path: root/include/asm-arm/arch-omap/board.h
2007-09-20ARM: OMAP: abstract debug card setup (smc, leds)David Brownell
Additional cleanup for debug boards on H2/P2/H3/H4: move the init code that's not board-specific into a new file where it can be easily shared between all the different boards (avoiding code duplication, and making it easier to support more devices). Make H4 use that. This should be easy to drop in to the OMAP1 boards using these debug cards; the only difference seems to be that the p2 does an extra reset of the smc using the fpga (probably all boards could do that, if it's necessary) and doesn't use the gpio mux or request APIs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-05-09Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (28 commits) ARM: OMAP: Fix GCC-reported compile time bug ARM: OMAP: restore CONFIG_GENERIC_TIME ARM: OMAP: partial LED fixes ARM: OMAP: add SoSSI clock (call propagate_rate for childrens) ARM: OMAP: FB sync with N800 tree (support for dynamic SRAM allocations) ARM: OMAP: Sync framebuffer headers with N800 tree ARM: OMAP: Mostly cosmetic to sync up with linux-omap tree ARM: OMAP: Fix gpmc header ARM: OMAP: Add mailbox support for IVA [ARM] armv7: add Makefile and Kconfig entries [ARM] armv7: add support for asid-tagged VIVT I-cache [ARM] armv7: add dedicated ARMv7 barrier instructions [ARM] armv7: Add ARMv7 cacheid macros [ARM] armv7: add support for ARMv7 cores. [ARM] Fix ARM branch relocation range [ARM] 4363/1: AT91: Remove legacy PIO definitions [ARM] 4361/1: AT91: Build error ARM: OMAP: Sync core code with linux-omap ARM: OMAP: Sync headers with linux-omap ARM: OMAP: h4 must have blinky leds!! ...
2007-05-09include files: convert "include" subdirectory to UTF-8John Anthony Kazos Jr
Convert the "include" subdirectory to UTF-8. Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08ARM: OMAP: Sync headers with linux-omapTony Lindgren
This patch syncs omap specific headers with linux-omap. Most of the changes needed because of bitrot caused by driver changes in linux-omap tree. Integrating this is needed for adding support for various omap drivers. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-26ARM: OMAP: Add OMAP_TAG_CAMERA_SENSORSamuel Ortiz
Add platform config data for camera sensors. Since it includes pointers, it should not be passed from the bootloader. Signed-off-by: Samuel Ortiz <samuel.ortiz@solidboot.com> Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-02[ARM] 3433/1: ARM: OMAP: 8/8 Update board filesTony Lindgren
Patch from Tony Lindgren This patch syncs OMAP board support with linux-omap tree. The highlights of the patch are: - Add support for Nokia 770 by Juha Yrjola - Add support for Samsung Apollon by Kyungmin Park - Add support for Amstrad E3 videophone by Jonathan McDowell - Remove board-netstar.c board support as requested by Ladislav Michl - Do platform_device registration in board files by Komal Shah et al. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-07[ARM] 2888/1: OMAP 3/4: Update omap include files, take 2Tony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. The highlights of the patch are: - Start adding 24xx support by Paul Mundt - Clean-up of cpu detection by Dirk Behme and Tony Lindgren - Add DSP header by Toshihiro Kobayashi - Add support for mtd-xip by Vladimir Barinov - Add various new mux registers - Move OMAP specific serial defines back to serial.h Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-10[PATCH] ARM: 2797/1: OMAP update 1/11: Update include filesTony Lindgren
Patch from Tony Lindgren This patch by various OMAP developers syncs the OMAP specific include files with the linux-omap tree. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
