path: root/include/acpi
2012-01-25ACPI: Store SRAT table revisionKurt Garloff
commit 8df0eb7c9d96f9e82f233ee8b74e0f0c8471f868 upstream. In SRAT v1, we had 8bit proximity domain (PXM) fields; SRAT v2 provides 32bits for these. The new fields were reserved before. According to the ACPI spec, the OS must disregrard reserved fields. In order to know whether or not, we must know what version the SRAT table has. This patch stores the SRAT table revision for later consumption by arch specific __init functions. Signed-off-by: Kurt Garloff <kurt@garloff.de> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-14Merge branches 'd3cold', 'bugzilla-37412' and 'bugzilla-38152' into releaseLen Brown
2011-07-13ACPI: Fixes device power states array overflowLin Ming
Commit 28c2103 added new state ACPI_STATE_D3_COLD, so the device power states array must be expanded by one also. v2: Use ACPI_D_STATE_COUNT instead of number 5 for the array size. Reported-by: Dan Carpenter <error27@gmail.com> Suggested-by: Oldřich Jedlička <oldium.pro@seznam.cz> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-07-13ACPI: Fix lockdep false positives in acpi_power_off()Rafael J. Wysocki
All ACPICA locks are allocated by the same function, acpi_os_create_lock(), with the help of a local variable called "lock". Thus, when lockdep is enabled, it uses "lock" as the name of all those locks and regards them as instances of the same lock, which causes it to report possible locking problems with them when there aren't any. To work around this problem, define acpi_os_create_lock() as a macro and make it pass its argument to spin_lock_init(), so that lockdep uses it as the name of the new lock. Define this macron in a Linux-specific file, to minimize the resulting modifications of the OS-independent ACPICA parts. This change is based on an earlier patch from Andrea Righi and it addresses a regression from 2.6.39 tracked as https://bugzilla.kernel.org/show_bug.cgi?id=38152 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Borislav Petkov <bp@alien8.de> Tested-by: Andrea Righi <andrea@betterlinux.com> Reviewed-by: Florian Mickler <florian@mickler.org> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-29Merge branches 'acpica', 'aml-custom', 'bugzilla-16548', 'bugzilla-20242', ↵Len Brown
'd3-cold', 'ec-asus' and 'thermal-fix' into release
2011-05-29ACPI: Add D3 cold stateLin Ming
_SxW returns an Integer containing the lowest D-state supported in state Sx. If OSPM has not indicated that it supports _PR3, then the value “3” corresponds to D3. If it has indicated _PR3 support, the value “3” represents D3hot and the value “4” represents D3cold. Linux does set _OSC._PR3, so we should fix it to expect that _SxW can return 4. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-29ACPI: processor: fix processor_physically_present in UP kernelLin Ming
Usually, there are multiple processors defined in ACPI table, for example Scope (_PR) { Processor (CPU0, 0x00, 0x00000410, 0x06) {} Processor (CPU1, 0x01, 0x00000410, 0x06) {} Processor (CPU2, 0x02, 0x00000410, 0x06) {} Processor (CPU3, 0x03, 0x00000410, 0x06) {} } processor_physically_present(...) will be called to check whether those processors are physically present. Currently we have below codes in processor_physically_present, cpuid = acpi_get_cpuid(...); if ((cpuid == -1) && (num_possible_cpus() > 1)) return false; return true; In UP kernel, acpi_get_cpuid(...) always return -1 and num_possible_cpus() always return 1, so processor_physically_present(...) always returns true for all passed in processor handles. This is wrong for UP processor or SMP processor running UP kernel. This patch removes the !SMP version of acpi_get_cpuid(), so both UP and SMP kernel use the same acpi_get_cpuid function. And for UP kernel, only processor 0 is valid. https://bugzilla.kernel.org/show_bug.cgi?id=16548 https://bugzilla.kernel.org/show_bug.cgi?id=16357 Tested-by: Anton Kochkov <anton.kochkov@gmail.com> Tested-by: Ambroz Bizjak <ambrop7@gmail.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-09ACPICA: Update to version 20110413Bob Moore
Version 20110413 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-09ACPICA: Execute an orphan _REG method under the EC deviceBob Moore
This change will force the execution of a _REG method underneath the EC device even if there is no corresponding operation region of type EmbeddedControl. Fixes a problem seen on some machines and apparently is compatible with Windows behavior. http://www.acpica.org/bugzilla/show_bug.cgi?id=875 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-09ACPICA: Move ACPI_NUM_PREDEFINED_REGIONS to a more appropriate placeBob Moore
