path: root/include/asm-arm/arch-omap/entry-macro.S
2008-05-23[ARM] fix OMAP include loopsRussell King
OMAP has two include loops in its header files: asm-arm/hardware.h <- asm-arm/arch-omap/io.h <- asm-arm/arch-omap/hardware.h <- asm-arm/hardware.h asm-arm/arch-omap/board-palmte.h <- asm-arm/arch-omap/hardware.h <- asm-arm/hardware.h <- asm-arm/arch-omap/gpio.h <- asm-arm/arch-omap/board-palmte.h Circular include dependencies are dangerous since they can result in inconsistent definitions being provided to other code, especially if '#ifndef' constructs are used. Solve these by removing the offending includes, and add additional includes where necessary. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-14ARM: OMAP2: Change 24xx to use new register accessPaul Walmsley
This patch changes 24xx to use new register access, except for clock framework. Clock framework register access will get updates in the next patch. Note that board-*.c files change GPMC (General Purpose Memory Controller) access to use gpmc_cs_write_reg() instead of accessing the registers directly. The code also uses gpmc_fck instead of it's parent clock core_l3_ck for GPMC clock. The H4 board file also adds h4_init_flash() function, which specify the flash start and end addresses. Also note that sleep.S removes some unused registers addresses. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-03-02ARM: OMAP: Add missing get_irqnr_preamble and arch_ret_to_user for omap2Tony Lindgren
Only entries for omap1 were added earlier. Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-02-17[ARM] 4185/2: entry: introduce get_irqnr_preamble and arch_ret_to_userDan Williams
get_irqnr_preamble allows machines to take some action before entering the get_irqnr_and_base loop. On iop we enable cp6 access. arch_ret_to_user is added to the userspace return path to allow individual architectures to take actions, like disabling coprocessor access, before the final return to userspace. Per Nicolas Pitre's note, there is no need to cp_wait on the return to user as the latency to return is sufficient. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-03[ARM] Cleanup ARM includesRussell King
arch/arm/kernel/entry-armv.S has contained a comment suggesting that asm/hardware.h and asm/arch/irqs.h should be moved into the asm/arch/entry-macro.S include. So move the includes to these two files as required. Add missing includes (asm/hardware.h, asm/io.h) to asm/arch/system.h includes which use those facilities, and remove asm/io.h from kernel/process.c. Remove other unnecessary includes from arch/arm/kernel, arch/arm/mm and arch/arm/mach-footbridge. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3143/1: OMAP 4/5: Update omap include filesTony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. This patch contains changes to common header files for omap1xxx and omap24xx by various omap developers, and improved cpu detection by Imre Deak Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-07[ARM] 2888/1: OMAP 3/4: Update omap include files, take 2Tony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. The highlights of the patch are: - Start adding 24xx support by Paul Mundt - Clean-up of cpu detection by Dirk Behme and Tony Lindgren - Add DSP header by Toshihiro Kobayashi - Add support for mtd-xip by Vladimir Barinov - Add various new mux registers - Move OMAP specific serial defines back to serial.h Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
