path: root/include/asm-alpha/system.h
2006-02-07[PATCH] __cmpxchg() must really always be inlined on alphaSteve Langasek
With the latest 2.6.15 kernel builds for alpha on Debian, we ran into a problem with undefined references to __cmpxchg_called_with_bad_pointer() in a couple of kernel modules (xfs.ko and drm.ko; see http://bugs.debian.org/347556). It looks like people have been trying to out-clever each other wrt the definition of "inline" on this architecture :), with the result that __cmpxchg(), which must be inlined so the compiler can see its argument is const, is not guaranteed to be inlined. Indeed, it was not being inlined when building with -Os. The attached patch fixes the issue by adding an __attribute__((always_inline)) explicitly to the definition of __cmpxchg() instead of relying on redefines of "inline" elsewhere to make this happen. Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] alpha: task_thread_info()Al Viro
use task_thread_info() for accesses to thread_info of task in arch/alpha and include/asm-alpha Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] sched: add cacheflush() asmIngo Molnar
Add per-arch sched_cacheflush() which is a write-back cacheflush used by the migration-cost calibration code at bootup time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-25[PATCH] alpha: atomic dependency fixAndrew Morton
My alpha build is exploding because asm/atomic.h now needs smb_mb(), which is over in the (not included) system.h. I fear what will happen if I include system.h into atomic.h, so let's put the barriers into their own header file. Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] alpha xchg fixAl Viro
alpha xchg has to be a macro - alpha disables always_inline and if that puppy does not get inlined, we immediately blow up on undefined reference. Happens even on gcc3; with gcc4 that happens a _lot_. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