Moved to where the predefined regions are actually defined. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-09ACPICA: Update internal address SpaceID for DataTable regionsBob Moore
Moved this internal space id in preparation for ACPI 5.0 changes that will include some new space IDs. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-25ACPI: osl, add acpi_os_create_lock interfaceLin Ming
2011-03-23Merge branch 'linus' into releaseLen Brown
Conflicts: arch/x86/kernel/acpi/sleep.c Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-23Merge branch 'acpica' into releaseLen Brown
2011-03-23ACPICA: Update version to 20110316Bob Moore
Version 20110316. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-23ACPICA: Header support for SLIC tableBob Moore
We finally have the definition for this table. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-22Merge branch 'apei-release' into releaseLen Brown
2011-03-21ACPI, APEI, Add ERST record ID cacheHuang Ying
APEI ERST firmware interface and implementation has no multiple users in mind. For example, if there is four records in storage with ID: 1, 2, 3 and 4, if two ERST readers enumerate the records via GET_NEXT_RECORD_ID as follow, reader 1 reader 2 1 2 3 4 -1 -1 where -1 signals there is no more record ID. Reader 1 has no chance to check record 2 and 4, while reader 2 has no chance to check record 1 and 3. And any other GET_NEXT_RECORD_ID will return -1, that is, other readers will has no chance to check any record even they are not cleared by anyone. This makes raw GET_NEXT_RECORD_ID not suitable for used by multiple users. To solve the issue, an in-memory ERST record ID cache is designed and implemented. When enumerating record ID, the ID returned by GET_NEXT_RECORD_ID is added into cache in addition to be returned to caller. So other readers can check the cache to get all record ID available. Signed-off-by: Huang Ying <ying.huang@intel.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-18Merge branch 'acpica' into releaseLen Brown
2011-03-15PM: Remove CONFIG_PM_OPSRafael J. Wysocki
After redefining CONFIG_PM to depend on (CONFIG_PM_SLEEP || CONFIG_PM_RUNTIME) the CONFIG_PM_OPS option is redundant and can be replaced with CONFIG_PM. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-02ACPICA: Update version to 20110211.Bob Moore
Version 20110211. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-02ACPICA: Fix unresolved name issue for no-debug and no-error-msg casesBob Moore
The _acpi_module_name was left undefined in these cases, but it is actually needed as a parameter to some interfaces. Define _acpi_module_name as a null string in these cases. Acpica BZ 888. http://www.acpica.org/bugzilla/show_bug.cgi?id=888 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-02ACPICA: Remove use of unreliable FADT revision fieldBob Moore
The revision number in the FADT has been found to be completely unreliable and cannot be trusted. Only the table length can be used to infer the actual version. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-02-24ACPI: Remove the wakeup.run_wake_count device fieldRafael J. Wysocki
The wakeup.run_wake_count ACPI device field is only used by the PCI runtime PM code to "protect" devices from being prepared for generating wakeup signals more than once in a row. However, it really doesn't provide any protection, because (1) all of the functions it is supposed to protect use their own reference counters effectively ensuring that the device will be set up for generating wakeup signals just once and (2) the PCI runtime PM code uses wakeup.run_wake_count in a racy way, since nothing prevents acpi_dev_run_wake() from being called concurrently from two different threads for the same device. Remove the wakeup.run_wake_count ACPI device field which is unnecessary, confusing and used in a wrong way. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-01-20Merge branch 'acpica' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPICA: Update version to 20110112 ACPICA: Update all ACPICA copyrights and signons to 2011 ACPICA: Fix issues/fault with automatic "serialized" method support ACPICA: Debugger: Lock namespace for duration of a namespace dump ACPICA: Fix namespace race condition ACPICA: Fix memory leak in acpi_ev_asynch_execute_gpe_method().
