path: root/include/asm-alpha/mmu_context.h
2008-08-15alpha: move include/asm-alpha to arch/alpha/include/asmLinus Torvalds
Sam Ravnborg did the build-test that the direct header file move works, I'm just committing it. This is a pure move: mkdir arch/alpha/include git mv include/asm-alpha arch/alpha/include/asm with no other changes. Requested-and-tested-by: Sam Ravnborg <sam@ravnborg.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-20alpha: fix compile failures with gcc-4.3 (bug #10438)Ivan Kokshaysky
Vast majority of these build failures are gcc-4.3 warnings about static functions and objects being referenced from non-static (read: "extern inline") functions, in conjunction with our -Werror. We cannot just convert "extern inline" to "static inline", as people keep suggesting all the time, because "extern inline" logic is crucial for generic kernel build. So - just make sure that all callees of critical "extern inline" functions are also "extern inline"; - use "static inline", wherever it's possible. traps.c: work around gcc-4.3 being too smart about array bounds-checking. TODO: add "gnu_inline" attribute to all our "extern inline" functions to ensure desired behaviour with future compilers. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15alpha: fix hard_smp_processor_id compile errorSimon Horman
"Remove hardcoding of hard_smp_processor_id on UP systems", 2f4dfe206a2fc07099dfad77a8ea2f4b4ae2140f in Linus' tree, moved the definition of hard_smp_processor_id linux/smp.h to asm/smp.h for UP systems. This causes a regression on Alpha. cc1: warnings being treated as errors arch/alpha/kernel/setup.c: In function 'setup_arch': arch/alpha/kernel/setup.c:506: warning: implicit declaration of function 'hard_smp_processor_id' make[1]: *** [arch/alpha/kernel/setup.o] error 1 make: *** [arch/alpha/kernel] error 2 By including asm/smp.h non-conditionally in asm/mmu_context.h the problem appears to be resolved. Cc: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Simon Horman <horms@verge.net.au> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] x86: PARAVIRT: add hooks to intercept mm creation and destructionJeremy Fitzhardinge
Add hooks to allow a paravirt implementation to track the lifetime of an mm. Paravirtualization requires three hooks, but only two are needed in common code. They are: arch_dup_mmap, which is called when a new mmap is created at fork arch_exit_mmap, which is called when the last process reference to an mm is dropped, which typically happens on exit and exec. The third hook is activate_mm, which is called from the arch-specific activate_mm() macro/function, and so doesn't need stub versions for other architectures. It's called when an mm is first used. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: linux-arch@vger.kernel.org Cc: James Bottomley <James.Bottomley@SteelEye.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-23[PATCH] more for_each_cpu() conversionsAndrew Morton
When we stop allocating percpu memory for not-possible CPUs we must not touch the percpu data for not-possible CPUs at all. The correct way of doing this is to test cpu_possible() or to use for_each_cpu(). This patch is a kernel-wide sweep of all instances of NR_CPUS. I found very few instances of this bug, if any. But the patch converts lots of open-coded test to use the preferred helper macros. Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Cc: Christian Zankel <chris@zankel.net> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: Nathan Scott <nathans@sgi.com> Cc: Jens Axboe <axboe@suse.de> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] alpha: task_thread_info()Al Viro
use task_thread_info() for accesses to thread_info of task in arch/alpha and include/asm-alpha Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
