path: root/include/asm-arm/arch-omap/gpio.h
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-23[ARM] fix OMAP include loopsRussell King
OMAP has two include loops in its header files: asm-arm/hardware.h <- asm-arm/arch-omap/io.h <- asm-arm/arch-omap/hardware.h <- asm-arm/hardware.h asm-arm/arch-omap/board-palmte.h <- asm-arm/arch-omap/hardware.h <- asm-arm/hardware.h <- asm-arm/arch-omap/gpio.h <- asm-arm/arch-omap/board-palmte.h Circular include dependencies are dangerous since they can result in inconsistent definitions being provided to other code, especially if '#ifndef' constructs are used. Solve these by removing the offending includes, and add additional includes where necessary. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-14ARM: OMAP: Use gpiolibDavid Brownell
Update OMAP to use the new GPIO implementation framework. This is just a quick'n'dirty update ... more code could now be removed, ideally as part of cleaning up the entire OMAP GPIO infrastructure ... Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-02-08ARM: OMAP: Add 24xx GPIO debounce supportKevin Hilman
Add 24xx GPIO debounce support. Also minor formatting clean-up. Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-02-08ARM: OMAP: Add 3430 gpio supportSyed Mohammed, Khasim
This patch adds 3430 gpio support. It also contains a fix by Paul Walmsley <paul@pwsan.com> to use the correct clock names for OMAP3430. Signed-off-by: Syed Mohammed Khasim <x0khasim@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-05-09include files: convert "include" subdirectory to UTF-8John Anthony Kazos Jr
Convert the "include" subdirectory to UTF-8. Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-16[PATCH] gpio_direction_output() needs an initial valueDavid Brownell
It's been pointed out that output GPIOs should have an initial value, to avoid signal glitching ... among other things, it can be some time before a driver is ready. This patch corrects that oversight, fixing - documentation - platforms supporting the GPIO interface - users of that call (just one for now, others are pending) There's only one user of this call for now since most platforms are still using non-generic GPIO setup code, which in most cases already couples the initial value with its "set output mode" request. Note that most platforms are clear about the hardware letting the output value be set before the pin direction is changed, but the s3c241x docs are vague on that topic ... so those chips might not avoid the glitches. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Andrew Victor <andrew@sanpeople.com> Acked-by: Milan Svoboda <msvoboda@ra.rockwell.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] OMAP GPIO wrappersDavid Brownell
This teaches OMAP how to implement the cross-platform GPIO interfaces. [akpm@osdl.org: cleanups] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-11-16[ARM] Include asm/hardware.h instead of asm/arch/hardware.hRussell King
Rationalise hardware.h include. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3143/1: OMAP 4/5: Update omap include filesTony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. This patch contains changes to common header files for omap1xxx and omap24xx by various omap developers, and improved cpu detection by Imre Deak Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-07[ARM] 2888/1: OMAP 3/4: Update omap include files, take 2Tony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. The highlights of the patch are: - Start adding 24xx support by Paul Mundt - Clean-up of cpu detection by Dirk Behme and Tony Lindgren - Add DSP header by Toshihiro Kobayashi - Add support for mtd-xip by Vladimir Barinov - Add various new mux registers - Move OMAP specific serial defines back to serial.h Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
