Sam Ravnborg did the build-test that the direct header file move works,
I'm just committing it.
This is a pure move:
mkdir arch/alpha/include
git mv include/asm-alpha arch/alpha/include/asm
with no other changes.
Requested-and-tested-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Vast majority of these build failures are gcc-4.3 warnings
about static functions and objects being referenced from
non-static (read: "extern inline") functions, in conjunction
with our -Werror.
We cannot just convert "extern inline" to "static inline",
as people keep suggesting all the time, because "extern inline"
logic is crucial for generic kernel build.
So
- just make sure that all callees of critical "extern inline"
functions are also "extern inline";
- use "static inline", wherever it's possible.
traps.c: work around gcc-4.3 being too smart about array
bounds-checking.
TODO: add "gnu_inline" attribute to all our "extern inline"
functions to ensure desired behaviour with future compilers.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
This code replaces earlier and incomplete handling of graphics on non-zero PCI
domains (aka hoses or peer PCI buses).
An option (CONFIG_VGA_HOSE) is set TRUE if configuring a GENERIC kernel, or a
kernel for MARVEL, TITAN, or TSUNAMI machines, as these are the machines whose
SRM consoles are capable of configuring and handling graphics options on
non-zero hoses. All other machines have the option set FALSE.
A routine, "find_console_vga_hose()", is used to find the graphics device
which the machine's firmware believes is the console device, and it sets a
global (pci_vga_hose) for later use in managing access to the device. This is
called in "init_arch" on TITAN and TSUNAMI machines; MARVEL machines use a
custom version of this routine because of extra complexity.
A routine, "locate_and_init_vga()", is used to find the graphics device and
set a global (pci_vga_hose) for later use in managing access to the device, in
the case where "find_console_vga_hose" has failed.
Various adjustments are made to the ioremap and ioportmap routines for
detecting and translating "legacy" VGA register and memory references to the
real PCI domain.
[akpm@linux-foundation.org: don't statically init bss]
[akpm@linux-foundation.org: build fix]
Signed-off-by: Jay Estabrook <jay.estabrook@hp.com>
VGA_MAP_MEM translates to ioremap() on some architectures. It makes sense
to do this to vga_vram_base, because we're going to access memory between
vga_vram_base and vga_vram_end.
But it doesn't really make sense to map starting at vga_vram_end, because
we aren't going to access memory starting there. On ia64, which always has
to be different, ioremapping vga_vram_end gives you something completely
incompatible with ioremapped vga_vram_start, so vga_vram_size ends up being
nonsense.
As a bonus, we often know the size up front, so we can use ioremap()
correctly, rather than giving it a zero size.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cc: "Luck, Tony" <tony.luck@intel.com>
infrastructure for it.
Let it rip!
