path: root/include/asm-alpha/core_t2.h
2008-08-15alpha: move include/asm-alpha to arch/alpha/include/asmLinus Torvalds
Sam Ravnborg did the build-test that the direct header file move works, I'm just committing it. This is a pure move: mkdir arch/alpha/include git mv include/asm-alpha arch/alpha/include/asm with no other changes. Requested-and-tested-by: Sam Ravnborg <sam@ravnborg.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-20alpha: fix compile failures with gcc-4.3 (bug #10438)Ivan Kokshaysky
Vast majority of these build failures are gcc-4.3 warnings about static functions and objects being referenced from non-static (read: "extern inline") functions, in conjunction with our -Werror. We cannot just convert "extern inline" to "static inline", as people keep suggesting all the time, because "extern inline" logic is crucial for generic kernel build. So - just make sure that all callees of critical "extern inline" functions are also "extern inline"; - use "static inline", wherever it's possible. traps.c: work around gcc-4.3 being too smart about array bounds-checking. TODO: add "gnu_inline" attribute to all our "extern inline" functions to ensure desired behaviour with future compilers. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01ALPHA: correct low-level I/O routines for sable-lynxJay Estabrook
This code corrects the behavior of the t2_readX/t2_writeX routines, and t2_ioreadNN/t2_iowriteNN routines. The value T2_DENSE_MEM is now subtracted from the "xaddr" argument in each of the readX/writeX routines, since those routines may be called directly, rather than always through the ioreadNN/iowriteNN routines. Examples of the direct calls, via the __raw_readX/writeX macros, are the memcpy_fromio/toio, _memset_c_io, and scr_memcpyw routines. Signed-off-by: Jay Estabrook <jay.estabrook@hp.com> Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-27[PATCH] spin/rwlock init cleanupsIngo Molnar
locking init cleanups: - convert " = SPIN_LOCK_UNLOCKED" to spin_lock_init() or DEFINE_SPINLOCK() - convert rwlocks in a similar manner this patch was generated automatically. Motivation: - cleanliness - lockdep needs control of lock initialization, which the open-coded variants do not give - it's also useful for -rt and for lock debugging in general Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
