return void
2015-10-25Merge branch 'device-properties'Rafael J. Wysocki
* device-properties: ACPI / property: Fix subnode lookup scope for data-only subnodes acpi-dma: Add support for "dma-names" device property device property: Add fwnode_property_match_string() ACPI / property: Extend device_get_next_child_node() to data-only nodes ACPI / gpio: Split acpi_get_gpiod_by_index() ACPI / property: Extend fwnode_property_* to data-only subnodes ACPI / property: Expose data-only subnodes via sysfs ACPI / property: Add support for data-only subnodes ACPI / property: Add routine for extraction of _DSD properties
2015-10-22ACPICA: Update version to 20150930Bob Moore
ACPICA commit e9c75ca267262326e80d49a290e8387a5963e2d2 Version 20150930. Link: https://github.com/acpica/acpica/commit/e9c75ca2 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-10-22ACPI: Enable build of AML interpreter debuggerLv Zheng
This patch enables ACPICA debugger files using a configurable CONFIG_ACPI_DEBUGGER configuration item. Those debugger related code that was originally masked as ACPI_FUTURE_USAGE now gets unmasked. Necessary OSL stubs are also added in this patch: 1. acpi_os_readable(): This should be arch specific in Linux, while this patch doesn't introduce real implementation and a complex mechanism to allow architecture specific acpi_os_readable() to be implemented to validate the address. It may be done by future commits. 2. acpi_os_get_line(): This is used to obtain debugger command input. This patch only introduces a simple KDB concept example in it and the example should be co-working with the code implemented in acpi_os_printf(). Since this KDB example won't be compiled unless ENABLE_DEBUGGER is defined and it seems Linux has already stopped to use ENABLE_DEBUGGER, thus do not expect it can work properly. This patch also cleans up all other ACPI_FUTURE_USAGE surroundings accordingly. 1. Since linkage error can be automatically detected, declaration in the headers needn't be surrounded by ACPI_FUTURE_USAGE. So only the following separate exported fuction bodies are masked by this macro (other exported fucntions may have already been masked at entire module level via drivers/acpi/acpica/Makefile): acpi_install_exception_handler() acpi_subsystem_status() acpi_get_system_info() acpi_get_statistics() acpi_install_initialization_handler() 2. Since strip can automatically zap the no-user functions, functions that are not marked with ACPI_EXPORT_SYMBOL() needn't get surrounded by ACPI_FUTURE_USAGE. So the following function which is not used by Linux kernel now won't get surrounded by this macro: acpi_ps_get_name() Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-10-22ACPICA: Debugger: Add thread ID support so that single step mode can only ↵Lv Zheng
apply to the debugger thread When the debugger is running in the kernel mode, acpi_db_single_step() may also be invoked by the kernel runtime code path but the single stepping command prompt may be erronously logged as the kernel logs and runtime code path cannot proceed. This patch fixes this issue by adding acpi_gbl_db_thread_id for the debugger thread and preventing acpi_db_single_step() to be invoked from other threads. It is not suitable to add acpi_thread_id parameter for acpi_os_execute() as the function may be implemented as work queue on some hosts. So it is better to let the hosts invoke acpi_set_debugger_thread_id(). Currently acpiexec is not configured as DEBUGGER_MULTI_THREADED, but we can do this. When we do this, it is better to invoke acpi_set_debugger_thread_id() in acpi_os_execute() when the execution type is OSL_DEBUGGER_MAIN_THREAD. The support should look like: create_thread(&tid); if (type == OSL_DEBUGGER_MAIN_THREAD) acpi_set_debugger_thread_id(tid); resume_thread(tid); Similarly, semop() may be used for pthread implementation. But this patch simply skips debugger thread ID check for application instead of introducing such complications as there is no need to skip acpi_db_single_step() for an application debugger - acpiexec. Note that the debugger thread ID can also be used by acpi_os_printf() to filter out debugger output. Lv Zheng. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-10-22ACPICA: Improve typechecking, both compile-time and runtimeBob Moore
ACPICA commit 8d0f96e2a11a4ceabb2cae4b41e0ce1f4d3786b9 Adds much stricter typechecking in the iASL compiler, and also adds some additional checking in the interpreter. Link: https://github.com/acpica/acpica/commit/8d0f96e2 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-10-22ACPICA: Update NFIT table to rename a flags fieldBob Moore
