path: root/include/asm-arm/arch-omap/io.h
2008-04-14ARM: OMAP2: Change 24xx to use new register accessPaul Walmsley
This patch changes 24xx to use new register access, except for clock framework. Clock framework register access will get updates in the next patch. Note that board-*.c files change GPMC (General Purpose Memory Controller) access to use gpmc_cs_write_reg() instead of accessing the registers directly. The code also uses gpmc_fck instead of it's parent clock core_l3_ck for GPMC clock. The H4 board file also adds h4_init_flash() function, which specify the flash start and end addresses. Also note that sleep.S removes some unused registers addresses. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-09-20ARM: OMAP: Add minimal OMAP2430 supportSyed Mohammed Khasim
This patch adds minimal OMAP2430 support to get the kernel booting on 2430SDP. Signed-off-by: Syed Mohammed Khasim <x0khasim@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-05-08ARM: OMAP: Sync headers with linux-omapTony Lindgren
This patch syncs omap specific headers with linux-omap. Most of the changes needed because of bitrot caused by driver changes in linux-omap tree. Integrating this is needed for adding support for various omap drivers. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-24[ARM] 3631/1: Remove legacy __mem_isa() definitionsAndrew Victor
Patch from Andrew Victor Remove the remaining legacy __mem_isa() definitions for the ARM platforms. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-08[ARM] 3279/1: OMAP: 1/3 Fix low-level io initTony Lindgren
Patch from Tony Lindgren This patch adds the missing cache flushes to common low-level init that are needed to access the IO region. These flushes are normally done at the end of devicemaps_init(), but we need to detect the OMAP core type early. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3143/1: OMAP 4/5: Update omap include filesTony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. This patch contains changes to common header files for omap1xxx and omap24xx by various omap developers, and improved cpu detection by Imre Deak Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-28[ARM] 1/4: Move include of asm/hardware.h to asm-arm/arch-*/io.hRussell King
Including asm/hardware.h into asm/io.h can cause #define clashes between platform specific definitions and driver local definitions. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-07[ARM] 2888/1: OMAP 3/4: Update omap include files, take 2Tony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. The highlights of the patch are: - Start adding 24xx support by Paul Mundt - Clean-up of cpu detection by Dirk Behme and Tony Lindgren - Add DSP header by Toshihiro Kobayashi - Add support for mtd-xip by Vladimir Barinov - Add various new mux registers - Move OMAP specific serial defines back to serial.h Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
