path: root/include/asm-alpha/barrier.h
2008-08-15alpha: move include/asm-alpha to arch/alpha/include/asmLinus Torvalds
Sam Ravnborg did the build-test that the direct header file move works, I'm just committing it. This is a pure move: mkdir arch/alpha/include git mv include/asm-alpha arch/alpha/include/asm with no other changes. Requested-and-tested-by: Sam Ravnborg <sam@ravnborg.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14read_barrier_depends arch fixletsNick Piggin
read_barrie_depends has always been a noop (not a compiler barrier) on all architectures except SMP alpha. This brings UP alpha and frv into line with all other architectures, and fixes incorrect documentation. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-14[PATCH] remove set_wmb - arch removalSteven Rostedt
set_wmb should not be used in the kernel because it just confuses the code more and has no benefit. Since it is not currently used in the kernel this patch removes it so that new code does not include it. All archs define set_wmb(var, value) to do { var = value; wmb(); } while(0) except ia64 and sparc which use a mb() instead. But this is still moot since it is not used anyway. Hasn't been tested on any archs but x86 and x86_64 (and only compiled tested) Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] fix alpha breakageIvan Kokshaysky
barrier.h uses barrier() in non-SMP case. And doesn't include compiler.h. Cc: Al Viro <viro@ftp.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-25[PATCH] alpha: atomic dependency fixAndrew Morton
My alpha build is exploding because asm/atomic.h now needs smb_mb(), which is over in the (not included) system.h. I fear what will happen if I include system.h into atomic.h, so let's put the barriers into their own header file. Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