ACPICA commit 534deab97fb416a13bfede15c538e2c9eac9384a Updated one of the memory subtable flags to clarify. Link: https://github.com/acpica/acpica/commit/534deab9 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-10-22ACPICA: Debugger: Update mutexes used for multithreaded debuggerBob Moore
ACPICA commit 6b2701f619040e803313363f516b200e362a9100 Make these mutex objects independent of the deadlock detection mechanism. This mechanism caused failures with the multithread debugger. This patch doesn't affect Linux kernel as debugger is currently not fully functioning in the Linux kernel. And the further debugger cleanups will take care of handling debugger command signalling correctly instead of using such kind of mutexes. So it is safe to leave this patch as it is. Link: https://github.com/acpica/acpica/commit/6b2701f6 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-10-22ACPICA: Remove unnecessary conditional compilationBob Moore
ACPICA commit eea1f0e561893b6d6417913b2d224082fe3a0a5e Remove use of ACPI_DEBUGGER and ACPI_DISASSEMBLER where these defines are used around entire modules. Note: This type of code also causes problems with IDEs. Link: https://github.com/acpica/acpica/commit/eea1f0e5 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-10-12CPPC: Probe for CPPC tables for each ACPI Processor objectAshwin Chaugule
For each detected ACPI Processor object (ACPI0007), search its device handle for CPPC specific tables (i.e. _CPC) and extract CPU specific performance capabilities. Signed-off-by: Ashwin Chaugule <ashwin.chaugule@linaro.org> Reviewed-by: Al Stone <al.stone@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-10-12ACPI: Introduce CPU performance controls using CPPCAshwin Chaugule
CPPC stands for Collaborative Processor Performance Controls and is defined in the ACPI v5.0+ spec. It describes CPU performance controls on an abstract and continuous scale allowing the platform (e.g. remote power processor) to flexibly optimize CPU performance with its knowledge of power budgets and other architecture specific knowledge. This patch adds a shim which exports commonly used functions to get and set CPPC specific controls for each CPU. This enables CPUFreq drivers to gather per CPU performance data and use with exisiting governors or even allows for customized governors which are implemented inside CPUFreq drivers. Signed-off-by: Ashwin Chaugule <ashwin.chaugule@linaro.org> Reviewed-by: Al Stone <al.stone@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-09-15ACPI: Eliminate CONFIG_.*{, _MODULE} #ifdef in favor of IS_ENABLED()Sudeep Holla
This commit removes all CONFIG_.*{,_MODULE} in ACPI code, replacing it with IS_ENABLED(). Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-09-15ACPI / scan: constify struct acpi_hardware_id::idRasmus Villemoes
This is preparation for using kstrdup_const to initialize that member. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-09-15ACPI / scan: constify first argument of struct acpi_scan_handler::matchRasmus Villemoes
One wouldn't expect a "match" function modify the string it searches for, and indeed the only instance of the struct acpi_scan_handler::match callback, acpi_pnp_match, can easily be changed. While there, update its helper matching_id(). This is also preparation for constifying struct acpi_hardware_id::id. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-09-15ACPI / property: Extend fwnode_property_* to data-only subnodesRafael J. Wysocki
Modify is_acpi_node() to return "true" for ACPI data-only subnodes as well as for ACPI device objects and change the name of to_acpi_node() to to_acpi_device_node() so it is clear that it covers ACPI device objects only. Accordingly, introduce to_acpi_data_node() to cover data-only subnodes in an analogous way. With that, make the fwnode_property_* family of functions work with ACPI data-only subnodes introduced previously. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
2015-09-15ACPI / property: Expose data-only subnodes via sysfsRafael J. Wysocki
Add infrastructure needed to expose data-only subnodes of ACPI device objects introduced previously via sysfs. Each data-only subnode is represented as a sysfs directory under the directory corresponding to its parent object (a device or a data-only subnode). Each of them has a "path" attribute (containing the full ACPI namespace path to the object the subnode data come from) at this time. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
2015-09-15ACPI / property: Add support for data-only subnodesRafael J. Wysocki