2011-01-18ACPICA: Update version to 20110112Bob Moore
Version 20110112. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-18ACPICA: Update all ACPICA copyrights and signons to 2011Bob Moore
2011-01-14Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI/PM: Report wakeup events before resuming devices PCI/PM: Use pm_wakeup_event() directly for reporting wakeup events PCI: sysfs: Update ROM to include default owner write access x86/PCI: make Broadcom CNB20LE driver EMBEDDED and EXPERIMENTAL x86/PCI: don't use native Broadcom CNB20LE driver when ACPI is available PCI/ACPI: Request _OSC control once for each root bridge (v3) PCI: enable pci=bfsort by default on future Dell systems PCI/PCIe: Clear Root PME Status bits early during system resume PCI: pci-stub: ignore zero-length id parameters x86/PCI: irq and pci_ids patch for Intel Patsburg PCI: Skip id checking if no id is passed PCI: fix __pci_device_probe kernel-doc warning PCI: make pci_restore_state return void PCI: Disable ASPM if BIOS asks us to PCI: Add mask bit definition for MSI-X table PCI: MSI: Move MSI-X entry definition to pci_regs.h Fix up trivial conflicts in drivers/net/{skge.c,sky2.c} that had in the meantime been converted to not use legacy PCI power management, and thus no longer use pci_restore_state() at all (and that caused trivial conflicts with the "make pci_restore_state return void" patch)
2011-01-14PCI/ACPI: Request _OSC control once for each root bridge (v3)Rafael J. Wysocki
Move the evaluation of acpi_pci_osc_control_set() (to request control of PCI Express native features) into acpi_pci_root_add() to avoid calling it many times for the same root complex with the same arguments. Additionally, check if all of the requisite _OSC support bits are set before calling acpi_pci_osc_control_set() for a given root complex. References: https://bugzilla.kernel.org/show_bug.cgi?id=20232 Reported-by: Ozan Caglayan <ozan@pardus.org.tr> Tested-by: Ozan Caglayan <ozan@pardus.org.tr> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-01-13Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (59 commits) ACPI / PM: Fix build problems for !CONFIG_ACPI related to NVS rework ACPI: fix resource check message ACPI / Battery: Update information on info notification and resume ACPI: Drop device flag wake_capable ACPI: Always check if _PRW is present before trying to evaluate it ACPI / PM: Check status of power resources under mutexes ACPI / PM: Rename acpi_power_off_device() ACPI / PM: Drop acpi_power_nocheck ACPI / PM: Drop acpi_bus_get_power() Platform / x86: Make fujitsu_laptop use acpi_bus_update_power() ACPI / Fan: Rework the handling of power resources ACPI / PM: Register power resource devices as soon as they are needed ACPI / PM: Register acpi_power_driver early ACPI / PM: Add function for updating device power state consistently ACPI / PM: Add function for device power state initialization ACPI / PM: Introduce __acpi_bus_get_power() ACPI / PM: Introduce function for refcounting device power resources ACPI / PM: Add functions for manipulating lists of power resources ACPI / PM: Prevent acpi_power_get_inferred_state() from making changes ACPICA: Update version to 20101209 ...