In some cases, the information expressed via device properties is hierarchical by nature. For example, the properties of a composite device consisting of multiple semi-dependent components may need to be represented in the form of a tree of property data sets corresponding to specific components of the device. Unfortunately, using ACPI device objects for this purpose turns out to be problematic, mostly due to the assumption made by some operating systems (that platform firmware generally needs to work with) that each device object in the ACPI namespace represents a device requiring a separate driver. That assumption leads to complications which reportedly are impractically difficult to overcome and a different approach is needed for the sake of interoperability. The approach implemented here is based on extending _DSD via pointers (links) to additional ACPI objects returning data packages formatted in accordance with the _DSD formatting rules defined by Section 6.2.5 of ACPI 6. Those additional objects are referred to as data-only subnodes of the device object containing the _DSD pointing to them. The links to them need to be located in a separate section of the _DSD data package following UUID dbb8e3e6-5886-4ba6-8795-1319f52a966b referred to as the Hierarchical Data Extension UUID as defined in [1]. Each of them is represented by a package of two strings. The first string in that package (the key) is regarded as the name of the data-only subnode pointed to by the link. The second string in it (the target) is expected to hold the ACPI namespace path (possibly utilizing the usual ACPI namespace search rules) of an ACPI object evaluating to a data package extending the _DSD. The device properties initialization code follows those links, creates a struct acpi_data_node object for each of them to store the data returned by the ACPI object pointed to by it and processes those data recursively (which may lead to the creation of more struct acpi_data_node objects if the returned data package contains the Hierarchical Data Extension UUID section with more links in it). All of the struct acpi_data_node objects are present until the the ACPI device object containing the _DSD with links to them is deleted and they are deleted along with that object. [1]: http://www.uefi.org/sites/default/files/resources/_DSD-hierarchical-data-extension-UUID-v1.pdf Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
2015-09-01Merge branch 'pm-cpufreq'Rafael J. Wysocki
* pm-cpufreq: (53 commits) cpufreq: speedstep-lib: Use monotonic clock cpufreq: powernv: Increase the verbosity of OCC console messages cpufreq: sfi: use kmemdup rather than duplicating its implementation cpufreq: drop !cpufreq_driver check from cpufreq_parse_governor() cpufreq: rename cpufreq_real_policy as cpufreq_user_policy cpufreq: remove redundant 'policy' field from user_policy cpufreq: remove redundant 'governor' field from user_policy cpufreq: update user_policy.* on success cpufreq: use memcpy() to copy policy cpufreq: remove redundant CPUFREQ_INCOMPATIBLE notifier event cpufreq: mediatek: Add MT8173 cpufreq driver dt-bindings: mediatek: Add MT8173 CPU DVFS clock bindings intel_pstate: append more Oracle OEM table id to vendor bypass list intel_pstate: Add SKY-S support intel_pstate: Fix possible overflow complained by Coverity cpufreq: Correct a freq check in cpufreq_set_policy() cpufreq: Lock CPU online/offline in cpufreq_register_driver() cpufreq: Replace recover_policy with new_policy in cpufreq_online() cpufreq: Separate CPU device registration from CPU online cpufreq: powernv: Restore cpu frequency to policy->cur on unthrottling ...
2015-09-01Merge branches 'acpi-scan', 'acpi-processor' and 'acpi-assorted'Rafael J. Wysocki
* acpi-scan: ACPI / bus: Move ACPI bus type registration ACPI / scan: Move bus operations and notification routines to bus.c ACPI / scan: Move device matching code to bus.c ACPI / scan: Move sysfs-related device code to a separate file * acpi-processor: PCC: Disable compilation by default ACPI: Decouple ACPI idle and ACPI processor drivers ACPI: Split out ACPI PSS from ACPI Processor driver PCC: Initialize PCC Mailbox earlier at boot ACPI / processor: remove leftover __refdata annotations * acpi-assorted: ACPI: fix acpi_debugfs_init prototype ACPI: Remove FSF mailing addresses
2015-08-25ACPICA: Update version to 20150818Bob Moore
ACPICA commit d93470de8febeecdc20633fde11cb0b200fa773b Version 20150818. Link: https://github.com/acpica/acpica/commit/d93470de Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-08-25ACPICA: Debugger: Split debugger initialization/termination APIsLv Zheng
ACPICA commit 7a3f22baab000b186779dac64ad71d9776b8f432 It is likely that the debugger is enabled only when a userspace program explicitly tells a kernel to do so, so it shouldn't be initialized as early as current implementation. The only tool requiring ACPI_DEBUGGER is acpiexec, so acpiexec need to call the new APIs by itself. And BSD developers may also get notified to invoke the APIs for DDB enabling. Lv Zheng. This patch doesn't affect Linux kernel as debugger is currently not enabled in the Linux kernel. Link: https://github.com/acpica/acpica/commit/7a3f22ba Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-08-25ACPICA: Header support to improve compatibility with MSVCBob Moore
ACPICA commit 5b4087fba991d8383046b550bbe22f3d8d9b9c8f Needed to improve MSVC editor support for symbols. For Linux kernel, this change is a no-op. Link: https://github.com/acpica/acpica/commit/5b4087fb Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-08-25ACPICA: Make the max-number-of-loops runtime configurableBob Moore
ACPICA commit a9d9c2d0c2d077bb3175ec9c252cf0e5da3efd45 Was previously compile-time only. Add support option for acpiexec. Link: https://github.com/acpica/acpica/commit/a9d9c2d0 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-08-25ACPICA: Debugger: Add option to display namespace summary/countsBob Moore
ACPICA commit bba222c15c2ce79076eb3a5e9d4d5f7120db8a00 If "Objects" command is invoked with no arguments, the counts for each object type are displayed. Linux kernel is not affected by this commit as currently debugger is not enabled in the Linux kernel. Link: https://github.com/acpica/acpica/commit/bba222c1 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-08-25ACPICA: Headers: Fix some comments, no functional changeBob Moore
ACPICA commit 539f8c03fe64305725bd85343e42f3b6c42aad14 A couple typos and long lines. Link: https://github.com/acpica/acpica/commit/539f8c03 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-08-25ACPICA: Disassembler: Remove duplicate code in _PLD processing.Bob Moore
ACPICA commit 6d9c827b540837b6e54059e17756a06985e4a196 ACPICA BZ 1176. Link: https://bugs.acpica.org/show_bug.cgi?id=1176 Link: https://github.com/acpica/acpica/commit/6d9c827b Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-08-25ACPICA: Correctly cleanup after a ACPI table load failureBob Moore
ACPICA commit ed7769e832de6c7ba90615480d916c85fd100422 If a table load fails, delete all namespace objects created by the table, otherwise these objects will be uninitialized, causing problems later. This appears to be a very rare problem. Also handle the unitialized node problem to prevent possible faults. ACPICA BZ 1185. Link: https://github.com/acpica/acpica/commit/ed7769e8 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-08-25ACPI: Decouple ACPI idle and ACPI processor driversAshwin Chaugule
This patch introduces a new Kconfig symbol, ACPI_PROCESSOR_IDLE, which is auto selected by architectures which support the ACPI based C states for CPU Idle management. The processor_idle driver in its present form contains declarations specific to X86 and IA64. Since there are no reasonable defaults for other architectures e.g. ARM64, the driver is selected only for X86 or IA64. This helps in decoupling the ACPI processor_driver from the ACPI processor_idle driver which is useful for the upcoming alternative patchwork for controlling CPU Performance (CPPC) and CPU Idle (LPI). Signed-off-by: Ashwin Chaugule <ashwin.chaugule@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-08-25ACPI: Split out ACPI PSS from ACPI Processor driverAshwin Chaugule
The ACPI processor driver is currently tied too closely to the ACPI P-states (PSS) and other related constructs for controlling CPU performance. The newer ACPI specification (v5.1 onwards) introduces alternative methods to PSS. These new mechanisms are described within each ACPI Processor object and so they need to be scanned whenever a new Processor object is detected. This patch introduces a new Kconfig symbol to allow for finer configurability among the two options for controlling performance states. There is no change in functionality and the option is auto-selected by the architectures which support it. A future commit will introduce support for CPPC: A newer method of controlling CPU performance. The OS is not expected to support CPPC and PSS at the same time, so the Kconfig option lets us make the two mutually exclusive at compile time. Signed-off-by: Ashwin Chaugule <ashwin.chaugule@linaro.org> [ rjw: Changelog ] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-23ACPICA: Update version to 20150717Bob Moore
ACPICA commit 8580ce04c1b7aa415c364b06e79edb8aca77dded Version 20150717. Link: https://github.com/acpica/acpica/commit/8580ce04 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-23ACPICA: iASL: Add support for TCPA Server TableBob Moore