2011-01-12ACPI: Drop device flag wake_capableRafael J. Wysocki
The wake_capable ACPI device flag is not necessary, because it is only used in scan.c for recording the information that _PRW is present for the given device. That information is only used by acpi_add_single_object() to decide whether or not to call acpi_bus_get_wakeup_device_flags(), so the flag may be dropped if the _PRW check is moved to acpi_bus_get_wakeup_device_flags(). Moreover, acpi_bus_get_wakeup_device_flags() always returns 0, so it really should be void. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-12Merge branch 'throttling' into releaseLen Brown
2011-01-12Merge branch 'wakeup-etc-rafael' into releaseLen Brown
2011-01-12Merge branch 'power-resource' into releaseLen Brown
2011-01-12ACPI / PM: Drop acpi_bus_get_power()Rafael J. Wysocki
There are no more users of acpi_bus_get_power(), so it can be dropped. Moreover, it should be dropped, because it modifies the device->power.state field of an ACPI device without updating the reference counters of the device's power resources, which is wrong. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-12ACPI / Fan: Rework the handling of power resourcesRafael J. Wysocki
Use the new function acpi_bus_update_power() for manipulating power resources used by ACPI fan devices, which allows them to be put into the right state during initialization and resume. Consequently, remove the flags.force_power_state field from struct acpi_device, which is not necessary any more. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-12ACPI / PM: Add function for updating device power state consistentlyRafael J. Wysocki
Add function acpi_bus_update_power() for reading the actual power state of an ACPI device and updating its device->power.state field in such a way that its power resources' reference counters will remain consistent with that field. For this purpose introduce __acpi_bus_set_power() setting the power state of an ACPI device without updating its device->power.state field and make acpi_bus_set_power() and acpi_bus_update_power() use it (acpi_bus_set_power() retains the current behavior for now). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-12ACPICA: Update version to 20101209Lin Ming
Version 20101209. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-12ACPICA: Global event handlerLin Ming
The global event handler is called whenever a general purpose or fixed ACPI event occurs. Also update Linux OSL to collect events counter with global event handler. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-12ACPICA: Implicit notify supportLin Ming
This feature provides an automatic device notification for wake devices when a wakeup GPE occurs and there is no corresponding GPE method or handler. Rather than ignoring such a GPE, an implicit AML Notify operation is performed on the parent device object. This feature is not part of the ACPI specification and is provided for Windows compatibility only. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-12ACPICA: New GPE handler callback definitionLin Ming
The new GPE handler callback has 2 additional parameters, gpe_device and gpe_number. typedef u32 (*acpi_gpe_handler) (acpi_handle gpe_device, u32 gpe_number, void *context); Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-12ACPICA: Rename some function and variable namesLin Ming
Some function and variable names are renamed to be consistent with ACPICA code base. acpi_raw_enable_gpe -> acpi_ev_add_gpe_reference acpi_raw_disable_gpe -> acpi_ev_remove_gpe_reference acpi_gpe_can_wake -> acpi_setup_gpe_for_wake acpi_gpe_wakeup -> acpi_set_gpe_wake_mask acpi_update_gpes -> acpi_update_all_gpes acpi_all_gpes_initialized -> acpi_gbl_all_gpes_initialized acpi_handler_info -> acpi_gpe_handler_info ... Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-10ACPI: Reevaluate whether the T-state is supported or not after cpu is ↵Zhao Yakui
online/offline After one CPU is offlined, it is unnecessary to switch T-state for it. So it will be better that the throttling is disabled after the cpu is offline. At the same time after one cpu is online, we should check whether the T-state is supported and then set the corresponding T-state flag. Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-07ACPI / PM: Drop special ACPI wakeup flagsRafael J. Wysocki
Drop special ACPI wakeup flags, wakeup.state.enabled and wakeup.flags.always_enabled, that aren't necessary any more after we've started to use standard device wakeup flags for handling ACPI wakeup devices. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-12-11ACPI: video: fix build for CONFIG_ACPI=nChris Wilson
In file included from drivers/gpu/drm/i915/intel_opregion.c:30: include/acpi/video.h:22: warning: ‘struct acpi_device’ declared inside parameter list ... include/acpi/video.h:24: error: ‘ENODEV’ undeclared (first use in this function) Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Len Brown <len.brown@intel.com>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-26Merge branch 'misc' into releaseLen Brown
2010-10-25Merge branch 'gpe-defer' into releaseLen Brown