ACPICA commit 55fa9555c71eaa99daebed4cd82cfde3875e8c45 In addition to the existing support for the client table. Link: https://github.com/acpica/acpica/commit/55fa9555 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-23ACPICA: MSVC: Fix inclusion order issue of <crtdbg.h>Lv Zheng
ACPICA commit 49c6a6517a906900e9baa51ad5859beeb8a3089f The following error logs can be seen for calloc/free/malloc/realloc that defined in the stdlib.h: ...\stdlib.h(281) : error C2059: syntax error : ',' ...\stdlib.h(281) : error C2143: syntax error : missing ')' before 'constant' ...\stdlib.h(281) : error C2143: syntax error : missing '{' before 'constant' ...\stdlib.h(281) : error C2059: syntax error : '<Unknown>' ...\stdlib.h(281) : error C2059: syntax error : ')' This is caused by the wrong inclusion order of stdlib.h/crtdbg.h introduced in acenv.h. This patch fixes this breakage. Lv Zheng. This patch doesn't affect Linux kernel. Link: https://github.com/acpica/acpica/commit/49c6a651 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-23ACPICA: Executer: Add option to bypass opcode tracingLv Zheng
ACPICA commit 61e9e20aadfaa03184d0959fbdc1fa5cdfea2551 This patch adds option to bypass opcode tracing. The option can be used to reduce the trace message output. Lv Zheng. Link: https://github.com/acpica/acpica/commit/61e9e20a Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-23ACPICA: Executer: Add OSL trace hook supportLv Zheng
ACPICA commit e8e4a9b19d0b72a7b165398bdc961fc2f6f502ec This patch adds OSL trace hook support. OSPMs are encouraged to use acpi_os_trace_point() with ACPI_USE_SYSTEM_TRACER defined to implement platform specific trace facility. Lv Zheng. Link: https://github.com/acpica/acpica/commit/e8e4a9b1 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-23ACPICA: Executer: Add interpreter tracing mode for method tracing facilityLv Zheng
ACPICA commit 07fffd02607685b655ed92ee15c160e6a810b60b The acpi_debug_trace() is the mechanism known as ACPI method tracing that is used by Linux as ACPICA debugging message reducer. This facility can be controlled through Linux ACPI subsystem - /sys/module/acpi/parameters. This facility requires CONFIG_ACPI_DEBUG to be enabled to see ACPICA trace logs in the kernel dmesg output. This patch enhances acpi_debug_trace() to make it not only a message reducer, but a real tracer to trace AML interpreter execution. Note that in addition to the AML tracer enabling, this patch also updates the facility with the following enhancements: 1. Allow a full path to be specified by the acpi_debug_trace() API. 2. Allow any method rather than just the entrance of acpi_evaluate_object() to be traced. 3. All interpreter ACPI_LV_TRACE_POINT messages are collected for ACPI_EXECUTER layer. The Makefile of drivers/acpi/acpica is also updated to include exdebug.o and the duplicated stubs are removed after that. Note that since this patch has enhanced the method tracing facility, Linux need also be updated after applying this patch. Lv Zheng. Link: https://github.com/acpica/acpica/commit/07fffd02 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-23ACPICA: Dispatcher: Add trace support for interpreterLv Zheng
ACPICA commit 71299ec8b49054daace0df50268e8e055654ca37 This patch adds trace point at the following point: 1. Begin/end of a control method execution; 2. Begin/end of an opcode execution. The trace point feature can be enabled by defining ACPI_DEBUG_OUTPUT and specifying a debug level that includes ACPI_LV_TRACDE_POINT and the debug layers that include ACPI_PARSER and ACPI_DISPACTCHER. In order to make aml_op_name of union acpi_parse_object usable for tracer, it is enabled for ACPI_DEBUG_OUTPUT in this patch. Lv Zheng. Link: https://github.com/acpica/acpica/commit/71299ec8 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-23ACPICA: Namespace: Add function to directly return normalized full pathLv Zheng
ACPICA commit 6e0229bb156d71675f2e07dc7960adb7ec0a60ea This patch adds functions to return normalized full path instead of "external path". The external path contains trailing "_" for each name segment while the normalized full path doesn't contain the trailing "_". Currently this function is used by the method tracing users to specify a none trailing "_" attached name path. Lv Zheng. Note that we need to validate and switch all Linux kernel acpi_get_name() users to use the new name type before removing the old name type from ACPICA. Link: https://github.com/acpica/acpica/commit/6e0229bb Signed-off-by: Lv Zheng <lv.zheng@intel.com> Reviewed-by: Ruiyi Zhang <ruiyi_zhang@hotmail.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-22ACPI / processor: Drop an unused argument of a cleanup routineRafael J. Wysocki
acpi_processor_unregister_performance() actually doesn't use its first argument, so drop it and update the callers accordingly. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
2015-07-08ACPI: Remove FSF mailing addressesJarkko Nikula
There is no need to carry potentially outdated Free Software Foundation mailing address in file headers since the COPYING file includes it. Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-02Merge tag 'acpica-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPICA updates from Rafael Wysocki: "Additional ACPICA material for v4.2-rc1 This will update the ACPICA code in the kernel to upstream revision 20150619 (a bug-fix release mostly including stable-candidate fixes) and restore an earlier ACPICA commit that had to be reverted due to a regression introduced by it (the regression is addressed by blacklisting the only known system affected by it to date). The only new feature added by this update is the support for overriding objects in the ACPI namespace and a new ACPI table that can be used for that called the Override System Definition Table (OSDT). That should allow us to "patch" the ACPI namespace built from incomplete or incorrect ACPI System Definition tables (DSDT, SSDT) during system startup without the need to provide replacements for all of those tables in the future. Specifics: - Fix system resume problems related to 32-bit and 64-bit versions of the Firmware ACPI Control Structure (FACS) in the firmare (Lv Zheng) - Fix double initialization of the FACS (Lv Zheng) - Add _CLS object processing code to ACPICA (Suravee Suthikulpanit) - Add support for the (currently missing) new GIC version field in the Multiple APIC Description Table (MADT) (Hanjun Guo) - Add support for overriding objects in the ACPI namespace to ACPICA and OSDT support (Lv Zheng, Bob Moore, Zhang Rui) - Updates related to the TCPA and TPM2 ACPI tables (Bob Moore) - Restore the commit modifying _REV to always return "2" (as required by ACPI 6) and add a blacklisting mechanism for systems that may be affected by that change (Rafael J Wysocki) - Assorted fixes and cleanups (Bob Moore, Lv Zheng, Sascha Wildner)" * tag 'acpica-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (28 commits) Revert 'Revert "ACPICA: Permanently set _REV to the value '2'."' ACPI / init: Make it possible to override _REV ACPICA: Update version to 20150619 ACPICA: Comment update, no functional change ACPICA: Update TPM2 ACPI table ACPICA: Update definitions for the TCPA and TPM2 ACPI tables ACPICA: Split C library prototypes to new header ACPICA: De-macroize calls to standard C library functions ACPI / acpidump: Update acpidump manual ACPICA: acpidump: Convert the default behavior to dump from /sys/firmware/acpi/tables ACPICA: acpidump: Allow customized tables to be dumped without accessing /dev/mem ACPICA: Cleanup output for the ASL Debug object ACPICA: Update for acpi_install_table memory types ACPICA: Namespace: Change namespace override to avoid node deletion ACPICA: Namespace: Add support of OSDT table ACPICA: Namespace: Add support to allow overriding objects ACPICA: ACPI 6.0: Add values for MADT GIC version field ACPICA: Utilities: Add _CLS processing ACPICA: Add dragon_fly support to unix file mapping file ACPICA: EFI: Add EFI interface definitions to eliminate dependency of GNU EFI ...
2015-07-01ACPICA: Update version to 20150619Bob Moore
ACPICA commit 2fcf4f4c95e6a4875f39a929f8f92ef50cc53bb5 ACPICA commit d7a940bb308d001b5d2b196174fee36c7daa61d6 Version 20150619. Link: https://github.com/acpica/acpica/commit/2fcf4f4c Link: https://github.com/acpica/acpica/commit/d7a940bb Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-01ACPICA: Update TPM2 ACPI tableBob Moore
ACPICA commit 254bf77e7ca01cb27e026fa5737f7df8dae03f2c - Add constans for the start_method. - Remove the control structure, not part of ACPI, not defined in the current TCG spec. Link: https://github.com/acpica/acpica/commit/254bf77e Reported-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-01ACPICA: Update definitions for the TCPA and TPM2 ACPI tablesBob Moore
ACPICA commit 33140b4498666337dd33a00cf3c4797a53981a7b Changes for a new version of the 3rd party spec for these tables, the "TCG ACPI Specification", December 14, 2014. Also, moved the definition of TPM2 to actbl2.h, next to TCPA, since both should be together. Update the table compiler/disassembler code for the tables. However, the "Server" TCPA table is not supported at this time. Link: https://github.com/acpica/acpica/commit/33140b44 Reported-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
